    4. Test Adapter nanoleaf-lightpanels v1.3.x GitHub/latest
    • O
      oFbEQnpoLKKl6mbY5e13 last edited by oFbEQnpoLKKl6mbY5e13
      Sieht gut aus:
      2020-07-06 16:01:38.441 - info: nanoleaf-lightpanels.0 (4374) starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels, node: v12.16.3, js-controller: 3.1.6
      2020-07-06 16:01:38.471 - info: nanoleaf-lightpanels.0 (4374) Nanoleaf adapter "nanoleaf-lightpanels.0" started.
      2020-07-06 16:01:38.474 - debug: nanoleaf-lightpanels.0 (4374) SSDP events initialized!
      2020-07-06 16:01:38.475 - info: nanoleaf-lightpanels.0 (4374) Connecting to "192.168.0.105:16021"...
      2020-07-06 16:01:38.514 - debug: nanoleaf-lightpanels.0 (4374) Connect timer stopped!
      2020-07-06 16:01:38.515 - info: nanoleaf-lightpanels.0 (4374) Connected to "192.168.0.105:16021
      2020-07-06 16:01:38.516 - warn: nanoleaf-lightpanels.0 (4374) nanoleaf device "NL29" unknown! Using Canvas device as fallback. Please report this to the developer!
      2020-07-06 16:01:38.518 - debug: nanoleaf-lightpanels.0 (4374) nanoleaf Device "Canvas" (NL29) detected!
      2020-07-06 16:01:38.636 - debug: nanoleaf-lightpanels.0 (4374) SSE subscription started, listening...
      2020-07-06 16:02:27.231 - debug: nanoleaf-lightpanels.0 (4374) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","location":"http://192.168.0.105:16021","usn":"uuid:XXX","nts":"ssdp:alive","nt":"nanoleaf:nl29"}
      2020-07-06 16:02:27.231 - debug: nanoleaf-lightpanels.0 (4374) ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","location":"http://192.168.0.105:16021","usn":"uuid:XXX","nts":"ssdp:alive","nt":"nanoleaf:nl29"}
      2020-07-06 16:02:27.232 - debug: nanoleaf-lightpanels.0 (4374) nanoleaf uuid:XXX from device '192.168.0.105' set!
      Suche auch:
      2020-07-06 16:04:14.689 - debug: nanoleaf-lightpanels.0 (4374) Incoming adapter message: searchDevice
      2020-07-06 16:04:14.802 - debug: nanoleaf-lightpanels.0 (4374) TEST: SSDP M-Search found device with USN: uuid:XXX and location: http://192.168.0.105:16021
      2020-07-06 16:04:14.802 - debug: nanoleaf-lightpanels.0 (4374) SSDP M-Search found device with USN: uuid:XXX and OpenAPI location: http://192.168.0.105:16021
      2020-07-06 16:04:14.803 - debug: nanoleaf-lightpanels.0 (4374) TEST: SSDP M-Search found device with USN: uuid:XXX and location: http://192.168.0.106:16021
      2020-07-06 16:04:14.805 - debug: nanoleaf-lightpanels.0 (4374) SSDP M-Search found device with USN: uuid:XXX and OpenAPI location: http://192.168.0.106:16021
      2020-07-06 16:04:19.692 - debug: nanoleaf-lightpanels.0 (4374) MSEARCH: 2 devices found!
      2 Gerät(e) wurde(n) gefunden und konnen in der Liste oben ausgewählt werden
      Welche Liste? 🤔
        daniel_2k @oFbEQnpoLKKl6mbY5e13 last edited by
        @oFbEQnpoLKKl6mbY5e13 sagte in Test Adapter nanoleaf-lightpanels v1.0.x GitHub/latest:
        Welche Liste?
        Wenn die Suche abgeschlossen ist, ist ja das Feld für Host/IP ja leer. Wenn du mit der Maus über das Feld fährst, sollte rechts ein Klapppfeil zu sehen sein. Dann kannst du die Liste ausklappen und da sollten dann alle gefundenen Geräte (IP) drin stehen.
        • O
          Da erscheint kein Pfeil.
          Aber wenn ich Doppelklicke, erhalte ich die zwei IP-Adressen.
            Naja, dass Verhalten dieser Datalist hängt auch etwas vom verwendeten Browser ab. Standardmäßig, wenn man die Adapter-Einstellungen öffnet, ist das ja nur ein stinknormales Inputfeld. Nachdem man die Suche angestoßen hat und was gefunden wurde, ist das eine Datalist. In Chrome sehe ich dann, wenn ich mit der Maus drüberhalte, einen Pfeil. Oder man klickt einfach in das Feld, dann geht die Liste auf.
            Bei Firefox, Edge etc. könnte sein, das da kein Pfeil zu sehen ist. Aber die Liste sollte durch reinklicken auf jeden Fall aufgehen. Habs mit Edge, IE, Firefox und Chrome getestet.
              daniel_2k last edited by
              Habe jetzt die Fixes in Version 1.0.2 gegossen und auf den GitHub Master sowie ins npm published.
              Sollte ab morgen im latest verfügbar sein. Bitte noch mal prüfen, jetzt sollte alles sauber laufen.
              • O
                Okayyyyy.
                (Mindestens 8 Zeichen... 😒 )
                • O
                  2020-07-07 08:23:58.795 - info: nanoleaf-lightpanels.0 (4987) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels, node: v12.16.3, js-controller: 3.1.6
                  2020-07-07 08:23:58.821 - info: nanoleaf-lightpanels.0 (4987) Nanoleaf adapter "nanoleaf-lightpanels.0" started.
                  2020-07-07 08:23:58.824 - debug: nanoleaf-lightpanels.0 (4987) SSDP events initialized!
                  2020-07-07 08:23:58.826 - info: nanoleaf-lightpanels.0 (4987) Connecting to "192.168.0.105:16021"...
                  2020-07-07 08:23:58.870 - debug: nanoleaf-lightpanels.0 (4987) Connect timer stopped!
                  2020-07-07 08:23:58.871 - info: nanoleaf-lightpanels.0 (4987) Connected to "192.168.0.105:16021"
                  2020-07-07 08:23:58.873 - debug: nanoleaf-lightpanels.0 (4987) nanoleaf Device "Canvas" (NL29) detected!
                  2020-07-07 08:23:59.445 - debug: nanoleaf-lightpanels.0 (4987) SSE subscription started, listening...
                  2020-07-07 08:24:41.897 - debug: nanoleaf-lightpanels.0 (4987) ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","location":"http://192.168.0.105:16021","usn":"uuid:XXX","nts":"ssdp:alive","nt":"nanoleaf:nl29"}
                  2020-07-07 08:24:41.899 - debug: nanoleaf-lightpanels.0 (4987) nanoleaf uuid:XXX from device '192.168.0.105' set!
                  • sentinel
                    sentinel last edited by
                    Hallo Daniel.
                    Habe heute Morgen das 1.0.2 update eingespielt und es lief alles gut. Jetzt musste ich gerade den server rebooten und der Adapter reconnected sich danach wieder alle zwei Minuten wie vorher 🙃
                    Das Panel habe ich heute losgeschickt 😉
                      daniel_2k @sentinel last edited by
                      @sentinel
                      Naja, wenn es erst funktioniert hat und dann nicht mehr, dann kann es eigentlich nur ein Firewall/Netzwerkproblem sein. Sprich, es kommen gar keine SSDP Multicasts in dem Adapter respektive ioBroker Host an. Du wolltest ja ohnehin einiges abdrehen. Vielleicht zu viel abgedreht 🙂 ?
                      Jedenfalls im Debug siehst du ja die ssdp:alive Nachrichten. In deinem Log ist davon ja nix zu sehen, also kommt nix an.
                        stefande last edited by
                        @daniel_2k
                        Ich hab hier ein paar Canvas die auch Probleme machen.
                        Der ioBroker läuft unter Debian Buster in einer VirtualBox.
                        Die Suche funktioniert aber das SSE nicht.
                        2020-07-07 18:21:20.253 - info: host.iobroker-deb "system.adapter.nanoleaf-lightpanels.0" enabled
                        2020-07-07 18:21:20.276 - info: host.iobroker-deb instance system.adapter.nanoleaf-lightpanels.0 started with pid 20074
                        2020-07-07 18:21:20.822 - debug: nanoleaf-lightpanels.0 (20074) Redis Objects: Use Redis connection: 127.0.0.1:9001
                        2020-07-07 18:21:20.857 - debug: nanoleaf-lightpanels.0 (20074) Objects client ready ... initialize now
                        2020-07-07 18:21:20.860 - debug: nanoleaf-lightpanels.0 (20074) Objects create System PubSub Client
                        2020-07-07 18:21:20.861 - debug: nanoleaf-lightpanels.0 (20074) Objects create User PubSub Client
                        2020-07-07 18:21:20.869 - debug: nanoleaf-lightpanels.0 (20074) Objects client initialize lua scripts
                        2020-07-07 18:21:20.882 - debug: nanoleaf-lightpanels.0 (20074) Objects connected to redis: 127.0.0.1:9001
                        2020-07-07 18:21:20.887 - debug: nanoleaf-lightpanels.0 (20074) objectDB connected
                        2020-07-07 18:21:20.889 - debug: nanoleaf-lightpanels.0 (20074) Redis States: Use Redis connection: 127.0.0.1:9000
                        2020-07-07 18:21:20.895 - debug: nanoleaf-lightpanels.0 (20074) States create User PubSub Client
                        2020-07-07 18:21:20.897 - debug: nanoleaf-lightpanels.0 (20074) States create System PubSub Client
                        2020-07-07 18:21:20.906 - debug: nanoleaf-lightpanels.0 (20074) States connected to redis: 127.0.0.1:9000
                        2020-07-07 18:21:20.907 - debug: nanoleaf-lightpanels.0 (20074) statesDB connected
                        2020-07-07 18:21:21.587 - info: nanoleaf-lightpanels.0 (20074) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels, node: v12.18.2, js-controller: 3.1.6
                        2020-07-07 18:21:21.617 - info: javascript.0 (1759) script.js.Adapter_Überwachung: Adapter_Überwachung OK
                        2020-07-07 18:21:21.601 - info: nanoleaf-lightpanels.0 (20074) Nanoleaf adapter "nanoleaf-lightpanels.0" started.
                        2020-07-07 18:21:21.603 - debug: nanoleaf-lightpanels.0 (20074) SSDP events initialized!
                        2020-07-07 18:21:21.604 - info: nanoleaf-lightpanels.0 (20074) Connecting to "192.168.0.151:16021"...
                        2020-07-07 18:21:21.658 - debug: nanoleaf-lightpanels.0 (20074) Connect timer stopped!
                        2020-07-07 18:21:21.659 - info: nanoleaf-lightpanels.0 (20074) Connected to "192.168.0.151:16021"
                        2020-07-07 18:21:21.668 - debug: nanoleaf-lightpanels.0 (20074) nanoleaf Device "Canvas" (NL29) detected!
                        2020-07-07 18:21:21.777 - debug: nanoleaf-lightpanels.0 (20074) SSE subscription started, listening...
                        2020-07-07 18:21:21.785 - debug: nanoleaf-lightpanels.0 (20074) Update from OpenAPI: value for state "Canvas.state" changed >>>> set new value: false
                        2020-07-07 18:21:21.797 - debug: nanoleaf-lightpanels.0 (20074) State change status: id: nanoleaf-lightpanels.0.Canvas.state: {"val":false,"ack":true,"ts":1594138881790,"q":0,"from":"system.adapter.nanoleaf-lightpanels.0","user":"system.user.admin","lc":1594138811247}
                        2020-07-07 18:21:24.247 - debug: nanoleaf-lightpanels.0 (20074) system.adapter.admin.0: logging true
                        2020-07-07 18:22:05.531 - info: host.iobroker-deb instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
                        2020-07-07 18:22:36.769 - warn: nanoleaf-lightpanels.0 (20074) Connection to '192.168.0.151:16021' lost, Error: No ssdp:alive detected. Try to reconnect...
                        2020-07-07 18:22:36.770 - debug: nanoleaf-lightpanels.0 (20074) Polling timer stopped!
                        2020-07-07 18:22:36.770 - debug: nanoleaf-lightpanels.0 (20074) Command queue cleared!
                        2020-07-07 18:22:36.771 - debug: nanoleaf-lightpanels.0 (20074) SSE connection closed!
                        2020-07-07 18:22:36.772 - debug: nanoleaf-lightpanels.0 (20074) Connect timer started with 60000 ms
                          daniel_2k @stefande last edited by
                          @stefande
                          Das SSE läuft schon, das hat mit dem "Keep alive" auch erstmal nix zu tun. Das ist ja nur eine ausgehende HTTP-Verbindung zu den nanoleafs.
                          Die Suche nutzt auch SSDP Nachrichten. Allerdings antworten die nanoleaf-Geräte auf einen MSEARCH-Request ja direkt dem Absender. Bei den SSDP:alive Notifications, die genutzt werden, um zu erkennen, ob das Gerät noch lebt, sind das allerdings Multicasts die von den nanoleafs gesendet werden. Die scheinen deinen ioBroker/Adapter nicht zu erreichen. Im Log sind die jedenfalls nicht zu sehen. Da ich die Auswertung der Nachrichten (bezüglich Notification Type in der 1.0.2 gefixt habe, dürfte das nicht die Ursache sein).
                          Kannst du prüfen, ob dein Debian dort firewalltechnisch diese blockiert?
                          • sentinel
                            @daniel_2k
                            Hab den Fehler bei mir gefunden. IGMP war nicht eingerichtet. Jetzt funzen die alive Signale wieder. Hatte meinen UniFi APs auch ein Update verpasst. Zu viele Updates zugleich sind nicht gut für eine anschließend notwendige Fehlersuche 🙂
                              stefande @daniel_2k last edited by
                              @daniel_2k
                              Ich bin jetzt nicht wirklich der Debian Spezialist, aber so wie ich das sehe sollte die Firewall nix machen.
                              iobroker-deb:~# iptables -L
                              Chain INPUT (policy ACCEPT)
                              target     prot opt source               destination
                              Chain FORWARD (policy ACCEPT)
                              Chain OUTPUT (policy ACCEPT)
                                daniel_2k @stefande last edited by daniel_2k
                                @stefande sagte in Test Adapter nanoleaf-lightpanels v1.0.x GitHub/latest:
                                @daniel_2k
                                Da hast du recht. Da wird gar nix gefiltert. Alles geht rein.
                                OK. Die Geräte-Suche geht, sagst du. D.h. du findest dein nanoleaf-Gerät und kannst es in der Liste auswählen?
                                Installiere mal die Test-Version hier von GitHub:
                                https://github.com/daniel-2k/ioBroker.nanoleaf-lightpanels/tarball/test
                                und stelle das Log-Level mal auf Debug. Dann werden alle SSDP Messages, die empfangen werden, geloggt. So sehen wir erstmal, ob überhaupt was ankommt und wenn ja, was genau.
                                  @daniel_2k
                                  Bitte schön:
                                  2020-07-07 20:02:17.288 - debug: nanoleaf-lightpanels.0 (9522) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  2020-07-07 20:02:17.328 - debug: nanoleaf-lightpanels.0 (9522) Objects client ready ... initialize now
                                  2020-07-07 20:02:17.330 - debug: nanoleaf-lightpanels.0 (9522) Objects create System PubSub Client
                                  2020-07-07 20:02:17.331 - debug: nanoleaf-lightpanels.0 (9522) Objects create User PubSub Client
                                  2020-07-07 20:02:17.332 - debug: nanoleaf-lightpanels.0 (9522) Objects client initialize lua scripts
                                  2020-07-07 20:02:17.357 - debug: nanoleaf-lightpanels.0 (9522) Objects connected to redis: 127.0.0.1:9001
                                  2020-07-07 20:02:17.361 - debug: nanoleaf-lightpanels.0 (9522) objectDB connected
                                  2020-07-07 20:02:17.363 - debug: nanoleaf-lightpanels.0 (9522) Redis States: Use Redis connection: 127.0.0.1:9000
                                  2020-07-07 20:02:17.370 - debug: nanoleaf-lightpanels.0 (9522) States create User PubSub Client
                                  2020-07-07 20:02:17.372 - debug: nanoleaf-lightpanels.0 (9522) States create System PubSub Client
                                  2020-07-07 20:02:17.383 - debug: nanoleaf-lightpanels.0 (9522) States connected to redis: 127.0.0.1:9000
                                  2020-07-07 20:02:17.383 - debug: nanoleaf-lightpanels.0 (9522) statesDB connected
                                  2020-07-07 20:02:18.161 - info: nanoleaf-lightpanels.0 (9522) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.nanoleaf-lightpanels, node: v12.18.2, js-controller: 3.1.6
                                  2020-07-07 20:02:18.184 - info: nanoleaf-lightpanels.0 (9522) Nanoleaf adapter "nanoleaf-lightpanels.0" started.
                                  2020-07-07 20:02:18.185 - debug: nanoleaf-lightpanels.0 (9522) SSDP events initialized!
                                  2020-07-07 20:02:18.186 - info: nanoleaf-lightpanels.0 (9522) Connecting to "192.168.0.151:16021"...
                                  2020-07-07 20:02:18.199 - info: javascript.0 (1759) script.js.Adapter_Überwachung: Adapter_Überwachung OK
                                  2020-07-07 20:02:18.226 - debug: nanoleaf-lightpanels.0 (9522) Connect timer stopped!
                                  2020-07-07 20:02:18.228 - info: nanoleaf-lightpanels.0 (9522) Connected to "192.168.0.151:16021"
                                  2020-07-07 20:02:18.230 - debug: nanoleaf-lightpanels.0 (9522) nanoleaf Device "Canvas" (NL29) detected!
                                  2020-07-07 20:02:18.279 - debug: nanoleaf-lightpanels.0 (9522) SSE subscription started, listening...
                                  2020-07-07 20:02:25.933 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:02:25.934 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                  2020-07-07 20:02:25.934 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                  2020-07-07 20:02:30.648 - debug: nanoleaf-lightpanels.0 (9522) system.adapter.admin.0: logging true
                                  2020-07-07 20:02:35.930 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:02:35.930 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                  2020-07-07 20:02:35.931 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                  2020-07-07 20:02:45.932 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:02:45.933 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                  2020-07-07 20:02:45.933 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                  2020-07-07 20:02:49.383 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:02:49.389 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec","nts":"ssdp:alive","nt":"uuid:9ab0c000-f668-11de-9976-00a0de87beec"}
                                  2020-07-07 20:02:49.390 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:device:MediaRenderer:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:MediaRenderer:1"}
                                  2020-07-07 20:02:49.391 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:AVTransport:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:AVTransport:1"}
                                  2020-07-07 20:02:49.392 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:RenderingControl:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:RenderingControl:1"}
                                  2020-07-07 20:02:49.392 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:ConnectionManager:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:ConnectionManager:1"}
                                  2020-07-07 20:02:55.938 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:02:55.940 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                  2020-07-07 20:02:55.942 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                  2020-07-07 20:03:05.936 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:03:05.937 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                  2020-07-07 20:03:05.937 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                  2020-07-07 20:03:10.034 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/MediaServerDevDesc.xml","usn":"uuid:fa095ecc-e13e-40e7-8e6c-444e6d1f32e1::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:03:10.036 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/MediaServerDevDesc.xml","usn":"uuid:fa095ecc-e13e-40e7-8e6c-444e6d1f32e1","nts":"ssdp:alive","nt":"uuid:fa095ecc-e13e-40e7-8e6c-444e6d1f32e1"}
                                  2020-07-07 20:03:10.038 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/MediaServerDevDesc.xml","usn":"uuid:fa095ecc-e13e-40e7-8e6c-444e6d1f32e1::urn:schemas-upnp-org:device:MediaServer:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:MediaServer:1"}
                                  2020-07-07 20:03:10.046 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/MediaServerDevDesc.xml","usn":"uuid:fa095ecc-e13e-40e7-8e6c-444e6d1f32e1::urn:schemas-upnp-org:service:ContentDirectory:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:ContentDirectory:1"}
                                  2020-07-07 20:03:10.049 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/MediaServerDevDesc.xml","usn":"uuid:fa095ecc-e13e-40e7-8e6c-444e6d1f32e1::urn:schemas-upnp-org:service:ConnectionManager:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:ConnectionManager:1"}
                                  2020-07-07 20:03:10.053 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/MediaServerDevDesc.xml","usn":"uuid:fa095ecc-e13e-40e7-8e6c-444e6d1f32e1::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1","nts":"ssdp:alive","nt":"urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1"}
                                  2020-07-07 20:03:10.057 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/MediaServerDevDesc.xml","usn":"uuid:fa095ecc-e13e-40e7-8e6c-444e6d1f32e1::urn:avm.de:service:AVM_ServerStatus:1","nts":"ssdp:alive","nt":"urn:avm.de:service:AVM_ServerStatus:1"}
                                  2020-07-07 20:03:11.034 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/fboxdesc.xml","usn":"uuid:123402409-bccb-40e7-8e6c-444E6D1F32E1::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:03:11.036 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/fboxdesc.xml","usn":"uuid:123402409-bccb-40e7-8e6c-444E6D1F32E1","nts":"ssdp:alive","nt":"uuid:123402409-bccb-40e7-8e6c-444E6D1F32E1"}
                                  2020-07-07 20:03:11.040 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/fboxdesc.xml","usn":"uuid:123402409-bccb-40e7-8e6c-444E6D1F32E1::urn:schemas-upnp-org:device:fritzbox:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:fritzbox:1"}
                                  2020-07-07 20:03:11.050 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/fboxdesc.xml","usn":"uuid:123402409-bccb-40e7-8e6c-444E6D1F32E1::urn:schemas-any-com:service:fritzbox:1","nts":"ssdp:alive","nt":"urn:schemas-any-com:service:fritzbox:1"}
                                  2020-07-07 20:03:15.944 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:03:15.945 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                  2020-07-07 20:03:15.947 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                  2020-07-07 20:03:22.033 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/avmnexusdesc.xml","usn":"uuid:535502409-bccb-40e7-8e6c-444E6D1F32E1::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:03:22.034 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/avmnexusdesc.xml","usn":"uuid:535502409-bccb-40e7-8e6c-444E6D1F32E1","nts":"ssdp:alive","nt":"uuid:535502409-bccb-40e7-8e6c-444E6D1F32E1"}
                                  2020-07-07 20:03:22.035 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/avmnexusdesc.xml","usn":"uuid:535502409-bccb-40e7-8e6c-444E6D1F32E1::urn:schemas-upnp-org:device:avmnexus:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:avmnexus:1"}
                                  2020-07-07 20:03:22.042 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"FB7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.20","location":"http://192.168.0.6:49000/avmnexusdesc.xml","usn":"uuid:535502409-bccb-40e7-8e6c-444E6D1F32E1::urn:schemas-any-com:service:avmnexus:1","nts":"ssdp:alive","nt":"urn:schemas-any-com:service:avmnexus:1"}
                                  2020-07-07 20:03:25.944 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:03:25.945 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                  2020-07-07 20:03:25.945 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                  2020-07-07 20:03:26.499 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:554/description.xml","usn":"uuid:3E82E8CB-0B6A-4EB0-A5C1-A3E932A587CE::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                  2020-07-07 20:03:26.501 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:554/description.xml","usn":"uuid:3E82E8CB-0B6A-4EB0-A5C1-A3E932A587CE","nts":"ssdp:alive","nt":"uuid:3E82E8CB-0B6A-4EB0-A5C1-A3E932A587CE","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                  2020-07-07 20:03:26.502 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:554/description.xml","usn":"uuid:3E82E8CB-0B6A-4EB0-A5C1-A3E932A587CE::urn:ses-com:device:SatIPServer:1","nts":"ssdp:alive","nt":"urn:ses-com:device:SatIPServer:1","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                  2020-07-07 20:03:27.500 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                  2020-07-07 20:03:27.502 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD","nts":"ssdp:alive","nt":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                  2020-07-07 20:03:27.505 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD::urn:schemas-upnp-org:device:MediaServer:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:MediaServer:1","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                  2020-07-07 20:03:27.506 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD::urn:schemas-upnp-org:service:ContentDirectory:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:ContentDirectory:1","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                  2020-07-07 20:03:27.508 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD::urn:schemas-upnp-org:service:ConnectionManager:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:ConnectionManager:1","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                  2020-07-07 20:03:27.509 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1","nts":"ssdp:alive","nt":"urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                  2020-07-07 20:03:33.251 - warn: nanoleaf-lightpanels.0 (9522) Connection to '192.168.0.151:16021' lost, Error: No ssdp:alive detected. Try to reconnect...
                                  2020-07-07 20:03:33.252 - debug: nanoleaf-lightpanels.0 (9522) Polling timer stopped!
                                  2020-07-07 20:03:33.253 - debug: nanoleaf-lightpanels.0 (9522) Command queue cleared!
                                  2020-07-07 20:03:33.254 - debug: nanoleaf-lightpanels.0 (9522) SSE connection closed!
                                  2020-07-07 20:03:33.255 - debug: nanoleaf-lightpanels.0 (9522) Connect timer started with 60000 ms
                                  2020-07-07 20:03:35.950 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:03:35.952 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                  2020-07-07 20:03:35.953 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                  2020-07-07 20:03:45.737 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"Linux/1.0 UPnP/1.1 IDL4K/1.0","location":"http://192.168.0.196:8080/desc.xml","usn":"uuid:c5338bfa-ce70-456b-8703-20825a95d406::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice","bootid.upnp.org":"634","configid.upnp.org":"0"}
                                  2020-07-07 20:03:45.738 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"Linux/1.0 UPnP/1.1 IDL4K/1.0","location":"http://192.168.0.196:8080/desc.xml","usn":"uuid:c5338bfa-ce70-456b-8703-20825a95d406","nts":"ssdp:alive","nt":"uuid:c5338bfa-ce70-456b-8703-20825a95d406","bootid.upnp.org":"634","configid.upnp.org":"0"}
                                  2020-07-07 20:03:45.738 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"Linux/1.0 UPnP/1.1 IDL4K/1.0","location":"http://192.168.0.196:8080/desc.xml","usn":"uuid:c5338bfa-ce70-456b-8703-20825a95d406::urn:ses-com:device:SatIPServer:1","nts":"ssdp:alive","nt":"urn:ses-com:device:SatIPServer:1","bootid.upnp.org":"634","configid.upnp.org":"0"}
                                  2020-07-07 20:03:45.950 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:03:45.950 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                  2020-07-07 20:03:45.951 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                  2020-07-07 20:03:49.454 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:03:49.455 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec","nts":"ssdp:alive","nt":"uuid:9ab0c000-f668-11de-9976-00a0de87beec"}
                                  2020-07-07 20:03:49.456 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:device:MediaRenderer:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:MediaRenderer:1"}
                                  2020-07-07 20:03:49.457 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:AVTransport:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:AVTransport:1"}
                                  2020-07-07 20:03:49.457 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:RenderingControl:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:RenderingControl:1"}
                                  2020-07-07 20:03:49.458 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:ConnectionManager:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:ConnectionManager:1"}
                                  2020-07-07 20:03:55.956 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:03:55.957 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                  2020-07-07 20:03:55.958 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                  2020-07-07 20:04:01.405 - info: daswetter.0 (9895) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.18.2, js-controller: 3.1.6
                                  2020-07-07 20:04:05.956 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:04:05.957 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                  2020-07-07 20:04:05.958 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                  2020-07-07 20:04:10.733 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"Linux/1.0 UPnP/1.1 IDL4K/1.0","location":"http://192.168.0.196:8080/desc.xml","usn":"uuid:c5338bfa-ce70-456b-8703-20825a95d406::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice","bootid.upnp.org":"634","configid.upnp.org":"0"}
                                  2020-07-07 20:04:10.736 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"Linux/1.0 UPnP/1.1 IDL4K/1.0","location":"http://192.168.0.196:8080/desc.xml","usn":"uuid:c5338bfa-ce70-456b-8703-20825a95d406","nts":"ssdp:alive","nt":"uuid:c5338bfa-ce70-456b-8703-20825a95d406","bootid.upnp.org":"634","configid.upnp.org":"0"}
                                  2020-07-07 20:04:10.742 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"Linux/1.0 UPnP/1.1 IDL4K/1.0","location":"http://192.168.0.196:8080/desc.xml","usn":"uuid:c5338bfa-ce70-456b-8703-20825a95d406::urn:ses-com:device:SatIPServer:1","nts":"ssdp:alive","nt":"urn:ses-com:device:SatIPServer:1","bootid.upnp.org":"634","configid.upnp.org":"0"}
                                  2020-07-07 20:04:15.959 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:04:15.960 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                  2020-07-07 20:04:15.961 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                  2020-07-07 20:04:25.959 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:04:25.959 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                  2020-07-07 20:04:25.960 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                  2020-07-07 20:04:33.268 - debug: nanoleaf-lightpanels.0 (9522) Connect timer stopped!
                                  2020-07-07 20:04:33.269 - info: nanoleaf-lightpanels.0 (9522) Reconnected to "192.168.0.151:16021"
                                  2020-07-07 20:04:33.270 - debug: nanoleaf-lightpanels.0 (9522) nanoleaf Device "Canvas" (NL29) detected!
                                  2020-07-07 20:04:33.343 - debug: nanoleaf-lightpanels.0 (9522) SSE subscription started, listening...
                                  2020-07-07 20:04:35.967 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:04:35.968 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                  2020-07-07 20:04:35.969 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                  2020-07-07 20:04:45.969 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:04:45.971 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                  2020-07-07 20:04:45.972 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                  2020-07-07 20:04:49.524 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:04:49.525 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec","nts":"ssdp:alive","nt":"uuid:9ab0c000-f668-11de-9976-00a0de87beec"}
                                  2020-07-07 20:04:49.526 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:device:MediaRenderer:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:MediaRenderer:1"}
                                  2020-07-07 20:04:49.528 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:AVTransport:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:AVTransport:1"}
                                  2020-07-07 20:04:49.529 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:RenderingControl:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:RenderingControl:1"}
                                  2020-07-07 20:04:49.529 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:ConnectionManager:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:ConnectionManager:1"}
                                  2020-07-07 20:04:50.502 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:554/description.xml","usn":"uuid:3E82E8CB-0B6A-4EB0-A5C1-A3E932A587CE::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                  2020-07-07 20:04:50.505 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:554/description.xml","usn":"uuid:3E82E8CB-0B6A-4EB0-A5C1-A3E932A587CE","nts":"ssdp:alive","nt":"uuid:3E82E8CB-0B6A-4EB0-A5C1-A3E932A587CE","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                  2020-07-07 20:04:50.507 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:554/description.xml","usn":"uuid:3E82E8CB-0B6A-4EB0-A5C1-A3E932A587CE::urn:ses-com:device:SatIPServer:1","nts":"ssdp:alive","nt":"urn:ses-com:device:SatIPServer:1","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                  2020-07-07 20:04:51.502 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                  2020-07-07 20:04:51.505 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD","nts":"ssdp:alive","nt":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                  2020-07-07 20:04:51.506 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD::urn:schemas-upnp-org:device:MediaServer:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:MediaServer:1","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                  2020-07-07 20:04:51.508 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD::urn:schemas-upnp-org:service:ContentDirectory:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:ContentDirectory:1","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                  2020-07-07 20:04:51.508 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD::urn:schemas-upnp-org:service:ConnectionManager:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:ConnectionManager:1","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                  2020-07-07 20:04:51.508 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0","location":"http://192.168.0.199:8889/description.xml","usn":"uuid:7498450A-B782-481E-87A3-22E803FF1DAD::urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1","nts":"ssdp:alive","nt":"urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1","bootid.upnp.org":"760817","configid.upnp.org":"0"}
                                  2020-07-07 20:04:55.973 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:04:55.975 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                  2020-07-07 20:04:55.976 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                  2020-07-07 20:05:05.974 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:05:05.974 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                  2020-07-07 20:05:05.975 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                  2020-07-07 20:05:15.978 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:05:15.980 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                  2020-07-07 20:05:15.981 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                  2020-07-07 20:05:25.985 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:05:25.986 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                  2020-07-07 20:05:25.988 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                  2020-07-07 20:05:35.990 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:05:35.990 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                  2020-07-07 20:05:35.991 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                  2020-07-07 20:05:45.993 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:05:45.994 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                  2020-07-07 20:05:45.994 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                  2020-07-07 20:05:48.326 - warn: nanoleaf-lightpanels.0 (9522) Connection to '192.168.0.151:16021' lost, Error: No ssdp:alive detected. Try to reconnect...
                                  2020-07-07 20:05:48.327 - debug: nanoleaf-lightpanels.0 (9522) Polling timer stopped!
                                  2020-07-07 20:05:48.327 - debug: nanoleaf-lightpanels.0 (9522) Command queue cleared!
                                  2020-07-07 20:05:48.328 - debug: nanoleaf-lightpanels.0 (9522) SSE connection closed!
                                  2020-07-07 20:05:48.328 - debug: nanoleaf-lightpanels.0 (9522) Connect timer started with 60000 ms
                                  2020-07-07 20:05:49.597 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:05:49.599 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec","nts":"ssdp:alive","nt":"uuid:9ab0c000-f668-11de-9976-00a0de87beec"}
                                  2020-07-07 20:05:49.600 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:device:MediaRenderer:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:MediaRenderer:1"}
                                  2020-07-07 20:05:49.601 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:AVTransport:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:AVTransport:1"}
                                  2020-07-07 20:05:49.602 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:RenderingControl:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:RenderingControl:1"}
                                  2020-07-07 20:05:49.604 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"VDK/5.0 UPnP/1.0 AV_Receiver/3.1 (RX-V671)","location":"http://192.168.0.102:49154/MediaRenderer/desc.xml","usn":"uuid:9ab0c000-f668-11de-9976-00a0de87beec::urn:schemas-upnp-org:service:ConnectionManager:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:service:ConnectionManager:1"}
                                  2020-07-07 20:05:55.997 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::upnp:rootdevice","nts":"ssdp:alive","nt":"upnp:rootdevice"}
                                  2020-07-07 20:05:55.997 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384::urn:schemas-upnp-org:device:basic:1","nts":"ssdp:alive","nt":"urn:schemas-upnp-org:device:basic:1"}
                                  2020-07-07 20:05:55.998 - debug: nanoleaf-lightpanels.0 (9522) TEST: ssdp:alive NOTIFY received: {"host":"239.255.255.250:1900","server":"node.js/12.18.2 UPnP/1.1 node-ssdp/4.0.0","location":"http://192.168.0.20:80/description.xml","usn":"uuid:00112233-4455-6677-8899-6e25ad18989384","nts":"ssdp:alive","nt":"uuid:00112233-4455-6677-8899-6e25ad18989384"}
                                  2020-07-07 20:05:58.692 - info: host.iobroker-deb "system.adapter.nanoleaf-lightpanels.0" disabled
                                  2020-07-07 20:05:58.697 - info: host.iobroker-deb stopInstance system.adapter.nanoleaf-lightpanels.0 (force=false, process=true)
                                  2020-07-07 20:05:58.703 - info: nanoleaf-lightpanels.0 (9522) Got terminate signal TERMINATE_YOURSELF
                                  2020-07-07 20:05:58.698 - info: host.iobroker-deb stopInstance system.adapter.nanoleaf-lightpanels.0 send kill signal
                                    @stefande
                                    Also wie du siehst kommen SSDP Multicasts grundsätzlich mal im Adapter an. Deine anderen Netzwerkgeräte sieht man.
                                    Aber es sind keine von den nanoleafs dabei. Deine Canvas senden offenbar schlicht keine ssdp:alive Nachrichten.
                                    Welche Firmware hast du im Einsatz?
                                    Im Moment kann ich mir das auch nicht erklären, warum die nichts senden.
                                    Kannst du die Canvas mal neustarten (Strom weg und wieder einschalten)?
                                      @daniel_2k sagte in Test Adapter nanoleaf-lightpanels v1.0.x GitHub/latest:
                                      Ach ja... Die Suche geht und das Nanoleaf lässt sich auswählen. Ein Pfeil ist allerdings bei mir auch nicht zu sehen. Aber das ist wohl nebensächlich.
                                      In der Zeit wo der Adapter grün ist kann ich steuern, und bekomme auch Rückmeldungen.
                                      Verliert er die Connection wird der Adapter gelb.
                                        @stefande
                                        Das mit dem Pfeil ist Browserspezifisch. Starte mal deine Canvas neu und schaue mal, ob dann was kommt. Kann nur am Gerät liegen, da andere SSDP Notifications ja ankommen.
                                          @daniel_2k
                                          Die Firmware ist 1.6.2 also aktuell.
                                          Ich werde gleich mal zur Steckdose kriechen.😢
                                            @daniel_2k
                                            Heureka!
                                            Nach einem Neustart kommen die Notifications. 👍
                                            Ich geh dann mal wieder zurück auf die 1.0.2
                                            31.7k
                                            79.8k
                                            canvas light panels nanoleaf shapes
                                            15
                                            143
                                            13506
