    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
      tombox @Sneak-L8 last edited by
      @Sneak-L8 ich bräuchte mehr log im debug mode
        Jaschkopf last edited by Jaschkopf
        Servus. Bekomme seit ein paar Tagen immer wieder Warnungen im Log. Hab mal auf Debug umgestellt:
        vw-connect.0	2020-06-20 09:13:27.417	debug	(15305) {"StoredVehicleDataResponse":{"vin":"WVWZZZAUZLxxxxxxx","vehicleData":{"data":[{"id":"0x0101010001","field":[{"id":"0x0101010001","tsCarSentUtc":"2020-06-20T06:49:51Z","tsCarSent":"2020-06-20T
        vw-connect.0	2020-06-20 09:13:27.361	debug	(15305) {"dwaPushHistory":null}
        vw-connect.0	2020-06-20 09:13:27.347	debug	(15305) {"storedPositionResponse":{"parkingTimeUTC":"2020-06-20T06:49:51Z","position":{"heading":{"direction":166},"carCoordinate":{"latitude":51xxxxxx,"longitude":91xxxxx}}}}
        vw-connect.0	2020-06-20 09:13:27.341	debug	(15305) {"charger":{"settings":{"maxChargeCurrent":{"content":16,"timestamp":"2020-06-20T06:48:53Z"},"chargeModeSelection":{"modificationState":{"content":"canNotBeModified","timestamp":"2020-06-20T06
        vw-connect.0	2020-06-20 09:13:27.338	debug	(15305) {"climater":{"settings":{"targetTemperature":{"timestamp":"2020-06-20T06:48:53Z","content":2960},"climatisationWithoutHVpower":{"timestamp":"2020-06-20T06:48:53Z","content":true},"heaterSource
        vw-connect.0	2020-06-20 09:13:27.314	debug	(15305) {"timer":{"timersAndProfiles":{"timerProfileList":{"timerProfile":[{"timestamp":"2020-06-20T06:48:53Z","profileName":"Standard","profileID":"1","operationCharging":false,"operationClimatisatio
        vw-connect.0	2020-06-20 09:13:27.304	debug	(15305) {"error":{"errorCode":"RS.security.9007","description":"The service: rheating_v1 for VIN: WVWZZZAUZLxxxxxxx could not be found."}}
        vw-connect.0	2020-06-20 09:13:27.260	warn	(15305) This value will not be set in future versions. Please report this to the developer.
        vw-connect.0	2020-06-20 09:13:27.260	warn	(15305) State value to set is invalid for vw-connect.0.WVWZZZAUZLxxxxxxx.destinations.destination.POIContact: The state contains no properties! At least one property is expected!
        vw-connect.0	2020-06-20 09:13:27.252	debug	(15305) {"destinations":[{"destination":{"address":{"addressType":0,"city":"Brühl","country":"Deutschland","street":"Berggeiststraße 31-41","zipCode":"50321"},"destinationSource":"Unknown","geoCoordin
        vw-connect.0	2020-06-20 09:13:26.996	debug	(15305) {"CurrentVehicleDataResponse":{"requestId":"70962588","vin":"WVWZZZAUZLxxxxxxx"}}
        vw-connect.0	2020-06-20 09:13:26.196	debug	(15305) {"vehicleData":{"systemId":"MSG-IVWB2222-1592637206051-48981-VDE","requestId":"MSG-IVWB2222-1592637206051-48981-VDE","brand":"VW","country":"DE","vin":"WVWZZZAUZLxxxxxxx","isConnect":"true","i
        vw-connect.0	2020-06-20 09:13:25.984	debug	(15305) {"userVehicles":{"vehicle":["WVWZZZAUZLxxxxxxx"]}}
        vw-connect.0	2020-06-20 09:13:25.796	debug	(15305) {"firstName":"xxxxxx","lastName":"xxxxxxxx","salutation":"SALUTATION:MR","dateOfBirth":"xxxxxxxxx","preferredContactChannel":"MARKETING_BLOCKADES:EMAIL","nickname":"xxxxxxx","businessIdenti
        vw-connect.0	2020-06-20 09:13:25.644	debug	(15305) getData
        vw-connect.0	2020-06-20 09:13:25.643	debug	(15305) Login successful
        vw-connect.0	2020-06-20 09:13:25.191	debug	(15305) Error: Invalid protocol: carnet:
        vw-connect.0	2020-06-20 09:13:24.593	debug	(15305) {"date":"Sat, 20 Jun 2020 07:13:24 GMT","content-length":"0","connection":"close","cache-control":"no-cache, no-store, max-age=0, must-revalidate","content-language":"en","expires":"0","locati
        vw-connect.0	2020-06-20 09:13:24.592	debug	(15305) ""
        vw-connect.0	2020-06-20 09:13:24.201	debug	(15305) parsePasswordForm
        vw-connect.0	2020-06-20 09:13:23.841	debug	(15305) parseEmailForm
        vw-connect.0	2020-06-20 09:13:23.279	info	(15305) starting. Version 0.0.16 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.18.0, js-controller: 3.1.5
        vw-connect.0	2020-06-20 09:13:23.228	debug	(15305) Plugin sentry Initialize Plugin (enabled=true)
        vw-connect.0	2020-06-20 09:13:19.415	info	(28476) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        vw-connect.0	2020-06-20 09:13:19.415	info	(28476) terminating
        vw-connect.0	2020-06-20 09:13:19.414	info	(28476) cleaned everything up...
        vw-connect.0	2020-06-20 09:13:19.414	info	(28476) Got terminate signal TERMINATE_YOURSELF
        Ich hoffe das Log hilft weiter. Habe aber meine persönlichen Daten entfernt.
        Fahrzeug ist ein VW eGolf Bj 10/2019
        Gruß Jaschkopf
          tombox @Jaschkopf last edited by
          @Jaschkopf der log zeigt keine Auffälligkeiten kannst ihn wieder löschen. Die Fehler können ignoriert werde
            Hier mal ein Auszug per Debug:
            2020-06-20 10:28:18.449 - info: vw-connect.0 (2825) starting. Version 0.0.17 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v10.20.1
            2020-06-20 10:28:20.244 - debug: vw-connect.0 (2825) parseEmailForm
            2020-06-20 10:28:21.209 - debug: vw-connect.0 (2825) parsePasswordForm
            2020-06-20 10:28:21.578 - debug: vw-connect.0 (2825) ""
            2020-06-20 10:28:21.579 - debug: vw-connect.0 (2825) {"date":"Sat, 20 Jun 2020 08:28:21 GMT","content-length":"0","connection":"close","cache-control":"no-cache, no-store, max-age=0, must-revalidate","content-language":"en","expires":"0","location":"https://identity.vwgroup.io/oidc/v1/oauth/sso?clientId=9496332b-ea03-4091-a224-8c746b885068@apps_vw-dilab_com&relayState=7c52e086ed6d4f773d2f870126455ff7f4ec738d&userId=<xxx>&HMAC=5ac48fd0881812bce073ffd2d58d70a8e0e099a2d667f5c2ec43967d00d044c8","pragma":"no-cache","strict-transport-security":"max-age=31536000 ; includeSubDomains","x-content-type-options":"nosniff","x-frame-options":"DENY","x-vcap-request-id":"<xxx>","x-xss-protection":"1; mode=block"}
            2020-06-20 10:28:22.507 - debug: vw-connect.0 (2825) Error: Invalid protocol: carnet:
            2020-06-20 10:28:23.124 - debug: vw-connect.0 (2825) Login successful
            2020-06-20 10:28:23.127 - debug: vw-connect.0 (2825) getData
            2020-06-20 10:28:23.318 - debug: vw-connect.0 (2825) {"firstName":"Techn. User","lastName":"ioBroker","salutation":"SALUTATION:MR","preferredContactChannel":"MARKETING_BLOCKADES:EMAIL","nickname":"Techn. User i.","businessIdentifierType":"BUSINESS_IDENTIFIER_TYPE:MBB_ID","businessIdentifierValue":"<xxx>","userIsPrivateIndicator":true,"preferredLanguage":"de"}
            2020-06-20 10:28:23.615 - debug: vw-connect.0 (2825) {"userVehicles":{"vehicle":["WVWZZZ<xxx>","WVWZZZ<xxx>7"]}}
            2020-06-20 10:28:23.635 - debug: vw-connect.0 (2825) getHomeRegion
            2020-06-20 10:28:23.640 - debug: vw-connect.0 (2825) getHomeRegion
            2020-06-20 10:28:24.876 - debug: vw-connect.0 (2825) [object Object]
            2020-06-20 10:28:25.038 - debug: vw-connect.0 (2825) [object Object]
            2020-06-20 10:28:25.249 - error: vw-connect.0 (2825) 403
            2020-06-20 10:28:25.252 - error: vw-connect.0 (2825) status update Failed
            2020-06-20 10:28:25.695 - debug: vw-connect.0 (2825) {"vehicleDataDetail":{"systemId":"XID_APP_VW","requestId":"MSG-IVWB2193-1592641705154-25916-VDE","brand":"VW","country":"DE","vin":"WVWZZZ<xxx>","isConnect":"true","isConnectSorglosReady":"false","vehicleDevices":{"vehicleDevice":[{"deviceType":"INFOTAINMENT","ecuGeneration":"MIB2high"},{"deviceType":"TELEMATICS","deviceId":"WVWZZZ<xxx>@75","ecuGeneration":"OCU2","embeddedSim":{"identification":{"type":"ICCID","content":"89314404000624733177"},"imei":"<xxx>","mno":"vodafone"}}]},"carportData":{"modelCode":"BE23D1","modelName":"e-GOLF COMFO 100 E1F","modelYear":"2019","color":"LA7W","countryCode":"DE","engine":"EAZ","mmi":"7UG","transmission":"RYG"}}}
            2020-06-20 10:28:25.785 - debug: vw-connect.0 (2825) {"vehicleDataDetail":{"systemId":"XID_APP_VW","requestId":"MSG-IVWB2220-1592641705011-19521-VDE","brand":"VW","country":"DE","vin":"WVWZZZ<xxx>","isConnect":"true","isConnectSorglosReady":"false","vehicleDevices":{"vehicleDevice":[{"deviceType":"INFOTAINMENT","ecuGeneration":"MIB2high"},{"deviceType":"TELEMATICS","deviceId":"WVWZZZ<xxx>@75","ecuGeneration":"OCU2","embeddedSim":{"identification":{"type":"ICCID","content":"89314404000394039177"},"imei":"<xxx>","mno":"vodafone"}}]},"carportData":{"modelCode":"BE23D1","modelName":"e-GOLF COMFO 100 E1F","modelYear":"2018","color":"LC9A","countryCode":"DE","engine":"EAZ","mmi":"7UG","transmission":"RYG"}}}
            2020-06-20 10:28:25.856 - debug: vw-connect.0 (2825) {"CurrentVehicleDataResponse":{"requestId":"70972528","vin":"WVWZZZ<xxx>"}}
            2020-06-20 10:28:26.137 - debug: vw-connect.0 (2825) {"error":{"errorCode":"dti.ge.unknown","description":"Internal server error"}}
            2020-06-20 10:28:26.143 - debug: vw-connect.0 (2825) {"error":{"errorCode":"tripstatistics.bs.notacceptable","description":"Not Acceptable"}}
            2020-06-20 10:28:26.200 - debug: vw-connect.0 (2825) {"climater":{"settings":{"targetTemperature":{"timestamp":"2020-06-13T17:18:11Z","content":2935},"climatisationWithoutHVpower":{"timestamp":"2020-06-13T17:18:11Z","content":true},"heaterSource":{"timestamp":"2020-06-13T17:18:11Z","content":"electric"}},"status":{"climatisationStatusData":{"climatisationState":{"timestamp":"2020-06-20T07:35:45Z","content":"off"},"climatisationStateErrorCode":{"timestamp":"2020-06-20T07:35:45Z","content":0},"remainingClimatisationTime":{"timestamp":"2020-06-20T07:35:45Z","content":16},"climatisationReason":{"timestamp":"2020-06-20T07:35:45Z","content":"immediate"}},"windowHeatingStatusData":{"windowHeatingStateFront":{"timestamp":"2020-01-29T17:58:50Z","content":"off"},"windowHeatingStateRear":{"timestamp":"2020-01-29T17:58:50Z","content":"off"},"windowHeatingErrorCode":{"timestamp":"2020-01-29T17:58:50Z","content":0}},"temperatureStatusData":{"outdoorTemperature":{"timestamp":"2020-06-20T07:35:51Z","content":2926}}}}}
            2020-06-20 10:28:26.268 - debug: vw-connect.0 (2825) {"error":{"errorCode":"dwap.bs.notacceptable","description":"Not Acceptable"}}
            2020-06-20 10:28:26.308 - debug: vw-connect.0 (2825) {"error":{"errorCode":"batterycharge.bs.notacceptable","description":"Not Acceptable"}}
            2020-06-20 10:28:26.334 - debug: vw-connect.0 (2825) {"error":{"errorCode":"RS.security.9007","description":"The service: rheating_v1 for VIN: WVWZZZ<xxx> could not be found."}}
            2020-06-20 10:28:26.346 - debug: vw-connect.0 (2825) {"findCarResponse":{"Position":{"timestampCarSent":"2020-06-20T09:35:39","timestampTssReceived":"2020-06-20T07:35:51Z","carCoordinate":{"latitude":49101713,"longitude":8654078},"timestampCarSentUTC":"2020-06-20T07:35:44Z","timestampCarCaptured":"2020-06-20T09:35:39"}}}
            2020-06-20 10:28:26.363 - debug: vw-connect.0 (2825) {"StoredVehicleDataResponse":{"vin":"WVWZZZ<xxx>","vehicleData":{"data":[{"id":"0x0101010001","field":[{"id":"0x0101010001","tsCarSentUtc":"2020-06-20T08:18:04Z","tsCarSent":"2000-01-01T00:00:00","tsCarCaptured":"2000-01-01T00:00:00","tsTssReceivedUtc":"2020-06-20T08:18:11Z","milCarCaptured":0,"milCarSent":0,"value":"echo"}]},{"id":"0x0101010002","field":[{"id":"0x0101010002","tsCarSentUtc":"2020-06-20T07:35:44Z","tsCarSent":"2020-06-20T09:35:39","tsCarCaptured":"2020-06-20T09:35:39","tsTssReceivedUtc":"2020-06-20T07:35:51Z","milCarCaptured":38313,"milCarSent":38313,"value":"38313"}]},{"id":"0x0203FFFFFF","field":[{"id":"0x0203010001","tsCarSentUtc":"2020-06-20T07:35:44Z","tsCarSent":"2020-06-20T09:35:39","tsCarCaptured":"2020-06-19T17:15:01","tsTssReceivedUtc":"2020-06-20T07:35:51Z","milCarCaptured":38297,"milCarSent":38313,"value":null},{"id":"0x0203010002","tsCarSentUtc":"2020-06-20T07:35:44Z","tsCarSent":"2020-06-20T09:35:39","tsCarCaptured":"2020-06-19T17:15:01","tsTssReceivedUtc":"2020-06-20T07:35:51Z","milCarCaptured":38297,"milCarSent":38313,"value":null},{"id":"0x0203010003","tsCarSentUtc":"2020-06-20T07:35:44Z","tsCarSent":"2020-06-20T09:35:39","tsCarCaptured":"2020-06-19T17:15:01","tsTssReceivedUtc":"2020-06-20T07:35:51Z","milCarCaptured":38297,"milCarSent":38313,"value":"-22100","unit":"km","textId":"interval.inspection.distance"},
            Es geht dabei um das 2. aufgeführte Auto.
              @Sneak-L8 Ich habe eine neue version in github hochgeladen bitte nochmal testen
                Sneak-L8 last edited by Sneak-L8
                Leider weiterhin der gleiche Fehler 403.
                Auch nachdem das 2. Fahrzeug aus dem Portal gelöscht wurde.
                vw-connect.0	2020-06-21 13:09:55.990	error	(11466) status update Failed
                vw-connect.0	2020-06-21 13:09:55.988	error	(11466) 403
                  Seit gestern ca. 13 Uhr sind die Fehler nun weg. Jetzt scheint der Adapter stabil zu laufen. Vielleicht hat sich das Löschen des 2. Fahrzeugs nicht gleich ausgewirkt.
                    kalled last edited by
                    bei mir funktioniert der abruf vom Akkustand in der 0.0.17 nicht, sobald ich auf 0.0.16 zurück gehe klappt es.
                    Es geht um dieses Objekt:
                    vw-connect.0.<Seriennummer>.charger.status.batteryStatusData.stateOfCharge.content
                    Ist das ein bekannter Fehler?
                    Danke & viele Grüße
                    Kalle
                      Ich würde sagen, ist nicht bekannt. Bei mir wird der SoC korrekt übermittelt (gerade gepürft).
                      tombox wird es helfen, wenn Du Fahrzeugmarke und Typ angibst und einen Blick ins Log wirfst, ob dort bereits (Fehler)Meldungen gechrieben wurden und Du diese dann ggfs. ebenfalls postest.
                        Es ist ein VW eGolf von diesem Jahr. Im Log sehe ich nix spannendes. Habe jetzt durch hin- und herprobieren gesehen, dass bei Downgrade auf 0.0.16 sofort ein Wert für SoC kommt, bei Upgrade auf 0.0.17 nicht.
                          tombox @kalled last edited by
                          @kalled kannst du bitte von GitHub testen und installieren und Bescheid geben ob die Version geht?
                            Servus. Habe den selben Fehler wie @kalled . Bei mir wird der Ladezustand auch nicht mehr abgerufen. Hab deswegen mal alle Objekte des Adapters gelöscht und den Adapter neu gestartet und jetzt werden sie nicht mehr angelegt bzw abgerufen. Version ist auch 0.0.17 und Fahrzeug ein 2019er eGolf.
                            Gruß Jaschkopf
                              kalled @tombox last edited by
                              @tombox erledigt und geht! Vielen Dank
                                @kalled ok dann werde ich mal eine neue Version releasen
                                • pfried
                                  pfried last edited by
                                  Hallo, da ich neu bin, darf ich mal Fragen was man in diesem Fall falsch gemacht hat:
                                  Vielen Dank schon jetzt für sachdienliche Hinweise 😊
                                    tombox @pfried last edited by
                                    @pfried unvollständiges nodejs update
                                    cd /opt/iobroker
                                    npm install canvas --unsafe-perm --production --save --prefix
                                    npm rebuild
                                    pfried 1 Reply Last reply Reply Quote 0
                                    • pfried
                                      pfried @tombox last edited by
                                      @tombox Danke!
                                      • pfried
                                        @tombox: Hallo, ich habe noch eine kurze Frage, bei mir kommt im LOG ab und zu:
                                        Mache ich da was falsch?
                                        Vielen Dank und liebe Grüße
                                        Paul
                                          @pfried Liegt nicht an dir sondern an vw oder mir. Wie oft kam das jetzt und wie lange schon
                                          • pfried
                                            @tombox Guten Morgen, ich habe den fix von Dir am 7.7.2020 vor 12:47h eingespielt und seither habe ich circa 2 oder 3 mal beobachtet. Dachte mir aber anfangs nichts dabei, deshalb habe ich die alten Log-Einträge nicht mehr.
                                            Liebe Grüße Paul
                                            81.1k
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            399
                                            3091
                                            1602582
