    4. Neuer Robonect HX Adapter
      Amokd0c last edited by Amokd0c
      Hallo! Hat der Adapter Probleme, wenn Sonderzeichen im Passwort enthalten sind?
      Ab und an bricht die Verbindung (noch) ab, hatte ihn aber testweise auch scho ins Wohnzimmer gestellt. Hier zeigt sich das gleiche Fehlerbild mit diesen Einträgen im Logfile:
      robonect.0 2020-06-18 13:55:19.735 info (2724) cleaned everything up...
      robonect.0 2020-06-18 13:55:19.733 error (2724) TypeError: Cannot read property 'status' of undefined at Robonect.<anonymous> (/opt/iobroker/node_modules/iobroker.robonect/main.js:295:42) at process._tickCallback (internal/process/ne
      robonect.0 2020-06-18 13:55:19.732 error (2724) unhandled promise rejection: Cannot read property 'status' of undefined
      robonect.0 2020-06-18 13:55:19.731 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      robonect.0 2020-06-18 13:55:19.727 error (2724) Error: Bad response: {"statusCode":401,"body":"","headers":{"content-type":"text/html","server":"FHDR","connection":"close","content-length":"0","cache-control":"no-cache","www-authenticate":"B
      robonect.0 2020-06-18 13:55:19.460 info (2724) Done
      robonect.0 2020-06-18 13:55:16.747 info (2724) Rest period 2 not configured. Period will be ignored.
      robonect.0 2020-06-18 13:55:16.745 info (2724) Rest period 1 not configured. Period will be ignored.
      robonect.0 2020-06-18 13:55:16.682 info (2724) starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.robonect, node: v10.20.1, js-controller: 3.1.5
      robonect.0 2020-06-18 11:54:43.232 info (2687) Terminated (NO_ERROR): Without reason
      robonect.0 2020-06-18 11:54:43.230 info (2687) terminating
      robonect.0 2020-06-18 11:54:43.213 info (2687) cleaned everything up...
      robonect.0 2020-06-18 11:54:43.211 error at process._tickCallback (internal/process/next_tick.js:68:7)
      robonect.0 2020-06-18 11:54:43.211 error at Robonect.<anonymous> (/opt/iobroker/node_modules/iobroker.robonect/main.js:295:42)
      robonect.0 2020-06-18 11:54:43.211 error (2687) TypeError: Cannot read property 'status' of undefined
      robonect.0 2020-06-18 11:54:43.210 error (2687) unhandled promise rejection: Cannot read property 'status' of undefined
      robonect.0 2020-06-18 11:54:43.205 error (2687) Error: Bad response: {"statusCode":401,"body":"","headers":{"content-type":"text/html","server":"FHDR","connection":"close","content-length":"0","cache-control":"no-cache","www-authenticate":"
      In den Einstellungen sind lediglich IP Adresse, Benutzername und Kennwort gesetzt.
      Vielen Dank!
        lonsimbt @Amokd0c last edited by
        @braindead
        Bei mir wirft der robonoct-Adapter (v0.1.3) auch neuerdings Fehler:
        robonect.0	2020-06-24 11:16:24.381	error	(4516) TypeError: Cannot read property 'status' of undefined at Robonect.<anonymous> (/opt/iobroker/node_modules/iobroker.robonect/main.js:295:42) at runMicrotasks (<anonymous>) at process
        robonect.0	2020-06-24 11:16:24.381	error	(4516) unhandled promise rejection: Cannot read property 'status' of undefined
        robonect.0	2020-06-24 11:16:24.380	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        robonect.0	2020-06-24 11:16:24.379	error	(4516) Error: Error: socket hang up
        Mein System:
        iobroker unter proxmox in Debian 10 Container
        Node.js v12.18.1
        js-controller v3.1.6
        Robonet FW v1.1b
        Gruß Marco
        braindead 1 Reply Last reply Reply Quote 0
        • braindead
          braindead Developer @lonsimbt last edited by
          @lonsimbt Der Fehler wird geworfen, weil die Antwort der Robonect API nicht dem entspricht, was der Adapter erwartet. Kannst Du irgendwie nachvollziehen, was der Mäher im Moment des Fehlers macht? Hat er evtl. keine gescheite WLAN Verbindung? Kommst Du zu diesem Zeitpunkt auf das Robonect Webinterface? Was heißt neuerdings? Hast Du irgendetwas verändert?
          Ich kann den Code so anpassen, dass eine andere Fehlermeldung geschmissen wird, das behebt das eigentliche Problem aber nicht.
            lonsimbt @braindead last edited by
            @braindead
            Die Fehlermeldungen kamen durchaus in einer Phase als es offensichtlich auch Verbindungsprobleme gab (auch wenn unser Garten nicht riesig ist). Diese Form von Fehlermeldungen habe ich aber bislang nicht beobachtet und sie ist auch in den LOGS der letzten fünf Tage nicht zu finden. Regelmäßig sehe ich folgendes im LOG
            robonect.0	2020-06-24 13:47:36.863	error	(5622) No connection to lawn mower. Check network connection.
            Ich habe keine Änderungen am Mähroboter oder dem Netzwerk vorgenommen, höchstens iobroker nebst Adapter auf den aktuellen Stand gebracht.
            Wenn klar ist woher der Fehler kommt, erscheint es mir sinnvoll, ihn abzufangen und eine aussagekräftige Fehlermeldung im LOG auszugeben.
            Gruß Marco
              klassisch Most Active @lonsimbt last edited by
              @lonsimbt sagte in Neuer Robonect HX Adapter:
              Disclaimer: Habe selbst noch keine Robonect Karte, weil noch Garantie auf den Mäher. Ist aber für die nächste Saison in Planung. Hab aber schon etliche Erfahrung mit den ESPs
              Klingt recht eindeutig nach Netzwerkproblemen
              Da reicht u.U. ein Nachbar der auf- oder umgerüstet hat und Frequenzen belegt, so daß Dein Router ausweicht. Oder der Router weicht nicht aus, aber die Ecke im Garten wird auch vom Nachbarn befeuert. Oder der Router wurde etwas verrückt. Oder irgendwo auf dem Funkweg ein leitfäiger Gegenstand eingebracht. Oder der ESP ist etwas verrutscht oder, oder oder... Funk hat halt so seine Eigenschaften
              Eigentlich kling die Fehlermeldung klar. Ich persönlich würde versuchen rauszufinden, an welcher Stelle das gehäuft passiert und versuchen, das funkschwache Gebiet mit einem Access-Point zu befeuern. Oder eine gute Antenne an den ESP frickeln. Aber das ist nicht Jedermanns Sache.
                lonsimbt @klassisch last edited by
                @klassisch sagte in Neuer Robonect HX Adapter:
                Sorry, der Bezug zu der aus meiner Sicht problematischen Fehlermeldung:
                war verloren gegangen. Die Meldung "No connection to lawn mower" ist aus meiner Sicht natürlich auch selbsterklärend.
                Mit gelegentlichen Verbindungsabbüchen kann ich leben und bislang hat unser Mähroboter sich dann auch immer wieder gemeldet.
                Gruß Marco
                  darkiop Most Active last edited by
                  Die finale 1.2 der Robonect Firmware ist seit dem 14.7. verfügbar:
                  https://robonect.de/viewtopic.php?f=39&t=3410
                  • braindead
                    braindead Developer @darkiop last edited by
                    @darkiop Danke für den Hinweis. Hast Du die Firmware schon installiert? Funktioniert sie grundsätzlich mit dem Adapter oder besteht dringender Handlungsbedarf? Im Changelog habe ich nichts gefunden, was auf ein mögliches Problem hinweisen würde.
                    L D 2 3 Replies Last reply Reply Quote 0
                      @braindead sagte in Neuer Robonect HX Adapter:
                      Ist hier seit einigen Tagen installiert und läuft unauffällig und ohne Probleme.
                      Gruß Marco
                        darkiop Most Active @braindead last edited by
                        @braindead Werd sie heut Abend drauf schieben.
                        • 2
                          2hot4you @braindead last edited by
                          Bei mir läuft es mit der Firmware 1.2 bisher auch unauffällig
                            fritz0815 last edited by fritz0815
                            meine WLAN Abdeckung ist nicht perfekt. Deswegen bekomme ich von Zeit zu Zeit "No connection to lawn mower", den ich ignoriere.
                            Manchmal erhalte ich aber zusätzlich eine Menge anderer Fehler und der Adapter crashed und wird neu gestartet. Ich habe Robonect FW 1.2 und Adapter 0.1.3
                            Gibt es dafür einen Fix oder Workaround?
                            Vielen Dank - Markus
                            2020-08-02 14:36:01.090 - error: robonect.0 (5567) No connection to lawn mower. Check network connection.
                            2020-08-02 14:37:07.996 - error: robonect.0 (5567) Error: CMD failed
                            2020-08-02 14:40:01.159 - error: robonect.0 (5567) No connection to lawn mower. Check network connection.
                            2020-08-02 14:44:31.489 - error: robonect.0 (5567) Error: Error: connect ETIMEDOUT 192.168.171.67:80
                            2020-08-02 14:44:31.494 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2020-08-02 14:44:31.494 - error: robonect.0 (5567) unhandled promise rejection: Cannot read property 'status' of undefined
                            2020-08-02 14:44:31.496 - error: robonect.0 (5567) TypeError: Cannot read property 'status' of undefined
                            • braindead
                              braindead Developer @fritz0815 last edited by
                              @fritz0815
                              Bevor der Adapter die Abfragen startet, schickt er einen Ping an den Mäher. Bekommt er keine Antwort, dann erscheint die Meldung "No connection to lawn mower" im Log. Bekommt er hingegen eine Antwort, dann schickt er nacheinander die Abfragen los. Hat Dein Mäher zwischenzeitlich kein WLAN mehr, kommt es zu den beschriebenen Fehlern.
                              Ich habe dazu einen GitHub Issue aufgemacht und werde mir das angucken.
                                fritz0815 @braindead last edited by fritz0815
                                @braindead Vielen Dank erst mal! Dummerweise habe ich nicht die vorangegangenen Meldungen geschickt. Ich habe oben den Log korrigiert. Manchmal bekomme ich aber auch die folgenden Meldungen:
                                2020-08-03 17:10:30.993 - info: host.usv Restart adapter system.adapter.robonect.0 because enabled
                                2020-08-03 17:11:01.075 - info: host.usv instance system.adapter.robonect.0 started with pid 9916
                                2020-08-03 17:11:03.113 - warn: robonect.0 (9916) Rest period 1 configured (20:00 - 08:00). Only API call /json?cmd=status will be done.
                                2020-08-03 17:11:14.296 - error: robonect.0 (9916) Error: Error: socket hang up
                                2020-08-03 17:11:14.367 - error: robonect.0 (9916) Error: Error: socket hang up
                                2020-08-03 17:11:14.403 - error: robonect.0 (9916) Error: Error: socket hang up
                                2020-08-03 17:11:14.431 - error: robonect.0 (9916) Error: Error: socket hang up
                                2020-08-03 17:11:14.470 - error: robonect.0 (9916) Error: Error: socket hang up
                                2020-08-03 17:11:14.532 - error: robonect.0 (9916) Error: Error: socket hang up
                                2020-08-03 17:11:14.563 - error: robonect.0 (9916) Error: Error: socket hang up
                                2020-08-03 17:11:14.590 - error: robonect.0 (9916) Error: Error: socket hang up
                                2020-08-03 17:13:10.002 - error: robonect.0 (9916) Error: Error: socket hang up
                                2020-08-03 17:13:10.011 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                2020-08-03 17:13:10.013 - error: robonect.0 (9916) unhandled promise rejection: Cannot read property 'status' of undefined
                                2020-08-03 17:13:10.016 - error: robonect.0 (9916) TypeError: Cannot read property 'status' of undefined
                                at Robonect. (/opt/iobroker/node_modules/iobroker.robonect/main.js:295:42)
                                at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                2020-08-03 17:13:10.609 - info: host.usv instance system.adapter.robonect.0 terminated with code 0 (NO_ERROR)
                                2020-08-03 17:13:10.614 - info: host.usv Restart adapter system.adapter.robonect.0 because enabled
                                • braindead
                                  @fritz0815 Danke. Da steht es ja noch viel eindeutiger: socket hang up. Ändert nichts daran, dass ich das abfangen sollte. 🙂
                                    Aiouh @stephan2k last edited by
                                    Hallo, ich habe mit Begeisterung mein Robonect im AM310installiert. Läuft auf Anhieb. (Firmware 1.2)
                                    Leider bekomme ich den Robonect NICHT verbunden obwohl das ja nicht DIE Herausforderung sein sollte :(. Benutzername / Kennwort schon mehrfach geprüft.
                                    robonect.0	2020-08-16 10:17:26.482	info	(17809) starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.robonect, node: v10.19.0, js-controller: 3.1.6
                                    robonect.0	2020-08-16 10:16:52.074	info	(17786) Terminated (NO_ERROR): Without reason
                                    robonect.0	2020-08-16 10:16:52.073	info	(17786) terminating
                                    robonect.0	2020-08-16 10:16:52.006	info	(17786) cleaned everything up...
                                    robonect.0	2020-08-16 10:16:52.005	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                                    robonect.0	2020-08-16 10:16:52.005	error	at Robonect.<anonymous> (/opt/iobroker/node_modules/iobroker.robonect/main.js:295:42)
                                    robonect.0	2020-08-16 10:16:52.005	error	(17786) TypeError: Cannot read property 'status' of undefined
                                    robonect.0	2020-08-16 10:16:52.005	error	(17786) unhandled promise rejection: Cannot read property 'status' of undefined
                                    robonect.0	2020-08-16 10:16:51.986	error	(17786) Error: Error: getaddrinfo ENOTFOUND top top:80
                                    robonect.0	2020-08-16 10:16:51.862	info	(17786) Done
                                    robonect.0	2020-08-16 10:16:27.466	warn	(17786) Rest period 2 configured (11:30 - 14:00). Only API call /json?cmd=status will be done.
                                    robonect.0	2020-08-16 10:16:27.460	warn	(17786) Rest period 1 configured (21:00 - 06:00). Only API call /json?cmd=status will be done.
                                    robonect.0	2020-08-16 10:16:27.365	info	(17786) starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.robonect, node: v10.19.0, js-controller: 3.1.6
                                    Beim MQTT Adapter klappt alles problemlos, nur liefert der noch zu wenig Werte..
                                    Wo kann ich suchen, was mach ich falsch ? Bin für Hilfe dankbar.
                                    • braindead
                                      braindead Developer @Aiouh last edited by
                                      @Aiouh getaddrinfo ENOTFOUND lässt darauf schließen, dass die IP Adresse nicht stimmt. Da darfst hier wirklich nur die IP ohne Protokoll und Port etc. eingeben.
                                        Aiouh @braindead last edited by Aiouh
                                        @braindead Hi, die IP stimmt und ist ohne port eingetragen
                                        Im debug log steht auch nichts Erhellendes 😞
                                          Malz1902 last edited by
                                          Hab meinem Robonect mal ne neue Antenne gegönnt, seid dem keine Timeouts mehr im gleichen Garten, also scheint die Antenne vom Robonect nicht so toll zu sein
                                            Aiouh @Malz1902 last edited by Aiouh
                                            @Malz1902 Ich hab ja ne gute Verbindung (dank vier verteilter Fritzboxen auf dem Grundstück...). Sowohl zum originalen WebUI als auch MQTT, nur nicht zum Robonect Adapter - der aber eben die Werte liefert die ich brauche.
                                            gardena garten husqvarna mähroboter robonect
                                            58
                                            467
                                            102473
