    4. Waschmaschinen Skript - alte Waschmaschine
      Dragon @Sebastian 0 last edited by
      @Sebastian-0 versuche es mal hiermit und gib ruhig eine rückmeldung.
        <variables>
          <variable type="" id="Hhe!Hg(xh7gHuy(6hLlx">WaMa_EinAus</variable>
          <variable type="undefined" id="timeout">timeout</variable>
        </variables>
        <block type="variables_set" id="i@;~wXOo)(5+=$*9v:QF" x="-1487" y="-712">
          <field name="VAR" id="Hhe!Hg(xh7gHuy(6hLlx" variabletype="">WaMa_EinAus</field>
            <block type="logic_boolean" id="stD7DD67D[4(YSQ3dCvR">
            <block type="on_ext" id="%l??Ns0%ZOhlZQJn)RIY">
              <value name="OID0">
                <shadow type="field_oid" id="8p+iN2CjzC1M$2o|Xq=m">
                  <field name="oid">sonoff.0.wama.ENERGY_Power</field>
                <block type="controls_if" id="-4y,4m5H6`8[U,UjJH(0">
                    <block type="logic_operation" id="-^U__L=#GGG_LD~6o~hg" inline="false">
                      <field name="OP">AND</field>
                      <comment pinned="false" h="90" w="276">Falls Maschinengang erkannt (Wattzahl &gt;10) UND Modus ist auf falsch dann starte und schreibe den aktuellen verbrauch in DP</comment>
                        <block type="logic_compare" id="-%Kg)H+S;{}Yyd@cqe=l">
                          <field name="OP">GTE</field>
                            <block type="on_source" id="QS5)==Ahwtfe.nNTl`R@">
                            <block type="math_number" id="OT1x**T)z3hCtGxhqDDI">
                              <field name="NUM">3</field>
                        <block type="logic_compare" id=",LW+*+gUB/lbO[yiNJdv">
                          <field name="OP">EQ</field>
                            <block type="variables_get" id="[$/1md}o9xogfLp*!}WA">
                            <block type="logic_boolean" id="V}KP*,b;J,.3q802Q0l^">
                    <block type="variables_set" id="HHIFm}6:*U#VVrIRv7e|">
                        <block type="logic_boolean" id="%.`!o$LmcZOm0##5WWoJ">
                  <value name="IF1">
                    <block type="logic_operation" id="0X}/pU5wm]*t/X()F/`o" inline="false">
                        <block type="logic_compare" id="igy_8vlVI|k$sL-O!_Ya">
                          <field name="OP">LTE</field>
                            <block type="on_source" id="oKi^o%$Qa%i0^MVE?s)Y">
                            <block type="math_number" id="*bx}yjZ_C7J2#/$NzLoS">
                              <field name="NUM">2</field>
                        <block type="logic_compare" id="G0Uqh*}eA:azZAk*i=9Q">
                            <block type="variables_get" id="wpJh-gXLr7*PATlD$R.+">
                            <block type="logic_boolean" id="z,qc#KI[8UAh!CGwL!G8">
                  <statement name="DO1">
                    <block type="timeouts_settimeout" id="Z(j/CPCQ(|-Kd8S5)`8R">
                      <field name="DELAY">20000 </field>
                      <field name="UNIT">ms</field>
                        <block type="controls_if" id="XQQbxoy?NpAex3?:E~TE">
                            <block type="logic_compare" id="6jt,tA.X{uH677$h/.!i">
                                <block type="on_source" id=",Hg?!*0ueS~(BO3NFPg`">
                                <block type="math_number" id="]RWnXnP;U#Y0)CVbUFuE">
                            <block type="variables_set" id="vj!Vu=sDr5yt.:ZU#OfU">
                                <block type="logic_boolean" id="5xCJ(QRB3mIo5.*f1Fsg">
                                <block type="debug" id="~(eEE8/,iS{wG@j0X)TU">
                                  <value name="TEXT">
                                    <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="3K0c5WSS9VmMq/XFB(e9">
                                    <block type="text_join" id="2xby$^zDuX^$?-Yp2~k,">
                                      <value name="ADD0">
                                        <block type="text" id="L6trfC]%tV;Q1#[_3UQJ">
                                          <field name="TEXT">Status Waschmaschine Ein/Aus ist: </field>
                                      <value name="ADD1">
                                        <block type="variables_get" id="mN7^USWq(%,us)OL?!1#">
                                    <block type="telegram" id=":)Sqh|eio_J%+h7Q@6nJ">
                                      <field name="LOG"></field>
                                      <value name="MESSAGE">
                                        <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="zaE.r=+WylppU_4Nmdx~">
                                          <field name="TEXT">Waschmaschine ist fertig</field>
                                        <block type="text_join" id="3,~.TJZeugM.!B%S1^X}">
                                          <value name="ADD0">
                                            <block type="text" id="|9?4%ic*sy2}Q088ry:q">
                                              <field name="TEXT">Wama1: Die Waschmaschine ist Fertig.</field>
                                          <value name="ADD1">
                                            <block type="time_get" id="a?D^RPe+s+Si=*kkfgj[">
                                              <mutation format="true" language="false"></mutation>
                                              <field name="OPTION">custom</field>
                                              <field name="FORMAT">\n</field>
                                      <value name="USERNAME">
                                        <block type="text" id="ClQ#mBX9^]LxIc[8FtLL">
                                          <field name="TEXT">Basti</field>
        paul53 @Dragon last edited by paul53
        @David-Froebus sagte:
        ... oder hiermit:
         <variables>
         </variables>
         <block type="on_ext" id="%l??Ns0%ZOhlZQJn)RIY" x="-1562" y="-710">
           <value name="OID0">
                 <block type="timeouts_cleartimeout" id="[|uKdSf;U5L|oAQLC}jm">
               <value name="IF1">
                 <block type="logic_negate" id="`-LWIv*z%.V!Fkvp3,tL">
                   <value name="BOOL">
                     <block type="variables_get" id="[ecAG5R%OiU,3;]/{,WZ">
                       <field name="VAR" id="timeout" variabletype="timeout">timeout</field>
                   <field name="DELAY">20</field>
                       <value name="TEXT">
                         <shadow type="text" id="3K0c5WSS9VmMq/XFB(e9">
                         <block type="text" id="C!8DETfUf]vT,!5*_()+">
                               <value name="ADD0">
                               <value name="ADD1">
                                   <field name="OPTION">hh:mm</field>
          Dragon @paul53 last edited by
          @paul53 Hätte es mir gern angesehen. leider nicht möglich zu importieren.
            Wirklich ? Ich kann es importieren.
                @David-Froebus
                Habe das Blockly gelöscht und anschließend ohne Probleme aus dem Forum importiert.
                  @paul53 habe noch mal ein neues blockly erstellt. Da lässte es sich importieren nur leider ergibt das skript keinen sinn. darin wird eine variable verwendet die weder definiert noch irgendwie gefüllt wird. sie wird lediglich geprüft. Aber nicht benutzt.
                    Meinst Du die Variable timeout ? Die wird mit "Ausführen timeout" gefüllt und mit "stop timeout" auf null gesetzt. Schau mal in den Javascript-Code.
                      Dragon @paul53 last edited by Dragon
                      @paul53 dann sehe ich das richtig dass du alle 20 sekunden bei änderung des powerwertes und niedriger als 3 eine nachricht bekommst. weil du prüfst ja nach 20 sek nicht noch einmal ob der wert immer noch so niedrig ist. also ab beginn der ersten programmpause bekommst du jede pause im zwanzig sekunden takt eine nachricht. ich denke das ist nicht das was er gewollt hat. oder verstehe ich das skript grad falsch?
                      und wenn ich ehrlich bin verstehe ich noch immer nicht was die prüfung von timeout zurückgibt.
                        Offenbar. Wenn der Wert >= 3 ist, wird der Timer gestoppt und die Variable timeout auf null gesetzt. Ist der Wert < 3, wird nur dann wenn die Variable timeout = null (oder undefined) ist, der Timer gestartet. Solange die Variable timeout nicht auf null gesetzt wird (Wert >= 3) kann kein neuer Timer starten.
                        D Sebastian 0 2 Replies Last reply Reply Quote 0
                          @paul53 vielen dank für die Erklärung. ich habe das Skript tatsächlich nicht verstanden. Ich denke wir erreichen Beide das Gleiche. Deines ist lediglich einfacher. Da habe ich doch wieder etwas dazugelernt und kann es vll auch in meinen Skripten verwenden. Vielen Dank!
                          • Sebastian 0
                            Sebastian 0 @paul53 last edited by
                            @paul53 @David-Froebus
                            Danke euch beiden! Ich teste mal beide Skripte aus und gebe euch eine Rückmeldung.
                            Sebastian 0 1 Reply Last reply Reply Quote 0
                            • Sebastian 0
                              Sebastian 0 @Sebastian 0 last edited by Sebastian 0
                              Leider hat die Änderung es verschlimmbessert 😄
                              Ich habe mal auf den Verbrauch während dem Waschens geachtet. Nach der Änderung war es so, dass jedes mal sobald die Maschine auf 2W gesprungen ist eine Nachricht kam. Vorher waren es pro Waschvorgang so ca. die hälfte der Nachrichten die ich bekommen habe.
                              @David-Froebus dein Skirpt ist "Wama1_alt/neu: Die Waschmaschine ist Fertig"
                              @paul53 deins ist "TEST FORUM 2 Waschmaschine ist Fertig"
                              Exaktes Waschende war 10:31 Uhr.
                              • home, [09.08.20 09:33]
                              • Waschmaschine fertig! TEST
                              • Wama2: Die Waschmaschine ist Fertig.
                              • Dauer: 4 Minuten.
                              • Die Waschmaschine ist Fertig.
                              • Dauer: 4 Minuten.
                              • Verbrauch: 0.13 kWh.
                              • home, [09.08.20 09:34]
                              • Wama1_alt/neu: Die Waschmaschine ist Fertig.
                              • home, [09.08.20 09:39]
                              • Dauer: 5 Minuten.
                              • Dauer: 5 Minuten.
                              • Verbrauch: 0.19 kWh.
                              • home, [09.08.20 09:40]
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • home, [09.08.20 09:42]
                              • Dauer: 1 Minuten.
                              • Dauer: 1 Minuten.
                              • Verbrauch: 0.02 kWh.
                              • home, [09.08.20 09:43]
                              • TEST FORUM 2 Waschmaschine ist Fertig.09:43
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • home, [09.08.20 09:44]
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • home, [09.08.20 09:46]
                              • Dauer: 1 Minuten.
                              • Dauer: 1 Minuten.
                              • Verbrauch: 0 kWh.
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • home, [09.08.20 09:47]
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • home, [09.08.20 09:48]
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • home, [09.08.20 09:49]
                              • Dauer: 1 Minuten.
                              • Dauer: 1 Minuten.
                              • Verbrauch: 0 kWh.
                              • home, [09.08.20 09:50]
                              • TEST FORUM 2 Waschmaschine ist Fertig.09:50
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • home, [09.08.20 09:51]
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • home, [09.08.20 09:53]
                              • Dauer: 1 Minuten.
                              • Dauer: 1 Minuten.
                              • Verbrauch: 0 kWh.
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • home, [09.08.20 09:54]
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • home, [09.08.20 09:55]
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • home, [09.08.20 10:02]
                              • Dauer: 7 Minuten.
                              • Dauer: 6 Minuten.
                              • Verbrauch: 0.03 kWh.
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • home, [09.08.20 10:03]
                              • TEST FORUM 2 Waschmaschine ist Fertig.10:03
                              • home, [09.08.20 10:05]
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • home, [09.08.20 10:06]
                              • TEST FORUM 2 Waschmaschine ist Fertig.10:06
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • home, [09.08.20 10:10]
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • TEST FORUM 2 Waschmaschine ist Fertig.10:10
                              • home, [09.08.20 10:11]
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • TEST FORUM 2 Waschmaschine ist Fertig.10:11
                              • home, [09.08.20 10:12]
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • TEST FORUM 2 Waschmaschine ist Fertig.10:12
                              • home, [09.08.20 10:15]
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • TEST FORUM 2 Waschmaschine ist Fertig.10:15
                              • home, [09.08.20 10:16]
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • TEST FORUM 2 Waschmaschine ist Fertig.10:16
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • home, [09.08.20 10:17]
                              • TEST FORUM 2 Waschmaschine ist Fertig.10:17
                              • home, [09.08.20 10:19]
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • home, [09.08.20 10:20]
                              • TEST FORUM 2 Waschmaschine ist Fertig.10:20
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • home, [09.08.20 10:21]
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • TEST FORUM 2 Waschmaschine ist Fertig.10:21
                              • home, [09.08.20 10:24]
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • TEST FORUM 2 Waschmaschine ist Fertig.10:24
                              • home, [09.08.20 10:26]
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • TEST FORUM 2 Waschmaschine ist Fertig.10:26
                              • home, [09.08.20 10:30]
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • Dauer: 0 Minuten.
                              • TEST FORUM 2 Waschmaschine ist Fertig.10:30
                              • Dauer: 0 Minuten.
                              • Dauer: 0 Minuten.
                              • Verbrauch: 0 kWh.
                              • home, [09.08.20 10:31]
                              • TEST FORUM 2 Waschmaschine ist Fertig.10:31
                                paul53 @Sebastian 0 last edited by paul53
                                @Sebastian-0 sagte:
                                Dann ist die Verzögerungszeit von 20 s zu kurz. Sie muss größer sein als die längste Pause (2 W).
                                blockly monitoring
                                931
