    4. JavaScript
    5. E3DC Hauskraftwerk steuern
    • smartboart
      smartboart @ArnoD last edited by smartboart
      @ArnoD kurze Fragen...
      1.
      nSpeicherMax_kWh ist das der verbaute Speicher, oder was die Anlage maximal kann?
      Wahrscheinlich der verbaute, das andere würde kein Sinn machen.. Aber ich frage sicherheitshalber nochmal..
      2.
      Was muss ich tun, wenn ich die States nicht unter Userdata anlegen möchte sonden wie gwohnt unter der javascript instance.
      scriptteil ( where ) für das anlegen unter userdata entfernen
      function createUserStates(where, force, statesToCreate, callback = undefined) {
          const WARN = false; // Only for 0_userdata.0: Throws warning in log, if state is already existing and force=false. Default is false, so no warning in log, if state exists.
          const LOG_DEBUG = false; // To debug this function, set to true
          // Per issue #474 (https://github.com/ioBroker/ioBroker.javascript/issues/474), the used function setObject() executes the callback
          // before the state is actual created. Therefore, we use a setTimeout and counter as a workaround.
          const DELAY = 50; // Delay in milliseconds (ms). Increase this to 100, if it is not working.
          // Validate "where"
          if (where.endsWith('.')) where = where.slice(0, -1); // Remove trailing dot
          if ( (where.match(/^((javascript\.([1-9][0-9]|[0-9]))$|0_userdata\.0$)/) == null) ) {
              log('This script does not support to create states under [' + where + ']', 'error');
              return;
          // Prepare "statesToCreate" since we also allow a single state to create
          if(!Array.isArray(statesToCreate[0])) statesToCreate = [statesToCreate]; // wrap into array, if just one array and not inside an array
          // Add "where" to STATES_TO_CREATE
          for (let i = 0; i < statesToCreate.length; i++) {
              let lpPath = statesToCreate[i][0].replace(/\.*\./g, '.'); // replace all multiple dots like '..', '...' with a single '.'
              lpPath = lpPath.replace(/^((javascript\.([1-9][0-9]|[0-9])\.)|0_userdata\.0\.)/,'') // remove any javascript.x. / 0_userdata.0. from beginning
              lpPath = where + '.' + lpPath; // add where to beginning of string
              statesToCreate[i][0] = lpPath;
          if (where != '0_userdata.0') {
              // Create States under javascript.x
              let numStates = statesToCreate.length;
              statesToCreate.forEach(function(loopParam) {
                  if (LOG_DEBUG) log('[Debug] Now we are creating new state [' + loopParam[0] + ']');
                  let loopInit = (loopParam[1]['def'] == undefined) ? null : loopParam[1]['def']; // mimic same behavior as createState if no init value is provided
                  createState(loopParam[0], loopInit, force, loopParam[1], function() {
                      numStates--;
                      if (numStates === 0) {
                          if (LOG_DEBUG) log('[Debug] All states processed.');
                          if (typeof callback === 'function') { // execute if a function was provided to parameter callback
                              if (LOG_DEBUG) log('[Debug] Function to callback parameter was provided');
                              return callback();
                          } else {
                              return;
          } else {
              // Create States under 0_userdata.0
              let counter = -1;
                  counter += 1;
                  if (LOG_DEBUG) log ('[Debug] Currently processing following state: [' + loopParam[0] + ']');
                  if( ($(loopParam[0]).length > 0) && (existsState(loopParam[0])) ) { // Workaround due to https://github.com/ioBroker/ioBroker.javascript/issues/478
                      // State is existing.
                      if (WARN && !force) log('State [' + loopParam[0] + '] is already existing and will no longer be created.', 'warn');
                      if (!WARN && LOG_DEBUG) log('[Debug] State [' + loopParam[0] + '] is already existing. Option force (=overwrite) is set to [' + force + '].');
                      if(!force) {
                          // State exists and shall not be overwritten since force=false
                          // So, we do not proceed.
                          numStates--;
                              if (LOG_DEBUG) log('[Debug] All states successfully processed!');
                                  if (LOG_DEBUG) log('[Debug] An optional callback function was provided, which we are going to execute now.');
                                  return callback();
                          } else {
                              // We need to go out and continue with next element in loop.
                              return; // https://stackoverflow.com/questions/18452920/continue-in-cursor-foreach
                      } // if(!force)
                  // State is not existing or force = true, so we are continuing to create the state through setObject().
                  let obj = {};
                  obj.type = 'state';
                  obj.native = {};
                  obj.common = loopParam[1];
                  setObject(loopParam[0], obj, function (err) {
                      if (err) {
                          log('Cannot write object for state [' + loopParam[0] + ']: ' + err);
                      } else {
                          let init = null;
                          if(loopParam[1].def === undefined) {
                              if(loopParam[1].type === 'number') init = 0;
                              if(loopParam[1].type === 'boolean') init = false;
                              if(loopParam[1].type === 'string') init = '';
                          } else {
                              init = loopParam[1].def;
                          setTimeout(function() {
                              setState(loopParam[0], init, true, function() {
                                  if (LOG_DEBUG) log('[Debug] setState durchgeführt: ' + loopParam[0]);
                                  numStates--;
                                          return callback();
                          }, DELAY + (20 * counter) );
      und dann wie folgt...
      // ********************* Einstellungen Instanz Script E3DC-Control ***********************
      let instanz = 'javascript.1.PVAnlage';
      und das ausklammern...
      //createUserStates('0_userdata.0', false, statesToCreate, function(){log('Jetzt sind alle States abgearbeitet');});
      Mic-M created this issue in ioBroker/ioBroker.javascript
      closed setObject() function: callback not working as intended. #474
      closed 0_userdata.0: existsState() vs. $-Selector $().length after state deletion #478
        stevie77 @Abyss last edited by
        @Abyss sagte in E3DC Hauskraftwerk steuern:
        Hatte gleich am Anfang versucht mit dem "Daten lesen" die bestehende Config einzulesen, was allerdings nicht funktioniert hat.
        Das scheint das intuitive Vorgehen zu sein, so hatte ich es auch erfolglos probiert. Man muss sogar sehr aufpassen, dass man beim Umstieg eine vorhandene Datei nicht erst in die States einliest. Da stand bei mir dann jede Menge Mist drin, weil die Parameter nicht dem Namen sondern scheinbar der Reihenfolge nach zugewiesen werden. Ich musste da erstmal aufräumen. Aber jetzt funktioniert's . Heute erster Tag mit ner Konfigdatei von Arno generiert. 🙂
        Und mit dem Schalter "Automatik" aktiviert man dann vermutlich die Prognose von Proplanta? sprich dann werden die config Werte dynamisch angepasst?
        Ich habe die View E3DC-Control importiert, aber ich finde gar keinen Schalter "Automatik". Auch bei den anderen Views habe ich in den Screenshots nichts gefunden. Wo ist dieser Button?
          ArnoD @smartboart last edited by ArnoD
          @smartboart sagte in E3DC Hauskraftwerk steuern:
          1.
          2.
          1. nSpeicherMax_kWh ist die Größe des verbauten Speicher. Wird für die Prognoseberechnung verwendet.
          2, am Ende der User Anpassungen kannst du einstellen welche Instanz verwendet werden soll:
          let instanz = "javascript.1."
          let PfadEbene1 = "PVAnlage."
          den Punkt am Ende nicht vergessen.
          smartboart 3 Replies Last reply Reply Quote 0
          • smartboart
            @ArnoD ja, das habe ich als erstes ausprobiert.....die states werden aber immer unter userdata abgelegt...
            • smartboart
              @ArnoD werden immer unter userdata abgelegt...egal was ich mache
              • smartboart
                @ArnoD wenn ich nur das so ändere
                let instanz = 'javascript.1.';
                wird trotzdem unter userdata abgelegt..
                das muss auch geändert weden...jetzt klappts...
                createUserStates('javascript.1', false, statesToCreate, function(){log('Jetzt sind alle States abgearbeitet');});
                sorry stand auf dem schlauch, war zu spät gestern...
                  ArnoD @stevie77 last edited by ArnoD
                  @stevie77 sagte in E3DC Hauskraftwerk steuern:
                  Ja, das ist richtig.
                  Es müssen zuerst die Werte im Script richtig eingetragen werden und dann erst die Datei e3dc-config.txt erstellt werden.
                  Es ist aktuell nicht möglich die vorhanden e3dc.config.txt (also nicht vom Script erstellte Datei) einzulesen.
                  Werde das aber bei Gelegenheit ändern, da es so nicht sauber Programmiert ist.
                  Wenn du die letzte Version der View hast sollte der Schalter enthalten sein.
                  Sonst den State "Automatik" unter "Allgemein" aus Vis auf true oder false setzen.
                    🤔 nuss jetzt noch was geändert werden ? 🙂
                    smartboart 1 Reply Last reply Reply Quote 0
                    • smartboart
                      @ArnoD nein nur die beiden sachen...
                        Welche beiden Sachen ??
                          ArnoD last edited by ArnoD
                          ok , habe es jetzt auch gesehen.
                          Die Zeile wäre so richtig:
                          createUserStates(instanz, false, statesToCreate, function(){log('Jetzt sind alle States abgearbeitet');});
                          Habe da mal was Versucht und vergessen wieder die richtige Variable einzutragen.
                          Fehler ist in Version 0.1.13 dann behoben.
                          smartboart 2 Replies Last reply Reply Quote 0
                          • smartboart
                            @ArnoD sagte in E3DC Hauskraftwerk steuern:
                            Ja ...danke..
                            ne Frage zur Config...
                            all das durchführen?
                            Die Config liegt dann aber untern nem anderen Ordner..
                            // Installieren git
                            sudo apt install git
                            git clone https://github.com/Eba-M/E3DC-Control.git
                            // updates runterladen (nur erforderlich, wenn ein neues Updat installiert werden soll
                            cd E3DC-Control // Nach E3DC wechseln und mit pull runterladen
                            git pull https://github.com/Eba-M/E3DC-Control.git`
                            // nach clone oder pull mit make kompilieren
                            cd E3DC-Control
                            make
                            // mit nano die Datei
                            nano e3dc.config.txt.template
                            // editieren und die Parameter
                            server_ip = xxx.xxx.xxx.xxx server_port = 5033 e3dc_user = xxxxxxxxxx e3dc_password = xxxxxxxx
                            // und die möglichen Parameter
                            wallbox = false
                            // true, wenn man die E3DC-Wallbox mit erweiterter Funktion nutzen möchte ext1 = false // true, wenn ein externer Zähler genutzt wird ext2 = false wurzelzaehler = 0 // 6 = externer Wurzelzähler einspeiselimit = 7.0 // 70% Einspeisegrenze bei z.B. 10kWp untererLadekorridor = 500
                            obererLadekorridor = 1500
                            // bei der PRO wird 4500 empfohlen minimumLadeleistung = 300 maximumLadeleistung = 3000
                            // 1500 bei mini, 3000 E12 und 9000/1200 PRO wrleistung = 12000
                            // AC-Leistung des WR, 4600 bei mini ladeschwelle = 15
                            // Unter 15% SoC wird immer geladen ladeende = 85
                            // Ziel SoC 85% zwischen winterminimum = 11
                            // winterminimum wintersonnenwende sommermaximum = 14
                            // sommermaximum sommersonnenwende sommerladeende = 18.5
                            // im Sommer wird das Laden auf 100% verzögert // Im Winterhalbjahr wird versucht den Speicher zum Hochtarif zu nutzen htmin = 30
                            // Speicherreserve 30% bei winterminimum htsockel = 10
                            // sockelwert bei Tag-Nachtgleiche hton = 5
                            // Begin Hochtarif htoff = 14
                            // Ende Hochtarif htsat = true
                            // Hochtarif Samstag htsun = true
                            // Hochtourig Sonntag debug = false logfile = logfile // zusätzliche debug informationenin eine logfile ausgeben // Alle Steuerungsanweisungen an E3DC
                            // anpassen und als //e3dc.config.txt // abspeichern.
                            // Installieren von Screen
                            sudo apt-get install screen
                            // Skriptdatei erstellen
                            nano E3DC.sh
                            // folgende kopieren
                            #!/bin/bash cd /home/pi/E3DC-Control while true; do ./E3DC-Control sleep 30 done
                            // Skriptdatei ausführbar machen
                            chmod +x E3DC.sh
                            // Ausführen
                            ./E3DC.sh
                            // Eintrag in die autostart datei /etc/rc.local
                            sudo nano /etc/rc.local
                            wird folgende Zeile vor dem „exit 0“ eingetragen
                            su pi -c "screen -dmS E3DC /home/pi/E3DC-Control/E3DC.sh"
                            exit 0
                            Richtig herunterfahren
                            sudo shutdown -h 0
                              @smartboart
                              Den Ordner musst du anpassen.
                              Der User "iobroker" muss auf den Ordner Schreib und Lese rechte haben.
                                Ich habe es unter dem Pfad: /home/iobroker/E3DC-Control/
                                installiert.
                                • smartboart
                                  hat sich erledigt
                                  • smartboart
                                    @ArnoD hab noch nen Fehler im Log...
                                    nachdem ich den State angelegt hatte wars gut..
                                    sagt dir das was?
                                    javascript.1	2020-07-12 17:53:42.366	warn	(1767) at processImmediate (internal/timers.js:456:21)
                                    javascript.1	2020-07-12 17:53:42.366	warn	(1767) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                                    javascript.1	2020-07-12 17:53:42.366	warn	(1767) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                                    javascript.1	2020-07-12 17:53:42.366	warn	(1767) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                                    javascript.1	2020-07-12 17:53:42.365	warn	(1767) at Object.<anonymous> (script.js.common.PVAnlage.E3DCS10EPro:1987:5)
                                    javascript.1	2020-07-12 17:53:42.365	warn	(1767) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20)
                                    javascript.1	2020-07-12 17:53:42.364	warn	(1767) You are assigning a object to the state "javascript.1.PVAnlage.E3DC-Control.History.HistoryJSON" which expects a string. Please fix your code to use a string or change the state type to object
                                    javascript.1	2020-07-12 17:53:42.360	warn	(1767) at processImmediate (internal/timers.js:456:21)
                                    javascript.1	2020-07-12 17:53:42.360	warn	(1767) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                                    javascript.1	2020-07-12 17:53:42.360	warn	(1767) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                                    javascript.1	2020-07-12 17:53:42.359	warn	(1767) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                                    javascript.1	2020-07-12 17:53:42.359	warn	(1767) at Object.<anonymous> (script.js.common.PVAnlage.E3DCS10EPro:1985:22)
                                    javascript.1	2020-07-12 17:53:42.353	warn	(1767) getState "javascript.1.PVAnlage.E3DC-Control.History.HistoryJSON_00" not found (3)
                                    S A 2 Replies Last reply Reply Quote 0
                                    • smartboart
                                      installiert.
                                      kurze Frage noch dazu...Hast du nur die config Datei oder alles dort installiert?
                                      ich habe alles da rein installiert und musste dennoch mit
                                      sudo chmod 666 e3dc.config.txt Schreibrechte vergeben, damit das Script die Datei beschreiben konnte...
                                      sieht so aus bei mir...
                                        stevie77 @smartboart last edited by
                                        @smartboart Den habe ich auch...
                                        • smartboart
                                          smartboart @stevie77 last edited by
                                          Was? den Fehler im log?
                                            @smartboart Äh, ja, sorry, in diesem komischen Forum gehen die Zusammenhänge ja immer flöten weil es schlecht lesbar ist. Ja, ich meinte den Fehler im Log, den habe ich auch...
                                            3439
                                            1579543
