    4. Test Adapter doorio v2.1.2
      MHeymann @Wal last edited by
      @Wal
      Vielen lieben Dank. Jetzt funktioniert der Start beim hochfahren.
      ... Dann baue ich mal weiter.
      Danke 🙂
        MHeymann @MHeymann last edited by
        Na toll neues Problem 😞
        Im ioBroker bekomme ich folgende Fehlermeldung:
        doorio.0	2020-08-01 18:50:35.102	error	(10064) uncaughtException: TypeError: Cannot read property 'val' of null
        doorio.0	2020-08-01 18:50:35.096	error	(10064) TypeError: Cannot read property 'val' of null at send2Server (/opt/iobroker/node_modules/iobroker.doorio/lib/client.js:40:50) at BaresipClient.onStateChange (/opt/iobroker/node_modules
        doorio.0	2020-08-01 18:50:35.090	error	(10064) uncaught exception: Cannot read property 'val' of null
        doorio.0	2020-08-01 18:45:34.864	error	(4324) uncaughtException: TypeError: Cannot read property 'val' of null
        doorio.0	2020-08-01 18:45:34.861	error	at processImmediate (timers.js:658:5)
        doorio.0	2020-08-01 18:45:34.861	error	at tryOnImmediate (timers.js:676:5)
        doorio.0	2020-08-01 18:45:34.861	error	at runCallback (timers.js:705:18)
        doorio.0	2020-08-01 18:45:34.861	error	at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5388:34)
        doorio.0	2020-08-01 18:45:34.861	error	at Adapter.emit (events.js:198:13)
        doorio.0	2020-08-01 18:45:34.861	error	at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.doorio/main.js:35:16)
        doorio.0	2020-08-01 18:45:34.861	error	at BaresipClient.onStateChange (/opt/iobroker/node_modules/iobroker.doorio/lib/client.js:37:41)
        doorio.0	2020-08-01 18:45:34.861	error	at send2Server (/opt/iobroker/node_modules/iobroker.doorio/lib/client.js:40:50)
        doorio.0	2020-08-01 18:45:34.861	error	(4324) TypeError: Cannot read property 'val' of null
        und der baresip Status dazu:
        ● baresip.service - baresip
           Loaded: loaded (/etc/systemd/system/baresip.service; enabled; vendor preset: enabled)
           Active: active (running) since Sat 2020-08-01 18:28:56 CEST; 18min ago
         Main PID: 479 (baresip)
           CGroup: /system.slice/baresip.service
                   └─479 /usr/bin/baresip -f /home/pi/.baresip
        Aug 01 18:34:10 Klingel baresip[479]: DoorIOSIP@192.168.2.1: {0/UDP/v4} 200 OK () [1 binding]
        Aug 01 18:38:40 Klingel baresip[479]: reg: sip:DoorIOSIP@192.168.2.1: 401 Unauthorized ()
        Aug 01 18:39:37 Klingel baresip[479]: DoorIOSIP@192.168.2.1: {0/UDP/v4} 200 OK () [1 binding]
        Aug 01 18:44:07 Klingel baresip[479]: reg: sip:DoorIOSIP@192.168.2.1: 401 Unauthorized ()
        Aug 01 18:44:44 Klingel baresip[479]: DoorIOSIP@192.168.2.1: {0/UDP/v4} 200 OK () [1 binding]
        Was könnte das sein?
        Thomas Braun Wal 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @MHeymann last edited by
          @MHeymann
          Welche node-Version ist da installiert?
          which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
          • Wal
            Wal Developer @MHeymann last edited by
            @MHeymann
            die Baresip-Meldungen sind i.O.
            Evtl. den Adapter auf Debug stellen, um mehr Log-Ausgabe zu erhalten.
            Diese Fehler kenne ich jetzt nicht.
            • Wal
              Wal Developer @Thomas Braun last edited by
              @Thomas-Braun sagte in Test Adapter doorio v1.0.x:
              @MHeymann
              Wie Thomas vermutet, könnte es auch an der Version von node liegen.
              Der Adapter ist für Node 10 u. 12, das ist i.M. Standard im ioBroker.
                @Wal
                Es ist Node.js v10.22.0 installiert. Debug log schaue ich später mal nach.
                  Thomas Braun Most Active @MHeymann last edited by Thomas Braun
                  @MHeymann
                  Auch richtig?
                  Die Ausgabe der obigen Befehlskette würde helfen...
                  Ich würde auch auf node12 gehen.
                    MHeymann @Thomas Braun last edited by
                    Hier mal die Ausgabe.
                    root@ioBroker:~# which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                    /usr/bin/nodejs
                    v10.22.0
                    /usr/bin/node
                    v10.22.0
                    /usr/bin/npm
                    6.14.6
                    nodejs:
                      Installed: 10.22.0-1nodesource1
                      Candidate: 10.22.0-1nodesource1
                      Version table:
                     *** 10.22.0-1nodesource1 500
                            500 https://deb.nodesource.com/node_10.x bionic/main amd64 Packages
                            100 /var/lib/dpkg/status
                         8.10.0~dfsg-2ubuntu0.4 500
                            500 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
                         8.10.0~dfsg-2ubuntu0.2 500
                            500 http://archive.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
                         8.10.0~dfsg-2 500
                            500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
                      @MHeymann
                      Man meldet sich nicht als root an.
                      Unter Ubuntu immer als normaler User und dann bei Notwendigkeit mit sudo den Befehl absetzen.
                        @Thomas-Braun
                        Ok. Ist meine Testumgebung auf Proxmox. Aber ist ist ja nicht der Fehler oder?
                          @MHeymann
                          Doch, das ist grundsätzlich ein Fehler. Das zerschießt dir u. U. die Pfade und Rechte.
                          Und auch in einem Testsystem arbeitet man nicht als root.
                            @Thomas-Braun
                            Da hast du sicherlich recht. Aber die anderen 30 Instanzen laufen ja problemlos.
                              @MHeymann
                              Heißt jetzt genau was? Die doorio-Instanz aber nicht.
                              Jetzt meldest du dich als USER an und jagst den
                              iobroker fix
                              durch das System.
                              Vielleicht hast du auch baresip durch den root-login krumm installiert.
                                MHeymann @Thomas Braun last edited by MHeymann
                                iobroker fix
                                Habe ich gemacht Fehler ist immer noch da.
                                Habe DoorIO im debug mode laufen lassen. Ich habe innerhalb weniger Minuten 1000de Einträge. Hatte das davor über mein Handy eingestellt und ca. eine Stunde laufen gelassen. Die Log Datei ist ca 550 MB groß. Ist das normal?
                                  @MHeymann
                                  Nein.
                                    baresip läuft auf nem anderen pi.
                                      @MHeymann Orgelst du da auch als root rum?
                                        @Thomas-Braun
                                        Nein.
                                          Hier mal ein Auszug aus der Log.
                                          Log.txt
                                          • Wal
                                            @MHeymann
                                            ist der Adapter dann grün ?
                                            Ich sehe den Error um 23:00 Uhr und um 23:03 Uhr sagt er dann Connect.
                                            door intercom doorpi türsprechstelle
                                            34
                                            583
                                            123094
