    4. Test Adapter Shelly v3.1.x
    • harrym
      harrym @K_o_bold last edited by
      @K_o_bold sagte in Test Adapter Shelly v3.1.x:
      Im CoAP Modus bin ich automatisch, wenn mqtt deaktiviert wird, oder?
      was ich mitbekommen habe, coap ist jetzt immer aktiv ..... ohne Gewährleistung g
      • Slowman
        Slowman last edited by
        Seit, wann der Fehler ist, weiß ich nicht. Bekomme immer diese Fehlermeldung:
        shelly.0	2020-08-12 17:49:31.218	error	(28717) Error in function httpIoBrokerState for state SHSW-PM#00598C#2.Relay0.Energy and request{"url":"http://192.168.2.109/settings","timeout":5000} for 192.168.2.109 (shelly1pm / shelly1pm-00598C /
        shelly.0	2020-08-12 17:49:31.205	error	(28717) Error in function httpIoBrokerState for state SHSW-PM#E64888#2.Relay0.Energy and request{"url":"http://192.168.2.108/settings","timeout":5000} for 192.168.2.108 (shelly1pm / shelly1pm-E64888 /
        shelly.0	2020-08-12 17:49:31.040	info	(28717) Shelly device 192.168.2.109 (shelly1pm / shelly1pm-00598C / SHSW-PM#00598C#2) with CoAP connected!
        shelly.0	2020-08-12 17:49:31.029	info	(28717) Shelly device 192.168.2.108 (shelly1pm / shelly1pm-E64888 / SHSW-PM#E64888#2) with CoAP connected!
        shelly.0	2020-08-12 17:49:30.960	info	(28717) Shelly device 192.168.2.104 (shelly1 / shelly1-BA07C9 / SHSW-1#BA07C9#2) with CoAP connected!
        shelly.0	2020-08-12 17:49:30.933	error	(28717) Error in function httpIoBrokerState for state SHSW-PM#E6491D#2.Relay0.Energy and request{"url":"http://192.168.2.105/settings","timeout":5000} for 192.168.2.105 (shelly1pm / shelly1pm-E6491D /
        shelly.0	2020-08-12 17:49:30.801	error	(28717) Error in function httpIoBrokerState for state SHPLG-S#F8C02D#2.Relay0.Energy and request{"url":"http://192.168.2.111/settings","timeout":5000} for 192.168.2.111 (shellyplug-s / shellyplug-s-F8
        shelly.0	2020-08-12 17:49:30.755	info	(28717) Shelly device 192.168.2.105 (shelly1pm / shelly1pm-E6491D / SHSW-PM#E6491D#2) with CoAP connected!
        shelly.0	2020-08-12 17:49:30.740	error	(28717) Error in function httpIoBrokerState for state SHPLG-S#F8C1C4#2.Relay0.Energy and request{"url":"http://192.168.2.110/settings","timeout":5000} for 192.168.2.110 (shellyplug-s / shellyplug-s-F8
        shelly.0	2020-08-12 17:49:30.668	info	(28717) Shelly device 192.168.2.111 (shellyplug-s / shellyplug-s-F8C02D / SHPLG-S#F8C02D#2) with CoAP connected!
        shelly.0	2020-08-12 17:49:30.600	info	(28717) Shelly device 192.168.2.110 (shellyplug-s / shellyplug-s-F8C1C4 / SHPLG-S#F8C1C4#2) with CoAP connected!
        shelly.0	2020-08-12 17:49:28.260	info	(28717) Shelly device 192.168.2.106 (shelly1 / shelly1-2271D5 / SHSW-1#2271D5#2) with CoAP connected!
        shelly.0	2020-08-12 17:49:25.542	info	(28717) Shelly device 192.168.2.103 (shelly1 / shelly1-B9F6D8 / SHSW-1#B9F6D8#2) with CoAP connected!
        shelly.0	2020-08-12 17:49:24.608	info	(28717) Shelly device 192.168.2.102 (shelly1 / shelly1-B9FD25 / SHSW-1#B9FD25#2) with CoAP connected!
        shelly.0	2020-08-12 17:49:23.093	info	(28717) Shelly device 192.168.2.101 (shelly1 / shelly1-B9F815 / SHSW-1#B9F815#2) with CoAP connected!
        shelly.0	2020-08-12 17:49:18.929	info	(28717) Listening for Shelly packets in the network
        shelly.0	2020-08-12 17:49:18.895	info	(28717) Starting Shelly adapter in CoAP modus.
        shelly.0	2020-08-12 17:49:18.871	info	(28717) Polltime of the shelly devices: 10 sec.
        shelly.0	2020-08-12 17:49:18.870	info	(28717) Starting Adapter shelly.0 in version 3.3.4
        shelly.0	2020-08-12 17:49:18.851	info	(28717) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.shelly, node: v12.18.2, js-controller: 3.1.6
        Neustarten des Adapter bzw. auf Version 3.32 brachte kein Erfolg. Shellys sind alle mit der aktuellen Firmware v1.8.0
        Danke für einen Tipp
        harrym Stuebi 2 Replies Last reply Reply Quote 0
        • harrym
          harrym @Slowman last edited by
          @Slowman na dann gugg mal hier ==> https://forum.iobroker.net/post/472738
          • Stuebi
            Stuebi @Slowman last edited by
            @Slowman ,
            Kurze Ergänzung, ab Firmware 1.8.0 ändert Shelly massiv etwas an ihrer CoAP Implementierung. Der Shelly Adapter 3.x.y wird im CoAP Modus und Shelly Firmware 1.8.0 oder größer nicht mehr funktionieren.
            Aus diesem Grund werden @harrym und ich in der Version 4.0.0 des Shelly Adapters die neue CoAP Implementierung umsetzen.
            Mit der Shelly Adapter Version 4.0.0 oder höher, wird kein Shelly Gerät mit einer Firmware kleiner als 1.8.0 mehr funktionieren
            Slowman 1 Reply Last reply Reply Quote 1
            • Slowman
              Slowman @Stuebi last edited by
              @Stuebi
              Vielen Dank für die Info. Mist, dann werde ich mal das automatische Update raus nehmen.
                MiB last edited by
                Moin,
                wenn der Adapter dann nur noch FW ab 1.8 unterstüzt, wie kann ich dann Shellys mit FW < 1.8 schalten und walten? Der Shelly 4Pro ist glaube noch auf 1.6.5 oder so, bei dem kommt wohl keine 1.8. Macht da noch jemand einen Ersatzadapter für die alten Shelly? Schade das ich das nicht kann. Wie geht ihr dann mit den anderen Shelly um?
                Viele Grüße
                Micha
                Stuebi 1 Reply Last reply Reply Quote 0
                • Stuebi
                  Stuebi @MiB last edited by
                  @MiB , der Shelly 4Pro ist der einzige Shelly der auch mit der Firmware < 1.8.x mit dem Shelly Adapter 4.0.0 funktioniert. Shelly plant momentan nicht die Firmware hier anzupassen. Also Du kannst den Shelly Adapter 4.0.0 mit dem 4Pro also nutzen.
                    MiB @Stuebi last edited by
                    @Stuebi
                    das ist ja cool,perfekt. wüsste jetzt echt nicht wie ich den hätte ersetzen können. Dann steht ja der Version 4 nichts im Weg, ausser der Dimmer, der hat noch die Vers. 1.7 aber ich hoffe da kommt noch ein Update.
                    da_Woody K Stuebi 3 Replies Last reply Reply Quote 0
                    • da_Woody
                      da_Woody @MiB last edited by
                      @MiB said in Test Adapter Shelly v3.1.x:
                      dimmer 1.7??? es gibt für DM1 und DM2 1.8.0!
                        klassisch Most Active @MiB last edited by
                        @MiB Dort sieht man das schön, was es gibt https://www.shelly-support.eu/index.php?shelly-firmware-archive/
                        • Stuebi
                          @MiB , Dimmer 1 oder Dimmer 2?
                            klassisch Most Active last edited by klassisch
                            Ich habe beim FW-Update bei meinen Shelly
                            • Internet in der Fritzbox freigeschaltet
                            • Auf der Website des Shelly einen reset ausgelöst
                            • FW- Update aufgerufen
                            • Falls die 1.8. nicht gleich angezeigt wurde auf der angeteigten FW-Nummer rumgeklickt. Dann hat er 1.8 gezeigt. Edit: Mußte auch mal von 1.6 auf 1.7 bevor es dann auf 1.8 ging
                            • Update
                            • Internet wieder sperren
                            • da_Woody
                              da_Woody @Stuebi last edited by
                              @Stuebi
                              egal.
                              • Stuebi
                                Stuebi @klassisch last edited by
                                @klassisch , cooler Tipp!
                                • Stuebi
                                  Stuebi @da_Woody last edited by
                                  @da_Woody , welche Firmware hat denn der Shelly Dimmer 1 und Shelly Dimmer 2 bei Dir?
                                  • da_Woody
                                    @Stuebi
                                    ich hab nur DM1 und der hat 1.8.0
                                    • Stuebi
                                      @da_Woody ja, es gibt Version 1.8 für den Dimmer 1 und Dimmer 2
                                      • da_Woody
                                        @Stuebi
                                        hab ich was anderes geschrieben? 😉
                                        • Stuebi
                                          @da_Woody und funktioniert dieser mit dem Shelly Adapter 4.0.0 nicht?
                                            MiB last edited by
                                            ich hab auch den Dimmer 1 und der hat FW 1.7 drauf und sagt er wäre aktuell. muss ich mal schauen wie ich das erzwinge.
                                            Danke für die Tipps
                                            Stuebi K 2 Replies Last reply Reply Quote 1
                                            adapter shelly
                                            36
                                            282
                                            44689
