    4. JavaScript
    5. [Vorlage] Generisches Fensteroffenskript + Vis
      terne @terne last edited by
      @Pittini
      und der Terrassensensor:
        "type": "state",
        "common": {
          "name": "Terrassentürkontakt:1.STATE",
          "def": "CLOSED",
          "type": "number",
          "read": true,
          "write": false,
          "min": 0,
          "max": 1,
          "states": {
            "0": "CLOSED",
            "1": "OPEN"
          "role": "value.window"
        "native": {
          "MIN": "CLOSED",
          "UNIT": "\"\"",
          "OPERATIONS": 5,
          "MAX": "OPEN",
          "FLAGS": 1,
          "ID": "STATE",
          "TAB_ORDER": 0,
          "TYPE": "ENUM",
          "DEFAULT": "CLOSED",
          "VALUE_LIST": [
            "CLOSED",
            "OPEN"
          "CONTROL": "DOOR_SENSOR.STATE"
        "from": "system.adapter.hm-rega.0",
        "user": "system.user.admin",
        "ts": 1592727381745,
        "_id": "hm-rpc.1.001098A993A02E.1.STATE",
        "acl": {
          "object": 1636,
          "state": 1636,
          "owner": "system.user.admin",
      und die Screenshot dazu:
        Pittini Developer @terne last edited by
        @terne Ok, danke. Da brauch ich bitte noch ein komplettes startlog und das Log beim öffnen des Küchenfensters.
          terne @Pittini last edited by
          @Pittini
          jawohl 🙂
          javascript.0	2020-06-30 20:23:29.351	info	(1182) script.js.common.Fensterscript: Reaching CreateRoomsWithVentWarnings
          javascript.0	2020-06-30 20:23:29.351	info	(1182) script.js.common.Fensterscript: RoomsWithOpenings: Küche 1 gekipptes Fenster<br>
          javascript.0	2020-06-30 20:23:29.351	info	(1182) script.js.common.Fensterscript: CreateOpenRoomsList()
          javascript.0	2020-06-30 20:23:29.351	info	(1182) script.js.common.Fensterscript: RoomsWithTiltedWindows: Küche 1 gekipptes Fenster
          javascript.0	2020-06-30 20:23:29.351	info	(1182) script.js.common.Fensterscript: Reaching CreateRoomsWithTiltedWindowsList
          javascript.0	2020-06-30 20:23:29.351	info	(1182) script.js.common.Fensterscript: RoomsWithOpenWindows: Küche 1 gekipptes Fenster
          javascript.0	2020-06-30 20:23:29.351	info	(1182) script.js.common.Fensterscript: Reaching CreateRoomsWithOpenWindowsList
          javascript.0	2020-06-30 20:23:29.350	info	(1182) script.js.common.Fensterscript: RoomsWithOpenDoors: Keine Tür/en geöffnet
          javascript.0	2020-06-30 20:23:29.350	info	(1182) script.js.common.Fensterscript: Reaching CreateRoomsWithOpenDoorsList
          javascript.0	2020-06-30 20:23:29.350	info	(1182) script.js.common.Fensterscript: Reaching CreateRoomsWithVentWarnings
          javascript.0	2020-06-30 20:23:29.350	info	(1182) script.js.common.Fensterscript: Room 4 = Terrassentür is open or disabled, no vent warning set
          javascript.0	2020-06-30 20:23:29.350	info	(1182) script.js.common.Fensterscript: Reaching VentCheck x=4 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593525272635
          javascript.0	2020-06-30 20:23:29.349	info	(1182) script.js.common.Fensterscript: Room 3 = Küche is open or disabled, no vent warning set
          javascript.0	2020-06-30 20:23:29.349	info	(1182) script.js.common.Fensterscript: Reaching VentCheck x=3 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593525862375
          javascript.0	2020-06-30 20:23:29.349	info	(1182) script.js.common.Fensterscript: Reaching CreateRoomsWithVentWarnings
          javascript.0	2020-06-30 20:23:29.349	info	(1182) script.js.common.Fensterscript: Room 2 = Keller2 is open or disabled, no vent warning set
          javascript.0	2020-06-30 20:23:29.349	info	(1182) script.js.common.Fensterscript: Reaching VentCheck x=2 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593525272635
          javascript.0	2020-06-30 20:23:29.349	info	(1182) script.js.common.Fensterscript: Room 1 = Haustür is open or disabled, no vent warning set
          javascript.0	2020-06-30 20:23:29.349	info	(1182) script.js.common.Fensterscript: Reaching VentCheck x=1 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593525272635
          javascript.0	2020-06-30 20:23:29.349	info	(1182) script.js.common.Fensterscript: Room 0 = Garagentür is open or disabled, no vent warning set
          javascript.0	2020-06-30 20:23:29.349	info	(1182) script.js.common.Fensterscript: Reaching VentCheck x=0 Init=true VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593525272635
          javascript.0	2020-06-30 20:23:29.348	info	(1182) script.js.common.Fensterscript: Offene Türen gesamt= 0
          javascript.0	2020-06-30 20:23:29.348	info	(1182) script.js.common.Fensterscript: Alle Türen geschlossen.
          javascript.0	2020-06-30 20:23:29.348	info	(1182) script.js.common.Fensterscript: Offene Fenster gesamt= 1
          javascript.0	2020-06-30 20:23:29.348	info	(1182) script.js.common.Fensterscript: reaching ClearWarnTime - [x] = 4
          javascript.0	2020-06-30 20:23:29.348	info	(1182) script.js.common.Fensterscript: RoomOpenDoorCount[TempRoomIndex]=0 TempRoom=Terrassentür TempRoomIndex=4
          javascript.0	2020-06-30 20:23:29.348	info	(1182) script.js.common.Fensterscript: reaching CheckWindow, SensorVal[4]=closed SensorOldVal= TempRoom=Terrassentür SensorType[x]=Door TempRoomIndex=4
          javascript.0	2020-06-30 20:23:29.348	info	(1182) script.js.common.Fensterscript: Reaching GetRoom x=4
          javascript.0	2020-06-30 20:23:29.347	info	(1182) script.js.common.Fensterscript: Reaching CheckForHmShit val=0 typof val=string x=4 Sensor[x]=hm-rpc.1.001098A993A02E.1.STATE
          javascript.0	2020-06-30 20:23:29.347	info	(1182) script.js.common.Fensterscript: Offene Türen gesamt= 0
          javascript.0	2020-06-30 20:23:29.347	info	(1182) script.js.common.Fensterscript: Alle Türen geschlossen.
          javascript.0	2020-06-30 20:23:29.347	info	(1182) script.js.common.Fensterscript: Offene Fenster gesamt= 1
          javascript.0	2020-06-30 20:23:29.347	info	(1182) script.js.common.Fensterscript: reaching ClearWarnTime - [x] = 0
          javascript.0	2020-06-30 20:23:29.347	info	(1182) script.js.common.Fensterscript: RoomOpenDoorCount[TempRoomIndex]=0 TempRoom=Garagentür TempRoomIndex=0
          javascript.0	2020-06-30 20:23:29.347	info	(1182) script.js.common.Fensterscript: reaching CheckWindow, SensorVal[3]=closed SensorOldVal= TempRoom=Garagentür SensorType[x]=Door TempRoomIndex=0
          javascript.0	2020-06-30 20:23:29.347	info	(1182) script.js.common.Fensterscript: Reaching GetRoom x=3
          javascript.0	2020-06-30 20:23:29.347	info	(1182) script.js.common.Fensterscript: Reaching CheckForHmShit val=0 typof val=string x=3 Sensor[x]=hm-rpc.1.00109A498AE939.1.STATE
          javascript.0	2020-06-30 20:23:29.346	info	(1182) script.js.common.Fensterscript: Offene Türen gesamt= 0
          javascript.0	2020-06-30 20:23:29.346	info	(1182) script.js.common.Fensterscript: Alle Türen geschlossen.
          javascript.0	2020-06-30 20:23:29.346	info	(1182) script.js.common.Fensterscript: Offene Fenster gesamt= 1
          javascript.0	2020-06-30 20:23:29.346	info	(1182) script.js.common.Fensterscript: reaching ClearWarnTime - [x] = 1
          javascript.0	2020-06-30 20:23:29.346	info	(1182) script.js.common.Fensterscript: RoomOpenDoorCount[TempRoomIndex]=0 TempRoom=Haustür TempRoomIndex=1
          javascript.0	2020-06-30 20:23:29.346	info	(1182) script.js.common.Fensterscript: reaching CheckWindow, SensorVal[2]=closed SensorOldVal= TempRoom=Haustür SensorType[x]=Door TempRoomIndex=1
          javascript.0	2020-06-30 20:23:29.346	info	(1182) script.js.common.Fensterscript: Reaching GetRoom x=2
          javascript.0	2020-06-30 20:23:29.346	info	(1182) script.js.common.Fensterscript: Reaching CheckForHmShit val=0 typof val=string x=2 Sensor[x]=hm-rpc.1.00109709ADC2FC.1.STATE
          javascript.0	2020-06-30 20:23:29.345	info	(1182) script.js.common.Fensterscript: Offene Türen gesamt= 0
          javascript.0	2020-06-30 20:23:29.345	info	(1182) script.js.common.Fensterscript: Alle Türen geschlossen.
          javascript.0	2020-06-30 20:23:29.345	info	(1182) script.js.common.Fensterscript: Offene Fenster gesamt= 1
          javascript.0	2020-06-30 20:23:29.344	info	(1182) script.js.common.Fensterscript: reaching ClearWarnTime - [x] = 2
          javascript.0	2020-06-30 20:23:29.344	info	(1182) script.js.common.Fensterscript: reaching CheckWindow, SensorVal[1]=closed SensorOldVal= TempRoom=Keller2 SensorType[x]=Window TempRoomIndex=2
          javascript.0	2020-06-30 20:23:29.344	info	(1182) script.js.common.Fensterscript: Reaching GetRoom x=1
          javascript.0	2020-06-30 20:23:29.344	info	(1182) script.js.common.Fensterscript: hm-rpc.0.NEQ1476360.1.STATE hat Zustandstext CLOSED, Wert= 0 Wert wird durch Zustandstext ersetzt
          javascript.0	2020-06-30 20:23:29.343	info	(1182) script.js.common.Fensterscript: Reaching CheckForHmShit val=0 typof val=string x=1 Sensor[x]=hm-rpc.0.NEQ1476360.1.STATE
          javascript.0	2020-06-30 20:23:29.343	info	(1182) script.js.common.Fensterscript: Offene Türen gesamt= 0
          javascript.0	2020-06-30 20:23:29.343	info	(1182) script.js.common.Fensterscript: Alle Türen geschlossen.
          javascript.0	2020-06-30 20:23:29.343	info	(1182) script.js.common.Fensterscript: Offene Fenster gesamt= 1
          javascript.0	2020-06-30 20:23:29.343	info	(1182) script.js.common.Fensterscript: TiltedWindowCount=1 RoomTiltedWindowCount=1 TempRoomIndex=3
          javascript.0	2020-06-30 20:23:29.343	info	(1182) script.js.common.Fensterscript: Reaching tilted+ in checkWindow
          javascript.0	2020-06-30 20:23:29.343	info	(1182) script.js.common.Fensterscript: Setting Interval to Room:Küche
          javascript.0	2020-06-30 20:23:29.342	info	(1182) script.js.common.Fensterscript: SendWindowWarnMsg=true TempRoomIndex=3
          javascript.0	2020-06-30 20:23:29.342	info	(1182) script.js.common.Fensterscript: RoomOpenWindowCount für Küche=1
          javascript.0	2020-06-30 20:23:29.342	info	(1182) script.js.common.Fensterscript: reaching CheckWindow, SensorVal[0]=tilted SensorOldVal= TempRoom=Küche SensorType[x]=Window TempRoomIndex=3
          javascript.0	2020-06-30 20:23:29.342	info	(1182) script.js.common.Fensterscript: Reaching GetRoom x=0
          javascript.0	2020-06-30 20:23:29.342	info	(1182) script.js.common.Fensterscript: Reaching CheckForHmShit val=1 typof val=string x=0 Sensor[x]=hm-rpc.1.00109709AAA7C6.1.STATE
          javascript.0	2020-06-30 20:23:29.341	info	(1182) script.js.common.Fensterscript: x=4=Terrassentür SendWindowWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
          javascript.0	2020-06-30 20:23:29.341	info	(1182) script.js.common.Fensterscript: x=3=Küche SendWindowWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
          javascript.0	2020-06-30 20:23:29.341	info	(1182) script.js.common.Fensterscript: x=2=Keller2 SendWindowWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
          javascript.0	2020-06-30 20:23:29.341	info	(1182) script.js.common.Fensterscript: x=1=Haustür SendWindowWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
          javascript.0	2020-06-30 20:23:29.341	info	(1182) script.js.common.Fensterscript: x=0=Garagentür SendWindowWarnMsg=true SendVentMsg=true SendWindowOpenCloseMsg=true SendDoorOpenCloseMsg=true
          javascript.0	2020-06-30 20:23:29.341	info	(1182) script.js.common.Fensterscript: CreateStates fertig!
          javascript.0	2020-06-30 20:23:29.339	info	(1182) script.js.common.Fensterscript: registered 0 subscriptions and 0 schedules
          javascript.0	2020-06-30 20:23:29.336	info	(1182) script.js.common.Fensterscript: Raum- 4 = Terrassentür hat Türsensor/en
          javascript.0	2020-06-30 20:23:29.336	info	(1182) script.js.common.Fensterscript: Raum- 3 = Garagentür hat Türsensor/en
          javascript.0	2020-06-30 20:23:29.336	info	(1182) script.js.common.Fensterscript: Raum- 2 = Haustür hat Türsensor/en
          javascript.0	2020-06-30 20:23:29.335	info	(1182) script.js.common.Fensterscript: Raum- 1 = Keller2 hat Fenstersensor/en
          javascript.0	2020-06-30 20:23:29.335	info	(1182) script.js.common.Fensterscript: Raum- 0 = Küche hat Fenstersensor/en
          javascript.0	2020-06-30 20:23:29.335	info	(1182) script.js.common.Fensterscript: starting Fensterskript, Version 1.6.3
          javascript.0	2020-06-30 20:23:29.331	info	(1182) Start javascript script.js.common.Fensterscript
          javascript.0	2020-06-30 20:23:25.499	info	(1182) script.js.common.Fensterscript: reaching ClearWarnTime - [x] = 4
          javascript.0	2020-06-30 20:23:25.499	info	(1182) script.js.common.Fensterscript: Clearing Interval for 3
          javascript.0	2020-06-30 20:23:25.498	info	(1182) script.js.common.Fensterscript: reaching ClearWarnTime - [x] = 3
          javascript.0	2020-06-30 20:23:25.498	info	(1182) script.js.common.Fensterscript: reaching ClearWarnTime - [x] = 2
          javascript.0	2020-06-30 20:23:25.498	info	(1182) script.js.common.Fensterscript: reaching ClearWarnTime - [x] = 1
          javascript.0	2020-06-30 20:23:25.498	info	(1182) script.js.common.Fensterscript: reaching ClearWarnTime - [x] = 0
          javascript.0	2020-06-30 20:23:25.497	info	(1182) Stop script script.js.common.Fensterscript
          und das Öffnen des Fensters:
          javascript.0	2020-06-30 20:27:15.098	info	(1182) script.js.common.Fensterscript: RoomsWithOpenings: Küche 1 gekipptes Fenster<br>
          javascript.0	2020-06-30 20:27:15.098	info	(1182) script.js.common.Fensterscript: CreateOpenRoomsList()
          javascript.0	2020-06-30 20:27:15.098	info	(1182) script.js.common.Fensterscript: RoomsWithOpenDoors: Keine Tür/en geöffnet
          javascript.0	2020-06-30 20:27:15.097	info	(1182) script.js.common.Fensterscript: Reaching CreateRoomsWithOpenDoorsList
          javascript.0	2020-06-30 20:27:15.097	info	(1182) script.js.common.Fensterscript: RoomsWithTiltedWindows: Küche 1 gekipptes Fenster
          javascript.0	2020-06-30 20:27:15.097	info	(1182) script.js.common.Fensterscript: Reaching CreateRoomsWithTiltedWindowsList
          javascript.0	2020-06-30 20:27:15.097	info	(1182) script.js.common.Fensterscript: RoomsWithOpenWindows: Küche 1 gekipptes Fenster
          javascript.0	2020-06-30 20:27:15.097	info	(1182) script.js.common.Fensterscript: Reaching CreateRoomsWithOpenWindowsList
          javascript.0	2020-06-30 20:27:15.097	info	(1182) script.js.common.Fensterscript: RoomStateTimeStamp at checkWindow= 1593541635095 ms =30.06.2020 20:27:15
          javascript.0	2020-06-30 20:27:15.097	info	(1182) script.js.common.Fensterscript: Reaching CreateRoomsWithVentWarnings
          javascript.0	2020-06-30 20:27:15.097	info	(1182) script.js.common.Fensterscript: Room 3 = Küche is open or disabled, no vent warning set
          javascript.0	2020-06-30 20:27:15.097	info	(1182) script.js.common.Fensterscript: Reaching VentCheck x=3 Init=false VentwarnTime[x]=0 RoomStateTimeStamp[x]=1593541635095
          javascript.0	2020-06-30 20:27:15.097	info	(1182) script.js.common.Fensterscript: Offene Türen gesamt= 0
          javascript.0	2020-06-30 20:27:15.096	info	(1182) script.js.common.Fensterscript: Alle Türen geschlossen.
          javascript.0	2020-06-30 20:27:15.096	info	(1182) script.js.common.Fensterscript: Offene Fenster gesamt= 1
          javascript.0	2020-06-30 20:27:15.096	info	(1182) script.js.common.Fensterscript: TiltedWindowCount=1 RoomTiltedWindowCount=1 TempRoomIndex=3
          javascript.0	2020-06-30 20:27:15.096	info	(1182) script.js.common.Fensterscript: Reaching tilted+ in checkWindow
          javascript.0	2020-06-30 20:27:15.096	info	(1182) script.js.common.Fensterscript: Setting Interval to Room:Küche
          javascript.0	2020-06-30 20:27:15.095	info	(1182) script.js.common.Fensterscript: SendWindowWarnMsg=true TempRoomIndex=3
          javascript.0	2020-06-30 20:27:15.095	info	(1182) script.js.common.Fensterscript: TempMessageLog=30.06.2020 20:27:15: Küche Fenster gekippt!,30.06.2020 20:25:46: Küche Fenster geschlossen!,30.06.2020 20:22:05: Terrassentür Tür geschlossen!,30
          javascript.0	2020-06-30 20:27:15.095	info	(1182) script.js.common.Fensterscript: Reaching WriteMessageLog, Message=Küche Fenster gekippt!
          javascript.0	2020-06-30 20:27:15.095	info	(1182) script.js.common.Fensterscript: Reaching Meldung, msg= Küche Fenster gekippt!
          javascript.0	2020-06-30 20:27:15.095	info	(1182) script.js.common.Fensterscript: Küche Fenster gekippt
          javascript.0	2020-06-30 20:27:15.095	info	(1182) script.js.common.Fensterscript: RoomOpenWindowCount für Küche=1
          javascript.0	2020-06-30 20:27:15.094	info	(1182) script.js.common.Fensterscript: reaching CheckWindow, SensorVal[0]=tilted SensorOldVal=closed TempRoom=Küche SensorType[x]=Window TempRoomIndex=3
          javascript.0	2020-06-30 20:27:15.094	info	(1182) script.js.common.Fensterscript: Reaching GetRoom x=0
          javascript.0	2020-06-30 20:27:15.094	info	(1182) script.js.common.Fensterscript: Reaching CheckForHmShit val=1 typof val=string x=0 Sensor[x]=hm-rpc.1.00109709AAA7C6.1.STATE
          javascript.0	2020-06-30 20:27:15.094	info	(1182) script.js.common.Fensterscript: Ignore Timeout for 0 exceeded, Value change happend, starting Functions
          javascript.0	2020-06-30 20:27:15.094	info	(1182) script.js.common.Fensterscript: InTimeout - Trigger= 0 Wert= 1 Alter Wert= 0
          javascript.0	2020-06-30 20:27:05.092	info	(1182) script.js.common.Fensterscript: Activating Ignore Timeout for 0, Value to ignore=closed
          javascript.0	2020-06-30 20:27:05.092	info	(1182) script.js.common.Fensterscript: Reaching CheckForHmShit val=0 typof val=string x=0 Sensor[x]=hm-rpc.1.00109709AAA7C6.1.STATE
          javascript.0	2020-06-30 20:27:05.092	info	(1182) script.js.common.Fensterscript: Oldstate=0
          javascript.0	2020-06-30 20:27:05.092	info	(1182) script.js.common.Fensterscript: Trigger= 0 Wert= 1 Alter Wert= 0
            @terne Mal bitte folgendes testen:
            Zeile 1062 lautet aktuell:
                if (Sensor[x].indexOf("hm-rpc.0") != -1) { //Prüfen ob Sensor= HM Sensor
            Lösch mal bitte die 0 und gugg obs dann geht.
              sigi234 Forum Testing Most Active @Pittini last edited by
              @Pittini
              Hallo, versteh das nicht warum es in Tagen ist?
              Anzahl der Tage nach der eine Lüftungsempfehlung ausgegeben wird
                Pittini Developer @sigi234 last edited by
                @sigi234 sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
                Weil die meisten halt täglich lüften und ich es deswegen so festgelegt hab. Könnten genausogut Millsekunden sein. Und wenn Du 2mal täglich lüften willst kannste ja 0.5 eingeben.
                  @Pittini sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
                  Danke, das war der entscheidende Hinweis. 😀
                    @Pittini
                    mal wieder perfekt 🙂
                    Funktioniert - vielen Dank
                    • Christoph1337
                      Christoph1337 last edited by
                      @Pittini
                      Ich hätte zwei Fragen zu der aktuellen Version.
                      1. NoMsgAtPresence
                        Ich habe oben einen DP (ist true) dafür angefügt und NoMsgAtPresence = true gesetzt.
                        trotzdem bekomme ich eine Ausgabe über Alexa und Telegram.
                      Macht ich etwas falsch?
                      Neuerdings werden auch Türen erfasst.
                      Kannst du die die Darstellung dafür vielleicht wie folgt anpassen:
                      Wenn ein Raum nur Fenster oder Tür -> eine Spalte.
                      Wenn Raum Fenster und Tür -> zwei Spalten.
                      Das wäre in der Darstellung deutlich schöner, da man in der Regel ja nur an wenigen Türen solche Türsensoren hat.
                        Pittini Developer @Christoph1337 last edited by
                        @Christoph1337 sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
                        NoMsgAtPresence
                        Nein, Bug, is im nächsten update gefixt.
                        Gute Idee, bau ich grad ein.
                          Bibo*13 last edited by
                          erstmal herzlichen Dank für das schöne Skript.
                          Ich habe eine Frage, wäre es möglich auch eine Nachricht auszugeben wenn eine Tür länger aufsteht.
                          Also Ansage wie bei einem Fenster "Tür seit nMinuten ist offen"
                          vielen Dank
                            Pittini Developer @Bibo*13 last edited by
                            @Bibo-13 sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
                            Aktuell nicht, aber ich schau mal wie groß der Aufwand wäre, evtl. bau ichs Dir rein.
                              Ok. Danke. Wäre schön wenns ginge.
                                Is drin. V1.6.5
                                crunchip B 2 Replies Last reply Reply Quote 1
                                  crunchip Forum Testing Most Active @Pittini last edited by crunchip
                                  @Pittini habs nu mal aktualisiert,von V 1.6.3 auf V 1.6.5 ab Zeile 30 Tabelleneinstellungen, muss noch etwas beachtet werden?Bekomme nun aber nach Scriptstart folgendes
                                    Pittini Developer @crunchip last edited by
                                    @crunchip sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
                                    habs nu mal aktualisiert, ab Zeile 30 Tabelleneinstellungen, muss noch etwas beachtet werden?Bekomme nun aber nach Scriptstart folgendes
                                    Ja is klar dass der Fehler kommt, Du mußt schon das ganze Skript aktualisieren, nicht erst ab Zeile 30. Da is ne Variable dazugekommen und eine wurde umbenannt.
                                      @Pittini und die Wäre??
                                      Ich sehe da nix, Zeile 1 hab ich ja geändert auf const Skriptversion = "1.6.5"
                                      Erste Änderung im Script ist bei Zeile 33 const DoorTiltedImg =
                                      Edit, Zeile 19 überlesen🤦
                                      passt wieder👍
                                        rotamint last edited by
                                        ich habe eine Frage zu Zeile 48:
                                        const RoomSortMode = 1; //0= Raumliste unsortiert, 1= alpabetisch sortiert, 2= Benutzerdefinierte Sortierung
                                        Wo kann ich das nach "2 / benutzerdefiniert" einrichten? Ich habe nichts gefunden.
                                        Danke. Gruß Stefan.
                                        Negalein P 2 Replies Last reply Reply Quote 0
                                        • Negalein
                                          Negalein Global Moderator @rotamint last edited by
                                          @Pittini
                                          bei mir muss ich das Script alle 1-2 Tage neu starten, da die Anzahl der offenen Fenster hängenbleibt, bzw. sogar hochgezählt wird bei ein und dem selben Fenster.
                                          Hab noch die 1.5.2, da ich derzeit das mit den Türen nicht benötige.
                                            Pittini Developer @rotamint last edited by
                                            @rotamint sagte in [Vorlage] Generisches Fensteroffenskript + Vis:
                                            Anleitung .6.13
                                            javascript monitoring template
                                            81
                                            768
                                            213594
