E3DC Hauskraftwerk steuern
@smartboart
Den Ordner musst du anpassen.
Der User "iobroker" muss auf den Ordner Schreib und Lese rechte haben. -
Ich habe es unter dem Pfad: /home/iobroker/E3DC-Control/
installiert. -
hat sich erledigt
@ArnoD hab noch nen Fehler im Log...
nachdem ich den State angelegt hatte wars gut..sagt dir das was?
javascript.1 2020-07-12 17:53:42.366 warn (1767) at processImmediate (internal/timers.js:456:21) javascript.1 2020-07-12 17:53:42.366 warn (1767) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37) javascript.1 2020-07-12 17:53:42.366 warn (1767) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25) javascript.1 2020-07-12 17:53:42.366 warn (1767) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38) javascript.1 2020-07-12 17:53:42.365 warn (1767) at Object.<anonymous> (script.js.common.PVAnlage.E3DCS10EPro:1987:5) javascript.1 2020-07-12 17:53:42.365 warn (1767) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1355:20) javascript.1 2020-07-12 17:53:42.364 warn (1767) You are assigning a object to the state "javascript.1.PVAnlage.E3DC-Control.History.HistoryJSON" which expects a string. Please fix your code to use a string or change the state type to object javascript.1 2020-07-12 17:53:42.360 warn (1767) at processImmediate (internal/timers.js:456:21) javascript.1 2020-07-12 17:53:42.360 warn (1767) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37) javascript.1 2020-07-12 17:53:42.360 warn (1767) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25) javascript.1 2020-07-12 17:53:42.359 warn (1767) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38) javascript.1 2020-07-12 17:53:42.359 warn (1767) at Object.<anonymous> (script.js.common.PVAnlage.E3DCS10EPro:1985:22) javascript.1 2020-07-12 17:53:42.353 warn (1767) getState "javascript.1.PVAnlage.E3DC-Control.History.HistoryJSON_00" not found (3) -
@ArnoD sagte in E3DC Hauskraftwerk steuern:
installiert.kurze Frage noch dazu...Hast du nur die config Datei oder alles dort installiert?
ich habe alles da rein installiert und musste dennoch mit
sudo chmod 666 e3dc.config.txt Schreibrechte vergeben, damit das Script die Datei beschreiben konnte...
sieht so aus bei mir...
@smartboart Den habe ich auch...
@stevie77 sagte in E3DC Hauskraftwerk steuern:
Was? den Fehler im log?
@smartboart Äh, ja, sorry, in diesem komischen Forum gehen die Zusammenhänge ja immer flöten weil es schlecht lesbar ist. Ja, ich meinte den Fehler im Log, den habe ich auch...
@stevie77 ok, dann wird arno sicher was finden...Ich habe den State manuell angelegt , dann taucht das nicht mehr im log auf.
Musstest du auch Schreibrechte für die Config vergeben und hast du auch komplett E3DC Control unter iobroker abgelegt? -
@smartboart Ich bin nicht so fit mit ioBroker, aber vielleicht probiere ich das auch mal so nen State anzulegen. Weiß nur nicht, ob das dann nicht weitere Fehler verdeckt (wo vielleicht auch noch was fehlt oder so).
Bei mir laufen ioBroker und E3DC-Control in zwei separaten fertigen Docker-Containern und ich habe ein Verzeichnis /home/iobroker/e3dc-config-transfer innerhalb des ioBroker-Containers auf das Konfigurationsverzeichnis des E3DC-Control-Docker-Containers auf dem Host gemappt. Schreibt der ioBroker die Konfigurationsdatei in dieses Verzeichnis, dann landet sie automatisch im Konfigurationsverzeichnis von E3DC-Control.
Rechte musste ich keine vergeben, weil der ioBroker-Benutzer unter /home/iobroker wohl von Haus aus alle Rechte besitzt. -
@smartboart sagte in E3DC Hauskraftwerk steuern:
Diesen State sollte es auch nicht geben.
Was bedeutet das irgendwo im Script versucht wird, auf den State "HistoryJSON_00" zuzugreifen.
Muss ich prüfen.
Komisch ist nur das bei mir der Fehler nicht auftritt. -
sudo chmod 666 e3dc.config.txt Schreibrechte vergeben, damit das Script die Datei beschreiben konnte...Habe auch alles dort intalliert und musste auch die rechte manuell neu vergeben.
@ArnoD ok danke....dann bin ich beruihgt..
Kann es sein das du in Vis ein Widget verwendest, um die Monate im Diagramm zu wechseln, und dort mit 0 beginnst für Januar ?
Habe mir das einfach gemacht und 1 für Januar bis 12 für Dezember verwendet.
Ich kann im Script 0 ignorieren, dann wird aber der Januar bei dir nicht angezeigt
@ArnoD soweit bin ich noch garnicht...
Ich habe meine vis noch nicht erstellt.
Das passiert bei mir( Fehler im log ) bei script neustart. -
vlt. hilft das,
nachdem ich den state angelegt habe sieht mein restart log nun so aus..javascript.1 2020-07-12 19:23:51.794 info (1840) script.js.common.PVAnlage.E3DCS10EPro: HistoryJSON_00 wurde unter HistoryJSON gespeichert javascript.1 2020-07-12 19:23:51.787 info (1840) script.js.common.PVAnlage.E3DCS10EPro: Jetzt sind alle States abgearbeitet javascript.1 2020-07-12 19:23:51.776 info (1840) script.js.common.PVAnlage.E3DCS10EPro: registered 5 subscriptions and 6 schedules javascript.1 2020-07-12 19:23:51.763 info (1840) script.js.common.PVAnlage.E3DCS10EPro: Schedule Automatik gestartet javascript.1 2020-07-12 19:23:51.757 info (1840) script.js.common.PVAnlage.E3DCS10EPro: JSON History ertellt javascript.1 2020-07-12 19:23:51.717 info (1840) Start javascript script.js.common.PVAnlage.E3DCS10EPro -
@smartboart
Ok, fehler gefunden.
Habe als Standard definition bei der Erstellung des State HistorySelect 0 eingetragen, was natürlich 1 sein muss.
Habe den Fehler korrigiert.
Bitte im State HistorySelect 1 eintragen, dann sollte die Meldung weg sein. -
@ArnoD ok super also im script auf def 1
[PfadEbene1 + PfadEbene2[2] + 'HistorySelect', {'def':1, 'name':'Select Menü für materialdesign json chart' ,'type':'number'}], -
@ArnoD Ich hätte noch grundsätzliche Verständnisfragen. Sorry.
Ich hab das JavaScript nun auf 0.1.13 aktualisiert und das TypeScript angelegt. Wenn ich probehalber die im Kommentar verlinkte View E3DC-Control: Stand 25.06.2020 importiere, dann ist da kein Automatik-Button. Aber egal, kann ich quasi kopieren von z.B. "Daten anlegen" und auf den State 0_userdata.0.E3DC-Control.Allgemein.Automatik verknüpfen und den dann irgendwie true oder false setzen. Mehr macht der nicht, ne? Oder braucht man da ne Art Toggle-Button in Vis, weil die anderen beiden Daten nur ne Funktion aufrufen?
Nur wenn 0_userdata.0.E3DC-Control.Allgemein.Automatik = true läuft das ganze Zeug um die Wettervorhersage an, richtig? Das würde dann vermutlich erklären, warum 0_userdata.0.E3DC-Control.Allgemein.PrognoseBerechnung_kWh_heute, 0_userdata.0.E3DC-Control.Allgemein.PrognoseFore_kWh_heute und 0_userdata.0.E3DC-Control.Allgemein.PrognoseProb_kWh_heute momentan alle auf 0 kWh stehen?
0_userdata.0.E3DC-Control.Allgemein.Prognose_1 bis 4 haben allerdings Werte... -
Die Einstellungen 1-5 werden in der View nur angezeigt, wenn 0_userdata.0.E3DC-Control.Allgemein.Automatik = true? Sie sind nicht für die manuelle Auswahl gedacht, sondern nur in Verbindung mit der Wettervorhersage, ne?
Wenn Automatik = true wird auch automatisch die Konfigurationsdatei von E3DC-Control (morgens irgendwann) erstellt, korrekt?
Der nächste Schritt wäre jetzt also hier true einzustellen (erst mal direkt in den States mangels Button) und sehen, ob morgen Prognosewerte kommen und ob irgendwas von Einstellung 1-5 aktiv wird... -
Die View Prognose: Stand 02.07.2020 ist nur für die Auswertung und nicht erforderlich für die Wettervorhersage und aktive Steuerung von E3DC-Control? Bis auf die Überschrift bleibt die momentan komplett leer, was aber wohl an fehlenden Vorhersagedaten liegt und dass ich History und das andere Teil noch irgendwie zum Speichern der Daten verleiten muss (wie weiter unten kürzlich erwähnt).
Nebenbei: Irgendwie witzig, es werden immer mehr Steuerungen...erst nur das Hauskraftwerk, dann wurde das von E3DC-Control gesteuert und nun ist E3DC-Control selbst auch fremdbestimmt durch ioBroker.
Wenn du es im Script machst musst du den State HistorySelect löschen und neu erstellen lassen oder du änderst diesen auch manuell auf 1.
Den State HistoryJSON_00 kannst du dann auch wieder löschen
