    3. Entwicklung
    4. [Major Update] UniFi Adapter v0.5.0
    • U
      UHT last edited by UHT
      Nach update auf 0.5.5 bekomme ich folgende Fehler:
      host.QNAP	2020-06-24 16:26:19.161	error	Caught by controller[1]: at Request.self.callback (/opt/iobroker/node_modules/node-unifi/node_modules/request/request.js:185:22)
      host.QNAP	2020-06-24 16:26:19.161	error	Caught by controller[1]: at Request.reqfunc [as _callback] (/opt/iobroker/node_modules/node-unifi/unifi.js:2824:13)
      host.QNAP	2020-06-24 16:26:19.160	error	Caught by controller[1]: at next (/opt/iobroker/node_modules/node-unifi/node_modules/async/dist/async.js:4453:13)
      host.QNAP	2020-06-24 16:26:19.160	error	Caught by controller[1]: at async.whilst.callback (/opt/iobroker/node_modules/node-unifi/unifi.js:2781:16)
      host.QNAP	2020-06-24 16:26:19.160	error	Caught by controller[1]: at check (/opt/iobroker/node_modules/node-unifi/node_modules/async/dist/async.js:4459:32)
      host.QNAP	2020-06-24 16:26:19.160	error	Caught by controller[1]: at /opt/iobroker/node_modules/node-unifi/node_modules/async/dist/async.js:321:20
      host.QNAP	2020-06-24 16:26:19.160	error	Caught by controller[1]: at async.whilst.err (/opt/iobroker/node_modules/node-unifi/unifi.js:2840:11)
      host.QNAP	2020-06-24 16:26:19.160	error	Caught by controller[1]: at controller.getDPIStats (/opt/iobroker/node_modules/iobroker.unifi/main.js:688:32)
      host.QNAP	2020-06-24 16:26:19.160	error	Caught by controller[1]: at Unifi.processDpi (/opt/iobroker/node_modules/iobroker.unifi/main.js:716:28)
      host.QNAP	2020-06-24 16:26:19.160	error	Caught by controller[1]: at Unifi.applyJsonLogic (/opt/iobroker/node_modules/iobroker.unifi/main.js:843:30)
      host.QNAP	2020-06-24 16:26:19.160	error	Caught by controller[1]: TypeError: Cannot read property 'lenth' of undefined
      host.QNAP	2020-06-24 16:26:19.159	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
      klingt nach einem Typo...
      EDIT:
      Nach einem speichern der konfig ist der Fehler weg...
      braindead 1 Reply Last reply Reply Quote 0
      • braindead
        braindead Developer @UHT last edited by
        @UHT Danke für den Hinweis. Das ist tatsächlich ein Typo. 👍
          MyMeyer @braindead last edited by
          Hallo, kann man folgendes beim Adapter einbauen. Das Gerät nach einer bestimmte Zeit gelöscht werden, wenn sie x Stunden nicht Online sind/waren. Nach wie viel Stunden genau gelöscht werden darf, sollte man als Einstellmöglichkeit im Adapter haben. So kann jeder Benutzer selber entscheiden wie lange Offline Geräte sichtbar sind.
          • braindead
            braindead Developer @MyMeyer last edited by
            @MyMeyer Einbauen kann man sicher vieles, ich werde es aber nicht machen. Was ist mit Clients, die sich nur alles paar Tage connecten? Sollen diese vom Löschen ausgenommen sein? Dann wird die Konfiguration beliebig kompliziert.
            Wenn Du das unbedingt brauchst, kannst Du das sicher über ein eigenes Script bzw. Blockly lösen.
              Dann muss ich es wohl über ein Script machen. 🙄
              • braindead
                braindead Developer last edited by
                Die nächste Version mit der Versionsnummer v0.5.6 steht in den Startlöchern und wartet darauf getestet zu werden. Folgende Punkte wurden implementiert:
                • (Scrounger, braindead1) Implemented Alarms, DPI & Gateway Traffic
                • (braindead1) Prevented creation of ghost clients caused by iOS MAC randomization
                • (dklinger) Implemented manual update trigger
                • (braindead1) Implemented deletion of used vouchers
                • (braindead1) Fixed some errors reported via Sentry
                Zum Testen müsst Ihr den Adapter einfach direkt von GitHub (über die Katze) aktualisieren. Ihr solltet dann die Versionsnummer v0.5.6-beta.1 angezeigt bekommen.
                Sofern es keine größeren Probleme gibt, soll v0.5.6 zum Wochenende hin die nächste stable Version werden.
                D coyote 2 Replies Last reply Reply Quote 0
                  darkiop Most Active @braindead last edited by
                  @braindead läuft seit heute Morgen ohne größere Auffälligkeiten.
                  Nur:
                  Die Objekte für den Gateway Traffic wurden angelegt, obwohl in den Einstellungen diese nicht ausgewählt sind:
                  • coyote
                    coyote Most Active @braindead last edited by coyote
                    @braindead bei mir wird wegen Gateway Traffic (wenn angewählt) der Adapter gar nicht erst grün.
                    unifi.0	2020-06-30 09:13:42.862	info	(29173) Terminated (NO_ERROR): Without reason
                    unifi.0	2020-06-30 09:13:42.858	info	(29173) terminating
                    unifi.0	2020-06-30 09:13:42.831	info	(29173) cleaned everything up...
                    unifi.0	2020-06-30 09:13:42.829	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                    unifi.0	2020-06-30 09:13:42.829	error	at Unifi.processGatewayTraffic (/opt/iobroker/node_modules/iobroker.unifi/main.js:830:38)
                    unifi.0	2020-06-30 09:13:42.829	error	(29173) TypeError: Cannot read property 'filter' of undefined
                    unifi.0	2020-06-30 09:13:42.829	error	(29173) unhandled promise rejection: Cannot read property 'filter' of undefined
                    Unhandled	2020-06-30 09:13:42.828	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    unifi.0	2020-06-30 09:13:27.602	info	(29173) UniFi adapter is ready
                    unifi.0	2020-06-30 09:13:27.485	info	(29173) starting. Version 0.5.6-beta.1 in /opt/iobroker/node_modules/iobroker.unifi, node: v10.21.0, js-controller: 3.1.6
                    unifi.0	2020-06-30 09:13:27.467	info	(29173) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                    • braindead
                      braindead Developer @coyote last edited by
                      @darkiop Werden nur die Channel angelegt, oder gibt es darunter auch DPs?
                      @coyote Hast Du ein USG? Falls nicht, kannst Du die Daten auch nicht abfragen. 🙂
                        @braindead gibt DPs welche auch aktualisiert werden:
                        • coyote
                          @braindead ja hab ich
                          • braindead
                            braindead Developer @darkiop last edited by
                            @darkiop said in [Major Update] UniFi Adapter v0.5.0:
                            Ich habe mir den Code gerade nochmal angesehen (ist schon etwas älter). Das "Problem" ist nicht auf Gateway Traffic beschränkt, sondern trifft auf alles zu, wo man States filtern kann: Wenn der Haken bei "... aktualisieren" gesetzt ist, unten aber keine States (heraus)gefiltert werden, dann werden alle übernommen.
                            Die Tatsache, dass Du darüber gestolpert bist, zeigt, dass das Verhalten des Adapters zwar erklärbar, aber für User wahrscheinlich nicht unbedingt logisch ist. Sollte das besser umgebaut werden?
                            Wobei es für mich nicht logisch ist den Haken bei "... aktualisieren" zu setzen und unten keine States auszuwählen. 😉
                            • braindead
                              @coyote said in [Major Update] UniFi Adapter v0.5.0:
                              Den Fehler Cannot read property 'filter' of undefined habe ich in Sentry schon öfter gesehen, habe aber bisher keine Erklärung, woher der kommt. Es wäre also gut, wenn Du mir bei der Suche helfen könntest.
                              Kann es sein, dass Du im UniFi Controller mehrere Sites hast? Wie heißen diese? Kann es sein, dass eine Deiner Sites hier keine Daten liefert? Ich nutze nur die Default Site, deshalb frage ich. 🙂
                              • coyote
                                @braindead klar, kann ich machen. Nein, nutze auch nur die Default Site
                                braindead Scrounger 2 Replies Last reply Reply Quote 0
                                  darkiop Most Active last edited by
                                  @braindead sagte in [Major Update] UniFi Adapter v0.5.0:
                                  Grundsätzlich stört (mich) das nicht. Evtl. könnte man aber per CSS die States unten ausblenden wenn der Haken nicht gesetzt ist.
                                  • braindead
                                    @darkiop Ich glaube Du hast die Frage falsch verstanden.Das Umbauen bezog sich darauf, ob weiterhin alle States importiert werden sollen, wenn keine States ausgewählt werden.
                                    • braindead
                                      Ich habe ehrlich gesagt keine Idee, warum es bei Dir nicht funktioniert. GRundsätzlich ließe sich der Fehler abfangen, aber Du würdest dann natürlich auf keinen Gateway Traffic einlesen können.
                                      @Scrounger Hast Du eine Idee?
                                      • Scrounger
                                        Scrounger Developer @coyote last edited by
                                        @braindead
                                        so spontan nicht.
                                        @coyote sagte in [Major Update] UniFi Adapter v0.5.0:
                                        Was für einen gateway hast du?
                                        • coyote
                                          coyote Most Active @Scrounger last edited by
                                          @Scrounger @braindead habe das kleine USG mit den 4 Ports.
                                          Kann morgen früh gerne nochmal aktivieren und testen ob der gleiche Fehler direkt wieder auftritt
                                          • Scrounger
                                            Scrounger Developer @coyote last edited by Scrounger
                                            @coyote
                                            Im unifi controller unter Wartung -> Statistik Daten-Speicherdauer hast du auch die Statistik aktiviert?
                                            Bitte log dich in den controller ein und führe folgenden befehl im browser aus:
                                            https://IP:PORT/api/s/default/stat/report/daily.gw - bei IP und PORT deine eintragen.
                                            Bitte das ergebnis posten.
                                            unifi
                                            54
                                            510
                                            113910
