    • simatec
      simatec Developer Most Active @pk68 last edited by
      @pk68
      Das ist nicht gewollt. Bitte poste mal den Debug Log
      P J 2 Replies Last reply Reply Quote 0
        pk68 @simatec last edited by
        @simatec
        2020-07-12 02:00:10.027 - debug: backitup.0 (26881) Backup has started ...
        2020-07-12 02:00:12.428 - debug: backitup.0 (26881) [iobroker/iobroker] host.Raspi4-iob 2778 states saved
        2020-07-12 02:00:12.462 - debug: backitup.0 (26881) [iobroker/iobroker] host.Raspi4-iob 3071 objects saved
        2020-07-12 02:00:14.989 - debug: backitup.0 (26881) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_07_12-02_00_10_backupiobroker.tar.gz
        2020-07-12 02:00:16.031 - debug: backitup.0 (26881) [iobroker/iobroker] done
        2020-07-12 02:00:16.677 - debug: backitup.0 (26881) [iobroker/historyDB] done
        2020-07-12 02:00:16.679 - debug: backitup.0 (26881) [iobroker/zigbee] found zigbee database: zigbee.0
        2020-07-12 02:00:16.680 - debug: backitup.0 (26881) [iobroker/zigbee] done
        2020-07-12 02:00:16.687 - debug: backitup.0 (26881) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_07_03-02_00_10_backupiobroker.tar.gz
        2020-07-12 02:00:16.688 - debug: backitup.0 (26881) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_07_02-02_00_10_backupiobroker.tar.gz
        2020-07-12 02:00:16.690 - debug: backitup.0 (26881) [iobroker/clean] delete /opt/iobroker/backups/historyDB_2020_07_03-02_00_15_backupiobroker.tar.gz
        2020-07-12 02:00:16.691 - debug: backitup.0 (26881) [iobroker/clean] delete /opt/iobroker/backups/historyDB_2020_07_02-02_00_16_backupiobroker.tar.gz
        2020-07-12 02:00:16.692 - debug: backitup.0 (26881) [iobroker/clean] done
        2020-07-12 02:00:16.698 - debug: backitup.0 (26881) [iobroker/telegram] [iobroker] used Telegram-Instance: telegram.0
        2020-07-12 02:00:16.699 - debug: backitup.0 (26881) [iobroker/telegram] done
        2020-07-12 02:00:16.704 - debug: backitup.0 (26881) [iobroker] exec: done
        2020-07-12 02:00:16.708 - debug: backitup.0 (26881) [iobroker/history] backitup.0.history.html
        2020-07-12 02:00:16.709 - debug: backitup.0 (26881) [iobroker] exec: done
        2020-07-12 02:00:16.710 - debug: backitup.0 (26881) [iobroker/history] backitup.0.history.json
        2020-07-12 02:00:16.712 - debug: backitup.0 (26881) [iobroker] exec: done
          Jan1 @simatec last edited by
          @simatec
          ist mir auch schon aufgefallen
          • Gargano
            Gargano last edited by
            Bei mir ist unter dem wiederherstellen Google nur der iobroker Pfad, der CCU Pfad fehlt. Backup CCU machen kann ich , der Pfad existiert auch in Google Drive, nur angezeigt wird er nicht. Wie kann ich denn da ein Restore der ccu machen ?
            • simatec
              simatec Developer Most Active @Gargano last edited by
              @Gargano
              Bitte Doku des Adapters lesen (Bereich Wiederherstellung)
                passuff last edited by
                ich habe eingestellt, dass die backups auf google drive gespeichert werden sollen. Bekomme seit eniger Zeit folgende Fehlermeldung:
                2020-07-20 02:00:21.482 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2020-07-20 02:00:21.572 - error: backitup.0 (23926) unhandled promise rejection: Rate Limit Exceeded
                2020-07-20 02:00:21.815 - error: backitup.0 (23926) Error: Rate Limit Exceeded
                at Gaxios._request (/opt/iobroker/node_modules/gaxios/src/gaxios.ts:108:15)
                at runMicrotasks ()
                at processTicksAndRejections (internal/process/task_queues.js:97:5)
                at OAuth2Client.requestAsync (/opt/iobroker/node_modules/google-auth-library/build/src/auth/oauth2client.js:342:22)
                2020-07-20 02:00:21.817 - info: backitup.0 (23926) cleaned everything up...
                2020-07-20 02:00:21.928 - info: backitup.0 (23926) terminating
                2020-07-20 02:00:21.931 - info: backitup.0 (23926) Terminated (NO_ERROR): Without reason
                2020-07-20 02:00:22.469 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                2020-07-20 02:00:22.470 - error: host.iobroker Caught by controller[1]: Error: Rate Limit Exceeded
                2020-07-20 02:00:22.470 - error: host.iobroker Caught by controller[1]: at Gaxios._request (/opt/iobroker/node_modules/gaxios/src/gaxios.ts:108:15)
                2020-07-20 02:00:22.470 - error: host.iobroker Caught by controller[1]: at runMicrotasks ()
                2020-07-20 02:00:22.471 - error: host.iobroker Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
                2020-07-20 02:00:22.471 - error: host.iobroker Caught by controller[1]: at OAuth2Client.requestAsync (/opt/iobroker/node_modules/google-auth-library/build/src/auth/oauth2client.js:342:22)
                2020-07-20 02:00:22.471 - info: host.iobroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                2020-07-20 02:00:22.471 - info: host.iobroker Restart adapter system.adapter.backitup.0 because enabled
                Das tritt nicht bei jedem backup auf. Manchmal funktioniert es auch. Hat jemand eine Idee?
                simatec P 2 Replies Last reply Reply Quote 0
                • simatec
                  simatec Developer Most Active @passuff last edited by
                  @passuff
                  Welche Version von backitup ist installiert und welche node, nodejs, npm und js-controller Versionen hast du laufen?
                    installiert habe ich Backitup in der Version 1.5.8.
                    root@iobroker:~# iobroker info
                    Platform       : linux
                    os             : linux
                    Architecture   : x64
                    CPUs           : 1
                    Speed          : 1699 MHz
                    Model          : Common KVM processor
                    RAM            : 3.8 GB
                    System uptime  : 23d. 13:42:14
                    Node.js        : v12.18.0
                    Disk size      : 27.4 GiB
                    Disk free      : 25.0 GiB
                    adapters count : 355
                    NPM            : v6.14.5
                    • simatec
                      Ab sofort ist die Version 1.5.9 auf Github und in Kürze auch im latest verfügbar ...
                      Changelog
                      1.5.9 (21.07.2020)
                      • (simatec) small fixes on mysql backup
                      • (simatec) next bugfixs errorhandling sentry.io
                      • (simatec) updated dependencies
                      • simatec
                        Ab sofort ist die Version 1.6.0 auf Github und in Kürze auch im latest verfügbar ...
                        Changelog
                        1.6.0 (03.08.2020)
                        • (Jey-Cee/simatec) adapter configuration revised
                          Kueppert @simatec last edited by
                          @simatec ich wundere mich schon länger, arum mein MySQL-Backup immer nur 0 kb groß ist. Hab mit phpmyadmin mal in die SQL reingeschaut - da sind jede Menge werte vorhanden. Also mal auf die VM gegangen und geschaut, ob das file überhaupt exitiert (mysqldump) - JA, das gibt es.
                          Hab dann mal ins LOG geschaut und folgenden Eintrag gefunden:
                          [ERROR] [mysql] - [IGNORED] Error: Command failed: /usr/bin/mysqldump  -u iobroker -p**** iobroker -h 192.168.178.73 -P 3306 > /opt/iobroker/backups/mysql_2020_08_04-09_31_43_backupiobroker.sql
                          /bin/sh: 1: /usr/bin/mysqldump: not found
                          (habe den Ordner zu der mysqldump eingetragen; vorher hatte ich aber den gleichen Fehler). Backitup findet die Datei nicht? Vorhanden ist sie aber...
                          Im Adapter habe ich den User für die Datenbank eingetragen - ist es möglich, dass dieser user die Datei ggf. nicht ausführen darf wegen fehlender Rechte? Im backitup-Adapter hab ich die Konfig vom MySQL-Adapter übernommen (der User für die DB ist korrekt).
                          Wenn ich Infos vergessen habe, die für eine ANalyse notwendig sind, teilt mir das bitte mit.
                          Die MySQL-DB läuft auf einer VM unter Proxmox (und wird problemlos beschrieben).
                          Danke euch und vG, Thorsten
                            passuff @passuff last edited by
                            @passuff sagte in Test Adapter Backitup v1.6.x:
                            at runMicrotasks ()
                            Gibts dazu schon was neues?
                            • simatec
                              simatec Developer Most Active @Kueppert last edited by
                              @Kueppert so wie ich das sehe, läuft deine sql nicht auf dem gleichen System wie dein iobroker.
                              mysqdump muss also auf deinem iobroker System auch installiert sein.
                              • simatec
                                @passuff
                                Eventuell mal deinen Token erneuern ... Kann auf allen Testsystemen den Fehler nicht nachstellen
                                  passuff @simatec last edited by
                                  @simatec habe extra einen neuen google Account für backitup erstellt. Hat aber auch nichts geholfen. Habe sogar ein Testsystem aufgesetzt - leider mit dem selben Ergebnis.
                                  • simatec
                                    @passuff
                                    Eventuell wurde bei einem Update von node, js-controller oder sonstiges auch was beschädigt.
                                    Lösche mal die Instanz und im Anschluss den Adapter von Backitup und installiere diesen nach einem Neustart mal neu.
                                      @simatec ahaaaa, danke für den Hinweis 😉
                                      Für alle, die das gleiche Setup haben (Debian 10) hier der Code-Schnipsel für die Installation:
                                      apt-get install default-mysql-client
                                      Nun geht das Backup auch. Danke und vG, Thorsten
                                        @simatec
                                        Habe den Adapter gelöscht und neu aufgesetzt. Da ich aber auf meinem Testsystem die selbe Fehlermeldung erhalte, glaube ich nicht dass sich etwas ändert. Ich bekomme die Fehlemeldung mittlerwele bei jedem zeitgesteuerten Start- bei manueller Auslösung aber nie.
                                        Welches Setup (node, js-controller..) nutzt du?
                                          @simatec
                                          Wie erwartet bleibt alles beim alten. Der zeitgesteuerte Upload auf gdrive funktioniert nicht! Manuell weiterhin ohne Probleme möglich. Biete mich gerne zum debugging an, falls du das bei dir nicht nachstellen kannst.
                                          • simatec
                                            Ab sofort steht die Version 1.6.1 zum testen auf Github und in kürze auch im latest zur Verfügung.
                                            Changelog
                                            1.6.1 (24.08.2020)
                                            • (Apollon77) several fixes and optimizations
                                            170
                                            2780
                                            2346449
