    4. [gelöst] BUG: sayit funktioniert bei win nicht zuverlässig.
    UNSOLVED [gelöst] BUG: sayit funktioniert bei win nicht zuverlässig.
      apollon77 last edited by
      JETZT bitte nochmal versuchen
        sigi234 Forum Testing Most Active @apollon77 last edited by sigi234
        @apollon77 sagte in BUG: sayit funktioniert unter win nicht zuverlässig.:
        Keine Datei im Ordner
        sayit.0	2020-07-27 18:49:24.451	debug	(21828) Duration "a b c ": 4
        sayit.0	2020-07-27 18:49:24.442	info	(21828) saying: a b c
        sayit.0	2020-07-27 18:49:15.433	debug	(21828) Duration "C:\Program Files\iobroker\Test\node_modules\iobroker.sayit/gong.mp3": 9
        sayit.0	2020-07-27 18:49:15.379	info	(21828) saying: C:\Program Files\iobroker\Test\node_modules\iobroker.sayit/gong.mp3
        javascript.0	2020-07-27 18:49:15.375	info	(27232) script.js.Test.sayit: registered 0 subscriptions and 0 schedules
        javascript.0	2020-07-27 18:49:15.370	info	(27232) Start javascript script.js.Test.sayit
        javascript.0	2020-07-27 18:49:15.363	info	(27232) Stop script script.js.Test.sayit
        sayit.0	2020-07-27 18:48:50.439	debug	(21828) system.adapter.admin.0: logging true
        sayit.0	2020-07-27 18:48:44.846	info	(21828) All files uploaded
        sayit.0	2020-07-27 18:48:44.714	info	(21828) Upload announce mp3 files
        sayit.0	2020-07-27 18:48:44.692	info	(21828) starting. Version 1.10.2 in C:/Program Files/iobroker/Test/node_modules/iobroker.sayit, node: v12.18.0, js-controller: 3.1.6
        sayit.0	2020-07-27 18:48:44.460	debug	(21828) Plugin sentry Initialize Plugin (enabled=true)
        sayit.0	2020-07-27 18:48:44.132	debug	(21828) statesDB connected
        sayit.0	2020-07-27 18:48:44.132	debug	(21828) States connected to redis: 127.0.0.1:9000
        sayit.0	2020-07-27 18:48:44.102	debug	(21828) States create System PubSub Client
        sayit.0	2020-07-27 18:48:44.081	debug	(21828) States create User PubSub Client
        sayit.0	2020-07-27 18:48:44.055	debug	(21828) Redis States: Use Redis connection: 127.0.0.1:9000
        sayit.0	2020-07-27 18:48:44.054	debug	(21828) objectDB connected
        sayit.0	2020-07-27 18:48:44.051	debug	(21828) Objects connected to redis: 127.0.0.1:9013
        sayit.0	2020-07-27 18:48:44.024	debug	(21828) Objects client initialize lua scripts
        sayit.0	2020-07-27 18:48:44.023	debug	(21828) Objects create User PubSub Client
        sayit.0	2020-07-27 18:48:44.023	debug	(21828) Objects create System PubSub Client
        sayit.0	2020-07-27 18:48:43.844	debug	(21828) Objects client ready ... initialize now
        sayit.0	2020-07-27 18:48:43.102	debug	(21828) Redis Objects: Use Redis connection: 127.0.0.1:9013
        host.Medion(Test)	2020-07-27 18:48:42.247	info	instance system.adapter.sayit.0 started with pid 21828
        host.Medion(Test)	2020-07-27 18:48:39.174	info	instance system.adapter.sayit.0 terminated with code null ()
        host.Medion(Test)	2020-07-27 18:48:39.173	warn	instance system.adapter.sayit.0 terminated due to SIGTERM
        host.Medion(Test)	2020-07-27 18:48:39.138	info	stopInstance timeout 1000 system.adapter.sayit.0 killing pid 25740
        host.Medion(Test)	2020-07-27 18:48:38.124	info	stopInstance system.adapter.sayit.0 (force=false, process=true)
        host.Medion(Test)	2020-07-27 18:48:09.929	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        ical.0	2020-07-27 18:48:09.427	info	(17472) Terminated (NO_ERROR): Without reason
        ical.0	2020-07-27 18:48:03.652	info	(17472) processing URL: Sigi https://calendar.google.com/calendar/ical/sigiking1%40gmail.com/private-0889be050404ce26f3cfb9051ca62c90/basic.ics
        ical.0	2020-07-27 18:48:02.114	info	(17472) starting. Version 1.7.0 in C:/Program Files/iobroker/Test/node_modules/iobroker.ical, node: v12.18.0, js-controller: 3.1.6
        host.Medion(Test)	2020-07-27 18:48:00.216	info	instance system.adapter.ical.0 started with pid 17472
        javascript.0	2020-07-27 18:47:38.596	info	(27232) script.js.Test.sayit: registered 0 subscriptions and 0 schedules
        • bahnuhr
          So,
          Installation hat geklappt.
          mp3 wird jetzt gespeichert in:
          C:\iobroker\iobroker-data\sayit
          Ist das richtig ?
          Oder wäre es nicht besser unter: ...iobroker-data/file/sayit.2
          Fazit:
          busy kommt weiterhin wenn die Datei erzeugt wurde und keine vorher angeklickt wurde.
          Genauer:
          mp3 erzeugt
          nix gemacht
          mp3 erzeugt -> busy
          oder
          mp3 erzeugt
          andere mp3 angeklickt
          mp3 erzeugt -> kein busy
          • bahnuhr
            So, ich bin noch eins weiter !!
            iob läuft auf nuc mit win10
            sayit.2 hat die Instanz von nuc mit win10
            sayit.4 hat die Instanz vom Surface im Wohnzimmer ebenfalls mit win10
            Wenn ich Script starte: setState('sayit.4.tts.text', "test ab2");
            dann kann mann dies so viel ändern wie man will die mp3 wird korrekt erzeugt.
            Wenn ich Script starte: setState('sayit.2.tts.text', "test ab2");
            dann kommt o.g. Verhalten.
            Fazit von mir:
            Sayit.2 zeigt "busy" auf dem Rechner wo iob läuft.
            Auf dem anderen Rechner wo iob nicht läuft klappt alles wie gewollt.
            Kann man dies verstehen ?
            • bahnuhr
              So, ich geb jetzt auf.
              Hab gedacht ich hätte es.
              wmp geschlossen und dann ging es.
              Aber nur kurz.
              manchmal steht im log "copied" dann ist die mp3 richtig.
              Aber manchmal auch nicht. Dann wird die mp3 richtig angesagt aber die Datei ist noch die alte.
              Ich versteh das nicht.
              mfg
              Dieter
                apollon77 @bahnuhr last edited by
                @bahnuhr sagte in BUG: sayit funktioniert unter win nicht zuverlässig.:
                Ist das richtig ?
                Ja korrekt. Und nein nicht in files/ 😉
                  Homoran Global Moderator Administrators @apollon77 last edited by
                  @bahnuhr Naja ok dann ists ja aber nichts mit "jemand blockt Sie wegen abspielen"
                  Es ist Windows selber, das die Datei nach dem schreiben noch nicht wieder freigibt.
                  Erst wenn Windows eine andere Datei anfassen muss lässt es die alte los.
                  Zumindest war das meine Beobachtung
                  • bahnuhr
                    bahnuhr Forum Testing Most Active @Homoran last edited by
                    @Homoran sagte in BUG: sayit funktioniert unter win nicht zuverlässig.:
                    das kann schon sein.
                    Aber ne Lösung ist das nicht.
                      na ok mit der Annahme ... lasst mich mal was versuchen 😉
                        Bzw ... hast DU mal versucht das Caching einzuschalten? Dann wird in jedem Fall noch eine zweite Datei geschrieben 🙂 Vllt reicht das ja
                        • bahnuhr
                          bahnuhr Forum Testing Most Active @apollon77 last edited by
                          wie und wo ist das ?
                            @bahnuhr Im Admin kannst Du ein cacheDirectory setzen
                            • bahnuhr
                              In der Instanz admin hab ich dies nicht.
                              Auch bei dem Schraubenschlüssel auf der Übersichtsseite oben gibt es dies auch nicht.
                              Kannst du bitte mal genauer schreiben wo dies sein soll.
                                @bahnuhr Hm ... egal ... ist Standardmässig an ... und denke einstellbar bei den Cloud-Generatoren
                                • bahnuhr
                                  bahnuhr Forum Testing Most Active @bahnuhr last edited by
                                  Wie hier schon erwähnt wird nur manchmal kopiert (Logik ist für mich nicht ersichtlich).
                                  Kann man dies ändern?
                                  Also jedes mal speichern.
                                  Dann müsste doch die mp3 richtig sein.
                                    @bahnuhr Log?
                                    • bahnuhr
                                      @bahnuhr Log?
                                      Gerne.
                                      Die ersten beiden Mal hat er nicht kopiert. Die nächsten Male aber doch.
                                      Vielleicht hilfst weiter.
                                      sayit.2	2020-07-28 13:42:53.605	debug	(146500) Duration "x y z": 3
                                      sayit.2	2020-07-28 13:42:53.505	info	(146500) Copied file "C:\iobroker\iobroker-data\sayit/sayit.2.say.mp3" to "C:\iobroker\cache\870dc326c1db7d0947a8cabda92536e2.mp3"
                                      sayit.2	2020-07-28 13:42:53.503	debug	(146500) Caching File C:\iobroker\cache\870dc326c1db7d0947a8cabda92536e2.mp3 for "de-DE_CLOUD_Female;x y z" now
                                      sayit.2	2020-07-28 13:42:53.502	debug	(146500) Status code: 200
                                      sayit.2	2020-07-28 13:42:53.321	debug	(146500) Cache File C:\iobroker\cache\870dc326c1db7d0947a8cabda92536e2.mp3 for "de-DE_CLOUD_Female;x y z" not found
                                      sayit.2	2020-07-28 13:42:53.321	info	(146500) saying: x y z
                                      sayit.2	2020-07-28 13:42:10.571	debug	(146500) Duration "test 1 2 ": 2
                                      sayit.2	2020-07-28 13:42:10.569	info	(146500) Copied file "C:\iobroker\iobroker-data\sayit/sayit.2.say.mp3" to "C:\iobroker\cache\6a9f31711abaa6d2303693eb16ff2686.mp3"
                                      sayit.2	2020-07-28 13:42:10.567	debug	(146500) Caching File C:\iobroker\cache\6a9f31711abaa6d2303693eb16ff2686.mp3 for "de-DE_CLOUD_Female;test 1 2 " now
                                      sayit.2	2020-07-28 13:42:10.565	debug	(146500) Status code: 200
                                      sayit.2	2020-07-28 13:42:10.401	debug	(146500) Cache File C:\iobroker\cache\6a9f31711abaa6d2303693eb16ff2686.mp3 for "de-DE_CLOUD_Female;test 1 2 " not found
                                      sayit.2	2020-07-28 13:42:10.401	info	(146500) saying: test 1 2
                                      sayit.2	2020-07-28 13:41:42.927	debug	(146500) Duration "1 2 3 4 5 ": 3
                                      sayit.2	2020-07-28 13:41:42.924	info	(146500) Copied file "C:\iobroker\iobroker-data\sayit/sayit.2.say.mp3" to "C:\iobroker\cache\9f64f57da4f54dfb6225235430ed13a9.mp3"
                                      sayit.2	2020-07-28 13:41:42.923	debug	(146500) Caching File C:\iobroker\cache\9f64f57da4f54dfb6225235430ed13a9.mp3 for "de-DE_CLOUD_Female;1 2 3 4 5 " now
                                      sayit.2	2020-07-28 13:41:42.922	debug	(146500) Status code: 200
                                      sayit.2	2020-07-28 13:41:42.748	debug	(146500) Cache File C:\iobroker\cache\9f64f57da4f54dfb6225235430ed13a9.mp3 for "de-DE_CLOUD_Female;1 2 3 4 5 " not found
                                      sayit.2	2020-07-28 13:41:42.748	info	(146500) saying: 1 2 3 4 5
                                      sayit.2	2020-07-28 13:41:11.051	debug	(146500) Duration "a b c d ": 2
                                      sayit.2	2020-07-28 13:41:11.049	info	(146500) Copied file "C:\iobroker\iobroker-data\sayit/sayit.2.say.mp3" to "C:\iobroker\cache\bee5de77c6cefefd29409e80ad13af2a.mp3"
                                      sayit.2	2020-07-28 13:41:11.048	debug	(146500) Caching File C:\iobroker\cache\bee5de77c6cefefd29409e80ad13af2a.mp3 for "de-DE_CLOUD_Female;a b c d " now
                                      sayit.2	2020-07-28 13:41:11.047	debug	(146500) Status code: 200
                                      sayit.2	2020-07-28 13:41:10.856	debug	(146500) Cache File C:\iobroker\cache\bee5de77c6cefefd29409e80ad13af2a.mp3 for "de-DE_CLOUD_Female;a b c d " not found
                                      sayit.2	2020-07-28 13:41:10.856	info	(146500) saying: a b c d
                                      sayit.2	2020-07-28 13:40:37.353	debug	(146500) Duration "Hallo": 1
                                      sayit.2	2020-07-28 13:40:37.352	info	(146500) Copied file "C:\iobroker\iobroker-data\sayit/sayit.2.say.mp3" to "C:\iobroker\cache\b9732e55d1e0743f0374dfbe0a5ac64e.mp3"
                                      sayit.2	2020-07-28 13:40:37.345	debug	(146500) Caching File C:\iobroker\cache\b9732e55d1e0743f0374dfbe0a5ac64e.mp3 for "de-DE_CLOUD_Female;Hallo" now
                                      sayit.2	2020-07-28 13:40:37.335	debug	(146500) Status code: 200
                                      sayit.2	2020-07-28 13:40:37.075	debug	(146500) Cache File C:\iobroker\cache\b9732e55d1e0743f0374dfbe0a5ac64e.mp3 for "de-DE_CLOUD_Female;Hallo" not found
                                      sayit.2	2020-07-28 13:40:37.075	info	(146500) saying: Hallo
                                      sayit.2	2020-07-28 13:39:53.032	debug	(146500) Duration "test 2": 2
                                      sayit.2	2020-07-28 13:39:53.025	info	(146500) saying: test 2
                                      sayit.2	2020-07-28 13:39:19.511	debug	(146500) Duration "test 3": 2
                                      sayit.2	2020-07-28 13:39:19.480	info	(146500) saying: test 3
                                        apollon77 @bahnuhr last edited by apollon77
                                        Copied
                                        Das wird über einen Stream gemacht ... und mit genau denen hatten wir bei Windows schonmal Probleme beim Logging.
                                        Update nochmal ... ich hab mal jetzt copyFile von nodejs verwendet ... gibts aber erst ab nodejs 8, aber da sist jetzt EOL ... also braucht nodejs 8.5+ dann jetzt!
                                        • bahnuhr
                                          @apollon77
                                          sayit.2	2020-07-28 15:07:58.410	debug	(6764) Duration "test 1 2 3": 3
                                          sayit.2	2020-07-28 15:07:58.404	info	(6764) saying: test 1 2 3
                                          sayit.2	2020-07-28 15:07:31.935	debug	(6764) Duration "test 1 2 3": 3
                                          sayit.2	2020-07-28 15:07:31.933	info	(6764) Copied file "C:\iobroker\iobroker-data\sayit/sayit.2.say.mp3" to "C:\iobroker\cache\05b3c89f93969b153a9d5d986b7ec4ab.mp3"
                                          sayit.2	2020-07-28 15:07:31.933	debug	(6764) Caching File C:\iobroker\cache\05b3c89f93969b153a9d5d986b7ec4ab.mp3 for "de-DE_CLOUD_Female;test 1 2 3" now
                                          sayit.2	2020-07-28 15:07:31.931	debug	(6764) Status code: 200
                                          sayit.2	2020-07-28 15:07:31.752	debug	(6764) Cache File C:\iobroker\cache\05b3c89f93969b153a9d5d986b7ec4ab.mp3 for "de-DE_CLOUD_Female;test 1 2 3" not found
                                          sayit.2	2020-07-28 15:07:31.752	info	(6764) saying: test 1 2 3
                                          sayit.2	2020-07-28 15:07:11.130	debug	(6764) Duration "test abcdef": 2
                                          sayit.2	2020-07-28 15:07:11.128	info	(6764) Copied file "C:\iobroker\iobroker-data\sayit/sayit.2.say.mp3" to "C:\iobroker\cache\aa7106ec4140aa0958c7214f7e202a02.mp3"
                                          sayit.2	2020-07-28 15:07:11.125	debug	(6764) Caching File C:\iobroker\cache\aa7106ec4140aa0958c7214f7e202a02.mp3 for "de-DE_CLOUD_Female;test abcdef" now
                                          sayit.2	2020-07-28 15:07:11.120	debug	(6764) Status code: 200
                                          sayit.2	2020-07-28 15:07:10.899	debug	(6764) Cache File C:\iobroker\cache\aa7106ec4140aa0958c7214f7e202a02.mp3 for "de-DE_CLOUD_Female;test abcdef" not found
                                          sayit.2	2020-07-28 15:07:10.899	info	(6764) saying: test abcdef
                                          Log sieht vergleichbar aus.
                                          Kann es sein, wenn man den gleichen Befehl nochmal sendet, dass dann der copy Befehl nicht kommt.
                                          Siehe log ganz oben.
                                            @apollon77
                                            Geht jetzt bei mir.
                                            sayit.0	2020-07-28 15:06:58.078	info	(11460) Copied file "C:\Program Files\iobroker\Test\iobroker-data\sayit/sayit.0.say.mp3" to "C:\Program Files\iobroker\Test\cache\d72f7f703b392c5f75121b51ee14540e.mp3"
                                            bug sayit
                                            4601
