    4. Anrufe auf FritzBox per Telegram auf Handy ankündigen
    • I
      invidianer @fastfoot last edited by
      @fastfoot
      Würde das hier funktionieren? Also mal angenommen, man möchte alles von google Gefundene sehen 😉
      <block xmlns="https://developers.google.com/blockly/xml" type="request" id=";NWL78MRH3K]c.U2x2Q%" x="38" y="-62">
        <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation>
        <field name="WITH_STATEMENT">FALSE</field>
        <field name="LOG"></field>
        <value name="URL">
          <shadow type="text">
          <block type="text_join" id="{jkgSs`i`c2dMd3y!+B7">
            <value name="ADD0">
              <block type="text" id="c?q7;tAr,f6+^/RvotyD">
                <field name="TEXT">http://www.google.de/search?q=</field>
            <value name="ADD1">
              <block type="get_value" id="yRZ8NIQ*l4@o-JO~)mA0">
                <field name="OID">tr-064.0.callmonitor.inbound.caller</field>
      • dslraser
        dslraser Forum Testing Most Active @invidianer last edited by dslraser
        @invidianer sagte in Anrufe auf FritzBox per Telegram auf Handy ankündigen:
        schau ins LOG
         <variables>
           <variable id="~(wP^e52kP.%=vPaHI9w">test</variable>
         </variables>
         <block type="variables_set" id="s4B~$]/6VL2A1f9Bp:GD" x="37" y="-12">
           <field name="VAR" id="~(wP^e52kP.%=vPaHI9w">test</field>
             <block type="text_join" id="blwbM;Ac=`arFhAm(KV_">
               <value name="ADD0">
                 <block type="text" id="jj)[F_`(lv?FzgO#m-|G">
               <value name="ADD1">
                 <block type="get_value" id="Tpx1He+WCUv!Nuy3o/5s">
             <block type="request" id=";NWL78MRH3K]c.U2x2Q%">
               <value name="URL">
                 <shadow type="text" id="8`Fv8q.0o+[ZYC8VL*TW">
                 <block type="variables_get" id="*4uO(~zHw0Sdx~7;q{o;">
                 <block type="debug" id="7rY3evKCF=]oen-_KaTy">
                   <value name="TEXT">
                     <shadow type="text" id="4tq(*v?j{=DhLp^0v_l|">
                     <block type="variables_get" id="?cfeb9k/G*s_^xHS7c3Z">
                     <block type="telegram" id="JHXPx7YPTmYL9wy0iUXW">
                       <value name="MESSAGE">
                         <shadow type="text" id="ptF!kPIAD@I]0y*oOXhB">
                         <block type="variables_get" id="Bez^{2@3WTO~D0aa*(K*">
                       <value name="USERNAME">
                         <block type="text" id="_F7g?nE8ZbYH)q6/U)O5">
                           <field name="TEXT">Heiko</field>
          fastfoot @dslraser last edited by
          @dslraser sagte in Anrufe auf FritzBox per Telegram auf Handy ankündigen:
          schau ins LOG
          ja aber schau mal was kommt wenn du dir das Ergebnis anzeigen lässt, das sind Tonnen an Text und man hat keinerlei Tool das zu parsen, denke das wäre selbst mit nem ausgewachsenen Adapter schwierig. Interessant wäre es schon 🙂
          Telefonbuch und der andere Link sind negativ, die wollen beide JS
            schau ins LOG
            ohhh, jetzt verstehe ich, vom Handy mit fertigem Link ist natürlich was anderes, dann ginge auch Das Telefonbuch, einfach die Nummer anhängen. Das Örtliche bietet das nicht, soweit gesehen.
            • dslraser
              dslraser Forum Testing Most Active @fastfoot last edited by dslraser
              @fastfoot
              Das geht schon mal...(aber ich bin nicht eingetragen zum testen)
               <variables>
               </variables>
                     <value name="ADD0">
                         <field name="TEXT">https://www.dasoertliche.de/Themen/</field>
                     <value name="ADD1">
                     <value name="ADD2">
                       <block type="text" id="jge{3yQ%ilq:|aT=ql:q">
                         <field name="TEXT">.html</field>
                     <value name="URL">
                         <value name="TEXT">
              Hier mal so ein Beispiellink der dann generiert und versendet werden sollte.
              Den Link braucht man ja nur dann über Telegram senden, wenn ein Anruf rein kommt, wo die Nummer angezeigt wird, aber die Nummer nicht im FritzBox Telefonbuch eingetragen ist.
              • I
                invidianer @dslraser last edited by
                Hallo nochmal,
                leider funktioniert das mit Eurer Hilfe angepaßte Skript noch nicht ganz: Ruft jemand an und überträgt seine Nummer, landet diese im Datenpunkt in ioBroker, aber Telegram sagt nur "Anruf von". Die Nummer wird also nicht angezeigt. Ich vermute mal, daß die Anfrage, ob die Variable leer ist, nicht funktioniert. Vielleicht muß dort satt dem "" " ist leer" (aus der Rubrik "Text") ein "null" rein (aus der Rubrik "Logik")?
                (Ein Anruf mit unterdrückter Nummer habe ich noch nicht getestet.)
                Danke & Grüße,
                Marcus
                • dslraser
                  @invidianer
                  Wie sieht denn Dein Blockly jetzt aus ? (Sreenshoot)
                  Meins läuft und fragt diese Möglichkeiten ab...
                  • I
                    invidianer @dslraser last edited by invidianer
                    @dslraser
                    Ah, ich Depp!
                    Habe vergessen, daß Foto und den Quelltext hochzuladen! Ist wohl zu warm hier unterm Dach 😉
                      <variables>
                        <variable id="HP^vL38Xt4P{-Gc{4A.,">Anrufernummer</variable>
                        <variable id="n,.bl90t$[=x3+48k@+#">Anrufername</variable>
                        <variable id="Y)MXKWj1KTSU)`wXj{W0">Ausgabe</variable>
                      </variables>
                      <block type="on" id="l1O_GvAVwV6Qa}gi5ol`" x="138" y="88">
                        <field name="OID">tr-064.0.callmonitor.ringing</field>
                          <block type="timeouts_settimeout" id="5*(_(vh~{z|d3b3)*?O-">
                            <field name="DELAY">1000</field>
                            <field name="UNIT">ms</field>
                              <block type="variables_set" id="gDED/!Q}E[2_Bg8snR=o">
                                <field name="VAR" id="HP^vL38Xt4P{-Gc{4A.,">Anrufernummer</field>
                                  <block type="get_value" id="(^k9zO;1+2^I]-]MTurc">
                                  <block type="variables_set" id="?LCU[n[X{M~/k5kRvRkt">
                                    <field name="VAR" id="n,.bl90t$[=x3+48k@+#">Anrufername</field>
                                      <block type="get_value" id="}RD8eCP*@a4[,)6qAZA6">
                                        <field name="OID">tr-064.0.callmonitor.inbound.callerName</field>
                                      <block type="controls_if" id="y:1x;{6Kj#3?D|c9TkcI">
                                        <mutation elseif="1" else="1"></mutation>
                                          <block type="logic_compare" id="k(hKgjA4sw@*rk-,`Drq">
                                            <field name="OP">EQ</field>
                                              <block type="logic_operation" id="l9LqvK!w}}0%Or$7Oc_$">
                                                <field name="OP">AND</field>
                                                  <block type="variables_get" id="HPQgSTtV#c-Q~=[|Ilgb">
                                                  <block type="variables_get" id="R^xZk8QY`cd5,c3@]YVQ">
                                              <block type="text_isEmpty" id="[-$0Ze|AO{y$1eFb-A/c">
                                                  <shadow type="text" id="ij~i5cDaL,=7*^_ufGn=">
                                                    <field name="TEXT"></field>
                                                  <block type="text" id="jE$xatYz=A1azr]0wGy[">
                                          <block type="variables_set" id="8JnRw+rIY)Es`U8DqQL,">
                                            <field name="VAR" id="Y)MXKWj1KTSU)`wXj{W0">Ausgabe</field>
                                              <block type="text" id="7ci8]f%|ElxIt_Nb]7z[">
                                                <field name="TEXT">Anruf von Unbekannt</field>
                                        <value name="IF1">
                                          <block type="logic_compare" id="?!|Cf@p7{g`qo.iN%oXQ">
                                              <block type="variables_get" id="Z9,pbGq#C[)}oFXamGQ^">
                                              <block type="text_isEmpty" id="f#[i~715LjaRtgs)Z`|W">
                                                  <block type="text" id="g-/3+g8|fdnmzim|=48}">
                                        <statement name="DO1">
                                          <block type="variables_set" id="VDu}R!p44D1cv+|M7*@V">
                                              <block type="text_join" id="@Eu/A*Axn~nAgiB87|6-">
                                                <value name="ADD0">
                                                  <block type="text" id="#enXtQW0iz3dO3:GOI=2">
                                                    <field name="TEXT">Anruf von </field>
                                                <value name="ADD1">
                                                  <block type="variables_get" id="49d5orI?C;emx/aq21(7">
                                        <statement name="ELSE">
                                          <block type="variables_set" id="%AV-0-~F||+*V.,V*2Dn">
                                              <block type="text_join" id="B|=,.mrQfROX`g6Y~?,3">
                                                <value name="ADD0">
                                                  <block type="text" id="z`TP{NSa0*ppD=U%Gm5(">
                                                <value name="ADD1">
                                                  <block type="variables_get" id="C+1J!pC,9:_nRfl^k9*B">
                                          <block type="telegram" id="zm9[+AcU}V{{T1a@+dch">
                                              <shadow type="text" id="{/~)c~0#,A.Nu$:MzLI*">
                                              <block type="variables_get" id="Nr1:faX};Rl|x@YiKLMB">
                    dslraser M 3 Replies Last reply Reply Quote 0
                    • dslraser
                      @invidianer
                      probiere mal so:
                       <variables>
                       </variables>
                       <block type="on" id="l1O_GvAVwV6Qa}gi5ol`" x="13" y="13">
                           <block type="timeouts_cleartimeout" id="F?b0Mb=@C$Z(-D`Xd%[r">
                                           <block type="variables_set" id="o~kPf3fyKg_PQ3]2@LvM">
                                               <block type="text" id="EQvBa756Wn8wr_X_z~F0">
                                                   <block type="logic_operation" id="l9LqvK!w}}0%Or$7Oc_$" inline="false">
                                                           <block type="text" id="Cy[Gic3=`]AfZBo98i9I">
                                                       <block type="logic_compare" id="si%vCkVScDKBJ;W!-oP_">
                                                           <block type="text" id="7!M8sEk,n:W:xAC}XHvF">
                                                 <value name="IF1">
                                                       <block type="text_join" id="z;%UBN3J+C1)I|-2MWk?">
                                                         <mutation items="7"></mutation>
                                                         <value name="ADD0">
                                                         <value name="ADD1">
                                                           <block type="text_newline" id="~r9g3%_d/5+zy_qyHA58">
                                                             <field name="Type">\n</field>
                                                         <value name="ADD2">
                                                           <block type="text" id="lt4umKo5y`ojTd(KLu%Y">
                                                             <field name="TEXT"> ruft gerade an . </field>
                                                         <value name="ADD3">
                                                           <block type="text_newline" id="?Z7~0wWBRIGrWqBsv9vu">
                                                         <value name="ADD4">
                                                         <value name="ADD5">
                                                           <block type="variables_get" id=".GQU;PMn)~s@mLP]|@KW">
                                                         <value name="ADD6">
                                                         <mutation items="4"></mutation>
                                                         <value name="ADD0">
                                                         <value name="ADD1">
                                                           <block type="text" id="6M};Ll}V$f-9j`,G(8B{">
                                                             <field name="TEXT"> ruft gerade an.</field>
                                                         <value name="ADD2">
                                                           <block type="text_newline" id="TG]GR2BWRT=}s`%}ph62">
                                                         <value name="ADD3">
                                                           <block type="variables_get" id="4S*l{XdLo6|k]-e0)}FK">
                      • I
                        @dslraser
                        Danke!!
                        Funktioniert!! 👍🏻
                          Jan1 @invidianer last edited by
                          @invidianer
                          Mal ne Frage warum Du das überhaupt mit IOBroker und Telegram machen möchtest, wenn das mit der myfritz App eh schon geht und die eigentlich aufs Handy gehört, allein schon wegen der kinderleichten VPN Geschichte mit der man dann auch gleich den IOBroker von Unterwegs bedienen kann und das ohne sonstigen Schnickschnack 😉
                          • I
                            Hallo nochmal,
                            gibt es eine Möglichkeit, das Ankündigen von Anrufen von Nummern, die in einem bestimmten Telefonbuch hinterlegt sind, zu verhindern?
                            Hintergrund der Frage ist, daß ich in der FritzBox ein Telefonbuch für unerwünschte Nummern angelegt (und auf "nicht durchlassen" gestellt) habe (es sind so viele, daß die "Sperrfunktion" nicht ausreicht), und Anrufe von denen möchte ich natürlich nicht angezeigt bekommen.
                            Viele Grüße,
                            Marcus
                              michael_4358 @invidianer last edited by michael_4358
                              @invidianer
                              ich habe dein script bei mir mit einfliessen lassen! perfekt!
                              EdiT:
                              Ich bin wirklich begeistert! danke für eure mühe!
                              • I
                                invidianer @michael_4358 last edited by
                                @michael_4358 said in Anrufe auf FritzBox per Telegram auf Handy ankündigen:
                                @invidianer
                                EdiT:
                                Das freut mich sehr, jedoch gebührt die Ehre eher den anderen hier, die mit geholfen haben, denn mein Skript hat ja anfangs nicht funktioniert.
                                  @invidianer
                                  andieser stelle vielen dank auch von mir!
                                  • I
                                    @michael_4358
                                    Sehr gerne!
                                    Wie gesagt, die Idee stammt aber doch gar nicht von mir und ohne Hilfe der Spezialisten hier hätte ich es nicht zum Laufen bekommen.
                                    Ich nutze das Skript, weil meine Mama auf Festnetz oft nervige Werbeanrufe bekommt. Wird die Nummer übertragen, sperre ich sie sofort in der FritzBox.
                                    • I
                                      invidianer last edited by invidianer
                                      Hallo Leute,
                                      da mir ja scheinbar keiner sagen kann, wie man (wenn überhaupt) die Anrufankündigungen für ein bestimmtes Telefonbuch (in dem Spamanrufer stehen) ausklammern kann:
                                      Wie kann ich sagen, daß Anrufe nur angekündigt werden, wenn im Anrufnamen nicht das Wort "Spam" vorkommt?
                                      Danke!
                                      EDIT: Habe es endlich hinbekommen. Wenn ich selbst oder einer derer Spammer, die ich in einem extra Telefonbuch in der FritzBox hinterlegt habe, und die alle mit "Arsch", gefolgt von einer Nummer, benamt wurden, bei meiner Mama auf Festnetz anrufen, bekomme ich keine Telegram-Meldung mehr:
                                      blockly
                                      3160
