    4. Test Adapter Alarm 3.6.x
    • blauholsten
      blauholsten Developer @blauholsten last edited by
      @blauholsten kannst du mir Mal einen kleinen debug Auszug senden
        sigi234 Forum Testing Most Active @blauholsten last edited by sigi234
        @blauholsten sagte in Test Adapter Alarm 1.1.x:
        alarm.0 2020-07-06 11:52:53.339 debug (21572) system.adapter.admin.0: logging true
        alarm.0 2020-07-06 11:52:52.438 debug (21572) state alarm.0.status.enableable changed: false (ack = false)
        alarm.0 2020-07-06 11:52:52.274 debug (21572) Notification circuit list: hm-rpc.0.NEQ1826414.1.STATE,hm-rpc.0.OEQ0926852.1.STATE
        alarm.0 2020-07-06 11:52:52.274 debug (21572) Inside circuit list: hm-rpc.0.NEQ1826414.1.STATE,hm-rpc.0.OEQ0926852.1.STATE
        alarm.0 2020-07-06 11:52:52.273 debug (21572) Alarm circuit list: hm-rpc.0.NEQ1826414.1.STATE,hm-rpc.0.OEQ0926852.1.STATE,hue.0.Philips_hue.Küche_Sensor.presence
        alarm.0 2020-07-06 11:52:52.271 debug (21572) SUBSCRIBTION for: hue.0.Philips_hue.Küche_Sensor.presence
        alarm.0 2020-07-06 11:52:52.270 debug (21572) SUBSCRIBTION for: hm-rpc.1.00091A49A082FC.1.MOTION
        alarm.0 2020-07-06 11:52:52.270 debug (21572) SUBSCRIBTION for: hm-rpc.0.OEQ0926852.1.STATE
        alarm.0 2020-07-06 11:52:52.269 debug (21572) SUBSCRIBTION for: hm-rpc.0.NEQ1818500.1.STATE
        alarm.0 2020-07-06 11:52:52.266 debug (21572) SUBSCRIBTION for: hm-rpc.0.NEQ1826414.1.STATE
        alarm.0 2020-07-06 11:52:51.053 debug (21572) system.adapter.admin.0: logging false
        alarm.0 2020-07-06 11:52:50.331 debug (21572) {"hm-rpc.0.NEQ1826414.1.STATE":true,"hm-rpc.0.NEQ1818500.1.STATE":false,"hm-rpc.0.OEQ0926852.1.STATE":true,"hm-rpc.1.00091A49A082FC.1.MOTION":false,"hue.0.Philips_hue.Küche_Sensor.presence":t
        alarm.0 2020-07-06 11:52:50.266 debug (21572) Night rest configured from 23:50 to 5:55
        alarm.0 2020-07-06 11:52:50.257 debug (21572) Messages to: ["email"]
        alarm.0 2020-07-06 11:52:50.237 info (21572) starting. Version 1.1.0 in C:/Program Files/iobroker/Test/node_modules/iobroker.alarm, node: v12.18.0, js-controller: 3.1.6
        alarm.0 2020-07-06 11:52:50.047 debug (21572) statesDB connected
        alarm.0 2020-07-06 11:52:50.047 debug (21572) States connected to redis: 127.0.0.1:9000
        alarm.0 2020-07-06 11:52:50.038 debug (21572) States create System PubSub Client
        alarm.0 2020-07-06 11:52:50.037 debug (21572) States create User PubSub Client
        alarm.0 2020-07-06 11:52:50.031 debug (21572) Redis States: Use Redis connection: 127.0.0.1:9000
        alarm.0 2020-07-06 11:52:50.031 debug (21572) objectDB connected
        alarm.0 2020-07-06 11:52:50.029 debug (21572) Objects connected to redis: 127.0.0.1:9013
        alarm.0 2020-07-06 11:52:50.018 debug (21572) Objects client initialize lua scripts
        alarm.0 2020-07-06 11:52:50.017 debug (21572) Objects create User PubSub Client
        alarm.0 2020-07-06 11:52:50.017 debug (21572) Objects create System PubSub Client
        alarm.0 2020-07-06 11:52:50.016 debug (21572) Objects client ready ... initialize now
        alarm.0 2020-07-06 11:52:50.000 debug (21572) Redis Objects: Use Redis connection: 127.0.0.1:9013
        alarm.0 2020-07-06 11:52:46.404 info (35040) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        alarm.0 2020-07-06 11:52:46.404 info (35040) terminating
        alarm.0 2020-07-06 11:52:46.402 info (35040) cleaned everything up...
        alarm.0 2020-07-06 11:52:46.400 info (35040) Got terminate signal TERMINATE_YOURSELF
        Kommt nicht immer, war jetzt das 2. Mal so. Glaube immer nach einen Neustart von ioB
        blauholsten 1 Reply Last reply Reply Quote 0
        • blauholsten
          blauholsten Developer @sigi234 last edited by
          @sigi234 ich bräuchte den Log wo das passiert
            Ja, aber es passiert nur selten. Warum kann ich nicht nachstellen. Weis nur das es um 09:19 Uhr war.
            Die LOG Größe ging innerhalb von 1 Sekunde auf 4 MB
            16:35: Alarmanlage kann nicht aktiviert werden, kontrolliere: Terrassentuer,Badfenster
            12:39: Alarmanlage deaktiviert
            12:39: Alarmanlage meldet Einbruch durch Panik Schalter
            12:39: Alarmanlage kann nicht aktiviert werden, kontrolliere: Terrassentuer,Badfenster
            12:38: Scharf innen deaktiviert
            12:38: Scharf innen aktiviert
            12:37: Alarmanlage kann nicht aktiviert werden, kontrolliere: Terrassentuer,Badfenster
            09:19: Nachtruhe beginnt
            09:19: Nachtruhe endet
              @blauholsten
              use.toggle_password -> Deaktivierung/Aktivierung der Anlage (Alarmkreis) mit Passwort
              Auf welches Skript greift das zu? Auf das von Pincode? @Homer-J
                kilasat last edited by
                vielleicht kann mir hier jemand helfen. Ich habe eine Zigbee Sirene von Heimann die am Conbee 2 betrieben wird. Diese wird mit dem Datenpunkt "alert" und dem State - Iselect ausgelöst. None = beendet die Sirene. Mit "blink" blint diese.
                Händisch ausgelöst funktioniert das ganze auch. Wenn ich dies jedoch mit dem Verknüpfungen aus dem Alarmadapter mache, dann passiert nichts. Ich sehe zwar, dass sich der State ändern aber es wird nichts ausgelöst. Woran könnte das liegen? Oder muss ich das sont mit einem Blockly machen?
                  kilasat @Homer.J. last edited by
                  @Homer-J sagte in Test Adapter Alarm 1.1.x:
                  So hab mal etwas zusammen gebastelt, frage vorne weg soll ich es hier einstellen hier mal ein paar Bilder zu meiner Visualisierung. Voraussetzung ist das [Projekt] MDCSS v2: Material Design CSS Version 2 .
                  So bitte Testen, die Datenpunkte so anlegen wie die Textdatei heißen dann sollte alles auf Anhieb klappen.
                  Ich habe für die Pineingabe ein eigenes Script, bitte unter Javascript anlegen die Alarmanlage ist schon damit verknüpft einzige im Script den eigenen Pin eingeben, ist beschriftet.
                  Viel Spaß damit.
                  Alarmanlage neu.rar
                  Muss ich ein MD_Demo oder MD_Simple vorher einrichten oder kann ich das irgendwo in eine bestehende VIS einfügen?
                  Homer.J. 1 Reply Last reply Reply Quote 0
                  • Homer.J.
                    Homer.J. @kilasat last edited by
                    @kilasat Eigentlich brauchst du nicht alles ist aber schwer zu erklären was du nehmen musst, deshalb nimm eins von beiden und was du nachher nicht brauchst schmeißt du raus.
                      @Homer-J
                      wieso sehe ich die Icons nicht? Hast Du eine Idee? Habe jetzt MD_Simple als Basis genommen.
                      • blauholsten
                        blauholsten Developer @kilasat last edited by
                        @kilasat kann es sein das dein Datenpunkt mit zahlen beschrieben werden muß,
                        Homer.J. K 2 Replies Last reply Reply Quote 0
                        • Homer.J.
                          Homer.J. @blauholsten last edited by Homer.J.
                          @kilasat Hast du den Adapter installiert. ?
                            @Homer-J
                            Nein ist nicht drauf. Habe es eben geprüft.
                            • Homer.J.
                              Homer.J. @kilasat last edited by Homer.J.
                              @kilasat den brauchst du für die button.
                              K 2 Replies Last reply Reply Quote 1
                                @Homer-J besser jetzt 🙈. Danke dir.
                                  Zwei Sachen verstehe ich noch nicht.
                                  Der Countdown wird bei mir ohne Zahlen im Kreis angezeigt. Und was bringen die ersten beiden Profile?
                                  • Homer.J.
                                    @kilasat der linke Button ist fürs rücksetzen wenn die Anlage Fehler zeigt der nächste fürs entschärfen der zeigt dir dann an bitte Pincode eingeben. Wenn ich dich jetzt richtig verstanden habe.
                                    Der Countdown ist bei mir im Adapter auf 30 Sekunden eingestellt vielleicht liegt es daran.
                                    • Mike Weber
                                      Mike Weber last edited by
                                      Erstmal ein großes Lob an die Entwickler. Ein toller Adapter. Glückwunsch.
                                      Klappt auch super, ich habe per Blockly noch um Geofencing erweitert, so dass die Alarmanlage automatisch aktiviert wird - vielleicht eine Idee für den Adapter. 😉
                                      Sonst in der Version 1.0.1 bisher alles schon sehr, sehr gut.
                                      Ein Bug ist mir aufgefallen, wenn man die Alarmanlage extern mit Warnungen aktiviert, dann klappt die Sprachausgabe nicht. Da wäre es toll, wenn dies, analog zu intern auch funktionieren würde. Danke.
                                      • blauholsten
                                        blauholsten Developer @Mike Weber last edited by
                                        @Mike-Weber sagte in Test Adapter Alarm 1.1.x:
                                        Wirklich ein BUG? Willst du eine Sprachausgabe bekommen wenn du nicht da bist???
                                        Mike Weber 1 Reply Last reply Reply Quote 0
                                        • Mike Weber
                                          Mike Weber @blauholsten last edited by
                                          @blauholsten Geht ja um die Aktivierung. 🙂
                                          • blauholsten
                                            @Mike-Weber um in deine beschriebene Situation zu kommen, musst du in den Optionen dies explizit aktivieren! Sollte man dies tun, muss man sich auch bewusst sein, dass noch Dinge offen sein können.
                                            alarm alarmanlage alarmsystem
                                            111
                                            1368
                                            555882
