    3. Entwicklung
    4. [Neuer Adapter] Proxmox VM
      Kueppert last edited by
      Hallo in die Runde,
      nachdem mein SATA-Controller vom NUC abgeraucht ist, hab ich mir das neue Proxmox auf ne SSD gemacht und an USB3 dran (war ne ganz schöne Aktion herauszufinden, dass der Controller hinüber ist 😞 )
      Hab nun Proxmox 6.1 druff...und leider tuts der Adapter damit anscheinend (noch) nicht? Erhalte im Log folgende Fehler beim Start vom Adapter:
      host.ioBroker2	2020-03-28 23:48:49.277	info	Restart adapter system.adapter.proxmox.0 because enabled
      host.ioBroker2	2020-03-28 23:48:49.276	info	instance system.adapter.proxmox.0 terminated with code 0 (NO_ERROR)
      host.ioBroker2	2020-03-28 23:48:49.276	error	Caught by controller[0]: at IncomingMessage.emit (events.js:203:15)
      host.ioBroker2	2020-03-28 23:48:49.276	error	Caught by controller[0]: at Object.onceWrapper (events.js:286:20)
      host.ioBroker2	2020-03-28 23:48:49.276	error	Caught by controller[0]: at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12)
      host.ioBroker2	2020-03-28 23:48:49.276	error	Caught by controller[0]: at Request.emit (events.js:198:13)
      host.ioBroker2	2020-03-28 23:48:49.276	error	Caught by controller[0]: at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10)
      host.ioBroker2	2020-03-28 23:48:49.276	error	Caught by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
      host.ioBroker2	2020-03-28 23:48:49.276	error	Caught by controller[0]: at Request.request [as _callback] (/opt/iobroker/node_modules/iobroker.proxmox/lib/proxmox.js:167:21)
      host.ioBroker2	2020-03-28 23:48:49.276	error	Caught by controller[0]: at _get.then.data (/opt/iobroker/node_modules/iobroker.proxmox/lib/proxmox.js:43:9)
      host.ioBroker2	2020-03-28 23:48:49.276	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.proxmox/main.js:342:27
      host.ioBroker2	2020-03-28 23:48:49.275	error	Caught by controller[0]: TypeError: Cannot read property 'uptime' of undefined
      proxmox.0	2020-03-28 23:48:48.755	info	(9713) Terminated (NO_ERROR): Without reason
      proxmox.0	2020-03-28 23:48:48.753	info	(9713) terminating
      proxmox.0	2020-03-28 23:48:48.746	info	(9713) cleaned everything up...
      proxmox.0	2020-03-28 23:48:48.745	error	(9713) TypeError: Cannot read property 'uptime' of undefined at /opt/iobroker/node_modules/iobroker.proxmox/main.js:342:27 at _get.then.data (/opt/iobroker/node_modules/iobroker.proxmox/lib/pr
      proxmox.0	2020-03-28 23:48:48.745	error	(9713) uncaught exception: Cannot read property 'uptime' of undefined
      proxmox.0	2020-03-28 23:48:45.526	info	(9713) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.proxmox, node: v10.16.0
      Jemand ne Idee?? Danke euch.
      Viele Grüße, Thorsten
        A Former User @Kueppert last edited by
        @Kueppert den Fehler hab ich auch, issue ist erstellt...
        Feuersturm 1 Reply Last reply Reply Quote 1
        • Feuersturm
          Feuersturm @Guest last edited by Feuersturm
          @ilovegym Hi, meinst du deinen Eintrag an diesem Issue https://github.com/iobroker-community-adapters/ioBroker.proxmox/issues/54 ? Das Ticket ist ja bereits geschlossen. Ich weiß nicht ob der Entwickler (@Meistertr ) Tickets verfolgt, welcher bereits geschlossen sind.
          Bei mir hab ich den Fehler noch nicht gesehen. Wie provozierst du den Fehler?
          Ilovegym66 created this issue in iobroker-community-adapters/ioBroker.proxmox
          closed error: restart adapter uncaught exception uptime of undefined #54
            A Former User @Feuersturm last edited by
            @Feuersturm gar nicht, er tritt alle stunde oder so auf.. dann läufts mal wieder.. hab leider keine Regelmässigkeit oder Abhängigkeit von irgendwas gefunden...
            Die VMs sind alle immer online.. und die Node ist auch immer erreichbar..
              hab nen neuen Issue aufgemacht: https://github.com/iobroker-community-adapters/ioBroker.proxmox/issues/56
              kueppert created this issue in iobroker-community-adapters/ioBroker.proxmox
              closed Caught by controller[0]: TypeError: Cannot read property 'uptime' of undefined #56
              • david83
                david83 last edited by david83
                Hallo, ist es irgendwie möglich bei der Konfiguration die IP Adresse von Proxmox mit https:// einzugeben?
                Ich bekomme nur eine Fehlermeldung im Log:
                Ohne https:// 404:Error: connect ECONNREFUSED 192.168.178.64:8006
                mit https:// 404:Error: getaddrinfo ENOTFOUND https
                Danke,
                David
                Hat sich erledigt, Adapter erneut installiert. Läuft
                  ThetaGamma @FredF last edited by
                  @FredF said in [Neuer Adapter] Proxmox VM:
                  @frana120500 sagte in [Neuer Adapter] Proxmox VM:
                  über den Adapter einen Shutdown Befehl senden für das komplette System
                  Ja
                  Hi
                  ich denke ich hab das Problem mit dem Shutdown des Nodes über IOBroker gelöst. Hab einen PR #72 gestellt, vielleicht mag der eine oder andere mal einen Betatest mit meiner neuen Version der main.js und proxmox.js machen
                  VG
                  T
                  Feuersturm FredF 2 Replies Last reply Reply Quote 1
                  • Feuersturm
                    Feuersturm @ThetaGamma last edited by
                    @ThetaGamma was müsste ich denn machen, um deinen Pullrequest bei mir testen zu können?
                      ThetaGamma @Feuersturm last edited by
                      @Feuersturm ich glaube die einfachste Variante wäre meinen Fork zu clonen
                      git clone https://github.com/ThetaGamma/ioBroker.proxmox.git)
                      und dann in deinem iobroker-Verzeichnis im proxmox-Adapter (liegt bei mir unter /opt/iobroker/node_modules/iobroker.proxmox die Dateien "main.js" und "lib/proxmox.js" zu ersetzen (vorher ein Kopie der Original-Dateien irgendwo ablegen 😉 )
                      Feuersturm 2 Replies Last reply Reply Quote 0
                      • Feuersturm
                        @ThetaGamma Danke für die Erklärung, ich werde heute Abend einmal versuchen deine neue Version auszuprobieren.
                        • FredF
                          FredF Most Active Forum Testing @ThetaGamma last edited by
                          @ThetaGamma
                          Habe deinen Fork über die Katze auf meinem Testsystem installiert.
                          Die Server Auswahl (PVE oder PAM) wird nicht gespeichert und einloggen geht nicht:
                          2020-08-08 18:54:38.969 - info: host.ioBrokerNeu instance system.adapter.proxmox.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2020-08-08 18:54:41.470 - info: host.ioBrokerNeu instance system.adapter.proxmox.0 started with pid 26785
                          2020-08-08 18:54:41.709 - debug: proxmox.0 (26785) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2020-08-08 18:54:41.833 - debug: proxmox.0 (26785) Objects client ready ... initialize now
                          2020-08-08 18:54:41.834 - debug: proxmox.0 (26785) Objects create System PubSub Client
                          2020-08-08 18:54:41.835 - debug: proxmox.0 (26785) Objects create User PubSub Client
                          2020-08-08 18:54:41.835 - debug: proxmox.0 (26785) Objects client initialize lua scripts
                          2020-08-08 18:54:41.843 - debug: proxmox.0 (26785) Objects connected to redis: 127.0.0.1:9001
                          2020-08-08 18:54:41.846 - debug: proxmox.0 (26785) objectDB connected
                          2020-08-08 18:54:41.847 - debug: proxmox.0 (26785) Redis States: Use Redis connection: 127.0.0.1:9000
                          2020-08-08 18:54:41.849 - debug: proxmox.0 (26785) States create User PubSub Client
                          2020-08-08 18:54:41.850 - debug: proxmox.0 (26785) States create System PubSub Client
                          2020-08-08 18:54:41.852 - debug: proxmox.0 (26785) States connected to redis: 127.0.0.1:9000
                          2020-08-08 18:54:41.852 - debug: proxmox.0 (26785) statesDB connected
                          2020-08-08 18:54:41.891 - info: proxmox.0 (26785) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.proxmox, node: v12.18.2, js-controller: 3.1.6
                          2020-08-08 18:54:44.932 - error: proxmox.0 (26785) 401: wrong User data, could not log in, please try again with correct user and pw
                          Passwort und Nutzer stimmen 100%tig
                          • Feuersturm
                            @ThetaGamma Ich hab wie du gesagt hast nur die beiden Dateien in meinem Dateisystem mit deinen Dateien ausgetauscht.
                            Ich kann einen Reboot und einen Shutdown vom Node pve durchführen.
                            Beim ersten reboot hatte ich den Fall, das proxmox nicht mehr erreichbar war. Hier half nur ein hartes ausschalten des Servers. Die einzelnen VMs wurden im Vorfeld durch den Reboot Prozess heruntergefahren.
                            Bei den nachfolgenden Reboots schien dann alles zu funktionieren. Ich werde nochmal ein paar weitere Reboots durchführen und schauen ob proxmox immer wieder startet.
                            So wie ich das Verhalten bei mir beobachtet habe werden die aktiven VMs beendet, es wird ein Reboot durchgeführt aber es werden im Nachgang keine VMs gestartet. Ist das bei euch auch so?
                              @Feuersturm Du kannst im Proxmox der VM das Attribut "start on boot" setzen:
                              • Feuersturm
                                @ThetaGamma Perfekt. Funktioniert. Bisher gab es bei den ganzen Reboots über ioBroker bei mir keine Probleme (ich verwende Proxmox 6.1-7).
                                  @FredF Sorry, welche Katze?
                                  Was auch immer deinen Fehler auslöst, kann ich Dir leider nicht sagen.
                                  Meine Vorgehensweise: Ich habe in einem jungfräulichen IOBroker-Container einfach die "originale" proxmox installiert und dann auf der Kommandozeile im Verzeichnis mit einem "git clone" das alte überschrieben. da geht alles...
                                    @Feuersturm Vielen Dank für's Testen - der PR wurde übrigens angenommen 😊 Damit dürfte es irgendwann auch offiziell verfügbar sein
                                      CruziX last edited by CruziX
                                      Edit: Hat sich nun doch erledigt. Ein Neustart hat wie immer geholfen
                                      • Feuersturm
                                        @Meistertr Gerade ist mir der Proxmox Adapter um die Ohren geflogen und ich bekomme keine Verbindung mehr hin (https://github.com/iobroker-community-adapters/ioBroker.proxmox/issues/82)
                                        Habe auf meinem Testsystem js-controller 3.2.8 am laufen.
                                        Kennt jemand das Problem?
                                        Feuer-sturm created this issue in iobroker-community-adapters/ioBroker.proxmox
                                        closed Unhandled promise rejection mit anschließendem Unable to authenticate with Proxmox host #82
                                          lonsimbt @Feuersturm last edited by
                                          @feuersturm
                                          Läuft hier bei mir mit js-controller 3.2.8, iobroker Proxmox Adapter 1.1.0 und Proxmox VE 6.3 zzt. fehlerfrei.
                                          Gruß Marco
                                          • Feuersturm
                                            Feuersturm @lonsimbt last edited by Feuersturm
                                            @lonsimbt Lief bei mir heute auch unter js-controller 3.2.8 ohne Probleme bis ich auf die Idee kam das Interval in der Proxmox Instanz zu ändern. Ist bei dir in der Instanz Konfiguration das Feld "Server" gefüllt?
                                            proxmox
                                            75
                                            486
                                            109799
