    3. Entwicklung
    4. [Major Update] UniFi Adapter v0.5.0
      BigChris last edited by
      Kann ich das hinzukommen eines neuen Clients erkennen? Würde das gerne zur Überwachung des Gastnetzes benutzen.
      • coyote
        coyote Most Active @braindead last edited by
        @braindead @Scrounger hier das Log mit der neuen Beta:
        unifi.0	2020-07-05 20:14:16.835	info	(19541) Terminated (NO_ERROR): Without reason
        unifi.0	2020-07-05 20:14:16.834	debug	(19541) Plugin sentry destroyed
        unifi.0	2020-07-05 20:14:16.833	info	(19541) terminating
        unifi.0	2020-07-05 20:14:16.831	info	(19541) cleaned everything up...
        unifi.0	2020-07-05 20:14:16.830	error	(19541) TypeError: Cannot read property 'filter' of undefined at Unifi.processGatewayTraffic (/opt/iobroker/node_modules/iobroker.unifi/main.js:895:38) at process._tickCallback (internal/proce
        unifi.0	2020-07-05 20:14:16.829	error	(19541) unhandled promise rejection: Cannot read property 'filter' of undefined
        unifi.0	2020-07-05 20:14:16.829	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        unifi.0	2020-07-05 20:14:16.826	silly	(19541) processGatewayTraffic: site: vlkecrbx, data: undefined
        unifi.0	2020-07-05 20:14:16.669	silly	(19541) processGatewayTraffic: filtered data: [{"time":1593388800000,"lan-rx_bytes":140952376913.2574,"lan-tx_bytes":143087948124.27737,"gw":"b4:fb:e4:83:5d:79","o":"gw","oid":"b4:fb:e4:83:5d:79"},{"t
        unifi.0	2020-07-05 20:14:16.669	silly	(19541) processGatewayTraffic: site: default, data: [{"time":1593388800000,"lan-rx_bytes":140952376913.2574,"lan-tx_bytes":143087948124.27737,"gw":"b4:fb:e4:83:5d:79","o":"gw","oid":"b4:fb:e4:83:5d:79
        unifi.0	2020-07-05 20:14:16.667	silly	(19541) fetchGatewayTraffic: [[{"time":1593388800000,"lan-rx_bytes":140952376913.2574,"lan-tx_bytes":143087948124.27737,"gw":"b4:fb:e4:83:5d:79","o":"gw","oid":"b4:fb:e4:83:5d:79"},{"time":15934752000
        unifi.0	2020-07-05 20:14:16.667	debug	(19541) fetchGatewayTraffic: 7
        unifi.0	2020-07-05 20:14:16.632	silly	(19541) fetchGatewayTraffic: start: 2020-6-28, end: 2020-7-5
        unifi.0	2020-07-05 20:14:16.626	silly	(19541) processDpi: filtered data: []
        unifi.0	2020-07-05 20:14:16.625	silly	(19541) processDpi: site: vlkecrbx, data: []
        unifi.0	2020-07-05 20:14:16.604	silly	(19541) processDpi: filtered data: [{}]
        unifi.0	2020-07-05 20:14:16.602	silly	(19541) processDpi: site: default, data: [{}]
        unifi.0	2020-07-05 20:14:16.601	silly	(19541) fetchDpi: [[{}],[]]
        unifi.0	2020-07-05 20:14:16.483	silly	(19541) processVouchers: site: vlkecrbx, data: []
        unifi.0	2020-07-05 20:14:16.423	silly	(19541) processVouchers: site: default, data: []
        unifi.0	2020-07-05 20:14:16.421	silly	(19541) fetchVouchers: [[],[]]
        unifi.0	2020-07-05 20:14:16.421	debug	(19541) fetchVouchers: 0
        unifi.0	2020-07-05 20:14:16.347	silly	(19541) processHealth: filtered data: [{"subsystem":"wlan","status":"unknown","num_ap":0,"num_adopted":0,"num_disabled":0,"num_disconnected":0,"num_pending":0},{"subsystem":"wan","num_gw":0,"num_adopt
        unifi.0	2020-07-05 20:14:16.347	silly	(19541) processHealth: site: vlkecrbx, data: [{"subsystem":"wlan","status":"unknown","num_ap":0,"num_adopted":0,"num_disabled":0,"num_disconnected":0,"num_pending":0},{"subsystem":"wan","num_gw":0,"nu
        unifi.0	2020-07-05 20:14:16.311	silly	(19541) processHealth: filtered data: [{"subsystem":"wlan","num_user":24,"num_guest":0,"num_iot":0,"tx_bytes-r":133520,"rx_bytes-r":235474,"status":"ok","num_ap":5,"num_adopted":5,"num_disabled":0,"nu
        unifi.0	2020-07-05 20:14:16.311	silly	(19541) processHealth: site: default, data: [{"subsystem":"wlan","num_user":24,"num_guest":0,"num_iot":0,"tx_bytes-r":133520,"rx_bytes-r":235474,"status":"ok","num_ap":5,"num_adopted":5,"num_disabled"
        unifi.0	2020-07-05 20:14:16.309	silly	(19541) fetchHealth: [[{"subsystem":"wlan","num_user":24,"num_guest":0,"num_iot":0,"tx_bytes-r":133520,"rx_bytes-r":235474,"status":"ok","num_ap":5,"num_adopted":5,"num_disabled":0,"num_disconnected":
        unifi.0	2020-07-05 20:14:16.308	debug	(19541) fetchHealth: 5
        unifi.0	2020-07-05 20:14:16.266	silly	(19541) processNetworks: filtered data: [{"_id":"5ea5c6b3a5e9e10174996771","attr_no_delete":true,"attr_hidden_id":"LAN","name":"LAN","site_id":"5ea5c6b3a5e9e10174996768","vlan_enabled":false,"purpose"
        unifi.0	2020-07-05 20:14:16.265	silly	(19541) processNetworks: site: vlkecrbx, data: [{"_id":"5ea5c6b3a5e9e10174996771","attr_no_delete":true,"attr_hidden_id":"LAN","name":"LAN","site_id":"5ea5c6b3a5e9e10174996768","vlan_enabled":false,"p
        unifi.0	2020-07-05 20:14:16.183	silly	(19541) processNetworks: filtered data: [{"_id":"5ad730672ac32c46b072fcf2","attr_no_delete":true,"attr_hidden_id":"LAN","name":"LAN","site_id":"5ad7305f2ac32c46b072fce8","vlan_enabled":false,"purpose"
        unifi.0	2020-07-05 20:14:16.182	silly	(19541) processNetworks: site: default, data: [{"_id":"5ad730672ac32c46b072fcf2","attr_no_delete":true,"attr_hidden_id":"LAN","name":"LAN","site_id":"5ad7305f2ac32c46b072fce8","vlan_enabled":false,"pu
        unifi.0	2020-07-05 20:14:16.179	silly	(19541) fetchNetworks: [[{"_id":"5ad730672ac32c46b072fcf2","attr_no_delete":true,"attr_hidden_id":"LAN","name":"LAN","site_id":"5ad7305f2ac32c46b072fce8","vlan_enabled":false,"purpose":"corporate","ip
        unifi.0	2020-07-05 20:14:16.177	debug	(19541) fetchNetworks: 7
        unifi.0	2020-07-05 20:14:16.149	silly	(19541) processWlans: filtered data: []
        unifi.0	2020-07-05 20:14:16.149	silly	(19541) processWlans: site: vlkecrbx, data: []
        unifi.0	2020-07-05 20:14:15.870	silly	(19541) processWlans: filtered data: [{"_id":"5ad731c32ac32c46b072fcfe","wlangroup_id":"5ad730672ac32c46b072fcf4","enabled":true,"name":"Coyote","security":"wpapsk","wpa_mode":"wpa2","wpa_enc":"ccmp",
        unifi.0	2020-07-05 20:14:15.869	silly	(19541) processWlans: site: default, data: [{"_id":"5ad731c32ac32c46b072fcfe","wlangroup_id":"5ad730672ac32c46b072fcf4","enabled":true,"name":"Coyote","security":"wpapsk","wpa_mode":"wpa2","wpa_enc":"
        unifi.0	2020-07-05 20:14:15.867	silly	(19541) fetchWlans: [[{"_id":"5ad731c32ac32c46b072fcfe","wlangroup_id":"5ad730672ac32c46b072fcf4","enabled":true,"name":"Coyote","security":"wpapsk","wpa_mode":"wpa2","wpa_enc":"ccmp","x_passphrase":"
        unifi.0	2020-07-05 20:14:15.867	debug	(19541) fetchWlans: 4
        unifi.0	2020-07-05 20:14:15.835	silly	(19541) processDevices: filtered data: []
        unifi.0	2020-07-05 20:14:15.834	silly	(19541) processDevices: site: vlkecrbx, data: []
        unifi.0	2020-07-05 20:14:15.595	silly	(19541) processDevices: filtered data: [{"_id":"5e7f7d21a5e9e1016f1f7a2a","ip":"192.168.66.6","mac":"74:83:c2:36:89:07","model":"U7LT","type":"uap","version":"4.3.13.11253","adopted":true,"site_id":"5
        unifi.0	2020-07-05 20:14:15.593	silly	(19541) processDevices: site: default, data: [{"_id":"5e7f7d21a5e9e1016f1f7a2a","ip":"192.168.66.6","mac":"74:83:c2:36:89:07","model":"U7LT","type":"uap","version":"4.3.13.11253","adopted":true,"site_
        unifi.0	2020-07-05 20:14:15.586	silly	(19541) fetchDevices: [[{"_id":"5e7f7d21a5e9e1016f1f7a2a","ip":"192.168.66.6","mac":"74:83:c2:36:89:07","model":"U7LT","type":"uap","version":"4.3.13.11253","adopted":true,"site_id":"5ad7305f2ac32c46b
        unifi.0	2020-07-05 20:14:15.585	debug	(19541) fetchDevices: 6
        unifi.0	2020-07-05 20:14:15.399	debug	(19541) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
        unifi.0	2020-07-05 20:14:15.360	debug	(19541) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
        unifi.0	2020-07-05 20:14:15.355	silly	(19541) processClients: filtered data: []
        unifi.0	2020-07-05 20:14:15.354	silly	(19541) processClients: site: vlkecrbx, data: []
        unifi.0	2020-07-05 20:14:15.188	debug	(19541) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
        unifi.0	2020-07-05 20:14:15.136	debug	(19541) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
        unifi.0	2020-07-05 20:14:12.717	silly	(19541) processClients: filtered data: [{"site_id":"5ad7305f2ac32c46b072fce8","assoc_time":1593949977,"latest_assoc_time":1593949978,"oui":"Espressi","user_id":"5e80e166a5e9e1016f1fc1fa","_id":"5e80e1
        unifi.0	2020-07-05 20:14:12.716	silly	(19541) processClients: site: default, data: [{"site_id":"5ad7305f2ac32c46b072fce8","assoc_time":1593949977,"latest_assoc_time":1593949978,"oui":"Espressi","user_id":"5e80e166a5e9e1016f1fc1fa","_id":"
        unifi.0	2020-07-05 20:14:12.714	silly	(19541) fetchClients: [[{"site_id":"5ad7305f2ac32c46b072fce8","assoc_time":1593949977,"latest_assoc_time":1593949978,"oui":"Espressi","user_id":"5e80e166a5e9e1016f1fc1fa","_id":"5e80e166a5e9e1016f1fc1
        unifi.0	2020-07-05 20:14:12.702	debug	(19541) fetchClients: 41
        unifi.0	2020-07-05 20:14:12.647	silly	(19541) processSiteSysinfo: site: vlkecrbx, data: [{"timezone":"UTC","autobackup":false,"build":"atag_5.13.29_13635","version":"5.13.29","previous_version":"5.12.72","debug_mgmt":"warn","debug_system"
        unifi.0	2020-07-05 20:14:12.628	silly	(19541) processSiteSysinfo: site: default, data: [{"timezone":"Europe/Brussels","autobackup":false,"build":"atag_5.13.29_13635","version":"5.13.29","previous_version":"5.12.72","debug_mgmt":"warn","de
        unifi.0	2020-07-05 20:14:12.627	silly	(19541) fetchSiteSysinfo: [[{"timezone":"Europe/Brussels","autobackup":false,"build":"atag_5.13.29_13635","version":"5.13.29","previous_version":"5.12.72","debug_mgmt":"warn","debug_system":"warn","de
        unifi.0	2020-07-05 20:14:12.621	debug	(19541) fetchSiteSysinfo: 2
        unifi.0	2020-07-05 20:14:12.584	silly	(19541) processSites: site: vlkecrbx, data: {"_id":"5ea5c6b3a5e9e10174996768","desc":"Test","name":"vlkecrbx","role":"admin"}
        unifi.0	2020-07-05 20:14:12.574	silly	(19541) processSites: site: default, data: {"_id":"5ad7305f2ac32c46b072fce8","name":"default","desc":"Default","attr_hidden_id":"default","attr_no_delete":true,"role":"admin"}
        unifi.0	2020-07-05 20:14:12.572	debug	(19541) fetchSites: default,vlkecrbx
        unifi.0	2020-07-05 20:14:12.556	debug	(19541) Login successful
        unifi.0	2020-07-05 20:14:12.132	silly	(19541) States system redis pmessage io.system.adapter.unifi.0.logLevel/io.system.adapter.unifi.0.logLevel:{"val":"silly","ack":true,"ts":1593972851686,"q":0,"from":"system.adapter.unifi.0","lc":15939
        unifi.0	2020-07-05 20:14:11.739	debug	(19541) Update started
        unifi.0	2020-07-05 20:14:11.724	debug	(19541) updateInterval = 60
        unifi.0	2020-07-05 20:14:11.708	debug	(19541) controller = 192.168.66.35:8443
        unifi.0	2020-07-05 20:14:11.681	info	(19541) UniFi adapter is ready
        unifi.0	2020-07-05 20:14:11.613	info	(19541) starting. Version 0.5.6-beta.2 in /opt/iobroker/node_modules/iobroker.unifi, node: v10.21.0, js-controller: 3.1.6
        unifi.0	2020-07-05 20:14:11.545	info	(19541) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        unifi.0	2020-07-05 20:14:11.517	debug	(19541) Plugin sentry Initialize Plugin (enabled=true)
        unifi.0	2020-07-05 20:13:38.060	info	(19504) Terminated (NO_ERROR): Without reason
        • braindead
          braindead Developer last edited by
          @coyote Danke für das Log. Laut Log hast Du doch zwei Sites: default und vlkecrbx, wobei vlkecrbx meistens keine Daten liefert, was dann irgendwann zum Fehler des Adapters führt.
          • coyote
            @braindead oh man 🤦‍♂️
            Du hast recht, ich hatte mich schon gewundert was "vlkecrbx" sein soll...
            Habe jetzt gerade den kompletten controller nochmal durchforstet und ja es stimmt, ich hab da irgendwann mal eine Site angelegt zum Testen, die heißt aber auch seltsamerweise "Test".
            Sorry, hatte ich die Woche auf die schnelle wohl übersehen und euch damit Arbeit verschafft 🤦‍♂️
            Gerade die "Test" Site gelöscht und dann läuft auch der Adapter mit aktiviertem Gateway Traffic.
            braindead Scrounger 2 Replies Last reply Reply Quote 0
            • braindead
              braindead Developer @coyote last edited by
              @coyote Du musst Dich nicht entschuldigen. Du bist wahrscheinlich nicht der einzige User mit mehreren Sites bei dem der Adapter deshalb nicht sauber läuft. Die Fehler werden demnächst sauber abgefangen und dann ist alles gut.
              Also nochmal: Vielen Dank für Deine Unterstützung!
              Xsev 1 Reply Last reply Reply Quote 2
              • Scrounger
                Scrounger Developer @coyote last edited by
                @coyote
                Wie @braindead schon gesagt hat, war nicht viel Aufwand, 5min die Zeilen anzufügen.
                Positiver Nebeneffekt des ganzen ist, dass man sieht das da noch was abgefangen werden muss. Von daher hinsichtlich Adapter Entwicklung und Stabilität top gelaufen, danke fürs testen!
                • Xsev
                  Xsev @braindead last edited by
                  @braindead
                  Kann man sich den live Traffic der Clients jetzt auch anzeigen lassen oder geht es rein ums Gateway?
                  • braindead
                    braindead Developer @Xsev last edited by
                    @Scrounger hat den Traffic eingebaut. Kannst Du die Frage von @Xsev beantworten?
                    • Scrounger
                      Scrounger Developer @Xsev last edited by
                      @Xsev
                      Traffic wird nur fürs Gateway angezeigt.
                      Xsev 1 Reply Last reply Reply Quote 0
                      • Xsev
                        Xsev @Scrounger last edited by
                        @Scrounger Ok danke für die Info.
                        • RK62
                          RK62 @braindead last edited by
                          @braindead Hab's gefunden: Bei dem betroffenen iPhone war Einstellungen / Mobiles Netz / WLAN-Anrufe auf AUS geschaltet. Nach dem Aktivieren läuft es da jetzt auch einwandfrei. 👍
                          • Tom Son
                            Tom Son last edited by
                            Hi...
                            Ich spiele auch grad mit dem Community Adapter, dabei ist mir was aufgefallen (was aber jetzt nicht so wichtig ist) dass bei nicht allen Geräten das "is_online" dabei ist. Natürlich kann ich das auch vom Ping Adapter auslesen, aber fein wäre es wenn alles in einem drinn ist...
                            Beim Router (ich habe den USG pro4) gibt es den Parameter für Temperatur nicht, könnte man den auch noch rein packen?
                            Geben würde es den: 5d90480f-488e-4ee2-96d8-9b53e0828950-grafik.png
                            Frage zum Traffik: wie visualisiert ihr denn den aktuellen eingehenden/ausgehenden Traffik?
                            • braindead
                              braindead Developer @Tom Son last edited by
                              @Tom-Son Wenn Du von Geräten sprichst, meinst Du Clients oder Devices? Clients sollten alle den is_online State haben. Devices haben den nicht, weil die eh permanent online sein sollten.
                              Tom Son 1 Reply Last reply Reply Quote 0
                              • Tom Son
                                Tom Son @braindead last edited by
                                @braindead Ja ich spreche von Devices, du hast recht "sollten" immer online sein, aber wenn man eine Komponennte ausfällt...
                                Wie gesagt, ist ja kein "musthave" 🙂 aber ein "wärenice"
                                • Scrounger
                                  Scrounger Developer @Tom Son last edited by
                                  @Tom-Son sagte in [Major Update] UniFi Adapter v0.5.0:
                                  Z.b. mit dem Material Design Widgets Bar Chart:
                                  • Tom Son
                                    Tom Son @Scrounger last edited by
                                    @Scrounger schaut schon mal gut aus 🙂
                                    Da ich noch blutiger Anfänger bin, wie hast du das zusammengebaut und umgerechnet? Braucht es da Scripte? Wärst du so knieweich und würdest hier mal den Widgetexport kopieren? 🙂
                                      darkiop Most Active @Tom Son last edited by darkiop
                                      @Tom-Son Schau dir einfach mal das Bar Chart Widget an, du kannst da einen DP je Bar definieren und den setzt du jeweils auf einen Tag:
                                      @Scrounger baust du dir für das Bar-Chart mit dem Traffic Daten ein JSON zusammen und rechnest da direkt von Bytes in GB um? Wenn ja, würdest du das zur Verfügung stellen?
                                      • Scrounger
                                        Scrounger Developer @darkiop last edited by Scrounger
                                        @darkiop sagte in [Major Update] UniFi Adapter v0.5.0:
                                        Jup bau das JSON per skript zusammen. Bin aktuell dran das Beispiel Material Design Widgets: UniFi Netzwerk Status für die Version 0.5.x anzupassen.
                                        Das wird aber wesentlich größer. Gibt dann mehr als nur die Clients Übersicht, u.a. Devices, Netzwerk Traffic, Speedtest, WLAN Anzahl Gerät, Alarmmeldungen, etc. in einer responsiv View. So in der Art wie das Wetter Beispiel Projekt.
                                        Hier ist der Code Auszug für das Traffic Bar Chart, da das aber sehr intergriert ist, funktioniert das nicht out of the box. Wer das braucht, muss sich noch etwas gedulden bis ich das neue Projekt fertig habe.
                                        function updateTrafficChart() {
                                            let methodName = 'updateTrafficChart'
                                            try {
                                                let chart = {};
                                                let graphs = [];
                                                let axisLabels = [];
                                                let gesendetValues = [];
                                                let empfangenValues = [];
                                                for (var i = gateway_lastDays - 1; i >= 0; i--) {
                                                    let dayDate = getValue(`unifi.0.default.gateway_traffic.${gatewayTrafficSettings.mac}.day_${i}.date`, undefined);
                                                    if (i === 0) {
                                                        axisLabels.push(`Heute\\n${moment(dayDate).format('DD.MM')}`);
                                                    } else if (i === 1) {
                                                        axisLabels.push(`Gestern\\n${moment(dayDate).format('DD.MM')}`);
                                                    } else {
                                                        if (dayDate) {
                                                            axisLabels.push(moment(dayDate).format('ddd[\\n]DD.MM'));
                                                        } else {
                                                            axisLabels.push(i);
                                                    let gesendet = getValue(`unifi.0.default.gateway_traffic.${gatewayTrafficSettings.mac}.day_${i}.sent`, 0) / 1024 / 1024 / 1024;
                                                    gesendetValues.push(gesendet);
                                                    let empfangen = getValue(`unifi.0.default.gateway_traffic.${gatewayTrafficSettings.mac}.day_${i}.received`, 0) / 1024 / 1024 / 1024;
                                                    empfangenValues.push(empfangen);
                                                graphs.push(
                                                    Object.assign(
                                                            data: empfangenValues,
                                                            color: gatewayTrafficSettings.empfangenColor,
                                                            legendText: 'empfangen'
                                                        }, gatewayTrafficChartSettings)
                                                graphs.push(
                                                    Object.assign({
                                                        data: gesendetValues,
                                                        color: gatewayTrafficSettings.gesendetColor,
                                                        legendText: 'gesendet'
                                                chart = {
                                                    axisLabels: axisLabels,
                                                    graphs: graphs
                                                mySetState(gateway_dpTrafficChart, JSON.stringify(chart), 'string', 'JSON string für JSON Chart Widget');
                                            } catch (ex) {
                                                console.error(`${methodName} error: ${ex.message}`);
                                                console.error(`${methodName} stack: ${ex.stack}`);
                                        • Tom Son
                                          Eine Frage, im Abschnitt "health" sind von 3 Adaptern (vermutlich) RX und TX aber welche Adapter sind das?
                                          braindead 1 Reply Last reply Reply Quote 0
                                          • Tom Son
                                            Noch ne Frage: im Abschnitt WAN lässt sich rx und tx nicht in die "Settings_for_history.0" hinzufügen. Ist das jetzt nur ein Problem bei mir? Oder geht das da generell nicht?
                                            1.2k
                                            unifi
                                            54
                                            510
                                            113884
