    4. [Major Update] SourceAnalytix v0.4.7-beta.0 released !
    • 0
      0018 @0018 last edited by
      habe gerade versucht mein Shelly 2.5 einzubinden. Habe dazu die einzelenen Energy-Counter in Wh in SA eingebunden. Im Log erhalte ich folgende Meldung:
      sourceanalytix.0	2020-07-31 09:47:44.819	warn	(4036) Object sourceanalytix.0.shelly__0__SHSW-25#68C63AF9D442#1__Relay0__Energy.2020.costs.weeks.14 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
      sourceanalytix.0	2020-07-31 09:47:44.762	warn	(4036) This object will not be created in future versions. Please report this to the developer.
      sourceanalytix.0	2020-07-31 09:47:44.761	warn	(4036) Object shelly__0__SHSW-25#68C63AF9D442#1__Relay0__Energy.2020.consumed.weeks.14 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
      sourceanalytix.0	2020-07-31 09:47:44.690	warn	(4036) This object will not be created in future versions. Please report this to the developer.
      sourceanalytix.0	2020-07-31 09:47:44.689	warn	(4036) Object sourceanalytix.0.shelly__0__SHSW-25#68C63AF9D442#1__Relay0__Energy.2020.consumed.weeks.14 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "numbe
      sourceanalytix.0	2020-07-31 09:47:44.634	warn	(4036) This object will not be created in future versions. Please report this to the developer.
      sourceanalytix.0	2020-07-31 09:47:44.633	warn	(4036) Object shelly__0__SHSW-25#68C63AF9D442#1__Relay0__Energy.2020.costs.weeks.13 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
      sourceanalytix.0	2020-07-31 09:47:44.576	warn	(4036) This object will not be created in future versions. Please report this to the developer.
      sourceanalytix.0	2020-07-31 09:47:44.575	warn	(4036) Object sourceanalytix.0.shelly__0__SHSW-25#68C63AF9D442#1__Relay0__Energy.2020.costs.weeks.13 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
      sourceanalytix.0	2020-07-31 09:47:44.517	warn	(4036) This object will not be created in future versions. Please report this to the developer.
      sourceanalytix.0	2020-07-31 09:47:44.517	warn	(4036) Object shelly__0__SHSW-25#68C63AF9D442#1__Relay0__Energy.2020.consumed.weeks.13 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
      sourceanalytix.0	2020-07-31 09:47:44.459	warn	(4036) This object will not be created in future versions. Please report this to the developer.
      sourceanalytix.0	2020-07-31 09:47:44.458	warn	(4036) Object sourceanalytix.0.shelly__0__SHSW-25#68C63AF9D442#1__Relay0__Energy.2020.consumed.weeks.13 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "numbe
      sourceanalytix.0	2020-07-31 09:47:44.401	warn	(4036) This object will not be created in future versions. Please report this to the developer.
      sourceanalytix.0	2020-07-31 09:47:44.401	warn	(4036) Object shelly__0__SHSW-25#68C63AF9D442#1__Relay0__Energy.2020.costs.weeks.12 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
      sourceanalytix.0	2020-07-31 09:47:44.344	warn	(4036) This object will not be created in future versions. Please report this to the developer.
      Das ist nur ein kleiner Auszug, bekomme die Meldung zu jedem Datenpunkt. Was hat dieses zu bedeuten?
      Kann man die Statusmeldungen
      sourceanalytix.0	2020-07-31 09:54:00.796	info	(4036) Meter Calculation executed consumed data for shelly.0.SHSW-25#68C63AF9D442#1.Relay1.Energy : {"consumedDay":8.996,"consumedWeek":8.996,"consumedMonth":8.996,"consumedQuarter":8.996,"consumedYea
      sourceanalytix.0	2020-07-31 09:54:00.792	info	(4036) Set calculated value 8.99635 on state : shelly__0__SHSW-25#68C63AF9D442#1__Relay1__Energy.Current_Reading}
      im Log irgendwie ausblenden? Sind mir sonst zu viele Einträge im Log zu SA.
        crunchip Forum Testing Most Active @0018 last edited by crunchip
        @0018 du brauchst Typ "Number" deines DP
        Stell die Instanz auf "warn" (instanzen- expertenmodus-logstufe)
        0 1 Reply Last reply Reply Quote 0
        • 0
          0018 @crunchip last edited by
          @crunchip Die ausgewählten Datenpunkte aus dem Shelly-Adapter haben den type "number".
            "from": "system.adapter.shelly.0",
            "user": "system.user.admin",
            "ts": 1595840820570,
            "common": {
              "name": "Energy",
              "type": "number",
              "role": "value.power",
              "unit": "Wh",
              "def": 0,
              "read": true,
              "write": false,
          so wie ich das aus dem Log entnehme
          erwartet SA string oder object, er bekommt aber eine number. Aber ein Enegieverbrauch ist doch eigentlich immer eine number oder nicht?
            dtp @Matis last edited by
            @Matis sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
            Vielleicht funzt sourceanalytix ja mal wieder, wäre schön, denn die ganzen Funktion wären schon hilfreich.
            Wäre schön. Im Moment ist dieser Adapter leider genau so unbrauchbar, wie der statistics-Adapter.
              @0018 https://github.com/iobroker-community-adapters/ioBroker.sourceanalytix/issues/134
              sigi2345 created this issue in iobroker-community-adapters/ioBroker.sourceanalytix
              closed Warn Meldung nach js-controller Test 3.0.6 #134
              • Atifan
                Atifan last edited by
                Hi, kann man schon sagen wann ca. die Tageswerte wieder implementiert werden (von Mo-So) ?
                • Palm_Maniac
                  Palm_Maniac last edited by Palm_Maniac
                  Die Frage ist, ob sich hier irgendwann am Adapter noch etwas tun wird. Leider gibt es aktuell dazu keine Alternative, außer viele Skripte, deshalb hoffen wir mal auf ein "Lebenszeichen". 😞
                  • JB_Sullivan
                    JB_Sullivan last edited by
                    Bei Facebook meldet sich der Entwickler hin und wieder mal zu Wort - hier aber ist Funkstille
                    Atifan 1 Reply Last reply Reply Quote 0
                    • Atifan
                      Atifan @JB_Sullivan last edited by
                      Gibt es evtl. Alternativen bzw. hat jemand Scripte mit denen man Verbrauchswerte für die letzten 7 Tage erzeugen kann?
                      vauvau07 A 2 Replies Last reply Reply Quote 0
                      • vauvau07
                        vauvau07 @Atifan last edited by
                        @Atifan
                        ich habe ein Blockly für den letzten Tag,Woche Monat,Jahr für diesen Adapter
                         <block type="schedule" id="XHN0@w_-bjdzn)jtY|QV" x="-587" y="-1312">
                           <field name="SCHEDULE">0 * * * *</field>
                             <block type="update" id="*ju7[3DwPQUnp,5}l.yo">
                               <field name="OID">javascript.2.Strom_SourceAnalytix.Strom_Referenz_Verbrauch_laufende_Stunde</field>
                                 <block type="get_value" id="Nhr2dcA^C^7n3{9.4(bq">
                                   <field name="OID">hm-rpc.0.MEQ0705007.1.ENERGY_COUNTER</field>
                                 <block type="controls_if" id="iC)BVwq6:y):Wr)VjrRw">
                                     <block type="logic_compare" id="dRhUfRd96D(MS|NYp`UV">
                                       <field name="OP">LT</field>
                                         <block type="get_value" id="}+x[i]73#(?SN#*jxe9n">
                                           <field name="OID">javascript.2.Strom_SourceAnalytix.Strom_Verbrauch_laufende_Stunde_max</field>
                                         <block type="get_value" id="Ed2.de/FV%kjC[LZ5kJ;">
                                           <field name="OID">javascript.2.Strom_SourceAnalytix.Strom_Verbrauch_laufende_Stunde</field>
                                     <block type="update" id=".0}=uLww61XoxN,J^Be8">
                                         <block type="get_value" id="YvDm9#tAN%Nd}p~jlYWo">
                             <block type="schedule" id="K.-?J%TwOh{wQFTNF@7%">
                               <field name="SCHEDULE">59 23 * * *</field>
                                 <block type="update" id="]7`m!c7*22WNqVfP`}2^">
                                   <field name="OID">javascript.2.Strom_SourceAnalytix.Strom_Verbrauch_gestern</field>
                                     <block type="get_value" id="Q`-Bh0G0-Ocd_J#n0[|4">
                                       <field name="OID">sourceanalytix.0.hm-rpc__0__MEQ0705007__1__ENERGY_COUNTER.consumption.01_current_day</field>
                                     <block type="update" id="7:ugm%E|S.VB7W0U%LZ+">
                                       <field name="OID">javascript.2.Strom_SourceAnalytix.Strom_Kosten_gestern</field>
                                       <field name="DELAY_MS">1000</field>
                                       <field name="UNIT">ms</field>
                                         <block type="get_value" id="f3?*e61b7B#,PMIouXOX">
                                           <field name="OID">sourceanalytix.0.hm-rpc__0__MEQ0705007__1__ENERGY_COUNTER.cost.01_current_day</field>
                                         <block type="update" id="t%WYL.^YKa30[)]Mu:%)">
                                           <field name="OID">javascript.2.Strom_SourceAnalytix.Strom_Leistungsaufnahme_aktuell_max</field>
                                             <block type="math_number" id="xCi^b%qdVcPik*;%,|_)">
                                               <field name="NUM">0</field>
                                             <block type="update" id="%EmGI~@R1Y2/~?RT+?c3">
                                                 <block type="math_number" id="%2PW!=P;j^uud5iq8R+y">
                                 <block type="schedule" id="[Q+S}a_XYRB+Tdk7x%pZ">
                                   <field name="SCHEDULE">0 0 * * 1</field>
                                     <block type="update" id="7pGRB@ylwUn+-KP-Gf;0">
                                       <field name="OID">javascript.2.Strom_SourceAnalytix.Strom_Verbrauch_letzte_Woche</field>
                                         <block type="get_value" id="N#}7T]uAR1av3VKD!N+i">
                                           <field name="OID">sourceanalytix.0.hm-rpc__0__MEQ0705007__1__ENERGY_COUNTER.consumption.02_current_week</field>
                                     <block type="schedule" id="5[yFxQ@FoI:BYk[4IVJ/">
                                       <field name="SCHEDULE">0 0 1 * *</field>
                                         <block type="update" id="}B_a|T@qN`Gsb+%1tCiw">
                                           <field name="OID">javascript.2.Strom_SourceAnalytix.Strom_Verbrauch_letzter_Monat</field>
                                             <block type="get_value" id="8|_CMfXm+O5;u{?dJRNT">
                                               <field name="OID">sourceanalytix.0.hm-rpc__0__MEQ0705007__1__ENERGY_COUNTER.consumption.03_current_month</field>
                                         <block type="on" id="V.-l]O)ki97rSsi{,gtm">
                                             <block type="update" id="3:kmsqschBQX?{7=1@{~">
                                                 <block type="math_arithmetic" id="[%))4rGnos0:[#X~119+">
                                                   <field name="OP">DIVIDE</field>
                                                     <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="HqeOH8D-aiI1J`5GF8xd">
                                                       <field name="NUM">1</field>
                                                     <block type="math_arithmetic" id="x/?]H0Kl`=R6(tb|6lB#">
                                                         <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="_.pu?F1?l`fcHVjby-Uf">
                                                         <block type="get_value" id="*E,@^v_!@2=,y?gP5Ck+">
                                                         <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="?/waTO)fpqk4cTd:a/@m">
                                                         <block type="get_value" id="u8)Ov;3JVS{Y(NV-;5ah">
                                                     <shadow type="math_number" id=";H?YT-xf!A/4dCQ`q7wU">
                                                       <field name="NUM">1000</field>
                                                 <block type="update" id="5N/ds(@#cuSA385N5|rS">
                                                   <field name="OID">javascript.2.Strom_SourceAnalytix.Strom_Zaehlerstand</field>
                                                     <block type="math_arithmetic" id="sX_nxv{!5@Qs@8S4E+h5">
                                                         <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="o2sG+O(14bkyCC/f=gvW">
                                                         <block type="math_arithmetic" id="Y0F,DC%7Xg-O%*TC1r,|">
                                                           <field name="OP">ADD</field>
                                                             <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="PDslwRX~Bq0XJq6{,N-;">
                                                             <block type="get_value" id="vHP,J3d+|4mi:cKktCRl">
                                                               <field name="OID">javascript.2.Strom_SourceAnalytix.Strom_Referenz_Zaehlerstand</field>
                                                             <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="MDv?xMDdL.w`cd8XeC+1">
                                                             <block type="get_value" id="3.`HaM^kBX:Piav`Z==O">
                                                         <shadow type="math_number" id="v6fAR#RiufFa[O9SRdA7">
                                                     <block type="update" id="bq4Y!xqOe:W,?~3qlb6y">
                                                       <field name="OID">javascript.2.Strom_SourceAnalytix.Strom_Verbrauch_seit_letzter_Ablesung</field>
                                                         <block type="math_arithmetic" id="QFh%=rVOTo9NDZ,c.Gk-">
                                                             <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="VI1qk42.U@SE`.q@0z7!">
                                                             <block type="get_value" id="J3Y:;AVpm:*x_d9pqk}0">
                                                               <field name="OID">javascript.2.Strom.Zaehlerst_Strom</field>
                                                             <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="}n)+j%c}Iy1/T=I8U])(">
                                                               <field name="NUM">124278.92</field>
                                                             <block type="get_value" id="kL!Oqh_u6#Ogne63nIlQ">
                                                               <field name="OID">javascript.2.Strom_SourceAnalytix.Strom_Referenz_Verbrauch_seit_letzter_Ablesung</field>
                                                         <block type="update" id="eY3g-.;V+D%KgVUX=c{%">
                                                           <field name="OID">javascript.2.Strom_SourceAnalytix.Strom_Kosten_kWh</field>
                                                             <block type="math_arithmetic" id="w(U5vz2bTuV^U|z#fvKw">
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id=":24_Yu~}-}ogRzgTW)qD">
        <block type="get_value" id="g/`]Ht8I3BZ;lP?p(%HG">
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="4Rvd8Fht%/;1_Of;~Gh:">
        <block type="get_value" id="C(;^m(?G|wIs4ChcW1Kk">
                                                             <block type="update" id="5jT_:Sc0;WGG;^[ZCC/Z">
                                                               <field name="OID">javascript.2.Strom_SourceAnalytix.Strom_Kosten_seit_letzter_Ablesung</field>
        <block type="math_arithmetic" id="el-M![;x{|cQl!a}FW:8">
        <block type="get_value" id="Z[WHiPE:E{+cNGK=c!X4">
        <block type="math_arithmetic" id="joHez~j1/|iJ7?2NeRAt">
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="4Z|)~e3rX,`l*=*KY(]?">
        <block type="get_value" id="Bp7u%LpV1K-p|++}`sZl">
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="3]}?S#~tl=MkCV2yTl?=">
        <block type="get_value" id="gVt[,4BL?wVUjQdJ9Z-q">
        <block type="controls_if" id="Q?MRtB7lLyq%ncUNMC]t">
        <block type="logic_compare" id="?F,VX!%;pPt#*RW.RWv;">
        <block type="get_value" id="lrd?hNTbTq`%0sx.;*ii">
        <block type="get_value" id="Z7Z`NXRr!=aoz%:I;-RZ">
        <field name="OID">hm-rpc.0.MEQ0705007.1.POWER</field>
        <block type="update" id="D)c;gm7[rLdTia*wf=]*">
        <block type="get_value" id="o=k8*t-@d0VOU,0A*oaW">
                                             <block type="create" id="yl=ip~bMA2AAjj%F[PR;">
                                               <field name="NAME">javascript.2.Strom_SourceAnalytix.Strom_Korrektur_Zaehlerstand</field>
                                                 <block type="create" id="B[*y/D?4=VA1%0Zh8E1#">
                                                   <field name="NAME">javascript.2.Strom_SourceAnalytix.Strom_Referenz_Zaehlerstand</field>
                                                     <block type="create" id="FL3)llI85EDlG]~CaYCC">
                                                       <field name="NAME">javascript.2.Strom_SourceAnalytix.Strom_Referenz_Verbrauch_seit_letzter_Ablesung</field>
                                                         <block type="create" id="a^@T|OfVWBmdDua!3KY@">
                                                           <field name="NAME">javascript.2.Strom_SourceAnalytix.Strom_Zaehlerstand</field>
                                                             <block type="create" id="v7}6]~SR+oO~#i:rBPZd">
                                                               <field name="NAME">javascript.2.Strom_SourceAnalytix.Strom_Verbrauch_seit_letzter_Ablesung</field>
        <block type="create" id="Y;{H!iKzq82eU^##*jH|">
        <field name="NAME">javascript.2.Strom_SourceAnalytix.Strom_Kosten_kWh</field>
        <block type="create" id="*D[a*OhsAB7EnqV(ikpi">
        <field name="NAME">javascript.2.Strom_SourceAnalytix.Strom_Kosten_seit_letzter_Ablesung</field>
        <block type="create" id="-hLR]yv{K^vC!rb1o13[">
        <field name="NAME">javascript.2.Strom_SourceAnalytix.Strom_Verbrauch_gestern</field>
        <block type="create" id="Xa=nTviSS`Eb^FcU[vpV">
        <field name="NAME">javascript.2.Strom_SourceAnalytix.Strom_Kosten_gestern</field>
        <block type="create" id="2oy((28j4FRi8Rw))d}{">
        <field name="NAME">javascript.2.Strom_SourceAnalytix.Strom_Verbrauch_letzte_Woche</field>
        <block type="create" id="C8s.jPXrZC|_?V:Bh%hY">
        <field name="NAME">javascript.2.Strom_SourceAnalytix.Strom_Verbrauch_letzter_Monat</field>
        <block type="create" id="=Kdpy}|}+e]hT.DhBRVH">
        <field name="NAME">javascript.2.Strom_SourceAnalytix.Strom_Verbrauch_letztes_Jahr</field>
                                                 <block type="create" id="^z:/aoogc*2oz(]/OpGP">
                                                   <field name="NAME">javascript.2.Strom_SourceAnalytix.Strom_Leistungsaufnahme_aktuell_max</field>
                                                     <block type="create" id="-aZ+@mDz2G)K:|pCr24G">
                                                       <field name="NAME">javascript.2.Strom_SourceAnalytix.Strom_Verbrauch_laufende_Stunde</field>
                                                         <block type="create" id="V=wW=Cu^1:FQj^FRB9},">
                                                           <field name="NAME">javascript.2.Strom_SourceAnalytix.Strom_Verbrauch_laufende_Stunde_max</field>
                                                             <block type="create" id="2rCPSrUD9i^jUGoKSz-2">
                                                               <field name="NAME">javascript.2.Strom_SourceAnalytix.Strom_Referenz_Verbrauch_laufende_Stunde</field>
                        </xml>_text
                        • Palm_Maniac
                          Vielleicht gibt es ja jemanden, der mal über den Code drüber schauen kann, um diesen leidigen NULL-Fehler auszumerzen. Das würde ja schon extrem helfen.
                            Adnim @Atifan last edited by
                            @Atifan sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                            evtl passt das skript hier bei euch auch?
                            https://github.com/hdering/homematic_verbrauchszaehler
                              mbpresents last edited by mbpresents
                              ich habe mir heute erstmals den SourceAnalytix Adapter installiert um Strom-/Kosten vom Zähler (Bezug/Einspeisung) zu analysieren.
                              Verknüpfung mit Zählerwerten (Smartmeter-Adapter) für Bezug und Einspeisung klappte und stehen jetzt unter weeks/months/quarter zur Verfügung. Diese würde ich gerne in eine InfluxDB schreiben und anschließend in Grafana visualisieren.
                              Mir stellen sich zwei Fragen:
                              1. zur Zeit sehe ich diese Werte unter Sourceanalytix.0 im Ordner Jahr 2020.
                                Am Bsp der Monate kann ich jeden einzelnen Monat konfigurieren das dieser in die InfluxDB geschrieben wird.
                                Bei der Konfiguration des Monatswert Januar sehe ich das der Datenpunkt wie folgt heißt: "sourceanalytix.0.smartmeter__0__1-0:1_8_0__255__value.2020.costs.months.01_January"
                                Wie verhält sich das ganze bei einem Jahreswechsel?
                                Wird dann automatisch einen neues Jahr erstellt oder einfach angepasst auf das neue Jahr?
                                Müssen die Monate des neuen Jahres dann wiederholt für das schreiben Datenpunkte in die influxDB neu konfiguriert werden?
                              2. gibt es einen Möglichkeit alle Monate etc auf einmal für das schreiben in eine Datenbank (Bsp. influx) zu konfigurieren? Im Moment erscheint der Aufwand recht hoch für jeden einzelnen Monat (noch aufwendiger wären die Kalenderwochen) zum schreiben in die InfluxDB zu konfigurieren.
                              Vieleicht habe ich auch einfach ein paar Punkte übersehen.
                              Freue mich auf Infos.
                                Andy200877 @mbpresents last edited by
                                @mbpresents
                                Ich würde da über ein kleines Script,
                                den aktuellen Tages / Wochen und Monatsverbrauch nehmen und diesen in einen eigenen Datenpunkt schreiben.
                                z.B. :
                                • täglich um 23:59 Uhr den aktuellen Tagesverbrauch in einen eigenen Datenpunkt schreiben.
                                • jeden Sonntag um 23:59 Uhr den aktuellen Wochenverbrauch in einen eigenen Datenpunkt schreiben.
                                • jeden letzten Tag des Monats um 23:59 Uhr den aktuellen Monatsverbrauch in einen eigenen Datenpunkt schreiben.
                                Diese Datenpunkte dann nach Grafana, SQL, oder sonst wohin aufzeichen.
                                Damit umgehst du das Jahres / Monatsproblem...
                                • Amnesia1211
                                  Amnesia1211 last edited by
                                  @Dutchman
                                  Hier ein Auszug aus dem Log, hoffe es Hilft dir bei der Fehlersuche.
                                  2020-08-14 04:53:25.465 - warn: sourceanalytix.0 (29949) This object will not be created in future versions. Please report this to the developer.
                                  2020-08-14 04:53:25.511 - warn: sourceanalytix.0 (29949) Object sonoff__0__NAS0__ENERGY_Power.2020.consumed.weeks.28 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                  2020-08-14 04:53:25.511 - warn: sourceanalytix.0 (29949) This object will not be created in future versions. Please report this to the developer.
                                  2020-08-14 04:53:25.558 - warn: sourceanalytix.0 (29949) Object sonoff__0__NAS0__ENERGY_Power.2020.meterReadings.weeks.28 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                  2020-08-14 04:53:25.558 - warn: sourceanalytix.0 (29949) This object will not be created in future versions. Please report this to the developer.
                                  2020-08-14 04:53:25.603 - warn: sourceanalytix.0 (29949) Object sonoff__0__NAS0__ENERGY_Power.2020.costs.weeks.28 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                  2020-08-14 04:53:25.604 - warn: sourceanalytix.0 (29949) This object will not be created in future versions. Please report this to the developer.
                                  2020-08-14 04:53:25.650 - warn: sourceanalytix.0 (29949) Object sonoff__0__NAS0__ENERGY_Power.2020.consumed.weeks.29 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                  2020-08-14 04:53:25.650 - warn: sourceanalytix.0 (29949) This object will not be created in future versions. Please report this to the developer.
                                  2020-08-14 04:53:25.696 - warn: sourceanalytix.0 (29949) Object sonoff__0__NAS0__ENERGY_Power.2020.meterReadings.weeks.29 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                  2020-08-14 04:53:25.696 - warn: sourceanalytix.0 (29949) This object will not be created in future versions. Please report this to the developer.
                                  Das ganze ging noch so weiter aber dann wird das hier zu groß denke ich....
                                  Danke schon mal für deine Mühe und Hilfe.
                                    dtp @Amnesia1211 last edited by dtp
                                    @Amnesia1211 Diese Warnmeldungen hatte ich auch zuhauf. War mit ein Grund, weshalb ich den Adapter erst mal wieder deinstalliert habe.
                                      Malz1902 @Andy200877 last edited by
                                      @Andy200877
                                      Habe das als Cron, f täglich 23.59 Sonntags um 23.59 und am 31.12. um 23.59 klappt, aber wie mache ich das für am Ende des Monats?
                                      SourceAnalytix habe mir den Adapter gerade installiert. Habe eine Steckdose per Sonoff Adapter, haben die SourceAnalytix für den Datenpunkt Energy Total aktiviert ist das richtig so? Wo finde ich denn dann die Werte täglich, monatlich, jährlich?
                                      • X
                                        xbow42 @Malz1902 last edited by
                                        @Malz1902 Cron "0 0 1 * *" jeden 1. im Monat 00:00
                                        • Atifan
                                          Atifan @xbow42 last edited by
                                          Falls es jemand brauchen kann.
                                          Habe mir jetzt zwei Blockly Scripte erstellt, mit denen ich den Stromverbrauch und den Wasserverbrauch der letzten 7 Tage logge und mir in Grafana anzeigen lasse.
                                          Brauche also kein Sourceanalytics mehr. Einziger Nachteil ist, meine Anzeige ist <heute, gestern, vorgestern, vor 3 Tagen, vor 4 Tagen, vor 5 Tagen, vor 6 Tagen> statt wie bei Sourceanalytics <Montag, Dienstag, Mittwoch, Donnerstag, Freitag, Samstag, Sonntag>.
                                            <block type="schedule" id="D8b8A[Vu|6HiotAVpgf/" x="-1488" y="188">
                                              <field name="SCHEDULE">{"time":{"exactTime":true,"start":"23:59"},"period":{"days":1}}</field>
                                                <block type="update" id="):pA.YXuccNrThTR!:N,">
                                                  <field name="OID">javascript.0.eigene_Datenpunkte.Wasserverbrauch_00_Zählerstand_Tagesende</field>
                                                    <block type="get_value" id="7G`A!*:dx08%5B96elT]">
                                                      <field name="OID">parser.0.Wasseruhr</field>
                                                    <block type="update" id="6KoxJ{5#BCT=E)KF{Zr8">
                                                      <field name="OID">javascript.0.eigene_Datenpunkte.Wasserverbrauch_07_vor_6_Tagen</field>
                                                        <block type="get_value" id="iBYl1VhiXq6|z?;O(w/|">
                                                          <field name="OID">javascript.0.eigene_Datenpunkte.Wasserverbrauch_06_vor_5_Tagen</field>
                                                        <block type="update" id="*OGNM{DqDcaZu+6AC8Um">
                                                            <block type="get_value" id="5C5(HYu#,S_BSa66[@GQ">
                                                              <field name="OID">javascript.0.eigene_Datenpunkte.Wasserverbrauch_05_vor_4_Tagen</field>
                                                            <block type="update" id="f^A-M[@es2H*}8,-$hK+">
        <block type="get_value" id="t?,5sT(3Y-yBo:[`^~%p">
        <field name="OID">javascript.0.eigene_Datenpunkte.Wasserverbrauch_04_vor_3_Tagen</field>
        <block type="update" id="y;x[:/!)QiA-b.8`]*D=">
        <block type="get_value" id="qG_mF^qIWz!M*wL3Ps?a">
        <field name="OID">javascript.0.eigene_Datenpunkte.Wasserverbrauch_03_vorgestern</field>
        <block type="update" id="H);_jP,CNUlYzpv^T0#X">
        <block type="get_value" id="2wx:gHJ,h=qqxUDn1l=G">
        <field name="OID">javascript.0.eigene_Datenpunkte.Wasserverbrauch_02_gestern</field>
        <block type="update" id=")@ujF(DE4(p9[OK*%:m}">
        <block type="get_value" id="jh[d9[qpG{6~pR@t^t5y">
        <field name="OID">javascript.0.eigene_Datenpunkte.Wasserverbrauch_01_heute_aktuell</field>
        <block type="update" id="7Im|mD4[-Z.D:(U9F(x/">
        <block type="math_number" id="M_;P6hIKRvX_b?QW*DJ2">
                                            <block type="on_ext" id="f+pE0a@G*zU-by@6FUe(" x="-1488" y="638">
                                              <value name="OID0">
                                                <shadow type="field_oid" id="C,Ac-zm;SE@/roO8`H/+">
                                                  <field name="oid">parser.0.Wasseruhr</field>
                                                <block type="update" id="C4J;CKp8]3C[X*9ZIz*v">
                                                    <block type="math_arithmetic" id="WW(1[CJW}{hk}w~P$kd#">
                                                        <shadow type="math_number" id="/tsl(y~_b6?I+crCT^i!">
                                                        <block type="math_arithmetic" id="!d}dAx;/HL+a^8}z/BFL">
                                                            <shadow type="math_number" id="_b8?QPIY?$6*D;mVJFL-">
                                                            <block type="get_value" id="0vp2e}Gb^x1mjg#FiqJy">
                                                            <shadow type="math_number" id="BwEZeMiifVwZBCfG6yq(">
                                                            <block type="get_value" id="+jIc+6OgAA@abWq$L)@V">
                                                        <shadow type="math_number" id="86+t92VTmBO)X4eOtNG:">
                                          Strom Netzbezug der letzten 7 Tage
                                                  <field name="OID">javascript.0.eigene_Datenpunkte.Strombezug_aus_Netz_00_Zählerstand_Tagesende</field>
                                                      <field name="OID">smartmeter.0.1-0:1_8_0__255.value</field>
                                                      <field name="OID">javascript.0.eigene_Datenpunkte.Strombezug_aus_Netz_07_vor_6_Tagen</field>
                                                          <field name="OID">javascript.0.eigene_Datenpunkte.Strombezug_aus_Netz_06_vor_5_Tagen</field>
                                                              <field name="OID">javascript.0.eigene_Datenpunkte.Strombezug_aus_Netz_05_vor_4_Tagen</field>
                                                            <block type="update" id="4+Yu3VFi-g]4or8^ljH%">
        <block type="get_value" id="c$3H$:n61`+:iYM+GG_j">
        <field name="OID">javascript.0.eigene_Datenpunkte.Strombezug_aus_Netz_04_vor_3_Tagen</field>
        <block type="update" id="KNZk!f$11}lld2/U_|VE">
        <block type="get_value" id="i3i^9sbtjB3qr:Nb!T9R">
        <field name="OID">javascript.0.eigene_Datenpunkte.Strombezug_aus_Netz_03_vorgestern</field>
        <block type="update" id="vZNud[nG`/c4G:s#!xLy">
        <block type="get_value" id="hfT!REZ9|yzwNXo@uUR)">
        <field name="OID">javascript.0.eigene_Datenpunkte.Strombezug_aus_Netz_02_gestern</field>
        <block type="update" id="z::D,8y8HP:a];[?B3+F">
        <block type="get_value" id="I}jFb{rET+wP~rcw#[si">
        <field name="OID">javascript.0.eigene_Datenpunkte.Strombezug_aus_Netz_01_heute_aktuell</field>
                                            <block type="on_ext" id="f+pE0a@G*zU-by@6FUe(" x="-1487" y="613">
                                              <value name="OID0">
                                                  <field name="oid">smartmeter.0.1-0:1_8_0__255.value</field>
                                          • Atifan
                                            Atifan @Atifan last edited by
                                            Anbei noch ein Screenshot der Datenpunkte die man vorher manuell anlegen muss.
                                            81.1k
                                            adapter sourceanalytix testen update
                                            103
                                            1082
                                            351393
