    4. Test Adapter mihome-vacuum v2.0.x
    • V
      vikk88 @dirkhe last edited by
      @dirkhe Okay danke. Ich habe jetzt nochmal die 2.0.7 installiert
      2020-07-14 20:55:48.821 - info: mihome-vacuum.0 (1811) Disconnect
      2020-07-14 20:55:48.833 - info: mihome-vacuum.0 (1811) Connected
      2020-07-14 20:56:13.244 - info: host.raspberrypi "system.adapter.mihome-vacuum.0" enabled
      2020-07-14 20:56:13.270 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 2533
      2020-07-14 20:56:13.276 - warn: mihome-vacuum.0 (1811) Got terminate signal. Checking desired PID: 0 vs own PID 1811
      2020-07-14 20:56:13.283 - info: mihome-vacuum.0 (1811) terminating
      2020-07-14 20:56:13.285 - info: mihome-vacuum.0 (1811) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2020-07-14 20:56:13.291 - warn: mihome-vacuum.0 (1811) Got terminate signal. Checking desired PID: 2533 vs own PID 1811
      2020-07-14 20:56:13.817 - error: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      2020-07-14 20:56:13.818 - info: host.raspberrypi Do not restart adapter system.adapter.mihome-vacuum.0 because desired by instance
      2020-07-14 20:56:18.963 - warn: mihome-vacuum.0 (2533) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
      2020-07-14 20:56:18.967 - warn: mihome-vacuum.0 (2533) This object will not be created in future versions. Please report this to the developer.
      2020-07-14 20:56:19.478 - info: mihome-vacuum.0 (2533) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.21.0, js-controller: 3.1.6
      2020-07-14 20:56:19.540 - info: mihome-vacuum.0 (2533) Expert mode disabled, states deleted
      2020-07-14 20:56:19.544 - info: mihome-vacuum.0 (2533) Cloud control disabled
      2020-07-14 20:56:19.893 - info: mihome-vacuum.0 (2533) Disconnect
      2020-07-14 20:56:20.006 - info: mihome-vacuum.0 (2533) Connected
      2020-07-14 20:56:20.440 - info: mihome-vacuum.0 (2533) set nächster Timer: Nicht verfügbar
      2020-07-14 20:56:35.038 - warn: mihome-vacuum.0 (2533) no answer received after after 3 times -> pause miIO.info from request parameters, try again in one hour
      2020-07-14 20:56:59.595 - info: sonoff.0 (681) Client [Schlafzimmer] connection closed: closed
      2020-07-14 20:56:59.860 - info: sonoff.0 (681) Client [Schlafzimmer] connected with secret 1594753019858_4793
      2020-07-14 20:56:59.901 - info: mihome-vacuum.0 (2533) Disconnect
      2020-07-14 20:56:59.916 - info: mihome-vacuum.0 (2533) Connected
      2020-07-14 20:57:18.155 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 2549
      2020-07-14 20:57:18.161 - warn: mihome-vacuum.0 (2533) Got terminate signal. Checking desired PID: 0 vs own PID 2533
      2020-07-14 20:57:18.165 - info: mihome-vacuum.0 (2533) terminating
      2020-07-14 20:57:18.168 - info: mihome-vacuum.0 (2533) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2020-07-14 20:57:18.174 - warn: mihome-vacuum.0 (2533) Got terminate signal. Checking desired PID: 2549 vs own PID 2533
      2020-07-14 20:57:18.708 - error: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      2020-07-14 20:57:18.709 - info: host.raspberrypi Do not restart adapter system.adapter.mihome-vacuum.0 because desired by instance
      2020-07-14 20:57:21.756 - warn: mihome-vacuum.0 (2549) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
      2020-07-14 20:57:21.767 - warn: mihome-vacuum.0 (2549) This object will not be created in future versions. Please report this to the developer.
      2020-07-14 20:57:22.583 - info: mihome-vacuum.0 (2549) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.21.0, js-controller: 3.1.6
      2020-07-14 20:57:22.640 - info: mihome-vacuum.0 (2549) Expert mode disabled, states deleted
      2020-07-14 20:57:22.644 - info: mihome-vacuum.0 (2549) Cloud control disabled
      2020-07-14 20:57:22.675 - info: mihome-vacuum.0 (2549) Disconnect
      2020-07-14 20:57:22.770 - info: mihome-vacuum.0 (2549) Connected
      2020-07-14 20:57:22.773 - warn: mihome-vacuum.0 (2549) Time difference between Mihome Vacuum and ioBroker: 1 sec
      2020-07-14 20:57:25.406 - info: mihome-vacuum.0 (2549) set nächster Timer: Nicht verfügbar
      2020-07-14 20:57:37.795 - warn: mihome-vacuum.0 (2549) no answer received after after 3 times -> pause miIO.info from request parameters, try again in one hour
      2020-07-14 20:58:02.682 - info: mihome-vacuum.0 (2549) Disconnect
      2020-07-14 20:58:02.690 - info: mihome-vacuum.0 (2549) Connected
      2020-07-14 20:58:12.507 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 2566
      2020-07-14 20:58:12.517 - warn: mihome-vacuum.0 (2549) Got terminate signal. Checking desired PID: 0 vs own PID 2549
      2020-07-14 20:58:12.524 - info: mihome-vacuum.0 (2549) terminating
      2020-07-14 20:58:12.532 - info: mihome-vacuum.0 (2549) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2020-07-14 20:58:12.546 - warn: mihome-vacuum.0 (2549) Got terminate signal. Checking desired PID: 2566 vs own PID 2549
      2020-07-14 20:58:13.080 - error: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      2020-07-14 20:58:13.081 - info: host.raspberrypi Do not restart adapter system.adapter.mihome-vacuum.0 because desired by instance
      2020-07-14 20:58:14.188 - debug: mihome-vacuum.0 (2566) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2020-07-14 20:58:14.852 - debug: mihome-vacuum.0 (2566) Objects client ready ... initialize now
      2020-07-14 20:58:14.861 - debug: mihome-vacuum.0 (2566) Objects create System PubSub Client
      2020-07-14 20:58:14.863 - debug: mihome-vacuum.0 (2566) Objects create User PubSub Client
      2020-07-14 20:58:14.865 - debug: mihome-vacuum.0 (2566) Objects client initialize lua scripts
      2020-07-14 20:58:14.889 - debug: mihome-vacuum.0 (2566) Objects connected to redis: 127.0.0.1:9001
      2020-07-14 20:58:14.906 - debug: mihome-vacuum.0 (2566) objectDB connected
      2020-07-14 20:58:14.911 - debug: mihome-vacuum.0 (2566) Redis States: Use Redis connection: 127.0.0.1:9000
      2020-07-14 20:58:14.924 - debug: mihome-vacuum.0 (2566) States create User PubSub Client
      2020-07-14 20:58:14.928 - debug: mihome-vacuum.0 (2566) States create System PubSub Client
      2020-07-14 20:58:14.945 - debug: mihome-vacuum.0 (2566) States connected to redis: 127.0.0.1:9000
      2020-07-14 20:58:14.946 - debug: mihome-vacuum.0 (2566) statesDB connected
      2020-07-14 20:58:15.686 - warn: mihome-vacuum.0 (2566) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
      2020-07-14 20:58:15.687 - warn: mihome-vacuum.0 (2566) This object will not be created in future versions. Please report this to the developer.
      2020-07-14 20:58:16.357 - info: mihome-vacuum.0 (2566) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.21.0, js-controller: 3.1.6
      2020-07-14 20:58:16.449 - info: mihome-vacuum.0 (2566) Expert mode disabled, states deleted
      2020-07-14 20:58:16.453 - info: mihome-vacuum.0 (2566) Cloud control disabled
      2020-07-14 20:58:16.484 - info: mihome-vacuum.0 (2566) Disconnect
      2020-07-14 20:58:16.498 - debug: mihome-vacuum.0 (2566) server started on 0.0.0.0:53421
      2020-07-14 20:58:16.570 - info: mihome-vacuum.0 (2566) Connected
      2020-07-14 20:58:16.573 - warn: mihome-vacuum.0 (2566) Time difference between Mihome Vacuum and ioBroker: 1 sec
      2020-07-14 20:58:16.582 - debug: mihome-vacuum.0 (2566) requesting params every: 60 Sec
      2020-07-14 20:58:17.023 - info: mihome-vacuum.0 (2566) set nächster Timer: Nicht verfügbar
      2020-07-14 20:58:31.589 - debug: mihome-vacuum.0 (2566) no answer for get_status(id:1) received, giving up
      2020-07-14 20:58:31.601 - debug: mihome-vacuum.0 (2566) no answer for miIO.info(id:2) received, giving up
      2020-07-14 20:58:31.602 - warn: mihome-vacuum.0 (2566) no answer received after after 3 times -> pause miIO.info from request parameters, try again in one hour
      2020-07-14 20:58:31.792 - debug: mihome-vacuum.0 (2566) no answer for get_consumable(id:3) received, giving up
      2020-07-14 20:58:31.993 - debug: mihome-vacuum.0 (2566) no answer for get_clean_summary(id:4) received, giving up
      2020-07-14 20:58:32.195 - debug: mihome-vacuum.0 (2566) no answer for get_sound_volume(id:5) received, giving up
      2020-07-14 20:58:34.492 - debug: mihome-vacuum.0 (2566) no answer for get_carpet_mode(id:6) received, giving up
      2020-07-14 20:58:34.496 - debug: mihome-vacuum.0 (2566) no answer for get_room_mapping(id:7) received, giving up
      2020-07-14 20:58:51.498 - debug: mihome-vacuum.0 (2566) no answer for get_status(id:8) received, giving up
      2020-07-14 20:58:56.492 - info: mihome-vacuum.0 (2566) Disconnect
      2020-07-14 20:58:56.508 - info: mihome-vacuum.0 (2566) Connected
      2020-07-14 20:58:56.515 - debug: mihome-vacuum.0 (2566) requesting params every: 60 Sec
      2020-07-14 20:59:00.577 - info: sonoff.0 (681) Client [Schlafzimmer] connection closed: closed
      2020-07-14 20:59:01.041 - info: sonoff.0 (681) Client [Schlafzimmer] connected with secret 1594753141040_7777
      2020-07-14 20:59:11.522 - debug: mihome-vacuum.0 (2566) no answer for get_status(id:9) received, giving up
      2020-07-14 20:59:11.533 - debug: mihome-vacuum.0 (2566) no answer for get_consumable(id:10) received, giving up
      2020-07-14 20:59:11.730 - debug: mihome-vacuum.0 (2566) no answer for get_clean_summary(id:11) received, giving up
      2020-07-14 20:59:11.929 - debug: mihome-vacuum.0 (2566) no answer for get_sound_volume(id:12) received, giving up
      2020-07-14 20:59:16.488 - debug: mihome-vacuum.0 (2566) requesting params every: 60 Sec
      2020-07-14 20:59:31.499 - debug: mihome-vacuum.0 (2566) no answer for get_consumable(id:13) received, giving up
      2020-07-14 20:59:31.504 - debug: mihome-vacuum.0 (2566) no answer for get_status(id:14) received, giving up
      2020-07-14 20:59:31.699 - debug: mihome-vacuum.0 (2566) no answer for get_clean_summary(id:15) received, giving up
      2020-07-14 20:59:31.901 - debug: mihome-vacuum.0 (2566) no answer for get_sound_volume(id:16) received, giving up
      2020-07-14 20:59:36.499 - info: mihome-vacuum.0 (2566) Disconnect
      2020-07-14 20:59:36.514 - info: mihome-vacuum.0 (2566) Connected
      2020-07-14 20:59:36.521 - debug: mihome-vacuum.0 (2566) requesting params every: 60 Sec
      2020-07-14 20:59:51.529 - debug: mihome-vacuum.0 (2566) no answer for get_status(id:17) received, giving up
      2020-07-14 20:59:51.536 - debug: mihome-vacuum.0 (2566) no answer for get_consumable(id:18) received, giving up
      2020-07-14 20:59:51.734 - debug: mihome-vacuum.0 (2566) no answer for get_clean_summary(id:19) received, giving up
      2020-07-14 20:59:51.935 - debug: mihome-vacuum.0 (2566) no answer for get_sound_volume(id:20) received, giving up
      2020-07-14 21:00:11.515 - debug: mihome-vacuum.0 (2566) no answer for get_status(id:21) received, giving up
      2020-07-14 21:00:16.488 - debug: mihome-vacuum.0 (2566) requesting params every: 60 Sec
      2020-07-14 21:00:16.508 - info: mihome-vacuum.0 (2566) Disconnect
      2020-07-14 21:00:16.517 - info: mihome-vacuum.0 (2566) Connected
      2020-07-14 21:00:16.520 - debug: mihome-vacuum.0 (2566) requesting params every: 60 Sec
      2020-07-14 21:00:31.497 - debug: mihome-vacuum.0 (2566) no answer for get_consumable(id:22) received, giving up
      2020-07-14 21:00:31.526 - debug: mihome-vacuum.0 (2566) no answer for get_status(id:23) received, giving up
      2020-07-14 21:00:31.531 - debug: mihome-vacuum.0 (2566) no answer for get_consumable(id:24) received, giving up
      2020-07-14 21:00:31.696 - debug: mihome-vacuum.0 (2566) no answer for get_clean_summary(id:25) received, giving up
      2020-07-14 21:00:31.729 - debug: mihome-vacuum.0 (2566) no answer for get_clean_summary(id:26) received, giving up
      2020-07-14 21:00:31.899 - debug: mihome-vacuum.0 (2566) no answer for get_sound_volume(id:27) received, giving up
      2020-07-14 21:00:31.935 - debug: mihome-vacuum.0 (2566) no answer for get_sound_volume(id:28) received, giving up
      D K 2 Replies Last reply Reply Quote 0
        dirkhe Developer @vikk88 last edited by
        @vikk88 Bitte deinstalliere den nochmal und installiere den 2.0.10 und schicke uns das log
          K_o_bold @vikk88 last edited by
          @vikk88 ,
          ist die IP Adresse des Saugers im Adapter richtig eingestellt?
            K_o_bold @dirkhe last edited by
            @dirkhe ,
            ok. Wenn denn noch Probleme mit der aktuellsten Adapter Version gibt, werde ich erst mal abwarten.
            Das debug log werde ich mal schicken sobald der Staubsauger das nächste mal läuft.
            Danke für die Rückmeldung.
            • V
              vikk88 @K_o_bold last edited by
              @K_o_bold ja die passt. Konnte die auch mit dem Adapter abrufen
              • V
                @dirkhe hier nochmal mit der 2.0.10
                2020-07-14 21:25:11.754 - debug: mihome-vacuum.0 (2566) no answer for get_status(id:282) received, giving up
                2020-07-14 21:25:11.757 - debug: mihome-vacuum.0 (2566) no answer for get_consumable(id:283) received, giving up
                2020-07-14 21:25:11.958 - debug: mihome-vacuum.0 (2566) no answer for get_clean_summary(id:284) received, giving up
                2020-07-14 21:25:12.167 - debug: mihome-vacuum.0 (2566) no answer for get_sound_volume(id:285) received, giving up
                2020-07-14 21:25:16.492 - debug: mihome-vacuum.0 (2566) requesting params every: 60 Sec
                2020-07-14 21:25:31.508 - debug: mihome-vacuum.0 (2566) no answer for get_consumable(id:286) received, giving up
                2020-07-14 21:25:31.705 - debug: mihome-vacuum.0 (2566) no answer for get_clean_summary(id:287) received, giving up
                2020-07-14 21:25:31.745 - debug: mihome-vacuum.0 (2566) no answer for get_status(id:288) received, giving up
                2020-07-14 21:25:31.902 - debug: mihome-vacuum.0 (2566) no answer for get_sound_volume(id:289) received, giving up
                2020-07-14 21:25:36.740 - info: mihome-vacuum.0 (2566) Disconnect
                2020-07-14 21:25:36.754 - info: mihome-vacuum.0 (2566) Connected
                2020-07-14 21:25:36.759 - debug: mihome-vacuum.0 (2566) requesting params every: 60 Sec
                2020-07-14 21:25:51.765 - debug: mihome-vacuum.0 (2566) no answer for get_status(id:290) received, giving up
                2020-07-14 21:25:51.770 - debug: mihome-vacuum.0 (2566) no answer for get_consumable(id:291) received, giving up
                2020-07-14 21:25:51.971 - debug: mihome-vacuum.0 (2566) no answer for get_clean_summary(id:292) received, giving up
                2020-07-14 21:25:52.169 - debug: mihome-vacuum.0 (2566) no answer for get_sound_volume(id:293) received, giving up
                2020-07-14 21:25:56.498 - info: host.raspberrypi "system.adapter.mihome-vacuum.0" enabled
                2020-07-14 21:25:56.531 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 3309
                2020-07-14 21:25:56.543 - warn: mihome-vacuum.0 (2566) Got terminate signal. Checking desired PID: 0 vs own PID 2566
                2020-07-14 21:25:56.550 - info: mihome-vacuum.0 (2566) terminating
                2020-07-14 21:25:56.553 - info: mihome-vacuum.0 (2566) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2020-07-14 21:25:56.558 - warn: mihome-vacuum.0 (2566) Got terminate signal. Checking desired PID: 3309 vs own PID 2566
                2020-07-14 21:25:57.088 - error: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                2020-07-14 21:25:57.089 - info: host.raspberrypi Do not restart adapter system.adapter.mihome-vacuum.0 because desired by instance
                2020-07-14 21:26:02.900 - info: mihome-vacuum.0 (3309) starting. Version 2.0.10 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.21.0, js-controller: 3.1.6
                2020-07-14 21:26:03.011 - info: mihome-vacuum.0 (3309) Expert mode disabled, states deleted
                2020-07-14 21:26:03.015 - info: mihome-vacuum.0 (3309) Cloud control disabled
                2020-07-14 21:26:03.166 - info: mihome-vacuum.0 (3309) connecting, this can take up to 10 minutes ...
                2020-07-14 21:26:03.610 - info: mihome-vacuum.0 (3309) set nächster Timer: Nicht verfügbar
                2020-07-14 21:26:13.689 - info: sonoff.0 (681) Client [Geräte] connection closed: closed
                2020-07-14 21:26:13.709 - info: sonoff.0 (681) Client [Geräte] connected with secret 1594754773705_6545
                2020-07-14 21:26:23.045 - info: mihome-vacuum.0 (3309) connecting, this can take up to 10 minutes ...
                • Diginix
                  Diginix @Guest last edited by
                  @ilovegym sagte in Test Adapter mihome-vacuum v2.0.x:
                  @Diginix du hattest doch auch mit der 2.1.0 keine Karte, oder?
                  Dass die Karte erst kommt, wenn der Sauger läuft und man am besten noch in der App ne Verbindung weiss ich, ich hatte ja Tage später immer noch keine Karte, obwohl die Sauger gelaufen sind. Da hab ich es ja auch erst gemerkt..
                  Korrekt, hatte mit 2.1.0 "connected" und auch den Sauger über den Adapter gestartet aber selbst nach 2 Minuten kein Kartenupdate. Rollback auf 2.0.10 und sofort die Karte. Wirklich lange hab ich nicht getestet.
                  In meinem Log (level info) kam nur:
                  mihome-vacuum.0	2020-07-11 14:40:15.219	warn	(2578714) Could not receive Mappointer, giving up
                  mihome-vacuum.0	2020-07-11 14:40:15.137	warn	(2578714) Could not receive Mappointer, giving up
                  mihome-vacuum.0	2020-07-11 14:40:09.180	warn	(2578714) Could not receive Mappointer, giving up
                    @vikk88 da scheint der Adapter irgendwie nicht richtig installiert zu sein. Der wird schon vorzeitig beendet. Gab es bei der Installation irgendwelche Probleme?
                    • V
                      @dirkhe anfangs ging es nicht weil ich canvas nicht installiert hatte. Nachdem ich die Befehle, welche in der Readme des Adapters stehen, eingegeben habe konnte ich ihn ganz normal installieren
                      • Meistertr
                        @ilovegym bitte nochmal von git teste. Ich habe glaub ich den Fehler im Megaupdate von Bluefox gefunden. Die Karte wurde erstellt aber nicht weitergegeben wenn sie über die cloud kommt. Hierzu muss mann auch sagen dass das update zwingen nötig war, da der compact mode schon seit einem Jahr auf umsetzung wartet...
                        ? Diginix 2 Replies Last reply Reply Quote 2
                          A Former User @Meistertr last edited by
                          @Meistertr sagte in Test Adapter mihome-vacuum v2.0.x:
                          Super, vielen vielen Dank! Das war's! Mit dieser Version laufen die Karten ohne Probleme, getestet mit S5 Firmware 3.5.7.2008 und der alten 3.3.9.1886. Steuerbefehle, Goto, Werte ( Saugleistung, etc) werden aktualisiert.
                          Und ja, ich kenn den Compactmodus, brauche ihn zwar nicht, aber die idee ist klasse! Und bin daher auch froh, dass die Adapter weiter aktuell entwickelt werden. War ja nur blöd dass ich selbst kein Backup hatte weil viel zu spät gemerkt..
                          Ich bleib auf der 2.1.0 jetzt und kann sie mit gutem Gewissen weiterempfehlen 🙂
                          Vielen Dank für den Sondereinsatz!
                          • Diginix
                            Diginix @Meistertr last edited by
                            @Meistertr Auch bei meinem 1S kommt mit der neuen 2.1 nun wieder die Karte.
                            Danke für euer Engagement @Meistertr @dirkhe @Bluefox !
                            Bluefox 1 Reply Last reply Reply Quote 0
                            • Meistertr
                              gut dann schieb ich sie wieder ins latest
                              • V
                                Erstmal danke für die ganze tolle Hilfe und für die Entwicklung dieses tollen Adapters. Ich habe meinen Fehler jetzt gefunden. Es war auch ganz Simpel aber manchmal kommt man da nicht drauf. Ich habe mir mit dem Adapter den Token und die Ip des Saugers geholt. Die Ip war richtig aber der Token nicht, dieser war auch viel kürzer als mein alter. Der Staubsauger hat mit der neuen Firmware auch eine andere Ip bekommen deshalb dachte ich das der Token sich auch geändert hat und weil die Instanz ja auch grün wurde habe ich nicht daran gedacht mal den anderen Token einzutragen.
                                • Diginix
                                  Diginix last edited by Diginix
                                  FYI: 2.1.1 läuft bei mir problemlos in den ersten kurzen Tests
                                    @Bluefox @Meistertr @dirkhe
                                    Version 2.1.1 läuft hier auch, hat sich nach dem Update und Upload nicht neu gestartet, die 4 Instanzen standen auf rot und ich musste sie stoppen und neu starten, dann gings... siehe log:
                                    2020-07-16 08:51:44.503  - info: host.iobroker iobroker upgrade mihome-vacuum
                                    2020-07-16 08:51:46.214  - info: host.iobroker iobroker Update mihome-vacuum from @2.1.0 to @2.1.1
                                    2020-07-16 08:51:46.578  - info: host.iobroker iobroker npm install iobroker.mihome-vacuum@2.1.1 --loglevel error --prefix "/opt/iobroker" (System call)
                                    2020-07-16 08:52:37.832  - info: host.iobroker iobroker upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
                                    2020-07-16 08:52:37.975  - info: host.iobroker iobroker upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
                                    2020-07-16 08:52:38.030  - info: host.iobroker iobroker upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
                                    2020-07-16 08:52:38.092  - info: host.iobroker iobroker upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
                                    2020-07-16 08:52:38.152  - info: host.iobroker iobroker upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
                                    2020-07-16 08:52:38.206  - info: host.iobroker iobroker upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/root/howto.md root/howto.md text/markdown
                                    2020-07-16 08:52:38.254  - info: host.iobroker iobroker Update "system.adapter.mihome-vacuum.3"
                                    2020-07-16 08:52:38.259  - info: host.iobroker iobroker Update "system.adapter.mihome-vacuum.2"
                                    2020-07-16 08:52:38.272  - info: host.iobroker iobroker Update "system.adapter.mihome-vacuum.1"
                                    2020-07-16 08:52:38.276  - info: host.iobroker iobroker Update "system.adapter.mihome-vacuum.0"
                                    2020-07-16 08:52:38.310  - info: host.iobroker stopInstance system.adapter.mihome-vacuum.3 (force=false, process=true)
                                    2020-07-16 08:52:38.312  - info: host.iobroker iobroker upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
                                    2020-07-16 08:52:38.328  - info: host.iobroker stopInstance system.adapter.mihome-vacuum.3 send kill signal
                                    2020-07-16 08:52:38.330  - info: mihome-vacuum.3 (24467) Got terminate signal TERMINATE_YOURSELF
                                    2020-07-16 08:52:38.333  - info: mihome-vacuum.3 (24467) terminating
                                    2020-07-16 08:52:38.334  - info: mihome-vacuum.3 (24467) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2020-07-16 08:52:38.342  - info: host.iobroker stopInstance system.adapter.mihome-vacuum.2 (force=false, process=true)
                                    2020-07-16 08:52:38.345  - info: host.iobroker stopInstance system.adapter.mihome-vacuum.1 (force=false, process=true)
                                    2020-07-16 08:52:38.347  - info: host.iobroker stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                    2020-07-16 08:52:38.351  - info: mihome-vacuum.2 (24473) Got terminate signal TERMINATE_YOURSELF
                                    2020-07-16 08:52:38.354  - info: mihome-vacuum.2 (24473) terminating
                                    2020-07-16 08:52:38.355  - info: mihome-vacuum.2 (24473) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2020-07-16 08:52:38.349  - info: host.iobroker stopInstance system.adapter.mihome-vacuum.2 send kill signal
                                    2020-07-16 08:52:38.365  - info: host.iobroker stopInstance system.adapter.mihome-vacuum.1 send kill signal
                                    2020-07-16 08:52:38.366  - info: host.iobroker stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                    2020-07-16 08:52:38.367  - info: mihome-vacuum.0 (24482) Got terminate signal TERMINATE_YOURSELF
                                    2020-07-16 08:52:38.371  - info: mihome-vacuum.1 (24480) Got terminate signal TERMINATE_YOURSELF
                                    2020-07-16 08:52:38.375  - info: mihome-vacuum.0 (24482) terminating
                                    2020-07-16 08:52:38.376  - info: mihome-vacuum.0 (24482) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2020-07-16 08:52:38.375  - info: mihome-vacuum.1 (24480) terminating
                                    2020-07-16 08:52:38.377  - info: mihome-vacuum.1 (24480) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2020-07-16 08:52:38.389  - info: host.iobroker iobroker upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
                                    2020-07-16 08:52:38.444  - info: host.iobroker iobroker upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
                                    2020-07-16 08:52:38.499  - info: host.iobroker iobroker upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
                                    2020-07-16 08:52:38.553  - info: host.iobroker iobroker upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
                                    2020-07-16 08:52:38.607  - info: host.iobroker iobroker upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
                                    2020-07-16 08:52:38.661  - info: host.iobroker iobroker Adapter "mihome-vacuum" updated
                                    2020-07-16 08:52:41.334  - warn: host.iobroker instance system.adapter.mihome-vacuum.3 still running with pid 24467
                                    2020-07-16 08:52:41.365  - warn: host.iobroker instance system.adapter.mihome-vacuum.2 still running with pid 24473
                                    2020-07-16 08:52:41.366  - warn: host.iobroker instance system.adapter.mihome-vacuum.1 still running with pid 24480
                                    2020-07-16 08:52:41.367  - warn: host.iobroker instance system.adapter.mihome-vacuum.0 still running with pid 24482
                                    2020-07-16 08:52:41.437  - error: host.iobroker instance system.adapter.mihome-vacuum.3 terminated by request of the instance itself and will not be restarted, before user restarts it.
                                    2020-07-16 08:52:41.438  - info: host.iobroker Do not restart adapter system.adapter.mihome-vacuum.3 because desired by instance
                                    2020-07-16 08:52:41.443  - error: host.iobroker instance system.adapter.mihome-vacuum.2 terminated by request of the instance itself and will not be restarted, before user restarts it.
                                    2020-07-16 08:52:41.444  - info: host.iobroker Do not restart adapter system.adapter.mihome-vacuum.2 because desired by instance
                                    2020-07-16 08:52:41.445  - error: host.iobroker instance system.adapter.mihome-vacuum.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                                    2020-07-16 08:52:41.445  - info: host.iobroker Do not restart adapter system.adapter.mihome-vacuum.0 because desired by instance
                                    2020-07-16 08:52:41.455  - error: host.iobroker instance system.adapter.mihome-vacuum.1 terminated by request of the instance itself and will not be restarted, before user restarts it.
                                    2020-07-16 08:52:41.456  - info: host.iobroker Do not restart adapter system.adapter.mihome-vacuum.1 because desired by instance
                                    2020-07-16 08:56:48.862  - info: host.iobroker "system.adapter.mihome-vacuum.0" disabled
                                    2020-07-16 08:56:48.906  - info: host.iobroker "system.adapter.mihome-vacuum.1" disabled
                                    2020-07-16 08:57:01.893  - info: host.iobroker "system.adapter.mihome-vacuum.2" disabled
                                    2020-07-16 08:57:01.952  - info: host.iobroker "system.adapter.mihome-vacuum.3" disabled
                                    2020-07-16 08:57:06.904  - info: host.iobroker "system.adapter.mihome-vacuum.0" enabled
                                    2020-07-16 08:57:06.975  - info: host.iobroker instance system.adapter.mihome-vacuum.0 started with pid 22812
                                    2020-07-16 08:57:08.206  - info: mihome-vacuum.0 (22812) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.18.2, js-controller: 3.1.6
                                    2020-07-16 08:57:08.816  - info: mihome-vacuum.0 (22812) Expert mode enabled, states created
                                    2020-07-16 08:57:08.817  - info: mihome-vacuum.0 (22812) Cloud control disabled
                                    2020-07-16 08:57:08.859  - info: mihome-vacuum.0 (22812) change states from State control.fan_power
                                    2020-07-16 08:57:08.860  - info: mihome-vacuum.0 (22812) extend state mop for State control.fan_power
                                    2020-07-16 08:57:08.871  - warn: mihome-vacuum.0 (22812) Time difference between Mihome Vacuum and ioBroker: 12 sec
                                    2020-07-16 08:57:08.871  - info: mihome-vacuum.0 (22812) connecting, this can take up to 10 minutes ...
                                    2020-07-16 08:57:08.951  - info: mihome-vacuum.0 (22812) Connected
                                    2020-07-16 08:57:09.918  - info: mihome-vacuum.0 (22812) set nächster Timer: Nicht verfügbar
                                    2020-07-16 08:57:09.969  - info: mihome-vacuum.0 (22812) create state for carpet_mode
                                    2020-07-16 08:57:10.300  - info: host.iobroker "system.adapter.mihome-vacuum.1" enabled
                                    2020-07-16 08:57:10.317  - info: host.iobroker instance system.adapter.mihome-vacuum.1 started with pid 22827
                                    2020-07-16 08:57:11.218  - info: mihome-vacuum.1 (22827) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.18.2, js-controller: 3.1.6
                                    2020-07-16 08:57:11.267  - info: mihome-vacuum.1 (22827) Expert mode enabled, states created
                                    2020-07-16 08:57:11.268  - info: mihome-vacuum.1 (22827) Cloud control disabled
                                    2020-07-16 08:57:11.292  - info: mihome-vacuum.1 (22827) change states from State control.fan_power
                                    2020-07-16 08:57:11.292  - info: mihome-vacuum.1 (22827) extend state mop for State control.fan_power
                                    2020-07-16 08:57:11.293  - info: mihome-vacuum.1 (22827) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
                                    2020-07-16 08:57:11.309  - warn: mihome-vacuum.1 (22827) Time difference between Mihome Vacuum and ioBroker: 11 sec
                                    2020-07-16 08:57:11.310  - info: mihome-vacuum.1 (22827) connecting, this can take up to 10 minutes ...
                                    2020-07-16 08:57:11.387  - info: mihome-vacuum.1 (22827) Connected
                                    2020-07-16 08:57:11.460  - info: host.iobroker "system.adapter.mihome-vacuum.2" enabled
                                    2020-07-16 08:57:11.487  - info: host.iobroker instance system.adapter.mihome-vacuum.2 started with pid 22842
                                    2020-07-16 08:57:12.243  - info: host.iobroker "system.adapter.mihome-vacuum.3" enabled
                                    2020-07-16 08:57:12.284  - info: host.iobroker instance system.adapter.mihome-vacuum.3 started with pid 22853
                                    2020-07-16 08:57:12.418  - info: mihome-vacuum.1 (22827) set nächster Timer: Nicht verfügbar
                                    2020-07-16 08:57:12.420  - info: mihome-vacuum.1 (22827) create state for carpet_mode
                                    2020-07-16 08:57:12.479  - info: mihome-vacuum.2 (22842) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.18.2, js-controller: 3.1.6
                                    2020-07-16 08:57:12.545  - info: mihome-vacuum.2 (22842) Expert mode enabled, states created
                                    2020-07-16 08:57:12.546  - info: mihome-vacuum.2 (22842) Cloud control disabled
                                    2020-07-16 08:57:12.576  - info: mihome-vacuum.2 (22842) change states from State control.fan_power
                                    2020-07-16 08:57:12.576  - info: mihome-vacuum.2 (22842) extend state mop for State control.fan_power
                                    2020-07-16 08:57:12.577  - info: mihome-vacuum.2 (22842) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
                                    2020-07-16 08:57:12.641  - warn: mihome-vacuum.2 (22842) Time difference between Mihome Vacuum and ioBroker: 12 sec
                                    2020-07-16 08:57:12.642  - info: mihome-vacuum.2 (22842) connecting, this can take up to 10 minutes ...
                                    2020-07-16 08:57:12.657  - info: mihome-vacuum.2 (22842) Connected
                                    2020-07-16 08:57:13.382  - info: mihome-vacuum.3 (22853) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.18.2, js-controller: 3.1.6
                                    2020-07-16 08:57:13.503  - info: mihome-vacuum.3 (22853) Expert mode enabled, states created
                                    2020-07-16 08:57:13.504  - info: mihome-vacuum.3 (22853) Cloud control disabled
                                    2020-07-16 08:57:13.538  - info: mihome-vacuum.3 (22853) change states from State control.fan_power
                                    2020-07-16 08:57:13.538  - info: mihome-vacuum.3 (22853) extend state mop for State control.fan_power
                                    2020-07-16 08:57:13.539  - info: mihome-vacuum.3 (22853) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
                                    2020-07-16 08:57:13.548  - warn: mihome-vacuum.3 (22853) Time difference between Mihome Vacuum and ioBroker: 11 sec
                                    2020-07-16 08:57:13.549  - info: mihome-vacuum.3 (22853) connecting, this can take up to 10 minutes ...
                                    2020-07-16 08:57:13.587  - info: mihome-vacuum.3 (22853) Connected
                                    2020-07-16 08:57:13.664  - info: mihome-vacuum.2 (22842) create state for carpet_mode
                                    2020-07-16 08:57:13.889  - info: mihome-vacuum.2 (22842) set nächster Timer: Nicht verfügbar
                                    2020-07-16 08:57:14.597  - info: mihome-vacuum.3 (22853) create state for carpet_mode
                                    2020-07-16 08:57:14.742  - info: mihome-vacuum.3 (22853) set nächster Timer: Nicht verfügbar
                                    2020-07-16 08:57:31.336  - info: mihome-vacuum.1 (22827) create states for water box
                                    2020-07-16 08:57:31.338  - info: mihome-vacuum.1 (22827) create states for water box filter
                                    2020-07-16 08:57:32.562  - info: mihome-vacuum.2 (22842) create states for water box
                                    2020-07-16 08:57:32.563  - info: mihome-vacuum.2 (22842) create states for water box filter
                                    2020-07-16 08:57:33.522  - info: mihome-vacuum.3 (22853) create states for water box
                                    2020-07-16 08:57:33.523  - info: mihome-vacuum.3 (22853) create states for water box filter
                                    2020-07-16 08:57:54.167  - info: mihome-vacuum.1 (22827) trigger cleaning all
                                    2020-07-16 09:00:00.381  - info: mihome-vacuum.0 (22812) trigger cleaning all
                                    Die Karte wird aktualisiert, sonst keine Anomalien festgestellt. ( hab das log auch nur auf info stehen)
                                      Sneaker75 last edited by
                                      Funktioniert bei jemandem der Datenpunkt water_box (Wischeinheit installiert) unter info? Der steht bei mir immer auf false - egal, ob die Wischeinheit eingeklickt ist oder nicht.
                                      Habe einen S5 mit Firmware 3.5.7_002008
                                      Meistertr TTBerlin 2 Replies Last reply Reply Quote 0
                                      • Meistertr
                                        Meistertr Developer @Sneaker75 last edited by
                                        @Sneaker75 hat der s5 nicht
                                          backfisch88 last edited by backfisch88
                                          2.1.1 mit neuster Firmware läuft perfekt. Beide Stockwerke gesaugt. Keine Fehler im log(s6)
                                          Sehr geil. Danke!
                                          Konnte mittlerweile einer herausfinden wie man über einen command die maps wiederherstellt? Bzw. die andere oder 2. map?
                                          geht aber seit dem multifloor nicht mehr
                                          • Bluefox
                                            Bluefox @Diginix last edited by
                                            @Diginix ganze Dankbarkeit würde ich an Meister richten. Ich habe nur kaputt gemacht...
                                            ? D 2 Replies Last reply Reply Quote 0
                                            1.0k
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            466535
