    4. FHEM Adapter
    FHEM Adapter
      djsirius last edited by
      Guten Morgen.
      seit dem Update wird meine Logdatei zuspamt mit:
      fhem.0 2020-06-25 09:25:39.752 info (19045) unhandled event FHEM: ---- | at atSpuelmaschinePower Next: 09:25:44 > no sync - no fhemObjects >> jsonlist2 atSpuelmaschinePower
      fhem.0 2020-06-25 09:29:54.787 info (19045) unhandled event FHEM: ---- | at atWaschmaschinePower Next: 09:29:59 > no sync - no fhemObjects >> jsonlist2 atWaschmaschinePower
      fhem.0 2020-06-25 09:29:54.787 info (19045) unhandled event FHEM: ---- | at atWaeschetrocknerPower Next: 09:29:59 > no sync - no fhemObjects >> jsonlist2 atWaeschetrocknerPower
      Weiß jemand was das bedeutet?
      Hier ein ausschnitt aus dem Debug:
      close Zeit
      debug
      Meldung
      fhem.0 2020-06-25 09:33:46.705 debug (1422) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM done {"val":"done","ack":true,"ts":1593070426699,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1593070426642
      fhem.0 2020-06-25 09:33:46.703 info (1422) END ===== Synchronised FHEM in 3915 ms 🙂
      fhem.0 2020-06-25 09:33:46.703 warn (1422) > more info FHEM Adapter visit https://github.com/iobroker-community-adapters/ioBroker.fhem/blob/master/docs/de/README.md
      fhem.0 2020-06-25 09:33:46.702 info (1422) > lastIOBout = ----- not in use - info.Configurations.advancedFunction(false) - fhem.0.info.Info.lastIOBout
      fhem.0 2020-06-25 09:33:46.702 info (1422) > lastSend2ioB = ----- not in use - info.Configurations.advancedFunction(false) - fhem.0.info.Info.lastSend2ioB
      fhem.0 2020-06-25 09:33:46.702 info (1422) > lastInfo = ----- not in use - info.Configurations.advancedFunction(false) - fhem.0.info.Info.lastInfo
      fhem.0 2020-06-25 09:33:46.702 info (1422) > lastError = ----- not in use - info.Configurations.advancedFunction(false) - fhem.0.info.Info.lastError
      fhem.0 2020-06-25 09:33:46.702 info (1422) > lastWarn = ----- not in use - info.Configurations.advancedFunction(false) - fhem.0.info.Info.lastWarn
      fhem.0 2020-06-25 09:33:46.701 info (1422) > Number devices of FHEM (ignored) = 2 - fhem.0.info.Info.numberDevicesFHEMignored
      fhem.0 2020-06-25 09:33:46.701 info (1422) > FHEM alive = true - fhem.0.info.Info.alive
      fhem.0 2020-06-25 09:33:46.701 info (1422) > Number devices of FHEM (synchronized) = 49 - fhem.0.info.Info.numberDevicesFHEMsync
      fhem.0 2020-06-25 09:33:46.701 info (1422) > Number of objects IOB in = 855 - fhem.0.info.Info.numberObjectsIOBin
      fhem.0 2020-06-25 09:33:46.701 info (1422) > Number of objects IOB out (possible) = 0 - fhem.0.info.Info.numberObjectsIOBoutSub
      fhem.0 2020-06-25 09:33:46.700 info (1422) > Number of objects IOB out (detected) = 0 - fhem.0.info.Info.numberObjectsIOBout
      fhem.0 2020-06-25 09:33:46.700 info (1422) > room of fhem.x.info.Configurations.onlySyncRoom exist = false - fhem.0.info.Info.roomioBroker
      fhem.0 2020-06-25 09:33:46.699 info (1422) > Number devices of FHEM (jsonlist2) = 53 - fhem.0.info.Info.numberDevicesFHEM
      fhem.0 2020-06-25 09:33:46.657 info (1422) > Date of main.js = 18.06.20 - fhem.0.info.Info.buildDate
      fhem.0 2020-06-25 09:33:46.657 debug (1422) [stateChange] stateChange (in): fhem.0.info.Commands.lastCommand save {"val":"save","ack":true,"ts":1593070426656,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1593070426
      fhem.0 2020-06-25 09:33:46.647 debug (1422) [stateChange] stateChange (in): fhem.0.info.Info.TEST {"fhem.0.alive":{"id":"fhem.0.alive"},"fhem.0.send2ioB":{"id":"fhem.0.send2ioB"}} {"val":"{"fhem.0.alive":{"id":"fhem.0.alive"},"fhe
      fhem.0 2020-06-25 09:33:46.645 debug (1422) [stateChange] stateChange (in): fhem.0.info.Commands.resultFHEM Wrote configuration to fhem.cfg<br> {"val":"Wrote configuration to fhem.cfg<br>","ack":true,"ts":1593070426642,"q":0,"from":"syst
      fhem.0 2020-06-25 09:33:46.644 debug (1422) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM done {"val":"done","ack":true,"ts":1593070426642,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1593070426642
      fhem.0 2020-06-25 09:33:46.642 debug (1422) [main] [eventFHEM] [processEvent] [parseEvent] [eventNOK] > unhandled event FHEM: global | Global global SAVE > no sync - SAVE or UPDATE
      fhem.0 2020-06-25 09:33:46.642 debug (1422) [main] [eventFHEM] eventFHEM(in): "Global global SAVE"
      fhem.0 2020-06-25 09:33:46.642 debug (1422) fhemIgnoreConfig = {"telnetPort_192.168.1.16_38568":{"id":"telnetPort_192.168.1.16_38568"},"telnetPort_192.168.1.16_38570":{"id":"telnetPort_192.168.1.16_38570"}}
      fhem.0 2020-06-25 09:33:46.641 debug (1422) fhemINs = {}
      fhem.0 2020-06-25 09:33:46.641 debug (1422) fhemIN = {}
      fhem.0 2020-06-25 09:33:46.641 debug (1422) fhemIgnore = {"fhem.0.alive":{"id":"fhem.0.alive"},"fhem.0.send2ioB":{"id":"fhem.0.send2ioB"}}
      fhem.0 2020-06-25 09:33:46.641 info (1422) STEP 15 ==== info Synchro
      fhem.0 2020-06-25 09:33:46.640 info (1422) > processed 0 event(s) of FHEM saved during synchro
      fhem.0 2020-06-25 09:33:46.640 info (1422) STEP 14 ==== processed saved event(s) of FHEM
      fhem.0 2020-06-25 09:33:46.600 debug (1422) [stateChange] stateChange (in): fhem.0.info.Commands.lastCommand set fhem.0.alive on-for-timer 360 {"val":"set fhem.0.alive on-for-timer 360","ack":true,"ts":1593070426594,"q":0,"from":"system.
      fhem.0 2020-06-25 09:33:46.599 debug (1422) [stateChange] stateChange (in): fhem.0.info.Debug.timeOut null {"val":null,"ack":true,"ts":1593070426594,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1593070426594}
      fhem.0 2020-06-25 09:33:46.598 debug (1422) [stateChange] stateChange (in): fhem.0.info.Debug.numberOut 0 {"val":0,"ack":true,"ts":1593070426594,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1592909961453}
      fhem.0 2020-06-25 09:33:46.597 debug (1422) [stateChange] stateChange (in): fhem.0.info.Debug.timeIn null {"val":null,"ack":true,"ts":1593070426594,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1593070426594}
      fhem.0 2020-06-25 09:33:46.597 debug (1422) [stateChange] stateChange (in): fhem.0.info.Debug.numberIn 0 {"val":0,"ack":true,"ts":1593070426594,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1593070426594}
      fhem.0 2020-06-25 09:33:46.596 debug (1422) [stateChange] stateChange (in): fhem.0.info.Info.alive true {"val":true,"ack":true,"ts":1593070426594,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1593070426594}
      fhem.0 2020-06-25 09:33:46.593 info (1422) stateChange (out): fhem.0.info.Commands.sendFHEM | save > save
      fhem.0 2020-06-25 09:33:46.593 debug (1422) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM save {"val":"save","ack":true,"ts":1593070426590,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1593070426590
      fhem.0 2020-06-25 09:33:46.593 debug (1422) [stateChange] stateChange (in): fhem.0.info.Commands.resultFHEM {"val":"","ack":true,"ts":1593070426590,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1592917803259}
      fhem.0 2020-06-25 09:33:46.592 debug (1422) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM done {"val":"done","ack":true,"ts":1593070426589,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1593070426589
      fhem.0 2020-06-25 09:33:46.591 debug (1422) [main] [eventFHEM] [processEvent] [parseEvent] [getAlive] alive true - start
      fhem.0 2020-06-25 09:33:46.590 debug (1422) [main] [eventFHEM] eventFHEM(in): "dummy fhem.0.alive on"
      fhem.0 2020-06-25 09:33:46.582 debug (1422) [stateChange] stateChange (in): fhem.0.info.Commands.lastCommand deleteattr fhem.0.alive event-on-change-reading {"val":"deleteattr fhem.0.alive event-on-change-reading","ack":true,"ts":1593070
      fhem.0 2020-06-25 09:33:46.580 info (1422) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
      fhem.0 2020-06-25 09:33:46.579 debug (1422) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM set fhem.0.alive on-for-timer 360 {"val":"set fhem.0.alive on-for-timer 360","ack":true,"ts":1593070426577,"q":0,"from":"system.ada
      fhem.0 2020-06-25 09:33:46.578 debug (1422) [stateChange] stateChange (in): fhem.0.info.Commands.resultFHEM {"val":"","ack":true,"ts":1593070426577,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1592917803259}
      fhem.0 2020-06-25 09:33:46.578 debug (1422) [main] [eventFHEM] [processEvent] [parseEvent] [eventNOK] > unhandled event FHEM: ---- | Global global DELETEATTR fhem.0.alive event-on-change-reading > no sync - "fhem.0.alive" included in fh
      fhem.0 2020-06-25 09:33:46.577 debug (1422) [main] [eventFHEM] eventFHEM(in): "Global global DELETEATTR fhem.0.alive event-on-change-reading"
      fhem.0 2020-06-25 09:33:46.569 info (1422) stateChange (out): fhem.0.info.Commands.sendFHEM | deleteattr fhem.0.alive event-on-change-reading > deleteattr fhem.0.alive event-on-change-reading
      fhem.0 2020-06-25 09:33:46.568 debug (1422) [stateChange] stateChange (in): fhem.0.info.Commands.sendFHEM deleteattr fhem.0.alive event-on-change-reading {"val":"deleteattr fhem.0.alive event-on-change-reading","ack":true,"ts":1593070426
      fhem.0 2020-06-25 09:33:46.568 debug (1422) [stateChange] stateChange (in): fhem.0.info.Info.alive false {"val":false,"ack":true,"ts":1593070426565,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1593070419604}
      fhem.0 2020-06-25 09:33:46.563 info (1422) > processed 3 stateChange(s) of ioBroker saved during synchro
      fhem.0 2020-06-25 09:33:46.563 info (1422) STEP 13 ==== processed saved stateChange(s) of ioBroker
      fhem.0 2020-06-25 09:33:46.563 info (1422) > save FHEM: Wrote configuration to fhem.cfg
      fhem.0 2020-06-25 09:33:46.563 debug (1422) [setAlive] start setAlive 300 sec
      fhem.0 2020-06-25 09:33:46.563 info (1422) > activate fhem.0.alive room ioB_System every 5 minutes
      fhem.0 2020-06-25 09:33:46.563 info (1422) STEP 12 ==== activate alive and save FHEM
      fhem.0 2020-06-25 09:33:46.562 info (1422) > dummy fhem.0.alive - use to check alive FHEM Adapter in FHEM
      fhem.0 2020-06-25 09:33:46.562 info (1422) > dummy fhem.0.send2ioB - use to set objects/states of ioBroker from FHEM
      fhem.0 2020-06-25 09:33:46.562 info (1422) > room ioB_IN: nothing to do.....
      fhem.0 2020-06-25 09:33:46.561 info (1422) STEP 11 ==== check/create FHEM dummy Devices in room ioB_IN/ioB_System
      fhem.0 2020-06-25 09:33:46.561 info (1422) > delete unused objects (*) > delete 0 channel(s) and 0 state(s)
      fhem.0 2020-06-25 09:33:46.519 info (1422) STEP 10 ===== check delete unused objects
      fhem.0 2020-06-25 09:33:46.518 debug (1422) [syncStates] end
      fhem.0 2020-06-25 09:33:46.468 debug (1422) [stateChange] stateChange (in): fhem.0.vitoconnect.heating_power_consumption_total_unit null {"val":null,"ack":true,"ts":1593070426466,"q":0,"from":"system.adapter.fhem.0","user":"system.user.a
      fhem.0 2020-06-25 09:33:46.466 debug (1422) [syncStates] update state: fhem.0.vitoconnect.heating_power_consumption_total_unit = null > NaN
      fhem.0 2020-06-25 09:33:46.370 debug (1422) [stateChange] stateChange (in): fhem.0.atWaschmaschinePower.state Next: 09:33:44 {"val":"Next: 09:33:44","ack":true,"ts":1593070426368,"q":0,"from":"system.adapter.fhem.0","user":"system.user.a
      fhem.0 2020-06-25 09:33:46.367 debug (1422) [syncStates] update state: fhem.0.atWaschmaschinePower.state = Next: 09:33:39 > Next: 09:33:44
      fhem.0 2020-06-25 09:33:46.322 debug (1422) [stateChange] stateChange (in): fhem.0.atWaeschetrocknerPower.state Next: 09:33:44 {"val":"Next: 09:33:44","ack":true,"ts":1593070426320,"q":0,"from":"system.adapter.fhem.0","user":"system.user
      fhem.0 2020-06-25 09:33:46.319 debug (1422) [syncStates] update state: fhem.0.atWaeschetrocknerPower.state = Next: 09:33:39 > Next: 09:33:44
      fhem.0 2020-06-25 09:33:46.274 debug (1422) [stateChange] stateChange (in): fhem.0.atSpuelmaschinePower.state Next: 09:33:44 {"val":"Next: 09:33:44","ack":true,"ts":1593070426272,"q":0,"from":"system.adapter.fhem.0","user":"system.user.a
      fhem.0 2020-06-25 09:33:46.272 debug (1422) [syncStates] update state: fhem.0.atSpuelmaschinePower.state = Next: 09:33:39 > Next: 09:33:44
      fhem.0 2020-06-25 09:33:46.200 debug (1422) [stateChange] stateChange (in): fhem.0.Rolladen_rechts_Marie.R-powerUpAction null {"val":null,"ack":true,"ts":1593070426199,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":
      fhem.0 2020-06-25 09:33:46.196 debug (1422) [syncStates] update state: fhem.0.Rolladen_rechts_Marie.R-powerUpAction = null > NaN
      fhem.0 2020-06-25 09:33:46.139 debug (1422) [stateChange] stateChange (in): fhem.0.Rolladen_links_Marie.R-powerUpAction null {"val":null,"ack":true,"ts":1593070426138,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1
      fhem.0 2020-06-25 09:33:46.138 debug (1422) [syncStates] update state: fhem.0.Rolladen_links_Marie.R-powerUpAction = null > NaN
      fhem.0 2020-06-25 09:33:46.054 debug (1422) [stateChange] stateChange (in): fhem.0.FileLog_WK_Waschmaschine.linesInTheFile 16067 {"val":16067,"ack":true,"ts":1593070426052,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","
      fhem.0 2020-06-25 09:33:46.051 debug (1422) [syncStates] update state: fhem.0.FileLog_WK_Waschmaschine.linesInTheFile = 16064 > 16067
      fhem.0 2020-06-25 09:33:46.002 debug (1422) [stateChange] stateChange (in): fhem.0.FileLog_WK_Waeschetrockner.linesInTheFile 29079 {"val":29079,"ack":true,"ts":1593070426000,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin"
      fhem.0 2020-06-25 09:33:45.999 debug (1422) [syncStates] update state: fhem.0.FileLog_WK_Waeschetrockner.linesInTheFile = 27746 > 29079
      fhem.0 2020-06-25 09:33:45.951 debug (1422) [stateChange] stateChange (in): fhem.0.FileLog_VitoConnect.linesInTheFile 120312 {"val":120312,"ack":true,"ts":1593070425950,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc"
      fhem.0 2020-06-25 09:33:45.949 debug (1422) [syncStates] update state: fhem.0.FileLog_VitoConnect.linesInTheFile = 89736 > 120312
      fhem.0 2020-06-25 09:33:45.859 debug (1422) [stateChange] stateChange (in): fhem.0.FileLog_K_Spuelmaschine.linesInTheFile 9510 {"val":9510,"ack":true,"ts":1593070425857,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc"
      fhem.0 2020-06-25 09:33:45.857 debug (1422) [syncStates] update state: fhem.0.FileLog_K_Spuelmaschine.linesInTheFile = 8816 > 9510
      fhem.0 2020-06-25 09:33:45.796 debug (1422) [stateChange] stateChange (in): fhem.0.Deckenlampe_Marie.R-powerUpAction null {"val":null,"ack":true,"ts":1593070425795,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1593
      fhem.0 2020-06-25 09:33:45.795 debug (1422) [syncStates] update state: fhem.0.Deckenlampe_Marie.R-powerUpAction = null > NaN
      fhem.0 2020-06-25 09:33:45.731 info (1422) > check update/create 806 state(s) / 806 state(s) to sync
      fhem.0 2020-06-25 09:33:45.730 info (1422) > no auto create of function(s) - fhem.0.info.Configurations.autoFunction (false)
      fhem.0 2020-06-25 09:33:45.729 debug (1422) [syncRoom] (USB-Sticks) fhem.0.myJeeLink,fhem.0.nanoCUL868
      fhem.0 2020-06-25 09:33:45.728 debug (1422) [syncRoom] (Küche) fhem.0.K_Spuelmaschine,fhem.0.K_Spuelmaschine_Power,fhem.0.atSpuelmaschinePower
      fhem.0 2020-06-25 09:33:45.727 debug (1422) [syncRoom] (Heizung) fhem.0.Heizung_Verbrauch,fhem.0.vitoconnect,fhem.0.vitoconnect_rg,fhem.0.vitoconnect_update
      fhem.0 2020-06-25 09:33:45.727 debug (1422) [syncRoom] (Waschküche) fhem.0.FileLog_WK_Waeschetrockner,fhem.0.FileLog_WK_Waschmaschine,fhem.0.WK_Waeschetrockner,fhem.0.WK_Waeschetrockner_Power,fhem.0.WK_Waschmaschine,fhem.0.WK_Waschmaschi
      fhem.0 2020-06-25 09:33:45.726 debug (1422) [syncRoom] (LogFiles) fhem.0.FileLog_Bad_Heizung,fhem.0.FileLog_Buero_Heizung,fhem.0.FileLog_Deckenlampe_Marie,fhem.0.FileLog_K_Spuelmaschine,fhem.0.FileLog_Kueche_Heizung,fhem.0.FileLog_Lichtt
      fhem.0 2020-06-25 09:33:45.726 debug (1422) [stateChange] stateChange (in): fhem.0.info.Info.numberObjectsIOBin 855 {"val":855,"ack":true,"ts":1593070425724,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":15929982900
      fhem.0 2020-06-25 09:33:45.725 debug (1422) [syncRoom] (Marie) fhem.0.Deckenlampe_Marie,fhem.0.Lichttaster_Deckenlampe_Marie,fhem.0.Lichttaster_Deckenlampe_Marie_Btn_01,fhem.0.Lichttaster_Deckenlampe_Marie_Btn_02,fhem.0.Rolladen_links_Ma
      fhem.0 2020-06-25 09:33:45.724 debug (1422) [syncRoom] (System) fhem.0.ActionDetector,fhem.0.WEB,fhem.0.allowed_WEB,fhem.0.allowed_telnetPort,fhem.0.autocreate,fhem.0.eventTypes,fhem.0.global,fhem.0.initialUsbCheck,fhem.0.teleBot,fhem.0.
      fhem.0 2020-06-25 09:33:45.723 info (1422) > check update/create 7 room(s) - fhem.0.info.Configurations.autoRoom (true)
      fhem.0 2020-06-25 09:33:45.673 debug (1422) [syncObjects] update object: fhem.0.vitoconnect_update (channel) - native
      fhem.0 2020-06-25 09:33:45.567 debug (1422) [syncObjects] update object: fhem.0.vitoconnect (channel) - native
      fhem.0 2020-06-25 09:33:45.562 debug (1422) [syncObjects] update object: fhem.0.telnetPort (channel) - native
      fhem.0 2020-06-25 09:33:45.490 debug (1422) [syncObjects] update object: fhem.0.teleBot (channel) - native
      fhem.0 2020-06-25 09:33:45.429 debug (1422) [syncObjects] update object: fhem.0.myJeeLink (channel) - native
      fhem.0 2020-06-25 09:33:45.357 debug (1422) [syncObjects] update object: fhem.0.atWaschmaschinePower (channel) - native
      fhem.0 2020-06-25 09:33:45.305 debug (1422) [syncObjects] update object: fhem.0.atWaeschetrocknerPower (channel) - native
      fhem.0 2020-06-25 09:33:45.252 debug (1422) [syncObjects] update object: fhem.0.atSpuelmaschinePower (channel) - native
      fhem.0 2020-06-25 09:33:45.230 debug (1422) [syncObjects] update object: fhem.0.WK_Waschmaschine (channel) - native
      fhem.0 2020-06-25 09:33:45.167 debug (1422) [syncObjects] update object: fhem.0.WK_Waeschetrockner (channel) - native
      fhem.0 2020-06-25 09:33:45.119 debug (1422) [syncObjects] update object: fhem.0.WEB (channel) - native
      fhem.0 2020-06-25 09:33:45.040 debug (1422) [syncObjects] update object: fhem.0.K_Spuelmaschine (channel) - native
      fhem.0 2020-06-25 09:33:44.950 debug (1422) [stateChange] stateChange (in): fhem.0.info.Info.numberDevicesFHEMsync 49 {"val":49,"ack":true,"ts":1593070424943,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1593070424
      fhem.0 2020-06-25 09:33:44.950 debug (1422) [stateChange] stateChange (in): fhem.0.info.Info.numberObjectsIOBout 0 {"val":0,"ack":true,"ts":1593070424943,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1569060856338}
      fhem.0 2020-06-25 09:33:44.949 debug (1422) [stateChange] stateChange (in): fhem.0.info.Info.numberDevicesFHEMignored 2 {"val":2,"ack":true,"ts":1593070424943,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":159247673
      fhem.0 2020-06-25 09:33:44.949 debug (1422) [stateChange] stateChange (in): fhem.0.info.Info.roomioBroker false {"val":false,"ack":true,"ts":1593070424943,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1569060856338
      fhem.0 2020-06-25 09:33:44.949 debug (1422) [stateChange] stateChange (in): fhem.0.info.Info.numberDevicesFHEM 53 {"val":53,"ack":true,"ts":1593070424943,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1593070424943}
      fhem.0 2020-06-25 09:33:44.946 debug (1422) [main] [eventFHEM] [processEvent] [parseEvent] [eventNOK] > unhandled event FHEM: ---- | at atWaschmaschinePower Next: 09:33:49 > no sync - not in fhemObjects and not global
      fhem.0 2020-06-25 09:33:44.946 debug (1422) [main] [eventFHEM] eventFHEM(in): "at atWaschmaschinePower Next: 09:33:49"
      fhem.0 2020-06-25 09:33:44.946 debug (1422) [main] [eventFHEM] [processEvent] [parseEvent] [eventNOK] > unhandled event FHEM: ---- | dummy WK_Waschmaschine_Power 0 > no sync - not in fhemObjects and not global
      fhem.0 2020-06-25 09:33:44.946 debug (1422) [main] [eventFHEM] eventFHEM(in): "dummy WK_Waschmaschine_Power 0"
      fhem.0 2020-06-25 09:33:44.945 debug (1422) [main] [eventFHEM] [processEvent] [parseEvent] [eventNOK] > unhandled event FHEM: ---- | at atWaeschetrocknerPower Next: 09:33:49 > no sync - not in fhemObjects and not global
      fhem.0 2020-06-25 09:33:44.945 debug (1422) [main] [eventFHEM] eventFHEM(in): "at atWaeschetrocknerPower Next: 09:33:49"
      fhem.0 2020-06-25 09:33:44.945 debug (1422) [main] [eventFHEM] [processEvent] [parseEvent] [eventNOK] > unhandled event FHEM: ---- | dummy WK_Waeschetrockner_Power 0 > no sync - not in fhemObjects and not global
      fhem.0 2020-06-25 09:33:44.945 debug (1422) [main] [eventFHEM] eventFHEM(in): "dummy WK_Waeschetrockner_Power 0"
      fhem.0 2020-06-25 09:33:44.945 debug (1422) [main] [eventFHEM] [processEvent] [parseEvent] [eventNOK] > unhandled event FHEM: ---- | at atSpuelmaschinePower Next: 09:33:49 > no sync - not in fhemObjects and not global
      fhem.0 2020-06-25 09:33:44.945 debug (1422) [main] [eventFHEM] eventFHEM(in): "at atSpuelmaschinePower Next: 09:33:49"
      fhem.0 2020-06-25 09:33:44.945 debug (1422) [main] [eventFHEM] [processEvent] [parseEvent] [eventNOK] > unhandled event FHEM: ---- | dummy K_Spuelmaschine_Power 0 > no sync - not in fhemObjects and not global
      fhem.0 2020-06-25 09:33:44.944 debug (1422) [main] [eventFHEM] eventFHEM(in): "dummy K_Spuelmaschine_Power 0"
      fhem.0 2020-06-25 09:33:44.939 info (1422) > check update/create 855 object(s) / 49 channel(s) and 806 state(s)
      fhem.0 2020-06-25 09:33:44.938 info (1422) STEP 09 ===== Synchro objects, rooms, functions, states
      fhem.0 2020-06-25 09:33:44.938 info (1422) > check channel - 49 Device(s) of FHEM synchronized
      fhem.0 2020-06-25 09:33:44.938 info (1422) > detected 0 objects to send FHEM (ioBout)
      fhem.0 2020-06-25 09:33:44.938 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.vitoconnect_update | name: vitoconnect_update | room: Heizung | role: undefined | function: no | 53/53
      fhem.0 2020-06-25 09:33:44.938 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.vitoconnect_rg | name: Heizung | room: Heizung | role: undefined | function: no | 52/53
      fhem.0 2020-06-25 09:33:44.935 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.vitoconnect | name: vitoconnect | room: Heizung | role: undefined | function: no | 51/53
      fhem.0 2020-06-25 09:33:44.935 info (1422) ignored FHEM device "telnetPort_192.168.1.16_38570" > no sync - room: hidden | 50/53
      fhem.0 2020-06-25 09:33:44.935 info (1422) ignored FHEM device "telnetPort_192.168.1.16_38568" > no sync - room: hidden | 49/53
      fhem.0 2020-06-25 09:33:44.935 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.telnetPort | name: telnetPort | room: System | role: undefined | function: no | 48/53
      fhem.0 2020-06-25 09:33:44.934 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.teleBot | name: teleBot | room: System | role: undefined | function: no | 47/53
      fhem.0 2020-06-25 09:33:44.934 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.nanoCUL868 | name: nanoCUL868 | room: USB-Sticks | role: undefined | function: no | 46/53
      fhem.0 2020-06-25 09:33:44.934 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.myJeeLink | name: myJeeLink | room: USB-Sticks | role: undefined | function: no | 45/53
      fhem.0 2020-06-25 09:33:44.934 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.initialUsbCheck | name: initialUsbCheck | room: System | role: undefined | function: no | 44/53
      fhem.0 2020-06-25 09:33:44.933 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.global | name: global | room: System | role: undefined | function: no | 43/53
      fhem.0 2020-06-25 09:33:44.933 info (1422) ignored FHEM device "fhem.0.send2ioB" > no sync - comment: Auto-created by ioBroker fhem.0 | 42/53
      fhem.0 2020-06-25 09:33:44.933 info (1422) ignored FHEM device "fhem.0.alive" > no sync - comment: Auto-created by ioBroker fhem.0 | 41/53
      fhem.0 2020-06-25 09:33:44.933 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.eventTypes | name: eventTypes | room: System | role: undefined | function: no | 40/53
      fhem.0 2020-06-25 09:33:44.933 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.autocreate | name: autocreate | room: System | role: undefined | function: no | 39/53
      fhem.0 2020-06-25 09:33:44.933 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.atWaschmaschinePower | name: atWaschmaschinePower | room: Waschküche | role: undefined | function: no | 38/53
      fhem.0 2020-06-25 09:33:44.932 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.atWaeschetrocknerPower | name: atWaeschetrocknerPower | room: Waschküche | role: undefined | function: no | 37/53
      fhem.0 2020-06-25 09:33:44.932 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.atSpuelmaschinePower | name: atSpuelmaschinePower | room: Küche | role: undefined | function: no | 36/53
      fhem.0 2020-06-25 09:33:44.932 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.allowed_telnetPort | name: allowed_telnetPort | room: System | role: undefined | function: no | 35/53
      fhem.0 2020-06-25 09:33:44.932 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.allowed_WEB | name: allowed_WEB | room: System | role: undefined | function: no | 34/53
      fhem.0 2020-06-25 09:33:44.932 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.WK_Waschmaschine_Power | name: WK_Waschmaschine_Power | room: Waschküche | role: undefined | function: no | 33/53
      fhem.0 2020-06-25 09:33:44.931 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.WK_Waschmaschine | name: WK_Waschmaschine | room: Waschküche | role: undefined | function: no | 32/53
      fhem.0 2020-06-25 09:33:44.931 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.WK_Waeschetrockner_Power | name: WK_Waeschetrockner_Power | room: Waschküche | role: undefined | function: no | 31/53
      fhem.0 2020-06-25 09:33:44.931 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.WK_Waeschetrockner | name: WK_Waeschetrockner | room: Waschküche | role: undefined | function: no | 30/53
      fhem.0 2020-06-25 09:33:44.931 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.WEB | name: WEB | room: System | role: undefined | function: no | 29/53
      fhem.0 2020-06-25 09:33:44.930 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.Rolladen_rechts_Marie | name: Rolladen_rechts_Marie | room: Marie | role: undefined | function: blind | 28/53
      fhem.0 2020-06-25 09:33:44.929 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.Rolladen_links_Marie | name: Rolladen_links_Marie | room: Marie | role: undefined | function: blind | 27/53
      fhem.0 2020-06-25 09:33:44.929 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.Logfile | name: Logfile | room: LogFiles | role: undefined | function: no | 26/53
      fhem.0 2020-06-25 09:33:44.929 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.Lichttaster_Deckenlampe_Marie_Btn_02 | name: Lichttaster_Deckenlampe_Marie_Btn_02 | room: Marie | role: undefined | function: no | 25/53
      fhem.0 2020-06-25 09:33:44.928 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.Lichttaster_Deckenlampe_Marie_Btn_01 | name: Lichttaster_Deckenlampe_Marie_Btn_01 | room: Marie | role: undefined | function: no | 24/53
      fhem.0 2020-06-25 09:33:44.928 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.Lichttaster_Deckenlampe_Marie | name: Lichttaster_Deckenlampe_Marie | room: Marie | role: undefined | function: no | 23/53
      fhem.0 2020-06-25 09:33:44.928 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.K_Spuelmaschine_Power | name: K_Spuelmaschine_Power | room: Küche | role: undefined | function: no | 22/53
      fhem.0 2020-06-25 09:33:44.927 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.K_Spuelmaschine | name: K_Spuelmaschine | room: Küche | role: undefined | function: no | 21/53
      fhem.0 2020-06-25 09:33:44.927 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.Heizung_Verbrauch | name: Heizung_Verbrauch | room: Heizung | role: undefined | function: no | 20/53
      fhem.0 2020-06-25 09:33:44.927 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.FileLog_Wohnzimmer_Heizung | name: FileLog_HM_42D82F | room: LogFiles | role: undefined | function: no | 19/53
      fhem.0 2020-06-25 09:33:44.927 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.FileLog_WK_Waschmaschine | name: FileLog_WK_Waschmaschine | room: Waschküche | role: undefined | function: no | 18/53
      fhem.0 2020-06-25 09:33:44.926 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.FileLog_WK_Waeschetrockner | name: FileLog_WK_Waeschetrockner | room: Waschküche | role: undefined | function: no | 17/53
      fhem.0 2020-06-25 09:33:44.926 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.FileLog_VitoConnect | name: FileLog_VitoConnect | room: LogFiles | role: undefined | function: no | 16/53
      fhem.0 2020-06-25 09:33:44.926 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.FileLog_Rolladen_rechts_Marie | name: FileLog_Rolladen_rechts_Marie | room: LogFiles | role: undefined | function: no | 15/53
      fhem.0 2020-06-25 09:33:44.925 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.FileLog_Rolladen_links_Marie | name: FileLog_Rolladen_links_Marie | room: LogFiles | role: undefined | function: no | 14/53
      fhem.0 2020-06-25 09:33:44.924 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.FileLog_PCA301_261589 | name: FileLog_PCA301_261589 | room: LogFiles | role: undefined | function: no | 13/53
      fhem.0 2020-06-25 09:33:44.924 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.FileLog_PCA301_261588 | name: FileLog_PCA301_261588 | room: LogFiles | role: undefined | function: no | 12/53
      fhem.0 2020-06-25 09:33:44.924 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.FileLog_PCA301_261500 | name: FileLog_PCA301_261500 | room: LogFiles | role: undefined | function: no | 11/53
      fhem.0 2020-06-25 09:33:44.924 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.FileLog_Marie_Heizung_Rechts | name: FileLog_Marie_Heizung_Rechts | room: LogFiles | role: undefined | function: no | 10/53
      fhem.0 2020-06-25 09:33:44.923 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.FileLog_Marie_Heizung_Links | name: FileLog_Marie_Heizung_Links | room: LogFiles | role: undefined | function: no | 9/53
      fhem.0 2020-06-25 09:33:44.923 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.FileLog_Lichttaster_Deckenlampe_Marie | name: FileLog_Lichttaster_Deckenlampe_Marie | room: LogFiles | role: undefined | function: no | 8/
      fhem.0 2020-06-25 09:33:44.923 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.FileLog_Kueche_Heizung | name: FileLog_HM_4101E9 | room: LogFiles | role: undefined | function: no | 7/53
      fhem.0 2020-06-25 09:33:44.922 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.FileLog_K_Spuelmaschine | name: FileLog_K_Spuelmaschine | room: LogFiles | role: undefined | function: no | 6/53
      fhem.0 2020-06-25 09:33:44.922 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.FileLog_Deckenlampe_Marie | name: FileLog_Deckenlampe_Marie | room: LogFiles | role: undefined | function: no | 5/53
      fhem.0 2020-06-25 09:33:44.922 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.FileLog_Buero_Heizung | name: FileLog_Heizung_Buero | room: LogFiles | role: undefined | function: no | 4/53
      fhem.0 2020-06-25 09:33:44.921 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.FileLog_Bad_Heizung | name: FileLog_Bad_Heizung | room: LogFiles | role: undefined | function: no | 3/53
      fhem.0 2020-06-25 09:33:44.920 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.Deckenlampe_Marie | name: Deckenlampe_Marie | room: Marie | role: undefined | function: no | 2/53
      fhem.0 2020-06-25 09:33:44.918 debug (1422) [main] [syncFHEM] [parseObjects] check channel fhem.0.ActionDetector | name: ActionDetector | room: System | role: undefined | function: no | 1/53
      fhem.0 2020-06-25 09:33:44.918 info (1422) > no sync device(s) with Internals:NAME = info - fhem.0.info.Configurations.ignoreObjectsInternalsNAME (info)
      fhem.0 2020-06-25 09:33:44.918 info (1422) STEP 08 ===== parse Objects - check 53 Device(s) of FHEM detected
      fhem.0 2020-06-25 09:33:44.915 info (1422) > get 53 Device(s) of FHEM
      fhem.0 2020-06-25 09:33:44.912 info (1422) > result of jsonlist2 OK
      fhem.0 2020-06-25 09:33:44.697 debug (1422) [stateChange] stateChange (in): fhem.0.info.connection true {"val":true,"ack":true,"ts":1593070424694,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1593070424694}
      fhem.0 2020-06-25 09:33:44.696 debug (1422) [stateChange] stateChange (in): fhem.0.info.Info.numberObjectsIOBoutSub 0 {"val":0,"ack":true,"ts":1593070424694,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":15690608563
      fhem.0 2020-06-25 09:33:44.692 info (1422) > Connected FHEM telnet 192.168.1.10:7072 - send telnet "jsonlist2"
      fhem.0 2020-06-25 09:33:44.692 info (1422) STEP 07 ===== connect FHEM telnet
      fhem.0 2020-06-25 09:33:44.686 info (1422) > no sync - fhem.0.info.Configurations.allowedIOBin
      fhem.0 2020-06-25 09:33:44.686 info (1422) STEP 06 ===== check Subscribe - check fhem.0.info.Configurations.allowedIOBin
      fhem.0 2020-06-25 09:33:44.684 info (1422) STEP 05 ===== Activate Debug-Mode for channel(s) - check fhem.0.info.Debug.activate
      fhem.0 2020-06-25 09:33:44.683 info (1422) > LOG "ignore FHEM device ....." ignored Devices from FHEM (info.Configurations) - info.Settings.logIgnoreConfigurations (true)
      fhem.0 2020-06-25 09:33:44.683 debug (1422) [main] [getSettings] [getSetting] info.Settings.logIgnoreConfigurations true
      fhem.0 2020-06-25 09:33:44.683 info (1422) > LOG "unhandled event FHEM ....." all events unhandled from FHEM - info.Settings.logUnhandledEventFHEM (true)
      fhem.0 2020-06-25 09:33:44.683 debug (1422) [main] [getSettings] [getSetting] info.Settings.logUnhandledEventFHEM true
      fhem.0 2020-06-25 09:33:44.682 debug (1422) [main] [getSettings] [getSetting] info.Settings.logEventFHEMstate false
      fhem.0 2020-06-25 09:33:44.682 debug (1422) [main] [getSettings] [getSetting] info.Settings.logEventFHEMreading false
      fhem.0 2020-06-25 09:33:44.681 info (1422) > LOG "event FHEM(g) ....." events global from FHEM - info.Settings.logEventFHEMglobal (true)
      fhem.0 2020-06-25 09:33:44.681 debug (1422) [main] [getSettings] [getSetting] info.Settings.logEventFHEMglobal true
      fhem.0 2020-06-25 09:33:44.681 debug (1422) [main] [getSettings] [getSetting] info.Settings.logEventFHEM false
      fhem.0 2020-06-25 09:33:44.680 info (1422) > LOG "stateChange: ....." all events ioBroker to FHEM - info.Settings.logEventIOB (true)
      fhem.0 2020-06-25 09:33:44.680 debug (1422) [main] [getSettings] [getSetting] info.Settings.logEventIOB true
      fhem.0 2020-06-25 09:33:44.645 info (1422) > LOG "Delete channel ....." - info.Settings.logDeleteChannel (true)
      fhem.0 2020-06-25 09:33:44.645 debug (1422) [main] [getSettings] [getSetting] info.Settings.logDeleteChannel true
      fhem.0 2020-06-25 09:33:44.645 info (1422) > LOG "Create channel ....." - info.Settings.logCreateChannel (true)
      fhem.0 2020-06-25 09:33:44.645 debug (1422) [main] [getSettings] [getSetting] info.Settings.logCreateChannel true
      fhem.0 2020-06-25 09:33:44.645 debug (1422) [main] [getSettings] [getSetting] info.Settings.logUpdateChannel false
      fhem.0 2020-06-25 09:33:44.645 debug (1422) [main] [getSettings] [getSetting] info.Settings.logCheckObject false
      fhem.0 2020-06-25 09:33:44.644 debug (1422) [stateChange] stateChange (in): fhem.0.info.Commands.lastCommand ----- start FHEM Adapter Instanz fhem.0 {"val":"----- start FHEM Adapter Instanz fhem.0","ack":true,"ts":1593070424637,"q":0,"fr
      fhem.0 2020-06-25 09:33:44.643 debug (1422) [stateChange] stateChange (in): fhem.0.info.Info.lastIOBout ----- not in use - info.Configurations.advancedFunction(false) {"val":"----- not in use - info.Configurations.advancedFunction(false)
      fhem.0 2020-06-25 09:33:44.643 debug (1422) [stateChange] stateChange (in): fhem.0.info.Info.lastSend2ioB ----- not in use - info.Configurations.advancedFunction(false) {"val":"----- not in use - info.Configurations.advancedFunction(fals
      fhem.0 2020-06-25 09:33:44.642 debug (1422) [stateChange] stateChange (in): fhem.0.info.Info.lastInfo ----- not in use - info.Configurations.advancedFunction(false) {"val":"----- not in use - info.Configurations.advancedFunction(false)",
      fhem.0 2020-06-25 09:33:44.642 debug (1422) [stateChange] stateChange (in): fhem.0.info.Info.lastError ----- not in use - info.Configurations.advancedFunction(false) {"val":"----- not in use - info.Configurations.advancedFunction(false)"
      fhem.0 2020-06-25 09:33:44.641 debug (1422) [stateChange] stateChange (in): fhem.0.info.Info.lastWarn ----- not in use - info.Configurations.advancedFunction(false) {"val":"----- not in use - info.Configurations.advancedFunction(false)",
      fhem.0 2020-06-25 09:33:44.640 debug (1422) [stateChange] stateChange (in): fhem.0.info.Info.buildDate 18.06.20 {"val":"18.06.20","ack":true,"ts":1593070424636,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":15929078
      fhem.0 2020-06-25 09:33:44.634 info (1422) STEP 04 ===== select messages ioBroker admin LOG - check fhem.0.info.Settings (true)
      fhem.0 2020-06-25 09:33:44.631 debug (1422) [main] [getConfigurationsFUNCTION] [getSetting] info.Configurations.oldState false
      fhem.0 2020-06-25 09:33:44.631 debug (1422) [main] [getConfigurationsFUNCTION] [getSetting] info.Configurations.syncUpdate false
      fhem.0 2020-06-25 09:33:44.631 debug (1422) [main] [getConfigurationsFUNCTION] [getSetting] info.Configurations.advancedFunction false
      fhem.0 2020-06-25 09:33:44.630 info (1422) > FUNCTION - delete unused objects automatically - info.Configurations.deleteUnusedObjects (true)
      fhem.0 2020-06-25 09:33:44.629 debug (1422) [main] [getConfigurationsFUNCTION] [getSetting] info.Configurations.deleteUnusedObjects true
      fhem.0 2020-06-25 09:33:44.629 debug (1422) [main] [getConfigurationsFUNCTION] [getSetting] info.Configurations.autoRest false
      fhem.0 2020-06-25 09:33:44.629 debug (1422) [main] [getConfigurationsFUNCTION] [getSetting] info.Configurations.autoStates false
      fhem.0 2020-06-25 09:33:44.628 debug (1422) [main] [getConfigurationsFUNCTION] [getSetting] info.Configurations.autoType false
      fhem.0 2020-06-25 09:33:44.590 debug (1422) [main] [getConfigurationsFUNCTION] [getSetting] info.Configurations.autoName false
      fhem.0 2020-06-25 09:33:44.590 info (1422) > FUNCTION - (fhem.0) auto create SmartName of object (Adapter Cloud/IoT) - info.Configurations.autoSmartName (true)
      fhem.0 2020-06-25 09:33:44.589 debug (1422) [main] [getConfigurationsFUNCTION] [getSetting] info.Configurations.autoSmartName true
      fhem.0 2020-06-25 09:33:44.589 debug (1422) [main] [getConfigurationsFUNCTION] [getSetting] info.Configurations.autoConfigFHEM false
      fhem.0 2020-06-25 09:33:44.589 info (1422) > FUNCTION - auto create room of channel (use Adapter Material) - info.Configurations.autoRoom (true)
      fhem.0 2020-06-25 09:33:44.588 debug (1422) [main] [getConfigurationsFUNCTION] [getSetting] info.Configurations.autoRoom true
      fhem.0 2020-06-25 09:33:44.588 debug (1422) [main] [getConfigurationsFUNCTION] [getSetting] info.Configurations.autoFunction false
      fhem.0 2020-06-25 09:33:44.587 debug (1422) [main] [getConfigurationsFUNCTION] [getSetting] info.Configurations.autoRole false
      fhem.0 2020-06-25 09:33:44.584 info (1422) STEP 03 ===== select function of Adapter (FUNCTION) - check fhem.0.info.Configurations (true)
      fhem.0 2020-06-25 09:33:44.583 debug (1422) [main] [getConfigurationsSYNC] [getConfig] info.Configurations.onlySyncRoom: null
      fhem.0 2020-06-25 09:33:44.536 debug (1422) [main] [getConfigurationsSYNC] [getConfig] info.Configurations.onlySyncRoom (ioBroker,ioB_OUT)
      fhem.0 2020-06-25 09:33:44.535 debug (1422) [main] [getConfigurationsSYNC] [getConfig] info.Configurations.onlySyncTYPE: null
      fhem.0 2020-06-25 09:33:44.492 debug (1422) [main] [getConfigurationsSYNC] [getConfig] info.Configurations.onlySyncTYPE ()
      fhem.0 2020-06-25 09:33:44.491 debug (1422) [main] [getConfigurationsSYNC] [getConfig] info.Configurations.onlySyncNAME: null
      fhem.0 2020-06-25 09:33:44.448 debug (1422) [main] [getConfigurationsSYNC] [getConfig] info.Configurations.onlySyncNAME ()
      fhem.0 2020-06-25 09:33:44.447 debug (1422) [main] [getConfigurationsSYNC] [getConfig] info.Configurations.ignorePossibleSets: null
      fhem.0 2020-06-25 09:33:44.404 debug (1422) [main] [getConfigurationsSYNC] [getConfig] info.Configurations.ignorePossibleSets (getConfig,etRegRaw,egBulk,regSet,deviceMsg,CommandAccepted)
      fhem.0 2020-06-25 09:33:44.403 debug (1422) [main] [getConfigurationsSYNC] [getConfig] info.Configurations.ignoreReadings: null
      fhem.0 2020-06-25 09:33:44.359 debug (1422) [main] [getConfigurationsSYNC] [getConfig] info.Configurations.ignoreReadings (currentTrackPositionSimulated,currentTrackPositionSimulatedSec)
      fhem.0 2020-06-25 09:33:44.359 debug (1422) [main] [getConfigurationsSYNC] [getConfig] info.Configurations.allowedInternals: null
      fhem.0 2020-06-25 09:33:44.316 debug (1422) [main] [getConfigurationsSYNC] [getConfig] info.Configurations.allowedInternals (TYPE,NAME)
      fhem.0 2020-06-25 09:33:44.315 debug (1422) [main] [getConfigurationsSYNC] [getConfig] info.Configurations.allowedAttributes: null
      fhem.0 2020-06-25 09:33:44.272 debug (1422) [main] [getConfigurationsSYNC] [getConfig] info.Configurations.allowedAttributes (room,alias,comment)
      fhem.0 2020-06-25 09:33:44.271 debug (1422) [main] [getConfigurationsSYNC] [getConfig] info.Configurations.ignoreObjectsInternalsTYPE: null
      fhem.0 2020-06-25 09:33:44.227 debug (1422) [main] [getConfigurationsSYNC] [getConfig] info.Configurations.ignoreObjectsInternalsTYPE ()
      fhem.0 2020-06-25 09:33:44.227 debug (1422) [main] [getConfigurationsSYNC] [getConfig] info.Configurations.ignoreObjectsInternalsNAME: null
      fhem.0 2020-06-25 09:33:44.184 debug (1422) [main] [getConfigurationsSYNC] [getConfig] info.Configurations.ignoreObjectsInternalsNAME (info)
      fhem.0 2020-06-25 09:33:44.183 debug (1422) [main] [getConfigurationsSYNC] [getConfig] info.Configurations.ignoreObjectsAttributesroom: null
      fhem.0 2020-06-25 09:33:44.140 debug (1422) [main] [getConfigurationsSYNC] [getConfig] info.Configurations.ignoreObjectsAttributesroom ()
      fhem.0 2020-06-25 09:33:44.139 debug (1422) [main] [getConfigurationsSYNC] [getConfig] info.Configurations.allowedIOBin: null
      fhem.0 2020-06-25 09:33:44.091 debug (1422) [main] [getConfigurationsSYNC] [getConfig] info.Configurations.allowedIOBin ()
      fhem.0 2020-06-25 09:33:44.091 info (1422) STEP 02 ===== Devices to sync (SYNC) - check fhem.0.info.Configurations (value)
      fhem.0 2020-06-25 09:33:44.090 info (1422) > 62 objects fhem.0.info OK
      fhem.0 2020-06-25 09:33:44.031 info (1422) > check old objects and delete
      fhem.0 2020-06-25 09:33:44.030 debug (1422) [main] [myObjects] > update fhem.0.info.Settings.logIgnoreConfigurations - LOG "ignore FHEM device ....." ignored Devices from FHEM (info.Configurations)
      fhem.0 2020-06-25 09:33:44.030 debug (1422) [main] [myObjects] > update fhem.0.info.Settings.logUpdateChannel - LOG "Update channel ....."
      fhem.0 2020-06-25 09:33:44.030 debug (1422) [main] [myObjects] > update fhem.0.info.Settings.logUnhandledEventFHEM - LOG "unhandled event FHEM ....." all events unhandled from FHEM
      fhem.0 2020-06-25 09:33:44.030 debug (1422) [main] [myObjects] > update fhem.0.info.Settings.logEventIOB - LOG "stateChange: ....." all events ioBroker to FHEM
      fhem.0 2020-06-25 09:33:44.030 debug (1422) [main] [myObjects] > update fhem.0.info.Settings.logEventFHEMstate - LOG "event FHEM(s) ....." events state from FHEM
      fhem.0 2020-06-25 09:33:44.029 debug (1422) [main] [myObjects] > update fhem.0.info.Settings.logEventFHEMreading - LOG "event FHEM(r) ....." events readings from FHEM
      fhem.0 2020-06-25 09:33:44.029 debug (1422) [main] [myObjects] > update fhem.0.info.Settings.logEventFHEMglobal - LOG "event FHEM(g) ....." events global from FHEM
      fhem.0 2020-06-25 09:33:44.029 debug (1422) [main] [myObjects] > update fhem.0.info.Settings.logEventFHEM - LOG "event FHEM ....." all events from FHEM over telnet)
      fhem.0 2020-06-25 09:33:44.029 debug (1422) [main] [myObjects] > update fhem.0.info.Settings.logDeleteChannel - LOG "Delete channel ....."
      fhem.0 2020-06-25 09:33:44.029 debug (1422) [main] [myObjects] > update fhem.0.info.Settings.logCreateChannel - LOG "Create channel ....."
      fhem.0 2020-06-25 09:33:44.028 debug (1422) [main] [myObjects] > update fhem.0.info.Settings.logCheckObject - LOG "check channel ....."
      fhem.0 2020-06-25 09:33:43.986 debug (1422) [main] [myObjects] > update fhem.0.info.Info.lastIOBout - lastIOBout
      fhem.0 2020-06-25 09:33:43.985 debug (1422) [main] [myObjects] > update fhem.0.info.Info.lastSend2ioB - lastSend2ioB
      fhem.0 2020-06-25 09:33:43.985 debug (1422) [main] [myObjects] > update fhem.0.info.Info.lastInfo - lastInfo
      fhem.0 2020-06-25 09:33:43.985 debug (1422) [main] [myObjects] > update fhem.0.info.Info.lastError - lastError
      fhem.0 2020-06-25 09:33:43.985 debug (1422) [main] [myObjects] > update fhem.0.info.Info.lastWarn - lastWarn
      fhem.0 2020-06-25 09:33:43.985 debug (1422) [main] [myObjects] > update fhem.0.info.Info.numberDevicesFHEMignored - Number devices of FHEM (ignored)
      fhem.0 2020-06-25 09:33:43.985 debug (1422) [main] [myObjects] > update fhem.0.info.Info.alive - FHEM alive
      fhem.0 2020-06-25 09:33:43.982 debug (1422) [main] [myObjects] > update fhem.0.info.Debug.timeOut - Average time(ms) stateChanges(s) of ioBroker last 5 min
      fhem.0 2020-06-25 09:33:43.982 debug (1422) [main] [myObjects] > update fhem.0.info.Debug.numberOut - Number of stateChanges(s) of ioBroker last 5 min
      fhem.0 2020-06-25 09:33:43.981 debug (1422) [main] [myObjects] > update fhem.0.info.Debug.timeIn - Average time(ms) of events of FHEM last 5 min
      fhem.0 2020-06-25 09:33:43.981 debug (1422) [main] [myObjects] > update fhem.0.info.Debug.numberIn - Number of events of FHEM last 5 min
      fhem.0 2020-06-25 09:33:43.981 debug (1422) [main] [myObjects] > update fhem.0.info.Debug.logDevelop - More info debug
      fhem.0 2020-06-25 09:33:43.981 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.syncUpdate - FUNCTION - sync update reading
      fhem.0 2020-06-25 09:33:43.981 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.advancedFunction - FUNCTION - advanced
      fhem.0 2020-06-25 09:33:43.981 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.logNoInfo - FUNCTION - no LOG info
      fhem.0 2020-06-25 09:33:43.981 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.oldState - FUNCTION - old version of state with true/false
      fhem.0 2020-06-25 09:33:43.981 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.deleteUnusedObjects - FUNCTION - delete unused objects automatically
      fhem.0 2020-06-25 09:33:43.981 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.autoRest - FUNCTION - auto create read,write,min,max,unit of object
      fhem.0 2020-06-25 09:33:43.981 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.autoStates - FUNCTION - auto create states of object
      fhem.0 2020-06-25 09:33:43.980 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.autoType - FUNCTION - auto create type of object
      fhem.0 2020-06-25 09:33:43.980 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.autoName - FUNCTION - auto create name of object
      fhem.0 2020-06-25 09:33:43.980 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.autoSmartName - FUNCTION - (fhem.0) auto create SmartName of object (Adapter Cloud/IoT)
      fhem.0 2020-06-25 09:33:43.980 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.autoRole - FUNCTION - auto create role of object (use Adapter Material)
      fhem.0 2020-06-25 09:33:43.980 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.autoRoom - FUNCTION - auto create room of channel (use Adapter Material)
      fhem.0 2020-06-25 09:33:43.980 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.autoFunction - FUNCTION - auto create function of object (use Adapter Material)
      fhem.0 2020-06-25 09:33:43.980 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.autoConfigFHEM - FUNCTION - allow special configurations FHEM
      fhem.0 2020-06-25 09:33:43.979 debug (1422) [main] [myObjects] > update fhem.0.info.Info.numberObjectsIOBin - Number of objects IOB in
      fhem.0 2020-06-25 09:33:43.977 debug (1422) [main] [myObjects] > update fhem.0.info.Info.numberObjectsIOBoutSub - Number of objects IOB out (possible)
      fhem.0 2020-06-25 09:33:43.977 debug (1422) [main] [myObjects] > update fhem.0.info.Info.numberObjectsIOBout - Number of objects IOB out (detected)
      fhem.0 2020-06-25 09:33:43.977 debug (1422) [main] [myObjects] > update fhem.0.info.Info.numberDevicesFHEMsync - Number devices of FHEM (synchronized)
      fhem.0 2020-06-25 09:33:43.977 debug (1422) [main] [myObjects] > update fhem.0.info.Info.numberDevicesFHEM - Number devices of FHEM (jsonlist2)
      fhem.0 2020-06-25 09:33:43.977 debug (1422) [main] [myObjects] > update fhem.0.info.Info.roomioBroker - room of fhem.x.info.Configurations.onlySyncRoom exist
      fhem.0 2020-06-25 09:33:43.977 debug (1422) [main] [myObjects] > update fhem.0.info.Info.buildDate - Date of main.js
      fhem.0 2020-06-25 09:33:43.977 debug (1422) [main] [myObjects] > update fhem.0.info.Debug.activate - Debug Mode for Device(s) NAME
      fhem.0 2020-06-25 09:33:43.976 debug (1422) [main] [myObjects] > update fhem.0.info.Debug.meta - Device NAME of FHEM
      fhem.0 2020-06-25 09:33:43.976 debug (1422) [main] [myObjects] > update fhem.0.info.Debug.jsonlist2 - jsonlist2 of FHEM
      fhem.0 2020-06-25 09:33:43.976 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.onlySyncTYPE - SYNC - only sync device(s) TYPE
      fhem.0 2020-06-25 09:33:43.976 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.onlySyncNAME - SYNC - only sync device(s) NAME
      fhem.0 2020-06-25 09:33:43.976 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.onlySyncRoom - SYNC - only sync device(s) if room exist (default: ioBroker,ioB_OUT)
      fhem.0 2020-06-25 09:33:43.976 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.ignorePossibleSets - SYNC - ignore PossibleSets (default: getConfig,etRegRaw,egBulk,regSet,deviceMsg,CommandAccepted)
      fhem.0 2020-06-25 09:33:43.976 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.ignoreReadings - SYNC - ignore Readings (default: currentTrackPositionSimulated,currentTrackPositionSimulatedSec)
      fhem.0 2020-06-25 09:33:43.975 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.allowedInternals - SYNC - allowed Internals (default: TYPE,NAME)
      fhem.0 2020-06-25 09:33:43.975 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.allowedAttributes - SYNC - allowed Attributes (default: room,alias,comment)
      fhem.0 2020-06-25 09:33:43.975 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.ignoreObjectsAttributesroom - SYNC - ignore device(s) of room(s) (default: )
      fhem.0 2020-06-25 09:33:43.975 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.ignoreObjectsInternalsNAME - SYNC - ignore device(s) NAME (default: info)
      fhem.0 2020-06-25 09:33:43.975 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.ignoreObjectsInternalsTYPE - SYNC - ignore device(s) TYPE (default: )
      fhem.0 2020-06-25 09:33:43.973 debug (1422) [main] [myObjects] > update fhem.0.info.Configurations.allowedIOBin - SYNC - allowed objects send2FHEM
      fhem.0 2020-06-25 09:33:43.962 debug (1422) [main] [myObjects] > update fhem.0.info.Commands.createSwitch - Create dummy as switch in room FHEM (NAME room)
      fhem.0 2020-06-25 09:33:43.962 debug (1422) [main] [myObjects] > update fhem.0.info.Commands.sendFHEM - Command to FHEM
      fhem.0 2020-06-25 09:33:43.961 debug (1422) [main] [myObjects] > update fhem.0.info.Commands.resultFHEM - Result of FHEM
      fhem.0 2020-06-25 09:33:43.961 debug (1422) [main] [myObjects] > update fhem.0.info.Commands.lastCommand - Last command to FHEM
      fhem.0 2020-06-25 09:33:43.936 info (1422) > check new/update objects
      fhem.0 2020-06-25 09:33:43.934 info (1422) STEP 01 ===== buildDate 18.06.20 - check objects fhem.0.info
      fhem.0 2020-06-25 09:33:43.933 debug (1422) [main] [firstCheck] [getSetting] info.Configurations.logNoInfo false
      fhem.0 2020-06-25 09:33:43.931 debug (1422) [main] [firstCheck] [getSetting] info.Debug.logDevelop false
      fhem.0 2020-06-25 09:33:43.884 debug (1422) [main] telnetOut.on ready
      fhem.0 2020-06-25 09:33:43.830 debug (1422) [main] start
      fhem.0 2020-06-25 09:33:43.817 info (1422) starting. Version 1.5.2 in /opt/iobroker/node_modules/iobroker.fhem, node: v10.18.0, js-controller: 3.1.4
      fhem.0 2020-06-25 09:33:39.604 info (19045) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      fhem.0 2020-06-25 09:33:39.603 info (19045) terminating
      fhem.0 2020-06-25 09:33:39.602 info (19045) Got terminate signal TERMINATE_YOURSELF
      Vielen Dank!
      LausiD 1 Reply Last reply Reply Quote 0
        Hallo.
        Kann mir keiner sagen, warum ich diese Meldung bekomme?
        1. unhandled event FHEM: ---- | at atWaschmaschinePower
        Vielen Dank!
          pole23 @LausiD last edited by
          @LausiD Ich habe die aktuellste Version neu installiert, leider wird "_switch" nicht erstellt.
          • LausiD
            LausiD @djsirius last edited by
            @djsirius sagte in FHEM Adapter:
            Ein state zB mit "Next: ..." kann leider nicht einwandfrei als state oder reading erkannt werden, deshalb der Umweg über jsonlist2.
            Falls du die Meldung nicht haben möchtest bitte fhem.0.info.Settings.logUnhandledEventFHEM auf false setzen.
            LausiD
            • LausiD
              LausiD @pole23 last edited by
              @pole23 sagte in FHEM Adapter:
              Stimmt, habe ich nochmal geprüft.
              Nach Update von github 1.5.2 buildDate 28.06.20 sollte es aber flutschen 🙂
              Für jedes Device TYPE "KNX" wird jetzt ein state_switch angelegt.
              LausiD
                @LausiD Funktioniert, vielen dank
                  djsirius @LausiD last edited by djsirius
                  @LausiD
                  könntest du mir vielleicht erklären, wie ich den Fehler beheben kann, weil die drei Blockly Scripte auch Probleme machen und nicht einwandfrei funktionieren. Ich finde den Fehler nicht!
                  Ich habe die Scripte nicht selbst geschrieben sondern von Kuddel https://forum.iobroker.net/topic/19611/vorstellung-meine-zweite-visualisierung/1200 übernommen.
                  Vielen Dank!
                  B LausiD 2 Replies Last reply Reply Quote 0
                    BerndG @djsirius last edited by
                    @LausiD
                    Hallo LausiD, die Konfigurationen
                    -fhem.0.info.Configurations.autoConfigFHEM
                    -fhem.0.info.Settings.logUnhandledEventFHEM
                    lassen sich nicht setzen. Sie stehen auf rot: (Bestätigt: false) und ändern sich nicht.
                    Habe ich ein Berechtigungsproblem?
                    Gruß Bernd
                    NPM 6.14.5
                    Node.js 12.18.1
                    JS-controller 3.16
                    FHEM-Adapter 1.5.2
                    Raspbian GNU/Linux 9 (stretch)
                    • LausiD
                      Sorry, Blocky ist gar nicht mein Thema.
                      Für Hilfe, Unterstützung solltest du vielleicht das Problem näher beschreiben.
                      Gruß LausiD
                      • LausiD
                        LausiD @BerndG last edited by
                        @BerndG sagte in FHEM Adapter:
                        Stimmt, bleiben auf rot stehen.
                        Funktioniert aber trotzdem alles, oder?
                        Gruß LausiD
                          BerndG @LausiD last edited by
                          @LausiD
                          Ja, es funktioniert, aber es ist schon irritierend, wenn im System etwas auf rot steht.
                          Gefahr erkannt ==> Gefahr gebannt :=))
                          Vielen Dank Bernd
                          • LausiD
                            Nach Update von github V1.5.3 buildDate 05.07.20 wird fhem.x.info mit true bestätigt
                            LausiD
                            • D3ltoroxp
                              D3ltoroxp last edited by
                              ich hätte mal eine Frage zu diesem genialen Adapter. Steuern von z.b. meinen Rollos funktioniert wunderbar. Kann ich mir denn auch Attribute in ioBroker anzeigen lassen und diese ändern ? Oder geht auch nur ändern, wenn ich weiß welche attr ?
                              • LausiD
                                LausiD @D3ltoroxp last edited by
                                @D3ltoroxp
                                Kann noch nicht so ganz folgen 😞
                                Was möchtest du genau machen?
                                Gruß LausiD
                                • D3ltoroxp
                                  D3ltoroxp @LausiD last edited by D3ltoroxp
                                  @LausiD
                                  Für die ganzen Devices in FHEM gibt es ja attr z.b. hier...
                                  In ioBroker bekomme ich über den Adapter ja nur den Bereich, indem man das Device steuern kann und Werte eintragen.
                                  Der Ordner Attribute ist zwar vorhanden, aber dort stehen ja z.b. all die attr aus dem ersten Screenshot nicht drin.
                                  Hier wollte ich fragen ob es irgendwie die Möglichkeit gibt, auch attr anzeigen zu lassen und diese zu ändern ?
                                  Beispiel Rollo, ich kann ja auf / ab, bestimmte PCT eingeben, das klappt. Kann aber an den Attr über ioBroker aus nicht ändern. z.b. das attr ASC_Ventil_Pos.
                                  EDIT::
                                  Ok hab grad was in der Wiki gefunden ::
                                  Attributes werden aus FHEM ausgelesen und können über ioBroker auch geändert werden. In der Default Einstellung werden falls vorhanden alias,comment,room synchronisiert. Ist alias nicht vorhanden wird automatisch fhem.x.Device.Attributes.alias mit Wert Internals:NAME angelegt. Jede Änderung an Atrributes wird an FHEM übertragen. Unter fhem.x.info.Configurations.allowedAttributes können weitere Atrributes hinzugefügt werden.
                                  Aber dennoch check ich grad nicht, wie ich oder was ich da eintragen muss, damit mir die attr meiner Rollo Devices angezeigt wird. Ich muss bestimmt hier ```
                                  etwas eintragen, weiß aber nicht was.
                                  • LausiD
                                    LausiD @D3ltoroxp last edited by LausiD
                                    @D3ltoroxp
                                    zB ASC_Ventil_Pos bei fhem.0.info.Configurations.allowedAttributes
                                    Mehere ATTR durch Komma getrennt eingeben
                                    • D3ltoroxp
                                      @LausiD
                                      Das kommt wenn ich auf ein attr klicke. Welche Schreibweise sollte es sein ?
                                      ioBroker muss ja wissen, welches Device ? So ? Bad.ASC_Ventilate_Window_Open ??
                                      • LausiD
                                        @D3ltoroxp
                                        Nein ohne device...nur ATTR also "ASC_Ventilate_Window_Open"
                                        D3ltoroxp 1 Reply Last reply Reply Quote 1
                                        • D3ltoroxp
                                          @LausiD said in FHEM Adapter:
                                          @D3ltoroxp
                                          Aber ich habe 14 Rollos (Devices), und bei allen heißt dieses Attr so. Wie weiß ioBroker welches zu welchem Rollo gehört ?
                                          • LausiD
                                            @D3ltoroxp
                                            Bei allen 14 Rollos kommt dieses ATTR mit...probier doch mal 🙂
                                            1.2k
                                            81.1k
                                            adapter fhem
                                            82
                                            676
                                            194199
