    5. [Vorlage] Gartenbewässerung mit 6 Ventilen
    • dslraser
      dslraser Forum Testing Most Active @Kuddel last edited by dslraser
      @Kuddel
      meine aktuelle v2.6.8
      ich habe Dir mal in Deine letzte 2.6.8 die Änderungen in der Datenpunkte_erstellen Funktion eingebaut (also auch den Teil mit dem löschen der nicht mehr benötigten Ventile und ändern der Namen)
      Hier der Inhalt der Funktion (also nicht das ganze Blockly)
      Schau es Dir einfach in Ruhe an wenn Du Zeit hast.
      * Create states under 0_userdata.0 or javascript.x
      * Current Version:     https://github.com/Mic-M/iobroker.createUserStates
      * Support:             https://forum.iobroker.net/topic/26839/
      * Autor:               Mic (ioBroker) | Mic-M (github)
      * Version:             1.1 (26 January 2020)
      * Example:             see https://github.com/Mic-M/iobroker.createUserStates#beispiel
      * PLEASE NOTE: Per https://github.com/ioBroker/ioBroker.javascript/issues/474, the used function setObject()
      *              executes the callback PRIOR to completing the state creation. Therefore, we use a setTimeout and counter.
      * @param {string} where          Where to create the state: '0_userdata.0' or 'javascript.x'.
      * @param {boolean} force         Force state creation (overwrite), if state is existing.
      * @param {array} statesToCreate  State(s) to create. single array or array of arrays
      * @param {object} [callback]     Optional: a callback function -- This provided function will be executed after all states are created.
      function createUserStates(where, force, statesToCreate, callback = undefined) {
         const WARN = false; // Only for 0_userdata.0: Throws warning in log, if state is already existing and force=false. Default is false, so no warning in log, if state exists.
         const LOG_DEBUG = false; // To debug this function, set to true
         // Per issue #474 (https://github.com/ioBroker/ioBroker.javascript/issues/474), the used function setObject() executes the callback
         // before the state is actual created. Therefore, we use a setTimeout and counter as a workaround.
         const DELAY = 50; // Delay in milliseconds (ms). Increase this to 100, if it is not working.
         // Validate "where"
         if (where.endsWith('.')) where = where.slice(0, -1); // Remove trailing dot
         if ( (where.match(/^((javascript\.([1-9][0-9]|[0-9]))$|0_userdata\.0$)/) == null) ) {
             log('This script does not support to create states under [' + where + ']', 'error');
             return;
         // Prepare "statesToCreate" since we also allow a single state to create
         if(!Array.isArray(statesToCreate[0])) statesToCreate = [statesToCreate]; // wrap into array, if just one array and not inside an array
         // Add "where" to STATES_TO_CREATE
         for (let i = 0; i < statesToCreate.length; i++) {
             let lpPath = statesToCreate[i][0].replace(/\.*\./g, '.'); // replace all multiple dots like '..', '...' with a single '.'
             lpPath = lpPath.replace(/^((javascript\.([1-9][0-9]|[0-9])\.)|0_userdata\.0\.)/,'') // remove any javascript.x. / 0_userdata.0. from beginning
             lpPath = where + '.' + lpPath; // add where to beginning of string
             statesToCreate[i][0] = lpPath;
         if (where != '0_userdata.0') {
             // Create States under javascript.x
             let numStates = statesToCreate.length;
             statesToCreate.forEach(function(loopParam) {
                 if (LOG_DEBUG) log('[Debug] Now we are creating new state [' + loopParam[0] + ']');
                 let loopInit = (loopParam[1]['def'] == undefined) ? null : loopParam[1]['def']; // mimic same behavior as createState if no init value is provided
                 createState(loopParam[0], loopInit, force, loopParam[1], function() {
                     numStates--;
                     if (numStates === 0) {
                         if (LOG_DEBUG) log('[Debug] All states processed.');
                         if (typeof callback === 'function') { // execute if a function was provided to parameter callback
                             if (LOG_DEBUG) log('[Debug] Function to callback parameter was provided');
                             return callback();
                         } else {
                             return;
         } else {
             // Create States under 0_userdata.0
             let counter = -1;
                 counter += 1;
                 if (LOG_DEBUG) log ('[Debug] Currently processing following state: [' + loopParam[0] + ']');
                 if( ($(loopParam[0]).length > 0) && (existsState(loopParam[0])) ) { // Workaround due to https://github.com/ioBroker/ioBroker.javascript/issues/478
                     // State is existing.
                     if (WARN && !force) log('State [' + loopParam[0] + '] is already existing and will no longer be created.', 'warn');
                     if (!WARN && LOG_DEBUG) log('[Debug] State [' + loopParam[0] + '] is already existing. Option force (=overwrite) is set to [' + force + '].');
                     if(!force) {
                         // State exists and shall not be overwritten since force=false
                         // So, we do not proceed.
                         numStates--;
                             if (LOG_DEBUG) log('[Debug] All states successfully processed!');
                                 if (LOG_DEBUG) log('[Debug] An optional callback function was provided, which we are going to execute now.');
                                 return callback();
                         } else {
                             // We need to go out and continue with next element in loop.
                             return; // https://stackoverflow.com/questions/18452920/continue-in-cursor-foreach
                     } // if(!force)
                 // State is not existing or force = true, so we are continuing to create the state through setObject().
                 let obj = {};
                 obj.type = 'state';
                 obj.native = {};
                 obj.common = loopParam[1];
                 setObject(loopParam[0], obj, function (err) {
                     if (err) {
                         log('Cannot write object for state [' + loopParam[0] + ']: ' + err);
                     } else {
                         let init = null;
                         if(loopParam[1].def === undefined) {
                             if(loopParam[1].type === 'number') init = 0;
                             if(loopParam[1].type === 'boolean') init = false;
                             if(loopParam[1].type === 'string') init = '';
                         } else {
                             init = loopParam[1].def;
                         setTimeout(function() {
                             setState(loopParam[0], init, true, function() {
                                 if (LOG_DEBUG) log('[Debug] setState durchgeführt: ' + loopParam[0]);
                                 numStates--;
                                         return callback();
                         }, DELAY + (20 * counter) );
      //log('--- Datenobjekte fuer die Bewaesserung werden angelegt ---')
      let vars = [
         //Bewässerung
         [basic_vars_pfad+'.bewaesserung_aktiv', {'name':'bewaesserung_aktiv','type':'boolean','read':true,'write':true,'role':'switch','def':false}],
         [basic_vars_pfad+'.bewaesserung_automatik', {'name':'bewaesserung_automatik','type':'boolean','read':true,'write':true,'role':'switch','def':false}],
         [basic_vars_pfad+'.bewaesserung_pause', {'name':'bewaesserung_pause','type':'boolean','read':true,'write':true,'role':'switch','def':false}],
         //Timer
         [basic_vars_pfad+'.lautzeit_gesamt_in_sek', {'name':'lautzeit_gesamt_in_sek','type':'number','read':true,'write':false,'role':'number','def':0,'unit':'Sekunden'}],
         [basic_vars_pfad+'.lautzeit_ende_uhrzeit', {'name':'lautzeit_ende_uhrzeit','type':'string','read':true,'write':false,'role':'string','def': ''}],
         [basic_vars_pfad+'.restlautzeit', {'name':'restlautzeit','type': 'mixed','read':true,'write':false,'role':'mixed','def':0}],
         [basic_vars_pfad+'.restlautzeit_in_sek', {'name':'restlautzeit_in_sek','type':'number','read':true,'write':false,'role':'number','def':0,'unit':'Sekunden'}],
         [basic_vars_pfad+'.gesamtfortschritt', {'name':'gesamtfortschritt','type':'number','read':true,'write':false,'role':'number','def':0,'unit':'%','min':0,'max':100}],
         [basic_vars_pfad+'.gesamtrest', {'name':'gesamtrest','type':'mixed','read':true,'write':false,'role':'mixed','def':100,'unit':'%','min':0,'max':100}],
         [basic_vars_pfad+'.letzter_durchgang', {'name':'letzter_durchgang','type':'string','read':true,'write':false,'role':'string','def': '00:00'}],
         //Schwellwerte
         [basic_vars_pfad+'.schwellwerte.schwellwert_check_aktiv', {'name':'schwellwert_check_aktiv','type':'boolean','read':true,'write':true,'role':'switch','def':true}],
         [basic_vars_pfad+'.schwellwerte.schwellwert_regen', {'name':'schwellwert_regen','type':'number','read':true,'write':true,'role':'number','def':0,'unit':'mm'}],
         [basic_vars_pfad+'.schwellwerte.schwellwert_temperatur', {'name':'schwellwert_temperatur','type':'number','read':true,'write':true,'role':'number','def':0,'unit':'°C'}],
         [basic_vars_pfad+'.schwellwerte.schwellwerte_ok', {'name':'schwellwerte_ok','type':'boolean','read':true,'write':false,'role':'switch','def':false}],
         [basic_vars_pfad+'.schwellwerte.schwellwerte_info_senden', {'name':'schwellwerte_info_senden','type':'boolean','read':true,'write':true,'role':'switch','def':false, 'descr':'Dieser DP wird ausgeloest, wenn die Automatik startet, die Schwellwerte aber ueberschritten wurden'}],
         [basic_vars_pfad+'.schwellwerte.gestern_regen', {'name':'gestern_regen','type':'number','read':true,'write':false,'role':'number','def':0,'unit':'mm'}],
         [basic_vars_pfad+'.schwellwerte.gestern_temp', {'name':'gestern_temp','type':'number','read':true,'write':false,'role':'number','def':0,'unit':'°C'}],
         //Ventile
         [basic_vars_pfad+'.ventile.anzahl_aktive_ventile', {'name':'anzahl_aktive_ventile','type':'number','read':true,'write':false,'role':'number','def':0,'min':0, 'max':6} ],
         //Zeitplan
         [basic_vars_pfad+'.zeitplan.cron_restart', {'name':'cron_restart','type': 'mixed','read':true,'write':false,'role':'mixed','def':0,'unit':'Uhr'}],
         [basic_vars_pfad+'.zeitplan.sonnenaufgang', {'name':'sonnenaufgang','type':'string','read':true,'write':false,'role':'string','def':'00:00','unit':'Uhr'}],
         [basic_vars_pfad+'.zeitplan.sonnenuntergang', {'name':'sonnenuntergang','type':'string','read':true,'write':false,'role':'string','def':'00:00','unit':'Uhr'}],
         //Morgens
         [basic_vars_pfad+'.zeitplan.morgens_aktiv', {'name':'morgens_aktiv','type':'boolean','read':true,'write':true,'role':'switch','def':false}],
         [basic_vars_pfad+'.zeitplan.morgens_uhrzeit_start', {'name':'morgens_uhrzeit_start','type':'string','read':true,'write':false,'role':'string','def':'00:00','unit':'Uhr'}],
         [basic_vars_pfad+'.zeitplan.morgens_uhrzeit_ende', {'name':'morgens_uhrzeit_ende','type':'string','read':true,'write':false,'role':'string','def':'00:00','unit':'Uhr'}],
         [basic_vars_pfad+'.zeitplan.morgens_verzoegerung_sonnenaufgang', {'name':'morgens_verzoegerung_sonnenaufgang','type': 'number','read':true,'write':true,'role':'number','def':0,'unit':'Minuten'}],
         //Abends
         [basic_vars_pfad+'.zeitplan.abends_aktiv', {'name':'abends_aktiv','type':'boolean','read':true,'write':true,'role':'switch','def':false}],
         [basic_vars_pfad+'.zeitplan.abends_uhrzeit_start', {'name':'abends_uhrzeit_start','type':'string','read':true,'write':false,'role':'string','def':'00:00','unit':'Uhr'}],
         [basic_vars_pfad+'.zeitplan.abends_uhrzeit_ende', {'name':'abends_uhrzeit_ende','type':'string','read':true,'write':false,'role':'string','def':'00:00','unit':'Uhr'}],
         [basic_vars_pfad+'.zeitplan.abends_verzoegerung_sonnenuntergang', {'name':'abends_verzoegerung_sonnenuntergang','type': 'number','read':true,'write':true,'role':'number','def':0,'unit':'Minuten'}],
         //Feste Startzeit 1
         [basic_vars_pfad+'.zeitplan.feste_startzeit_1_aktiv', {'name':'feste_startzeit_1_aktiv','type':'boolean','read':true,'write':true,'role':'switch','def':false}],
         [basic_vars_pfad+'.zeitplan.feste_startzeit_1_uhrzeit_start', {'name':'feste_startzeit_1_uhrzeit_start','type':'string','read':true,'write':true,'role':'string','def':'00:00','unit':'Uhr'}],
         [basic_vars_pfad+'.zeitplan.feste_startzeit_1_uhrzeit_ende', {'name':'feste_startzeit_1_uhrzeit_ende','type':'string','read':true,'write':false,'role':'string','def':'00:00','unit':'Uhr'}],
         //Feste Startzeit 2
         [basic_vars_pfad+'.zeitplan.feste_startzeit_2_aktiv', {'name':'feste_startzeit_2_aktiv','type':'boolean','read':true,'write':true,'role':'switch','def':false}],
         [basic_vars_pfad+'.zeitplan.feste_startzeit_2_uhrzeit_start', {'name':'feste_startzeit_2_uhrzeit_start','type':'string','read':true,'write':true,'role':'string','def':'00:00','unit':'Uhr'}],
         [basic_vars_pfad+'.zeitplan.feste_startzeit_2_uhrzeit_ende', {'name':'feste_startzeit_2_uhrzeit_ende','type':'string','read':true,'write':false,'role':'string','def':'00:00','unit':'Uhr'}],
         //Feste Startzeit 3
         [basic_vars_pfad+'.zeitplan.feste_startzeit_3_aktiv', {'name':'feste_startzeit_3_aktiv','type':'boolean','read':true,'write':true,'role':'switch','def':false}],
         [basic_vars_pfad+'.zeitplan.feste_startzeit_3_uhrzeit_start', {'name':'feste_startzeit_3_uhrzeit_start','type':'string','read':true,'write':true,'role':'string','def':'00:00','unit':'Uhr'}],
         [basic_vars_pfad+'.zeitplan.feste_startzeit_3_uhrzeit_ende', {'name':'feste_startzeit_3_uhrzeit_ende','type':'string','read':true,'write':false,'role':'string','def':'00:00','unit':'Uhr'}],
      createUserStates(basic_vars_speicherort, false, vars);
         //Diese DPs sollen bei jedem Speichern überschrieben werden
         let vars_writable = [
         [basic_vars_pfad+'.ventile.anzahl_ventile', {'name':'anzahl_ventile','type':'number','read':true,'write':false,'role':'number','def':basic_vars_anzahl_ventile,'min':0, 'max':basic_vars_anzahl_ventile} ],
         [basic_vars_pfad+'.ventile.ventil_1.ventil_1_name', {'name':'ventil_1_name','type':'string','read':true,'write':false,'role':'string','def':basic_vars_kreis1_name}],
         [basic_vars_pfad+'.ventile.ventil_2.ventil_2_name', {'name':'ventil_2_name','type':'string','read':true,'write':false,'role':'string','def':basic_vars_kreis2_name}],
         [basic_vars_pfad+'.ventile.ventil_3.ventil_3_name', {'name':'ventil_3_name','type':'string','read':true,'write':false,'role':'string','def':basic_vars_kreis3_name}],
         [basic_vars_pfad+'.ventile.ventil_4.ventil_4_name', {'name':'ventil_4_name','type':'string','read':true,'write':false,'role':'string','def':basic_vars_kreis4_name}],
         [basic_vars_pfad+'.ventile.ventil_5.ventil_5_name', {'name':'ventil_5_name','type':'string','read':true,'write':false,'role':'string','def':basic_vars_kreis5_name}],
         [basic_vars_pfad+'.ventile.ventil_6.ventil_6_name', {'name':'ventil_6_name','type':'string','read':true,'write':false,'role':'string','def':basic_vars_kreis6_name}],
      createUserStates(basic_vars_speicherort, true, vars_writable);
      if(basic_vars_anzahl_ventile > 0) {
         let vars_ventil_1 = [
         //Ventil 1
         [basic_vars_pfad+'.ventile.ventil_1.ventil_1', {'name':'ventil_1','type':'boolean','read':true,'write':true,'role':'switch','def':false}],
         [basic_vars_pfad+'.ventile.ventil_1.ventil_1_dauer', {'name': 'ventil_1_dauer','type':'number','read':true,'write':true,'role':'number','def':0,'unit':'Sekunden'}],
         [basic_vars_pfad+'.ventile.ventil_1.ventil_1_dauer_in_min', {'name': 'ventil_1_dauer_in_min','type':'number','read':true,'write':true,'role':'number','def':0,'unit':'Minuten'}],
         [basic_vars_pfad+'.ventile.ventil_1.ventil_1_ende', {'name':'ventil_1_ende','type':'string','read':true,'write':false,'role':'string','def':'00:00','unit':'Uhr'}],
         [basic_vars_pfad+'.ventile.ventil_1.ventil_1_fortschritt', {'name':'ventil_1_fortschritt','type':'number','read':true,'write':false,'role':'number','def':0,'unit':'%','min':0,'max':100}],
         [basic_vars_pfad+'.ventile.ventil_1.ventil_1_rest', {'name':'ventil_1_rest','type':'number','read':true,'write':false,'role':'number','def':100,'unit':'%','min':0,'max':100}],
         //[basic_vars_pfad+'.ventile.ventil_1.ventil_1_name', {'name':'ventil_1_name','type':'string','read':true,'write':false,'role':'string','def':basic_vars_kreis1_name}],
         [basic_vars_pfad+'.ventile.ventil_1.ventil_1_restzeit', {'name':'ventil_1_restzeit','type': 'string','read':true,'write':false,'role':'string','def':'0:00','unit':'Minuten'}],
         [basic_vars_pfad+'.ventile.ventil_1.ventil_1_restzeit_in_sek', {'name':'ventil_1_restzeit_in_sek','type':'number','read':true,'write':false,'role':'number','def':0,'unit':'Sekunden'}],
         [basic_vars_pfad+'.ventile.ventil_1.ventil_1_status', {'name':'ventil_1_status','type':'boolean','read':true,'write':false,'role':'switch','def':false}],
         [basic_vars_pfad+'.ventile.ventil_1.ventil_1_parallel', {'name':'ventil_1_parallel','type':'boolean','read':true,'write':true,'role':'switch','def':false,'descr':'Wenn dieser DP aktiviert wird, dann werden Ventil 2 bis X parallel zu Ventil 1 gestartet. Usecase: an Ventil 1 ist ein Tropfschlauch angeschlossen.'}],
      createUserStates(basic_vars_speicherort, false, vars_ventil_1);}
      if(basic_vars_anzahl_ventile > 1) {
         let vars_ventil_2 = [
         //Ventil 2
         [basic_vars_pfad+'.ventile.ventil_2.ventil_2', {'name':'ventil_2','type':'boolean','read':true,'write':true,'role':'switch','def':false}],
         [basic_vars_pfad+'.ventile.ventil_2.ventil_2_dauer', {'name': 'ventil_2_dauer','type':'number','read':true,'write':true,'role':'number','def':0,'unit':'Sekunden'}],
         [basic_vars_pfad+'.ventile.ventil_2.ventil_2_dauer_in_min', {'name': 'ventil_2_dauer_in_min','type':'number','read':true,'write':true,'role':'number','def':0,'unit':'Minuten'}],
         [basic_vars_pfad+'.ventile.ventil_2.ventil_2_ende', {'name':'ventil_2_ende','type':'string','read':true,'write':false,'role':'string','def':'00:00','unit':'Uhr'}],
         [basic_vars_pfad+'.ventile.ventil_2.ventil_2_fortschritt', {'name':'ventil_2_fortschritt','type':'number','read':true,'write':false,'role':'number','def':0,'unit':'%','min':0,'max':100}],
         [basic_vars_pfad+'.ventile.ventil_2.ventil_2_rest', {'name':'ventil_2_rest','type':'number','read':true,'write':false,'role':'number','def':100,'unit':'%','min':0,'max':100}],
         //[basic_vars_pfad+'.ventile.ventil_2.ventil_2_name', {'name':'ventil_2_name','type':'string','read':true,'write':false,'role':'string','def':basic_vars_kreis2_name}],
         [basic_vars_pfad+'.ventile.ventil_2.ventil_2_restzeit', {'name':'ventil_2_restzeit','type': 'string','read':true,'write':false,'role':'string','def':'0:00','unit':'Minuten'}],
         [basic_vars_pfad+'.ventile.ventil_2.ventil_2_restzeit_in_sek', {'name':'ventil_2_restzeit_in_sek','type':'number','read':true,'write':false,'role':'number','def':0,'unit':'Sekunden'}],
         [basic_vars_pfad+'.ventile.ventil_2.ventil_2_status', {'name':'ventil_2_status','type':'boolean','read':true,'write':false,'role':'switch','def':false}],
      createUserStates(basic_vars_speicherort, false, vars_ventil_2);}
      if(basic_vars_anzahl_ventile > 2) {
      let vars_ventil_3 = [
         //Ventil 3
         [basic_vars_pfad+'.ventile.ventil_3.ventil_3', {'name':'ventil_3','type':'boolean','read':true,'write':true,'role':'switch','def':false}],
         [basic_vars_pfad+'.ventile.ventil_3.ventil_3_dauer', {'name': 'ventil_3_dauer','type':'number','read':true,'write':true,'role':'number','def':0,'unit':'Sekunden'}],
         [basic_vars_pfad+'.ventile.ventil_3.ventil_3_dauer_in_min', {'name': 'ventil_3_dauer_in_min','type':'number','read':true,'write':true,'role':'number','def':0,'unit':'Minuten'}],
         [basic_vars_pfad+'.ventile.ventil_3.ventil_3_ende', {'name':'ventil_3_ende','type':'string','read':true,'write':false,'role':'string','def':'00:00','unit':'Uhr'}],
         [basic_vars_pfad+'.ventile.ventil_3.ventil_3_fortschritt', {'name':'ventil_3_fortschritt','type':'number','read':true,'write':false,'role':'number','def':0,'unit':'%','min':0,'max':100}],
         [basic_vars_pfad+'.ventile.ventil_3.ventil_3_rest', {'name':'ventil_3_rest','type':'number','read':true,'write':false,'role':'number','def':100,'unit':'%','min':0,'max':100}],
         //[basic_vars_pfad+'.ventile.ventil_3.ventil_3_name', {'name':'ventil_3_name','type':'string','read':true,'write':false,'role':'string','def':basic_vars_kreis3_name}],
         [basic_vars_pfad+'.ventile.ventil_3.ventil_3_restzeit', {'name':'ventil_3_restzeit','type': 'string','read':true,'write':false,'role':'string','def':'0:00','unit':'Minuten'}],
         [basic_vars_pfad+'.ventile.ventil_3.ventil_3_restzeit_in_sek', {'name':'ventil_3_restzeit_in_sek','type':'number','read':true,'write':false,'role':'number','def':0,'unit':'Sekunden'}],
         [basic_vars_pfad+'.ventile.ventil_3.ventil_3_status', {'name':'ventil_3_status','type':'boolean','read':true,'write':false,'role':'switch','def':false}],
      createUserStates(basic_vars_speicherort, false, vars_ventil_3);}
      if(basic_vars_anzahl_ventile > 3) {
         let vars_ventil_4 = [
         //Ventil 4
         [basic_vars_pfad+'.ventile.ventil_4.ventil_4', {'name':'ventil_4','type':'boolean','read':true,'write':true,'role':'switch','def':false}],
         [basic_vars_pfad+'.ventile.ventil_4.ventil_4_dauer', {'name': 'ventil_4_dauer','type':'number','read':true,'write':true,'role':'number','def':0,'unit':'Sekunden'}],
         [basic_vars_pfad+'.ventile.ventil_4.ventil_4_dauer_in_min', {'name': 'ventil_4_dauer_in_min','type':'number','read':true,'write':true,'role':'number','def':0,'unit':'Minuten'}],
         [basic_vars_pfad+'.ventile.ventil_4.ventil_4_ende', {'name':'ventil_4_ende','type':'string','read':true,'write':false,'role':'string','def':'00:00','unit':'Uhr'}],
         [basic_vars_pfad+'.ventile.ventil_4.ventil_4_fortschritt', {'name':'ventil_4_fortschritt','type':'number','read':true,'write':false,'role':'number','def':0,'unit':'%','min':0,'max':100}],
         [basic_vars_pfad+'.ventile.ventil_4.ventil_4_rest', {'name':'ventil_4_rest','type':'number','read':true,'write':false,'role':'number','def':100,'unit':'%','min':0,'max':100}],
         //[basic_vars_pfad+'.ventile.ventil_4.ventil_4_name', {'name':'ventil_4_name','type':'string','read':true,'write':false,'role':'string','def':basic_vars_kreis4_name}],
         [basic_vars_pfad+'.ventile.ventil_4.ventil_4_restzeit', {'name':'ventil_4_restzeit','type': 'string','read':true,'write':false,'role':'string','def':'0:00','unit':'Minuten'}],
         [basic_vars_pfad+'.ventile.ventil_4.ventil_4_restzeit_in_sek', {'name':'ventil_4_restzeit_in_sek','type':'number','read':true,'write':false,'role':'number','def':0,'unit':'Sekunden'}],
         [basic_vars_pfad+'.ventile.ventil_4.ventil_4_status', {'name':'ventil_4_status','type':'boolean','read':true,'write':false,'role':'switch','def':false}],
      createUserStates(basic_vars_speicherort, false, vars_ventil_4);}
      if(basic_vars_anzahl_ventile > 4) {
         let vars_ventil_5 = [
         //Ventil 5
         [basic_vars_pfad+'.ventile.ventil_5.ventil_5', {'name':'ventil_5','type':'boolean','read':true,'write':true,'role':'switch','def':false}],
         [basic_vars_pfad+'.ventile.ventil_5.ventil_5_dauer', {'name': 'ventil_5_dauer','type':'number','read':true,'write':true,'role':'number','def':0,'unit':'Sekunden'}],
         [basic_vars_pfad+'.ventile.ventil_5.ventil_5_dauer_in_min', {'name': 'ventil_5_dauer_in_min','type':'number','read':true,'write':true,'role':'number','def':0,'unit':'Minuten'}],
         [basic_vars_pfad+'.ventile.ventil_5.ventil_5_ende', {'name':'ventil_5_ende','type':'string','read':true,'write':false,'role':'string','def':'00:00','unit':'Uhr'}],
         [basic_vars_pfad+'.ventile.ventil_5.ventil_5_fortschritt', {'name':'ventil_5_fortschritt','type':'number','read':true,'write':false,'role':'number','def':0,'unit':'%','min':0,'max':100}],
         [basic_vars_pfad+'.ventile.ventil_5.ventil_5_rest', {'name':'ventil_5_rest','type':'number','read':true,'write':false,'role':'number','def':100,'unit':'%','min':0,'max':100}],
         //[basic_vars_pfad+'.ventile.ventil_5.ventil_5_name', {'name':'ventil_5_name','type':'string','read':true,'write':false,'role':'string','def':basic_vars_kreis5_name}],
         [basic_vars_pfad+'.ventile.ventil_5.ventil_5_restzeit', {'name':'ventil_5_restzeit','type': 'string','read':true,'write':false,'role':'string','def':'0:00','unit':'Minuten'}],
         [basic_vars_pfad+'.ventile.ventil_5.ventil_5_restzeit_in_sek', {'name':'ventil_5_restzeit_in_sek','type':'number','read':true,'write':false,'role':'number','def':0,'unit':'Sekunden'}],
         [basic_vars_pfad+'.ventile.ventil_5.ventil_5_status', {'name':'ventil_5_status','type':'boolean','read':true,'write':false,'role':'switch','def':false}],
      createUserStates(basic_vars_speicherort, false, vars_ventil_5);}
      if(basic_vars_anzahl_ventile > 5) {
         let vars_ventil_6 = [
         //Ventil 6
         [basic_vars_pfad+'.ventile.ventil_6.ventil_6', {'name':'ventil_6','type':'boolean','read':true,'write':true,'role':'switch','def':false}],
         [basic_vars_pfad+'.ventile.ventil_6.ventil_6_dauer', {'name': 'ventil_6_dauer','type':'number','read':true,'write':true,'role':'number','def':0,'unit':'Sekunden'}],
         [basic_vars_pfad+'.ventile.ventil_6.ventil_6_dauer_in_min', {'name': 'ventil_6_dauer_in_min','type':'number','read':true,'write':true,'role':'number','def':0,'unit':'Minuten'}],
         [basic_vars_pfad+'.ventile.ventil_6.ventil_6_ende', {'name':'ventil_6_ende','type':'string','read':true,'write':false,'role':'string','def':'00:00','unit':'Uhr'}],
         [basic_vars_pfad+'.ventile.ventil_6.ventil_6_fortschritt', {'name':'ventil_6_fortschritt','type':'number','read':true,'write':false,'role':'number','def':0,'unit':'%','min':0,'max':100}],
         [basic_vars_pfad+'.ventile.ventil_6.ventil_6_rest', {'name':'ventil_6_rest','type':'number','read':true,'write':false,'role':'number','def':100,'unit':'%','min':0,'max':100}],
         //[basic_vars_pfad+'.ventile.ventil_6.ventil_6_name', {'name':'ventil_6_name','type':'string','read':true,'write':false,'role':'string','def':basic_vars_kreis6_name}],
         [basic_vars_pfad+'.ventile.ventil_6.ventil_6_restzeit', {'name':'ventil_6_restzeit','type': 'string','read':true,'write':false,'role':'string','def':'0:00','unit':'Minuten'}],
         [basic_vars_pfad+'.ventile.ventil_6.ventil_6_restzeit_in_sek', {'name':'ventil_6_restzeit_in_sek','type':'number','read':true,'write':false,'role':'number','def':0,'unit':'Sekunden'}],
         [basic_vars_pfad+'.ventile.ventil_6.ventil_6_status', {'name':'ventil_6_status','type':'boolean','read':true,'write':false,'role':'switch','def':false}],
      createUserStates(basic_vars_speicherort, false, vars_ventil_6);}
      //Ab hier nicht benötigte Datenpunkte löschen
      //Ventil 1 wieder löschen
      timeout = setTimeout(function () {
      if(basic_vars_anzahl_ventile < 1 && basic_vars_speicherort.slice(0, 10) == 'javascript') {
      const idsjs = $('javascript.*.'+[basic_vars_pfad]+'.ventile.ventil_1.*');
      idsjs.each(function(id, i) {
      if(existsState(id)) deleteState(id.substring(13));})};
      if(basic_vars_anzahl_ventile < 1 && basic_vars_speicherort.slice(0, 10) == '0_userdata') {
      const idsud = $('0_userdata.0.'+[basic_vars_pfad]+'.ventile.ventil_1.*');
      idsud.each(function(id, i) {
      if(existsState(id)) deleteState(id);})};
      //Ventil 2 wieder löschen
      if(basic_vars_anzahl_ventile < 2 && basic_vars_speicherort.slice(0, 10) == 'javascript') {
      const idsjs = $('javascript.*.'+[basic_vars_pfad]+'.ventile.ventil_2.*');
      if(basic_vars_anzahl_ventile < 2 && basic_vars_speicherort.slice(0, 10) == '0_userdata') {
      const idsud = $('0_userdata.0.'+[basic_vars_pfad]+'.ventile.ventil_2.*');
      //Ventil 3 wieder löschen
      if(basic_vars_anzahl_ventile < 3 && basic_vars_speicherort.slice(0, 10) == 'javascript') {
      const idsjs = $('javascript.*.'+[basic_vars_pfad]+'.ventile.ventil_3.*');
      if(basic_vars_anzahl_ventile < 3 && basic_vars_speicherort.slice(0, 10) == '0_userdata') {
      const idsud = $('0_userdata.0.'+[basic_vars_pfad]+'.ventile.ventil_3.*');
      //Ventil 4 wieder löschen
      if(basic_vars_anzahl_ventile < 4 && basic_vars_speicherort.slice(0, 10) == 'javascript') {
      const idsjs = $('javascript.*.'+[basic_vars_pfad]+'.ventile.ventil_4.*');
      if(basic_vars_anzahl_ventile < 4 && basic_vars_speicherort.slice(0, 10) == '0_userdata') {
      const idsud = $('0_userdata.0.'+[basic_vars_pfad]+'.ventile.ventil_4.*');
      //Ventil 5 wieder löschen
      if(basic_vars_anzahl_ventile < 5 && basic_vars_speicherort.slice(0, 10) == 'javascript') {
      const idsjs = $('javascript.*.'+[basic_vars_pfad]+'.ventile.ventil_5.*');
      if(basic_vars_anzahl_ventile < 5 && basic_vars_speicherort.slice(0, 10) == '0_userdata') {
      const idsud = $('0_userdata.0.'+[basic_vars_pfad]+'.ventile.ventil_5.*');
      //Ventil 6 wieder löschen
      if(basic_vars_anzahl_ventile < 6 && basic_vars_speicherort.slice(0, 10) == 'javascript') {
      const idsjs = $('javascript.*.'+[basic_vars_pfad]+'.ventile.ventil_6.*');
      if(basic_vars_anzahl_ventile < 6 && basic_vars_speicherort.slice(0, 10) == '0_userdata') {
      const idsud = $('0_userdata.0.'+[basic_vars_pfad]+'.ventile.ventil_6.*');
      }, 5000);
      //Funktion main mit Verzögerung aufrufen
         Variablen_definieren();
      }, 5000);
      Mic-M created this issue in ioBroker/ioBroker.javascript
      closed setObject() function: callback not working as intended. #474
      closed 0_userdata.0: existsState() vs. $-Selector $().length after state deletion #478
        sigi234 Forum Testing Most Active @Kuddel last edited by sigi234
        @Kuddel sagte in [Vorlage] Gartenbewässerung mit 6 Ventilen:
        @sigi234 ich meine ja. aber würde ich auf jeden fall morgen noch einmal testen
        Test:
        javascript.0	2020-07-23 21:36:15.275	warn	(25464) You are assigning a object to the state "javascript.0.bewaesserung.ventile.ventil_6.ventil_6_restzeit_in_sek" which expects a number. Please fix your code to use a number or change the state
        RAW:
          "user": "system.user.admin",
          "ts": 1595360262144,
          "common": {
            "name": "ventil_6_restzeit_in_sek",
            "type": "number",
            "role": "number",
            "unit": "Sekunden",
            "def": 0,
            "read": true,
            "write": true
          "native": {},
          "acl": {
            "object": 1636,
            "owner": "system.user.admin",
            "state": 1636
          "_id": "javascript.0.bewaesserung.ventile.ventil_6.ventil_6_restzeit_in_sek",
          "type": "state"
        Ventil 6 geht statt 1 Minute auf 1 Sekunde
          Kuddel @sigi234 last edited by
          @sigi234 danke für die Rückmeldung. Versuche ich heute vormittag nochmal zu testen
            @sigi234
            Bei mir funktioniert Ventil 6 (Shelly) fehlerfrei
            Hast du es merhfach versucht ?
              Ja
                @sigi234 habe gerade die erweiterung von @dslraser zum löschen der nicht mehr benötigten DPs eingebaut.
                • Anzahl Ventile auf 5 geändert
                • Alle DPs für Ventil 6 wurden gelöscht
                • Anzahl Ventile auf 6 geändert
                • Alle DPs für Ventil 6 wurden erstellt
                • Dauer Ventil 6 auf 5 Minuten gestellt
                • Bewässerung manuell gestartet
                  Schon aktuell in bewaesserung_v2.6.8.zip ?
                    @sigi234 bewaesserung_v2.6.9.zip
                      @Kuddel
                      Irgendwas stimmt nicht bei mir.
                      K dslraser 2 Replies Last reply Reply Quote 0
                        Kuddel @sigi234 last edited by Kuddel
                        @sigi234 das sieht irgendwie komisch aus.
                        meine VIS hast du 1 zu 1 importiert ?
                        das z.b. bei der dauer bei 1 min als wert 60 gesendet wird ?
                        Vllt. stellst du mir dein Skript mal zur Verfügung ? Ich würde das bei mir mal laufen lassen
                          Blockly_Kuddel_Bewaesserung_sigi234.zip
                          • dslraser
                            dslraser Forum Testing Most Active @sigi234 last edited by dslraser
                            @sigi234
                            hast Du mal alle "alten" Datenpunkte gelöscht und durch das Blockly neu erstellen lassen ?
                            Es wird so einiges in Admin und JS gepuffert. Die JS Instanz mal neu starten kann auch nicht schaden.
                            Die Admin Instanz auch mal neu starten.
                            Achtung, Admin nicht stoppen, nur neu starten mit dem Pfeilkreis, sonst sperrst Du Dich selbst aus und musst den Admin über die Konsole neu starten.
                            Ob VIS States bzw. den Inhalt puffert weiß ich nicht, ich habe kein VIS.
                              sigi234 Forum Testing Most Active @dslraser last edited by
                              @dslraser sagte in [Vorlage] Gartenbewässerung mit 6 Ventilen:
                              @sigi234
                              hast Du mal alle "alte"n Datenpunkte gelöscht und durch das Blockly neu erstellen lassen ?
                              Ja
                              Ja
                                Ja, aber Ventil 5 kopiert und auf 6 angepasst.
                                  @sigi234
                                  • dein Skript importiert
                                  • Meine DPs alle gelöscht
                                  • DPs neu erstellt
                                  • Deine Aktoren geändert
                                  • Alle Ventile auf Dauer 1 min gestellt
                                  • Lief alles problemlos ohne Fehler durch
                                    Ev. liegt es daran weil ich nur Virtuelle DP habe.
                                      @sigi234 kannst du zum testen mal die direkten States angeben?
                                      • Andreas K
                                        Andreas K @Kuddel last edited by
                                        @Kuddel Danke, für deine Hilfe....
                                        Es wäre so einfach gewesen 😕
                                        Aber dafür hab ich`s jetzt gut erklärt bekommen.
                                        DANKE DANKE DANKE!
                                        Gruss Andi
                                          Habe (noch) keinen Garten. 😀
                                            @sigi234 habe zum testen auch schon mal HM-Steckdosen oder so genommen
                                            sigi234 dslraser 2 Replies Last reply Reply Quote 0
                                            1187
                                            315446
