    4. Beta-Test Android App ioGo 2.1.x
      e-s @Guest last edited by
      @nis
      Zeitangabe funktioniert, wenn man die app aber ärgert dann kann man diese abschießen.
      Wenn man 2l eingibt, meckert er ordnungsgemäß wegen falschem Zeichen.
      Gibt man aber 2m30s ein, wird die Eingabe übernommen aber die app crasht dauerhaft. Im log kann ich aber nichts sehen:
      08:33:00:542 D/StateFirebaseServiceImpl - 61: Service created
      08:33:00:556 D/EnumFirebaseServiceImpl - 54: Service created
      08:33:00:648 I/FirebaseService - 205: DeviceFirebaseServiceImpl successfully connected
      08:33:00:654 I/DeviceFirebaseServiceImpl - 73: buffer is empty
      08:33:00:657 I/FirebaseService - 205: StateFirebaseServiceImpl successfully connected
      08:33:00:662 I/FirebaseService - 205: EnumFirebaseServiceImpl successfully connected
      08:33:00:894 V/FCMService - 78:  onCreate called
      08:33:00:913 D/FCMService - 85: Message received
      08:33:01:744 I/DeviceFirebaseServiceImpl - 87: send device S105G
      08:33:14:240 D/StateFirebaseServiceImpl - 61: Service created
      08:33:14:253 D/EnumFirebaseServiceImpl - 54: Service created
      08:33:14:345 I/FirebaseService - 205: DeviceFirebaseServiceImpl successfully connected
      08:33:14:348 I/DeviceFirebaseServiceImpl - 73: buffer is empty
      08:33:14:353 I/FirebaseService - 205: StateFirebaseServiceImpl successfully connected
      08:33:14:357 I/FirebaseService - 205: EnumFirebaseServiceImpl successfully connected
      08:33:29:148 I/StateFirebaseServiceImpl - 117: send new value for 0_userdata.0.Funktionen.Warnungen.Shelly_Temperatur
      08:33:33:677 V/FCMService - 78:  onCreate called
      08:33:33:704 D/FCMService - 85: Message received
      08:33:33:742 D/FCMService - 85: Message received
      08:33:34:008 D/FCMService - 85: Message received
      08:33:36:333 D/StateFirebaseServiceImpl - 61: Service created
      08:33:36:346 D/EnumFirebaseServiceImpl - 54: Service created
      08:33:36:461 I/FirebaseService - 205: DeviceFirebaseServiceImpl successfully connected
      08:33:36:476 I/DeviceFirebaseServiceImpl - 73: buffer is empty
      08:33:36:479 I/FirebaseService - 205: StateFirebaseServiceImpl successfully connected
      08:33:36:484 I/FirebaseService - 205: EnumFirebaseServiceImpl successfully connected
      08:33:38:018 V/FCMService - 78:  onCreate called
      08:33:38:029 D/FCMService - 85: Message received
      08:33:38:834 I/DeviceFirebaseServiceImpl - 87: send device S105G
      08:33:41:630 D/FCMService - 85: Message received
      08:33:41:685 D/FCMService - 85: Message received
      08:33:41:721 D/FCMService - 85: Message received
      08:33:48:013 V/FCMService - 78:  onCreate called
      08:33:48:030 I/FirebaseService - 205: DeviceFirebaseServiceImpl successfully connected
      08:33:48:036 I/DeviceFirebaseServiceImpl - 73: buffer is empty
      08:33:48:053 D/FCMService - 85: Message received
      • Basti97
        Basti97 Most Active last edited by
        Wie funktioniert jetzt die GPS Anwesenheit genau. Muss ich nur die App und den Adapter installieren. Und dann wird wohl der GPS Standort geschickt. Wie funktioniert es außerhalb wenn ich nicht mehr Zuhause bin wie bekommt iobroker die GPS- Standort.
          A Former User @Basti97 last edited by
          @Basti97 sagte in Beta-Test Android App ioGo 2.1.x:
          Du benötigst die App und den Adapter mit einer Lizenz. Dann kannst du in der App mehrere Gebiete einrichten, also GPS Punkt mit Umkreis. Jedes Gebiet bekommt einen Namen. Die Gebiete werden in ioBroker synchronisiert und zudem ob sich das Smartphone in einem der Gebiete befindet.
          Der GPS Standort wird nicht von der App an ioBroker übermittelt. Nur die eingerichteten Gebiete mit Änderungen True/False bei betreten oder verlassen.
          Basti97 1 Reply Last reply Reply Quote 0
          • Basti97
            Basti97 Most Active @Guest last edited by
            @nis OK Danke das klingt interessant.
              crunchip Forum Testing Most Active @Guest last edited by
              @nis Nachrichten löschen funktioniert bei mir nach wie vor nicht.
              Bei mir ist 2d bei Push Nachrichten löschen hinterlegt, werden aber nicht gelöscht.
              Neuschwansteini 1 Reply Last reply Reply Quote 0
              • Neuschwansteini
                Neuschwansteini @crunchip last edited by
                @crunchip sagte in Beta-Test Android App ioGo 2.1.x:
                Richtig, habe gerade auch gesehen, dass die alten Nachrichten noch da sind... 2d habe ich auch stehen. Auch ein Ändern auf 5h brachte nichts.
                Übrigens, kann man, wenn Msgs selektiert sind, das an der Msg selbst sichtbar machen?
                Ich seh nicht, welche ausgewählt wurde, nur oben die Anzahl...
                  crunchip Forum Testing Most Active @Neuschwansteini last edited by crunchip
                  @ilovegym glaub die Zeit ändern, bei bestehenden Nachrichten, hat sowieso keinen Einfluss und gilt erst bei neu ankommenden Nachrichten, zwecks "Berechnung".
                  Eine "Markierung" wäre schön.
                  Gab es nicht mal einen Button, alle auf einmal, zu löschen?
                    e-s @crunchip last edited by
                    @crunchip @ilovegym
                    Verstehe euch nicht ganz. Automatisches löschen der Nachrichten gibt es nicht, nur das automatische ausblenden aus der statusleiste. Also macht da auch nur Minuten oder Stunden Sinn.
                    Alle Nachrichten löschen selbst klappt auch recht einfach, einfach auf eine Nachricht lange drücken, dann oben rechts die 2 Haken und den Papierkorb. Fertig.
                      crunchip Forum Testing Most Active @e-s last edited by
                      @e-s OK, das war das mit den Doppelhaken, eine anwählen, dann auf✓✓.
                      Ich dachte, das automatische löschen ist für den Nachrichtenordner gedacht, die pushMeldung kommt doch nur einmalig, Wisch ich die weg, ist se weg.
                        e-s @crunchip last edited by e-s
                        @crunchip
                        Das hatte ich damals angeregt, ich lasse mir per push die eingehenden Anrufe anzeigen. Das können manchmal sehr viele sein, deswegen lasse ich diese nach 1min wieder ausblenden, da nicht mehr relevant.
                        Meine Hoffnung war damals aber, die Zeit zur selbstauflösung mitsenden zu können um relevante Nachrichten länger in der leiste lassen zu können.
                        Ausserdem verschwindet diese eben nur beim wischen, nicht aber wenn man auf die Nachricht klickt um sie vollständig lesen zu können.
                          A Former User @e-s last edited by
                          @e-s sagte in Beta-Test Android App ioGo 2.1.x:
                          Das ist auch noch geplant
                            langesmann last edited by
                            Hallo
                            Ich versuche laufend einen neuen User in meinen Account einzubinden aber bei der Installation auf dem 2. Gerät soll ich mir weiterhin einen neuen Account zu legen.
                            Ich habe im Admin das Familien Abo aber bekomme keine Freigabe. Als Admin gehe ich auf add user, gebe dort den Namen und die Emailadresse an, dann auf Save aber nichts passiert.
                            Bitte melde dich mal
                              e-s @langesmann last edited by
                              @langesmann
                              Frag mal in discord nach.
                              31.7k
                              79.8k
                              android beta geofence iogo test
                              10
                              272
                              24002
