    3. Entwicklung
    4. lgtv Adapter zur Steuerung von LG WebOS SmartTVs
      dirkhe Developer @toschi last edited by
      @toschi vor 5 Minuten hätte ich dir helfen können, aber leider ist mir gerade die glaskugel runter gefallen.
      Scherz beiseite, ohne debug Log kann dir keiner helfen
        Ich habe den Adapter auf Debug gestellt und dieses aus dem Log kopiert. Oder wie macht man das?
        host.IO-Broker 2020-07-08 22:07:15.181 info instance system.adapter.lgtv.0 started with pid 15621
        host.IO-Broker 2020-07-08 22:06:45.173 info Restart adapter system.adapter.lgtv.0 because enabled
        host.IO-Broker 2020-07-08 22:06:45.173 info instance system.adapter.lgtv.0 terminated with code 0 (NO_ERROR)
        lgtv.0 2020-07-08 22:06:44.671 debug (15576) Connection closed: 1000
        lgtv.0 2020-07-08 22:06:44.661 info (15576) Terminated (NO_ERROR): Without reason
        lgtv.0 2020-07-08 22:06:44.660 info (15576) terminating
        lgtv.0 2020-07-08 22:06:44.656 debug (15576) TV is off
        lgtv.0 2020-07-08 22:06:44.654 error at processTicksAndRejections (internal/process/task_queues.js:79:11)
        lgtv.0 2020-07-08 22:06:44.654 error at /opt/iobroker/node_modules/websocket/lib/WebSocketConnection.js:323:40
        lgtv.0 2020-07-08 22:06:44.654 error at WebSocketConnection.processFrame (/opt/iobroker/node_modules/websocket/lib/WebSocketConnection.js:554:26)
        lgtv.0 2020-07-08 22:06:44.654 error at WebSocketConnection.emit (events.js:315:20)
        lgtv.0 2020-07-08 22:06:44.654 error at WebSocketConnection.<anonymous> (/opt/iobroker/node_modules/lgtv2/index.js:146:48)
        lgtv.0 2020-07-08 22:06:44.654 error at Object.42c660520001 (/opt/iobroker/node_modules/iobroker.lgtv/lgtv.js:387:30)
        lgtv.0 2020-07-08 22:06:44.654 error (15576) TypeError: Cannot read property 'indexOf' of undefined
        lgtv.0 2020-07-08 22:06:44.654 error (15576) uncaught exception: Cannot read property 'indexOf' of undefined
        lgtv.0 2020-07-08 22:06:44.653 debug (15576) audio/getVolume: {"volumeStatus":{"activeStatus":true,"adjustVolume":true,"maxVolume":100,"muteStatus":false,"volume":12,"soundOutput":"tv_external_speaker"},"returnValue":true,"callerId":"se
        lgtv.0 2020-07-08 22:06:44.634 debug (15576) WebOS TV Connected
        lgtv.0 2020-07-08 22:06:44.582 debug (15576) Connecting to WebOS TV: ws://192.168.10.94:3000
        lgtv.0 2020-07-08 22:06:44.575 debug (15576) adapter.config = {"ip":"192.168.10.94","mac":"","timeout":"5000","reconnect":"5000","power":true,"healthIntervall":""}
        lgtv.0 2020-07-08 22:06:44.574 info (15576) Ready. Configured WebOS TV IP: 192.168.10.94
        lgtv.0 2020-07-08 22:06:44.564 info (15576) starting. Version 1.1.6 in /opt/iobroker/node_modules/iobroker.lgtv, node: v12.17.0, js-controller: 3.1.6
        lgtv.0 2020-07-08 22:06:41.633 debug (15576) statesDB connected
        lgtv.0 2020-07-08 22:06:41.633 debug (15576) States connected to redis: 127.0.0.1:9000
        lgtv.0 2020-07-08 22:06:41.628 debug (15576) States create System PubSub Client
        lgtv.0 2020-07-08 22:06:41.627 debug (15576) States create User PubSub Client
        lgtv.0 2020-07-08 22:06:41.624 debug (15576) Redis States: Use Redis connection: 127.0.0.1:9000
        lgtv.0 2020-07-08 22:06:41.623 debug (15576) objectDB connected
        lgtv.0 2020-07-08 22:06:41.621 debug (15576) Objects connected to redis: 127.0.0.1:9001
        lgtv.0 2020-07-08 22:06:41.612 debug (15576) Objects client initialize lua scripts
        lgtv.0 2020-07-08 22:06:41.611 debug (15576) Objects create User PubSub Client
        lgtv.0 2020-07-08 22:06:41.611 debug (15576) Objects create System PubSub Client
        lgtv.0 2020-07-08 22:06:41.610 debug (15576) Objects client ready ... initialize now
        lgtv.0 2020-07-08 22:06:41.591 debug (15576) Redis Objects: Use Redis connection: 127.0.0.1:9001
        host.IO-Broker 2020-07-08 22:06:41.314 info instance system.adapter.lgtv.0 started with pid 15576
        host.IO-Broker 2020-07-08 22:06:11.304 info Restart adapter system.adapter.lgtv.0 because enabled
          dirkhe Developer last edited by dirkhe
          Da ist definitiv ein Bug im Code. Ich meine, dass ich den schon mal gesehen habe und gedacht, dass ich den gefixt habe, vlt habe ich das aber auch nur lokal gemacht
          Schau mal hier https://forum.iobroker.net/post/449292
          @SchuetzeSchulz den fix könntest du eigentlich direkt übernehmen?
            SchuetzeSchulz @toschi last edited by
            @toschi
            Bitte mal den Adapter deinstallieren und neu vom Github installieren.
            Der Fehler sollte jetzt - hoffentlich - dank @dirkhe weg sein 🙂
              Die Installation von GitHub bricht mit Fehler ab:
              Fertig mit Fehler: internal/modules/cjs/loader.js:1175 throw err; ^SyntaxError: /opt/iobroker/node_modules/iobroker.lgtv/io-package.json: Unexpected token } in JSON at position 520 at parse () at Object.Module._extensions..json (internal/modules/cjs/loader.js:1172:22) at Module.load (internal/modules/cjs/loader.js:986:32) at Function.Module._load (internal/modules/cjs/loader.js:879:14) at Module.require (internal/modules/cjs/loader.js:1026:19) at require (internal/modules/cjs/helpers.js:72:18) at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:481:19) at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:1781:24 at ChildProcess. (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:478:47) at ChildProcess.emit (events.js:315:20)
                @toschi
                Da hat sich leider noch ein Fehler eingeschlichen gehabt.
                Bitte nochmal probieren.
                  sigi234 Forum Testing Most Active @SchuetzeSchulz last edited by sigi234
                  @SchuetzeSchulz sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                  @toschi
                  $ ./iobroker upgrade lgtv
                  Update lgtv from @1.1.6 to @1.1.7
                  NPM version: 6.14.4
                  npm install iobroker.lgtv@1.1.7 --loglevel error (System call)
                  gyp
                   ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: tar.extract is not a functiongyp ERR! stack     at Request.<anonymous> (C:\Program Files\iobroker\Test\nodejs\node_modules\npm\node_modules\node-gyp\lib\install.js:199:22)gyp ERR! stack     at Request.emit (events.js:327:22)gyp ERR! stack     at Request.onRequestResponse (C:\Program Files\iobroker\Test\nodejs\node_modules\npm\node_modules\request\request.js:1066:10)gyp ERR! stack     at ClientRequest.emit (events.js:315:20)gyp ERR! stack     at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:596:27)gyp ERR! stack     at HTTPParser.parserOnHeadersComplete (_http_common.js:119:17)gyp ERR! stack     at TLSSocket.socketOnData (_http_client.js:469:22)gyp ERR! stack     at TLSSocket.emit (events.js:315:20)gyp ERR! stack     at addChunk (_stream_readable.js:295:12)gyp ERR! stack     at readableAddChunk (_stream_readable.js:271:9)gyp ERR! System Windows_NT 10.0.19041gyp ERR! command "C:\\Program Files\\iobroker\\Test\\nodejs\\node.exe" "C:\\Program Files\\iobroker\\Test\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd C:\Program Files\iobroker\Test\node_modules\unix-dgramgyp ERR! node -v v12.18.0gyp ERR! node-gyp -v v5.1.0gyp ERR! This is a bug in `node-gyp`.gyp ERR! Try to update node-gyp and file an Issue if it does not help:gyp ERR!     <https://github.com/nodejs/node-gyp/issues>
                  ERROR: Cannot find io-package.json in C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv
                  ERROR: Cannot parse C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv/io-package.json:SyntaxError: Unexpected token } in JSON at position 520Cannot find io-package.json in C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv
                  Adapter "lgtv" updated
                  upload [3] lgtv.admin C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv/admin/words.js words.js application/javascript
                   writeFile will not write this file (words.js) in future versions: undefined
                   DB closed
                  upload [2] lgtv.admin C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv/admin/lgtv.png lgtv.png image/png
                   writeFile will not write this file (lgtv.png) in future versions: undefined
                  upload [1] lgtv.admin C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv/admin/index_m.html index_m.html text/html
                   writeFile will not write this file (index_m.html) in future versions: undefined
                  upload [0] lgtv.admin C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv/admin/index.html index.html text/html
                   writeFile will not write this file (index.html) in future versions: undefined
                  ERROR: process exited with code 29
                  os: win32
                  RAM: 7.9 GB
                  Node.js: v12.18.0
                  NPM: 6.14.4
                  JS-Controller: 3.1.6
                  Admin: 4.1.1
                  Active instances: 46
                  • kmxak
                    Von Github direkt installieren funktioniert. Über Update Button geht es nicht.
                      sigi234 Forum Testing Most Active @kmxak last edited by
                      @kmxak sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                      Kann ich bestätigen.
                        ich habe den adapter Version 1.1.7 gerade neu in iobroker normal installiert. Hat funktioniert kann aber erst nachmittags testen da TV aus ist.
                          Hab jetzt mal auf Hithub und NPM die Version 1.1.8 veröffentlicht.
                          Kann allerdings dauern, bis sie im Stable repository ist.
                            Die Version 1.1.7 hat sich verbunden. Laut,leise,Kanal+ und - funktioniert. Den Rest kann ich erst später probieren. Die 1.1.8 kann ich abends testen.
                              Die 1.1.8 läuft bei mir auch. Keine Probleme gefunden. Vielen Dank für die schnelle Hilfe.
                                @SchuetzeSchulz
                                Die 1.1.8 läuft bei mir auch. Keine Probleme gefunden. 👍
                                  SchuetzeSchulz @sigi234 last edited by
                                  Der Dank gilt @dirkhe . Er hat den "Fehler" ja gefunden 🙂
                                    Dank an @dirkhe 😀
                                      liv-in-sky @SchuetzeSchulz last edited by liv-in-sky
                                      @SchuetzeSchulz
                                      hi
                                      bei der installation probleme - im info wird update auf 1.1.8 angezeigt - wenn fertig ist es aber immer noch 1.1.7
                                      wenn ich über "katze" installiere kommt code 25
                                        erde-online @liv-in-sky last edited by
                                        ich habe das gleiche Problem.Nach Installation von 1.1.8 habe ich immer noch 1.1.7 und mir wird die Installation auf 1.1.8 vorgeschlagen.
                                          SchuetzeSchulz @erde-online last edited by
                                          Bitte bei Problemen den Adapter mal komplett deinstallieren und dann neu installieren.
                                            @SchuetzeSchulz adapter gelöscht - neu installiert - selbes problem
                                            lgtv
                                            113
                                            861
                                            312392
