    4. Test Adapter mihome-vacuum v2.0.x
      K_o_bold last edited by K_o_bold
      @dirkhe , @Meistertr ,
      ich habe heute nach dem Saugen mal ins log geschaut und folgendes entdeckt:
      mihome-vacuum.0	2020-07-14 10:38:51.620	warn	(8477) This object will not be created in future versions. Please report this to the developer.
      mihome-vacuum.0	2020-07-14 10:38:51.620	warn	(8477) Object mihome-vacuum.0.rooms.room6.state is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json
      mihome-vacuum.0	2020-07-14 10:38:51.619	warn	(8477) This object will not be created in future versions. Please report this to the developer.
      mihome-vacuum.0	2020-07-14 10:38:51.618	warn	(8477) Object mihome-vacuum.0.rooms.room5.state is invalid: obj.common.type has an invalid value (text) but has to be one of number, string, boolean, array, object, mixed, file, json
      Und kurz vorher das hier:
      host.nuc	2020-07-14 10:37:58.060	error	Caught by controller[18]: 18: 0x13c9919 [io.mihome-vacuum.0]
      host.nuc	2020-07-14 10:37:58.060	error	Caught by controller[17]: 17: 0xc3070b v8::internal::Builtin_JsonStringify(int, unsigned long*, v8::internal::Isolate*) [io.mihome-vacuum.0]
      host.nuc	2020-07-14 10:37:58.060	error	Caught by controller[16]: 16: 0xe26ba4 v8::internal::JsonStringify(v8::internal::Isolate*, v8::internal::Handle<v8::internal::Object>, v8::internal::Handle<v8::internal::Object>, v8::internal::Handle
      host.nuc	2020-07-14 10:37:58.059	error	Caught by controller[15]: 15: 0xe25eff v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_<false>(v8::internal::Handle<v8::internal::Object>, bool, v8::internal::Handle<v8
      host.nuc	2020-07-14 10:37:58.059	error	Caught by controller[14]: 14: 0xe261f6 v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_<false>(v8::internal::Handle<v8::internal::Object>, bool, v8::internal::Handle<v8
      host.nuc	2020-07-14 10:37:58.059	error	Caught by controller[13]: 13: 0xe212e1 v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_<true>(v8::internal::Handle<v8::internal::Object>, bool, v8::internal::Handle<v8:
      host.nuc	2020-07-14 10:37:58.059	error	Caught by controller[12]: 12: 0xe20588 v8::internal::JsonStringifier::SerializeString(v8::internal::Handle<v8::internal::String>) [io.mihome-vacuum.0]
      host.nuc	2020-07-14 10:37:58.059	error	Caught by controller[11]: 11: 0x10c2385 v8::internal::IncrementalStringBuilder::Extend() [io.mihome-vacuum.0]
      host.nuc	2020-07-14 10:37:58.059	error	Caught by controller[10]: 10: 0xd0a16c v8::internal::Factory::NewRawOneByteString(int, v8::internal::AllocationType) [io.mihome-vacuum.0]
      host.nuc	2020-07-14 10:37:58.059	error	Caught by controller[9]: 9: 0xd3c2bc v8::internal::Heap::AllocateRawWithRetryOrFail(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.mihome-v
      host.nuc	2020-07-14 10:37:58.058	error	Caught by controller[8]: 8: 0xd39805 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.mihome-vacuum.0]
      host.nuc	2020-07-14 10:37:58.058	error	Caught by controller[7]: 7: 0xd38955 v8::internal::Heap::PerformGarbageCollection(v8::internal::GarbageCollector, v8::GCCallbackFlags) [io.mihome-vacuum.0]
      host.nuc	2020-07-14 10:37:58.058	error	Caught by controller[6]: 6: 0xd2c0d6 v8::internal::Heap::RecomputeLimits(v8::internal::GarbageCollector) [io.mihome-vacuum.0]
      host.nuc	2020-07-14 10:37:58.058	error	Caught by controller[5]: 5: 0xd2ba45 [io.mihome-vacuum.0]
      host.nuc	2020-07-14 10:37:58.058	error	Caught by controller[4]: 4: 0xb7f2d9 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
      host.nuc	2020-07-14 10:37:58.058	error	Caught by controller[3]: 3: 0xb7ef5e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
      host.nuc	2020-07-14 10:37:58.058	error	Caught by controller[2]: 2: 0xa08d0c node::OnFatalError(char const*, char const*) [io.mihome-vacuum.0]
      host.nuc	2020-07-14 10:37:58.057	error	Caught by controller[1]: 1: 0xa08900 node::Abort() [io.mihome-vacuum.0]
      host.nuc	2020-07-14 10:37:58.054	error	Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
      Könnt ihr mit diesen Meldungen etwas anfangen?
      Edit: Der Saugvorgang wurde ganz normal abgeschlossen
      Aber gestern habe ich ihn in einem anderen Stockwerk laufen lassen, kann es damit zusammen hängen?
        Kueppert @K_o_bold last edited by
        @K_o_bold sagte in Test Adapter mihome-vacuum v2.0.x:
        Sieht nach einem OutOfMemory-Problem aus. Hatte ich auch schon (trotz 3,5GB RAM).
          K_o_bold @Kueppert last edited by
          @Kueppert ,
          kann ich mir nicht vorstellen, ich habe 8 GB Ram und aktuell noch 3,5 GB frei. Das RAM Diagram meines Servers sieht auch nicht auffällig aus
            @K_o_bold ich hatte (als ich das Problem mal hatte) auch nicht dran geglaubt, dass es an fehlendem Speicher liegt...ich bin gespannt, ob der Fehler gefunden werden kann.
              dirkhe Developer last edited by
              Also Erst mal scheinst du eine alte Version zu nutzen, da die state für rooms mittlerweile vom typ String sind.
              Um weiteres festzustellen, brauchen wir ein debug Log. Das sieht irgendwie so aus, als wenn er den Compact mode nutzen will, der ist aktuell nur in der 2.1 drin, mit dem es aber andere Probleme gibt.
              • V
                vikk88 @K_o_bold last edited by
                @K_o_bold hm merkwürdig. Was, mache ich denn falsch? Bei mir steht die ganze Zeit connecting, this can take up to ten minutes im Log. Ich habe extra alles aktualisiert. Hat jemand eine Idee was ich noch probieren könnte?
                  A Former User @vikk88 last edited by A Former User
                  @vikk88 sagte in Test Adapter mihome-vacuum v2.0.x:
                  Hat jemand den S5 mit der aktuellen Firmware ans laufen bekommen?
                  Ich hab 4 S5, 3 davon mit der 3.5.7.2008 und einer der sich hartnäckig weigert, upzudaten, hat noch die x.x.1886 drauf.. läuft aber nur im Keller und fängt die Spinnen, von daher isses mir egal..
                  Was verstehst du unter aktueller Firmware?
                  • V
                    vikk88 @Guest last edited by
                    @ilovegym genau die 3.5.7_002008 habe ich drauf. Adapter Version momentan ist die 2.0.10. Admin ist auf Version 4 und node js die Version 10. Der Roboter verbindet sich einfach nicht
                      @vikk88 internet für den Roby frei, die richtigen Daten in der Config im Adapter eingetragen? Mal die App aufgemacht und n paar Minuten gewartet?
                      • V
                        @ilovegym jepp ist alles richtig eingestellt. Internet ist auch frei, mit der alten Firmware und der älteren Adapter Version lief auch alles. Komischerweise wird mit der 2.0.07 die Instanz auch grün aber ich kann ihn trotzdem nicht steuern. Im log steht dann immer im Wechsel connected, disconnected
                          @vikk88 welche 2.0.0.7 meinst du? welche Version vom Adapter hast du ?
                          Mal die Instanz gelöscht, reboot und den Adapter neu installiert ? ( upload ?)
                            Wenn da ständig connected/disconnected steht, sieht das nach netztwerkproblem aus. Bitte poste hier mal das debug log
                            • Meistertr
                              so habe die 2.1 heute noch einmal ausgiebiger mit saugen getestet und ich kann keine Fehler feststellen, auch im log von @ilovegym sehe ich vom Adapter keine Auffälligkeiten, es wurde einmal die Karte gespeichert ( Zeit: 2020-07-11 14:18:27.001) diese MUSS gespeichert worden sein da Code sich nicht einfach ändert. Das bedeutet der Adapter hat keinen Fehler, da die Verbindungen stehen und die Daten richtig verarbeitet werden. des Rest muss an der Cloud liegen. kann die Probleme von ilovegym denn noch jemand bestätigen? wenn der Roboter geladen im Dock steht, geht er in eine Art "Wachschlaf" dabei kann es vorkommen, dass er beim Adapterstart die Verbindung nicht direkt bekommt Abhilfe ist hier ein Saugvorgang starten oder App/Valetudo Interface öffnen, danach sollte die Verbindung dann eigentlich stehen..
                              • V
                                @ilovegym sorry ich meinte die Adapterversion 2.0.7, mit dieser wurde die Instanz grün aber ich konnte trotzdem keine Befehle senden. Aktuell habe ich die 2.0.10 drauf und da bleibt die Instanz gelb
                                • V
                                  vikk88 @dirkhe last edited by
                                  @dirkhe sorry für die doofe Frage aber wie mache ich das?
                                    Adapter auf debug stellen (unter instances Expertenlodus und dann die logStufe) dann das log hier posten. GGf. kanst du das log auch noch mihome-vacuum filtern) Wurde auch schon zigfach im forum gepostet
                                      A Former User @Meistertr last edited by
                                      @Meistertr Hi, das habe ich auch im log gelesen, das komische ist ja, dass die Datenpunkte map64 und mapURL nicht beschrieben wurden. Daher wurde mir in der VIS und per Telegram-Msg auch keine neue Karte angezeigt.
                                      Keine Ahnung, wo er das abgespeichert hat...
                                      @Diginix du hattest doch auch mit der 2.1.0 keine Karte, oder?
                                      Dass die Karte erst kommt, wenn der Sauger läuft und man am besten noch in der App ne Verbindung weiss ich, ich hatte ja Tage später immer noch keine Karte, obwohl die Sauger gelaufen sind. Da hab ich es ja auch erst gemerkt..
                                      • V
                                        @dirkhe Okay danke. Ich habe jetzt nochmal die 2.0.7 installiert
                                        2020-07-14 20:55:48.821 - info: mihome-vacuum.0 (1811) Disconnect
                                        2020-07-14 20:55:48.833 - info: mihome-vacuum.0 (1811) Connected
                                        2020-07-14 20:56:13.244 - info: host.raspberrypi "system.adapter.mihome-vacuum.0" enabled
                                        2020-07-14 20:56:13.270 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 2533
                                        2020-07-14 20:56:13.276 - warn: mihome-vacuum.0 (1811) Got terminate signal. Checking desired PID: 0 vs own PID 1811
                                        2020-07-14 20:56:13.283 - info: mihome-vacuum.0 (1811) terminating
                                        2020-07-14 20:56:13.285 - info: mihome-vacuum.0 (1811) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2020-07-14 20:56:13.291 - warn: mihome-vacuum.0 (1811) Got terminate signal. Checking desired PID: 2533 vs own PID 1811
                                        2020-07-14 20:56:13.817 - error: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                                        2020-07-14 20:56:13.818 - info: host.raspberrypi Do not restart adapter system.adapter.mihome-vacuum.0 because desired by instance
                                        2020-07-14 20:56:18.963 - warn: mihome-vacuum.0 (2533) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                        2020-07-14 20:56:18.967 - warn: mihome-vacuum.0 (2533) This object will not be created in future versions. Please report this to the developer.
                                        2020-07-14 20:56:19.478 - info: mihome-vacuum.0 (2533) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.21.0, js-controller: 3.1.6
                                        2020-07-14 20:56:19.540 - info: mihome-vacuum.0 (2533) Expert mode disabled, states deleted
                                        2020-07-14 20:56:19.544 - info: mihome-vacuum.0 (2533) Cloud control disabled
                                        2020-07-14 20:56:19.893 - info: mihome-vacuum.0 (2533) Disconnect
                                        2020-07-14 20:56:20.006 - info: mihome-vacuum.0 (2533) Connected
                                        2020-07-14 20:56:20.440 - info: mihome-vacuum.0 (2533) set nächster Timer: Nicht verfügbar
                                        2020-07-14 20:56:35.038 - warn: mihome-vacuum.0 (2533) no answer received after after 3 times -> pause miIO.info from request parameters, try again in one hour
                                        2020-07-14 20:56:59.595 - info: sonoff.0 (681) Client [Schlafzimmer] connection closed: closed
                                        2020-07-14 20:56:59.860 - info: sonoff.0 (681) Client [Schlafzimmer] connected with secret 1594753019858_4793
                                        2020-07-14 20:56:59.901 - info: mihome-vacuum.0 (2533) Disconnect
                                        2020-07-14 20:56:59.916 - info: mihome-vacuum.0 (2533) Connected
                                        2020-07-14 20:57:18.155 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 2549
                                        2020-07-14 20:57:18.161 - warn: mihome-vacuum.0 (2533) Got terminate signal. Checking desired PID: 0 vs own PID 2533
                                        2020-07-14 20:57:18.165 - info: mihome-vacuum.0 (2533) terminating
                                        2020-07-14 20:57:18.168 - info: mihome-vacuum.0 (2533) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2020-07-14 20:57:18.174 - warn: mihome-vacuum.0 (2533) Got terminate signal. Checking desired PID: 2549 vs own PID 2533
                                        2020-07-14 20:57:18.708 - error: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                                        2020-07-14 20:57:18.709 - info: host.raspberrypi Do not restart adapter system.adapter.mihome-vacuum.0 because desired by instance
                                        2020-07-14 20:57:21.756 - warn: mihome-vacuum.0 (2549) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                        2020-07-14 20:57:21.767 - warn: mihome-vacuum.0 (2549) This object will not be created in future versions. Please report this to the developer.
                                        2020-07-14 20:57:22.583 - info: mihome-vacuum.0 (2549) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.21.0, js-controller: 3.1.6
                                        2020-07-14 20:57:22.640 - info: mihome-vacuum.0 (2549) Expert mode disabled, states deleted
                                        2020-07-14 20:57:22.644 - info: mihome-vacuum.0 (2549) Cloud control disabled
                                        2020-07-14 20:57:22.675 - info: mihome-vacuum.0 (2549) Disconnect
                                        2020-07-14 20:57:22.770 - info: mihome-vacuum.0 (2549) Connected
                                        2020-07-14 20:57:22.773 - warn: mihome-vacuum.0 (2549) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                        2020-07-14 20:57:25.406 - info: mihome-vacuum.0 (2549) set nächster Timer: Nicht verfügbar
                                        2020-07-14 20:57:37.795 - warn: mihome-vacuum.0 (2549) no answer received after after 3 times -> pause miIO.info from request parameters, try again in one hour
                                        2020-07-14 20:58:02.682 - info: mihome-vacuum.0 (2549) Disconnect
                                        2020-07-14 20:58:02.690 - info: mihome-vacuum.0 (2549) Connected
                                        2020-07-14 20:58:12.507 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 2566
                                        2020-07-14 20:58:12.517 - warn: mihome-vacuum.0 (2549) Got terminate signal. Checking desired PID: 0 vs own PID 2549
                                        2020-07-14 20:58:12.524 - info: mihome-vacuum.0 (2549) terminating
                                        2020-07-14 20:58:12.532 - info: mihome-vacuum.0 (2549) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2020-07-14 20:58:12.546 - warn: mihome-vacuum.0 (2549) Got terminate signal. Checking desired PID: 2566 vs own PID 2549
                                        2020-07-14 20:58:13.080 - error: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                                        2020-07-14 20:58:13.081 - info: host.raspberrypi Do not restart adapter system.adapter.mihome-vacuum.0 because desired by instance
                                        2020-07-14 20:58:14.188 - debug: mihome-vacuum.0 (2566) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        2020-07-14 20:58:14.852 - debug: mihome-vacuum.0 (2566) Objects client ready ... initialize now
                                        2020-07-14 20:58:14.861 - debug: mihome-vacuum.0 (2566) Objects create System PubSub Client
                                        2020-07-14 20:58:14.863 - debug: mihome-vacuum.0 (2566) Objects create User PubSub Client
                                        2020-07-14 20:58:14.865 - debug: mihome-vacuum.0 (2566) Objects client initialize lua scripts
                                        2020-07-14 20:58:14.889 - debug: mihome-vacuum.0 (2566) Objects connected to redis: 127.0.0.1:9001
                                        2020-07-14 20:58:14.906 - debug: mihome-vacuum.0 (2566) objectDB connected
                                        2020-07-14 20:58:14.911 - debug: mihome-vacuum.0 (2566) Redis States: Use Redis connection: 127.0.0.1:9000
                                        2020-07-14 20:58:14.924 - debug: mihome-vacuum.0 (2566) States create User PubSub Client
                                        2020-07-14 20:58:14.928 - debug: mihome-vacuum.0 (2566) States create System PubSub Client
                                        2020-07-14 20:58:14.945 - debug: mihome-vacuum.0 (2566) States connected to redis: 127.0.0.1:9000
                                        2020-07-14 20:58:14.946 - debug: mihome-vacuum.0 (2566) statesDB connected
                                        2020-07-14 20:58:15.686 - warn: mihome-vacuum.0 (2566) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                        2020-07-14 20:58:15.687 - warn: mihome-vacuum.0 (2566) This object will not be created in future versions. Please report this to the developer.
                                        2020-07-14 20:58:16.357 - info: mihome-vacuum.0 (2566) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.21.0, js-controller: 3.1.6
                                        2020-07-14 20:58:16.449 - info: mihome-vacuum.0 (2566) Expert mode disabled, states deleted
                                        2020-07-14 20:58:16.453 - info: mihome-vacuum.0 (2566) Cloud control disabled
                                        2020-07-14 20:58:16.484 - info: mihome-vacuum.0 (2566) Disconnect
                                        2020-07-14 20:58:16.498 - debug: mihome-vacuum.0 (2566) server started on 0.0.0.0:53421
                                        2020-07-14 20:58:16.570 - info: mihome-vacuum.0 (2566) Connected
                                        2020-07-14 20:58:16.573 - warn: mihome-vacuum.0 (2566) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                        2020-07-14 20:58:16.582 - debug: mihome-vacuum.0 (2566) requesting params every: 60 Sec
                                        2020-07-14 20:58:17.023 - info: mihome-vacuum.0 (2566) set nächster Timer: Nicht verfügbar
                                        2020-07-14 20:58:31.589 - debug: mihome-vacuum.0 (2566) no answer for get_status(id:1) received, giving up
                                        2020-07-14 20:58:31.601 - debug: mihome-vacuum.0 (2566) no answer for miIO.info(id:2) received, giving up
                                        2020-07-14 20:58:31.602 - warn: mihome-vacuum.0 (2566) no answer received after after 3 times -> pause miIO.info from request parameters, try again in one hour
                                        2020-07-14 20:58:31.792 - debug: mihome-vacuum.0 (2566) no answer for get_consumable(id:3) received, giving up
                                        2020-07-14 20:58:31.993 - debug: mihome-vacuum.0 (2566) no answer for get_clean_summary(id:4) received, giving up
                                        2020-07-14 20:58:32.195 - debug: mihome-vacuum.0 (2566) no answer for get_sound_volume(id:5) received, giving up
                                        2020-07-14 20:58:34.492 - debug: mihome-vacuum.0 (2566) no answer for get_carpet_mode(id:6) received, giving up
                                        2020-07-14 20:58:34.496 - debug: mihome-vacuum.0 (2566) no answer for get_room_mapping(id:7) received, giving up
                                        2020-07-14 20:58:51.498 - debug: mihome-vacuum.0 (2566) no answer for get_status(id:8) received, giving up
                                        2020-07-14 20:58:56.492 - info: mihome-vacuum.0 (2566) Disconnect
                                        2020-07-14 20:58:56.508 - info: mihome-vacuum.0 (2566) Connected
                                        2020-07-14 20:58:56.515 - debug: mihome-vacuum.0 (2566) requesting params every: 60 Sec
                                        2020-07-14 20:59:00.577 - info: sonoff.0 (681) Client [Schlafzimmer] connection closed: closed
                                        2020-07-14 20:59:01.041 - info: sonoff.0 (681) Client [Schlafzimmer] connected with secret 1594753141040_7777
                                        2020-07-14 20:59:11.522 - debug: mihome-vacuum.0 (2566) no answer for get_status(id:9) received, giving up
                                        2020-07-14 20:59:11.533 - debug: mihome-vacuum.0 (2566) no answer for get_consumable(id:10) received, giving up
                                        2020-07-14 20:59:11.730 - debug: mihome-vacuum.0 (2566) no answer for get_clean_summary(id:11) received, giving up
                                        2020-07-14 20:59:11.929 - debug: mihome-vacuum.0 (2566) no answer for get_sound_volume(id:12) received, giving up
                                        2020-07-14 20:59:16.488 - debug: mihome-vacuum.0 (2566) requesting params every: 60 Sec
                                        2020-07-14 20:59:31.499 - debug: mihome-vacuum.0 (2566) no answer for get_consumable(id:13) received, giving up
                                        2020-07-14 20:59:31.504 - debug: mihome-vacuum.0 (2566) no answer for get_status(id:14) received, giving up
                                        2020-07-14 20:59:31.699 - debug: mihome-vacuum.0 (2566) no answer for get_clean_summary(id:15) received, giving up
                                        2020-07-14 20:59:31.901 - debug: mihome-vacuum.0 (2566) no answer for get_sound_volume(id:16) received, giving up
                                        2020-07-14 20:59:36.499 - info: mihome-vacuum.0 (2566) Disconnect
                                        2020-07-14 20:59:36.514 - info: mihome-vacuum.0 (2566) Connected
                                        2020-07-14 20:59:36.521 - debug: mihome-vacuum.0 (2566) requesting params every: 60 Sec
                                        2020-07-14 20:59:51.529 - debug: mihome-vacuum.0 (2566) no answer for get_status(id:17) received, giving up
                                        2020-07-14 20:59:51.536 - debug: mihome-vacuum.0 (2566) no answer for get_consumable(id:18) received, giving up
                                        2020-07-14 20:59:51.734 - debug: mihome-vacuum.0 (2566) no answer for get_clean_summary(id:19) received, giving up
                                        2020-07-14 20:59:51.935 - debug: mihome-vacuum.0 (2566) no answer for get_sound_volume(id:20) received, giving up
                                        2020-07-14 21:00:11.515 - debug: mihome-vacuum.0 (2566) no answer for get_status(id:21) received, giving up
                                        2020-07-14 21:00:16.488 - debug: mihome-vacuum.0 (2566) requesting params every: 60 Sec
                                        2020-07-14 21:00:16.508 - info: mihome-vacuum.0 (2566) Disconnect
                                        2020-07-14 21:00:16.517 - info: mihome-vacuum.0 (2566) Connected
                                        2020-07-14 21:00:16.520 - debug: mihome-vacuum.0 (2566) requesting params every: 60 Sec
                                        2020-07-14 21:00:31.497 - debug: mihome-vacuum.0 (2566) no answer for get_consumable(id:22) received, giving up
                                        2020-07-14 21:00:31.526 - debug: mihome-vacuum.0 (2566) no answer for get_status(id:23) received, giving up
                                        2020-07-14 21:00:31.531 - debug: mihome-vacuum.0 (2566) no answer for get_consumable(id:24) received, giving up
                                        2020-07-14 21:00:31.696 - debug: mihome-vacuum.0 (2566) no answer for get_clean_summary(id:25) received, giving up
                                        2020-07-14 21:00:31.729 - debug: mihome-vacuum.0 (2566) no answer for get_clean_summary(id:26) received, giving up
                                        2020-07-14 21:00:31.899 - debug: mihome-vacuum.0 (2566) no answer for get_sound_volume(id:27) received, giving up
                                        2020-07-14 21:00:31.935 - debug: mihome-vacuum.0 (2566) no answer for get_sound_volume(id:28) received, giving up
                                        D K 2 Replies Last reply Reply Quote 0
                                          dirkhe Developer @vikk88 last edited by
                                          @vikk88 Bitte deinstalliere den nochmal und installiere den 2.0.10 und schicke uns das log
                                            K_o_bold @vikk88 last edited by
                                            @vikk88 ,
                                            ist die IP Adresse des Saugers im Adapter richtig eingestellt?
                                            1.0k
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            495747
