(gelöst)VIS läuft nicht mehr
Danke Rainer, habs probiert, leider kein erfolg im gegenteil noch mehr Fehler.
Ich sende gleich eine neue Log, vom kompletten reboot.
Gruß Dirk
Hier der log ich hoffe ist nicht zu unübersichtlich:
hm-rpc.1 2016-06-24 15:48:15.068 info hm-rpc.1 Connected
hm-rpc.1 2016-06-24 15:48:15.019 info hm-rpc.1 binrpc -> listDevices 3
hm-rpc.1 2016-06-24 15:48:14.756 info hm-rpc.1 Disconnected
hm-rpc.0 2016-06-24 15:47:48.869 error hm-rpc.0 Socket error: Error: read ECONNRESET
hm-rpc.1 2016-06-24 15:47:14.742 info hm-rpc.1 Connected
hm-rpc.1 2016-06-24 15:47:14.690 info hm-rpc.1 binrpc -> listDevices 3
hm-rpc.1 2016-06-24 15:47:14.430 info hm-rpc.1 Disconnected
hm-rpc.1 2016-06-24 15:46:14.389 info hm-rpc.1 Connected
hm-rpc.1 2016-06-24 15:46:14.339 info hm-rpc.1 binrpc -> listDevices 3
hm-rpc.1 2016-06-24 15:46:14.054 info hm-rpc.1 Disconnected
hm-rpc-0 2016-06-24 15:45:31.104 error Socket error: Error: read ECONNRESET
hm-rpc-1 2016-06-24 15:45:14.018 info Connected
hm-rpc-1 2016-06-24 15:45:13.984 info binrpc -> listDevices 3
hm-rpc-1 2016-06-24 15:45:13.659 info Disconnected
admin-0 2016-06-24 15:45:02.569 info Repository received successfully.
host-RPi2 2016-06-24 15:45:02.190 warn warning: Timeout by read all package.json (87) seconds
host-RPi2 2016-06-24 15:44:34.643 info instance system.adapter.vis.0 terminated while should be started once
vis-0 2016-06-24 15:44:24.913 info starting. Version 0.10.5 in /opt/iobroker/node_modules/iobroker.vis
history-0 2016-06-24 15:44:17.091 info enabled logging of hm-rpc.0.MEQ0706275.1.POWER
history-0 2016-06-24 15:44:17.089 info enabled logging of hm-rpc.0.MEQ0706275.1.ENERGY_COUNTER
history-0 2016-06-24 15:44:17.087 info enabled logging of hm-rpc.0.MEQ0833081.1.TEMPERATURE
history-0 2016-06-24 15:44:17.085 info enabled logging of hm-rpc.0.MEQ0833081.1.HUMIDITY
history-0 2016-06-24 15:44:17.077 info enabled logging of hm-rpc.0.NEQ0124755.1.TEMPERATURE
history-0 2016-06-24 15:44:16.982 info starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.history
host-RPi2 2016-06-24 15:44:14.519 info instance system.adapter.history.0 started with pid 683
hm-rpc-1 2016-06-24 15:44:13.630 info Connected
hm-rpc-1 2016-06-24 15:44:13.559 info binrpc -> listDevices 3
hm-rpc-1 2016-06-24 15:44:13.402 info binrpc client is trying to connect to 192.168.178.21:8701 with ["xmlrpc_bin://0.0.0.0:8701","hm-rpc.1"]
hm-rpc-1 2016-06-24 15:44:13.396 info binrpc server is trying to listen on 0.0.0.0:8701
hm-rpc-1 2016-06-24 15:44:12.990 info starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
host-RPi2 2016-06-24 15:44:10.521 info instance system.adapter.hm-rpc.1 started with pid 674
host-RPi2 2016-06-24 15:44:08.374 info instance system.adapter.ical.0 terminated with code 0 (OK)
host-RPi2 2016-06-24 15:44:04.531 info instance system.adapter.dwd.0 terminated with code 0 (OK)
dwd-0 2016-06-24 15:44:03.027 info starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.dwd
ical-0 2016-06-24 15:44:00.676 info processing URL: Dirk Kuhl https://calendar.google.com/calendar/ical/dirkkuhl%40gmail.com/private-3057398946f84443c8f01a177bf408d2/basic.ics
fritzbox-0 2016-06-24 15:43:59.959 info adapter connected to fritzbox: 192.168.178.1
fritzbox-0 2016-06-24 15:43:59.833 info try to connect: 192.168.178.1
fritzbox-0 2016-06-24 15:43:59.743 info starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.fritzbox
host-RPi2 2016-06-24 15:43:58.533 info instance system.adapter.dwd.0 started with pid 661
host-RPi2 2016-06-24 15:43:58.510 info instance scheduled system.adapter.dwd.0 3 * * * *
ical-0 2016-06-24 15:43:57.988 info starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.ical
host-RPi2 2016-06-24 15:43:55.398 info instance system.adapter.fritzbox.0 started with pid 652
host-RPi2 2016-06-24 15:43:51.251 info instance system.adapter.ical.0 started with pid 647
host-RPi2 2016-06-24 15:43:51.225 info instance scheduled system.adapter.ical.0 1,5 * * *
hm-rega-0 2016-06-24 15:43:48.776 info got state values
hm-rega-0 2016-06-24 15:43:47.034 info request state values
hm-rega-0 2016-06-24 15:43:47.031 info deleted 0 variables
hm-rega-0 2016-06-24 15:43:47.029 info added/updated 15 variables
hm-rega-0 2016-06-24 15:43:46.891 info got 15 variables
hm-rega-0 2016-06-24 15:43:46.504 info deleted 0 programs
hm-rega-0 2016-06-24 15:43:46.503 info added/updated 13 programs
hm-rega-0 2016-06-24 15:43:46.387 info got 13 programs
hm-rega-0 2016-06-24 15:43:46.335 info renamed hm-rpc.1.CUX9100001 to "Mail"
hm-rega-0 2016-06-24 15:43:46.313 info renamed hm-rpc.1.CUX9100001.0 to "Mail:0"
hm-rega-0 2016-06-24 15:43:46.296 info renamed hm-rpc.1.CUX9100001.1 to "Mail:1"
hm-rega-0 2016-06-24 15:43:44.866 info added/updated rooms to enum.rooms
hm-rega-0 2016-06-24 15:43:44.737 info added/updated functions to enum.functions
hm-rega-0 2016-06-24 15:43:44.517 info added/updated 0 favorites to enum.favorites
hm-rega-0 2016-06-24 15:43:44.421 info time difference local-ccu 0s
hm-rega-0 2016-06-24 15:43:44.302 info ReGaHSS 192.168.178.21 up
hm-rega-0 2016-06-24 15:43:41.261 info subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
hm-rega-0 2016-06-24 15:43:41.212 info starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.hm-rega
hm-rpc-0 2016-06-24 15:43:43.919 info binrpc client is trying to connect to 192.168.178.21:2001 with ["xmlrpc_bin://0.0.0.0:2001","hm-rpc.0"]
hm-rpc-0 2016-06-24 15:43:43.913 info binrpc server is trying to listen on 0.0.0.0:2001
hm-rpc-0 2016-06-24 15:43:42.941 info starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
host-RPi2 2016-06-24 15:43:40.124 info instance system.adapter.hm-rpc.0 started with pid 634
hmm-0 2016-06-24 15:43:36.188 info Starting homematic-manager: /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js
hmm-0 2016-06-24 15:43:36.123 info starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.hmm
host-RPi2 2016-06-24 15:43:18.092 info instance system.adapter.hm-rega.0 started with pid 616
web-0 2016-06-24 15:43:16.852 info http server listening on port 8082
web-0 2016-06-24 15:43:16.838 info socket.io server listening on port 8082
host-RPi2 2016-06-24 15:43:16.477 info Update repository "default" under "conf/sources-dist.json"
admin-0 2016-06-24 15:43:15.943 info received all objects
web-0 2016-06-24 15:43:15.085 info starting. Version 1.4.7 in /opt/iobroker/node_modules/iobroker.web
admin-0 2016-06-24 15:43:14.968 info received all states
host-RPi2 2016-06-24 15:43:14.260 info instance system.adapter.hmm.0 started with pid 607
admin-0 2016-06-24 15:43:12.660 info Use link "http://localhost:8081" to configure.
admin-0 2016-06-24 15:43:12.658 info http server listening on port 8081
admin-0 2016-06-24 15:43:12.650 info Request actual repository...
admin-0 2016-06-24 15:43:12.645 info requesting all objects
admin-0 2016-06-24 15:43:12.637 info requesting all states
admin-0 2016-06-24 15:43:12.449 info starting. Version 1.2.3 in /opt/iobroker/node_modules/iobroker.admin
host-RPi2 2016-06-24 15:43:09.376 info instance system.adapter.web.0 started with pid 598
host-RPi2 2016-06-24 15:43:05.470 info instance system.adapter.admin.0 started with pid 502
host-RPi2 2016-06-24 15:43:05.343 info starting 16 instances
host-RPi2 2016-06-24 15:43:05.337 info 20 instances found
host-RPi2 2016-06-24 15:43:05.295 info InMemoryDB connected
inMem-objects 2016-06-24 15:43:05.267 info listening on port 9001
inMem-states 2016-06-24 15:43:04.866 info listening on port 9000
host-RPi2 2016-06-24 15:43:04.667 info ip addresses: fe80::a809:eb38:e347:bcd3
host-RPi2 2016-06-24 15:43:04.663 info hostname: RPi2
host-RPi2 2016-06-24 15:43:04.661 info Copyright (c) 2014-2016 bluefox, hobbyquaker
host-RPi2 2016-06-24 15:43:04.634 info iobroker.js-controller version 0.9.0 js-controller starting
host-RPi2 2016-06-24 15:42:56.633 info terminated
host-RPi2 2016-06-24 15:42:56.556 warn stopInstance system.adapter.text2command.0 not running
host-RPi2 2016-06-24 15:42:56.555 info stopInstance system.adapter.text2command.0
host-RPi2 2016-06-24 15:42:56.555 warn stopInstance system.adapter.telegram.0 not running
host-RPi2 2016-06-24 15:42:56.555 info stopInstance system.adapter.telegram.0
host-RPi2 2016-06-24 15:42:56.555 info stopInstance system.adapter.vis.0
host-RPi2 2016-06-24 15:42:56.554 info stopInstance system.adapter.vis-metro.0
host-RPi2 2016-06-24 15:42:56.554 warn stopInstance system.adapter.history.0 not running
host-RPi2 2016-06-24 15:42:56.554 info stopInstance system.adapter.history.0
host-RPi2 2016-06-24 15:42:56.553 warn stopInstance system.adapter.hm-rpc.1 not running
host-RPi2 2016-06-24 15:42:56.553 info stopInstance system.adapter.hm-rpc.1
host-RPi2 2016-06-24 15:42:56.552 warn stopInstance system.adapter.sayit.0 not running
host-RPi2 2016-06-24 15:42:56.552 info stopInstance system.adapter.sayit.0
host-RPi2 2016-06-24 15:42:56.551 info stopInstance system.adapter.vis-plumb.0
host-RPi2 2016-06-24 15:42:56.550 info stopInstance system.adapter.vis-fancyswitch.0
host-RPi2 2016-06-24 15:42:56.548 warn stopInstance system.adapter.dwd.0 not scheduled
host-RPi2 2016-06-24 15:42:56.529 info stopInstance system.adapter.dwd.0
host-RPi2 2016-06-24 15:42:56.523 warn stopInstance system.adapter.fritzbox.0 not running
host-RPi2 2016-06-24 15:42:56.523 info stopInstance system.adapter.fritzbox.0
host-RPi2 2016-06-24 15:42:56.522 warn stopInstance system.adapter.ical.0 not scheduled
host-RPi2 2016-06-24 15:42:56.520 info stopInstance system.adapter.ical.0
host-RPi2 2016-06-24 15:42:56.520 info stopInstance system.adapter.vis-timeandweather.0
host-RPi2 2016-06-24 15:42:56.519 info stopInstance system.adapter.vis-hqwidgets.0
host-RPi2 2016-06-24 15:42:56.519 warn stopInstance system.adapter.hm-rpc.0 not running
host-RPi2 2016-06-24 15:42:56.519 info stopInstance system.adapter.hm-rpc.0
host-RPi2 2016-06-24 15:42:56.518 warn stopInstance system.adapter.hm-rega.0 not running
host-RPi2 2016-06-24 15:42:56.518 info stopInstance system.adapter.hm-rega.0
host-RPi2 2016-06-24 15:42:56.518 warn stopInstance system.adapter.hmm.0 not running
host-RPi2 2016-06-24 15:42:56.517 info stopInstance system.adapter.hmm.0
host-RPi2 2016-06-24 15:42:56.517 warn stopInstance system.adapter.web.0 not running
host-RPi2 2016-06-24 15:42:56.517 info stopInstance system.adapter.web.0
host-RPi2 2016-06-24 15:42:56.516 warn stopInstance system.adapter.admin.0 not running
host-RPi2 2016-06-24 15:42:56.516 info stopInstance system.adapter.admin.0
host-RPi2 2016-06-24 15:42:56.514 info received SIGTERM
host-RPi2 2016-06-24 15:42:55.898 info terminated
host-RPi2 2016-06-24 15:42:55.677 info terminated
host-RPi2 2016-06-24 15:42:55.575 info instance system.adapter.hmm.0 terminated with code 0 (OK)
hmm-0 2016-06-24 15:42:55.557 info terminating
host-RPi2 2016-06-24 15:42:55.541 info stopInstance system.adapter.hmm.0 killing pid 607
host-RPi2 2016-06-24 15:42:55.540 warn stopInstance system.adapter.text2command.0 not running
host-RPi2 2016-06-24 15:42:55.539 info stopInstance system.adapter.text2command.0
host-RPi2 2016-06-24 15:42:55.538 warn stopInstance system.adapter.telegram.0 not running
host-RPi2 2016-06-24 15:42:55.537 info stopInstance system.adapter.telegram.0
host-RPi2 2016-06-24 15:42:55.537 info stopInstance system.adapter.vis.0
host-RPi2 2016-06-24 15:42:55.537 info stopInstance system.adapter.vis-metro.0
host-RPi2 2016-06-24 15:42:55.536 warn stopInstance system.adapter.history.0 not running
host-RPi2 2016-06-24 15:42:55.536 info stopInstance system.adapter.history.0
host-RPi2 2016-06-24 15:42:55.536 warn stopInstance system.adapter.hm-rpc.1 not running
host-RPi2 2016-06-24 15:42:55.535 info stopInstance system.adapter.hm-rpc.1
host-RPi2 2016-06-24 15:42:55.535 warn stopInstance system.adapter.sayit.0 not running
host-RPi2 2016-06-24 15:42:55.533 info stopInstance system.adapter.sayit.0
host-RPi2 2016-06-24 15:42:55.532 info stopInstance system.adapter.vis-plumb.0
host-RPi2 2016-06-24 15:42:55.532 info stopInstance system.adapter.vis-fancyswitch.0
host-RPi2 2016-06-24 15:42:55.531 warn stopInstance system.adapter.dwd.0 not scheduled
host-RPi2 2016-06-24 15:42:55.531 info stopInstance system.adapter.dwd.0
host-RPi2 2016-06-24 15:42:55.529 warn stopInstance system.adapter.fritzbox.0 not running
host-RPi2 2016-06-24 15:42:55.529 info stopInstance system.adapter.fritzbox.0
host-RPi2 2016-06-24 15:42:55.528 warn stopInstance system.adapter.ical.0 not scheduled
host-RPi2 2016-06-24 15:42:55.527 info stopInstance system.adapter.ical.0
host-RPi2 2016-06-24 15:42:55.527 info stopInstance system.adapter.vis-timeandweather.0
host-RPi2 2016-06-24 15:42:55.527 info stopInstance system.adapter.vis-hqwidgets.0
host-RPi2 2016-06-24 15:42:55.526 warn stopInstance system.adapter.hm-rpc.0 not running
host-RPi2 2016-06-24 15:42:55.525 info stopInstance system.adapter.hm-rpc.0
host-RPi2 2016-06-24 15:42:55.525 warn stopInstance system.adapter.hm-rega.0 not running
host-RPi2 2016-06-24 15:42:55.524 info stopInstance system.adapter.hm-rega.0
host-RPi2 2016-06-24 15:42:55.516 info stopInstance system.adapter.hmm.0
host-RPi2 2016-06-24 15:42:55.516 warn stopInstance system.adapter.web.0 not running
host-RPi2 2016-06-24 15:42:55.515 info stopInstance system.adapter.web.0
host-RPi2 2016-06-24 15:42:55.513 warn stopInstance system.adapter.admin.0 not running
host-RPi2 2016-06-24 15:42:55.512 info stopInstance system.adapter.admin.0
host-RPi2 2016-06-24 15:42:55.510 info received SIGTERM
host-RPi2 2016-06-24 15:42:55.105 info instance system.adapter.fritzbox.0 terminated with code 0 (OK)
fritzbox-0 2016-06-24 15:42:55.084 info terminating
host-RPi2 2016-06-24 15:42:54.783 info instance system.adapter.hm-rpc.1 terminated with code 0 (OK)
host-RPi2 2016-06-24 15:42:54.753 info instance system.adapter.web.0 terminated with code 0 (OK)
host-RPi2 2016-06-24 15:42:54.750 info instance system.adapter.history.0 terminated with code 0 (OK)
host-RPi2 2016-06-24 15:42:54.748 info instance system.adapter.hm-rega.0 terminated with code 0 (OK)
host-RPi2 2016-06-24 15:42:54.745 info instance system.adapter.admin.0 terminated with code 0 (OK)
host-RPi2 2016-06-24 15:42:54.561 warn stopInstance system.adapter.text2command.0 not running
host-RPi2 2016-06-24 15:42:54.560 info stopInstance system.adapter.text2command.0
host-RPi2 2016-06-24 15:42:54.559 warn stopInstance system.adapter.telegram.0 not running
host-RPi2 2016-06-24 15:42:54.558 info stopInstance system.adapter.telegram.0
host-RPi2 2016-06-24 15:42:54.554 info stopInstance system.adapter.vis.0
host-RPi2 2016-06-24 15:42:54.553 info stopInstance system.adapter.vis-metro.0
host-RPi2 2016-06-24 15:42:54.543 info stopInstance system.adapter.history.0 killing pid 693
host-RPi2 2016-06-24 15:42:54.542 info stopInstance system.adapter.history.0
host-RPi2 2016-06-24 15:42:54.541 info stopInstance system.adapter.hm-rpc.1 killing pid 684
host-RPi2 2016-06-24 15:42:54.540 info stopInstance system.adapter.hm-rpc.1
host-RPi2 2016-06-24 15:42:54.539 warn stopInstance system.adapter.sayit.0 not running
host-RPi2 2016-06-24 15:42:54.537 info stopInstance system.adapter.sayit.0
host-RPi2 2016-06-24 15:42:54.536 info stopInstance system.adapter.vis-plumb.0
host-RPi2 2016-06-24 15:42:54.536 info stopInstance system.adapter.vis-fancyswitch.0
host-RPi2 2016-06-24 15:42:54.535 info stopInstance canceled schedule system.adapter.dwd.0
host-RPi2 2016-06-24 15:42:54.533 info stopInstance system.adapter.dwd.0
host-RPi2 2016-06-24 15:42:54.532 info stopInstance system.adapter.fritzbox.0 killing pid 653
host-RPi2 2016-06-24 15:42:54.531 info stopInstance system.adapter.fritzbox.0
host-RPi2 2016-06-24 15:42:54.530 info stopInstance canceled schedule system.adapter.ical.0
host-RPi2 2016-06-24 15:42:54.526 info stopInstance system.adapter.ical.0
host-RPi2 2016-06-24 15:42:54.526 info stopInstance system.adapter.vis-timeandweather.0
host-RPi2 2016-06-24 15:42:54.525 info stopInstance system.adapter.vis-hqwidgets.0
host-RPi2 2016-06-24 15:42:54.524 info stopInstance system.adapter.hm-rpc.0 killing pid 621
host-RPi2 2016-06-24 15:42:54.523 info stopInstance system.adapter.hm-rpc.0
host-RPi2 2016-06-24 15:42:54.522 info stopInstance system.adapter.hm-rega.0 killing pid 616
host-RPi2 2016-06-24 15:42:54.518 info stopInstance system.adapter.hm-rega.0
host-RPi2 2016-06-24 15:42:54.514 info stopInstance system.adapter.hmm.0
host-RPi2 2016-06-24 15:42:54.513 info stopInstance system.adapter.web.0 killing pid 510
host-RPi2 2016-06-24 15:42:54.508 info stopInstance system.adapter.admin.0 killing pid 502
host-RPi2 2016-06-24 15:42:54.507 info stopInstance system.adapter.admin.0
host-RPi2 2016-06-24 15:42:54.503 info received SIGTERM
hm-rpc-1 2016-06-24 15:42:54.738 info terminating
web-0 2016-06-24 15:42:54.717 info terminating
web-0 2016-06-24 15:42:54.577 info terminated http server on port 8082
web-0 2016-06-24 15:42:54.520 info terminating http server on port 8082
hm-rpc-1 2016-06-24 15:42:54.623 info Disconnected
hm-rpc-0 2016-06-24 15:42:54.539 info binrpc -> 192.168.178.21:2001 init ["xmlrpc_bin://0.0.0.0:2001",""]
admin-0 2016-06-24 15:42:54.598 info terminating
hm-rpc-1 2016-06-24 15:42:54.570 info binrpc -> 192.168.178.21:8701 init ["xmlrpc_bin://0.0.0.0:8701",""]
admin-0 2016-06-24 15:42:54.515 info terminating http server on port 8081
hmm-0 2016-06-24 15:42:54.525 info kill hmm task
hm-rpc-1 2016-06-24 15:42:19.095 info Connected
hm-rpc-1 2016-06-24 15:42:19.037 info binrpc -> listDevices 3
hm-rpc-1 2016-06-24 15:42:18.774 info Disconnected
fritzbox-0 2016-06-24 15:42:09.697 info data from 192.168.178.1: 24.06.16 15:42:09;DISCONNECT;1;173;
hm-rpc-1 2016-06-24 15:41:18.762 info Connected
hm-rpc-1 2016-06-24 15:41:18.709 info binrpc -> listDevices 3
hm-rpc-1 2016-06-24 15:41:18.436 info Disconnected
hm-rpc-0 2016-06-24 15:41:04.387 error Socket error: Error: read ECONNRESET
host-RPi2 2016-06-24 15:40:43.731 info instance system.adapter.text2command.0 terminated with code 0 (OK)
host-RPi2 2016-06-24 15:40:43.184 info stopInstance system.adapter.text2command.0 killing pid 716
host-RPi2 2016-06-24 15:40:43.183 info stopInstance system.adapter.text2command.0
host-RPi2 2016-06-24 15:40:43.182 info object change system.adapter.text2command.0
host-RPi2 2016-06-24 15:40:42.196 info instance system.adapter.telegram.0 terminated with code 0 (OK)
host-RPi2 2016-06-24 15:40:41.628 info stopInstance system.adapter.telegram.0 killing pid 711
host-RPi2 2016-06-24 15:40:41.627 info stopInstance system.adapter.telegram.0
host-RPi2 2016-06-24 15:40:41.626 info object change system.adapter.telegram.0
host-RPi2 2016-06-24 15:40:39.860 info instance system.adapter.sayit.0 terminated with code 0 (OK)
host-RPi2 2016-06-24 15:40:39.307 info stopInstance system.adapter.sayit.0 killing pid 675
host-RPi2 2016-06-24 15:40:39.306 info stopInstance system.adapter.sayit.0
host-RPi2 2016-06-24 15:40:39.298 info object change system.adapter.sayit.0
hm-rpc-1 2016-06-24 15:40:18.420 info Connected
hm-rpc-1 2016-06-24 15:40:18.323 info binrpc -> listDevices 3
hm-rpc-1 2016-06-24 15:40:18.036 info Disconnected
hm-rpc-0 2016-06-24 15:39:30.075 error Socket error: Error: read ECONNRESET
hm-rpc-1 2016-06-24 15:39:18.011 info Connected
hm-rpc-1 2016-06-24 15:39:17.969 info binrpc -> listDevices 3
hm-rpc-1 2016-06-24 15:39:17.647 info Disconnected
fritzbox-0 2016-06-24 15:39:16.938 info data from 192.168.178.1: 24.06.16 15:39:16;CONNECT;1;10;035365441721;
fritzbox-0 2016-06-24 15:39:10.386 info data from 192.168.178.1: 24.06.16 15:39:10;CALL;1;10;23798;035365441721;SIP0;
telegram-0 2016-06-24 15:38:38.735 info getMe: {"id":220635275,"first_name":"HMBaseBot1","username":"ioKuhlBot"}
host-RPi2 2016-06-24 15:38:38.338 info instance system.adapter.vis.0 terminated while should be started once
telegram-0 2016-06-24 15:38:38.135 info starting. Version 0.2.4 in /opt/iobroker/node_modules/iobroker.telegram
telegram-0 2016-06-24 15:38:37.601 error no connection to objects DB
text2command-0 2016-06-24 15:38:37.172 info starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.text2command
vis-0 2016-06-24 15:38:28.334 info starting. Version 0.10.5 in /opt/iobroker/node_modules/iobroker.vis
host-RPi2 2016-06-24 15:38:33.860 info instance system.adapter.text2command.0 started with pid 716
host-RPi2 2016-06-24 15:38:29.859 info instance system.adapter.telegram.0 started with pid 711
admin-0 2016-06-24 15:38:25.786 info Repository received successfully.
history-0 2016-06-24 15:38:20.474 info enabled logging of hm-rpc.0.MEQ0706275.1.POWER
history-0 2016-06-24 15:38:20.472 info enabled logging of hm-rpc.0.MEQ0706275.1.ENERGY_COUNTER
history-0 2016-06-24 15:38:20.471 info enabled logging of hm-rpc.0.MEQ0833081.1.TEMPERATURE
history-0 2016-06-24 15:38:20.469 info enabled logging of hm-rpc.0.MEQ0833081.1.HUMIDITY
history-0 2016-06-24 15:38:20.464 info enabled logging of hm-rpc.0.NEQ0124755.1.TEMPERATURE
history-0 2016-06-24 15:38:20.374 info starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.history
host-RPi2 2016-06-24 15:38:17.856 info instance system.adapter.history.0 started with pid 693
hm-rpc-1 2016-06-24 15:38:17.619 info Connected
hm-rpc-1 2016-06-24 15:38:17.502 info binrpc -> listDevices 3
hm-rpc-1 2016-06-24 15:38:17.334 info binrpc client is trying to connect to 192.168.178.21:8701 with ["xmlrpc_bin://0.0.0.0:8701","hm-rpc.1"]
hm-rpc-1 2016-06-24 15:38:17.329 info binrpc server is trying to listen on 0.0.0.0:8701
hm-rpc-1 2016-06-24 15:38:16.919 info starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
host-RPi2 2016-06-24 15:38:13.861 info instance system.adapter.hm-rpc.1 started with pid 684
sayit-0 2016-06-24 15:38:12.494 info Upload announce mp3 files
sayit-0 2016-06-24 15:38:12.438 info starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.sayit
host-RPi2 2016-06-24 15:38:09.853 info instance system.adapter.sayit.0 started with pid 675
host-RPi2 2016-06-24 15:38:07.604 info instance system.adapter.ical.0 terminated with code 0 (OK)
host-RPi2 2016-06-24 15:38:04.013 info instance system.adapter.dwd.0 terminated with code 0 (OK)
dwd-0 2016-06-24 15:38:02.464 info starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.dwd
ical-0 2016-06-24 15:37:59.845 info processing URL: Dirk Kuhl https://calendar.google.com/calendar/ical/dirkkuhl%40gmail.com/private-3057398946f84443c8f01a177bf408d2/basic.ics
fritzbox-0 2016-06-24 15:37:59.584 info adapter connected to fritzbox: 192.168.178.1
fritzbox-0 2016-06-24 15:37:59.461 info try to connect: 192.168.178.1
fritzbox-0 2016-06-24 15:37:59.345 info starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.fritzbox
host-RPi2 2016-06-24 15:37:57.866 info instance system.adapter.dwd.0 started with pid 662
host-RPi2 2016-06-24 15:37:57.841 info instance scheduled system.adapter.dwd.0 3 * * * *
ical-0 2016-06-24 15:37:57.005 info starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.ical
host-RPi2 2016-06-24 15:37:54.905 info instance system.adapter.fritzbox.0 started with pid 653
host-RPi2 2016-06-24 15:37:50.073 info instance system.adapter.ical.0 started with pid 648
host-RPi2 2016-06-24 15:37:50.038 info instance scheduled system.adapter.ical.0 1,5 * * *
hm-rega-0 2016-06-24 15:37:48.060 info got state values
hm-rega-0 2016-06-24 15:37:46.301 info request state values
hm-rega-0 2016-06-24 15:37:46.298 info deleted 0 variables
hm-rega-0 2016-06-24 15:37:46.297 info added/updated 15 variables
hm-rega-0 2016-06-24 15:37:46.153 info got 15 variables
hm-rega-0 2016-06-24 15:37:45.793 info deleted 0 programs
hm-rega-0 2016-06-24 15:37:45.791 info added/updated 13 programs
hm-rega-0 2016-06-24 15:37:45.689 info got 13 programs
hm-rega-0 2016-06-24 15:37:45.626 info renamed hm-rpc.1.CUX9100001 to "Mail"
hm-rega-0 2016-06-24 15:37:45.615 info renamed hm-rpc.1.CUX9100001.0 to "Mail:0"
hm-rega-0 2016-06-24 15:37:45.596 info renamed hm-rpc.1.CUX9100001.1 to "Mail:1"
hm-rega-0 2016-06-24 15:37:44.376 info added/updated rooms to enum.rooms
hm-rega-0 2016-06-24 15:37:44.203 info added/updated functions to enum.functions
hm-rega-0 2016-06-24 15:37:44.007 info added/updated 0 favorites to enum.favorites
hm-rega-0 2016-06-24 15:37:43.910 info time difference local-ccu 1s
hm-rega-0 2016-06-24 15:37:43.795 info ReGaHSS 192.168.178.21 up
hm-rega-0 2016-06-24 15:37:40.308 info subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
hm-rega-0 2016-06-24 15:37:40.254 info starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.hm-rega
hm-rpc-0 2016-06-24 15:37:42.820 info binrpc client is trying to connect to 192.168.178.21:2001 with ["xmlrpc_bin://0.0.0.0:2001","hm-rpc.0"]
hm-rpc-0 2016-06-24 15:37:42.814 info binrpc server is trying to listen on 0.0.0.0:2001
hm-rpc-0 2016-06-24 15:37:41.795 info starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
hmm-0 2016-06-24 15:37:39.653 info Starting homematic-manager: /opt/iobroker/node_modules/iobroker.hmm/node_modules/homematic-manager/main.js
hmm-0 2016-06-24 15:37:39.590 info starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.hmm
host-RPi2 2016-06-24 15:37:38.602 info instance system.adapter.hm-rpc.0 started with pid 621
host-RPi2 2016-06-24 15:37:17.964 info instance system.adapter.hm-rega.0 started with pid 616
web-0 2016-06-24 15:37:16.787 info http server listening on port 8082
web-0 2016-06-24 15:37:16.772 info socket.io server listening on port 8082
host-RPi2 2016-06-24 15:37:16.350 info Update repository "default" under "conf/sources-dist.json"
admin-0 2016-06-24 15:37:15.821 info received all objects
web-0 2016-06-24 15:37:15.017 info starting. Version 1.4.7 in /opt/iobroker/node_modules/iobroker.web
admin-0 2016-06-24 15:37:14.907 info received all states
host-RPi2 2016-06-24 15:37:14.221 info instance system.adapter.hmm.0 started with pid 607
admin-0 2016-06-24 15:37:12.605 info Use link "http://localhost:8081" to configure.
admin-0 2016-06-24 15:37:12.604 info http server listening on port 8081
admin-0 2016-06-24 15:37:12.596 info Request actual repository...
admin-0 2016-06-24 15:37:12.591 info requesting all objects
admin-0 2016-06-24 15:37:12.583 info requesting all states
admin-0 2016-06-24 15:37:12.393 info starting. Version 1.2.3 in /opt/iobroker/node_modules/iobroker.admin
host-RPi2 2016-06-24 15:37:09.345 info instance system.adapter.web.0 started with pid 510
host-RPi2 2016-06-24 15:37:05.442 info instance system.adapter.admin.0 started with pid 502Dirk
Ich habe das log mal in spoiler versteckt
sieht gar nicht sooo wild aus. nur in den letzten (obersten) Zeilen
lediglich 2x error, 1x warn, aber die gleichen.
Timeout beim Versuch mit dem repository zu verbinden
hm-rpc.0 hat probleme mit der Verbindung (dort mal die Konfig überprüfen!)
hm-rpc-1 steigt dauernd aus.
Da bin ich jetzt auch überfragt.
Trotzdem:
stelle mal dein Repo auf "online"
geh mal bitte auf die Konsole und mach ein
cd /opt/iobroker iobroker update iobroker upgrade
Rainer
ich habe dasselbe Problem.
Bei einem Neustart werden die Daten aktualisiert, aber dann nicht weiter geschrieben.
Hallo Zusammen, ich hab mal das Thema geändert den meine Komplette Visualisierung ist frozen.
Ich häng mal noch ein Bild vom Systemadapter ran, eigentlich sollte dort die IP vom IO stehen.
Wenn ich diese händisch eintrage fällt sie wieder raus. Hat jemeand eine Idee?
Rainer deine Tipps hab ich alle durchgefüht, der Aha effeckt blieb leider aus.
Gruß Dirk
1162_image_13.png -
eigentlich sollte dort die IP vom IO stehen. `
korrekt!…und was steht in der Konfiguration der Instanz?
Rainer
Hier das Bild Rainer
1162_image_14.png -
Hier das Bild Rainer `
Und dich stört das Wort "invalid" gar nicht?Wähle bitte da die IP Adresse, die von CCU erreichbar ist.
und was steht da, wenn du auf den Pfeil neben 0.0.0.0 (invalid) klickst?
Rainer
Hallo Bluefox,
@Bluefox:Und dich stört das Wort "invalid" gar nicht? Wähle bitte da die IP Adresse, die von CCU erreichbar ist. `
natürlich stört mich das und das Thema hatten wir schon, ich kann dort die IP nicht auswählen
http://forum.iobroker.net/download/file … &mode=view
deswegen den Umweg über den System Adapter, aber geht diesmal auch nicht.
und was steht da, wenn du auf den Pfeil neben 0.0.0.0 (invalid) klickst? `
Das Bild kann ich erst morgen senden, steht aber keine IP drinn.
Gruß Dirk
Wenn die IP-Adresse nicht angeboten wird, dann schau mal http://forum.iobroker.net/viewtopic.php?f=20&t=3088#p28164.
Ja mach ich, danke für die Hilfe.
Dirk
…und stell mal im hm rpc von BIN-RPC auf XML-RPC um.
Rainer `
Hallo Rainer,warum sollte dies einen Unterschied machen?
Lief bisher bei mir auch ohne Fehler.
Und ich möchte es nicht auf Verdacht umstellen.
Es gab eine Version, da war ein Bug im bin.
Ist aber mit der neuesten Version anscheinend behoben.
Rainer
Guten Morgen, Hallo Rainer,
wenn du keinen Kommentar zu meinen Bildern abgibst gehe ich davon aus das die Einstellungen
richtig sind?
Kannst du mir einen Tipp geben wenn ich io neu aufsetze, welche Odner ich bedenkenlos rüberkopieren Kann?
Oder gibt es da generell Probleme?
Gruß Dirk
richtig sind `
Nein scheinen sie nicht zu sein.Bin nur seitdem nicht mehr an meine Installation gekommen um es mit meinen Einstellungen zu vergleichen.
Aber wenn du sie mit den Einstellungen vergleichst, die in dem von mir verlinkten Screenshot waren, dann fehlen bei dir die netzwerkdaten vollständig.
Da ich keine Ahnung habe wieso und keine Zeit und Möglichkeit hatte es bei mir zu vergleichen und ggf. zu provozieren habe ich erst mal nichts gesagt.
Rainer
Habe jetzt mal meine Einstellungen angesehen
Daten sind alle vorhanden.
Welche Admin und welche js-controller Version hast du?
Rainer
Soooo Rainer, einmal neues Update vom hm manager und eine neues Update vom rpc (jetzt ist alles egal) und es läuft wieder,
wer hätte das gedacht. Also jhg Update
Danke an Bluefox
Gruß Dirk
Jetzt Sooonnntag!
