[Vorlage] Denon HEOS Script
 Hallo, ich danke vielmals für dieses Script. Habe es heute das erste mal hinzugefügt.
 Ich laufe direkt auf einen Fehler beim Starten:21:34:42.068 error javascript.0 (21822) script.js.Heos: [Heos] parseResponse: Unexpected end of JSON input {"heos": {"command": "player/get_now_playing_media", "result": "success", "message": "pid=1849007305"}, "payload": {"type": "song", "song": "Casimir von Oettingen & Lenia don't wanna go home 21:34:42.070 error javascript.0 (21822) script.js.Heos: [Heos] parseResponse: Unexpected token K in JSON at position 1 Kater Blau 24.02.19", "album": "", "artist": "Casimir von Oettingen", "image_url": "https://i1.sndcdn.com/artworks-000495104037-6l4zar-t500x500.jpg", "album_id": "1", "mid": "581602872", "qid": 3, "sid": 9, "gid": 1849007305}, "options": []} 21:34:42.088 error javascript.0 (21822) script.js.Heos: [Heos] parseResponse: Unexpected end of JSON input {"heos": {"command": "player/get_now_playing_media", "result": "success", "message": "pid=-1557307954"}, "payload": {"type": "song", "song": "Casimir von Oettingen & Lenia don't wanna go home 21:34:42.090 error javascript.0 (21822) script.js.Heos: [Heos] parseResponse: Unexpected token K in JSON at position 1 Kater Blau 24.02.19", "album": "", "artist": "Casimir von Oettingen", "image_url": "https://i1.sndcdn.com/artworks-000495104037-6l4zar-t500x500.jpg", "album_id": "1", "mid": "581602872", "qid": 3, "sid": 9, "gid": 1849007305}, "options": []} 21:34:42.105 error javascript.0 (21822) script.js.Heos: [Heos] parseResponse: Unexpected end of JSON input {"heos": {"command": "player/get_now_playing_media", "result": "success", "message": "pid=413862456"}, "payload": {"type": "song", "song": "Casimir von Oettingen & Lenia don't wanna go home 21:34:42.107 error javascript.0 (21822) script.js.Heos: [Heos] parseResponse: Unexpected token K in JSON at position 1 Kater Blau 24.02.19", "album": "", "artist": "Casimir von Oettingen", "image_url": "https://i1.sndcdn.com/artworks-000495104037-6l4zar-t500x500.jpg", "album_id": "1", "mid": "581602872", "qid": 3, "sid": 9, "gid": 1849007305}, "options": []}Jetzt hab ich mir mal den Liedtitel (Soundcloud) angesehen. Der beinhaltet ein "|". Kann es sein, dass daher der Parsing-Error entsteht? Das "Lied" habe ich einfach in meinen Likes drin.
 Hast du zufällig eine Idee wie man das fixen könnte?Schöne Grüße
 @Stueckinger Oh das ist natürlich blöd. Mit der Pipe | wurden die Heos Nachrichten gesplittet  Jetzt funktioniert es: heos.js Jetzt funktioniert es: heos.js@Mars Ja der Gong kommt bei mir auch noch nicht mit durch. Hatte gedacht, dass sayit alles in eine mp3 packt...
 @withstu super, dankeschön. Das hat funktioniert.
 Man kann nur auf Favoriten - sprich Radiosender - zugreifen, oder? (Presets)
 Meine Playlists tauchen leider nicht auf.
 ich musste heute ein Backup von heute morgen einspielen über backitup wegen einer Vis View.... Seit dem Zeitpunkt des neuen Backups wird mein Java Adapter beendet sobald ich das Heos Skript aktiviere. Das passiert mit meinem alten Skript was bisher lief aber auch wenn ich das neue von ende 2019 nehme, welches ich gerade getestet habe.Was mich total verwundert ist, das gleich der ganze Adapter 4.6.17 auf rot geht. Node.js
 v12.18.1
 NPM
 6.14.4Es kommt folgende Meldung host.Homeserver 2020-06-19 17:46:59.368 info Restart adapter system.adapter.javascript.0 because enabled host.Homeserver 2020-06-19 17:46:59.367 error instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.Homeserver 2020-06-19 17:46:59.367 error Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:84:21) host.Homeserver 2020-06-19 17:46:59.367 error Caught by controller[0]: at emitErrorAndCloseNT (internal/streams/destroy.js:60:3) host.Homeserver 2020-06-19 17:46:59.367 error Caught by controller[0]: at emitErrorNT (internal/streams/destroy.js:92:8) host.Homeserver 2020-06-19 17:46:59.367 error Caught by controller[0]: at Socket.EventEmitter.emit (domain.js:482:12) host.Homeserver 2020-06-19 17:46:59.367 error Caught by controller[0]: at Socket.emit (events.js:315:20) host.Homeserver 2020-06-19 17:46:59.367 error Caught by controller[0]: at Socket.<anonymous> (script.js.HIFI.Heos:629:18) host.Homeserver 2020-06-19 17:46:59.366 error Caught by controller[0]: at Heos.disconnect (script.js.HIFI.Heos:543:30) host.Homeserver 2020-06-19 17:46:59.364 error Caught by controller[0]: TypeError: this.nodessdp_client.destroy is not a function javascript.0 2020-06-19 17:46:59.308 info (15005) script.js.HIFI.Heos: registered 1 subscription and 0 schedules javascript.0 2020-06-19 17:46:59.265 info (15005) script.js.HIFI.Heos: [Heos] connecting to HEOS ... javascript.0 2020-06-19 17:46:59.257 info (15005) Start javascript script.js.HIFI.Heos
 @Stueckinger Prinzipiell kann man auf alles zugreifen. Habe die Playlists und Sources inkl. Play Buttons hinzugefügt: heos.js
 @withstu weißt du ob das mit den neuen Home 150 oder größer besser/anders ist?`
 Ich habe nämlich noch eine alte HEOS HomeCinema Soundbar. Die Frage ist wenn ich jetzt eine neue Home 150 Box kaufe und dann diese anspreche und die alte soundbar in die gleiche Gruppe nehme, Verbesserung verspricht.Gibt es eine andere sinnvolle Lösung die HEOS Box als SmartHome Sprachrohr zu nutzen mit oder ohen sayit adapter?
 @Mars @withstu Ich könnte mir vorstellen, dass der Grund warum der Gong nicht gespielt wird, die Pufferungszeit vom Heos ist. Wenn ich ein mp3 Abspiele werden immer erst 5 Sekunden lautlos gespielt, bevor ich was höre.
 Versucht doch mal, vor den Gong z.B. leere 5 Sekunden in das mp3 zu packen.
 Ich schätze, dass sich das bei neueren Boxen auch nicht anders verhält, weil das System den Puffer braucht, um mehrere Boxen synchron spielen zu können.
 Nur ein Gedankenanstoß, vielleicht hilfts.
 Viele Grüße Christian
 Hallo @withstu,
 das Skript lief in der Version 2.0 vom Anfang Mai super, ist aber am Freitag nach dem Update der Heos-Boxen abgeschmiert und hat mir das Log gescheit mit Information gefüllt. Die Heos-App hat ein Update verlangt, ich habe dann alle Boxen gleich mit upgedated. Im Log ist folgendes passiert:Beim Update kam: 2020-06-25 19:01:55.020 - [33mwarn[39m: javascript.1 (1416) script.js.Steuerung.heos: [Heos] HEOS closed the connection to 192.168.111.20 2020-06-25 19:01:55.022 - [32minfo[39m: javascript.1 (1416) script.js.Steuerung.heos: [Heos] reconnecting to HEOS ... 2020-06-25 19:01:55.023 - [32minfo[39m: javascript.1 (1416) script.js.Steuerung.heos: [Heos] disconnecting from HEOS ... 2020-06-25 19:01:55.025 - [32minfo[39m: javascript.1 (1416) script.js.Steuerung.heos: [Heos] [HEARTBEAT] Stop interval 2020-06-25 19:01:55.026 - [32minfo[39m: javascript.1 (1416) script.js.Steuerung.heos: [HeosPlayer 1645177266] stopping HEOS player with pid 1645177266 (192.168.111.22) 2020-06-25 19:01:55.044 - [32minfo[39m: javascript.1 (1416) script.js.Steuerung.heos: [HeosPlayer -140829128] stopping HEOS player with pid -140829128 (192.168.111.23) 2020-06-25 19:01:55.065 - [32minfo[39m: javascript.1 (1416) script.js.Steuerung.heos: [HeosPlayer -1359970574] stopping HEOS player with pid -1359970574 (192.168.111.20) 2020-06-25 19:01:55.085 - [31merror[39m: javascript.1 (1416) script.js.Steuerung.heos: [Heos] Error: This socket has been ended by the other party 2020-06-25 19:01:55.086 - [32minfo[39m: javascript.1 (1416) script.js.Steuerung.heos: [Heos] reconnecting to HEOS ... 2020-06-25 19:01:55.086 - [32minfo[39m: javascript.1 (1416) script.js.Steuerung.heos: [Heos] disconnecting from HEOS ... 2020-06-25 19:01:55.087 - [32minfo[39m: javascript.1 (1416) script.js.Steuerung.heos: [Heos] [HEARTBEAT] Stop interval 2020-06-25 19:01:55.088 - [31merror[39m: javascript.1 (1416) script.js.Steuerung.heos: [Heos] Error: This socket has been ended by the other party 2020-06-25 19:01:55.088 - [32minfo[39m: javascript.1 (1416) script.js.Steuerung.heos: [Heos] reconnecting to HEOS ... 2020-06-25 19:01:55.088 - [32minfo[39m: javascript.1 (1416) script.js.Steuerung.heos: [Heos] disconnecting from HEOS ... 2020-06-25 19:01:55.088 - [32minfo[39m: javascript.1 (1416) script.js.Steuerung.heos: [Heos] [HEARTBEAT] Stop intervalInnerhalb von 2 Sekunden wurden hier ca. 1500 mal diese 4 Zeilen geschrieben.
 Dann kam diese Meldung, aber nur ca. 80 mal:2020-06-25 19:02:10.461 - [31merror[39m: javascript.1 (1416) script.js.Steuerung.heos: [Heos] sendMsg: Maximum call stack size exceededWeiter gings ca. 1500x mit folgender Meldung: 2020-06-25 19:02:11.831 - [32minfo[39m: javascript.1 (1416) script.js.Steuerung.heos: [Heos] disconnected from HEOSund 2020-06-25 19:02:24.383 - [32minfo[39m: javascript.1 (1416) script.js.Steuerung.heos: [Heos] searching for HEOS devices ...und dann bis ichs gemerkt habe (ca. 400k Einträge in 2h): 2020-06-25 19:02:48.835 - [32minfo[39m: javascript.1 (1416) script.js.Steuerung.heos: [Heos] still searching for HEOS devices ...Ich habe dann den iobroker neu gestartet. Wahrscheinlich hätte ein Restart des javascript Adapters auch gereicht? aber ich habe den broker eh angehalten wegen mehrfacher Updates. Irgendwie hat wohl das Update der Boxen das Skript bzw. den Adapter verwirrt.
 Wenn ich alle Boxen ausstecke, dann kommt zwar auch "searching", jedoch nur im 30s-Takt.Hier wäre es eventuell günstiger, den Ausgabe bzw. auch den Verbindungsversuch zu minimieren, dass der nicht im ms-Takt einen Reconnect versucht. Auch scheint hier das Heartbeat Intervall (15s) nicht zu greifen? Oder wird das nur angewendet, wenn die Verbindung aufgebaut ist? Viele Grüße
 Christian
 Das Update führt wohl selbst auch zu Problemen... Caschys Blog: Denon Heos: Probleme nach Firmware-Update.
 http://feedproxy.google.com/~r/stadt-bremerhaven/dqXM/~3/tPazcUOP0Ys/Könnte also auch daran liegen. Grüße Brati
 Hey @chrisblu,
 hatte gerade mal das Debugging eingeschaltet und dabei ein HEOS Player aktualisiert. Bei mir gab es keine Probleme. Das Script trennt die Verbindung, falls der Heartbeat fehlschlägt und reconnected, wenn der Player nach dem Update gefunden wurde.
 Die reconnect Funktion wird immer aufgerufen, falls HEOS Fehler wirft oder die Verbindung fehlerhaft ist. Nach dem disconnect wird dann 5 Sekunden gewartet, um eine neue Verbindung aufzubauen. Leider gab es hier keine Beschränkung wie oft diese Funktion ausgeführt wird. Bei vielen Fehlern würden auch die reconnect Funktion sehr oft aufgerufen werden. Habe jetzt im Script versucht das wiederholte Ausführen der reconnect Funktion zu unterbinden. Ich hoffe, dass dadurch der Fehler Geschichte ist.
 Der Heartbeat wird übrigens nur aktiviert, falls es eine Verbindung zu einem HEOS Player gibt. Bei einem reconnect/disconnect wird der Heartbeat ausgeschaltet.@Mars Da sich die Schnittstelle bei den neuen Playern nicht geändert hat, wird es da auch nicht besser funktionieren. Problem mit dem Gong und sayit ist, dass sayit den Gong und den Text hintereinander unter der selben URL veröffentlicht (Die Datei wird nach dem Gong mit der Text mp3 ersetzt). Dadurch müsste mein Script quasi zweimal im richtigen Moment play_stream ausführen und dafür die Längen der beiden mp3s kennen. Dafür habe ich aktuell noch keine Lösung. Der Sonos Adapter arbeitet da wohl mit einer Queue https://github.com/ioBroker/ioBroker.sonos/blob/master/lib/tts.js. Durch die Integration von Sonos im sayit Adapter wird zudem für den Gong und den Text jeweils ein Update auf dem tts state durchgeführt. Script: heos.js
 @withstu Ja mit Gong und anschließender Ansage bekomme ich auch nicht vernünftig zum laufen.
 Generell ist die 5 sec. Zeitverzögerung für eine Haustürklingel nicht ganz optimal. Manchmal geht es auch deutlich länger, wenn in meinem Fall die Soundbar im "sleep" ist.
 Ich habe vor meinen Gong jetzt 5 sec. Leerlauf eingebaut. Der Gong kommt so immer sauber durch aber halt manchmal recht spät.
 Zudem muss man wissen wie lange der Gong in etwa läuft um dann wieder ein "Stop" an den Heos Lautsprecher zu schicken sonst läuft dieser in Endlosschleife!
 Wenn jemand hier Tips hat darf er diese gerne äußern!
 Danke!
 @Mars Eine Idee wäre den Gong in eine HEOS Playlist zu packen und über die neuen Playlist States (0_userdata.0.heos.playlists.ID.play) das Abspielen zu triggern. Dauert auch bei mehreren Playern nicht länger als 2 Sekunden. Vorher sollte Shuffle noch deaktiviert werden (player/set_play_mode&shuffle=off) bzw. Repeat (player/set_play_mode&repeat=off). Wenn die Playlist einmal abgespielt wurde, stoppen die Player die Wiedergabe. Bei dieser Variante ist natürlich die gespielte Musik verloren und müsste wieder gestartet werden. Leider speichert HEOS in den Playlists kein Url Stream und damit wäre TTS aus dem Rennen.
 @Mars Mir kommt da als Quelle noch ein mp3 auf einem USB-Stick direkt in der Box in den Sinn. Könnte schneller gehen, aber ob man das ansteuern kann? Ein Versuch wärs Wert. Das Problem mit der unterbrochenen/ abgebrochenen Musik wird da aber wohl auch auftreten. Vielleicht könnte man den aktuellen Status durch ein Skript vor dem Auslösen auslesen und dann wieder weiterspielen?
 @withstu das hatte ich in einer Playlist gemacht, jedoch wusste ich noch nicht wie man eine Playlist abspielt. Das ist ja aber jetzt mit einem Datenpunkt sehr einfach geworden. Also der Klingel Gong wird so zuverlässig eingespielt. Habe noch 2 sec. Leerlauf vor den Gong gepackt, dann kommt dieser sauber durch.
 Mein Ziel wäre es eigtl. Alexa zu ersetzen als Ausgabe Lautsprecher da es hier über die Cloud geht.
 Für mich als Laie ist unklar was jetzt bei dem sehr umfangreichen Script noch fehlt, dass es wie bei einer Sonos Box mit dem "text to speech" funktioniert?
 @chrisblu die Gong MP3 ist auf einem USB direkt an der Box dran. Das mit dem auslesen und wieder einspielen des Status war auch mal mein Gedanke hatte ich aber noch nicht probiert.
 möglicherweise kam die Frage schon, aber kann man rausbekommen, ob auf einen der Quick-Select buttons gedrückt worden ist?Mein Use-Case: Wenn ich im Bad die (1) drücke, dann soll das gleiche gespielt werden, was gerade im Wohnzimmer läuft. Grüße,
 klaus
 @Mars Das Problem ist hier die HEOS API. Es gibt nur eine play_stream Funktion, die einen Stream sofort abgespielt. Für unsere TTS Funktion bräuchten wir aber eher eine Funktion, die den Stream lediglich zur Queue hinzufügt, aber nicht abspielt. So ist es quasi unmöglich mehrere Streams (Gong + TTS) hintereinander abzuspielen. Zudem ist der Sonos Adapter in den SayIt Adapter integriert und hat so die Dauer der Audiofiles zur Verfügung. @Klaus-Baumecker Es gibt kein Event dafür, um das zu erkennen. Workaround könnte sein, dass du hinter dem Quickselect ein stilles Lied mit einem bestimmten Lied Titel hinterlegst und dann ein Script den Liedtitel überwachen lässt. Btw. mir ist aufgefallen, dass die States der Gruppen nicht richtig funktioniert haben. Deswegen gibts ne neue Version: heos.js
 @withstu Das mit dem stillen Lied hatte ich mir auch schon überlegt. Bzw einen URL, der direkt das Web-API vom iobroker anspricht. Ich werde das demnächst mal probieren und berichte dann. Ich hatte übrigens auch einen Fehler im Script entdeckt: Beim scannen nach HEOS devices wird bei mir ein ungültiges device gefunden. Daraufhin bricht die Suche ab. Ich checke mal das neue von Dir bei Gelegenheit. Vielleicht sollte man es auch nach Github schieben. Dann kann man besser mir issues und PRs arbeiten.
 @withstu Vielen Dank für das coole Skript. Aktuell habe ich ein Problem mit dem Skript in meiner Umgebung. Umgebung: Mein ioBroker läuft in einem Docker auf einem Synology-NAS. Das Netzwerk ist im Bridged-Mode mit dem NAS (für einen Teil der Adapter leider erforderlich). Im Bridged-Mode läuft das Denon Skript nicht. Es kommt die Meldung "[Heos] searching for HEOS devices ...", ohne das etwas gefunden wird. Fehleranalyse: Habe das Skript in einem separaten MACVLAN Ausprobiert. Damit hat das Skript fehlerfrei funktioniert. Es wurden sofort die beiden Heos-Lautsprecher und der AVR gefunden. Meine Vermutung ist jetzt, dass für das Skript eine Portweiterleitung in der Konfiguration des Docker-Containers fehlt. Frage: Welche Ports werden für den Betrieb des Skriptes benötigt? Die Ports 1255 und 53871 habe ich bereits eingerichtet. Fehlen da noch weitere? Wäre super, wenn mir jemand weiterhelfen kann.
 Lieben Gruß, DobbyMuh
 @DobbyMuh Ich glaub das Beste ist, wenn du dir ein kleines node Script bastelst und die Device Suche nachstellst. Dazu brauchst du folgendes Paket https://www.npmjs.com/package/node-ssdp und das Target "urn:schemas-denon-com:device:ACT-Denon:1". Die Ports passen. Eventuell hilft auch Wireshark weiter... @Klaus-Baumecker Ich arbeite gerade an einen HEOS Adapter auf GitHub. Falls du den Fehler noch eingrenzen kannst wäre das super. @Uhula Ich hab dich auf GitHub zum privaten Heos Adapter Repo hinzugefügt. Kannst ja mal schauen, was du noch dazu beitragen kannst. Mir gefällt aktuell noch nicht, dass ich deine schöne Player Klasse auflösen musste. Habe das Script erstmal nach dem Motto "Make it work" in einen Adapter transformiert
