    4. JavaScript
    5. Hilfe bei Skript
    Hilfe bei Skript
      paul53 @Dominik F. last edited by paul53
      @Dominik-F
      Vorschlag:
      const id_Power_Poolpumpe = 'hm-rpc.0.OEQ0572933.2.POWER'/*Steckdose Poolpumpe Garage Messwert POWER*/;
      const id_Poolpumpe = 'hm-rpc.0.OEQ0572933.1.STATE'/*Steckdose Poolpumpe Garage STATE*/;
      on({id: id_Power_Poolpumpe, valLt: 500, oldValGe: 500}, function() {
         setState(id_Poolpumpe, false);
      @Dominik-F sagte in Hilfe bei Skript:
      vielleicht auch mal kurzzeitig nur Luft zieht, habe ich den Timer eingebaut von 10 Sekunden.
      Wenn auch das berücksichtigt werden soll:
      var timer = null;
      on(id_Power_Poolpumpe, function(dp) {
         if(dp.state.val < 500) {
            if(dp.oldState.val >= 500) {
               timer = setTimout( function() {
               }, 10000);
         } else if(timer) clearTimeout(timer);
      Dominik F. 2 Replies Last reply Reply Quote 0
      • Dominik F.
        Dominik F. @paul53 last edited by
        Bekomme folgende Fehlermeldung wenn ich das zweite Skript aktiviere:
        javascript.0	2020-06-29 13:41:43.587	error	(31835) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        javascript.0	2020-06-29 13:41:43.587	error	(31835) at runMicrotasks (<anonymous>)
        javascript.0	2020-06-29 13:41:43.586	error	(31835) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
        javascript.0	2020-06-29 13:41:43.586	error	(31835) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2020-06-29 13:41:43.586	error	(31835) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:608:33
        javascript.0	2020-06-29 13:41:43.586	error	(31835) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1112:17
        javascript.0	2020-06-29 13:41:43.586	error	(31835) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1521:17
        javascript.0	2020-06-29 13:41:43.586	error	(31835) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1468:37)
        javascript.0	2020-06-29 13:41:43.586	error	(31835) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:1245:28)
        javascript.0	2020-06-29 13:41:43.586	error	(31835) at Object.createScript (vm.js:263:10)
        javascript.0	2020-06-29 13:41:43.586	error	(31835) at new Script (vm.js:88:7)
        javascript.0	2020-06-29 13:41:43.586	error	(31835) SyntaxError: Unexpected token '{'
        javascript.0	2020-06-29 13:41:43.586	error	(31835) ^
        javascript.0	2020-06-29 13:41:43.586	error	(31835) if(dp.oldState.val >= 500 {
        javascript.0	2020-06-29 13:41:43.585	error	at script.js.common.Poolpumpe_Ueberwachung:8
        javascript.0	2020-06-29 13:41:43.585	error	(31835) script.js.common.Poolpumpe_Ueberwachung compile failed:
        • Dominik F.
          Habe die Fehler glaube ich gefunden, so dass im log nix mehr angezeigt wird.
          Wie kann ich nun testen ob alles funktioniert? Ich hab die Werte mal auf 600 gestellt aber es wird nix geschaltet
          var timer = null;
          on(id_Power_Poolpumpe, function (dp) {
              if (dp.state.val < 600) {
                  if (dp.oldState.val >= 600) {
                      timer = setTimeout(function () {
                      }, 10000);
                  else if (timer) clearTimeout(timer);
            @Dominik-F sagte:
            Kann auch nicht, denn der Wert müsste erst über 600 gehen, damit beim Zurückgehen unter 600 abgeschaltet wird.
            Die Pumpe wird abgeschaltet, wenn der Wert den Grenzwert(500) erstmalig unterschreitet und innerhalb von 10 s unterhalb des Grenzwertes bleibt.
            Dominik F. 1 Reply Last reply Reply Quote 0
            • Dominik F.
              Okay, das ist genau das was ich möchte. Was muss ich denn einstellen, damit er zu testzwecken abschaltet? oder muss ich dafür die Pumpe einmal kein Wasser ziehen lassen?
                @Dominik-F sagte:
                Das ist der beste Test, denn zu diesem Zweck soll es dienen.
                • Dominik F.
                  Mir ist gerade aufgefallen, dass die Pumpe immer ausgeschaltet wird obwohl sie Wasser zieht und Power über 500 W war
                    @Dominik-F sagte:
                    Richtig (Zeile 13 und 14 vertauschen):
                    • Dominik F.
                      alles klar. ich werde es gleich mal testen und dann Rückmeldung geben. Vielen Dank schonmal.
                      • Dominik F.
                        Dominik F. @paul53 last edited by Dominik F.
                        Das Skript funktioniert soweit. Wenn man nun die Poolpumpe manuell ausschaltet, dann geht ja logischerweise die Leistung auf 0 und das Skript schaltet die Poolpumpe "nochmal" aus und gibt im Log aus, dass die Pumpe überprüft werden soll.
                        Ich möchte später noch Pushnachrichten zu dem Skript hinzufügen (Sollte ich eigentlich selber hinbekommen) und das würde dann zur Verwirrung führen wenn ich 3 mal am Tag ne Nachricht bekomme das etwas mit der Pumpe nicht stimmt. Hast du ne Idee wie man das Problem lösen kann?
                        Hier die aktuelle Version:
                        const logging = true;
                        var timer = null;
                            if (dp.state.val < 500) {
                                if (dp.oldState.val >= 500) {
                                        if (logging) { log('Poolpumpe ausgeschaltet - Poolpumpe überprüfen') };
                                    }, 10000);
                          Es wir hoffentlich nicht 3 mal am Tag durch ein Script ausgeschaltet ?
                          var timer = null;
                                      }, 10000);
                              } else if (timer) clearTimeout(timer);
                          on({id: id_Poolpumpe, change: 'lt', from: 'system.adapter.javascript.0'}, function() { // triggert beim Ausschalten
                              if (logging) log('Poolpumpe ausgeschaltet - Poolpumpe überprüfen');
                          • Dominik F.
                            @paul53 sagte in Hilfe bei Skript:
                            Doch, genau das wird es 😄 Die Pumpe läuft 3 mal pro Tag für 2h
                              @Dominik-F sagte:
                              Dann anders.
                              var timer = null;
                                              if(getState(id_Poolpumpe).val) {
                                          }, 10000);
                              • Dominik F.
                                Vielen Dank, ich werde es morgen testen
                                javascript
                                772
