    4. Setzen von HM Systemvariablen mit JS
      jensus11 last edited by
      So jetzt konnte ich das Testen.
      Das ist die Log Meldung.
      geofency-0	2016-02-26 20:05:10	info	adapter geofency received webhook from device Hans.php with values: name: Haus, entry: 1
      geofency-0	2016-02-26 20:04:50	info	adapter geofency received webhook from device Hans.php with values: name: Haus, entry: 0
      javascript-0	2016-02-26 20:03:43	info	script.js.test: registered 1 subscription and 0 schedules
      javascript-0	2016-02-26 20:03:42	info	Start javascript script.js.test
      javascript-0	2016-02-26 20:03:42	info	Stop script script.js.test
      javascript-0	2016-02-26 20:03:39	info	script.js.test: registered 1 subscription and 0 schedules
      javascript-0	2016-02-26 20:03:39	info	Start javascript script.js.test
      javascript-0	2016-02-26 20:03:20	info	Stop script script.js.test
      javascript-0	2016-02-26 20:02:54	info	Stop script script.js.Script1
      javascript-0	2016-02-26 20:01:06	info	Stop script script.js.geo1
        pix last edited by
        das ist aber nicht die Logausgabe bei Änderung des Status. Die sollte mit "Neuer Geofency-Wert " beginnen.
        Pix
          wenn ich unter Webhook betreten oder verlassen in der App betätige kommen diese Zeilen im Log.
          was kann das denn sein das ich da nicht das habe was du schreibst?
          geofency-0	2016-02-26 20:53:31	info	adapter geofency received webhook from device Hans.php with values: name: Haus, entry: 1
          geofency-0	2016-02-26 20:52:10	info	adapter geofency received webhook from device Hans.php with values: name: Haus, entry: 0
          und wenn ich das script aktualisiere kommt das.
          javascript-0	2016-02-26 21:02:34	info	script.js.test: registered 1 subscription and 0 schedules
          javascript-0	2016-02-26 21:02:34	info	Start javascript script.js.test
          javascript-0	2016-02-26 21:02:34	info	Stop script script.js.test
          • ruhr70
            ruhr70 last edited by
            @jensus11:
            on('geofency.0.Hans.php.Haus.entry.state', function(obj) {
                log('Neuer Geofency-Wert ' + obj.state.val);
                setState('hm-rega.0.7680.state', obj.state.val);
            Kann das sein, dass das .state da nicht hingehört?
            Also:
            on('geofency.0.Hans.php.Haus.entry', function(obj) {
            Welchen Wert benötigst Du in der CCU Variable?
            Geofency liefert nicht true oder false sondern "0" und "1".
              ich brauche eigentlich die Werte wahr und falsch für zu Hause und unterwegs.
              wenn ich das state weglasse dann kommen Fehlermeldungen im Log.
              TypeError:	2016-02-28 12:58:15	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
              TypeError:	2016-02-28 12:58:15	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30)
              TypeError:	2016-02-28 12:58:15	error	at Object.that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1969:80)
              TypeError:	2016-02-28 12:58:15	error	at Object.utils.adapter.stateChange (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:215:17)
              TypeError:	2016-02-28 12:58:15	error	at checkPatterns (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:524:17)
              TypeError:	2016-02-28 12:58:15	error	at getObjectEnums (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2434:28)
              TypeError:	2016-02-28 12:58:15	error	at getObjectEnums (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2415:17)
              TypeError:	2016-02-28 12:58:15	error	at /opt/iobroker/node_modules/iobroker.javascript/javascript.js:528:48
              TypeError:	2016-02-28 12:58:15	error	at Object.subs.callback (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:1190:48)
              TypeError:	2016-02-28 12:58:15	error	at Object. (script.js.Anwesenheit:3:45)
              TypeError:	2016-02-28 12:58:15	error	Cannot read property 'val' of undefined
              message	2016-02-28 12:58:15	error	geofency.0.Hans.php.Haus.entry [object Object] Cannot read property 'val' of undefined
              javascript-0	2016-02-28 12:58:15	info	script.js.Anwesenheit: Neuer Geofency-Wert 1
              geofency-0	2016-02-28 12:58:15	info	adapter geofency received webhook from device Hans.php with values: name: Haus, entry: 1
              • ruhr70
                @jensus11:
                Jetzt reagiert Dein Script schon einmal auf die Geofency Änderung. Die Ausgabe war die Log() Zeile.
                D.h. ohne .state war richtig. Das Script reagiert nun auf Veränderungen.
                @jensus11:
                Hatte ich übersehen. Auch im hm-rega Datenpunkt ist das .state zu viel. Der Datenpunkt heisst einfach nur 7680.
                Das state ist deswegen verwirrend, da in den hm-rpc die benötigten Datenpunkten oft STATE heissen.
                Die richtige Bezeichnung findest Du immer in der linken Spalte unter Objekte, wenn Du bis zum Ende aufgeklappt hast.
                Das state, welches Du jeweils eingetragen hast ist einfach nur die Typenbeschreibung aus der Spalte Typ.
                So sollte es dann funktionieren:
                    setState('hm-rega.0.7680', obj.state.val);
                • ruhr70
                      if (obj.state.val == "1") {
                      	setState('hm-rega.0.7680', true);
                      } else {
                      	setState('hm-rega.0.7680', false);
                  Noch mit der Umwandlung der "1" in true und der "0" in false.
                    Super, jetzt funktioniert das. Leider mit eine Änderung noch.
                    Das state musste ich noch entfernen.
                    so ist das jetzt korrekt.
                        } else {
                    • ruhr70
                      ach…
                      sorry... da hatte ich den falschen Code von oben codiert und verändert 😉
                        dtp last edited by
                        Hätte hierzu noch eine ergänzende Frage.
                        Ich habe folgendes Skript, um damit einen ioBroker-Datenpunkt in eine HM-Systemvariable zu schreiben:
                        // Vitotronic Partybetrieb
                        on( 'javascript.0.Vitotronic.BetriebParty', function (obj) {
                          log(obj.newState.val);
                          setState('hm-rega.0.2883.state', obj.newState.val);
                        Problem ist, dass der Datenpunkt "javascript.0.Vitotronic.BetriebParty" die Zustände "an" und "aus" besitzen kann, "hm-rega.0.2883.state" aber nur 0 und 1 akzeptiert. Nun könnte man natürlich nach obigem Beispiel eine kleine if-Abfrage zum Übersetzen der Zustände einfügen. Bei einigen Datenpunkten sind aber fünf und mehr verschiedene Werte möglich. Daher würde ich gerne auf eine Transformation verzichten und die Werte direkt in die Systemvariable schreiben.
                        Mit
                          curl -s -k "http://192.168.0.20:8181/rega.exe?x=dom.GetObject(2883).State('an')"
                        klappt das auch. Aber wie kann ich das nun in das obige Skript einbinden? Geht das z.B. mit exec?
                        Gruß,
                        Thorsten
                          paul53 last edited by
                          @dtp:
                          Problem ist, dass der Datenpunkt "javascript.0.Vitotronic.BetriebParty" die Zustände "an" und "aus" besitzen kann, "hm-rega.0.2883.state" aber nur 0 und 1 akzeptiert. `
                          Dann hat die SV den falschen Typ. Sie muss vom Typ "Zeichenkette" sein !
                          Außerdem ist die ID der SV 'hm-rega.0.2883'.
                            setState('hm-rega.0.2883', obj.newState.val);  // in SV vom Typ "Zeichenkette" übertragen
                            @dtp:
                            Nun könnte man natürlich nach obigem Beispiel eine kleine if-Abfrage zum Übersetzen der Zustände einfügen. Bei einigen Datenpunkten sind aber fünf und mehr verschiedene Werte möglich. `
                            Wenn SV vom Typ "Werteliste" gesetzt werden sollen, ist das auch nicht so schwierig:
                            // Zustandstexte Betriebsart
                            var ba = ['Abschaltbetrieb','Nur Warmwasser','Heizen und Warmwasser','Dauernd red. Betrieb','Dauernd Normalbetrieb'];
                            on('javascript.0.Vitotronic.Betriebsart', function (obj) {
                              setState('hm-rega.0.1234', ba.indexOf(obj.newState.val));
                              dtp last edited by
                              Danke, das hat mir schon mal sehr geholfen.
                              Gruß,
                              Thorsten
                                dtp last edited by
                                So, habe mir jetzt auf der CCU die Systemvariable als Werteliste mit den Werten
                                Abschaltbetrieb;Nur Warmwasser;Heizen und Warmwasser;Dauernd red. Betrieb;Dauernd Normalbetrieb
                                angelegt und setze deren Werte nun folgendermaßen:
                                // Vitotronic Betriebsart
                                  switch (obj.newState.val) {
                                    case "Abschaltbetrieb":
                                      setState('hm-rega.0.1234', 0);
                                    break;
                                    case "Nur Warmwasser":
                                      setState('hm-rega.0.1234', 1);
                                    break;
                                    case "Heizen und Warmwasser":
                                      setState('hm-rega.0.1234', 2);
                                    break;
                                    case "Dauernd red. Betrieb":
                                      setState('hm-rega.0.1234', 3);
                                    break;
                                    case "Dauernd Normalbetrieb":
                                      setState('hm-rega.0.1234', 4);
                                    break;
                                Damit habe ich eine Möglichkeit, die verschiedenen Zustände von "javascript.0.Vitotronic.Betriebsart" unabhängig von ihrer Reihenfolge in die Systemvariable der CCU zu schreiben.
                                Gruß,
                                Thorsten
                                  @dtp:
                                  Damit habe ich eine Möglichkeit, die verschiedenen Zustände von "javascript.0.Vitotronic.Betriebsart" unabhängig von ihrer Reihenfolge in die Systemvariable der CCU zu schreiben. `
                                  Das geht auch mit dem Array. Die Reihenfolge im Array muss der in der Werteliste (CCU) entsprechen und hat nichts mit der Wertzuordnung in vcontrold zu tun. Die Einzeltexte innerhalb des Array müssen identisch zu den Texten in der vito.xml sein, können aber von den Texten in der Werteliste abweichen.
                                    dtp last edited by
                                    Meinst Du mit Array die obige Variable "ba"? Da gab es nur leider ein kleines Problem. Der Datenpunkt "javascript.0.Vitotronic.Betriebsart" enthält die Strings "Abschaltbetrieb", "Nur Warmwasser" etc. Dein obiger Skriptvorschlag geht aber davon aus, dass "javascript.0.Vitotronic.Betriebsart" die Integer-Werte 0 bis 4 annimmt, die dann als Index in "setState" übergeben werden.
                                    Oder habe ich da was falsch verstanden?
                                      @dtp:
                                      Dein obiger Skriptvorschlag geht aber davon aus, dass "javascript.0.Vitotronic.Betriebsart" die Integer-Werte 0 bis 4 annimmt, die dann als Index in "setState" übergeben werden. `
                                      Nein, der Vorschlag geht davon aus, dass "javascript.0.Vitotronic.Betriebsart" den jeweiligen Zustandstext ("Abschaltbetrieb", …) enthält. Würde der Datenpunkt den Wert 0 bis 4 enthalten, könnte man ihn direkt ohne Umweg über
                                      in die SV schreiben. ba.indexOf(Text) ermittelt die Position des Textes im Array ba. Das Ergebnis ist ein Integer-Wert 0 bis 4.
                                        dtp last edited by
                                        Hallo paul53,
                                        danke. Da lag wohl ein kleiner Denkfehler meinerseits vor.
                                        Gruß,
                                        Thorsten
                                        5843
