    3. Entwicklung
    4. Adapter: broadlink2
    Adapter: broadlink2
      Sven79 last edited by Sven79
      % ./broadlink_cli --type 0x5f36 --host 10.0.1.92 --mac 24dfa7d60b09 --temp
      Traceback (most recent call last):
        File "./broadlink_cli", line 116, in <module>
          print(dev.check_temperature())
        File "/usr/local/lib/python3.7/site-packages/broadlink/__init__.py", line 673, in check_temperature
          return self._read_sensor( 0x24, 4, 100.0 )
        File "/usr/local/lib/python3.7/site-packages/broadlink/__init__.py", line 653, in _read_sensor
          check_error(response[0x22:0x24])
        File "/usr/local/lib/python3.7/site-packages/broadlink/exceptions.py", line 97, in check_error
          raise exception(error_code)
      broadlink.exceptions.StorageError: The device storage is full
        swagner @frankjoke last edited by
        @frankjoke ich habe jetzt die letzte Version von Github installiert mit dem Debug settings bekomme ich folgendes in log angezeigt, mit not reachable.
        broadlink2.0	2020-06-28 21:59:10.102	info	(5159) discover [ '192.168.1.151' ] from 0.0.0.0:48439
        broadlink2.0	2020-06-28 21:59:10.100	info	(5159) debug: UDP listening on 0.0.0.0:48439
        broadlink2.0	2020-06-28 21:59:10.099	info	(5159) debug: should discover/search [ { address: '192.168.1.151', port: 80, devtype: 24374, oname: '智能遥控', cloud: 0, maco: <Buffer ac 41 50 a7 df 24>, mac: '24:df:a7:50:41:ac', type: 'rm4', name: 'RM
        broadlink2.0	2020-06-28 21:59:10.097	info	(5159) debug: device RM:0x5f36_24:df:a7:50:41:ac not reachable, waiting for it again { here: false }
        broadlink2.0	2020-06-28 21:59:10.096	info	(5159) Unrecoverable Send packet error { cmd: 0,command: 238,err: 65531,response:<Buffer 5a a5 aa 55 5a a5 aa 55 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9d d2 fb ff 36
        broadlink2.0	2020-06-28 21:59:10.094	info	(5159) debug: send Error on device RM4, RM:0x5f36_24:df:a7:50:41:ac, 24:df:a7:50:41:ac, 192.168.1.151, 智能遥控: { cmd: 0, command: 238, err: 65531, response: <Buffer 5a a5 aa 55 5a a5 aa 55 00 00 00 00 0
        broadlink2.0	2020-06-28 21:58:40.079	info	(5159) found macs: 24:df:a7:50:41:ac
        broadlink2.0	2020-06-28 21:58:40.079	info	(5159) broadlink2.0 started and found 1 devices named RM:0x5f36_24:df:a7:50:41:ac
        broadlink2.0	2020-06-28 21:58:40.078	info	(5159) Poll every 30 secods.
        broadlink2.0	2020-06-28 21:58:40.077	info	(5159) debug: ChangeState ack:true of broadlink2.0._SendScene =
        broadlink2.0	2020-06-28 21:58:40.067	info	(5159) debug: created State broadlink2.0._SendScene
        broadlink2.0	2020-06-28 21:58:37.845	info	(5159) discover [ '192.168.1.151' ] from 0.0.0.0:57242
        broadlink2.0	2020-06-28 21:58:37.842	info	(5159) debug: UDP listening on 0.0.0.0:57242
        broadlink2.0	2020-06-28 21:58:37.838	info	(5159) debug: should discover/search [ { address: '192.168.1.151', port: 80, devtype: 24374, oname: '智能遥控', cloud: 0, maco: <Buffer ac 41 50 a7 df 24>, mac: '24:df:a7:50:41:ac', type: 'rm4', name: 'RM
        broadlink2.0	2020-06-28 21:58:37.835	info	(5159) debug: device RM:0x5f36_24:df:a7:50:41:ac not reachable, waiting for it again { here: false }
        broadlink2.0	2020-06-28 21:58:37.834	info	(5159) debug: Device RM:0x5f36_24:df:a7:50:41:ac returned { here: false }
        broadlink2.0	2020-06-28 21:58:37.831	info	(5159) Unrecoverable Send packet error { cmd: 0,command: 238,err: 65531,response:<Buffer 5a a5 aa 55 5a a5 aa 55 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9c d2 fb ff 36
        broadlink2.0	2020-06-28 21:58:37.828	info	(5159) debug: send Error on device RM4, RM:0x5f36_24:df:a7:50:41:ac, 24:df:a7:50:41:ac, 192.168.1.151, 智能遥控: { cmd: 0, command: 238, err: 65531, response: <Buffer 5a a5 aa 55 5a a5 aa 55 00 00 00 00 0
        broadlink2.0	2020-06-28 21:58:37.786	info	(5159) debug: ChangeState ack:true of _NewDeviceScan = false
        broadlink2.0	2020-06-28 21:58:31.792	info	(5159) debug: ChangeState ack:true of broadlink2.0.RM:0x5f36_24:df:a7:50:41:ac._notReachable = false
        broadlink2.0	2020-06-28 21:58:31.782	info	(5159) debug: created State broadlink2.0.RM:0x5f36_24:df:a7:50:41:ac._notReachable
        broadlink2.0	2020-06-28 21:58:31.763	info	(5159) Device RM:0x5f36_24:df:a7:50:41:ac dedected: address=192.168.1.151, mac=24:df:a7:50:41:ac, typ=rm4, id=0x5f36 devtype=rm4
        broadlink2.0	2020-06-28 21:58:31.654	info	(5159) debug: UDP listening on 0.0.0.0:34892
        broadlink2.0	2020-06-28 21:58:31.541	info	(5159) discover [ '192.168.1.255', '255.255.255.255', '224.0.0.251' ] from 0.0.0.0:40066
        broadlink2.0	2020-06-28 21:58:31.538	info	(5159) debug: UDP listening on 0.0.0.0:40066
        broadlink2.0	2020-06-28 21:58:31.534	info	(5159) debug: ChangeState ack:true of broadlink2.0._NewDeviceScan = true
        broadlink2.0	2020-06-28 21:58:31.518	info	(5159) debug: created State broadlink2.0._NewDeviceScan
        broadlink2.0	2020-06-28 21:58:31.483	info	(5159) debug: UDP listening on 0.0.0.0:15001
        broadlink2.0	2020-06-28 21:58:31.447	info	(5159) Discover Broadlink devices for 10sec on broadlink2.0
        broadlink2.0	2020-06-28 21:58:31.437	info	(5159) debug: Config IP-Address end to remove: .fritz.box
        broadlink2.0	2020-06-28 21:58:31.435	info	(5159) macObjects: []
        broadlink2.0	2020-06-28 21:58:31.432	info	(5159) interface to be used: { netmaskBits: 24, address: '192.168.1.30/24', addrs: [ 192, 168, 1, 30 ], cidr: '192.168.1.30/24', bcaddr: '192.168.1.255' }:
        broadlink2.0	2020-06-28 21:58:31.419	info	(5159) broadlink2 has 0 old devices!
        broadlink2.0	2020-06-28 21:58:31.417	info	(5159) Devices to rename:
        broadlink2.0	2020-06-28 21:58:31.415	info	(5159) Devices to add: 0x5f36=RM4
        broadlink2.0	2020-06-28 21:58:31.413	info	(5159) Scanning additional IP's:
        broadlink2.0	2020-06-28 21:58:31.399	info	(5159) broadlink2 initialization started...
        broadlink2.0	2020-06-28 21:58:31.258	info	(5159) starting. Version 2.1.3 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.19.0, js-controller: 3.1.6
        host.ioBroker-RasPi	2020-06-28 21:58:28.293	info	instance system.adapter.broadlink2.0 started with pid 5159
        frankjoke 1 Reply Last reply Reply Quote 0
          @frankjoke hilft dir das vielleicht weiter? Ich habe es direkt über Python versucht:
          Python 3.7.4 (default, Oct 12 2019, 18:55:28)
          [Clang 11.0.0 (clang-1100.0.33.8)] on darwin
          Type "help", "copyright", "credits" or "license" for more information.
          >>> import broadlink
          >>> devices = broadlink.discover(timeout=5)
          >>> devices[0].auth()
          True
          >>> devices[0].check_data()
            File "<stdin>", line 1, in <module>
            File "/usr/local/lib/python3.7/site-packages/broadlink/__init__.py", line 600, in check_data
          >>> pprint(devices[0], indent=2)
          <broadlink.rm4 object at 0x110454890>
          >>> pprint(vars(devices[0]))
          {'_code_sending_header': b'\xd0\x00',
           '_request_header': b'\x04\x00',
           'aes': <cryptography.hazmat.primitives.ciphers.base.Cipher object at 0x110454c50>,
           'cloud': False,
           'count': 41593,
           'devtype': 24374,
           'host': ('10.0.1.92', 80),
           'id': b'\x01\x00\x00\x00',
           'iv': bytearray(b'V.\x17\x99m\t=(\xdd\xb3\xbaiZ.oX'),
           'lock': <unlocked _thread.lock object at 0x10fdd4b10>,
           'mac': bytearray(b'\t\x0b\xd6\xa7\xdf$'),
           'name': '智能遥控',
           'timeout': 10,
           'type': 'RM4'}
          >>> pprint(dir(devices[0]))
          ['__class__',
           '__delattr__',
           '__dict__',
           '__dir__',
           '__doc__',
           '__eq__',
           '__format__',
           '__ge__',
           '__getattribute__',
           '__gt__',
           '__hash__',
           '__init__',
           '__init_subclass__',
           '__le__',
           '__lt__',
           '__module__',
           '__ne__',
           '__new__',
           '__reduce__',
           '__reduce_ex__',
           '__repr__',
           '__setattr__',
           '__sizeof__',
           '__str__',
           '__subclasshook__',
           '__weakref__',
           '_code_sending_header',
           '_read_sensor',
           '_request_header',
           'aes',
           'auth',
           'cancel_sweep_frequency',
           'check_data',
           'check_frequency',
           'check_humidity',
           'check_sensors',
           'check_temperature',
           'cloud',
           'count',
           'decrypt',
           'devtype',
           'encrypt',
           'enter_learning',
           'find_rf_packet',
           'get_type',
           'host',
           'id',
           'iv',
           'lock',
           'mac',
           'name',
           'send_data',
           'send_packet',
           'sweep_frequency',
           'timeout',
           'type',
           'update_aes']
          • frankjoke
            frankjoke @swagner last edited by
            @swagner
            @Sven79
            Danke für den Python.Test Sven! Also bekommt auch der Python-Treiber den selben Fehler!
            Laut log von swagner ist meldet das Gerät bei jedem Befehl einen Fehler (auch wenn ich den Speicherfehler ausblende)!
            Ich weiß nicht was ich da machen soll, vielleicht hat das Ding einfach nur den Cloud-treiber drin und ist nicht mit dem 'alten' Protokoll kompatibel!
            M S 2 Replies Last reply Reply Quote 0
              muckel @frankjoke last edited by
              @frankjoke
              @Sven79
              Ich hatte auch mal das Problem, dass er sich aus der Cloud-App nicht mehr in die e-control anmelden lies.
              Meine Lösung beim RM4 war:
              Reset RM4 > mit Cloud-App wieder ins Netzwerk bringen (Step 1) und gleich danach die Cloud-App abschießen.
              Somit war mein RM4 im Netzwerk, aber nicht in der Cloud.
              Probieren geht über studieren. Vielleicht hilft es.
              • Christoph1337
                Christoph1337 @frankjoke last edited by
                @frankjoke
                ooohh! Mega genial! Dank dir!
                So hast du dir das gedacht, oder?
                • frankjoke
                  frankjoke @Christoph1337 last edited by
                  @Christoph1337
                  Im Prinzip ja, aber ins off-Feld musst du noch -16 (in deinem Fall) schreiben!
                    @frankjoke ich habe mir jetzt den RM4C bestellt. Meine Empfehlung wäre eine Liste zu erstellen mit.
                    Type, ID, S/N, Status
                    RM3 MINI, 0x5f36, S/N RM61, funktioniert nicht
                    Mfg
                    Stefan
                    • frankjoke
                      frankjoke @muckel last edited by
                      @muckel
                      Danke für die Info, vielleicht können es die betroffenen ja mal testen!
                      Ich denke das Problem mein RM3 Mini neu ist jedoch dass er mit e-control ins netzt geholt werden kann aber dann einen storage Fehler bei jedem Befehl bringt! Das einzige was funktioniert scheint das Auth zu sein (sonst würde er einen Auth- oder Key-Fehler melden).
                      • frankjoke
                        @swagner
                        Habe das gemacht, in meinem ersten Post, den ich immer wieder update habe ich eine solche Problemliste angefangen.
                        https://forum.iobroker.net/topic/6881/adapter-broadlink2
                        p.s.: Ich habe die Einstellungen so dass ich im menü unter dem post bei Sortieren nach: Neueste zuerst eingestellt habe, damit kommt immer der letzt post nach meinem 1. post und ich brauch nicht scrollen um die letzten posts zu sehen!
                        • No Name
                          No Name last edited by Negalein
                          Please add Broadlink Bestcon MCB1
                          It is working only with app https://play.google.com/store/apps/details?id=cn.com.broadlink.econtrol.international
                          It is new device.
                          Mac adress Broadlink Bestcon MCB1 c8:f7:42:75:d3:ed
                          Log:
                          2020-06-30 10:33:36.098 - info: broadlink2.0 (12670) starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.21.0, js-controller: 3.1.5
                          2020-06-30 10:33:36.759 - info: broadlink2.0 (12670) debug: broadlink2 received 45 objects and 45 states, with config ip,scenes,switches,poll,new,rename,additional,lang,latitude,longitude,adapterConf,loglevel
                          2020-06-30 10:33:36.766 - info: broadlink2.0 (12670) broadlink2 initialization started...
                          2020-06-30 10:33:36.788 - info: broadlink2.0 (12670) Scanning additional IP's: 192.168.1.199
                          2020-06-30 10:33:36.791 - info: broadlink2.0 (12670) Devices to add:
                          2020-06-30 10:33:36.794 - info: broadlink2.0 (12670) Devices to rename: SP:0x7547_78:0f:77:17:8d:49=bathroom
                          2020-06-30 10:33:36.801 - info: broadlink2.0 (12670) broadlink2 has 6 old devices!
                          2020-06-30 10:33:36.832 - info: broadlink2.0 (12670) interface to be used: { netmaskBits: 24, address: '192.168.1.7/24', addrs: [ 192, 168, 1, 7 ], cidr: '192.168.1.7/24', bcaddr: '192.168.1.255' }:
                          2020-06-30 10:33:36.841 - info: broadlink2.0 (12670) interface to be used: { netmaskBits: 23, address: '10.121.82.11/23', addrs: [ 10, 121, 82, 11 ], cidr: '10.121.82.11/23', bcaddr: '10.121.83.255' }:
                          2020-06-30 10:33:36.850 - info: broadlink2.0 (12670) macObjects: [ '34:ea:34:50:d0:15', '34:ea:34:bd:a7:ec', '34:ea:34:bd:bc:da', '78:0f:77:01:b2:f0', '78:0f:77:17:8d:49', '78:0f:77:17:a3:69' ]
                          2020-06-30 10:33:36.853 - info: broadlink2.0 (12670) debug: Config IP-Address end to remove: .fritz.box
                          2020-06-30 10:33:36.951 - info: broadlink2.0 (12670) debug: created State broadlink2.0.Scenes.Fernsehen
                          2020-06-30 10:33:37.025 - info: broadlink2.0 (12670) debug: ChangeState ack:false of broadlink2.0.Scenes.Fernsehen = false
                          2020-06-30 10:33:37.071 - info: broadlink2.0 (12670) Discover Broadlink devices for 10sec on broadlink2.0
                          2020-06-30 10:33:37.106 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:15001
                          2020-06-30 10:33:37.160 - info: broadlink2.0 (12670) debug: created State broadlink2.0._NewDeviceScan
                          2020-06-30 10:33:37.245 - info: broadlink2.0 (12670) debug: ChangeState ack:true of broadlink2.0._NewDeviceScan = true
                          2020-06-30 10:33:37.261 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:44249
                          2020-06-30 10:33:37.271 - info: broadlink2.0 (12670) discover [ '192.168.1.255', '10.121.83.255', '255.255.255.255', '224.0.0.251' ] from 0.0.0.0:44249
                          2020-06-30 10:33:37.461 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:51877
                          2020-06-30 10:33:37.479 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:51637
                          2020-06-30 10:33:37.488 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:47716
                          2020-06-30 10:33:37.498 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:47712
                          2020-06-30 10:33:37.523 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:36622
                          2020-06-30 10:33:37.986 - info: broadlink2.0 (12670) Device bathroom dedected: address=192.168.1.5, mac=78:0f:77:17:8d:49, typ=sp2, id=0x7547 devtype=OEM branded SPMini2, originalName=SP:0x7547_78:0f:77:17:8d:49
                          2020-06-30 10:33:38.045 - info: broadlink2.0 (12670) Device RM:0x2737_c8:f7:42:16:85:ac dedected: address=192.168.1.25, mac=c8:f7:42:16:85:ac, typ=rm, id=0x2737 devtype=RM Mini
                          2020-06-30 10:33:38.052 - info: broadlink2.0 (12670) Device SP:0x7547_34:ea:34:bd:a7:ec dedected: address=192.168.1.23, mac=34:ea:34:bd:a7:ec, typ=sp2, id=0x7547 devtype=OEM branded SPMini2
                          2020-06-30 10:33:38.057 - info: broadlink2.0 (12670) Device SP:0x7547_34:ea:34:bd:bc:da dedected: address=192.168.1.27, mac=34:ea:34:bd:bc:da, typ=sp2, id=0x7547 devtype=OEM branded SPMini2
                          2020-06-30 10:33:38.100 - info: broadlink2.0 (12670) debug: created State broadlink2.0.bathroom._notReachable
                          2020-06-30 10:33:38.159 - info: broadlink2.0 (12670) debug: created State broadlink2.0.RM:0x2737_c8:f7:42:16:85:ac._notReachable
                          2020-06-30 10:33:38.175 - info: broadlink2.0 (12670) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:a7:ec._notReachable
                          2020-06-30 10:33:38.205 - info: broadlink2.0 (12670) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:bc:da._notReachable
                          2020-06-30 10:33:38.284 - info: broadlink2.0 (12670) Device SP:0x753e_34:ea:34:50:d0:15 dedected: address=192.168.1.21, mac=34:ea:34:50:d0:15, typ=sp2, id=0x753e devtype=OEM branded SPMini2
                          2020-06-30 10:33:38.370 - info: broadlink2.0 (12670) debug: created State broadlink2.0.SP:0x753e_34:ea:34:50:d0:15._notReachable
                          2020-06-30 10:33:42.745 - info: broadlink2.0 (12670) debug: Try to discover 192.168.1.199
                          2020-06-30 10:33:42.754 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:52636
                          2020-06-30 10:33:42.759 - info: broadlink2.0 (12670) discover [ '192.168.1.199' ] from 0.0.0.0:52636
                          2020-06-30 10:33:47.023 - info: broadlink2.0 (12670) debug: ChangeState ack:true of _NewDeviceScan = false
                          2020-06-30 10:33:47.081 - info: broadlink2.0 (12670) debug: created State broadlink2.0.States.Steckdose_A
                          2020-06-30 10:33:47.190 - info: broadlink2.0 (12670) debug: created State broadlink2.0.States.Lüfter_A
                          2020-06-30 10:33:47.423 - info: broadlink2.0 (12670) debug: created State broadlink2.0.States.TVWZKanal
                          2020-06-30 10:33:47.558 - warn: broadlink2.0 (12670) device SP:0x753e_78:0f:77:01:b2:f0 not found, please rescan later again or delete it! It was: 192.168.1.24,80,30014,[object Object],78:0f:77:01:b2:f0,sp2,SP:0x753e_78:0f:77:01:b2:f0,0x753e,OEM branded SPMini2,SP:0x753e_78:0f:77:01:b2:f0
                          2020-06-30 10:33:47.563 - warn: broadlink2.0 (12670) device SP:0x7547_78:0f:77:17:a3:69 not found, please rescan later again or delete it! It was: 192.168.1.8,80,30023,[object Object],78:0f:77:17:a3:69,sp2,SP:0x7547_78:0f:77:17:a3:69,0x7547,OEM branded SPMini2,SP:0x7547_78:0f:77:17:a3:69
                          2020-06-30 10:33:47.624 - info: broadlink2.0 (12670) debug: Device bathroom returned { here: true, state: false }
                          2020-06-30 10:33:47.741 - info: broadlink2.0 (12670) debug: created State broadlink2.0.bathroom
                          2020-06-30 10:33:47.808 - info: broadlink2.0 (12670) debug: ChangeState ack:true of broadlink2.0.bathroom = false
                          2020-06-30 10:33:47.957 - info: broadlink2.0 (12670) debug: created State broadlink2.0.bathroom.state
                          2020-06-30 10:33:48.393 - info: broadlink2.0 (12670) debug: Device RM:0x2737_c8:f7:42:16:85:ac returned { here: true, temperature: 0 }
                          2020-06-30 10:33:48.438 - info: broadlink2.0 (12670) debug: created State broadlink2.0.RM:0x2737_c8:f7:42:16:85:ac.Temperature
                          2020-06-30 10:33:48.512 - info: broadlink2.0 (12670) debug: created State broadlink2.0.RM:0x2737_c8:f7:42:16:85:ac
                          2020-06-30 10:33:48.584 - info: broadlink2.0 (12670) debug: created State broadlink2.0.RM:0x2737_c8:f7:42:16:85:ac._Learn
                          2020-06-30 10:33:48.656 - info: broadlink2.0 (12670) debug: created State broadlink2.0.RM:0x2737_c8:f7:42:16:85:ac._SendCode
                          2020-06-30 10:33:48.701 - info: broadlink2.0 (12670) debug: Device SP:0x7547_34:ea:34:bd:a7:ec returned { here: true, state: false }
                          2020-06-30 10:33:48.772 - info: broadlink2.0 (12670) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:a7:ec
                          2020-06-30 10:33:48.885 - info: broadlink2.0 (12670) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:a7:ec.state
                          2020-06-30 10:33:48.933 - info: broadlink2.0 (12670) debug: Device SP:0x7547_34:ea:34:bd:bc:da returned { here: true, state: false }
                          2020-06-30 10:33:49.038 - info: broadlink2.0 (12670) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:bc:da
                          2020-06-30 10:33:49.068 - info: broadlink2.0 (12670) debug: ChangeState ack:true of broadlink2.0.SP:0x7547_34:ea:34:bd:bc:da = false
                          2020-06-30 10:33:49.103 - info: broadlink2.0 (12670) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:bc:da.state
                          2020-06-30 10:33:49.238 - info: broadlink2.0 (12670) debug: Device SP:0x753e_34:ea:34:50:d0:15 returned { here: true, state: false }
                          2020-06-30 10:33:49.284 - info: broadlink2.0 (12670) debug: created State broadlink2.0.SP:0x753e_34:ea:34:50:d0:15
                          2020-06-30 10:33:49.374 - info: broadlink2.0 (12670) debug: ChangeState ack:true of broadlink2.0.SP:0x753e_34:ea:34:50:d0:15 = false
                          2020-06-30 10:33:49.421 - info: broadlink2.0 (12670) debug: created State broadlink2.0.SP:0x753e_34:ea:34:50:d0:15.state
                          2020-06-30 10:33:49.429 - info: broadlink2.0 (12670) debug: should discover/search [ { address: '192.168.1.24', port: 80, devtype: 30014, maco: { type: 'Buffer', data: [Array] }, mac: '78:0f:77:01:b2:f0', type: 'sp2', name: 'SP:0x753e_78:0f:77:01:b2:f0', devhex: '0x753e', devname: 'OEM branded SPMini2', iname: 'SP:0x753e_78:0f:77:01:b2:f0' }, { address: '192.168.1.8', port: 80, devtype: 30023, maco: { type: 'Buffer', data: [Array] }, mac: '78:0f:77:17:a3:69', type: 'sp2', name: 'SP:0x7547_78:0f:77:17:a3:69', devhex: '0x7547', devname: 'OEM branded SPMini2', iname: 'SP:0x7547_78:0f:77:17:a3:69' } ]
                          2020-06-30 10:33:49.435 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:42792
                          2020-06-30 10:33:49.439 - info: broadlink2.0 (12670) discover [ '192.168.1.24' ] from 0.0.0.0:42792
                          2020-06-30 10:33:51.667 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:37634
                          2020-06-30 10:33:51.670 - info: broadlink2.0 (12670) discover [ '192.168.1.8' ] from 0.0.0.0:37634
                          2020-06-30 10:33:54.252 - info: broadlink2.0 (12670) debug: created State broadlink2.0._SendScene
                          2020-06-30 10:33:54.256 - info: broadlink2.0 (12670) Poll every 20 secods.
                          2020-06-30 10:33:54.263 - info: broadlink2.0 (12670) broadlink2.0 started and found 5 devices named bathroom, RM:0x2737_c8:f7:42:16:85:ac, SP:0x7547_34:ea:34:bd:a7:ec, SP:0x7547_34:ea:34:bd:bc:da, SP:0x753e_34:ea:34:50:d0:15
                          2020-06-30 10:33:54.267 - info: broadlink2.0 (12670) 2 were not found: SP:0x753e_78:0f:77:01:b2:f0, SP:0x7547_78:0f:77:17:a3:69
                          2020-06-30 10:33:54.270 - info: broadlink2.0 (12670) found macs: 78:0f:77:17:8d:49, c8:f7:42:16:85:ac, 34:ea:34:bd:a7:ec, 34:ea:34:bd:bc:da, 34:ea:34:50:d0:15
                          2020-06-30 10:34:34.568 - info: broadlink2.0 (12670) debug: should discover/search [ { address: '192.168.1.24', port: 80, devtype: 30014, maco: { type: 'Buffer', data: [Array] }, mac: '78:0f:77:01:b2:f0', type: 'sp2', name: 'SP:0x753e_78:0f:77:01:b2:f0', devhex: '0x753e', devname: 'OEM branded SPMini2', iname: 'SP:0x753e_78:0f:77:01:b2:f0' }, { address: '192.168.1.8', port: 80, devtype: 30023, maco: { type: 'Buffer', data: [Array] }, mac: '78:0f:77:17:a3:69', type: 'sp2', name: 'SP:0x7547_78:0f:77:17:a3:69', devhex: '0x7547', devname: 'OEM branded SPMini2', iname: 'SP:0x7547_78:0f:77:17:a3:69' } ]
                          2020-06-30 10:34:34.582 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:52590
                          2020-06-30 10:34:34.587 - info: broadlink2.0 (12670) discover [ '192.168.1.24' ] from 0.0.0.0:52590
                          2020-06-30 10:34:36.818 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:41145
                          2020-06-30 10:34:36.821 - info: broadlink2.0 (12670) discover [ '192.168.1.8' ] from 0.0.0.0:41145
                          2020-06-30 10:35:49.867 - info: host.server iobroker upload [5] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/words.js words.js application/javascript
                          2020-06-30 10:35:50.247 - info: host.server iobroker Update "system.adapter.broadlink2.0"
                          2020-06-30 10:35:50.256 - info: host.server iobroker Update "system.adapter.broadlink2.1"
                          2020-06-30 10:35:50.320 - info: host.server stopInstance system.adapter.broadlink2.0 (force=false, process=true)
                          2020-06-30 10:35:50.326 - info: host.server stopInstance system.adapter.broadlink2.0 send kill signal
                          2020-06-30 10:35:50.336 - info: broadlink2.0 (12670) Got terminate signal TERMINATE_YOURSELF
                          2020-06-30 10:35:50.350 - info: broadlink2.0 (12670) Adapter disconnected and stopped with dostop(null) and callback(true)
                          2020-06-30 10:35:50.354 - info: broadlink2.0 (12670) terminating
                          2020-06-30 10:35:50.361 - info: broadlink2.0 (12670) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2020-06-30 10:35:50.558 - info: host.server iobroker upload [4] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/style.css style.css text/css
                          2020-06-30 10:35:50.648 - info: host.server iobroker upload [3] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/index_m.html index_m.html text/html
                          2020-06-30 10:35:50.730 - info: host.server iobroker upload [2] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/index.html index.html text/html
                          2020-06-30 10:35:50.826 - info: host.server iobroker upload [1] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/broadlink2.png broadlink2.png image/png
                          2020-06-30 10:35:50.956 - info: host.server instance system.adapter.broadlink2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2020-06-30 10:35:51.002 - info: host.server iobroker upload [0] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/broadlink.png broadlink.png image/png
                          2020-06-30 10:35:51.080 - info: host.server iobroker Adapter "broadlink2" updated
                          2020-06-30 10:35:52.142 - info: host.server iobroker exit 0
                          2020-06-30 10:35:53.834 - info: host.server instance system.adapter.broadlink2.0 started with pid 16215
                          2020-06-30 10:36:00.414 - debug: broadlink2.0 (16215) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2020-06-30 10:36:00.814 - debug: broadlink2.0 (16215) Objects client ready ... initialize now
                          2020-06-30 10:36:00.854 - debug: broadlink2.0 (16215) Objects create System PubSub Client
                          2020-06-30 10:36:00.864 - debug: broadlink2.0 (16215) Objects create User PubSub Client
                          2020-06-30 10:36:00.869 - debug: broadlink2.0 (16215) Objects client initialize lua scripts
                          2020-06-30 10:36:00.994 - debug: broadlink2.0 (16215) Objects connected to redis: 127.0.0.1:9001
                          2020-06-30 10:36:01.068 - debug: broadlink2.0 (16215) objectDB connected
                          2020-06-30 10:36:01.093 - debug: broadlink2.0 (16215) Redis States: Use Redis connection: 127.0.0.1:9000
                          2020-06-30 10:36:01.266 - debug: broadlink2.0 (16215) States create User PubSub Client
                          2020-06-30 10:36:01.364 - debug: broadlink2.0 (16215) States create System PubSub Client
                          2020-06-30 10:36:01.571 - debug: broadlink2.0 (16215) States connected to redis: 127.0.0.1:9000
                          2020-06-30 10:36:01.577 - debug: broadlink2.0 (16215) statesDB connected
                          2020-06-30 10:36:03.490 - info: broadlink2.0 (16215) starting. Version 2.1.3 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.21.0, js-controller: 3.1.5
                          2020-06-30 10:36:04.474 - info: broadlink2.0 (16215) debug: broadlink2 received 45 objects and 45 states, with config ip,scenes,switches,poll,new,rename,additional,lang,latitude,longitude,adapterConf,loglevel
                          2020-06-30 10:36:04.505 - info: broadlink2.0 (16215) broadlink2 initialization started...
                          2020-06-30 10:36:04.557 - info: broadlink2.0 (16215) Scanning additional IP's: 192.168.1.199
                          2020-06-30 10:36:04.564 - info: broadlink2.0 (16215) Devices to add:
                          2020-06-30 10:36:04.575 - info: broadlink2.0 (16215) Devices to rename: SP:0x7547_78:0f:77:17:8d:49=bathroom
                          2020-06-30 10:36:04.586 - info: broadlink2.0 (16215) broadlink2 has 6 old devices!
                          2020-06-30 10:36:04.678 - info: broadlink2.0 (16215) interface to be used: { netmaskBits: 24, address: '192.168.1.7/24', addrs: [ 192, 168, 1, 7 ], cidr: '192.168.1.7/24', bcaddr: '192.168.1.255' }:
                          2020-06-30 10:36:04.683 - info: broadlink2.0 (16215) interface to be used: { netmaskBits: 23, address: '10.121.82.11/23', addrs: [ 10, 121, 82, 11 ], cidr: '10.121.82.11/23', bcaddr: '10.121.83.255' }:
                          2020-06-30 10:36:04.689 - info: broadlink2.0 (16215) macObjects: [ '34:ea:34:50:d0:15', '34:ea:34:bd:a7:ec', '34:ea:34:bd:bc:da', '78:0f:77:01:b2:f0', '78:0f:77:17:8d:49', '78:0f:77:17:a3:69' ]
                          2020-06-30 10:36:04.691 - info: broadlink2.0 (16215) debug: Config IP-Address end to remove: .fritz.box
                          2020-06-30 10:36:04.976 - info: broadlink2.0 (16215) debug: created State broadlink2.0.Scenes.Fernsehen
                          2020-06-30 10:36:05.077 - info: broadlink2.0 (16215) debug: ChangeState ack:false of broadlink2.0.Scenes.Fernsehen = false
                          2020-06-30 10:36:05.136 - info: broadlink2.0 (16215) Discover Broadlink devices for 10sec on broadlink2.0
                          2020-06-30 10:36:05.191 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:15001
                          2020-06-30 10:36:05.249 - info: broadlink2.0 (16215) debug: created State broadlink2.0._NewDeviceScan
                          2020-06-30 10:36:05.317 - info: broadlink2.0 (16215) debug: ChangeState ack:true of broadlink2.0._NewDeviceScan = true
                          2020-06-30 10:36:05.330 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:46514
                          2020-06-30 10:36:05.341 - info: broadlink2.0 (16215) discover [ '192.168.1.255', '10.121.83.255', '255.255.255.255', '224.0.0.251' ] from 0.0.0.0:46514
                          2020-06-30 10:36:05.505 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:49271
                          2020-06-30 10:36:05.517 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:37642
                          2020-06-30 10:36:05.526 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:54922
                          2020-06-30 10:36:05.536 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:32991
                          2020-06-30 10:36:05.554 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:47222
                          2020-06-30 10:36:05.565 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:59820
                          2020-06-30 10:36:05.576 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:58098
                          2020-06-30 10:36:05.685 - info: broadlink2.0 (16215) debug: send Error on device SP2, undefined, c8:f7:42:75:d7:23, 192.168.1.34, 30063: { cmd: NaN, command: 233, cmdHex: '0xe9', payload: , err: 'Authentication failed' }
                          2020-06-30 10:36:05.689 - info: broadlink2.0 (16215) Unrecoverable Send packet error Authentication failed on SP2, undefined, c8:f7:42:75:d7:23, 192.168.1.34, 30063
                          2020-06-30 10:36:05.716 - info: broadlink2.0 (16215) debug: send Error on device SP2, undefined, c8:f7:42:75:d3:ed, 192.168.1.37, 30063: { cmd: NaN, command: 233, cmdHex: '0xe9', payload: , err: 'Authentication failed' }
                          2020-06-30 10:36:05.724 - info: broadlink2.0 (16215) Unrecoverable Send packet error Authentication failed on SP2, undefined, c8:f7:42:75:d3:ed, 192.168.1.37, 30063
                          2020-06-30 10:36:05.835 - info: broadlink2.0 (16215) Device SP:0x7547_34:ea:34:bd:a7:ec dedected: address=192.168.1.23, mac=34:ea:34:bd:a7:ec, typ=sp2, id=0x7547 devtype=OEM branded SPMini2
                          2020-06-30 10:36:05.856 - info: broadlink2.0 (16215) Device bathroom dedected: address=192.168.1.5, mac=78:0f:77:17:8d:49, typ=sp2, id=0x7547 devtype=OEM branded SPMini2, originalName=SP:0x7547_78:0f:77:17:8d:49
                          2020-06-30 10:36:05.864 - info: broadlink2.0 (16215) Device SP:0x7547_34:ea:34:bd:bc:da dedected: address=192.168.1.27, mac=34:ea:34:bd:bc:da, typ=sp2, id=0x7547 devtype=OEM branded SPMini2
                          2020-06-30 10:36:05.885 - info: broadlink2.0 (16215) Device RM:0x2737_c8:f7:42:16:85:ac dedected: address=192.168.1.25, mac=c8:f7:42:16:85:ac, typ=rm, id=0x2737 devtype=RM Mini
                          2020-06-30 10:36:06.038 - info: broadlink2.0 (16215) Device SP:0x753e_34:ea:34:50:d0:15 dedected: address=192.168.1.21, mac=34:ea:34:50:d0:15, typ=sp2, id=0x753e devtype=OEM branded SPMini2
                          2020-06-30 10:36:06.053 - info: broadlink2.0 (16215) debug: send Error on device SP2, undefined, c8:f7:42:75:d7:23, 192.168.1.34, 30063: { cmd: NaN, command: 233, cmdHex: '0xe9', payload: , err: 'Authentication failed' }
                          2020-06-30 10:36:06.057 - info: broadlink2.0 (16215) Unrecoverable Send packet error Authentication failed on SP2, undefined, c8:f7:42:75:d7:23, 192.168.1.34, 30063
                          2020-06-30 10:36:06.065 - info: broadlink2.0 (16215) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:a7:ec._notReachable
                          2020-06-30 10:36:06.079 - info: broadlink2.0 (16215) debug: send Error on device SP2, undefined, c8:f7:42:75:d3:ed, 192.168.1.37, 30063: { cmd: NaN, command: 233, cmdHex: '0xe9', payload: , err: 'Authentication failed' }
                          2020-06-30 10:36:06.083 - info: broadlink2.0 (16215) Unrecoverable Send packet error Authentication failed on SP2, undefined, c8:f7:42:75:d3:ed, 192.168.1.37, 30063
                          2020-06-30 10:36:06.106 - info: broadlink2.0 (16215) debug: created State broadlink2.0.bathroom._notReachable
                          2020-06-30 10:36:06.117 - info: broadlink2.0 (16215) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:bc:da._notReachable
                          2020-06-30 10:36:06.152 - info: broadlink2.0 (16215) debug: created State broadlink2.0.RM:0x2737_c8:f7:42:16:85:ac._notReachable
                          2020-06-30 10:36:06.345 - info: broadlink2.0 (16215) debug: created State broadlink2.0.SP:0x753e_34:ea:34:50:d0:15._notReachable
                          2020-06-30 10:36:06.384 - info: broadlink2.0 (16215) debug: send Error on device SP2, undefined, c8:f7:42:75:d7:23, 192.168.1.34, 30063: { cmd: NaN, command: 233, cmdHex: '0xe9', payload: , err: 'Authentication failed' }
                          2020-06-30 10:36:06.387 - info: broadlink2.0 (16215) Unrecoverable Send packet error Authentication failed on SP2, undefined, c8:f7:42:75:d7:23, 192.168.1.34, 30063
                          2020-06-30 10:36:06.437 - info: broadlink2.0 (16215) debug: send Error on device SP2, undefined, c8:f7:42:75:d3:ed, 192.168.1.37, 30063: { cmd: NaN, command: 233, cmdHex: '0xe9', payload: , err: 'Authentication failed' }
                          2020-06-30 10:36:06.442 - info: broadlink2.0 (16215) Unrecoverable Send packet error Authentication failed on SP2, undefined, c8:f7:42:75:d3:ed, 192.168.1.37, 30063
                          2020-06-30 10:36:10.902 - info: broadlink2.0 (16215) debug: Try to discover 192.168.1.199
                          2020-06-30 10:36:10.914 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:49194
                          2020-06-30 10:36:10.924 - info: broadlink2.0 (16215) discover [ '192.168.1.199' ] from 0.0.0.0:49194
                          2020-06-30 10:36:15.179 - info: broadlink2.0 (16215) debug: ChangeState ack:true of _NewDeviceScan = false
                          2020-06-30 10:36:15.231 - info: broadlink2.0 (16215) debug: created State broadlink2.0.States.Steckdose_A
                          2020-06-30 10:36:15.316 - info: broadlink2.0 (16215) debug: created State broadlink2.0.States.Lüfter_A
                          2020-06-30 10:36:15.363 - info: broadlink2.0 (16215) debug: created State broadlink2.0.States.TVWZKanal
                          2020-06-30 10:36:15.486 - warn: broadlink2.0 (16215) device SP:0x753e_78:0f:77:01:b2:f0 not found, please rescan later again or delete it! It was: 192.168.1.24,80,30014,[object Object],78:0f:77:01:b2:f0,sp2,SP:0x753e_78:0f:77:01:b2:f0,0x753e,OEM branded SPMini2,SP:0x753e_78:0f:77:01:b2:f0
                          2020-06-30 10:36:15.490 - warn: broadlink2.0 (16215) device SP:0x7547_78:0f:77:17:a3:69 not found, please rescan later again or delete it! It was: 192.168.1.8,80,30023,[object Object],78:0f:77:17:a3:69,sp2,SP:0x7547_78:0f:77:17:a3:69,0x7547,OEM branded SPMini2,SP:0x7547_78:0f:77:17:a3:69
                          2020-06-30 10:36:15.553 - info: broadlink2.0 (16215) debug: Device SP:0x7547_34:ea:34:bd:a7:ec returned { here: true, state: false }
                          2020-06-30 10:36:15.604 - info: broadlink2.0 (16215) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:a7:ec
                          2020-06-30 10:36:15.672 - info: broadlink2.0 (16215) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:a7:ec.state
                          2020-06-30 10:36:15.759 - info: broadlink2.0 (16215) debug: Device bathroom returned { here: true, state: false }
                          2020-06-30 10:36:15.801 - info: broadlink2.0 (16215) debug: created State broadlink2.0.bathroom
                          2020-06-30 10:36:15.863 - info: broadlink2.0 (16215) debug: created State broadlink2.0.bathroom.state
                          2020-06-30 10:36:15.935 - info: broadlink2.0 (16215) debug: Device SP:0x7547_34:ea:34:bd:bc:da returned { here: true, state: false }
                          2020-06-30 10:36:15.986 - info: broadlink2.0 (16215) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:bc:da
                          2020-06-30 10:36:16.032 - info: broadlink2.0 (16215) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:bc:da.state
                          2020-06-30 10:36:16.079 - info: broadlink2.0 (16215) debug: Device RM:0x2737_c8:f7:42:16:85:ac returned { here: true, temperature: 0 }
                          2020-06-30 10:36:16.147 - info: broadlink2.0 (16215) debug: created State broadlink2.0.RM:0x2737_c8:f7:42:16:85:ac.Temperature
                          2020-06-30 10:36:16.260 - info: broadlink2.0 (16215) debug: created State broadlink2.0.RM:0x2737_c8:f7:42:16:85:ac
                          2020-06-30 10:36:16.392 - info: broadlink2.0 (16215) debug: created State broadlink2.0.RM:0x2737_c8:f7:42:16:85:ac._Learn
                          2020-06-30 10:36:16.435 - info: broadlink2.0 (16215) debug: created State broadlink2.0.RM:0x2737_c8:f7:42:16:85:ac._SendCode
                          2020-06-30 10:36:16.585 - info: broadlink2.0 (16215) debug: Device SP:0x753e_34:ea:34:50:d0:15 returned { here: true, state: false }
                          2020-06-30 10:36:16.712 - info: broadlink2.0 (16215) debug: created State broadlink2.0.SP:0x753e_34:ea:34:50:d0:15
                          2020-06-30 10:36:16.808 - info: broadlink2.0 (16215) debug: created State broadlink2.0.SP:0x753e_34:ea:34:50:d0:15.state
                          2020-06-30 10:36:16.818 - info: broadlink2.0 (16215) debug: should discover/search [ { address: '192.168.1.24', port: 80, devtype: 30014, maco: { type: 'Buffer', data: [Array] }, mac: '78:0f:77:01:b2:f0', type: 'sp2', name: 'SP:0x753e_78:0f:77:01:b2:f0', devhex: '0x753e', devname: 'OEM branded SPMini2', iname: 'SP:0x753e_78:0f:77:01:b2:f0' }, { address: '192.168.1.8', port: 80, devtype: 30023, maco: { type: 'Buffer', data: [Array] }, mac: '78:0f:77:17:a3:69', type: 'sp2', name: 'SP:0x7547_78:0f:77:17:a3:69', devhex: '0x7547', devname: 'OEM branded SPMini2', iname: 'SP:0x7547_78:0f:77:17:a3:69' } ]
                          2020-06-30 10:36:16.824 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:54865
                          2020-06-30 10:36:16.828 - info: broadlink2.0 (16215) discover [ '192.168.1.24' ] from 0.0.0.0:54865
                          2020-06-30 10:36:19.068 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:39361
                          2020-06-30 10:36:19.073 - info: broadlink2.0 (16215) discover [ '192.168.1.8' ] from 0.0.0.0:39361
                          2020-06-30 10:36:21.416 - info: broadlink2.0 (16215) debug: created State broadlink2.0._SendScene
                          2020-06-30 10:36:21.419 - info: broadlink2.0 (16215) Poll every 20 secods.
                          2020-06-30 10:36:21.421 - info: broadlink2.0 (16215) broadlink2.0 started and found 5 devices named SP:0x7547_34:ea:34:bd:a7:ec, bathroom, SP:0x7547_34:ea:34:bd:bc:da, RM:0x2737_c8:f7:42:16:85:ac, SP:0x753e_34:ea:34:50:d0:15
                          2020-06-30 10:36:21.423 - info: broadlink2.0 (16215) 2 were not found: SP:0x753e_78:0f:77:01:b2:f0, SP:0x7547_78:0f:77:17:a3:69
                          2020-06-30 10:36:21.425 - info: broadlink2.0 (16215) found macs: 34:ea:34:bd:a7:ec, 78:0f:77:17:8d:49, 34:ea:34:bd:bc:da, c8:f7:42:16:85:ac, 34:ea:34:50:d0:15
                          2020-06-30 10:37:01.707 - info: broadlink2.0 (16215) debug: should discover/search [ { address: '192.168.1.24', port: 80, devtype: 30014, maco: { type: 'Buffer', data: [Array] }, mac: '78:0f:77:01:b2:f0', type: 'sp2', name: 'SP:0x753e_78:0f:77:01:b2:f0', devhex: '0x753e', devname: 'OEM branded SPMini2', iname: 'SP:0x753e_78:0f:77:01:b2:f0' }, { address: '192.168.1.8', port: 80, devtype: 30023, maco: { type: 'Buffer', data: [Array] }, mac: '78:0f:77:17:a3:69', type: 'sp2', name: 'SP:0x7547_78:0f:77:17:a3:69', devhex: '0x7547', devname: 'OEM branded SPMini2', iname: 'SP:0x7547_78:0f:77:17:a3:69' } ]
                          2020-06-30 10:37:01.721 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:48069
                          2020-06-30 10:37:01.725 - info: broadlink2.0 (16215) discover [ '192.168.1.24' ] from 0.0.0.0:48069
                          2020-06-30 10:37:03.961 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:33564
                          2020-06-30 10:37:03.967 - info: broadlink2.0 (16215) discover [ '192.168.1.8' ] from 0.0.0.0:33564
                          2020-06-30 10:38:21.755 - info: broadlink2.0 (16215) debug: should discover/search [ { address: '192.168.1.24', port: 80, devtype: 30014, maco: { type: 'Buffer', data: [Array] }, mac: '78:0f:77:01:b2:f0', type: 'sp2', name: 'SP:0x753e_78:0f:77:01:b2:f0', devhex: '0x753e', devname: 'OEM branded SPMini2', iname: 'SP:0x753e_78:0f:77:01:b2:f0' }, { address: '192.168.1.8', port: 80, devtype: 30023, maco: { type: 'Buffer', data: [Array] }, mac: '78:0f:77:17:a3:69', type: 'sp2', name: 'SP:0x7547_78:0f:77:17:a3:69', devhex: '0x7547', devname: 'OEM branded SPMini2', iname: 'SP:0x7547_78:0f:77:17:a3:69' } ]
                          2020-06-30 10:38:21.762 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:54709
                          2020-06-30 10:38:21.766 - info: broadlink2.0 (16215) discover [ '192.168.1.24' ] from 0.0.0.0:54709
                            ElseKling last edited by
                            Mein RM4 mini (S/N: RM9250201405) kam heute. Per e-control is WLAN und sofort alles funktioniert.👍
                            Beim R3 Mini (S/N: RM6120204399) gebe ich auf. Egal ob per e-control oder cloud-App kommt immer der Storage Fehler.
                            Da hier ja noch einige R3 minis zum Testen vorhanden sind, geht meiner wieder zurück.
                              Mein RM mini 4 kam heute ebenfalls - und funktioniert auf Anhieb mit dem ioBroker Adapter. Der Weg über Python führt allerdings wieder direkt in den StorageError:
                              % python3
                              >>> import broadlink
                              >>> devices[0].auth()
                              True
                              Dies funktioniert hingegen fehlerfrei:
                              % ./broadlink_cli --type 0x5f36 --host 10.0.1.108 --mac 24DFA7E83C47 --sensors
                              temperature 0.0
                              humidity 0.0
                              Ich werde den RM mini 3 daher zurücksenden und beim RM mini 4 bleiben. Danke für eure Unterstützung!
                              • frankjoke
                                frankjoke @No Name last edited by
                                @No-Name
                                Do confirm that the device is not even listed as unknown and does not answer to device scan?
                                If you bring in the device with this app then it's definitely in cloud mode and would not work with broadlink2.
                                Did you try to bring it in with e-control? You may not be able to use it on the e-control app but it might be found then.
                                If the device does not answer it means it is not in the network or does not support old BL protocol.
                                p.s.: You seem to have a very strange and unrealiable network because you have a lot of errors! I don't know what you use but I would replace it with a Mesch-Wlan!
                                • frankjoke
                                  frankjoke last edited by frankjoke
                                  @alle
                                  Habe gerade ein update von der v2.1.4 beta (um 22:59) auf git gestellt!
                                  Der Hauptgrund ist dass ich heute das Kabel (https://www.amazon.de/gp/product/B081GDH5TM/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1) geliefert bekommen habe und bin drauf gekommen dass ich die Humidity nur dem RM4P und nicht dem RM4 (mini...) einprogrammiert habe.
                                  Nun funktioniert die Temperatur und Humidity auch auf meinen RM4-Mini!
                                    Flugschüler last edited by
                                    Habe auch das Kabel aber bei mir funktioniert es nicht, mit welcher app hast du den RM4 mini ins netz gestellt?
                                    • frankjoke
                                      frankjoke @Flugschüler last edited by
                                      @Flugschüler
                                      Immer e-control, aber daran liegt's nicht, denn wenn du die cloud-app verwendest würde alles andere auch nicht funktionieren.
                                      Funktioniert die Temperatur oder beides nicht?
                                      Ich habe den RM4 Mini nicht neu ins Netz geholt, nur altes Kabel abgesteckt und neues (mit integrierten Sensor) angesteckt und es ging nach dem update der Software sofort (vorher funktionierte nur die Temperatur)!
                                        Flugschüler @frankjoke last edited by Flugschüler
                                        @frankjoke Es funktioniert nur die Temperatur und die Luftfeuchtigkeit nicht. Ich habe den RM4C mini.
                                        M frankjoke 2 Replies Last reply Reply Quote 0
                                          Muchul @Flugschüler last edited by Muchul
                                          @Flugschüler
                                          Hast du auch dieses Kabel:
                                          Wenn nicht geht es nicht.
                                          Der Sensor ist in dem Kabel
                                            Flugschüler @Muchul last edited by Flugschüler
                                            @Muchul Ja genau das hab ich. Was für einen RM mini hast du?
                                            81.1k
                                            broad2 broadlink rm pro rm3 mini rm4
                                            169
                                            1365
                                            615480
