    4. JavaScript
    5. [Vorlage] Flexibles Timerskript + Vis
      Aachen1305 @deta last edited by
      @deta sagte in [Vorlage] Flexibles Timerskript + Vis:
      @Aachen1305 bei mir gehts
      Welche Version hast Du installiert? Bei mir läuft die V2.1.4
        Aachen1305 last edited by Aachen1305
        Hier noch die Log Datei
        code_text
        5.7.2020, 20:20:55.302	[info ]: javascript.0 (7442) Stop script script.js.smarthome.steckdosen.Timeskript
        5.7.2020, 20:20:55.311	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Timer Schedule 1 killed
        5.7.2020, 20:20:55.311	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Timer Schedule 2 killed
        5.7.2020, 20:20:55.311	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Timer Schedule 3 killed
        5.7.2020, 20:20:55.312	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Timer Schedule 4 killed
        5.7.2020, 20:20:55.312	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Timer Schedule 5 killed
        5.7.2020, 20:20:55.312	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Timer Schedule 6 killed
        5.7.2020, 20:20:55.460	[info ]: javascript.0 (7442) Start javascript script.js.smarthome.steckdosen.Timeskript
        5.7.2020, 20:20:55.475	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Starting TimerSkript V2.1.4
        5.7.2020, 20:20:55.480	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: registered 0 subscriptions and 0 schedules
        5.7.2020, 20:20:55.525	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Initial CreateStates finished!
        5.7.2020, 20:20:55.526	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching Main
        5.7.2020, 20:20:55.526	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching Init()
        5.7.2020, 20:20:55.543	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching CreateTimerCountList()
        5.7.2020, 20:20:55.544	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching SetValueListPairs()
        5.7.2020, 20:20:55.545	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching ConvertPresence. TempPresence=true
        5.7.2020, 20:20:55.546	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching CreateTrigger()
        5.7.2020, 20:20:55.556	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Timer CreateState(s) finished!
        5.7.2020, 20:20:55.559	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching CreateDeviceTrigger() Trigger added for sonoff.0.Pool-Pumpe.POWER whichone= 0
        5.7.2020, 20:20:55.562	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching SetTimer(whichone=,0 GoToTommorrow=false)
        5.7.2020, 20:20:55.564	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Timer 1 will be set, GoToTommorrow=false
        5.7.2020, 20:20:55.567	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching CreateTimeDaysString(whichone=0)
        5.7.2020, 20:20:55.567	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching MakeCronString(whichone=0)
        5.7.2020, 20:20:55.568	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: CronString for Timer 1 created 00 00 09 * * *
        5.7.2020, 20:20:55.570	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Timer CreateState(s) finished!
        5.7.2020, 20:20:55.571	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching SetTimer(whichone=,1 GoToTommorrow=false)
        5.7.2020, 20:20:55.571	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Timer 2 will be set, GoToTommorrow=false
        5.7.2020, 20:20:55.571	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching CreateTimeDaysString(whichone=1)
        5.7.2020, 20:20:55.571	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching MakeCronString(whichone=1)
        5.7.2020, 20:20:55.572	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: CronString for Timer 2 created 00 00 15 * * *
        5.7.2020, 20:20:55.573	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Timer CreateState(s) finished!
        5.7.2020, 20:20:55.574	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching CreateDeviceTrigger() Trigger added for sonoff.0.Schalter-Kompressor.POWER whichone= 1
        5.7.2020, 20:20:55.574	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching SetTimer(whichone=,2 GoToTommorrow=false)
        5.7.2020, 20:20:55.574	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Timer 3 will be set, GoToTommorrow=false
        5.7.2020, 20:20:55.575	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching CreateTimeDaysString(whichone=2)
        5.7.2020, 20:20:55.575	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching MakeCronString(whichone=2)
        5.7.2020, 20:20:55.575	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: CronString for Timer 3 created 00 00 09 * * *
        5.7.2020, 20:20:55.576	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Timer CreateState(s) finished!
        5.7.2020, 20:20:55.577	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching SetTimer(whichone=,3 GoToTommorrow=false)
        5.7.2020, 20:20:55.577	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Timer 4 will be set, GoToTommorrow=false
        5.7.2020, 20:20:55.577	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching CreateTimeDaysString(whichone=3)
        5.7.2020, 20:20:55.577	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching MakeCronString(whichone=3)
        5.7.2020, 20:20:55.578	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: CronString for Timer 4 created 00 00 20 * * *
        5.7.2020, 20:20:55.579	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Timer CreateState(s) finished!
        5.7.2020, 20:20:55.579	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching CreateDeviceTrigger() Trigger added for sonoff.0.Kuechenleuchte.POWER whichone= 2
        5.7.2020, 20:20:55.580	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching SetTimer(whichone=,4 GoToTommorrow=false)
        5.7.2020, 20:20:55.580	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Timer 5 will be set, GoToTommorrow=false
        5.7.2020, 20:20:55.581	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching DetermineNextActiveAstroDay(whichone=4 GoToTommorrow=false)
        5.7.2020, 20:20:55.581	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching CheckTodayAstroIsOver(AstroChoice=dusk Shift=0)
        5.7.2020, 20:20:55.588	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Es ist 18:20:55, Astroevent today is still upcoming at: 20:37:01
        5.7.2020, 20:20:55.589	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Initial NextActiveDay=Sonntag =0 TodayAstroIsOver=false
        5.7.2020, 20:20:55.589	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: NextActiveDayIndex=0 and x=0 and TodayAstroIsOver=false and GoToTommorrow=false
        5.7.2020, 20:20:55.589	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Returning FoundIndex=0 FoundDiff=0
        5.7.2020, 20:20:55.590	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching DetermineChoosenAstroTime( AstroChoice=dusk AddDays=0 Shift=0)
        5.7.2020, 20:20:55.593	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: dusk today starts at:20:37:01 and starts next active day at 20:37:01
        5.7.2020, 20:20:55.595	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Returning next active Astrotime=20:37:01
        5.7.2020, 20:20:55.598	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching MakeCronString(whichone=4)
        5.7.2020, 20:20:55.599	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Cronstring for Timer 5 Astro created 01 37 20 * * 0
        5.7.2020, 20:20:55.615	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Timer CreateState(s) finished!
        5.7.2020, 20:20:55.615	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching SetTimer(whichone=,5 GoToTommorrow=false)
        5.7.2020, 20:20:55.616	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Timer 6 will be set, GoToTommorrow=false
        5.7.2020, 20:20:55.616	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching CreateTimeDaysString(whichone=5)
        5.7.2020, 20:20:55.617	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching MakeCronString(whichone=5)
        5.7.2020, 20:20:55.617	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: CronString for Timer 6 created 00 00 23 * * *
        5.7.2020, 20:20:55.619	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching CreateTimerTargetsNameList()
        5.7.2020, 20:20:55.619	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Original TargetNames are:Pool-Pumpe,Schalter-Kompressor,Kuechenleuchte,Shelly_Küche,Shelly-Esszimmer
        5.7.2020, 20:20:55.620	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Possible Target are:sonoff.0.Pool-Pumpe.POWER,sonoff.0.Schalter-Kompressor.POWER,sonoff.0.Kuechenleuchte.POWER,shelly.0.SHSW-1#C4271A#1.Relay0.Switch,shelly.0.SHSW-1#C42A03#1.Relay0.Switch
        5.7.2020, 20:20:55.620	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: New TargetNames are:Pool-Pumpe,Schalter-Kompressor,Kuechenleuchte,Shelly_Küche,Shelly-Esszimmer
        5.7.2020, 20:20:55.621	[info ]: javascript.0 (7442) script.js.smarthome.steckdosen.Timeskript: Reaching MakeTable
          Pittini Developer @Aachen1305 last edited by
          @Aachen1305 sagte in [Vorlage] Flexibles Timerskript + Vis:
          Log is unauffällig, da is alles ok, die Timer werden gesetzt.
            @Pittini
            Habe jetzt festgestellt, das die Zeiten nicht stimmen. Wenn ich zum Bespiel sage, starte Poolpumpe um 9Uhr, schaltet das Skript die erst 2 Std. später ein. Habe aber noch nicht rausgefunden wieso. Kurios 😕
              Ich behaupte jetzt mal dass das nicht am Skript liegt, der Timer wird korrekt gesetzt für 9:00, da stimmt vermutlich iwas mit Ländereinstellungen etc. nicht.
                Aachen1305 @Pittini last edited by
                @Pittini sagte in [Vorlage] Flexibles Timerskript + Vis:
                Könnte es an der Astro Funktion liegen? Dort zeigt mir das Log einen Zeitunterschied von den 2Std. an?
                  Such nicht im Skript oder bei den Funktionen den Fehler, hätte das Skript da nen Bug würde der jeden betreffen. Iwas stimmt mit Deiner Konfig nicht, evtl. Längen- Breitengrad falsch, oder Sommer- Winterzeit....iwas in der Richtung.
                    Danke Dir👍
                      @Pittini
                      Ich hab den Fehler gefunden. Er sitzt natürlich vor dem Rechner. Ich habe die falsche Zeitzone im LXC Container eingetragen. Jetzt passt alles.
                        Pittini Developer last edited by
                        Feature update
                        V2.1.5 (19.07.2020)
                        • Add: Option "Wert senden" zu Aktionen, sowie entsprechendes Eingabefeld und Spalte in der Tabelle hinzugefügt. Somit können jetzt z.B. Rollos auf bestimmte Positionen gefahren werden, Lichter gedimmt etc.
                        • Q
                          Qlink last edited by
                          @Pittini
                          Ich habe aktuell die Version 2.1.0 von dir im Einsatz.
                          Muss ich bei einem "Update" auf die Version 2.1.5 irgendwas speziell beachten, oder einfach nur das Script austauschen ?
                          Danke für deine tolle Arbeit.
                          Beste Grüße
                            Pittini Developer @Qlink last edited by
                            @Qlink sagte in [Vorlage] Flexibles Timerskript + Vis:
                            Da sich in der 2.1.1 und in der 2.1.5 auch das Vis geändert hat (1 Button und zwei Eingabefelder hinzugekommen), solltest Du auch das updaten.
                              Freaknet last edited by
                              @Pittini
                              Hi Pittini,
                              erstmal vielen Dank für das Script. Wenns läuft ist das echt der Hammer!
                              Leider hab ich aber dabei ein Problem, welches ich seit gestern nicht gelöst bekomme. Hier im Thread hab ich auch dazu nix passendes gefunden was hätte helfen können.
                              Folgendes Problem.
                              Beim Start des Script stürzt meine JavaScript Instanz ab und es kommen einige Fehlermeldungen im Script und auch im Log. Hab schon div. Einstellungen versucht, doch immer das selbe Problem. Denke es liegt an mir, aber komme nicht auf die Lösung.
                              Vielleicht kannst Du mal über die Log drüberschaun und sagen woran es liegen könnte. Hoffe die Bilder im Anhang reichen für eine erste Analyse.
                              Danke!
                                Pittini Developer @Freaknet last edited by
                                @Freaknet sagte in [Vorlage] Flexibles Timerskript + Vis:
                                Ich vermute am UserData Channel. Bleib mal beim javascript Channel.
                                F 2 Replies Last reply Reply Quote 1
                                  Freaknet @Pittini last edited by Freaknet
                                  @Pittini
                                  Werd ich versuchen!
                                  Kann es sein das es auch evtl. an den Datenpunkten selbst liegen kann?
                                  Hab alle Datenpunkte für TimerTarget aus dem Alias.0 genommen und nicht direkt die aus dem Adapter (z.B. Hue, Shelly oder Sonoff).
                                  Nachtrag:
                                  Jetzt läuft das Script 🙂 Bin auf den javascript gewechselt und jetzt kommen keine Fehler mehr. Nur das mit Alias.0 klappt wohl nicht mit dem Namen. Hab im Bild mal markiert was ich meine. Bei Alias.0 Datenpunkten kommt der Name nicht in der Vis, bei den anderen schon. Kann man da noch was optimieren?
                                    @Pittini
                                    Scheint stabil zu laufen jetzt!
                                    Danke Pittini für die schnelle Hilfe 👍 .
                                    Muss jetzt nur noch meine alias.0 Datenpunkte dazu bringen den Namen in der Vis angezeigt zu bekommen, da ich eigentlich nur mit alias arbeite...
                                    Denke aber da muss im Script was geändert werden, oder?
                                    Vielleicht weiß Du da was oder hast einen Rat 😉
                                      Seh da eigentlich grad keinen Grund warum die Namen da nicht kommen. Schau ich mir mal an.
                                        @Pittini
                                        Also grad nochmal paar Datenpunkte aus dem alias.0 Ordner eingefügt (Screen).
                                        Immer das selbe Problem... die Namen werden in der Vis nicht angezeigt und nur (Objekt Objekt) (siehe Foto) angezeigt. Wenn es nichts hilft muss ich wohl die Datenpunkte aus den Adaptern nehmen, da funktioniert das sehr gut!
                                        Also das Schaltziel wird richtig angezeigt... nur der Zielname wird nicht übernommen.
                                          Hi nochmal,
                                          also das Problem konnte ich jetzt lösen.
                                          Das Problem lag an den Namen der alias.0 Ordner.
                                          Die ID und der Name des Objekt´s müssen sich unterscheiden, dann wird auch in der Vis alles korrekt angezeigt. Siehe Beispiel:
                                          Vorher:
                                          Nachher:
                                          Vielleicht hilft das jemanden ja weiter 😉
                                            Netter workaround bei dem ich grad nicht weis warums funktioniert. Das eigentliche Problem ist in der 2.1.6 behoben, sollte jetzt auch im Aliasordner klappen.
                                            javascript template
                                            40
                                            500
                                            111803
