    4. Test Adapter mihome-vacuum v2.0.x
    • Kevin
      Kevin @Thomas Braun last edited by
      @Thomas-Braun
      Also ich hab es nun gefixed bekommen.
      Node12 installieren
      IoBroker fix
      npm rebuild im IoBroker Verzeichnis
      npm rebuild --build-from-source canvas
      Iobroker fix
      Seitdem funktioniert es auch mit node 12
      Thomas Braun X 3 Replies Last reply Reply Quote 1
        Thomas Braun Most Active @Kevin last edited by
        @Kevin Mein reden...
        • X
          xADDRx @Kevin last edited by
          @Kevin verändert es irgendwas am System?
          Nicht das dann gar nichts mehr geht.
          Kevin 1 Reply Last reply Reply Quote 0
          • Kevin
            Kevin @xADDRx last edited by
            @xADDRx kann nur von meiner Erfahrung sprechen. Bei mir lief dannach immer noch alles wie davor.
            • X
              @Kevin IObroker fix ging durch..
              beim npm Fehler:
              root@debian:/opt/iobroker# npm rebuild
              > iobroker@1.0.6 install /opt/iobroker/node_modules/iobroker
              > node lib/setup.js
              NPM version: 6.13.4
              NPM 5 is currently NOT supported!
              Please use "npm install -g npm@4" to downgrade npm to 4.x and try again.
              You need to make sure to downgrade again with the above command after you
              installed an update to nodejs/npm!
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! iobroker@1.0.6 install: `node lib/setup.js`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the iobroker@1.0.6 install script.
              npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
              npm ERR!     /home/iobroker/.npm/_logs/2020-08-07T09_32_00_912Z-debug.log
              root@debian:/opt/iobroker# npm rebuild --build-from-source canvas
              > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
              > node-pre-gyp install --fallback-to-build
              node-pre-gyp WARN Using request for node-pre-gyp https download
              Package pixman-1 was not found in the pkg-config search path.
              Perhaps you should add the directory containing `pixman-1.pc'
              to the PKG_CONFIG_PATH environment variable
              No package 'pixman-1' found
              gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
              gyp ERR! configure error
              gyp ERR! stack Error: `gyp` failed with exit code: 1
              gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
              gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
              gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
              gyp ERR! System Linux 4.9.0-4-amd64
              gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
              gyp ERR! cwd /opt/iobroker/node_modules/canvas
              gyp ERR! node -v v12.16.3
              gyp ERR! node-gyp -v v5.1.0
              gyp ERR! not ok
              node-pre-gyp ERR! build error
              node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
              node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
              node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
              node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
              node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
              node-pre-gyp ERR! System Linux 4.9.0-4-amd64
              node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
              node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
              node-pre-gyp ERR! node -v v12.16.3
              node-pre-gyp ERR! node-pre-gyp -v v0.11.0
              node-pre-gyp ERR! not ok
              npm ERR! errno 1
              npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
              npm ERR!
              npm ERR! Failed at the canvas@2.6.1 install script.
              npm ERR!     /home/iobroker/.npm/_logs/2020-08-07T09_32_42_894Z-debug.log
              gyp ERR! not ok
              npm ERR! errno 1
              npm ERR!
              npm ERR!     /home/iobroker/.npm/_logs/2020-08-07T09_36_07_361Z-debug.log
              Kevin Thomas Braun 2 Replies Last reply Reply Quote 0
              • Kevin
                @xADDRx
                ist deine npm version aktuell?
                • X
                  @Kevin Wenn ich das richtig sehe habe ich Version : NPM version: 6.13.4 drauf...
                    Thomas Braun Most Active @xADDRx last edited by Thomas Braun
                    @xADDRx Docker auf einer Synology? Ansonsten: Meld dich nicht als root an!
                    Da scheint mir die Installation von node mal wieder in die Hose gegangen zu sein.
                    Schau hier rein:
                    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                    • X
                      xADDRx @Thomas Braun last edited by
                      @Thomas-Braun Keine Synology! Node habe ich nach der Anleitung damals ohne Fehler installiert gehabt.
                        @xADDRx
                        Dann ist da wohl alles mögliche verfummelt. Deine Version vom js-controller ist auch uralt. Jedenfalls lt. Log.
                        root-Login ist jedenfalls absoluter Quark. Kannste Mal den @Freaknet fragen. Nur ein paar Postings zuvor.
                        Wenn du Hilfe beim glattziehen möchtest mach am besten einen neuen, eigenen Thread dafür auf. Hier führt das zu weit.
                        • X
                          xADDRx @Thomas Braun last edited by xADDRx
                          @Thomas-Braun Hmmm. Also JS Controller ist aug 3.1.6. Auch habe ich sonst keine Porbleme. Sowohl die Karte als auch die Räume haben ja vorm Adapter Update funktionert und wurden geladen sobald man auf dem Button geklickt hat...
                          Thomas Braun X 2 Replies Last reply Reply Quote 0
                            @xADDRx Das Install-Log zeigt was anderes an.
                            • X
                              @Thomas-Braun Was sollte ich am besten tun??
                              • Kevin
                                Kevin @xADDRx last edited by Kevin
                                @xADDRx
                                Versuch mal das:
                                iobroker stop
                                sudo apt-get update
                                sudo apt-get upgrade
                                sudo apt-get --purge remove nodejs -y
                                sudo apt-get autoremove -y
                                sudo reboot
                                curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
                                sudo sh -c "echo deb https://deb.nodesource.com/node_12.x disco main \> /etc/apt/sources.list.d/nodesource.list"
                                sudo apt-get update
                                sudo apt-get install nodejs -y
                                npm install -g npm@6
                                sudo reboot
                                iobroker update
                                iobroker upgrade self
                                iobroker fix
                                cd /opt/iobroker/
                                npm rebuild
                                  Thomas Braun Most Active @Kevin last edited by Thomas Braun
                                  @Kevin Woher weißt du dass da Disco läuft?
                                  So wird das mutmaßliche Installationschaos doch nur noch größer...
                                  Da dürfte eher ein Debian laufen, kein Ubuntu.
                                  • Kevin
                                    @Thomas-Braun so habe ich es bei mir zum laufen gebracht. Auf raspbian
                                      @Kevin Dann hast du jetzt ein falsches Repo drin. Disco Dingo ist nicht für Raspian gedacht.
                                      Vermutlich bist Du auch auf einem hervorragenden Weg dein System zu zerballern.
                                        @xADDRx Mach einen neuen Thread auf und poste da die Ausgabe von
                                        lsb_release -a
                                        sowie von
                                        which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                        Komplette Eingaben und auch Ausgaben posten, nichts kürzen oder abändern...
                                        Das gleiche würde ich @Kevin auch empfehlen...
                                          Sweatchuck @K_o_bold last edited by
                                          @K_o_bold
                                          Habe die Version 5 drauf und bisher ausschließlich den Container von Buanet genutz. Funktioniert trotzdem nicht.
                                          Entsprechend der Anleitung von Buanet habe ich über portainer den ioBroker Container über Recreate neu erstellt und das neueste Image eingespielt. (siehe Bild)
                                          • X
                                            @Thomas-Braun https://forum.iobroker.net/topic/35767/node-fehlerbehebung
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            467283
