    4. JavaScript
    5. [Vorlage] Alias per Skript erzeugen
    • _nico
      _nico last edited by _nico
      Hi @paul53, ich mal wieder. ✌
      Ich möchte über dein Alias Skript bei den Aliases History (sql.0) und Lovelace (lovelace.0) konfigurieren.
      Er verwirft aber meine konfigurierte Custom-Variable.
      Der lovelaceAlias muss statt "." "_" haben.
      desc = 'per Script von paul53 erstellt';
      function createAliasOnOff(idDst, naAlia, idSrc, idRd) {
        var lovelaceAlias = idDst.replace('.','_');
        var typeAlias = 'boolean';
        var states = {false: 'Off', true: 'On'};
        var custom = {"sql.0": { "enabled": true, "changesOnly": false, "debounce": 0, "maxLength": 10, "retention": 0, "changesRelogInterval": 0, "changesMinDelta": 0, "storageType": "", "aliasId": "", "counter": false}, "lovelace.0": { "enabled": true, "entity": "switch", "name": lovelaceAlias}};
        if(existsState(idDst)) log(idDst + ' schon vorhanden !', 'warn');
        else {
          var obj = {};
          obj.type = 'state';
          obj.common = getObject(idSrc).common;
          obj.common.alias = {};
          if(idRd) {
              obj.common.alias.id = {};
              obj.common.alias.id.read = idRd;
              obj.common.alias.id.write = idSrc;
              obj.common.read = true;
          } else obj.common.alias.id = idSrc;
          if(typeAlias) obj.common.type = typeAlias;
          if(obj.common.read !== false && read) obj.common.alias.read = read;
          if(obj.common.write !== false && write) obj.common.alias.write = write;
          if(naAlia) obj.common.name = naAlia;
          if(role) obj.common.role = role;
          if(desc) obj.common.desc = desc;
          if(min !== undefined) obj.common.min = min;
          if(max !== undefined) obj.common.max = max;
          if(unit) obj.common.unit = unit;
          if(states) obj.common.states = states;
          if(custom && obj.common.custom) obj.common.custom = custom;
          obj.native = {};
          setObject(idDst, obj);
          if(raum && getObject('enum.rooms.' + raum)) {
             let obj = getObject('enum.rooms.' + raum)
             obj.common.members.push(idDst);
             setObject('enum.rooms.' + raum, obj);
          if(gewerk && getObject('enum.functions.' + gewerk)) {
             let obj = getObject('enum.functions.' + gewerk)
             setObject('enum.functions.' + gewerk, obj);
      var typeAlias, read, write, role, desc, min, max, unit, states, custom, raum, gewerk;
      const idAliaOnOff11 = 'Test.On6';
      const naAliaOnOff11 = 'Test';
      const idOrigOnOff11 = 'zwave2.0.Node_013.Binary_Switch.targetValue';
      const idReadOnOff11 = 'zwave2.0.Node_013.Binary_Switch.currentValue';
      createAliasOnOff('alias.0.' + idAliaOnOff11, naAliaOnOff11, idOrigOnOff11, idReadOnOff11);
        paul53 @_nico last edited by paul53
        @_nico sagte:
        Das Script ist nicht von mir.
        Mit dem SQL-custom kenne ich mich nicht aus. Weshalb erstellst Du ihn nicht nachträglich im Tab "Objekte" ?
        Das sieht für mich nach getrenntem Kommando und Status aus. Die kann man im Alias zusammenführen, aber nicht mit diesem Script, sondern mit dem untersten in meinem ersten Post.
        _nico 1 Reply Last reply Reply Quote 0
        • _nico
          _nico @paul53 last edited by _nico
          @paul53 sagte in [Vorlage] Alias per Skript erzeugen:
          @_nico sagte:
          Doch klar, aus dem ersten Post. Ich habe es etwas angepasst, dass es mir alle Aliases auf einmal anlegt.
          Naja, es handelt sich um über 300 Aliases - wollte mir den Aufwand auf diesem Weg ersparen.
          Doch oder? Jetzt bringst du mich aber durcheinander.
          if(idRd) {
          UPDATE_22:44
          in
          if(custom) obj.common.custom = custom;
          geändert. Scheint zu gehen.
            @_nico sagte:
            Was ist lovelaceAlias ? Die Variable wird nirgends ausgewertet.
              @_nico sagte:
              Sorry, mich hat die völlig geänderte Reihenfolge durcheinander gebracht. An der Stelle passt es.
              @_nico sagte:
              Ja, wenn das Original noch kein common.custom hat, muss man es so machen.
              • _nico
                @_nico sagte:
                Die Visualisierungslösung "Lovelace" benötigt einen Alias für die jeweiligen Daten aus der History-Instanz, dass ist mein lovelaceAlias - weil er sonst einen nimmt den ich nicht bzw. nur schwierig zuordnen kann.
                Doch, am Ende von var custom. 🙂
                Aber aktuell wird nur der erste "." ersetzt, müssen aber alle "." werden. Das bekomme ich aber sicher alleine hin.
                DANKE für deine Unterstützung.
                • _nico
                  Hi @paul53,
                  es geht um dein Skript aus dem ersten Post, wo man Gewerke und Räume mit übergeben kann.
                  EDIT(17.02.2020): Da man Raum und Gewerk in die Struktur der Alias-ID einbringen kann, sind enums für Raum und Gewerk oftmals nicht erforderlich. Für diejenigen, die den erzeugten Alias-Datenpunkt zu enum.rooms und/oder enum.functions hinzufügen wollen, hier eine Version, die es ermöglicht:
                  Du hast ja gestern bereits mitbekommen, dass ich mir ein "großes Skript" gebaut habe, was mir alle Aliases "in einem Rutsch" anlegt. Nun habe ich es noch etwas erweitert und gebe bei einigen auch ein Gewerk mit. Allerdings, habe ich nun den Fall, dass nur das letzte Gerät im Skript, welches dem Gewerk zugeordnet werden soll, im Gewerk ist.
                  Vermutlich weil es asynchron läuft? Daran werde ich sicher nicht viel ändern können oder?
                  Gruß Nico
                  ioBroker_Alias.js
                    @_nico sagte:
                    Ja, so wie es jetzt angelegt ist, funktioniert es nicht. Du müsstest zu Beginn alle benötigten Räume und Gewerke einlesen, dann innerhalb der Funktionen die Datenpunkte hinzufügen und zum Schluss die Räume und Gewerke mit setObject() schreiben.
                    Alternative: Du arbeitest bei allen Alias, die Enums verwenden, mit unterschiedlichen Verzögerungen beim Aufruf der Funktion.
                    • _nico
                      @_nico sagte:
                      Hmm, ne. Das ist irgendwie nicht schön. Wenn dann hätte ich es schon gerne halbwegs ordentlich.
                      Klingt besser. Weiß aber so garnicht, wie ich das machen soll. Kannst du mir mit ein paar Codeschnipsel auf die Sprünge helfen und ich sehe dann, was ich daraus machen kann?
                      DANKE
                        @_nico sagte:
                        Habe ich es richtig gesehen, dass nur das Gewerk "batterien" verwendet wird ?
                        • _nico
                          @_nico sagte:
                          Aktuell ja, weil ich ja noch im Umbau stecke. Kommt aber noch "rauchmelder", "luftfeuchte", etc. dazu.
                            @_nico
                            Zu Beginn des Scriptes einlesen (Beispiel "batterien"):
                            var batt = getObject('enum.functions.batterien');
                            Diesen Teil in allen Funktionen:
                            ersetzen durch:
                                if(gewerk) {
                                    if(gewerk == 'batterien') batt.common.members.push(idDst);
                                    // usw. für weitere Gewerke
                            Und zum Ende des Scriptes schreiben:
                            setObject('enum.functions.batterien', batt);
                            • _nico
                              Danke für deine Zeit und überdurchschnittliche Hilfsbereitschaft! ♥
                                Katzenpapa @paul53 last edited by Katzenpapa
                                states = {false: 'geschlossen', true: 'offen'}
                                @paul53 Hallo Paul. Wo trage ich das ein? Ich habe mir einen Magnetkontaktschalter an ein ElectroDragon gesteckt und ihn als Sensor in Iobroker definiert. Nun hätte ich auch gerne Offen/Geschlossen anstatt true/False.
                                Gruß Paul
                                  paul53 @Katzenpapa last edited by
                                  @Katzenpapa sagte in [Vorlage] Alias per Skript erzeugen:
                                  Entferne die Kommentarzeichen bei
                                  // states = {0: 'Aus', 1: 'Auto', 2: 'Ein'}; // Zahlen (Multistate) oder Logikwert (z.B. Aus/Ein)
                                  und ersetze die Zuweisung:
                                  states = {false: 'geschlossen', true: 'offen'}; // Zahlen (Multistate) oder Logikwert (z.B. Aus/Ein)
                                  • _nico
                                    Same procedure as every day, @paul53. 😂
                                    Ich haben ein kleines Problem und überlege, wie ich es ordentlich lösen kann. Daraus ergibt sich für mich folgende Frage:
                                    Kann ich die den read Parameter noch komplexer aufbauen?
                                    Beispiel:
                                    read = "val < 20 ? true : false"; // Erkennung "Aus" --> false erfolgt automatisch
                                    Aktuell alias.0.Haus.OG-Schlafzimmer.Beschattung.Franzoesischer-Balkon.PositionTarget:
                                    "alias": {
                                          "id": "zwave2.0.Node_026.Multilevel_Switch.targetValue",
                                          "write": "Math.round(val)"
                                    Meine Vorhaben in Worten für alias.0.Haus.OG-Schlafzimmer.Beschattung.Franzoesischer-Balkon.PositionTarget:
                                    • Wenn "zwave2.0.Node_026.Multilevel_Switch.targetValue" != null > nimm den Wert von dem DP.
                                    • Wenn "zwave2.0.Node_026.Multilevel_Switch.targetValue" = null > nimm den Wert von "zwave2.0.Node_015.Binary_Switch.currentValue"
                                    Baue ich dann in den read Parameter einfach ein normales JavaScript-IF?
                                    Gruß Nico
                                      @_nico
                                      Man kann nicht zwischen zwei Datenpunkten umschalten. Dazu benötigt man ein Script.
                                      Wenn es "targetValue" und "currentValue" gibt, müsste der Alias eigentlich so aussehen.
                                      "alias": {
                                            "id": {
                                               "write": "zwave2.0.Node_026.Multilevel_Switch.targetValue",
                                               "read": "zwave2.0.Node_026.Multilevel_Switch.currentValue"
                                      • _nico
                                        @_nico
                                        Schade. 😞
                                        UPDATE: Löse mein Problem jetzt über ein Blockly Skript.
                                        "alias": {
                                              "id": {
                                        Korrekt. Wenn dieser Alias-Datenpunkt wie bei einer Lampe oder einem Schalter genutzt wird. In dem speziellen Fall "Rollläden", erwartet HomeKit für TargetPosition und CurrentPosition zwei voneinander getrennte DPs - damit wird auch eine Animation "Öffnen" und "Schließen" angezeigt - ähnlich wie beim Garagentor.
                                          johannes1702 last edited by
                                          ich habe mal eine Frage zum Skript im ersten Post. Entweder habe ich einen Denkfehler, oder ich mache etwas falsch. 🙂
                                          Ich habe einen Sensor, dessen ID deconz.0.Sensors.13 lautet:
                                          Dafür würde ich gerne einen Alias "Schlafzimmer_Bewegungsmelder" erstellen. Also passe ich das Skript so an:
                                          // Original-Datenpunkt
                                          const idOrigin = 'deconz.0.Sensors.13';
                                          // Alias-Datenpunkt
                                          const idAlias = 'Schlafzimmer_Bewegungsmelder';
                                          Entsprechend wird dann auch der Alias Datenpunkt angelegt. Alledings ohne die states, also z.B. Battery.
                                          Heißt das, dass ich das Skript für jeden Datenpunkt für den ich ein Alias will laufen lassen muss und entsprechend die Anpassungen unter idOrigin und idAlias vornehmen muss? Oder übersehe ich was und das kann automatisch erfolgen?
                                          Danke und LG
                                          Johannes
                                            paul53 @johannes1702 last edited by paul53
                                            @johannes1702 sagte:
                                            Ja, das Skript kann nur auf einzelne Datenpunkte angewendet werden, nicht auf ein Gerät.
                                            314
                                            61072
