    4. Test: Adapter Log Parser v0.x.x GitHub
      Kuddel @Mic last edited by
      @Mic
      Debug-Log
      2020-07-30 00:00:01.001  - debug: logparser.0 (9633) callAtMidnight() : timer reached timeout, so we execute function 'updateTodayYesterday'
      2020-07-30 00:00:01.055  - debug: logparser.0 (9633) updateTodayYesterday() : Filter 'All', updated 500 logs.
      2020-07-30 00:00:01.194  - debug: logparser.0 (9633) updateTodayYesterday() : Filter 'Warn', updated 500 logs.
      2020-07-30 00:00:01.242  - debug: logparser.0 (9633) updateTodayYesterday() : Filter 'Error', updated 500 logs.
      2020-07-30 00:00:01.269  - debug: logparser.0 (9633) updateTodayYesterday() : Filter 'Homematic', updated 218 logs.
      2020-07-30 00:00:01.320  - debug: logparser.0 (9633) updateTodayYesterday() : Filter 'Javascript', updated 500 logs.
      2020-07-30 00:00:01.488  - debug: logparser.0 (9633) updateTodayYesterday() : Filter 'Alexa', updated 500 logs.
      2020-07-30 00:00:01.498  - debug: logparser.0 (9633) updateTodayYesterday() : Filter 'Nut', updated 111 logs.
      2020-07-30 00:00:01.528  - debug: logparser.0 (9633) updateTodayYesterday() : Filter 'Bewaesserung', updated 500 logs.
      2020-07-30 00:00:01.528  - debug: logparser.0 (9633) callAtMidnight() called, provided function: 'updateTodayYesterday'. Timeout at 00:00:01, which is in 86399472ms.
      Mic 1 Reply Last reply Reply Quote 0
      • Mic
        Mic Developer @Kuddel last edited by
        @Kuddel
        Führe mal bitte folgendes Script im JavaScript-Adapter aus. Ich möchte prüfen, ob er die aktuelle Uhrzeit deines Systems richtig erkennt:
        const dateObj = new Date();
        const isoDateStrHelper = dateToLocalIsoString(dateObj); // like: '2020-02-20T19:52:13.634'
        log(`Ermittelte aktuelle Uhrzeit: ${isoDateStrHelper}`);
         * Convert date/time to a local ISO string
         * This function is needed since toISOString() uses UTC +0 (Zulu) as time zone.
         * https://stackoverflow.com/questions/10830357/
         * Mic-M, 04/Apr/2020
         * @param {object}  date    Date object
         * @return {string}  string like "2015-01-26T06:40:36.181", without trailing Z (which would represent Zulu time zone)
        function dateToLocalIsoString(date) {
            const timezoneOffset = date.getTimezoneOffset() * 60000; //offset in milliseconds
            return (new Date(date.getTime() - timezoneOffset)).toISOString().slice(0, -1);
        Poste dann das Log hier, also etwa:
        20:55:08.230	info	javascript.0 (1672) script.js.Test_1: Ermittelte aktuelle Uhrzeit: 2020-07-30T20:55:08.230
          @Mic
          javascript.0	2020-07-31 07:23:43.471	info	(73851) script.js.java.test.test: Ermittelte aktuelle Uhrzeit: 2020-07-31T07:23:43.471
          • Glasfaser
            Glasfaser @Kuddel last edited by
            @Kuddel sagte in Test: Adapter Log Parser v0.x.x GitHub:
            Habe ein komisches Phänomen:
            Hast du danach mal dein System neu gestartet ........ !?
              Kuddel @Glasfaser last edited by
              @Glasfaser ja das System wurd schon einmal neugestartet
              • Glasfaser
                Kannst du in deinen Script mal zusätzlich Bewässerung1 anlegen und im Adapter den Log neu dazu nehmen , ob es auch dort so ist .
                  @Glasfaser ist erstellt. ich werde beobachten
                    Kuddel @Kuddel last edited by
                    @Kuddel leider ist das verhalten im neuen log genau so
                    • Glasfaser
                      Glasfaser @Kuddel last edited by Glasfaser
                      @Kuddel
                      Logpaser Version 1.0.3
                      Fehler gefunden ..... den Rest muss @Mic rausfinden 🙂
                      Habe mal um die gleiche Uhrzeit den Log geschrieben ... aber an der Uhrzeit liegt es nicht .
                      Sondern ... an der Tabellenauswahl von den Datenpunkten (Json) !
                      @Mic sagte in Test: Adapter Log Parser v0.x.x GitHub:
                      Es scheint, dass wohl das 0:00 Uhr Schedule für die Aktualisierung der Datumswerte auf heute/gestern nicht ausgeführt wurde.
                      Da hat sich wohl ein Fehler in den letzten Versionen eingeschlichen , so das die Datumswerte in den JSON von den einzelnen Tabellen nicht geändert werden , sondern nur die vom visualization.table0.json !?
                      Hier die Tabelle Bewaesserung über den Datenpunkt ( die Formatierung der Tabelle ist nicht eingestellt bitte nicht beachten )
                      logparser.0.filters.Bewaesserung.json
                      hier die Tabelle Bewaesserung über den Datenpunkt ( gewählt Bewaesserung )
                      logparser.0.visualization.table0.json
                      und hier mein Datenpunkt von der EMA .
                      logparser.0.filters.Alarmzustand_Scharfschaltung.json
                      • Mic
                        Mic Developer @Glasfaser last edited by
                        @Kuddel
                        Heute/Gestern-Fehler:
                        @Glasfaser
                        Danke, dass du dir das näher angesehen hast und das isolieren konntest!
                        So wie es scheint, war der Fehler schon immer da, aber fiel nie wirklich auf, weil über "logparser.0.visualization"-Datenpunkte immer die aktuelle Variable gelesen wird, und nicht der State in Filter.
                        Sollte jetzt behoben sein in Version 1.0.4.
                        @Kuddel
                        @Glasfaser
                        Bitte testet mal jetzt die 1.0.4 und gebt Feedback ob alles so jetzt geht.
                        Danke.
                        Glasfaser K 2 Replies Last reply Reply Quote 1
                          sigi234 Forum Testing Most Active @Mic last edited by sigi234
                          @Mic
                          Hallo, kann man die Filter nicht exportieren? Sichern?
                          Edit:
                          Gibt es ja schon.
                          Mic Glasfaser 3 Replies Last reply Reply Quote 0
                          • Mic
                            Mic Developer @sigi234 last edited by
                            @sigi234 sagte in Test: Adapter Log Parser v0.x.x GitHub:
                            Bitte beschreibe den Use Case.
                            • Glasfaser
                              Glasfaser @sigi234 last edited by
                              • Glasfaser
                                Glasfaser @Mic last edited by
                                @Kuddel
                                @Glasfaser
                                Danke.
                                Werde ich machen 😉
                                • Mic
                                  @Glasfaser sagte in Test: Adapter Log Parser v0.x.x GitHub:
                                  Werde ich machen
                                  Sobald erfolgreich getestet, pushe ich NPM, so dass die 1.0.4 sofort ins Latest Repository geht.
                                  • Glasfaser
                                    @Mic
                                    Edit:
                                    Gibt es ja schon.
                                    • Glasfaser
                                      Glasfaser @Mic last edited by Glasfaser
                                      @Mic 👍
                                      Mic 1 Reply Last reply Reply Quote 1
                                        @Kuddel
                                        @Glasfaser
                                        Danke.
                                        Version 1.0.4 ist installiert, ich werde berichten. Vielen Dank schon einmal
                                        • Mic
                                          @Glasfaser
                                          vielen Dank für das visuelle Feedback 🙂 Ich pushe jetzt die 1.0.4 ins Latest.
                                            @Mic bei mir funzt es jetzt auch
                                            adapter log logging logparser parser vis
                                            21
                                            213
                                            32555
