    4. (Alexa Adapter) Cannot find module 'https-proxy-agent'
    UNSOLVED (Alexa Adapter) Cannot find module 'https-proxy-agent'
    • moelski
      moelski last edited by
      Ja ist sauber installiert.
      Hat ja bis vor dem Update alles sauber gelaufen.
        Thomas Braun Most Active @moelski last edited by Thomas Braun
        @moelski
        Das es bislang lief heißt ja nix.
        Bei mir schaut das so aus:
        pi@raspberrypi:~$ cd /opt/iobroker/
        pi@raspberrypi:/opt/iobroker$ npm list http-proxy-agent
        iobroker.inst@2.0.3 /opt/iobroker
        ├─┬ iobroker.alexa2@3.2.8
        │ └─┬ virtual-device-sdk@1.7.3
        │   └── http-proxy-agent@4.0.1
        └─┬ iobroker.nuki-extended@2.2.6
          └─┬ npm@6.14.6
            └─┬ npm-registry-fetch@4.0.5
              └─┬ make-fetch-happen@5.0.2
                └── http-proxy-agent@2.1.0
        Was liefert denn
        which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
        Unabhängig vom Ergebnis würde ich auf node12 updaten.
          Chrischo last edited by
          bei mir erscheinen die gleichen Fehlermeldungen seit dem Update auf 3.2.8.
          host.raspberrypi	2020-07-17 13:46:15.780	error	instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.raspberrypi	2020-07-17 13:46:15.779	error	Caught by controller[0]: }
          host.raspberrypi	2020-07-17 13:46:15.779	error	Caught by controller[0]: ]
          host.raspberrypi	2020-07-17 13:46:15.779	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.alexa2/main.js'
          host.raspberrypi	2020-07-17 13:46:15.778	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-device-sdk/lib/src/Index.js',
          host.raspberrypi	2020-07-17 13:46:15.778	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-device-sdk/lib/src/VirtualDevice.js',
          host.raspberrypi	2020-07-17 13:46:15.778	error	Caught by controller[0]: requireStack: [
          host.raspberrypi	2020-07-17 13:46:15.778	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
          host.raspberrypi	2020-07-17 13:46:15.778	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19) {
          host.raspberrypi	2020-07-17 13:46:15.777	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
          host.raspberrypi	2020-07-17 13:46:15.777	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
          host.raspberrypi	2020-07-17 13:46:15.777	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
          host.raspberrypi	2020-07-17 13:46:15.777	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
          host.raspberrypi	2020-07-17 13:46:15.776	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-device-sdk/lib/src/VirtualDevice.js:41:23)
          host.raspberrypi	2020-07-17 13:46:15.776	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
          host.raspberrypi	2020-07-17 13:46:15.776	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
          host.raspberrypi	2020-07-17 13:46:15.776	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:842:27)
          host.raspberrypi	2020-07-17 13:46:15.775	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:966:15)
          host.raspberrypi	2020-07-17 13:46:15.775	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.alexa2/main.js
          host.raspberrypi	2020-07-17 13:46:15.775	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-device-sdk/lib/src/Index.js
          host.raspberrypi	2020-07-17 13:46:15.775	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-device-sdk/lib/src/VirtualDevice.js
          host.raspberrypi	2020-07-17 13:46:15.774	error	Caught by controller[0]: Require stack:
          host.raspberrypi	2020-07-17 13:46:15.774	error	Caught by controller[0]: Error: Cannot find module 'https-proxy-agent'
          host.raspberrypi	2020-07-17 13:46:15.774	error	Caught by controller[0]: ^
          host.raspberrypi	2020-07-17 13:46:15.773	error	Caught by controller[0]: throw err;
          host.raspberrypi	2020-07-17 13:46:15.773	error	Caught by controller[0]: internal/modules/cjs/loader.js:969
          pi@raspberrypi:~ $ cd /opt/iobroker/
          pi@raspberrypi:/opt/iobroker $ npm list http-proxy-agent
          ├─┬ iobroker.unifi@0.5.5
          │ └─┬ node-unifi@1.3.3
          │   └─┬ snyk@1.346.0
          │     └─┬ proxy-agent@3.1.1
          │       ├── http-proxy-agent@2.1.0
          │       └─┬ pac-proxy-agent@3.0.1
          │         └── http-proxy-agent@2.1.0
          └─┬ iobroker.vis-weather@2.5.2
            └─┬ npm@6.14.5
              └─┬ npm-registry-fetch@4.0.4
          /usr/bin/nodejs
          v12.18.2
          /usr/bin/node
          v12.18.2
          /usr/bin/npm
          6.14.5
          nodejs:
            Installed: 12.18.2-1nodesource1
            Candidate: 12.18.2-1nodesource1
            Version table:
           *** 12.18.2-1nodesource1 500
                  500 https://deb.nodesource.com/node_12.x buster/main arm64 Packages
                  100 /var/lib/dpkg/status
               10.21.0~dfsg-1~deb10u1 500
                  500 http://deb.debian.org/debian-security buster/updates/main arm64 Packages
               10.19.0~dfsg1-1 500
                  500 http://deb.debian.org/debian buster/main arm64 Packages
          Der Alexa Adapter lässt sich auch nicht mehr starten.
          Selbst bei einem Downgrade auf die ältere und zuvor funktionierende Version funktioniert nicht mehr und es kommen die gleichen Fehlermeldungen.
          Interessanter Weise hat das Update auf einem zweiten Raspi mit nahezu den gleichen Adaptern problemlos funktioniert. Beide Raspis sind aktuell.
          Vielleicht kann jemand helfen?
          Vielen Dank
            Bibo*13 last edited by
            ich habe das gleiche Problem, nach Upgarde auf 3.2.8 startet die Instance nicht mehr.
            Gibt es da mittlerweile etwas Neues?
              Jan1 last edited by Jan1
              bei mir läuft es ohne Probleme, aber meine Ausgabe zu dem angemeckerten Modul sieht so aus:
              jan@Beelink:/opt/iobroker$ npm list http-proxy-agent
              └── (empty)
              Das ist bei mir gar nicht vorhanden, wobei ich es manuell finden kann:
              • moelski
                Ok hier die Ausgaben von ...
                /usr/bin/nodejs
                v10.20.1
                /usr/bin/node
                v10.20.1
                /usr/bin/npm
                6.14.4
                nodejs:
                  Installed: 10.20.1-1nodesource1
                  Candidate: 10.20.1-1nodesource1
                  Version table:
                 *** 10.20.1-1nodesource1 500
                        500 https://deb.nodesource.com/node_10.x stretch/main amd64 Packages
                     4.8.2~dfsg-1 500
                        500 http://ftp.de.debian.org/debian stretch/main amd64 Packages
                Und hier noch die Ausgabe von dem npm Aufruf:
                dominik@SHome-IoBroker:~$ cd /opt/iobroker/
                dominik@SHome-IoBroker:/opt/iobroker$ npm list http-proxy-agent
                [sudo] password for dominik:
                └─┬ iobroker.alexa2@3.2.8
                Grüße Dominik
                  @moelski
                  Wenn beim Aufruf von npm im Verzeichnis /opt/iobroker nach dem sudo Passwort gefragt wird dürfte da irgendwas mit den Rechten für die User nicht stimmen.
                  Jag mal den
                  iobroker fix
                  durch.
                  Und ich würde an deiner Stelle den Absprung von Stretch planen. Je länger du das rauszögerst, umso komplizierter kann das werden.
                  • moelski
                    Moin !
                    fix durchgeführt:
                        Checking ioBroker user and directory permissions (2/3)
                    Created /etc/sudoers.d/iobroker
                    Fixing directory permissions...
                        Checking autostart (3/3)
                    Enabling autostart...
                    Autostart enabled!
                        Your installation was fixed successfully
                        Run iobroker start to start ioBroker again!
                    dominik@SHome-IoBroker:/opt/iobroker$ iobroker start
                    dominik@SHome-IoBroker:/opt/iobroker$ iobroker fix^C
                    Aber der Fehler mit dem Alexa bleibt leider immer noch.
                    Stretch Update ... Hmm, ok da müsste ich dann wohl demnächst mal ran ...
                      mrzee last edited by
                      Bei mir ist es das gleiche.
                      System ist jedoch Ubuntu - nach dem letzten Update bekomme ich die gleichen Fehlermeldungen und stelle fest, dass der Pfad, auf den das Log verweist, gar nicht existiert.
                      Gleichmaßen kann ich den http-proxy-agent aber auch nicht neuinstallieren.
                        Thomas Braun Most Active @mrzee last edited by
                        @mrzee Für Ubuntu gelten die gleichen Anmerkungen zu nodejs wie zu Debian.
                          mrzee @Thomas Braun last edited by mrzee
                          @Thomas-Braun
                          Danke - ich komme mit den ganzen Distris immer durcheinander. Ich habe das Problem aber gefunden:
                          Scheinbar wurde bei einem Update, entweder Adapter oder OS, das Verzeichnis /opt/iobroker/node_modules/https-proxy-agent wie auch immer beschädigt. Eine manuelle Neuinstallation via NPM hat funktioniert und der Adapter läuft wieder.
                            Hi wunderbar das das Problem gefunden wurde.
                            Leider bin ich etwas unbedart und weiß nicht wie ich den fehlenden http-proxy-agent fixen soll.
                            Kann mir bitte jemand da auf die Sprünge helfen.
                              Würde mich auch interessieren. Habe den fixer laufen lassen - hat aber nicht geholfen. Habe die Instanz und den kompletten Adapter deinstalliert und anschließend neu installiert - leider auch keine Besserung. Das ist aber wirklich sehr ärgerlich.
                                Dabei bleibt´s dann stehen und der Adapter startet nicht.
                                  Thomas Braun Most Active @Chrischo last edited by
                                  @Chrischo Und was sagt das Log? Und ist nodejs sauber?
                                    Chrischo @Thomas Braun last edited by
                                    @Thomas-Braun
                                    nicht viel Neues 😞
                                    host.raspberrypi	2020-07-19 14:20:20.839	error	instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    host.raspberrypi	2020-07-19 14:20:20.839	error	Caught by controller[0]: }
                                    host.raspberrypi	2020-07-19 14:20:20.838	error	Caught by controller[0]: ]
                                    host.raspberrypi	2020-07-19 14:20:20.838	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.alexa2/main.js'
                                    host.raspberrypi	2020-07-19 14:20:20.838	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-device-sdk/lib/src/Index.js',
                                    host.raspberrypi	2020-07-19 14:20:20.838	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-device-sdk/lib/src/VirtualDevice.js',
                                    host.raspberrypi	2020-07-19 14:20:20.838	error	Caught by controller[0]: requireStack: [
                                    host.raspberrypi	2020-07-19 14:20:20.838	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                    host.raspberrypi	2020-07-19 14:20:20.837	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19) {
                                    host.raspberrypi	2020-07-19 14:20:20.837	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
                                    host.raspberrypi	2020-07-19 14:20:20.837	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
                                    host.raspberrypi	2020-07-19 14:20:20.837	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
                                    host.raspberrypi	2020-07-19 14:20:20.837	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
                                    host.raspberrypi	2020-07-19 14:20:20.836	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-device-sdk/lib/src/VirtualDevice.js:41:23)
                                    host.raspberrypi	2020-07-19 14:20:20.836	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
                                    host.raspberrypi	2020-07-19 14:20:20.836	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
                                    host.raspberrypi	2020-07-19 14:20:20.836	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:842:27)
                                    host.raspberrypi	2020-07-19 14:20:20.836	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:966:15)
                                    host.raspberrypi	2020-07-19 14:20:20.835	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.alexa2/main.js
                                    host.raspberrypi	2020-07-19 14:20:20.835	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-device-sdk/lib/src/Index.js
                                    host.raspberrypi	2020-07-19 14:20:20.835	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-device-sdk/lib/src/VirtualDevice.js
                                    host.raspberrypi	2020-07-19 14:20:20.835	error	Caught by controller[0]: Require stack:
                                    host.raspberrypi	2020-07-19 14:20:20.835	error	Caught by controller[0]: Error: Cannot find module 'https-proxy-agent'
                                    host.raspberrypi	2020-07-19 14:20:20.835	error	Caught by controller[0]: ^
                                    host.raspberrypi	2020-07-19 14:20:20.834	error	Caught by controller[0]: throw err;
                                    host.raspberrypi	2020-07-19 14:20:20.834	error	Caught by controller[0]: internal/modules/cjs/loader.js:969
                                      @Chrischo nodejs sauber?
                                        @Thomas-Braun wie überprüfe ich die "Sauberkeit"?
                                        Augenscheinlich macht es keine Probleme.
                                          @Chrischo
                                            @Thomas-Braun
                                            pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                            /usr/bin/nodejs
                                            v12.18.2
                                            /usr/bin/node
                                            v12.18.2
                                            /usr/bin/npm
                                            6.14.5
                                            nodejs:
                                              Version table:
                                                 10.19.0~dfsg1-1 500
                                            Das hatte ich aber bereits weiter oben im Beitrag schon gepostet.
                                            alexa error https-proxy-agent
                                            3051
