    4. JSON Werte in Datenpunkte
    • Kevin
      Kevin last edited by
      Ich bin ganz neu in der Welt des ioBrokers und Umsteiger von fhem.
      Ich versuche gerade auch eine Json von meinem 3D Drucker auszulesen und die entsprechenden Datensätze selbst anlegen zulassen. Leider komme ich nicht weiter:
      Das ist der Output von meiner URL von dem 3D Drucker.
      {"status":"P","coords":{"axesHomed":[1,1,1,1,1,1],"wpl":1,"xyz":[160.851,108.581,27.592,45.000,2.000,24.000],"machine":[115.842,58.395,33.482,45.000,2.000,18.110],"extr":[20722.2,0.0,0.0,0.0]},"speeds":{"requested":40.0,"top":40.0},"currentTool":0,"params":{"atxPower":-1,"fanPercent":[0,100,-1,90,100,0,100,0,100,50],"speedFactor":100.0,"extrFactors":[100.0,100.0,100.0,100.0],"babystep":0.000},"seq":2,"sensors":{"probeValue":0,"fanRPM":[-1,-1,-1,-1,-1,-1,-1,-1,-1,-1]},"temps":{"bed":{"current":90.0,"active":90.0,"standby":0.0,"state":2,"heater":0},"current":[90.0,235.4,30.4,31.9,32.7],"state":[2,2,0,0,0],"tools":{"active":[[235.0],[0.0],[0.0],[0.0]],"standby":[[235.0],[0.0],[0.0],[0.0]]},"extra":[]},"time":45569.0,"currentLayer":138,"currentLayerTime":77.1,"extrRaw":[20698.6,0.0,0.0,0.0],"fractionPrinted":88.1,"filePosition":16983003,"firstLayerDuration":749.6,"firstLayerHeight":0.20,"printDuration":24418.6,"warmUpDuration":397.2,"timesLeft":{"file":3431.8,"filament":2551.1,"layer":6133.5}}
      Das ist dazu mein Script:
      var request = require('request');
       Intervall = setInterval(SendRequest,5000);
      function SendRequest(){
          var options = {
              url: 'http://URLVON3DRUCKER',
          request(options, function (error, response, body){
              if (!error){
                  CreateDevices(JSON.parse(body));
                  console.log(body);
              else{ console.error(error);}
      }//End of Function SendRequest
      function CreateDevices(data){
      if ("undefined" !== typeof  data.result){
          for (i = 0; i < data.result.length; i++) {
                       for (var ObjName in data.result[i].acState) {
                           if (!getObject('0_userdata.0.3DPrinter.' +i +'.acState' +'.' +ObjName)){
                               createState('0_userdata.0.3DPrinter.' +i +'.acState' +'.' +ObjName,data.result[i].acState[ObjName],{type: typeof data.result[i].acState[ObjName], role: ObjName});
                               console.log('ERSTELLT');
                           else{setState('0_userdata.0.3DPrinter.' +i +'.acState' + '.' +ObjName,data.result[i].acState[ObjName],akt=true)}
      else{console.warn('Response in JSON nicht gefunden ! ')}
      }//End of Function CreateDevices
      Dann bekomme ich folgende Meldung in dem Log:
      javascript.0	2020-07-29 20:53:50.291	warn	(24214) script.js.common.3D_Printer: Response in JSON nicht gefunden !
      javascript.0	2020-07-29 20:53:45.258	info	(24214) script.js.common.3D_Printer: {"status":"P","coords":{"axesHomed":[1,1,1,1,1,1],"wpl":1,"xyz":[164.129,107.010,27.592,45.000,2.000,24.000],"machine":[123.229,61.852,33.48
      An was kann das liegen?
      Die Werte einzeln an ioBroker zu schreiben bekomme ich über ein anderes Skript hin. Nur hätte ich gerne alle Werte automatisch angelegt.
        paul53 @Kevin last edited by paul53
        @Kevin sagte:
        Das Objekt enthält keine Eigenschaft result und ist auch kein Array.
        Versuche es mal so:
        function iter(name, obj) {
           for(let i in obj) {
              if(typeof obj[i] == 'object') iter(name + '.' + i, obj[i]);
              else {
                 log(name + '.' + i + ': ' + obj[i]);
                 if(existsState(name + '.' + i)) setState(name + '.' + i, obj[i]);
                 else createState(name + '.' + i, obj[i]); // type: "mixed"
            var options = {
                if (!error) iter('0_userdata.0.3DPrinter', JSON.parse(body));
                else console.error(error);
        schedule('*/5 * * * * *', SendRequest);
        Kevin 1 Reply Last reply Reply Quote 0
        • Kevin
          Kevin @paul53 last edited by
          @paul53 said in JSON Werte in Datenpunkte:
        function iter(name, obj) {        for(let i in obj) {        if(typeof obj[i] == 'object') iter(name + '.' + i, obj[i]);        else {        log(name + '.' + i + ': ' + obj[i]);        if(existsState(name + '.' + i) setState(name + '.' + i, obj[i]);        else createState(name + '.' + i, obj[i]); // type: "mixed"        }        }        }        function SendRequest(){        var options = {        url: 'http://URLVON3DRUCKER',        };        request(options, function (error, response, body){        if (!error) iter('0_userdata.0.3DPrinter', JSON.parse(body));        else console.error(error);        });        }        schedule('*/5 * * * * *', SendRequest);
          Danke schon mal für dein Hilfe 🙂
          Leider hat es nicht ganz funktioniert:
          javascript.0	2020-07-29 22:56:55.543	error	(24214) at process._tickCallback (internal/process/next_tick.js:68:7)
          javascript.0	2020-07-29 22:56:55.543	error	(24214) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
          javascript.0	2020-07-29 22:56:55.542	error	(24214) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
          javascript.0	2020-07-29 22:56:55.542	error	(24214) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17)
          javascript.0	2020-07-29 22:56:55.542	error	(24214) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:1124:17)
          javascript.0	2020-07-29 22:56:55.541	error	(24214) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1533:17)
          javascript.0	2020-07-29 22:56:55.541	error	(24214) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1480:37)
          javascript.0	2020-07-29 22:56:55.541	error	(24214) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:1257:28)
          javascript.0	2020-07-29 22:56:55.540	error	(24214) at Object.createScript (vm.js:277:10)
          javascript.0	2020-07-29 22:56:55.540	error	(24214) at new Script (vm.js:83:7)
          javascript.0	2020-07-29 22:56:55.540	error	(24214) SyntaxError: Unexpected identifier
          javascript.0	2020-07-29 22:56:55.539	error	(24214) ^^^^^^^^
          javascript.0	2020-07-29 22:56:55.539	error	(24214) if(existsState(name + '.' + i) setState(name + '.' + i, obj[i]);
          javascript.0	2020-07-29 22:56:55.539	error	at script.js.common.Skript_1:6
          javascript.0	2020-07-29 22:56:55.539	error	(24214) script.js.common.Skript_1 compile failed:
            @Kevin sagte:
            existsState(id) wird anscheinend angemeckert. Welche Version des Javascript-Adapters ?
            • Kevin
              @paul53 Sollte eigentlich die aktuellste Version sein: 4.6.21
                @Kevin
                Sorry, da fehlt eine schließende Klammer vor setState. Habe sie ergänzt.
                • Kevin
                  @paul53 Perfekt danke für die schnelle Hilfe. Genau wie ich es mir vorgestellt habe.
                    @Kevin sagte:
                    Dann markiere bitte das Thema in der Überschrift des ersten Beitrags als [gelöst].
                    • Kevin
                      @paul53 Ich habe noch eine Frage 🙂
                      Lässt sich verhindern, dass die Abfrage durchgeführt wird, wenn der Drucker ausgeschaltet ist?
                      javascript.0	2020-07-31 07:08:11.796	error	(24214) Request error: Error: connect ETIMEDOUT 91.15.159.27:8000
                      javascript.0	2020-07-31 07:08:11.795	error	(24214) script.js.common.3D_Printer: {'errno':'ETIMEDOUT','code':'ETIMEDOUT','syscall':'connect','address':'IP','port':8000}
                        @Kevin sagte:
                        Wie kann man das feststellen ? Nur ping ?
                        • Kevin
                          @paul53 Ich könnte es über einen Datenpunkt an der Fritzbox abfragen. Dann wäre Datenpunkt 3Drucker.active auf true sobald er im netzwerk ist
                            @Kevin sagte:
                            Dann mache die Abfrage als erstes in der Funktion SendRequest().
                              if(getState('abc.0.xyz.3Drucker.active').val) {
                                var options = {
                            4141
