    3. Entwicklung
    4. [Major Update] UniFi Adapter v0.5.0
    • braindead
      braindead Developer last edited by
      @coyote Ich habe gerade v0.5.6-beta.2 auf GitHub veröffentlicht. @Scrounger hat allerhand Debug Meldungen eingebaut. Kannst Du die neue Version bitte einmal installieren, Dein Debug Level auf "silly" stellen und die Log Meldungen hier posten?
        BigChris last edited by
        Kann ich das hinzukommen eines neuen Clients erkennen? Würde das gerne zur Überwachung des Gastnetzes benutzen.
        • coyote
          coyote Most Active @braindead last edited by
          @braindead @Scrounger hier das Log mit der neuen Beta:
          unifi.0	2020-07-05 20:14:16.835	info	(19541) Terminated (NO_ERROR): Without reason
          unifi.0	2020-07-05 20:14:16.834	debug	(19541) Plugin sentry destroyed
          unifi.0	2020-07-05 20:14:16.833	info	(19541) terminating
          unifi.0	2020-07-05 20:14:16.831	info	(19541) cleaned everything up...
          unifi.0	2020-07-05 20:14:16.830	error	(19541) TypeError: Cannot read property 'filter' of undefined at Unifi.processGatewayTraffic (/opt/iobroker/node_modules/iobroker.unifi/main.js:895:38) at process._tickCallback (internal/proce
          unifi.0	2020-07-05 20:14:16.829	error	(19541) unhandled promise rejection: Cannot read property 'filter' of undefined
          unifi.0	2020-07-05 20:14:16.829	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          unifi.0	2020-07-05 20:14:16.826	silly	(19541) processGatewayTraffic: site: vlkecrbx, data: undefined
          unifi.0	2020-07-05 20:14:16.669	silly	(19541) processGatewayTraffic: filtered data: [{"time":1593388800000,"lan-rx_bytes":140952376913.2574,"lan-tx_bytes":143087948124.27737,"gw":"b4:fb:e4:83:5d:79","o":"gw","oid":"b4:fb:e4:83:5d:79"},{"t
          unifi.0	2020-07-05 20:14:16.669	silly	(19541) processGatewayTraffic: site: default, data: [{"time":1593388800000,"lan-rx_bytes":140952376913.2574,"lan-tx_bytes":143087948124.27737,"gw":"b4:fb:e4:83:5d:79","o":"gw","oid":"b4:fb:e4:83:5d:79
          unifi.0	2020-07-05 20:14:16.667	silly	(19541) fetchGatewayTraffic: [[{"time":1593388800000,"lan-rx_bytes":140952376913.2574,"lan-tx_bytes":143087948124.27737,"gw":"b4:fb:e4:83:5d:79","o":"gw","oid":"b4:fb:e4:83:5d:79"},{"time":15934752000
          unifi.0	2020-07-05 20:14:16.667	debug	(19541) fetchGatewayTraffic: 7
          unifi.0	2020-07-05 20:14:16.632	silly	(19541) fetchGatewayTraffic: start: 2020-6-28, end: 2020-7-5
          unifi.0	2020-07-05 20:14:16.626	silly	(19541) processDpi: filtered data: []
          unifi.0	2020-07-05 20:14:16.625	silly	(19541) processDpi: site: vlkecrbx, data: []
          unifi.0	2020-07-05 20:14:16.604	silly	(19541) processDpi: filtered data: [{}]
          unifi.0	2020-07-05 20:14:16.602	silly	(19541) processDpi: site: default, data: [{}]
          unifi.0	2020-07-05 20:14:16.601	silly	(19541) fetchDpi: [[{}],[]]
          unifi.0	2020-07-05 20:14:16.483	silly	(19541) processVouchers: site: vlkecrbx, data: []
          unifi.0	2020-07-05 20:14:16.423	silly	(19541) processVouchers: site: default, data: []
          unifi.0	2020-07-05 20:14:16.421	silly	(19541) fetchVouchers: [[],[]]
          unifi.0	2020-07-05 20:14:16.421	debug	(19541) fetchVouchers: 0
          unifi.0	2020-07-05 20:14:16.347	silly	(19541) processHealth: filtered data: [{"subsystem":"wlan","status":"unknown","num_ap":0,"num_adopted":0,"num_disabled":0,"num_disconnected":0,"num_pending":0},{"subsystem":"wan","num_gw":0,"num_adopt
          unifi.0	2020-07-05 20:14:16.347	silly	(19541) processHealth: site: vlkecrbx, data: [{"subsystem":"wlan","status":"unknown","num_ap":0,"num_adopted":0,"num_disabled":0,"num_disconnected":0,"num_pending":0},{"subsystem":"wan","num_gw":0,"nu
          unifi.0	2020-07-05 20:14:16.311	silly	(19541) processHealth: filtered data: [{"subsystem":"wlan","num_user":24,"num_guest":0,"num_iot":0,"tx_bytes-r":133520,"rx_bytes-r":235474,"status":"ok","num_ap":5,"num_adopted":5,"num_disabled":0,"nu
          unifi.0	2020-07-05 20:14:16.311	silly	(19541) processHealth: site: default, data: [{"subsystem":"wlan","num_user":24,"num_guest":0,"num_iot":0,"tx_bytes-r":133520,"rx_bytes-r":235474,"status":"ok","num_ap":5,"num_adopted":5,"num_disabled"
          unifi.0	2020-07-05 20:14:16.309	silly	(19541) fetchHealth: [[{"subsystem":"wlan","num_user":24,"num_guest":0,"num_iot":0,"tx_bytes-r":133520,"rx_bytes-r":235474,"status":"ok","num_ap":5,"num_adopted":5,"num_disabled":0,"num_disconnected":
          unifi.0	2020-07-05 20:14:16.308	debug	(19541) fetchHealth: 5
          unifi.0	2020-07-05 20:14:16.266	silly	(19541) processNetworks: filtered data: [{"_id":"5ea5c6b3a5e9e10174996771","attr_no_delete":true,"attr_hidden_id":"LAN","name":"LAN","site_id":"5ea5c6b3a5e9e10174996768","vlan_enabled":false,"purpose"
          unifi.0	2020-07-05 20:14:16.265	silly	(19541) processNetworks: site: vlkecrbx, data: [{"_id":"5ea5c6b3a5e9e10174996771","attr_no_delete":true,"attr_hidden_id":"LAN","name":"LAN","site_id":"5ea5c6b3a5e9e10174996768","vlan_enabled":false,"p
          unifi.0	2020-07-05 20:14:16.183	silly	(19541) processNetworks: filtered data: [{"_id":"5ad730672ac32c46b072fcf2","attr_no_delete":true,"attr_hidden_id":"LAN","name":"LAN","site_id":"5ad7305f2ac32c46b072fce8","vlan_enabled":false,"purpose"
          unifi.0	2020-07-05 20:14:16.182	silly	(19541) processNetworks: site: default, data: [{"_id":"5ad730672ac32c46b072fcf2","attr_no_delete":true,"attr_hidden_id":"LAN","name":"LAN","site_id":"5ad7305f2ac32c46b072fce8","vlan_enabled":false,"pu
          unifi.0	2020-07-05 20:14:16.179	silly	(19541) fetchNetworks: [[{"_id":"5ad730672ac32c46b072fcf2","attr_no_delete":true,"attr_hidden_id":"LAN","name":"LAN","site_id":"5ad7305f2ac32c46b072fce8","vlan_enabled":false,"purpose":"corporate","ip
          unifi.0	2020-07-05 20:14:16.177	debug	(19541) fetchNetworks: 7
          unifi.0	2020-07-05 20:14:16.149	silly	(19541) processWlans: filtered data: []
          unifi.0	2020-07-05 20:14:16.149	silly	(19541) processWlans: site: vlkecrbx, data: []
          unifi.0	2020-07-05 20:14:15.870	silly	(19541) processWlans: filtered data: [{"_id":"5ad731c32ac32c46b072fcfe","wlangroup_id":"5ad730672ac32c46b072fcf4","enabled":true,"name":"Coyote","security":"wpapsk","wpa_mode":"wpa2","wpa_enc":"ccmp",
          unifi.0	2020-07-05 20:14:15.869	silly	(19541) processWlans: site: default, data: [{"_id":"5ad731c32ac32c46b072fcfe","wlangroup_id":"5ad730672ac32c46b072fcf4","enabled":true,"name":"Coyote","security":"wpapsk","wpa_mode":"wpa2","wpa_enc":"
          unifi.0	2020-07-05 20:14:15.867	silly	(19541) fetchWlans: [[{"_id":"5ad731c32ac32c46b072fcfe","wlangroup_id":"5ad730672ac32c46b072fcf4","enabled":true,"name":"Coyote","security":"wpapsk","wpa_mode":"wpa2","wpa_enc":"ccmp","x_passphrase":"
          unifi.0	2020-07-05 20:14:15.867	debug	(19541) fetchWlans: 4
          unifi.0	2020-07-05 20:14:15.835	silly	(19541) processDevices: filtered data: []
          unifi.0	2020-07-05 20:14:15.834	silly	(19541) processDevices: site: vlkecrbx, data: []
          unifi.0	2020-07-05 20:14:15.595	silly	(19541) processDevices: filtered data: [{"_id":"5e7f7d21a5e9e1016f1f7a2a","ip":"192.168.66.6","mac":"74:83:c2:36:89:07","model":"U7LT","type":"uap","version":"4.3.13.11253","adopted":true,"site_id":"5
          unifi.0	2020-07-05 20:14:15.593	silly	(19541) processDevices: site: default, data: [{"_id":"5e7f7d21a5e9e1016f1f7a2a","ip":"192.168.66.6","mac":"74:83:c2:36:89:07","model":"U7LT","type":"uap","version":"4.3.13.11253","adopted":true,"site_
          unifi.0	2020-07-05 20:14:15.586	silly	(19541) fetchDevices: [[{"_id":"5e7f7d21a5e9e1016f1f7a2a","ip":"192.168.66.6","mac":"74:83:c2:36:89:07","model":"U7LT","type":"uap","version":"4.3.13.11253","adopted":true,"site_id":"5ad7305f2ac32c46b
          unifi.0	2020-07-05 20:14:15.585	debug	(19541) fetchDevices: 6
          unifi.0	2020-07-05 20:14:15.399	debug	(19541) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          unifi.0	2020-07-05 20:14:15.360	debug	(19541) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          unifi.0	2020-07-05 20:14:15.355	silly	(19541) processClients: filtered data: []
          unifi.0	2020-07-05 20:14:15.354	silly	(19541) processClients: site: vlkecrbx, data: []
          unifi.0	2020-07-05 20:14:15.188	debug	(19541) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          unifi.0	2020-07-05 20:14:15.136	debug	(19541) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          unifi.0	2020-07-05 20:14:12.717	silly	(19541) processClients: filtered data: [{"site_id":"5ad7305f2ac32c46b072fce8","assoc_time":1593949977,"latest_assoc_time":1593949978,"oui":"Espressi","user_id":"5e80e166a5e9e1016f1fc1fa","_id":"5e80e1
          unifi.0	2020-07-05 20:14:12.716	silly	(19541) processClients: site: default, data: [{"site_id":"5ad7305f2ac32c46b072fce8","assoc_time":1593949977,"latest_assoc_time":1593949978,"oui":"Espressi","user_id":"5e80e166a5e9e1016f1fc1fa","_id":"
          unifi.0	2020-07-05 20:14:12.714	silly	(19541) fetchClients: [[{"site_id":"5ad7305f2ac32c46b072fce8","assoc_time":1593949977,"latest_assoc_time":1593949978,"oui":"Espressi","user_id":"5e80e166a5e9e1016f1fc1fa","_id":"5e80e166a5e9e1016f1fc1
          unifi.0	2020-07-05 20:14:12.702	debug	(19541) fetchClients: 41
          unifi.0	2020-07-05 20:14:12.647	silly	(19541) processSiteSysinfo: site: vlkecrbx, data: [{"timezone":"UTC","autobackup":false,"build":"atag_5.13.29_13635","version":"5.13.29","previous_version":"5.12.72","debug_mgmt":"warn","debug_system"
          unifi.0	2020-07-05 20:14:12.628	silly	(19541) processSiteSysinfo: site: default, data: [{"timezone":"Europe/Brussels","autobackup":false,"build":"atag_5.13.29_13635","version":"5.13.29","previous_version":"5.12.72","debug_mgmt":"warn","de
          unifi.0	2020-07-05 20:14:12.627	silly	(19541) fetchSiteSysinfo: [[{"timezone":"Europe/Brussels","autobackup":false,"build":"atag_5.13.29_13635","version":"5.13.29","previous_version":"5.12.72","debug_mgmt":"warn","debug_system":"warn","de
          unifi.0	2020-07-05 20:14:12.621	debug	(19541) fetchSiteSysinfo: 2
          unifi.0	2020-07-05 20:14:12.584	silly	(19541) processSites: site: vlkecrbx, data: {"_id":"5ea5c6b3a5e9e10174996768","desc":"Test","name":"vlkecrbx","role":"admin"}
          unifi.0	2020-07-05 20:14:12.574	silly	(19541) processSites: site: default, data: {"_id":"5ad7305f2ac32c46b072fce8","name":"default","desc":"Default","attr_hidden_id":"default","attr_no_delete":true,"role":"admin"}
          unifi.0	2020-07-05 20:14:12.572	debug	(19541) fetchSites: default,vlkecrbx
          unifi.0	2020-07-05 20:14:12.556	debug	(19541) Login successful
          unifi.0	2020-07-05 20:14:12.132	silly	(19541) States system redis pmessage io.system.adapter.unifi.0.logLevel/io.system.adapter.unifi.0.logLevel:{"val":"silly","ack":true,"ts":1593972851686,"q":0,"from":"system.adapter.unifi.0","lc":15939
          unifi.0	2020-07-05 20:14:11.739	debug	(19541) Update started
          unifi.0	2020-07-05 20:14:11.724	debug	(19541) updateInterval = 60
          unifi.0	2020-07-05 20:14:11.708	debug	(19541) controller = 192.168.66.35:8443
          unifi.0	2020-07-05 20:14:11.681	info	(19541) UniFi adapter is ready
          unifi.0	2020-07-05 20:14:11.613	info	(19541) starting. Version 0.5.6-beta.2 in /opt/iobroker/node_modules/iobroker.unifi, node: v10.21.0, js-controller: 3.1.6
          unifi.0	2020-07-05 20:14:11.545	info	(19541) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
          unifi.0	2020-07-05 20:14:11.517	debug	(19541) Plugin sentry Initialize Plugin (enabled=true)
          unifi.0	2020-07-05 20:13:38.060	info	(19504) Terminated (NO_ERROR): Without reason
          • braindead
            @coyote Danke für das Log. Laut Log hast Du doch zwei Sites: default und vlkecrbx, wobei vlkecrbx meistens keine Daten liefert, was dann irgendwann zum Fehler des Adapters führt.
            • coyote
              @braindead oh man 🤦‍♂️
              Du hast recht, ich hatte mich schon gewundert was "vlkecrbx" sein soll...
              Habe jetzt gerade den kompletten controller nochmal durchforstet und ja es stimmt, ich hab da irgendwann mal eine Site angelegt zum Testen, die heißt aber auch seltsamerweise "Test".
              Sorry, hatte ich die Woche auf die schnelle wohl übersehen und euch damit Arbeit verschafft 🤦‍♂️
              Gerade die "Test" Site gelöscht und dann läuft auch der Adapter mit aktiviertem Gateway Traffic.
              braindead Scrounger 2 Replies Last reply Reply Quote 0
              • braindead
                braindead Developer @coyote last edited by
                @coyote Du musst Dich nicht entschuldigen. Du bist wahrscheinlich nicht der einzige User mit mehreren Sites bei dem der Adapter deshalb nicht sauber läuft. Die Fehler werden demnächst sauber abgefangen und dann ist alles gut.
                Also nochmal: Vielen Dank für Deine Unterstützung!
                Xsev 1 Reply Last reply Reply Quote 2
                • Scrounger
                  Scrounger Developer @coyote last edited by
                  @coyote
                  Wie @braindead schon gesagt hat, war nicht viel Aufwand, 5min die Zeilen anzufügen.
                  Positiver Nebeneffekt des ganzen ist, dass man sieht das da noch was abgefangen werden muss. Von daher hinsichtlich Adapter Entwicklung und Stabilität top gelaufen, danke fürs testen!
                  • Xsev
                    Xsev @braindead last edited by
                    @braindead
                    Kann man sich den live Traffic der Clients jetzt auch anzeigen lassen oder geht es rein ums Gateway?
                    • braindead
                      braindead Developer @Xsev last edited by
                      @Scrounger hat den Traffic eingebaut. Kannst Du die Frage von @Xsev beantworten?
                      • Scrounger
                        Scrounger Developer @Xsev last edited by
                        @Xsev
                        Traffic wird nur fürs Gateway angezeigt.
                        Xsev 1 Reply Last reply Reply Quote 0
                        • Xsev
                          Xsev @Scrounger last edited by
                          @Scrounger Ok danke für die Info.
                          • RK62
                            RK62 @braindead last edited by
                            @braindead Hab's gefunden: Bei dem betroffenen iPhone war Einstellungen / Mobiles Netz / WLAN-Anrufe auf AUS geschaltet. Nach dem Aktivieren läuft es da jetzt auch einwandfrei. 👍
                            • Tom Son
                              Tom Son last edited by
                              Hi...
                              Ich spiele auch grad mit dem Community Adapter, dabei ist mir was aufgefallen (was aber jetzt nicht so wichtig ist) dass bei nicht allen Geräten das "is_online" dabei ist. Natürlich kann ich das auch vom Ping Adapter auslesen, aber fein wäre es wenn alles in einem drinn ist...
                              Beim Router (ich habe den USG pro4) gibt es den Parameter für Temperatur nicht, könnte man den auch noch rein packen?
                              Geben würde es den: 5d90480f-488e-4ee2-96d8-9b53e0828950-grafik.png
                              Frage zum Traffik: wie visualisiert ihr denn den aktuellen eingehenden/ausgehenden Traffik?
                              • braindead
                                braindead Developer @Tom Son last edited by
                                @Tom-Son Wenn Du von Geräten sprichst, meinst Du Clients oder Devices? Clients sollten alle den is_online State haben. Devices haben den nicht, weil die eh permanent online sein sollten.
                                Tom Son 1 Reply Last reply Reply Quote 0
                                • Tom Son
                                  Tom Son @braindead last edited by
                                  @braindead Ja ich spreche von Devices, du hast recht "sollten" immer online sein, aber wenn man eine Komponennte ausfällt...
                                  Wie gesagt, ist ja kein "musthave" 🙂 aber ein "wärenice"
                                  • Scrounger
                                    Scrounger Developer @Tom Son last edited by
                                    @Tom-Son sagte in [Major Update] UniFi Adapter v0.5.0:
                                    Z.b. mit dem Material Design Widgets Bar Chart:
                                    • Tom Son
                                      Tom Son @Scrounger last edited by
                                      @Scrounger schaut schon mal gut aus 🙂
                                      Da ich noch blutiger Anfänger bin, wie hast du das zusammengebaut und umgerechnet? Braucht es da Scripte? Wärst du so knieweich und würdest hier mal den Widgetexport kopieren? 🙂
                                        darkiop Most Active @Tom Son last edited by darkiop
                                        @Tom-Son Schau dir einfach mal das Bar Chart Widget an, du kannst da einen DP je Bar definieren und den setzt du jeweils auf einen Tag:
                                        @Scrounger baust du dir für das Bar-Chart mit dem Traffic Daten ein JSON zusammen und rechnest da direkt von Bytes in GB um? Wenn ja, würdest du das zur Verfügung stellen?
                                        • Scrounger
                                          Scrounger Developer @darkiop last edited by Scrounger
                                          @darkiop sagte in [Major Update] UniFi Adapter v0.5.0:
                                          Jup bau das JSON per skript zusammen. Bin aktuell dran das Beispiel Material Design Widgets: UniFi Netzwerk Status für die Version 0.5.x anzupassen.
                                          Das wird aber wesentlich größer. Gibt dann mehr als nur die Clients Übersicht, u.a. Devices, Netzwerk Traffic, Speedtest, WLAN Anzahl Gerät, Alarmmeldungen, etc. in einer responsiv View. So in der Art wie das Wetter Beispiel Projekt.
                                          Hier ist der Code Auszug für das Traffic Bar Chart, da das aber sehr intergriert ist, funktioniert das nicht out of the box. Wer das braucht, muss sich noch etwas gedulden bis ich das neue Projekt fertig habe.
                                          function updateTrafficChart() {
                                              let methodName = 'updateTrafficChart'
                                              try {
                                                  let chart = {};
                                                  let graphs = [];
                                                  let axisLabels = [];
                                                  let gesendetValues = [];
                                                  let empfangenValues = [];
                                                  for (var i = gateway_lastDays - 1; i >= 0; i--) {
                                                      let dayDate = getValue(`unifi.0.default.gateway_traffic.${gatewayTrafficSettings.mac}.day_${i}.date`, undefined);
                                                      if (i === 0) {
                                                          axisLabels.push(`Heute\\n${moment(dayDate).format('DD.MM')}`);
                                                      } else if (i === 1) {
                                                          axisLabels.push(`Gestern\\n${moment(dayDate).format('DD.MM')}`);
                                                      } else {
                                                          if (dayDate) {
                                                              axisLabels.push(moment(dayDate).format('ddd[\\n]DD.MM'));
                                                          } else {
                                                              axisLabels.push(i);
                                                      let gesendet = getValue(`unifi.0.default.gateway_traffic.${gatewayTrafficSettings.mac}.day_${i}.sent`, 0) / 1024 / 1024 / 1024;
                                                      gesendetValues.push(gesendet);
                                                      let empfangen = getValue(`unifi.0.default.gateway_traffic.${gatewayTrafficSettings.mac}.day_${i}.received`, 0) / 1024 / 1024 / 1024;
                                                      empfangenValues.push(empfangen);
                                                  graphs.push(
                                                      Object.assign(
                                                              data: empfangenValues,
                                                              color: gatewayTrafficSettings.empfangenColor,
                                                              legendText: 'empfangen'
                                                          }, gatewayTrafficChartSettings)
                                                  graphs.push(
                                                      Object.assign({
                                                          data: gesendetValues,
                                                          color: gatewayTrafficSettings.gesendetColor,
                                                          legendText: 'gesendet'
                                                  chart = {
                                                      axisLabels: axisLabels,
                                                      graphs: graphs
                                                  mySetState(gateway_dpTrafficChart, JSON.stringify(chart), 'string', 'JSON string für JSON Chart Widget');
                                              } catch (ex) {
                                                  console.error(`${methodName} error: ${ex.message}`);
                                                  console.error(`${methodName} stack: ${ex.stack}`);
                                          • Tom Son
                                            Eine Frage, im Abschnitt "health" sind von 3 Adaptern (vermutlich) RX und TX aber welche Adapter sind das?
                                            braindead 1 Reply Last reply Reply Quote 0
                                            1.2k
                                            unifi
                                            54
                                            510
                                            113884
