    4. JavaScript
    5. [Vorlage] Flexibles Timerskript + Vis
    • gelberlemmy
      gelberlemmy last edited by
      @Pittini
      so nach dem Starten des Skriptes:
      javascript.0	2020-07-27 20:50:00.031	info	(4109) script.js.common.Timer_Target: Reaching MakeTable
      javascript.0	2020-07-27 20:50:00.030	info	(4109) script.js.common.Timer_Target: Reaching SetLockStates() TriggerIndex=-1 SwitchingTimerIndex=0
      javascript.0	2020-07-27 20:50:00.029	info	(4109) script.js.common.Timer_Target: Reaching Meldung, msg= Timer 1, Virtuelle Devices.0, hat ausgeschaltet
      javascript.0	2020-07-27 20:50:00.028	info	(4109) script.js.common.Timer_Target: Timer 1, Virtuelle Devices.0, switched off
      javascript.0	2020-07-27 20:50:00.025	info	(4109) script.js.common.Timer_Target: Reaching DoAction(), aktiv=true Rolle=0 whichone=0 Presence=true MyTimer[whichone][13]=Virtuelle_Devices.0.Gartenbewäserung MyTimer[whichone][14]=true
      javascript.0	2020-07-27 20:49:46.880	info	(4109) script.js.common.Timer_Target: Reaching MakeTable
      javascript.0	2020-07-27 20:49:46.879	info	(4109) script.js.common.Timer_Target: New TargetNames are:Virtuelle Devices.0
      javascript.0	2020-07-27 20:49:46.878	info	(4109) script.js.common.Timer_Target: Possible Target are:Virtuelle_Devices.0.Gartenbewäserung
      javascript.0	2020-07-27 20:49:46.878	info	(4109) script.js.common.Timer_Target: Original TargetNames are:Virtuelle Devices.0
      javascript.0	2020-07-27 20:49:46.878	info	(4109) script.js.common.Timer_Target: Reaching CreateTimerTargetsNameList()
      javascript.0	2020-07-27 20:49:46.877	info	(4109) script.js.common.Timer_Target: Reaching SetTimer(whichone=,1 GoToTommorrow=false)
      javascript.0	2020-07-27 20:49:46.876	info	(4109) script.js.common.Timer_Target: Timer CreateState(s) finished!
      javascript.0	2020-07-27 20:49:46.840	info	(4109) script.js.common.Timer_Target: CronString for Timer 1 created 00 50 20 * * *
      javascript.0	2020-07-27 20:49:46.839	info	(4109) script.js.common.Timer_Target: Reaching MakeCronString(whichone=0)
      javascript.0	2020-07-27 20:49:46.838	info	(4109) script.js.common.Timer_Target: Reaching CreateTimeDaysString(whichone=0)
      javascript.0	2020-07-27 20:49:46.838	info	(4109) script.js.common.Timer_Target: Timer 1 will be set, GoToTommorrow=false
      javascript.0	2020-07-27 20:49:46.837	info	(4109) script.js.common.Timer_Target: Reaching SetTimer(whichone=,0 GoToTommorrow=false)
      javascript.0	2020-07-27 20:49:46.837	info	(4109) script.js.common.Timer_Target: Reaching CreateDeviceTrigger() Trigger added for Virtuelle_Devices.0.Gartenbewäserung whichone= 0
      javascript.0	2020-07-27 20:49:46.835	info	(4109) script.js.common.Timer_Target: Timer CreateState(s) finished!
      javascript.0	2020-07-27 20:49:46.829	info	(4109) script.js.common.Timer_Target: Reaching CreateTrigger()
      javascript.0	2020-07-27 20:49:46.828	info	(4109) script.js.common.Timer_Target: Reaching ConvertPresence. TempPresence=true
      javascript.0	2020-07-27 20:49:46.827	info	(4109) script.js.common.Timer_Target: Reaching SetValueListPairs()
      javascript.0	2020-07-27 20:49:46.826	info	(4109) script.js.common.Timer_Target: Reaching CreateTimerCountList()
      javascript.0	2020-07-27 20:49:46.820	info	(4109) script.js.common.Timer_Target: Reaching Init()
      javascript.0	2020-07-27 20:49:46.820	info	(4109) script.js.common.Timer_Target: Reaching Main
      javascript.0	2020-07-27 20:49:46.819	info	(4109) script.js.common.Timer_Target: Initial CreateStates finished!
      javascript.0	2020-07-27 20:49:46.807	info	(4109) script.js.common.Timer_Target: registered 0 subscriptions and 0 schedules
      javascript.0	2020-07-27 20:49:46.800	info	(4109) script.js.common.Timer_Target: Starting TimerSkript V2.1.5
      javascript.0	2020-07-27 20:49:46.777	info	(4109) Start javascript script.js.common.Timer_Target
      javascript.0	2020-07-27 20:49:29.718	info	(4109) script.js.common.Timer_Target: Timer Schedule 2 killed
      javascript.0	2020-07-27 20:49:29.718	info	(4109) script.js.common.Timer_Target: Timer Schedule 1 killed
      javascript.0	2020-07-27 20:49:29.709	info	(4109) Stop script script.js.common.Timer_Target
      Jetzt nachdem ich den Browser aktualisiert habe und nur "undefined" in allen Auswahlspalten habe. Einfach einmal eine Spalte angeklickt :
      javascript.0	2020-07-27 20:53:39.087	error	(4109) at processImmediate (internal/timers.js:456:21)
      javascript.0	2020-07-27 20:53:39.087	error	(4109) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
      javascript.0	2020-07-27 20:53:39.087	error	(4109) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
      javascript.0	2020-07-27 20:53:39.087	error	(4109) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
      javascript.0	2020-07-27 20:53:39.086	error	(4109) at Object.<anonymous> (script.js.common.Timer_Target:1105:98)
      javascript.0	2020-07-27 20:53:39.086	error	(4109) at DetermineNextActiveAstroDay (script.js.common.Timer_Target:513:32)
      javascript.0	2020-07-27 20:53:39.086	error	(4109) at CheckTodayAstroIsOver (script.js.common.Timer_Target:624:15)
      javascript.0	2020-07-27 20:53:39.085	error	(4109) Error in callback: TypeError: Cannot read property 'setMinutes' of undefined
      javascript.0	2020-07-27 20:53:39.066	error	(4109) Cannot get astro date for "undefined"
      javascript.0	2020-07-27 20:53:39.064	info	(4109) script.js.common.Timer_Target: Reaching CheckTodayAstroIsOver(AstroChoice=undefined Shift=0)
      javascript.0	2020-07-27 20:53:39.062	info	(4109) script.js.common.Timer_Target: Reaching DetermineNextActiveAstroDay(whichone=-1 GoToTommorrow=false)
      javascript.0	2020-07-27 20:53:39.061	info	(4109) script.js.common.Timer_Target: Astro choosen
      javascript.0	2020-07-27 20:53:39.061	info	(4109) script.js.common.Timer_Target: Reaching MakeTable
      javascript.0	2020-07-27 20:53:39.060	info	(4109) script.js.common.Timer_Target: Reaching SwitchEditMode(whichone, onoff), whichonex=undefined TimerCount=2 onoff=true
      javascript.0	2020-07-27 20:53:02.988	info	(4109) script.js.common.Timer_Target: Template TimerTarget changed, typeof=string Wert=
      javascript.0	2020-07-27 20:53:02.959	info	(4109) script.js.common.Timer_Target: Timertemplate changed to undefined
      javascript.0	2020-07-27 20:53:02.958	info	(4109) script.js.common.Timer_Target: Reaching MakeTable
      javascript.0	2020-07-27 20:53:02.958	info	(4109) script.js.common.Timer_Target: Reaching SwitchEditMode(whichone, onoff), whichonex=0 TimerCount=2 onoff=false
      javascript.0	2020-07-27 20:53:02.955	info	(4109) script.js.common.Timer_Target: Typeof MyTimer[undefined]=undefined
      javascript.0	2020-07-27 20:53:02.954	info	(4109) script.js.common.Timer_Target: Reaching WriteToTemplate(whichone), whichone=undefined
      Ich hoffe damit kann etwas anfangen. So Script ist das Pausenzeichen wieder auf "gelb" Skript neu gestartet. Und nun läuft es wieder
      Gruß André
        Pittini Developer last edited by
        @gelberlemmy sagte in [Vorlage] Flexibles Timerskript + Vis:
        Also das ist ein sehr seltsamer Fehler und ich bin mir fast sicher dasses nicht am Skript liegt. Also müssen wir das mal eingrenzen. Das erste Log oben schaut ok aus, es wurde wohl auch korrekt geschaltet.
        Beim 2ten Log sind plötzlich Werte "undefined" also nicht vorhanden. Auch das das beim klicken ins Vis passiert ist seltsam, da sollte nämlich gar nix passieren, erst bei Änderung eines Wertes darf da was passieren.
        Beschreibe bitte mal wirklich Schritt für Schritt was Du machst und zeig mir bitte nen Screenshot aus der Objektliste den aufgeklappten Ordner "javascript.0.Timer", sowie Screenshots von den aufgeklappten Channels 0,1, und Template.
        • gelberlemmy
          @Pittini
          Danke für die schnelle Rückmeldung.
          Wie folgt:
          1. nach dem Start des Skriptes läuft die Seite mit dem Timer problemlos.
          2. manuelle aktualisierung des Webbrowsers.
          3. Ansicht nur noch die obere Zeile wo die Daten bearbeitet werden. Angelegte Timer nicht sichtbar.
          4. Anklicken eines Feldes erscheinen die angelegten Timer wieder.
          5. Auswahlen in der oberen Zeilen nur noch "undefined" Bearbeiten bestehenden Timer nicht möglich.
          6. Fehlermeldungen im LOG. Skript Pausenzeichen gelb.
          7. Stop dann Start des Skriptes, alles wieder in Funktion.
          Siehe auch die Bilder aus meinem ersten Post. Dort kann man gut sehen, dass dort nur die oberen Zeilemn angezeigt werden.
          Anbei die Bilder der Objektwerte:
          Gruß André
            Pittini Developer @gelberlemmy last edited by
            @gelberlemmy
            Nochmal zur Sicherheit. Du installierst das Skript, Du stellst via Vis nen Timer (oder auch mehrere) ein. Setzen und ändern/löschen/hinzufügen funktioniert einwandfrei, die Timer schalten auch.
            Dann machst Du ne manuelle Aktualisierung des Browsers und zack isses kacke? Is das korrekt nachvollzogen so?
            gelberlemmy P 2 Replies Last reply Reply Quote 0
            • gelberlemmy
              gelberlemmy @Pittini last edited by
              @Pittini ja so ist es. Dann Neustart Skript und alles wieder schön
                Schon mal Browsercache leeren probiert? Schon mal mit nem anderen Browser probiert? Wenn nein, bitte beides mal machen.
                gelberlemmy 1 Reply Last reply Reply Quote 0
                • gelberlemmy
                  @Pittini sagte in [Vorlage] Flexibles Timerskript + Vis:
                  Ja den Cache habe ich bereits mehrfach gelöscht.
                  Auch mit anderen Browsern das Problem. Chrome und FireFox auf PC, Fully Kiosk auf Tablet und Chrome auf einem Android Smartphone.
                    deta Most Active last edited by
                    Nur zur Info, ich hab gestern aktuelle vom Git installiert und bei mir ist alles sofort nach neustart des Skrippt sichtbar gewesen. Keine Probleme.
                      @gelberlemmy Nur mal als Test ins blaue. Mach mal aus der 500 in Zeile 1155 ne 1000, dann speichern und testen bitte.
                      • gelberlemmy
                        Leider keine Änderung
                          Pittini Developer @Pittini last edited by
                          Ok, dann fällt mir grad offiziell nix mehr ein, vermutlich is der Effekt nach irgendeinem update weg, aber das kanns natürlich ned sein. Evtl. fällt ja @Dutchman oder @apollon77 oder @AlCalzone was dazu ein.
                          • AlCalzone
                            AlCalzone Developer @Pittini last edited by
                            Evtl. fällt ja @AlCalzone was dazu ein.
                            dazu bräuchte ich mal ein tl;dr, damit ich nicht den ganzen Thread nach Infos durchstöbern muss.
                              Pittini Developer @AlCalzone last edited by
                              @AlCalzone sagte in [Vorlage] Flexibles Timerskript + Vis:
                              Ok, gern, hier Zusammenfassung:
                              @gelberlemmy hat mein Timerskript installiert. Es funktioniert alles wie es soll (haben auch inzwischen etliche Leuts ohne Probleme laufen), allerdings funktionierts nur solange bis er nen manuellen Browserrefresh macht. Danach steigt das Skript aus. Die Logs sagen mir, es steigt aus weil "undefined" Werte in Dps geschrieben werden die da nix zu suchen haben. Das Problem ist, ich hab null Ahnung warum. Die Logs dazu siehste hier: https://forum.iobroker.net/topic/33228/vorlage-flexibles-timerskript-vis/229 und hier is der Ursprungspost zum Thema https://forum.iobroker.net/topic/33228/vorlage-flexibles-timerskript-vis/219
                              Das Startlog ist völlig normal, alles bestens, Timer wird gesetzt, Timer wird ausgeführt. Im Log drunter siehste dann schon dass da undefined Werte reinkommen, dass das Skript da dann aussteigt is soweit klar und logisch. Nur woher kommen die Werte beim Browseraktualisieren?
                              Als Massnahme wurde bereits durchgeführt: Browsercache leeren, anderen Browser verwenden, Skriptverzeichnis löschen und Dps neu erstellen lassen, JS Instanz neustarten.
                              • AlCalzone
                                @Pittini Browser-Refresh dürfte keinen Einfluss auf Variablen in Skripten haben, da diese im Backend (ioBroker) laufen.
                                Die fragliche Zeile (631) verwendet eine Astro-Zeit, ohne zu prüfen, ob diese existiert. Es gibt ein paar Astro-Events, die an bestimmten Breitengraden zu bestimmten Jahreszeiten nicht existieren.
                                Ich vermute, das ist die Ursache.
                                  Hm, glaub ich eigentlich nicht, läßt sich aber ja leicht verifizieren indem wir @gelberlemmy mal fragen ob er überhaupt nen Astrotimer verwendet hatte. Ich seh das Problem hier:
                                  Die Variable whichone legt fest welcher Timer in die TemplateDps geschrieben wird, wenn da ein undefined kommt kann nur murks rauskommen, nur woher kommt das undefined?
                                  Das Skript is so aufgebaut das je nachdem, welcher Timer in ner Valuelist gewählt wird, die Werte dieses Timers in ein Template geschrieben wird, worauf sich das Vis bezieht. Beim klick auf des speichernbutton werden die Werte ausm (jetzt ja geänderten) Template in die eigentlichen TimerDps zurückgeschrieben. Iwo da vermute ich passiert was, aber wie gesagt ich komm da ned weiter.
                                  Das ganze funktioniert bisher einwandfrei und ich glaub auch ned mal dasses am Skript liegt, kanns aber halt auch ned ausschliessen bevor die wahre Ursache gefunden wurde.
                                  • AlCalzone
                                    Wieso nicht? Steht doch in mehreren Logs oben:
                                    javascript.0	2020-07-26 18:12:22.858	error	(2508) at CheckTodayAstroIsOver (script.js.Meine_Scripte.Timersteuerung:631:15)
                                    javascript.0	2020-07-26 18:12:22.857	error	(2508) Error in callback: TypeError: Cannot read property 'setMinutes' of undefined
                                    javascript.0	2020-07-26 18:12:22.848	error	(2508) Cannot get astro date for "time"
                                    Ich würde jetzt nicht pauschal ausschließen wollen, dass das nicht doch dafür sorgt, dass ungewollte Werte in DPs landen.
                                    • gelberlemmy
                                      Moin, also ich habe noch nie einen Astro Tier verwendet. Immer nur eine Schaltung zur bestimmten Uhrzeit.
                                        Jaein, das isn Folgefehler. Ich hab da ne Abfrage drin die auf !time prüft und da fällt natürlich das undefined drunter, gedacht war wenns nicht time ist, musses Astro sein, deswegen springt er in den falshen Zweig dann. Es bleibt aber immer noch die Frage, woher kommt das undefined das das auslöst. Ich fang das jetzt mal ab, dann soll @gelberlemmy mal posten wie oder was sich am Fehler geändert hat.
                                        @gelberlemmy bitte mal Zeile 1110 ändern von:
                                                    if (x == 5 && dp.state.val != "time") { //TimerChoice geändert und Astro gewählt
                                        auf:
                                                    if (x == 5 && dp.state.val != "time" && typeof dp.state.val != "undefined") { //TimerChoice geändert und Astro gewählt
                                        Dann bitte mal testen und ggfs. das entstandene Log wieder hier posten.
                                        • gelberlemmy
                                          @Pittini danke für die Arbeit. Werde es nachher einmal probieren
                                          • gelberlemmy
                                            gelberlemmy @gelberlemmy last edited by
                                            @gelberlemmy
                                            so keine Änderung. Die Fehlermeldungen gehen auch erst los, sobald ich in den Spalten "undefined" auswähle.
                                            javascript.0	2020-07-31 21:13:37.206	error	(21270) at processImmediate (internal/timers.js:456:21)
                                            javascript.0	2020-07-31 21:13:37.206	error	(21270) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
                                            javascript.0	2020-07-31 21:13:37.205	error	(21270) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
                                            javascript.0	2020-07-31 21:13:37.205	error	(21270) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
                                            javascript.0	2020-07-31 21:13:37.204	error	(21270) at Object.<anonymous> (script.js.common.TimerTarget:1112:98)
                                            javascript.0	2020-07-31 21:13:37.204	error	(21270) at DetermineNextActiveAstroDay (script.js.common.TimerTarget:520:32)
                                            javascript.0	2020-07-31 21:13:37.203	error	(21270) at CheckTodayAstroIsOver (script.js.common.TimerTarget:631:15)
                                            javascript.0	2020-07-31 21:13:37.203	error	(21270) Error in callback: TypeError: Cannot read property 'setMinutes' of undefined
                                            javascript.0	2020-07-31 21:13:37.199	error	(21270) Cannot get astro date for "undefined"
                                            javascript.0	2020-07-31 21:13:37.198	info	(21270) script.js.common.TimerTarget: Reaching CheckTodayAstroIsOver(AstroChoice=undefined Shift=0)
                                            javascript.0	2020-07-31 21:13:37.198	info	(21270) script.js.common.TimerTarget: Reaching DetermineNextActiveAstroDay(whichone=-1 GoToTommorrow=false)
                                            javascript.0	2020-07-31 21:13:37.197	info	(21270) script.js.common.TimerTarget: Astro choosen
                                            javascript.0	2020-07-31 21:13:37.196	info	(21270) script.js.common.TimerTarget: Reaching MakeTable
                                            javascript.0	2020-07-31 21:13:37.195	info	(21270) script.js.common.TimerTarget: Reaching SwitchEditMode(whichone, onoff), whichonex=undefined TimerCount=1 onoff=true
                                            javascript.0	2020-07-31 21:13:33.022	info	(21270) script.js.common.TimerTarget: Reaching MakeTable
                                            javascript.0	2020-07-31 21:13:33.021	info	(21270) script.js.common.TimerTarget: Reaching SwitchEditMode(whichone, onoff), whichonex=undefined TimerCount=1 onoff=true
                                            javascript.0	2020-07-31 21:13:22.307	info	(21270) script.js.common.TimerTarget: Template TimerTarget changed, typeof=string Wert=
                                            javascript.0	2020-07-31 21:13:22.267	info	(21270) script.js.common.TimerTarget: Timertemplate changed to undefined
                                            javascript.0	2020-07-31 21:13:22.266	info	(21270) script.js.common.TimerTarget: Reaching MakeTable
                                            javascript.0	2020-07-31 21:13:22.266	info	(21270) script.js.common.TimerTarget: Reaching SwitchEditMode(whichone, onoff), whichonex=0 TimerCount=1 onoff=false
                                            javascript.0	2020-07-31 21:13:22.263	info	(21270) script.js.common.TimerTarget: Typeof MyTimer[undefined]=undefined
                                            javascript.0	2020-07-31 21:13:22.262	info	(21270) script.js.common.TimerTarget: Reaching WriteToTemplate(whichone), whichone=undefined
                                            javascript template
                                            40
                                            500
                                            111863
