    4. Test Adapter deConz v2.0.x
    • Jey Cee
      Jey Cee Developer @comchris last edited by
      @comchris kannst du bitte den Adapter löschen und neu installieren. Ich hab eine Log Ausgabe an der Stelle eingebaut wo der Fehler auftritt.
      Kannst du mir dann bitte das Log hier zeigen.
        Hallo Jey Cee,
        anbei das Log hab den Adapter komplett deinstalliert und dann neu von der Katze...
        deconz.0	2020-07-26 14:27:30.231	info	(7763) Terminated (NO_ERROR): Without reason
        deconz.0	2020-07-26 14:27:30.231	debug	(7763) Plugin sentry destroyed
        deconz.0	2020-07-26 14:27:30.230	info	(7763) terminating
        deconz.0	2020-07-26 14:27:30.223	debug	(7763) Websocket connection closed
        deconz.0	2020-07-26 14:27:30.222	info	(7763) cleaned everything up...
        deconz.0	2020-07-26 14:27:30.219	error	(7763) TypeError: Cannot read property 'toString' of null at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:1305:68) at runMicrotasks (<anonymous>) at processTicksAn
        deconz.0	2020-07-26 14:27:30.219	error	(7763) unhandled promise rejection: Cannot read property 'toString' of null
        deconz.0	2020-07-26 14:27:30.218	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        deconz.0	2020-07-26 14:27:30.217	info	(7763) getAllSensors MAC: fsm-x0bb
        deconz.0	2020-07-26 14:27:30.211	info	(7763) getAllSensors MAC: 00:0b:57:ff:fe:92:1c:1f-01-1000
        deconz.0	2020-07-26 14:27:30.203	info	(7763) getAllSensors MAC: d0:cf:5e:ff:fe:10:34:94-01-1000
        deconz.0	2020-07-26 14:27:30.153	info	(7763) getAllSensors MAC: 00:15:8d:00:02:13:66:36-01-0006
        deconz.0	2020-07-26 14:27:30.106	info	(7763) getAllSensors MAC: 90:fd:9f:ff:fe:90:04:8c-01-1000
        deconz.0	2020-07-26 14:27:30.054	info	(7763) getAllSensors MAC: 00:15:8d:00:02:13:43:31-01-0006
        deconz.0	2020-07-26 14:27:29.975	debug	(7763) Code 200: Request succeded get group attributes 65155: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["15
        deconz.0	2020-07-26 14:27:29.973	debug	(7763) Code 200: Request succeded get group attributes 35304: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":true,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["14"
        deconz.0	2020-07-26 14:27:29.971	debug	(7763) Code 200: Request succeded get group attributes 32875: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["11
        deconz.0	2020-07-26 14:27:29.916	debug	(7763) Code 200: Request succeded get group attributes 31638: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":true,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["142
        deconz.0	2020-07-26 14:27:29.915	debug	(7763) Code 200: Request succeded get group attributes 29462: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["68
        deconz.0	2020-07-26 14:27:29.913	debug	(7763) Code 200: Request succeded get group attributes 29319: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["16
        deconz.0	2020-07-26 14:27:29.911	debug	(7763) Code 200: Request succeded get group attributes 28432: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["11
        deconz.0	2020-07-26 14:27:29.909	debug	(7763) Code 200: Request succeded get group attributes 28181: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["11
        deconz.0	2020-07-26 14:27:29.907	debug	(7763) Code 200: Request succeded get group attributes 21480: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["5"
        deconz.0	2020-07-26 14:27:29.905	debug	(7763) Code 200: Request succeded get group attributes 17360: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["75
        deconz.0	2020-07-26 14:27:29.902	debug	(7763) Code 200: Request succeded get group attributes 15237: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["42
        deconz.0	2020-07-26 14:27:29.900	debug	(7763) Code 200: Request succeded get group attributes 13841: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["14
        deconz.0	2020-07-26 14:27:29.896	debug	(7763) Code 200: Request succeded get group attributes 8516: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["8"]
        deconz.0	2020-07-26 14:27:29.893	debug	(7763) Code 200: Request succeded get group attributes 8230: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["56"
        deconz.0	2020-07-26 14:27:29.890	debug	(7763) Code 200: Request succeded get group attributes 6321: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["92"
        deconz.0	2020-07-26 14:27:29.888	debug	(7763) Code 200: Request succeded get group attributes 29: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":true,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["179"],
        deconz.0	2020-07-26 14:27:29.886	debug	(7763) Code 200: Request succeded get group attributes 28: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":true,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag
        deconz.0	2020-07-26 14:27:29.885	debug	(7763) Code 200: Request succeded get group attributes 26: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"eta
        deconz.0	2020-07-26 14:27:29.884	debug	(7763) Code 200: Request succeded get group attributes 25: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["160"]
        deconz.0	2020-07-26 14:27:29.882	debug	(7763) Code 200: Request succeded get group attributes 23: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["167"]
        deconz.0	2020-07-26 14:27:29.881	debug	(7763) Code 200: Request succeded get group attributes 22: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"eta
        deconz.0	2020-07-26 14:27:29.879	debug	(7763) Code 200: Request succeded get group attributes 20: {"action":{"bri":3,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag"
        deconz.0	2020-07-26 14:27:29.877	debug	(7763) Code 200: Request succeded get group attributes 18: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":true,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag
        deconz.0	2020-07-26 14:27:29.868	info	(7763) getAllSensors MAC: 00:21:2e:ff:ff:01:3e:6b-01
        deconz.0	2020-07-26 14:27:29.846	debug	(7763) Code 200: Request succeded get group attributes 17: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"eta
        deconz.0	2020-07-26 14:27:29.844	debug	(7763) Code 200: Request succeded get group attributes 16: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"eta
        deconz.0	2020-07-26 14:27:29.842	debug	(7763) Code 200: Request succeded get group attributes 15: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"eta
        deconz.0	2020-07-26 14:27:29.840	debug	(7763) Code 200: Request succeded get group attributes 14: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"eta
        deconz.0	2020-07-26 14:27:29.838	debug	(7763) Code 200: Request succeded get group attributes 13: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"eta
        deconz.0	2020-07-26 14:27:29.836	debug	(7763) Code 200: Request succeded get group attributes 12: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":"1","xy":[0,0]},"devicemembership":[],"etag
        deconz.0	2020-07-26 14:27:29.834	debug	(7763) Code 200: Request succeded get group attributes 11: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"eta
        deconz.0	2020-07-26 14:27:29.832	debug	(7763) Code 200: Request succeded get group attributes 10: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"eta
        deconz.0	2020-07-26 14:27:29.831	debug	(7763) Code 200: Request succeded get group attributes 9: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":"1","xy":[0,0]},"devicemembership":[],"etag"
        deconz.0	2020-07-26 14:27:29.829	debug	(7763) Code 200: Request succeded get group attributes 7: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":true,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag"
        deconz.0	2020-07-26 14:27:29.827	debug	(7763) Code 200: Request succeded get group attributes 6: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag
        deconz.0	2020-07-26 14:27:29.825	debug	(7763) Code 200: Request succeded get group attributes 5: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":true,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag"
        deconz.0	2020-07-26 14:27:29.823	debug	(7763) Code 200: Request succeded get group attributes 4: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag
        deconz.0	2020-07-26 14:27:29.821	debug	(7763) Code 200: Request succeded get group attributes 3: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag
        deconz.0	2020-07-26 14:27:29.819	debug	(7763) Code 200: Request succeded get group attributes 2: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag
        deconz.0	2020-07-26 14:27:29.817	debug	(7763) Code 200: Request succeded get group attributes 1: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag
        deconz.0	2020-07-26 14:27:29.675	debug	(7763) Code 200: Request succeded get all groups: {"1":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"
        deconz.0	2020-07-26 14:27:29.673	info	(7763) getAllSensors MAC: 00:0b:57:ff:fe:ca:02:49-01-1000
        deconz.0	2020-07-26 14:27:29.672	debug	(7763) Code 200: Request succeded get all sensors: {"101":{"config":{"battery":100,"on":true,"reachable":true},"ep":1,"etag":"1fa93d2859aaaab9e842f1948a4d64db","lastseen":"2020-07-26T12:09:42.808","ma
        deconz.0	2020-07-26 14:27:29.500	debug	(7763) Code 200: Request succeded get all lights: {"1":{"etag":"510d41155131dcdfdab39612cca1096f","hascolor":false,"lastannounced":null,"lastseen":"2020-07-26T12:25:13Z","manufacturername":"OSRAM","mo
        deconz.0	2020-07-26 14:27:29.489	debug	(7763) Subscribed to updates...
        deconz.0	2020-07-26 14:27:29.484	info	(7763) deConz Version: 2.5.78; API version: 1.16.0
        deconz.0	2020-07-26 14:27:29.482	debug	(7763) Code 200: Request succeded get config: {"UTC":"2020-07-26T12:27:29","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF013E6B","datastoreversion":"93","device
        deconz.0	2020-07-26 14:27:29.434	info	(7763) starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.deconz, node: v12.18.3, js-controller: 3.1.6
        deconz.0	2020-07-26 14:27:29.429	info	(7763) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        deconz.0	2020-07-26 14:27:29.427	debug	(7763) Plugin sentry Initialize Plugin (enabled=true)
        deconz.0	2020-07-26 14:26:58.163	info	(6750) Terminated (NO_ERROR): Without reason
        deconz.0	2020-07-26 14:26:58.163	debug	(6750) Plugin sentry destroyed
        deconz.0	2020-07-26 14:26:58.163	info	(6750) terminating
        deconz.0	2020-07-26 14:26:58.159	debug	(6750) Websocket connection closed
        deconz.0	2020-07-26 14:26:58.158	info	(6750) cleaned everything up...
        deconz.0	2020-07-26 14:26:58.157	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
        deconz.0	2020-07-26 14:26:58.157	error	at runMicrotasks (<anonymous>)
        deconz.0	2020-07-26 14:26:58.157	error	at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:1305:68)
        deconz.0	2020-07-26 14:26:58.157	error	(6750) TypeError: Cannot read property 'toString' of null
        deconz.0	2020-07-26 14:26:58.157	error	(6750) unhandled promise rejection: Cannot read property 'toString' of null
        deconz.0	2020-07-26 14:26:58.156	info	(6750) getAllSensors MAC: fsm-x0bb
        deconz.0	2020-07-26 14:26:58.148	info	(6750) getAllSensors MAC: 00:0b:57:ff:fe:92:1c:1f-01-1000
        deconz.0	2020-07-26 14:26:58.099	info	(6750) getAllSensors MAC: d0:cf:5e:ff:fe:10:34:94-01-1000
        deconz.0	2020-07-26 14:26:58.039	info	(6750) getAllSensors MAC: 00:15:8d:00:02:13:66:36-01-0006
        deconz.0	2020-07-26 14:26:57.992	info	(6750) getAllSensors MAC: 90:fd:9f:ff:fe:90:04:8c-01-1000
        deconz.0	2020-07-26 14:26:57.910	info	(6750) getAllSensors MAC: 00:15:8d:00:02:13:43:31-01-0006
        • Jey Cee
          @comchris hast du regeln in deConz/Phoscon angelegt? Wenn ja kannst du mir mal bitte einen Screenshot der Sensor Objekte mit der Adapter v1 machen.
          Sieht so aus als wäre die MAC fsm-x0bb ein Virtueller Sensor, der für eine Regel angelegt wurde. Zumindest versteh ich das so, nachdem was ich gefunden habe.
            Hallo Jey Cee,
            eine Virtuelle Gruppe macht Phoscon ja bereits wenn ein Bewegungsmelder angesteuert wird, dies habe ich schon ein paar mal. Ansonsten machen die Ikea Schalter meist ja Gruppen, wobei dies glaub ich dann keine virtuellen sind. Wollte eigentlich herausfinden was das für ein zsm-x0bb Gruppe ist allerdings kann ich nirgendwo die Mac finden... Oberfläche Phoscon und auch grafische Gui nicht. Der Adapter V2 liest soweit ich gesehen hab auch alle Lampen ein und ein paar Sensoren wobei hier keine "virtuelle" Gruppe dabei ist, also hast du hier bestimmt Recht. Ich könnte höchstens mal alle löschen und dann testen, könnte ich aber erst morgen machen....
            Bildschirmfoto 2020-07-26 um 18.39.27.png Bildschirmfoto 2020-07-26 um 18.37.00.png Bildschirmfoto 2020-07-26 um 18.36.43.png
            Diese Sensoren liest er in der V2 noch ein.
            Jey Cee 2 Replies Last reply Reply Quote 0
            • Jey Cee
              @comchris sagte in Test Adapter deConz v2.0.x:
              Ne das kann nicht die Lösung sein, das muss ja später auch mit denen funktionieren. Aber wenn ich weis wonach ich Filtern muss ist das kein Problem.
              • JackDaniel
                JackDaniel last edited by
                hi,
                ist das eigentlich nur bei so, oder sogar gewollt das bei jedem adapter stop/start der api key weg ist und ich den adapter neu über die phoscon app verdinden muss?
                danke im voraus.
                saluti
                daniel
                • simatec
                  simatec Developer Most Active @Jey Cee last edited by
                  @Jey-Cee sagte in Test Adapter deConz v2.0.x:
                  Denke das sollte kein Problem sein, muss nur schauen wie ich an die zip Datei komme und wo die hin soll. Nach Möglichkeit kommt das mit in den Backitup Adapter.
                  Das wäre ne super Geschichte. Hatte auch schon mal geschaut, aber bin irgendwie noch nicht weitergekommen.
                  • Jey Cee
                    Jey Cee Developer @simatec last edited by
                    @simatec backup funktion hab ich schon eingebaut. Um an die Zip zu kommen muss man wohl ftp/sftp(ssh) Verbindung herstellen.
                    Aber ich würde mir Wünschen das es für so etwas ein Globales Konten managment gibt. Dann könnten alle Adapter darauf zurück greifen und man muss nicht durch alle Adapter durch und hat schnell einen Überblick. Im Adapter dann nur noch einen Link zum Konten managment bzw. ein Drop Down mit der Konten Auswahl, am besten noch gefiltert
                    • Jey Cee
                      Die Version 2.0.3 liegt auf Github zum Testen bereit. Es gab einige Bugfixes, aber auch ein paar kleine Neuerungen. Changlog wie immer im ersten Beitrag oder in der Readme.md.
                      Backup: Mit dem State backup wird eine Zip Datei auf dem Gerät erzeugt auf dem deConz läuft. Unter Linux findet man diese Datei hier ->
                      .local/share/dresden-elektronik/deCONZ/
                      Bei Windows kenne ich den Pfad nicht, wenn ihn also jemand findet bitte hier teilen.
                      • simatec
                        simatec Developer Most Active @Jey Cee last edited by simatec
                        @Jey-Cee
                        Schaue mal hier ...
                        Wäre das eventuell eine Möglichkeit für dich, das Backup in den Standard Backupordner von iobroker zu holen?
                        So setze ich das mit dem CCU-Backup um
                        • Jey Cee
                          @simatec finde ich sehr Dirty. Ich habe jetzt einfach mal einen feature Request bei deconz erstellt, mal sehen ob da interesse da ist das als Endpoint der Api zur verfügung zu stellen.
                            Pittini Developer last edited by
                            Die ohnehin irgendwie etwas unklare Umbennungsstrategie (manches wird autom. umbenannt, manches nicht) hat in der V 2.0.3 ne zusätzliche Variante bekommen, siehe rote Marker im Bild:
                              SevenUp @Pittini last edited by SevenUp
                              @Pittini kann ich so auch bei mir bestätigen.
                              Sonst kämpfte ich die letzten 2 Tagen mit einem ähnlichen Problem wie du.
                              Ich habe einen Bewegungsmelder (IKEA), der einen selbst definierten DP1 schalten soll (anwesend ja/nein), mehr nicht.
                              Und ich habe einen DP2, der in Abhängigkeit von einer Osram-Steckdose geschaltet werden soll (Steckdose an -> triggert den DP2), der absolut nichts mit dem Bewegungsmelder zu tun haben soll.
                              Nun ist aber komisches Verhalten: wird eine Bewegung erkannt, dann wird DP2 getriggert, obwohl die Osram Steckdose ihren Zustand nicht geändert hat.
                              Seltsam und ich blicke da noch nicht durch. Adapter komplett löschen und alles neu einrichten hat zwar Zeit gekostet, aber leider keine Lösung gebracht.
                              Nachtrag: ich habe das Gefühl, dass die angezeigten Namen/Datenpunkte nicht immer den richtigen Geräten zugewiesen wurden und es dadurch zu einem Durcheinander kommt...
                              • Jey Cee
                                Jey Cee Developer @SevenUp last edited by
                                @SevenUp sagte in Test Adapter deConz v2.0.x:
                                Zeig mal dein Skript und das Log.
                                • Jey Cee
                                  Jey Cee Developer @JackDaniel last edited by
                                  @JackDaniel sagte in Test Adapter deConz v2.0.x:
                                  hi,
                                  danke im voraus.
                                  saluti
                                  daniel
                                  Nein das ist es nicht, kann mich auch nicht erinnern das jemand schon mal das Problem hatte das er jedesmal weg ist.
                                  Hast du den Adapter gelöscht bevor du die neue Version installiert hast?
                                  JackDaniel 1 Reply Last reply Reply Quote 0
                                    SevenUp @Jey Cee last edited by
                                    @Jey-Cee ich habe es dir hier im Chat geschickt und hoffe, dass es angekommen ist.
                                    • Jey Cee
                                      @comchris kannst du bitte nochmal Testen? Die Virtuellen Sensoren sollten den Adapter jetzt nicht mehr abstürzen lassen.
                                        Hallo JeyCee schaut sehr gut aus, und funktioniert bis dato einwandfrei. Backup hab ich auch schon getestet. Die Umlautenproblematik ist jetzt mit der ID vermutlich auch Geschichte oder? Die "fehlerhafte" Benennung die Pittini hat konnte ich nicht bestätigen, bei mir ist alles sauber.
                                        • Jey Cee
                                          @comchris schön das es bei dir läuft.
                                          Kann mich gar nicht daran erinnern das es damit Probleme gab. Bei mir gibt es einige Umlaute in Namen und damit habe ich kein Problem.
                                          • JackDaniel
                                            JackDaniel @Jey Cee last edited by JackDaniel
                                            @Jey-Cee
                                            Hab nochmal alles von Null gemacht, läuft nun wie es soll👍
                                            79.9k
                                            conbee deconz phoscon
                                            38
                                            196
                                            21736
