    4. Hm-rpc 1.2.0
    Hm-rpc 1.2.0
      Brati last edited by
      Hab heute auch geupdated. BIN RPC läuft XML auch. Folgende Fehler bleiben, also waren vorher auch schon.
      1. Jalousie Status wird bei Neustart von Iobroker nicht eingelesen
      2. Bei Bin RPC fehlen die Namen der Geräte
      Die CCU läuft auf 2.17.15.
      Gesendet via Tapatalk.
        pix last edited by
        habe ja auf ein Backup vor dem Update zurückgespielt (hm-rpc 1.1.3). Leider seitdem trotzdem Fehler:
        2016-06-21 22:06:57.129  - [31merror[39m: hm-rpc.0 Error: XML-RPC fault: ping: unknown method name
        2016-06-21 22:08:27.130  - [31merror[39m: hm-rpc.0 Error: XML-RPC fault: ping: unknown method name
        `2016-06-21 21:36:20.053  - [32minfo[39m: host.MacMini-Ethernet.fritz.box instance system.adapter.hm-rpc.0 started with pid 3024
        2016-06-21 21:36:20.585  - [32minfo[39m: hm-rpc.0 starting. Version 1.1.3 in /Users/pix/Documents/iobroker/node_modules/iobroker.hm-rpc
        2016-06-21 21:36:20.780  - [32minfo[39m: hm-rpc.0 binrpc server is trying to listen on 192.168.178.38:3000
        2016-06-21 21:36:20.781  - [32minfo[39m: hm-rpc.0 binrpc -> 192.168.178.33:2001 init ["xmlrpc_bin://192.168.178.38:3000","hm-rpc.0"]
        2016-06-21 21:36:20.794  - [32minfo[39m: hm-rpc.0 binrpc <- listDevices ["hm-rpc.0"]
        2016-06-21 21:36:20.832  - [32minfo[39m: hm-rpc.0 binrpc -> 371 devices
        2016-06-21 21:36:23.877  - [31merror[39m: uncaught exception: Cannot read property '2' of undefined
        2016-06-21 21:36:23.879  - [31merror[39m: TypeError: Cannot read property '2' of undefined
            at handleCall (/Users/pix/Documents/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:74:48)
            at Socket. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:55:22)
            at emitOne (events.js:77:13)
            at Socket.emit (events.js:169:7)
            at readableAddChunk (_stream_readable.js:146:16)
            at Socket.Readable.push (_stream_readable.js:110:10)
            at TCP.onread (net.js:523:20)
        2016-06-21 21:36:23.880  - [32minfo[39m: hm-rpc.0 binrpc -> 192.168.178.33:2001 init ["xmlrpc_bin://192.168.178.38:3000",""]
        2016-06-21 21:36:23.951  - [32minfo[39m: hm-rpc.0 terminating[/code]</anonymous>`
        Pix
        Edit: Nach Neustart CCU1 hetzt keine Verbindung mehr über HM-RPC.0 (ccu1)
        • Bluefox
          Bluefox last edited by
          Ich habe 1.3.0 auf dem git gemacht.
          Kann jemand prüfen? Da habe ich das Problem mit bin-rpc gelöst.
          • Bluefox
            @pix:
            Pix
            Da kommen unerwartete Daten vom CCU.
            Kannst du _~~[i]~~/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js[/i]_ ändern (ab Zeile 70):
            von
            `~~[code]~~	    // reorder WORKING datapoint
                        for (var i = 0; i < request.params[0].length; i++) {
                            if (request.params[0][i].params[2] === 'WORKING') {
                                request.params[0][0] = request.params[0].splice(i, 1, request.params[0][0])[0];
            auf
                            if (request.params[0][i].params && request.params[0][i].params[2] === 'WORKING') {
                        }` [/i][/i][/code][/i][/code]
            • nieIP
              nieIP last edited by
              Hallo
              ich versuche es. Bisher bin ich noch mit der Installation beschäftigt 😞
              1.3.0 bin-rpc funktioniert bei mir.
              Daten werden von der CCU empfangen.
              Danke für die Reparatur
               hm-rpc-0	2016-06-23 22:58:51.987	info	Connected
              hm-rpc-0	2016-06-23 22:58:50.118	info	binrpc -> 680 devices
              hm-rpc-0	2016-06-23 22:58:49.942	info	binrpc <- listDevices ["hm-rpc.0"]
              hm-rpc-0	2016-06-23 22:58:49.924	info	binrpc <- system.listMethods ["hm-rpc.0"]
              hm-rpc-0	2016-06-23 22:58:49.890	info	Connected. Send init...
              hm-rpc-0	2016-06-23 22:58:49.685	info	1 Init binrc...
              hm-rpc-0	2016-06-23 22:58:49.681	info	binrpc client is trying to connect to 192.168.1.55:2001 with ["xmlrpc_bin://192.168.1.161:2001","hm-rpc.0"]
              hm-rpc-0	2016-06-23 22:58:49.679	info	binrpc server is trying to listen on 192.168.1.161:2001
              hm-rpc-0	2016-06-23 22:58:48.547	info	starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
              host-raspi-3	2016-06-23 22:58:47.286	info	instance system.adapter.hm-rpc.0 started with pid 31917
              host-raspi-3	2016-06-23 22:58:44.852	info	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
              hm-rpc-0	2016-06-23 22:58:44.822	info	terminating
                Habe wie immer direkt in der produktiven Umgebung upgedatet.
                Keine Fehlermeldung im Log.
                Umgeschaltet auf BIN
                hm-rpc-1	2016-06-23 22:57:28.427	warn	No image for "HM-RC-2-PBU-FM" found.
                hm-rpc-1	2016-06-23 22:57:28.427	warn	No image for "HM-PB-2-FM" found.
                hm-rpc-1	2016-06-23 22:57:28.426	warn	No image for "HM-PB-2-FM" found.
                hm-rpc-1	2016-06-23 22:57:28.416	warn	No image for "ZEL STG RM FDK" found.
                hm-rpc-1	2016-06-23 22:57:28.415	warn	No image for "ZEL STG RM FDK" found.
                hm-rpc-1	2016-06-23 22:57:28.414	warn	No image for "ZEL STG RM FDK" found.
                hm-rpc-1	2016-06-23 22:57:28.408	info	binrpc <- newDevices 382
                hm-rpc-1	2016-06-23 22:57:25.365	info	Connected
                hm-rpc-1	2016-06-23 22:57:25.185	info	binrpc -> 0 devices
                hm-rpc-1	2016-06-23 22:57:25.132	info	binrpc <- listDevices ["hm-rpc.1"]
                hm-rpc-1	2016-06-23 22:57:25.117	info	binrpc <- system.listMethods ["hm-rpc.1"]
                hm-rpc-1	2016-06-23 22:57:25.093	info	Connected. Send init...
                hm-rpc-1	2016-06-23 22:57:24.886	info	1 Init binrc...
                hm-rpc-1	2016-06-23 22:57:24.882	info	binrpc client is trying to connect to 192.168.138.52:2001 with ["xmlrpc_bin://192.168.138.44:2001","hm-rpc.1"]
                hm-rpc-1	2016-06-23 22:57:24.879	info	binrpc server is trying to listen on 192.168.138.44:2001
                hm-rpc-1	2016-06-23 22:57:24.205	info	starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
                host-Test-Pi3	2016-06-23 22:57:22.896	info	instance system.adapter.hm-rpc.1 started with pid 31010
                Sieht gut aus, (trotz lxccu 😄 )
                Mal überwachen, ob die Daten auch aktualisiert werden
                Rainer
                • Bluefox
                  Wer hat die Bilder für: ZEL STG RM FDK, HM-PB-2-FM und HM-RC-2-PBU-FM?
                  angelnu?
                    Der Zel ist ein tfk nur von Roto
                    Rainer
                    • N
                      nobody last edited by
                      Hallo Bluefox,
                      ich hab die Version 1.3.0 installiert und mit mehreren Aktoren ausprobiert.
                      Mit einfachen Schaltaktoren klappt die Übertragung in beide Richtungen.
                      Problem ist auch hier der Jalousie-Aktor. Damit klappt es bei mir leider noch nicht.
                      Wenn ich den Wert für level in VIS ändere, wird dieser korrekt übertragen.
                      Wenn ich die Jalousie von Hand oder in der Homematic ändere, kam jedoch nur eine Änderung auf 0 (komplett zu) durch. Alle anderen Änderungen werden nicht übertragen.
                      Markus
                      • N
                        Ich hab jetzt auch den Grund gefunden, warum die Level-Werte falsch sind:
                        Es fehlt die Sonderlogik für Unit=100% in der neuen Version.
                        Statt 45% oder 100% wird nun als Level 0.45 % oder 1 % eingetragen.
                          pix last edited by
                          @Bluefox:
                          Kannst du /opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js ändern (ab Zeile 70):
                          von
                           `// reorder WORKING datapoint
                          auf
                          Erledigt. HM-RPC und HM-REGA vorher angehalten. Warte Änderungen ab.
                          Danke,
                          Pix
                          ~~[color]~~
                          EDIT:[/color]
                          XML Verbindung brachte weiterhin Fehler:
                          `~~[code]~~2016-06-24 11:57:19.970  - [31merror[39m: hm-rpc.0 Error: XML-RPC fault: ping: unknown method name[/code]`
                          Umstellung auf BIN-RPC funktionierte danach tadellos. Keine Fehler ausser dem obligatorischen
                          `~~[code]~~2016-06-24 11:58:40.865  - [33mwarn[39m: hm-rpc.1 No image for "HM-TC-IT-WM-W-EU" found.[/code]`
                           :lol:
                          Somit sind auch Fehler beim Auslesen der Stromzähler und beim Schreiben der LED16-Anzeige wieder korrigiert.
                          Danke![/code][/code][/i][/i][/code][/i]
                          • Bluefox
                            @nobody:
                            filename="levelbug.png" index="0">~~ `
                            Kannst du das Objekt hier Posten?
                            • N
                              Was benötigst du genau?
                              Hier erstmal ein Export eines Jalousieaktors von der Admin-Seite:
                              ! {"hm-rpc.0.MEQ0735184.1":{"_id":"hm-rpc.0.MEQ0735184.1","type":"channel","common":{"name":"HM-LC-Bl1PBU-FMMEQ0735184:1","role":"blind","icon":"/icons/PushButton-2ch-wm_thumb.png"},"native":{"ADDRESS":"MEQ0735184:1","AES_ACTIVE":0,"DIRECTION":2,"FLAGS":1,"INDEX":1,"LINK_SOURCE_ROLES":"","LINK_TARGET_ROLES":"SWITCHWEATHER_CS","PARAMSETS":["LINK","MASTER","VALUES"],"PARENT":"MEQ0735184","PARENT_TYPE":"HM-LC-Bl1PBU-FM","TYPE":"BLIND","VERSION":8}},"hm-rpc.0.MEQ0735184.0":{"_id":"hm-rpc.0.MEQ0735184.0","type":"channel","common":{"name":"RolloWohnzOst1:0","icon":"/icons/PushButton-2ch-wm_thumb.png"},"native":{"ADDRESS":"MEQ0735184:0","AES_ACTIVE":0,"DIRECTION":0,"FLAGS":3,"INDEX":0,"LINK_SOURCE_ROLES":"","LINK_TARGET_ROLES":"","PARAMSETS":["MASTER","VALUES"],"PARENT":"MEQ0735184","PARENT_TYPE":"HM-LC-Bl1PBU-FM","TYPE":"MAINTENANCE","VERSION":8}},"hm-rpc.0.MEQ0735184":{"_id":"hm-rpc.0.MEQ0735184","type":"device","common":{"name":"RolloWohnzOst1","role":"blind","icon":"/icons/PushButton-2ch-wm_thumb.png"},"native":{"ADDRESS":"MEQ0735184","AVAILABLE_FIRMWARE":"2.8","CHILDREN":["MEQ0735184:0","MEQ0735184:1"],"FIRMWARE":"2.8","FLAGS":1,"INTERFACE":"LEQ0418982","PARAMSETS":["MASTER"],"PARENT":"","RF_ADDRESS":4093332,"ROAMING":0,"RX_MODE":1,"TYPE":"HM-LC-Bl1PBU-FM","UPDATABLE":1,"VERSION":8}},"hm-rpc.0.MEQ0735184.0.AES_KEY":{"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":127,"role":"value","name":"RolloWohnzOst1:0.AES_KEY"},"native":{"DEFAULT":0,"FLAGS":0,"ID":"AES_KEY","MAX":127,"MIN":0,"OPERATIONS":1,"TAB_ORDER":8,"TYPE":"INTEGER","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.0.AES_KEY"},"hm-rpc.0.MEQ0735184.0.CONFIG_PENDING":{"type":"state","common":{"def":false,"type":"boolean","read":true,"write":false,"role":"indicator","name":"RolloWohnzOst1:0.CONFIG_PENDING"},"native":{"DEFAULT":false,"FLAGS":9,"ID":"CONFIG_PENDING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":2,"TYPE":"BOOL","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.0.CONFIG_PENDING"},"hm-rpc.0.MEQ0735184.0.DEVICE_IN_BOOTLOADER":{"type":"state","common":{"def":false,"type":"boolean","read":true,"write":false,"name":"RolloWohnzOst1:0.DEVICE_IN_BOOTLOADER"},"native":{"DEFAULT":false,"FLAGS":9,"ID":"DEVICE_IN_BOOTLOADER","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":6,"TYPE":"BOOL","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.0.DEVICE_IN_BOOTLOADER"},"hm-rpc.0.MEQ0735184.0.DUTYCYCLE":{"type":"state","common":{"def":false,"type":"boolean","read":true,"write":false,"role":"value","name":"RolloWohnzOst1:0.DUTYCYCLE"},"native":{"DEFAULT":false,"FLAGS":9,"ID":"DUTYCYCLE","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":3,"TYPE":"BOOL","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.0.DUTYCYCLE"},"hm-rpc.0.MEQ0735184.0.RSSI_DEVICE":{"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":-2147483648,"max":2147483647,"role":"value","name":"RolloWohnzOst1:0.RSSI_DEVICE"},"native":{"DEFAULT":0,"FLAGS":1,"ID":"RSSI_DEVICE","MAX":2147483647,"MIN":-2147483648,"OPERATIONS":5,"TAB_ORDER":4,"TYPE":"INTEGER","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.0.RSSI_DEVICE"},"hm-rpc.0.MEQ0735184.0.RSSI_PEER":{"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":-2147483648,"max":2147483647,"role":"value.rssi","name":"RolloWohnzOst1:0.RSSI_PEER"},"native":{"DEFAULT":0,"FLAGS":1,"ID":"RSSI_PEER","MAX":2147483647,"MIN":-2147483648,"OPERATIONS":5,"TAB_ORDER":5,"TYPE":"INTEGER","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.0.RSSI_PEER"},"hm-rpc.0.MEQ0735184.0.STICKY_UNREACH":{"type":"state","common":{"def":false,"type":"boolean","read":true,"write":true,"role":"indicator.unreach","name":"RolloWohnzOst1:0.STICKY_UNREACH"},"native":{"DEFAULT":false,"FLAGS":25,"ID":"STICKY_UNREACH","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":1,"TYPE":"BOOL","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.0.STICKY_UNREACH"},"hm-rpc.0.MEQ0735184.0.UNREACH":{"type":"state","common":{"def":false,"type":"boolean","read":true,"write":false,"role":"indicator.unreach","name":"RolloWohnzOst1:0.UNREACH"},"native":{"DEFAULT":false,"FLAGS":9,"ID":"UNREACH","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.0.UNREACH"},"hm-rpc.0.MEQ0735184.0.UPDATE_PENDING":{"type":"state","common":{"def":false,"type":"boolean","read":true,"write":false,"name":"RolloWohnzOst1:0.UPDATE_PENDING"},"native":{"DEFAULT":false,"FLAGS":9,"ID":"UPDATE_PENDING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":7,"TYPE":"BOOL","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.0.UPDATE_PENDING"},"hm-rpc.0.MEQ0735184.1.DIRECTION":{"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":3,"states":{"0":"NONE","1":"UP","2":"DOWN","3":"UNDEFINED"},"role":"indicator.direction","name":"HM-LC-Bl1PBU-FMMEQ0735184:1.DIRECTION"},"native":{"DEFAULT":0,"FLAGS":3,"ID":"DIRECTION","MAX":3,"MIN":0,"OPERATIONS":5,"TAB_ORDER":3,"TYPE":"ENUM","UNIT":"","VALUE_LIST":["NONE","UP","DOWN","UNDEFINED"]},"_id":"hm-rpc.0.MEQ0735184.1.DIRECTION"},"hm-rpc.0.MEQ0735184.1.INHIBIT":{"type":"state","common":{"def":false,"type":"boolean","read":true,"write":true,"role":"state.inhibit","name":"HM-LC-Bl1PBU-FMMEQ0735184:1.INHIBIT"},"native":{"CONTROL":"NONE","DEFAULT":false,"FLAGS":1,"ID":"INHIBIT","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":2,"TYPE":"BOOL","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.1.INHIBIT"},"hm-rpc.0.MEQ0735184.1.INSTALL_TEST":{"type":"state","common":{"def":false,"type":"boolean","read":false,"write":true,"role":"indicator","name":"HM-LC-Bl1PBU-FMMEQ0735184:1.INSTALL_TEST"},"native":{"DEFAULT":false,"FLAGS":3,"ID":"INSTALL_TEST","MAX":true,"MIN":false,"OPERATIONS":2,"TAB_ORDER":4,"TYPE":"ACTION","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.1.INSTALL_TEST"},"hm-rpc.0.MEQ0735184.1.LEVEL":{"type":"state","common":{"def":0,"type":"number","read":true,"write":true,"min":0,"max":100,"unit":"%","role":"level.blind","workingID":"WORKING","name":"HM-LC-Bl1PBU-FMMEQ0735184:1.LEVEL"},"native":{"CONTROL":"BLIND.LEVEL","DEFAULT":0,"FLAGS":1,"ID":"LEVEL","MAX":1,"MIN":0,"OPERATIONS":7,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"100%"},"_id":"hm-rpc.0.MEQ0735184.1.LEVEL"},"hm-rpc.0.MEQ0735184.1.STOP":{"type":"state","common":{"def":false,"type":"boolean","read":false,"write":true,"role":"action.stop","name":"HM-LC-Bl1PBU-FMMEQ0735184:1.STOP"},"native":{"CONTROL":"BLIND.STOP","DEFAULT":false,"FLAGS":1,"ID":"STOP","MAX":true,"MIN":false,"OPERATIONS":2,"TAB_ORDER":1,"TYPE":"ACTION","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.1.STOP"},"hm-rpc.0.MEQ0735184.1.WORKING":{"type":"state","common":{"def":false,"type":"boolean","read":true,"write":false,"role":"indicator.working","name":"HM-LC-Bl1PBU-FMMEQ0735184:1.WORKING"},"native":{"DEFAULT":false,"FLAGS":3,"ID":"WORKING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":5,"TYPE":"BOOL","UNIT":""},"_id":"hm-rpc.0.MEQ0735184.1.WORKING"},"hm-rpc.0.MEQ0735184.0.CONFIG_PENDING_ALARM":{"type":"state","common":{"name":"AL-MEQ0735184:0.CONFIG_PENDING","type":"boolean","role":"indicator.alarm","read":true,"write":true,"def":false},"native":{"Name":"AL-MEQ0735184:0.CONFIG_PENDING","TypeName":"ALARM","DP":"12759"},"_id":"hm-rpc.0.MEQ0735184.0.CONFIG_PENDING_ALARM"},"hm-rpc.0.MEQ0735184.0.DEVICE_IN_BOOTLOADER_ALARM":{"type":"state","common":{"name":"AL-MEQ0735184:0.DEVICE_IN_BOOTLOADER","type":"boolean","role":"indicator.alarm","read":true,"write":true,"def":false},"native":{"Name":"AL-MEQ0735184:0.DEVICE_IN_BOOTLOADER","TypeName":"ALARM","DP":"12763"},"_id":"hm-rpc.0.MEQ0735184.0.DEVICE_IN_BOOTLOADER_ALARM"},"hm-rpc.0.MEQ0735184.0.DUTYCYCLE_ALARM":{"type":"state","common":{"name":"AL-MEQ0735184:0.DUTYCYCLE","type":"boolean","role":"indicator.alarm","read":true,"write":true,"def":false},"native":{"Name":"AL-MEQ0735184:0.DUTYCYCLE","TypeName":"ALARM","DP":"12767"},"_id":"hm-rpc.0.MEQ0735184.0.DUTYCYCLE_ALARM"},"hm-rpc.0.MEQ0735184.0.STICKY_UNREACH_ALARM":{"type":"state","common":{"name":"AL-MEQ0735184:0.STICKY_UNREACH","type":"boolean","role":"indicator.alarm","read":true,"write":true,"def":false},"native":{"Name":"AL-MEQ0735184:0.STICKY_UNREACH","TypeName":"ALARM","DP":"12773"},"_id":"hm-rpc.0.MEQ0735184.0.STICKY_UNREACH_ALARM"},"hm-rpc.0.MEQ0735184.0.UNREACH_ALARM":{"type":"state","common":{"name":"AL-MEQ0735184:0.UNREACH","type":"boolean","role":"indicator.alarm","read":true,"write":true,"def":false},"native":{"Name":"AL-MEQ0735184:0.UNREACH","TypeName":"ALARM","DP":"12777"},"_id":"hm-rpc.0.MEQ0735184.0.UNREACH_ALARM"},"hm-rpc.0.MEQ0735184.0.UPDATE_PENDING_ALARM":{"type":"state","common":{"name":"AL-MEQ0735184:0.UPDATE_PENDING","type":"boolean","role":"indicator.alarm","read":true,"write":true,"def":false},"native":{"Name":"AL-MEQ0735184:0.UPDATE_PENDING","TypeName":"ALARM","DP":"12781"},"_id":"hm-rpc.0.MEQ0735184.0.UPDATE_PENDING_ALARM"}}
                              • N
                                Ich hab mal noch ein wenig nachgeforscht. Das Problem ist der folgende Code-Abschnitt:
                                    event: function (err, params) {
                                        adapter.log.debug(adapter.config.type + 'rpc <- event ' + JSON.stringify(params));
                                        var val;
                                        var channel = params[1].replace(':', '.');
                                        var name = params[0] + '.' + channel + '.' + params[2];
                                        if (dpTypes[name] && dpTypes[name].UNIT === '100%') {
                                            val = (params[3] * 100);
                                        } else {
                                            val = params[3];
                                Es wird versucht, mit dem Namen in dpTypes den Eintrag zu finden. Problem ist nur, dass kein Eintrag gefunden wird.
                                Hier der relevante Ausschnitt für einen der Aktoren:
                                ! name: raspberrypi.hm-rpc.0.LEQ1438264.1.LEVEL New value:1
                                ! dpTypes: {"hm-rpc.0.LEQ1438264.0.AES_KEY":{"UNIT":"","TYPE":"INTEGER"},"hm-rpc.0.LEQ1438264.0.CONFIG_PENDING":{"UNIT":"","TYPE":"BOOL"},"hm-rpc.0.LEQ1438264.0.DEVICE_IN_BOOTLOADER":{"UNIT":"","TYPE":"BOOL"},"hm-rpc.0.LEQ1438264.0.DUTYCYCLE":{"UNIT":"","TYPE":"BOOL"},"hm-rpc.0.LEQ1438264.0.RSSI_DEVICE":{"UNIT":"","TYPE":"INTEGER"},"hm-rpc.0.LEQ1438264.0.RSSI_PEER":{"UNIT":"","TYPE":"INTEGER"},"hm-rpc.0.LEQ1438264.0.STICKY_UNREACH":{"UNIT":"","TYPE":"BOOL"},"hm-rpc.0.LEQ1438264.0.UNREACH":{"UNIT":"","TYPE":"BOOL"},"hm-rpc.0.LEQ1438264.0.UPDATE_PENDING":{"UNIT":"","TYPE":"BOOL"},"hm-rpc.0.LEQ1438264.1.DIRECTION":{"UNIT":"","TYPE":"ENUM"},"hm-rpc.0.LEQ1438264.1.INHIBIT":{"UNIT":"","TYPE":"BOOL"},"hm-rpc.0.LEQ1438264.1.INSTALL_TEST":{"UNIT":"","TYPE":"ACTION"},"hm-rpc.0.LEQ1438264.1.LEVEL":{"UNIT":"100%","TYPE":"FLOAT"},"hm-rpc.0.LEQ1438264.1.STOP":{"UNIT":"","TYPE":"ACTION"},"hm-rpc.0.LEQ1438264.1.WORKING":{"UNIT":"","TYPE":"BOOL"}}
                                Update:
                                Der Name, mit dem gesucht wird, enthält den Host-Namen der Instanz raspberrypi.hm-rpc.0.LEQ1438264.1.LEVEL,
                                Im Array sind die Werte aber nur ohne Host-Namen drin: hm-rpc.0.LEQ1438264.1.LEVEL
                                mfg
                                Markus
                                • N
                                  Hallo bluefox,
                                  ich hab jetzt die hm-rpc.js so abgeändert, dass in den Methoden für das Setzen und Übertagen der Werte beim Zugriff auf dpTypes der Hostname ergänzt wird. Jetzt funktioniert bei mir die Übertagung wieder in beide Richtungen.
                                  Keine Ahnung, ob die Änderung so in deinem Interesse ist, aber vielleicht hilft die Datei ja bei der Fehlerbereinigung.
                                  Markus
                                  632_hm-rpc.js
                                  • Bluefox
                                    Ich habe da was geändert, was ich nicht ändern sollte. Jetzt gibt es neue Version.
                                    • Bluefox
                                      Geht jetzt ?
                                      • N
                                        Hallo bluefox,
                                        Ja geht jetzt wieder.
                                        Vielen Dank.
                                        Gesendet von meinem GT-N8000 mit Tapatalk
                                          Hmm, Update installiert und Reboot gemacht. Die Jalousien haben danach Level "null". Nach der ersten Betätigung egal ob Iobroker oder am Gerät stimmt es.
                                          Grüße Brati
                                            Ist so! 😄
                                            Dazu gibt's schon mehrere Postings.
                                            Rainer
                                            63
                                            7216
