    4. Test Adapter mihome-vacuum v2.0.x
      dirkhe Developer @Rushmed last edited by
      @Rushmed stell mal das log auf debug
        Rushmed Most Active @dirkhe last edited by
        @dirkhe
        mihome-vacuum.0	2020-08-14 21:45:34.950	info	(3510) Terminated (NO_ERROR): Without reason
        mihome-vacuum.0	2020-08-14 21:45:34.946	info	(3510) terminating
        mihome-vacuum.0	2020-08-14 21:45:34.918	error	(3510) TypeError: Cannot read property 'val' of null at /opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/roomManager.js:144:51 at /opt/iobroker/node_modules/iobroker.js-controller/lib/ada
        mihome-vacuum.0	2020-08-14 21:45:34.911	error	(3510) uncaught exception: Cannot read property 'val' of null
        mihome-vacuum.0	2020-08-14 21:45:34.903	debug	(3510) stateChange mihome-vacuum.0.rooms.275001013621.mapIndex.roomClean {"val":true,"ack":false,"ts":1597434334896,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597343114831}
        mihome-vacuum.0	2020-08-14 21:45:29.580	debug	(3510) Receive <<< {"result":[{"msg_ver":2,"msg_seq":3558,"state":8,"battery":100,"clean_time":10,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
        mihome-vacuum.0	2020-08-14 21:45:29.534	debug	(3510) sendMsg[1] >>> {"id":37,"method":"get_status"}
        mihome-vacuum.0	2020-08-14 21:45:18.416	debug	(3510) Receive <<< {"result":["ok"],"id":36}
        mihome-vacuum.0	2020-08-14 21:45:18.377	debug	(3510) sendMsg[1] >>> {"id":36,"method":"find_me"}
        mihome-vacuum.0	2020-08-14 21:45:18.376	debug	(3510) stateChange mihome-vacuum.0.control.find {"val":true,"ack":false,"ts":1597434318372,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597265268021}
        mihome-vacuum.0	2020-08-14 21:45:09.609	debug	(3510) Receive <<< {"result":[{"msg_ver":2,"msg_seq":3557,"state":8,"battery":100,"clean_time":10,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
        mihome-vacuum.0	2020-08-14 21:45:09.532	debug	(3510) sendMsg[1] >>> {"id":35,"method":"get_status"}
        mihome-vacuum.0	2020-08-14 21:44:51.693	debug	(3510) Mappointer_updated
        mihome-vacuum.0	2020-08-14 21:44:51.691	debug	(3510) Receive <<< {"result":["roboroommap%2F321636546%2F1"],"id":34}
        mihome-vacuum.0	2020-08-14 21:44:51.654	debug	(3510) sendMsg[1] >>> {"id":34,"method":"get_map_v1"}
        mihome-vacuum.0	2020-08-14 21:44:50.253	debug	(3510) Receive <<< {"result":[10689,143015000,22,[1597423082,1597414047,1597411995,1597344916,1597332841,1597331343,1597326675,1597322633,1597321619,1597321488,1597321049,1597320922,1597320739,159731
        mihome-vacuum.0	2020-08-14 21:44:50.154	debug	(3510) sendMsg[1] >>> {"id":33,"method":"get_clean_summary"}
        mihome-vacuum.0	2020-08-14 21:44:49.661	debug	(3510) Receive <<< {"result":[{"main_brush_work_time":10689,"side_brush_work_time":10689,"filter_work_time":10689,"filter_element_work_time":7543,"sensor_dirty_time":10689}],"id":32}
        mihome-vacuum.0	2020-08-14 21:44:49.652	debug	(3510) sendMsg[1] >>> {"id":32,"method":"get_consumable"}
        mihome-vacuum.0	2020-08-14 21:44:49.648	info	(3510) create states for water box filter
        mihome-vacuum.0	2020-08-14 21:44:49.646	info	(3510) create states for water box
        mihome-vacuum.0	2020-08-14 21:44:49.643	debug	(3510) Receive <<< {"result":[{"msg_ver":2,"msg_seq":3556,"state":8,"battery":100,"clean_time":10,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"la
        mihome-vacuum.0	2020-08-14 21:44:49.528	debug	(3510) sendMsg[1] >>> {"id":31,"method":"get_status"}
        mihome-vacuum.0	2020-08-14 21:44:34.572	debug	(3510) CLEAN_LOGGING[{"Datum":"14.8","Start":"18:38","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"14.8","Start":"16:07","Saugzeit":"22 min","Fläche":"9.36 m²","Error":0,"Ende"
        mihome-vacuum.0	2020-08-14 21:44:34.378	debug	(3510) Receive <<< {"result":[[1597265144,1597265146,2,0,0,0,2,1,43]],"id":30}
        mihome-vacuum.0	2020-08-14 21:44:34.370	debug	(3510) sendMsg[1] >>> {"id":30,"method":"get_clean_record","params":[1597265144]}
        mihome-vacuum.0	2020-08-14 21:44:34.174	debug	(3510) Receive <<< {"result":[[1597266329,1597266345,16,0,0,0,2,1,60]],"id":29}
        mihome-vacuum.0	2020-08-14 21:44:34.169	debug	(3510) sendMsg[1] >>> {"id":29,"method":"get_clean_record","params":[1597266329]}
        mihome-vacuum.0	2020-08-14 21:44:33.976	debug	(3510) Receive <<< {"result":[[1597266401,1597266403,2,0,0,0,2,1,43]],"id":28}
        mihome-vacuum.0	2020-08-14 21:44:33.968	debug	(3510) sendMsg[1] >>> {"id":28,"method":"get_clean_record","params":[1597266401]}
        mihome-vacuum.0	2020-08-14 21:44:33.774	debug	(3510) Receive <<< {"result":[[1597266433,1597266614,181,4265000,0,0,2,1,60]],"id":27}
        mihome-vacuum.0	2020-08-14 21:44:33.766	debug	(3510) sendMsg[1] >>> {"id":27,"method":"get_clean_record","params":[1597266433]}
        mihome-vacuum.0	2020-08-14 21:44:33.570	debug	(3510) Receive <<< {"result":[[1597268211,1597268217,6,0,0,0,2,1,60]],"id":26}
        mihome-vacuum.0	2020-08-14 21:44:33.565	debug	(3510) sendMsg[1] >>> {"id":26,"method":"get_clean_record","params":[1597268211]}
        mihome-vacuum.0	2020-08-14 21:44:33.371	debug	(3510) Receive <<< {"result":[[1597294395,1597296293,1898,32012500,0,1,5,1,52]],"id":25}
        mihome-vacuum.0	2020-08-14 21:44:33.363	debug	(3510) sendMsg[1] >>> {"id":25,"method":"get_clean_record","params":[1597294395]}
        mihome-vacuum.0	2020-08-14 21:44:33.188	debug	(3510) Receive <<< {"result":[[1597319289,1597319912,605,7660000,0,1,5,1,52]],"id":24}
        mihome-vacuum.0	2020-08-14 21:44:33.161	debug	(3510) sendMsg[1] >>> {"id":24,"method":"get_clean_record","params":[1597319289]}
        mihome-vacuum.0	2020-08-14 21:44:32.968	debug	(3510) Receive <<< {"result":[[1597320739,1597320899,15,220000,0,0,1,1,43]],"id":23}
        mihome-vacuum.0	2020-08-14 21:44:32.959	debug	(3510) sendMsg[1] >>> {"id":23,"method":"get_clean_record","params":[1597320739]}
        mihome-vacuum.0	2020-08-14 21:44:32.766	debug	(3510) Receive <<< {"result":[[1597320922,1597320988,23,0,0,0,2,2,61]],"id":22}
        mihome-vacuum.0	2020-08-14 21:44:32.757	debug	(3510) sendMsg[1] >>> {"id":22,"method":"get_clean_record","params":[1597320922]}
        mihome-vacuum.0	2020-08-14 21:44:32.563	debug	(3510) Receive <<< {"result":[[1597321049,1597321413,346,3345000,0,1,2,1,52]],"id":21}
        mihome-vacuum.0	2020-08-14 21:44:32.554	debug	(3510) sendMsg[1] >>> {"id":21,"method":"get_clean_record","params":[1597321049]}
        mihome-vacuum.0	2020-08-14 21:44:32.360	debug	(3510) Receive <<< {"result":[[1597321488,1597321547,59,1775000,0,0,1,1,43]],"id":20}
        mihome-vacuum.0	2020-08-14 21:44:32.353	debug	(3510) sendMsg[1] >>> {"id":20,"method":"get_clean_record","params":[1597321488]}
        mihome-vacuum.0	2020-08-14 21:44:32.156	debug	(3510) Receive <<< {"result":[[1597321619,1597322479,844,7545000,0,1,2,1,52]],"id":19}
        mihome-vacuum.0	2020-08-14 21:44:32.151	debug	(3510) sendMsg[1] >>> {"id":19,"method":"get_clean_record","params":[1597321619]}
        mihome-vacuum.0	2020-08-14 21:44:32.110	warn	(3510) HTTP error when getting token cookie
        mihome-vacuum.0	2020-08-14 21:44:32.109	error	(3510) HTTP error when getting token cookie{}
        mihome-vacuum.0	2020-08-14 21:44:31.956	debug	(3510) Receive <<< {"result":[[1597322633,1597325189,2556,33375000,0,1,2,1,52]],"id":18}
        mihome-vacuum.0	2020-08-14 21:44:31.950	debug	(3510) Mappointer_updated
        mihome-vacuum.0	2020-08-14 21:44:31.949	debug	(3510) Receive <<< {"result":["roboroommap%2F321636546%2F0"],"id":17}
        mihome-vacuum.0	2020-08-14 21:44:31.948	debug	(3510) sendMsg[1] >>> {"id":18,"method":"get_clean_record","params":[1597322633]}
        mihome-vacuum.0	2020-08-14 21:44:31.939	debug	(3510) 1. Mappointer_nomap___retry
        mihome-vacuum.0	2020-08-14 21:44:31.938	debug	(3510) sendMsg[1] >>> {"id":17,"method":"get_map_v1"}
        mihome-vacuum.0	2020-08-14 21:44:31.754	debug	(3510) Receive <<< {"result":[[1597326675,1597328878,2203,31472500,0,1,1,1,52]],"id":16}
        mihome-vacuum.0	2020-08-14 21:44:31.745	debug	(3510) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1597326675]}
        mihome-vacuum.0	2020-08-14 21:44:31.550	debug	(3510) Receive <<< {"result":[[1597331343,1597331356,13,0,0,0,5,1,60]],"id":15}
        mihome-vacuum.0	2020-08-14 21:44:31.543	debug	(3510) sendMsg[1] >>> {"id":15,"method":"get_clean_record","params":[1597331343]}
        mihome-vacuum.0	2020-08-14 21:44:31.435	debug	(3510) Receive <<< {"result":["retry"],"id":14}
        mihome-vacuum.0	2020-08-14 21:44:31.427	debug	(3510) 0. Mappointer_nomap___retry
        mihome-vacuum.0	2020-08-14 21:44:31.426	debug	(3510) sendMsg[1] >>> {"id":14,"method":"get_map_v1"}
        mihome-vacuum.0	2020-08-14 21:44:31.350	debug	(3510) Receive <<< {"result":[[1597332841,1597332874,33,482500,0,0,5,1,60]],"id":13}
        mihome-vacuum.0	2020-08-14 21:44:31.341	debug	(3510) sendMsg[1] >>> {"id":13,"method":"get_clean_record","params":[1597332841]}
        mihome-vacuum.0	2020-08-14 21:44:31.145	debug	(3510) Receive <<< {"result":[[1597344916,1597344932,16,0,0,0,5,1,60]],"id":12}
        mihome-vacuum.0	2020-08-14 21:44:31.140	debug	(3510) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1597344916]}
        mihome-vacuum.0	2020-08-14 21:44:30.946	debug	(3510) Receive <<< {"result":[[1597411995,1597412226,231,5247500,0,1,2,3,56]],"id":11}
        mihome-vacuum.0	2020-08-14 21:44:30.939	debug	(3510) sendMsg[1] >>> {"id":11,"method":"get_clean_record","params":[1597411995]}
        mihome-vacuum.0	2020-08-14 21:44:30.924	debug	(3510) Receive <<< {"result":["retry"],"id":10}
        mihome-vacuum.0	2020-08-14 21:44:30.916	debug	(3510) sendMsg[1] >>> {"id":10,"method":"get_map_v1"}
        mihome-vacuum.0	2020-08-14 21:44:30.746	debug	(3510) Receive <<< {"result":[[1597414047,1597415374,1327,9362500,0,1,2,3,56]],"id":9}
        mihome-vacuum.0	2020-08-14 21:44:30.738	debug	(3510) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1597414047]}
        mihome-vacuum.0	2020-08-14 21:44:30.732	debug	(3510) Receive <<< {"result":[[16,"275001013621"],[17,"275001013648"],[18,"275001013628"]],"id":8}
        mihome-vacuum.0	2020-08-14 21:44:30.730	info	(3510) create state for carpet_mode
        mihome-vacuum.0	2020-08-14 21:44:30.729	debug	(3510) Receive <<< {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":7}
        mihome-vacuum.0	2020-08-14 21:44:30.716	debug	(3510) sendMsg[1] >>> {"id":8,"method":"get_room_mapping"}
        mihome-vacuum.0	2020-08-14 21:44:30.715	debug	(3510) sendMsg[1] >>> {"id":7,"method":"get_carpet_mode"}
        mihome-vacuum.0	2020-08-14 21:44:30.552	debug	(3510) Receive <<< {"result":[[1597423082,1597423092,10,0,0,0,2,2,61]],"id":6}
        mihome-vacuum.0	2020-08-14 21:44:30.536	debug	(3510) sendMsg[1] >>> {"id":6,"method":"get_clean_record","params":[1597423082]}
        mihome-vacuum.0	2020-08-14 21:44:30.528	debug	(3510) Receive <<< {"result":[10689,143015000,22,[1597423082,1597414047,1597411995,1597344916,1597332841,1597331343,1597326675,1597322633,1597321619,1597321488,1597321049,1597320922,1597320739,159731
        mihome-vacuum.0	2020-08-14 21:44:30.516	debug	(3510) sendMsg[1] >>> {"id":5,"method":"get_clean_summary"}
        mihome-vacuum.0	2020-08-14 21:44:30.325	debug	(3510) Receive <<< {"result":[{"main_brush_work_time":10689,"side_brush_work_time":10689,"filter_work_time":10689,"filter_element_work_time":7543,"sensor_dirty_time":10689}],"id":4}
        mihome-vacuum.0	2020-08-14 21:44:30.316	debug	(3510) sendMsg[1] >>> {"id":4,"method":"get_consumable"}
        mihome-vacuum.0	2020-08-14 21:44:30.123	debug	(3510) Receive <<< {"result":[90],"id":3}
        mihome-vacuum.0	2020-08-14 21:44:30.115	debug	(3510) sendMsg[1] >>> {"id":3,"method":"get_sound_volume"}
        mihome-vacuum.0	2020-08-14 21:44:30.051	info	(3510) set nächster Timer: Nicht verfügbar
        mihome-vacuum.0	2020-08-14 21:44:29.922	debug	(3510) Receive <<< {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-47},"netif":{"localI
        mihome-vacuum.0	2020-08-14 21:44:29.918	debug	(3510) Next WiFi check: 14.08 21:45
        mihome-vacuum.0	2020-08-14 21:44:29.916	debug	(3510) sendMsg[1] >>> {"id":2,"method":"miIO.info"}
        mihome-vacuum.0	2020-08-14 21:44:29.714	info	(3510) Connected
        mihome-vacuum.0	2020-08-14 21:44:29.710	debug	(3510) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        mihome-vacuum.0	2020-08-14 21:44:29.707	debug	(3510) Receive <<< {"result":[{"msg_ver":2,"msg_seq":3555,"state":8,"battery":100,"clean_time":10,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"la
        mihome-vacuum.0	2020-08-14 21:44:29.698	debug	(3510) sendMsg[1] >>> {"id":1,"method":"get_status"}
        mihome-vacuum.0	2020-08-14 21:44:29.674	debug	(3510) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        mihome-vacuum.0	2020-08-14 21:44:29.673	info	(3510) connecting, this can take up to 10 minutes ...
        mihome-vacuum.0	2020-08-14 21:44:29.671	debug	(3510) Receive <<< Helo <<< 2131002000000000132bc8c25f36e99dffffffffffffffffffffffffffffffff
        mihome-vacuum.0	2020-08-14 21:44:29.605	info	(3510) New generation or new fw(3.5.8,4436) detected, create new states goto and zoneclean
        mihome-vacuum.0	2020-08-14 21:44:29.597	debug	(3510) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
        mihome-vacuum.0	2020-08-14 21:44:29.533	debug	(3510) server started on 0.0.0.0:53421
        mihome-vacuum.0	2020-08-14 21:44:29.517	info	(3510) Create state clean_home for controlling by cloud adapter
        mihome-vacuum.0	2020-08-14 21:44:29.515	info	(3510) Expert mode disabled, states deleted
        mihome-vacuum.0	2020-08-14 21:44:29.504	debug	(3510) Xiaomi Cloud: Logging in
        mihome-vacuum.0	2020-08-14 21:44:29.501	debug	(3510) load Map creator... true
        mihome-vacuum.0	2020-08-14 21:44:29.412	info	(3510) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.18.3, js-controller: 3.1.6
        mihome-vacuum.0	2020-08-14 21:44:27.908	debug	(3510) statesDB connected
        mihome-vacuum.0	2020-08-14 21:44:27.907	debug	(3510) States connected to redis: 127.0.0.1:9000
        mihome-vacuum.0	2020-08-14 21:44:27.894	debug	(3510) States create System PubSub Client
        mihome-vacuum.0	2020-08-14 21:44:27.891	debug	(3510) States create User PubSub Client
        mihome-vacuum.0	2020-08-14 21:44:27.881	debug	(3510) Redis States: Use Redis connection: 127.0.0.1:9000
        mihome-vacuum.0	2020-08-14 21:44:27.879	debug	(3510) objectDB connected
        mihome-vacuum.0	2020-08-14 21:44:27.872	debug	(3510) Objects connected to redis: 127.0.0.1:9001
        mihome-vacuum.0	2020-08-14 21:44:27.850	debug	(3510) Objects client initialize lua scripts
        mihome-vacuum.0	2020-08-14 21:44:27.849	debug	(3510) Objects create User PubSub Client
        mihome-vacuum.0	2020-08-14 21:44:27.847	debug	(3510) Objects create System PubSub Client
        mihome-vacuum.0	2020-08-14 21:44:27.844	debug	(3510) Objects client ready ... initialize now
        mihome-vacuum.0	2020-08-14 21:44:27.801	debug	(3510) Redis Objects: Use Redis connection: 127.0.0.1:9001
        mihome-vacuum.0	2020-08-14 21:44:23.511	info	(7879) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        mihome-vacuum.0	2020-08-14 21:44:23.509	info	(7879) terminating
        mihome-vacuum.0	2020-08-14 21:44:23.506	info	(7879) Got terminate signal TERMINATE_YOURSELF
        Habe kurz noch die "find" Funktion getestet, die funktioniert.
          @Rushmed dir fehlt der dp roomFanPower. Fehlt der in allen Räumen? Wenn nein, dann lösch mal den Raum und lass ihn neu anlegen. Wenn der überall fehlt, dann ist das ein Bug, dann muss ich mal schauen, das ich das abfange
            Rushmed Most Active @dirkhe last edited by Rushmed
            @dirkhe roomFanPower existiert in den Raümen, siehe Screenshot. Ich hab ihn auch scho explizit gesetzt vor dem Anfordern der Reinigung.
            Ich werd sie trotzdem mal löschen.
            ERROR: HTTP Error when getting cookie token beim Speichern der Instanzeinstellungen.
            Aktuell bleibt der Adapter gelb, ich versuchs weiter.
            Edit:
            Nach dem Löchen der Ordner hat sich die Struktur geändert un ist nun:
            Jetzt funktionierts.
            Edit2:
            Ich habe nochmal über die Xiaomi Home app die Karte (Etage) hin und zurück gewechselt. Dabei werden die Datenpunkte umsortiert.
            Dann funktioniert es nichtmehr.
            Erneutes Löschen der Ordner und Neuladen der Karte stellt die korrekte Struktur wieder her und es funktioniert.
            Ist über den Adapter ein wechsel der gespeicherten Karten möglich?
            Danke schonmal.
              @Rushmed ich habe bei mir kein raumwechsel gemacht, daher kann ich das aktuell nicht nachvollziehen. Kannst du das debug log nochmal schicken, wenn du die Karte wechselt? Ich vermute mal, das er auf einen Fehler läuft, wenn er die Räume anlegen will, den ich abfangen muss
                @dirkhe Klaro!
                Karte in der Xiaomi App gewechselt und Räume über DP neu geladen.
                mihome-vacuum.0	2020-08-14 23:55:37.936	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4261,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
                mihome-vacuum.0	2020-08-14 23:55:37.886	debug	(8589) sendMsg[1] >>> {"id":53,"method":"get_status"}
                mihome-vacuum.0	2020-08-14 23:55:17.966	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4260,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
                mihome-vacuum.0	2020-08-14 23:55:17.885	debug	(8589) sendMsg[1] >>> {"id":52,"method":"get_status"}
                mihome-vacuum.0	2020-08-14 23:54:58.004	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4259,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
                mihome-vacuum.0	2020-08-14 23:54:58.002	debug	(8589) Receive <<< {"partner_id":"","id":51,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-44},"netif":{"localI
                mihome-vacuum.0	2020-08-14 23:54:57.883	debug	(8589) Next WiFi check: 14.08 23:55
                mihome-vacuum.0	2020-08-14 23:54:57.883	debug	(8589) sendMsg[1] >>> {"id":51,"method":"miIO.info"}
                mihome-vacuum.0	2020-08-14 23:54:57.882	debug	(8589) sendMsg[1] >>> {"id":50,"method":"get_status"}
                mihome-vacuum.0	2020-08-14 23:54:37.927	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4258,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
                mihome-vacuum.0	2020-08-14 23:54:37.877	debug	(8589) sendMsg[1] >>> {"id":49,"method":"get_status"}
                mihome-vacuum.0	2020-08-14 23:54:17.959	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4257,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
                mihome-vacuum.0	2020-08-14 23:54:17.875	debug	(8589) sendMsg[1] >>> {"id":48,"method":"get_status"}
                mihome-vacuum.0	2020-08-14 23:53:57.993	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4256,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
                mihome-vacuum.0	2020-08-14 23:53:57.989	debug	(8589) Receive <<< {"partner_id":"","id":47,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-44},"netif":{"localI
                mihome-vacuum.0	2020-08-14 23:53:57.874	debug	(8589) Next WiFi check: 14.08 23:54
                mihome-vacuum.0	2020-08-14 23:53:57.873	debug	(8589) sendMsg[1] >>> {"id":47,"method":"miIO.info"}
                mihome-vacuum.0	2020-08-14 23:53:57.872	debug	(8589) sendMsg[1] >>> {"id":46,"method":"get_status"}
                mihome-vacuum.0	2020-08-14 23:53:37.921	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4245,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
                mihome-vacuum.0	2020-08-14 23:53:37.869	debug	(8589) sendMsg[1] >>> {"id":45,"method":"get_status"}
                mihome-vacuum.0	2020-08-14 23:53:17.955	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4235,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_
                mihome-vacuum.0	2020-08-14 23:53:17.867	debug	(8589) sendMsg[1] >>> {"id":44,"method":"get_status"}
                mihome-vacuum.0	2020-08-14 23:53:16.841	debug	(8589) system.adapter.admin.0: logging true
                mihome-vacuum.0	2020-08-14 23:52:58.455	debug	(8589) system.adapter.admin.0: logging false
                mihome-vacuum.0	2020-08-14 23:52:57.886	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4224,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
                mihome-vacuum.0	2020-08-14 23:52:57.882	debug	(8589) Receive <<< {"partner_id":"","id":43,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-44},"netif":{"local
                mihome-vacuum.0	2020-08-14 23:52:57.866	debug	(8589) Next WiFi check: 14.08 23:53
                mihome-vacuum.0	2020-08-14 23:52:57.865	debug	(8589) sendMsg[1] >>> {"id":43,"method":"miIO.info"}
                mihome-vacuum.0	2020-08-14 23:52:57.864	debug	(8589) sendMsg[1] >>> {"id":42,"method":"get_status"}
                mihome-vacuum.0	2020-08-14 23:52:53.977	info	(8589) room: 275001013628 not mapped
                mihome-vacuum.0	2020-08-14 23:52:53.976	info	(8589) room: 275001013648 not mapped
                mihome-vacuum.0	2020-08-14 23:52:53.971	info	(8589) room: 275001013621 not mapped
                mihome-vacuum.0	2020-08-14 23:52:53.968	info	(8589) room: 275001013646 mapped with index undefined
                mihome-vacuum.0	2020-08-14 23:52:53.965	info	(8589) room: 275001013645 mapped with index undefined
                mihome-vacuum.0	2020-08-14 23:52:53.961	info	(8589) room: 275001013642 mapped with index undefined
                mihome-vacuum.0	2020-08-14 23:52:53.959	info	(8589) room: 275001013641 mapped with index undefined
                mihome-vacuum.0	2020-08-14 23:52:53.955	info	(8589) room: 275001013647 mapped with index undefined
                mihome-vacuum.0	2020-08-14 23:52:53.887	debug	(8589) Receive <<< {"result":[[20,"275001013647"],[16,"275001013641"],[17,"275001013642"],[18,"275001013645"],[19,"275001013646"]],"id":41}
                mihome-vacuum.0	2020-08-14 23:52:53.762	debug	(8589) sendMsg[1] >>> {"id":41,"method":"get_room_mapping"}
                mihome-vacuum.0	2020-08-14 23:52:53.760	debug	(8589) stateChange mihome-vacuum.0.rooms.loadRooms {"val":true,"ack":false,"ts":1597441973751,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597332190595}
                mihome-vacuum.0	2020-08-14 23:52:37.873	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4212,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
                mihome-vacuum.0	2020-08-14 23:52:37.861	debug	(8589) sendMsg[1] >>> {"id":40,"method":"get_status"}
                mihome-vacuum.0	2020-08-14 23:52:17.946	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4200,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
                mihome-vacuum.0	2020-08-14 23:52:17.860	debug	(8589) sendMsg[1] >>> {"id":39,"method":"get_status"}
                mihome-vacuum.0	2020-08-14 23:51:57.980	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4199,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
                mihome-vacuum.0	2020-08-14 23:51:57.979	debug	(8589) Receive <<< {"partner_id":"","id":38,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-44},"netif":{"local
                mihome-vacuum.0	2020-08-14 23:51:57.859	debug	(8589) Next WiFi check: 14.08 23:52
                mihome-vacuum.0	2020-08-14 23:51:57.858	debug	(8589) sendMsg[1] >>> {"id":38,"method":"miIO.info"}
                mihome-vacuum.0	2020-08-14 23:51:57.857	debug	(8589) sendMsg[1] >>> {"id":37,"method":"get_status"}
                mihome-vacuum.0	2020-08-14 23:51:37.912	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4198,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
                mihome-vacuum.0	2020-08-14 23:51:37.855	debug	(8589) sendMsg[1] >>> {"id":36,"method":"get_status"}
                mihome-vacuum.0	2020-08-14 23:51:17.940	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4197,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
                mihome-vacuum.0	2020-08-14 23:51:17.854	debug	(8589) sendMsg[1] >>> {"id":35,"method":"get_status"}
                mihome-vacuum.0	2020-08-14 23:51:00.016	debug	(8589) Mappointer_updated
                mihome-vacuum.0	2020-08-14 23:51:00.015	debug	(8589) Receive <<< {"result":["roboroommap%2F321636546%2F1"],"id":34}
                mihome-vacuum.0	2020-08-14 23:50:59.979	debug	(8589) sendMsg[1] >>> {"id":34,"method":"get_map_v1"}
                mihome-vacuum.0	2020-08-14 23:50:58.588	debug	(8589) Receive <<< {"result":[10854,145977500,26,[1597438510,1597437891,1597437765,1597437590,1597423082,1597414047,1597411995,1597344916,1597332841,1597331343,1597326675,1597322633,1597321619,159732
                mihome-vacuum.0	2020-08-14 23:50:58.479	debug	(8589) sendMsg[1] >>> {"id":33,"method":"get_clean_summary"}
                mihome-vacuum.0	2020-08-14 23:50:57.985	debug	(8589) Receive <<< {"result":[{"main_brush_work_time":10854,"side_brush_work_time":10854,"filter_work_time":10854,"filter_element_work_time":7737,"sensor_dirty_time":10854}],"id":32}
                mihome-vacuum.0	2020-08-14 23:50:57.977	debug	(8589) sendMsg[1] >>> {"id":32,"method":"get_consumable"}
                mihome-vacuum.0	2020-08-14 23:50:57.975	info	(8589) create states for water box filter
                mihome-vacuum.0	2020-08-14 23:50:57.973	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4196,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
                mihome-vacuum.0	2020-08-14 23:50:57.852	debug	(8589) sendMsg[1] >>> {"id":31,"method":"get_status"}
                mihome-vacuum.0	2020-08-14 23:50:42.847	debug	(8589) CLEAN_LOGGING[{"Datum":"14.8","Start":"22:55","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"14.8","Start":"22:44","Saugzeit":"1 min","Fläche":"1.52 m²","Error":0,"Ende":
                mihome-vacuum.0	2020-08-14 23:50:42.653	debug	(8589) Receive <<< {"result":[[1597268211,1597268217,6,0,0,0,2,1,60]],"id":30}
                mihome-vacuum.0	2020-08-14 23:50:42.646	debug	(8589) sendMsg[1] >>> {"id":30,"method":"get_clean_record","params":[1597268211]}
                mihome-vacuum.0	2020-08-14 23:50:42.453	debug	(8589) Receive <<< {"result":[[1597294395,1597296293,1898,32012500,0,1,5,1,52]],"id":29}
                mihome-vacuum.0	2020-08-14 23:50:42.445	debug	(8589) sendMsg[1] >>> {"id":29,"method":"get_clean_record","params":[1597294395]}
                mihome-vacuum.0	2020-08-14 23:50:42.252	debug	(8589) Receive <<< {"result":[[1597319289,1597319912,605,7660000,0,1,5,1,52]],"id":28}
                mihome-vacuum.0	2020-08-14 23:50:42.243	debug	(8589) sendMsg[1] >>> {"id":28,"method":"get_clean_record","params":[1597319289]}
                mihome-vacuum.0	2020-08-14 23:50:42.049	debug	(8589) Receive <<< {"result":[[1597320739,1597320899,15,220000,0,0,1,1,43]],"id":27}
                mihome-vacuum.0	2020-08-14 23:50:42.040	debug	(8589) sendMsg[1] >>> {"id":27,"method":"get_clean_record","params":[1597320739]}
                mihome-vacuum.0	2020-08-14 23:50:41.846	debug	(8589) Receive <<< {"result":[[1597320922,1597320988,23,0,0,0,2,2,61]],"id":26}
                mihome-vacuum.0	2020-08-14 23:50:41.837	debug	(8589) sendMsg[1] >>> {"id":26,"method":"get_clean_record","params":[1597320922]}
                mihome-vacuum.0	2020-08-14 23:50:41.643	debug	(8589) Receive <<< {"result":[[1597321049,1597321413,346,3345000,0,1,2,1,52]],"id":25}
                mihome-vacuum.0	2020-08-14 23:50:41.634	debug	(8589) sendMsg[1] >>> {"id":25,"method":"get_clean_record","params":[1597321049]}
                mihome-vacuum.0	2020-08-14 23:50:41.444	debug	(8589) Receive <<< {"result":[[1597321488,1597321547,59,1775000,0,0,1,1,43]],"id":24}
                mihome-vacuum.0	2020-08-14 23:50:41.432	debug	(8589) sendMsg[1] >>> {"id":24,"method":"get_clean_record","params":[1597321488]}
                mihome-vacuum.0	2020-08-14 23:50:41.239	debug	(8589) Receive <<< {"result":[[1597321619,1597322479,844,7545000,0,1,2,1,52]],"id":23}
                mihome-vacuum.0	2020-08-14 23:50:41.230	debug	(8589) sendMsg[1] >>> {"id":23,"method":"get_clean_record","params":[1597321619]}
                mihome-vacuum.0	2020-08-14 23:50:41.036	debug	(8589) Receive <<< {"result":[[1597322633,1597325189,2556,33375000,0,1,2,1,52]],"id":22}
                mihome-vacuum.0	2020-08-14 23:50:41.028	debug	(8589) sendMsg[1] >>> {"id":22,"method":"get_clean_record","params":[1597322633]}
                mihome-vacuum.0	2020-08-14 23:50:40.835	debug	(8589) Receive <<< {"result":[[1597326675,1597328878,2203,31472500,0,1,1,1,52]],"id":21}
                mihome-vacuum.0	2020-08-14 23:50:40.826	debug	(8589) sendMsg[1] >>> {"id":21,"method":"get_clean_record","params":[1597326675]}
                mihome-vacuum.0	2020-08-14 23:50:40.633	debug	(8589) Receive <<< {"result":[[1597331343,1597331356,13,0,0,0,5,1,60]],"id":20}
                mihome-vacuum.0	2020-08-14 23:50:40.625	debug	(8589) sendMsg[1] >>> {"id":20,"method":"get_clean_record","params":[1597331343]}
                mihome-vacuum.0	2020-08-14 23:50:40.430	debug	(8589) Receive <<< {"result":[[1597332841,1597332874,33,482500,0,0,5,1,60]],"id":19}
                mihome-vacuum.0	2020-08-14 23:50:40.421	debug	(8589) sendMsg[1] >>> {"id":19,"method":"get_clean_record","params":[1597332841]}
                mihome-vacuum.0	2020-08-14 23:50:40.370	warn	(8589) HTTP error when getting token cookie
                mihome-vacuum.0	2020-08-14 23:50:40.369	error	(8589) HTTP error when getting token cookie{}
                mihome-vacuum.0	2020-08-14 23:50:40.225	debug	(8589) Receive <<< {"result":[[1597344916,1597344932,16,0,0,0,5,1,60]],"id":18}
                mihome-vacuum.0	2020-08-14 23:50:40.220	debug	(8589) sendMsg[1] >>> {"id":18,"method":"get_clean_record","params":[1597344916]}
                mihome-vacuum.0	2020-08-14 23:50:40.216	debug	(8589) Mappointer_updated
                mihome-vacuum.0	2020-08-14 23:50:40.215	debug	(8589) Receive <<< {"result":["roboroommap%2F321636546%2F0"],"id":17}
                mihome-vacuum.0	2020-08-14 23:50:40.208	debug	(8589) 1. Mappointer_nomap___retry
                mihome-vacuum.0	2020-08-14 23:50:40.207	debug	(8589) sendMsg[1] >>> {"id":17,"method":"get_map_v1"}
                mihome-vacuum.0	2020-08-14 23:50:40.027	debug	(8589) Receive <<< {"result":[[1597411995,1597412226,231,5247500,0,1,2,3,56]],"id":16}
                mihome-vacuum.0	2020-08-14 23:50:40.018	debug	(8589) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1597411995]}
                mihome-vacuum.0	2020-08-14 23:50:39.829	debug	(8589) Receive <<< {"result":[[1597414047,1597415374,1327,9362500,0,1,2,3,56]],"id":15}
                mihome-vacuum.0	2020-08-14 23:50:39.817	debug	(8589) sendMsg[1] >>> {"id":15,"method":"get_clean_record","params":[1597414047]}
                mihome-vacuum.0	2020-08-14 23:50:39.705	debug	(8589) Receive <<< {"result":["retry"],"id":14}
                mihome-vacuum.0	2020-08-14 23:50:39.700	debug	(8589) 0. Mappointer_nomap___retry
                mihome-vacuum.0	2020-08-14 23:50:39.699	debug	(8589) sendMsg[1] >>> {"id":14,"method":"get_map_v1"}
                mihome-vacuum.0	2020-08-14 23:50:39.624	debug	(8589) Receive <<< {"result":[[1597423082,1597423092,10,0,0,0,2,2,61]],"id":13}
                mihome-vacuum.0	2020-08-14 23:50:39.616	debug	(8589) sendMsg[1] >>> {"id":13,"method":"get_clean_record","params":[1597423082]}
                mihome-vacuum.0	2020-08-14 23:50:39.423	debug	(8589) Receive <<< {"result":[[1597437590,1597437762,70,970000,0,0,2,3,60]],"id":12}
                mihome-vacuum.0	2020-08-14 23:50:39.415	debug	(8589) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1597437590]}
                mihome-vacuum.0	2020-08-14 23:50:39.218	debug	(8589) Receive <<< {"result":[[1597437765,1597437801,36,470000,0,0,2,3,60]],"id":11}
                mihome-vacuum.0	2020-08-14 23:50:39.213	debug	(8589) sendMsg[1] >>> {"id":11,"method":"get_clean_record","params":[1597437765]}
                mihome-vacuum.0	2020-08-14 23:50:39.196	debug	(8589) Receive <<< {"result":["retry"],"id":10}
                mihome-vacuum.0	2020-08-14 23:50:39.191	debug	(8589) sendMsg[1] >>> {"id":10,"method":"get_map_v1"}
                mihome-vacuum.0	2020-08-14 23:50:39.021	debug	(8589) Receive <<< {"result":[[1597437891,1597437942,51,1522500,0,0,2,3,60]],"id":9}
                mihome-vacuum.0	2020-08-14 23:50:39.010	debug	(8589) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1597437891]}
                mihome-vacuum.0	2020-08-14 23:50:39.004	debug	(8589) Receive <<< {"result":[[16,"275001013621"],[17,"275001013648"],[18,"275001013628"]],"id":8}
                mihome-vacuum.0	2020-08-14 23:50:39.003	info	(8589) create state for carpet_mode
                mihome-vacuum.0	2020-08-14 23:50:39.001	debug	(8589) Receive <<< {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":7}
                mihome-vacuum.0	2020-08-14 23:50:38.992	debug	(8589) sendMsg[1] >>> {"id":8,"method":"get_room_mapping"}
                mihome-vacuum.0	2020-08-14 23:50:38.991	debug	(8589) sendMsg[1] >>> {"id":7,"method":"get_carpet_mode"}
                mihome-vacuum.0	2020-08-14 23:50:38.815	debug	(8589) Receive <<< {"result":[[1597438510,1597438518,8,0,0,0,2,3,60]],"id":6}
                mihome-vacuum.0	2020-08-14 23:50:38.808	debug	(8589) sendMsg[1] >>> {"id":6,"method":"get_clean_record","params":[1597438510]}
                mihome-vacuum.0	2020-08-14 23:50:38.802	debug	(8589) Receive <<< {"result":[10854,145977500,26,[1597438510,1597437891,1597437765,1597437590,1597423082,1597414047,1597411995,1597344916,1597332841,1597331343,1597326675,1597322633,1597321619,159732
                mihome-vacuum.0	2020-08-14 23:50:38.792	debug	(8589) sendMsg[1] >>> {"id":5,"method":"get_clean_summary"}
                mihome-vacuum.0	2020-08-14 23:50:38.601	debug	(8589) Receive <<< {"result":[{"main_brush_work_time":10854,"side_brush_work_time":10854,"filter_work_time":10854,"filter_element_work_time":7737,"sensor_dirty_time":10854}],"id":4}
                mihome-vacuum.0	2020-08-14 23:50:38.591	debug	(8589) sendMsg[1] >>> {"id":4,"method":"get_consumable"}
                mihome-vacuum.0	2020-08-14 23:50:38.404	debug	(8589) Receive <<< {"result":[90],"id":3}
                mihome-vacuum.0	2020-08-14 23:50:38.393	debug	(8589) sendMsg[1] >>> {"id":3,"method":"get_sound_volume"}
                mihome-vacuum.0	2020-08-14 23:50:38.391	info	(8589) set nächster Timer: Nicht verfügbar
                mihome-vacuum.0	2020-08-14 23:50:38.198	debug	(8589) Receive <<< {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-44},"netif":{"localI
                mihome-vacuum.0	2020-08-14 23:50:38.194	debug	(8589) Next WiFi check: 14.08 23:51
                mihome-vacuum.0	2020-08-14 23:50:38.192	debug	(8589) sendMsg[1] >>> {"id":2,"method":"miIO.info"}
                mihome-vacuum.0	2020-08-14 23:50:37.989	info	(8589) Connected
                mihome-vacuum.0	2020-08-14 23:50:37.986	debug	(8589) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                mihome-vacuum.0	2020-08-14 23:50:37.983	debug	(8589) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4195,"state":8,"battery":100,"clean_time":8,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab
                mihome-vacuum.0	2020-08-14 23:50:37.972	debug	(8589) sendMsg[1] >>> {"id":1,"method":"get_status"}
                mihome-vacuum.0	2020-08-14 23:50:37.940	debug	(8589) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                mihome-vacuum.0	2020-08-14 23:50:37.939	info	(8589) connecting, this can take up to 10 minutes ...
                mihome-vacuum.0	2020-08-14 23:50:37.937	debug	(8589) Receive <<< Helo <<< 2131002000000000132bc8c25f37072dffffffffffffffffffffffffffffffff
                mihome-vacuum.0	2020-08-14 23:50:37.930	info	(8589) New generation or new fw(3.5.8,4436) detected, create new states goto and zoneclean
                mihome-vacuum.0	2020-08-14 23:50:37.916	debug	(8589) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                mihome-vacuum.0	2020-08-14 23:50:37.857	debug	(8589) server started on 0.0.0.0:53421
                mihome-vacuum.0	2020-08-14 23:50:37.842	info	(8589) Create state clean_home for controlling by cloud adapter
                mihome-vacuum.0	2020-08-14 23:50:37.840	info	(8589) Expert mode disabled, states deleted
                mihome-vacuum.0	2020-08-14 23:50:37.831	debug	(8589) Xiaomi Cloud: Logging in
                mihome-vacuum.0	2020-08-14 23:50:37.828	debug	(8589) load Map creator... true
                mihome-vacuum.0	2020-08-14 23:50:37.730	info	(8589) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.18.3, js-controller: 3.1.6
                mihome-vacuum.0	2020-08-14 23:50:36.347	debug	(8589) statesDB connected
                mihome-vacuum.0	2020-08-14 23:50:36.346	debug	(8589) States connected to redis: 127.0.0.1:9000
                mihome-vacuum.0	2020-08-14 23:50:36.311	debug	(8589) States create System PubSub Client
                mihome-vacuum.0	2020-08-14 23:50:36.308	debug	(8589) States create User PubSub Client
                mihome-vacuum.0	2020-08-14 23:50:36.296	debug	(8589) Redis States: Use Redis connection: 127.0.0.1:9000
                mihome-vacuum.0	2020-08-14 23:50:36.294	debug	(8589) objectDB connected
                mihome-vacuum.0	2020-08-14 23:50:36.287	debug	(8589) Objects connected to redis: 127.0.0.1:9001
                mihome-vacuum.0	2020-08-14 23:50:36.262	debug	(8589) Objects client initialize lua scripts
                mihome-vacuum.0	2020-08-14 23:50:36.261	debug	(8589) Objects create User PubSub Client
                mihome-vacuum.0	2020-08-14 23:50:36.260	debug	(8589) Objects create System PubSub Client
                mihome-vacuum.0	2020-08-14 23:50:36.256	debug	(8589) Objects client ready ... initialize now
                mihome-vacuum.0	2020-08-14 23:50:36.216	debug	(8589) Redis Objects: Use Redis connection: 127.0.0.1:9001
                mihome-vacuum.0	2020-08-14 23:50:31.904	info	(12559) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                mihome-vacuum.0	2020-08-14 23:50:31.903	info	(12559) terminating
                mihome-vacuum.0	2020-08-14 23:50:31.900	info	(12559) Got terminate signal TERMINATE_YOURSELF
                Die Datenpunkte "roomClean" und "state" werden bei Kartenwechsel jeweils neu angelegt und in den ordner "mapIndex" verschoben. Das macht mir erstens den gezielten Raumzugriff unmöglich und eliminiert zweitens meine IOT smart Devices.
                  freaktech last edited by freaktech
                  Hallo Leute!
                  Hab jetzt nen S5 Max und bekomme in den Kartenlink keinen Eintrag.
                  Bin leider nicht so der Profi, aber hier mal meine Infos und Einstellungen
                  PI4
                  Adapter mihome-vacuum Version 2.2.0
                  Modell S5 Max
                  Firmware lt Mi Home APP 3.5.8_0876
                  Logging:
                  mihome-vacuum.0	2020-08-15 08:41:49.625	debug	(28150) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1012,"state":8,"battery":100,"clean_time":13,"clean_area":140000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":
                  mihome-vacuum.0	2020-08-15 08:41:49.621	debug	(28150) Receive <<< {"partner_id":"","id":119,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_0876","ap":{"ssid":"dexter","bssid":"74:83:c2:87:ca:a6","rssi":-47},"netif":{"localIp":
                  mihome-vacuum.0	2020-08-15 08:41:49.615	debug	(28150) Next WiFi check: 15.08 08:42
                  mihome-vacuum.0	2020-08-15 08:41:49.614	debug	(28150) sendMsg[1] >>> {"id":119,"method":"miIO.info"}
                  mihome-vacuum.0	2020-08-15 08:41:49.613	debug	(28150) sendMsg[1] >>> {"id":118,"method":"get_status"}
                  mihome-vacuum.0	2020-08-15 08:41:41.447	debug	(28150) system.adapter.admin.0: logging true
                  mihome-vacuum.0	2020-08-15 08:41:29.617	debug	(28150) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1011,"state":8,"battery":100,"clean_time":13,"clean_area":140000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
                  mihome-vacuum.0	2020-08-15 08:41:29.608	debug	(28150) sendMsg[1] >>> {"id":117,"method":"get_status"}
                  mihome-vacuum.0	2020-08-15 08:41:10.637	debug	(28150) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1010,"state":8,"battery":100,"clean_time":13,"clean_area":140000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
                  mihome-vacuum.0	2020-08-15 08:41:09.606	debug	(28150) sendMsg[1] >>> {"id":116,"method":"get_status"}
                  mihome-vacuum.0	2020-08-15 08:40:49.613	debug	(28150) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1009,"state":8,"battery":100,"clean_time":13,"clean_area":140000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
                  mihome-vacuum.0	2020-08-15 08:40:49.610	debug	(28150) Receive <<< {"partner_id":"","id":115,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_0876","ap":{"ssid":"dexter","bssid":"74:83:c2:87:ca:a6","rssi":-47},"netif":{"localIp"
                  mihome-vacuum.0	2020-08-15 08:40:49.605	debug	(28150) Next WiFi check: 15.08 08:41
                  mihome-vacuum.0	2020-08-15 08:40:49.604	debug	(28150) sendMsg[1] >>> {"id":115,"method":"miIO.info"}
                  mihome-vacuum.0	2020-08-15 08:40:49.603	debug	(28150) sendMsg[1] >>> {"id":114,"method":"get_status"}
                  mihome-vacuum.0	2020-08-15 08:40:29.608	debug	(28150) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1008,"state":8,"battery":100,"clean_time":13,"clean_area":140000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
                  mihome-vacuum.0	2020-08-15 08:40:29.601	debug	(28150) sendMsg[1] >>> {"id":113,"method":"get_status"}
                  mihome-vacuum.0	2020-08-15 08:40:09.608	debug	(28150) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1007,"state":8,"battery":100,"clean_time":13,"clean_area":140000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
                  mihome-vacuum.0	2020-08-15 08:40:09.600	debug	(28150) sendMsg[1] >>> {"id":112,"method":"get_status"}
                  mihome-vacuum.0	2020-08-15 08:39:49.608	debug	(28150) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1006,"state":8,"battery":100,"clean_time":13,"clean_area":140000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
                  mihome-vacuum.0	2020-08-15 08:39:49.606	debug	(28150) Receive <<< {"partner_id":"","id":111,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_0876","ap":{"ssid":"dexter","bssid":"74:83:c2:87:ca:a6","rssi":-47},"netif":{"localIp"
                  mihome-vacuum.0	2020-08-15 08:39:49.599	debug	(28150) Next WiFi check: 15.08 08:40
                  mihome-vacuum.0	2020-08-15 08:39:49.598	debug	(28150) sendMsg[1] >>> {"id":111,"method":"miIO.info"}
                  mihome-vacuum.0	2020-08-15 08:39:49.593	debug	(28150) sendMsg[1] >>> {"id":110,"method":"get_status"}
                  der Adapter selbst läuft nun
                  die Räume sind drinnen und auf Steuerungsbefehle per Blockly reagiert er auch
                  Bildschirmfoto 2020-08-15 um 08.43.28.png Bildschirmfoto 2020-08-15 um 08.43.54.png Bildschirmfoto 2020-08-15 um 08.43.58.png
                  danke Tom
                  evtl. kann mal wer mit Teamviewer helfen, ich checks nicht mehr
                    A Former User @freaktech last edited by
                    @freaktech in dem Log seh ich jetzt weniger einen Fehler, der wichtige Teil fehlt anscheinend... ?
                    Hast du mal canvas neu gebaut? ( falls nicht, google mal hier im Thread danach, ist xmal beschrieben)
                    Ansonsten hilft für die Fehlersuche immer das Log vom Starten des Adapters
                      freaktech @Guest last edited by
                      @ilovegym
                      Please install canvas and the libs manually with:
                      sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                      sudo npm install canvas --unsafe-perm=true
                      das hab ich probiert
                      jetzt versucht er wieder seit 10 min zu verbinden ?!?
                        Thomas Braun Most Active @freaktech last edited by Thomas Braun
                        @freaktech npm ohne sudo
                        Dafür musst du aber in /opt/iobroker stehen.
                        Was liefert denn nachfolgende Befehlsfolge bei dir?
                        pi@raspberrypi:~ $ cd /opt/iobroker/
                        pi@raspberrypi:/opt/iobroker $ npm list canvas
                        iobroker.inst@2.0.3 /opt/iobroker
                        ├── canvas@2.6.1
                        ├─┬ iobroker.iot@1.7.0
                        │ └── canvas@2.6.1  deduped
                        └─┬ iobroker.mihome-vacuum@2.1.1
                          freaktech @Thomas Braun last edited by freaktech
                          @Thomas-Braun
                          wie komm ich von
                          pi@ioBroker-RasPi4:~ $
                          dort hin?
                          was genau eintippen?
                          danke
                          pi@ioBroker-RasPi4:/opt/iobroker $ npm install canvas --unsafe-perm=true
                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/canvas
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.5 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-aead-crypto@^2.0.0 (node_modules/node-dtls-client/node_modules/node-aead-crypto):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported engine for node-aead-crypto@2.2.0: wanted: {"node":">4 <10"} (current: {"node":"12.18.3","npm":"6.14.6"})
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Not compatible with your version of node/npm: node-aead-crypto@2.2.0
                          npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/node-aead-crypto/package.json'
                          npm ERR! code EACCES
                          npm ERR! syscall access
                          npm ERR! path /opt/iobroker/node_modules/canvas
                          npm ERR! errno -13
                          npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/canvas'
                          npm ERR!  [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/canvas'] {
                          npm ERR!   errno: -13,
                          npm ERR!   code: 'EACCES',
                          npm ERR!   syscall: 'access',
                          npm ERR!   path: '/opt/iobroker/node_modules/canvas'
                          npm ERR! }
                          npm ERR!
                          npm ERR! The operation was rejected by your operating system.
                          npm ERR! It is likely you do not have the permissions to access this file as the current user
                          npm ERR!
                          npm ERR! If you believe this might be a permissions issue, please double-check the
                          npm ERR! permissions of the file and its containing directories, or try running
                          npm ERR! the command again as root/Administrator.
                          npm ERR!     /home/iobroker/.npm/_logs/2020-08-15T11_21_54_151Z-debug.log
                            @freaktech
                            ├── canvas@2.6.1
                              @Thomas-Braun
                              pi@ioBroker-RasPi4:/opt/iobroker $ npm list canvas
                              ├── canvas@2.6.1
                              ├─┬ iobroker.iot@1.5.3
                              └─┬ iobroker.mihome-vacuum@2.2.0
                                freaktech @freaktech last edited by
                                @freaktech ```
                                mihome-vacuum.0 2020-08-15 13:28:54.574 debug (7072) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1906,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
                                mihome-vacuum.0 2020-08-15 13:28:53.134 debug (7072) sendMsg[1] >>> {"id":97,"method":"get_status"}
                                mihome-vacuum.0 2020-08-15 13:28:45.683 debug (7072) system.adapter.admin.0: logging true
                                mihome-vacuum.0 2020-08-15 13:28:39.140 debug (7072) Mappointer_updated
                                mihome-vacuum.0 2020-08-15 13:28:39.138 debug (7072) Receive <<< {"result":["rubyslite%2F320252511%2F1"],"id":96}
                                mihome-vacuum.0 2020-08-15 13:28:39.132 debug (7072) sendMsg[1] >>> {"id":96,"method":"get_map_v1"}
                                mihome-vacuum.0 2020-08-15 13:28:39.130 debug (7072) stateChange mihome-vacuum.0.map.loadMap {"val":true,"ack":false,"ts":1597490919126,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597432659531}
                                mihome-vacuum.0 2020-08-15 13:28:35.470 debug (7072) Mappointer_updated
                                mihome-vacuum.0 2020-08-15 13:28:35.469 debug (7072) Receive <<< {"result":["rubyslite%2F320252511%2F0"],"id":95}
                                mihome-vacuum.0 2020-08-15 13:28:35.463 debug (7072) 1. Mappointer_nomap___retry
                                mihome-vacuum.0 2020-08-15 13:28:35.462 debug (7072) sendMsg[1] >>> {"id":95,"method":"get_map_v1"}
                                mihome-vacuum.0 2020-08-15 13:28:34.961 debug (7072) Receive <<< {"result":["retry"],"id":94}
                                mihome-vacuum.0 2020-08-15 13:28:34.955 debug (7072) 0. Mappointer_nomap___retry
                                mihome-vacuum.0 2020-08-15 13:28:34.954 debug (7072) sendMsg[1] >>> {"id":94,"method":"get_map_v1"}
                                mihome-vacuum.0 2020-08-15 13:28:34.452 debug (7072) Receive <<< {"result":["retry"],"id":93}
                                mihome-vacuum.0 2020-08-15 13:28:34.446 debug (7072) sendMsg[1] >>> {"id":93,"method":"get_map_v1"}
                                mihome-vacuum.0 2020-08-15 13:28:34.445 debug (7072) stateChange mihome-vacuum.0.map.loadMap {"val":true,"ack":false,"ts":1597490914442,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597432659531}
                                mihome-vacuum.0 2020-08-15 13:28:33.430 debug (7072) Receive <<< {"partner_id":"","id":92,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_0876","ap":{"ssid":"dexter","bssid":"74:83:c2:87:ca:a6","rssi":-44},"netif":{"localIp":"
                                mihome-vacuum.0 2020-08-15 13:28:33.415 debug (7072) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1905,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
                                mihome-vacuum.0 2020-08-15 13:28:33.260 debug (7072) system.adapter.admin.0: logging false
                                mihome-vacuum.0 2020-08-15 13:28:33.132 debug (7072) Next WiFi check: 15.08 13:29
                                mihome-vacuum.0 2020-08-15 13:28:33.131 debug (7072) sendMsg[1] >>> {"id":92,"method":"miIO.info"}
                                mihome-vacuum.0 2020-08-15 13:28:33.130 debug (7072) sendMsg[1] >>> {"id":91,"method":"get_status"}
                                mihome-vacuum.0 2020-08-15 13:28:13.136 debug (7072) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1904,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
                                mihome-vacuum.0 2020-08-15 13:28:13.128 debug (7072) sendMsg[1] >>> {"id":90,"method":"get_status"}
                                mihome-vacuum.0 2020-08-15 13:27:53.135 debug (7072) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1903,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
                                mihome-vacuum.0 2020-08-15 13:27:53.126 debug (7072) sendMsg[1] >>> {"id":89,"method":"get_status"}
                                mihome-vacuum.0 2020-08-15 13:27:33.133 debug (7072) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1902,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
                                mihome-vacuum.0 2020-08-15 13:27:33.131 debug (7072) Receive <<< {"partner_id":"","id":88,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_0876","ap":{"ssid":"dexter","bssid":"74:83:c2:87:ca:a6","rssi":-44},"netif":{"localIp":"
                                mihome-vacuum.0 2020-08-15 13:27:33.126 debug (7072) Next WiFi check: 15.08 13:28
                                mihome-vacuum.0 2020-08-15 13:27:33.125 debug (7072) sendMsg[1] >>> {"id":88,"method":"miIO.info"}
                                mihome-vacuum.0 2020-08-15 13:27:33.124 debug (7072) sendMsg[1] >>> {"id":87,"method":"get_status"}
                                mihome-vacuum.0 2020-08-15 13:27:15.492 debug (7072) system.adapter.admin.0: logging true
                                mihome-vacuum.0 2020-08-15 13:27:13.131 debug (7072) Receive <<< {"result":[{"msg_ver":2,"msg_seq":1901,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
                                mihome-vacuum.0 2020-08-15 13:27:13.123 debug (7072) sendMsg[1] >>> {"id":86,"method":"get_status"}
                                  @freaktech
                                  ls -la /opt/iobroker/node_modules/canvas/
                                    @Thomas-Braun
                                    pi@ioBroker-RasPi4:/opt/iobroker $ ls -la /opt/iobroker/node_modules/canvas/
                                    insgesamt 144
                                    drwxr-xr-x+   8 pi       pi        4096 Aug 13 14:37 .
                                    drwxrwxrwx+ 816 iobroker iobroker 36864 Aug 14 21:15 ..
                                    -rw-r--r--+   1 pi       pi        6832 Okt 26  1985 binding.gyp
                                    -rw-r--r--+   1 pi       pi        1064 Okt 26  1985 browser.js
                                    drwxr-xr-x+   3 pi       pi        4096 Aug 13 14:37 build
                                    -rw-r--r--+   1 pi       pi       28011 Okt 26  1985 CHANGELOG.md
                                    -rw-r--r--+   1 pi       pi        2363 Okt 26  1985 index.js
                                    drwxr-xr-x+   2 pi       pi        4096 Aug 13 14:37 lib
                                    drwxr-xr-x+  10 pi       pi        4096 Aug 13 14:37 node_modules
                                    -rw-r--r--+   1 pi       pi        3210 Aug 13 14:37 package.json
                                    -rw-r--r--+   1 pi       pi       26514 Okt 26  1985 Readme.md
                                    drwxr-xr-x+   4 pi       pi        4096 Aug 13 14:37 src
                                    drwxr-xr-x+   2 pi       pi        4096 Aug 13 14:37 types
                                    drwxr-xr-x+   2 pi       pi        4096 Aug 13 14:37 util
                                      @freaktech
                                      Die Dateien gehören dem falschen User.
                                      So muss das aussehen:
                                      pi@raspberrypi:~ $ ls -la /opt/iobroker/node_modules/canvas/
                                      insgesamt 136
                                      drwxrwxr-x+   8 iobroker iobroker  4096 Mai  9 14:23 .
                                      drwxrwxr-x+ 806 iobroker iobroker 28672 Aug 14 09:30 ..
                                      -rw-rwxr--+   1 iobroker iobroker  6832 Okt 26  1985 binding.gyp
                                      -rw-rwxr--+   1 iobroker iobroker  1064 Okt 26  1985 browser.js
                                      drwxrwxr-x+   3 iobroker iobroker  4096 Mai  9 14:23 build
                                      -rw-rwxr--+   1 iobroker iobroker 28011 Okt 26  1985 CHANGELOG.md
                                      -rw-rwxr--+   1 iobroker iobroker  2363 Okt 26  1985 index.js
                                      drwxrwxr-x+   2 iobroker iobroker  4096 Apr 29 18:57 lib
                                      drwxrwxr-x+   9 iobroker iobroker  4096 Apr 29 18:57 node_modules
                                      -rw-rwxr--+   1 iobroker iobroker  3154 Apr 29 18:57 package.json
                                      -rw-rwxr--+   1 iobroker iobroker 26514 Okt 26  1985 Readme.md
                                      drwxrwxr-x+   4 iobroker iobroker  4096 Apr 29 18:57 src
                                      drwxrwxr-x+   2 iobroker iobroker  4096 Apr 29 18:57 types
                                      drwxrwxr-x+   2 iobroker iobroker  4096 Apr 29 18:57 util
                                      pi@raspberrypi:~ $
                                        @Thomas-Braun
                                        das versteh ich leider nicht
                                          @freaktech said in Test Adapter mihome-vacuum v2.0.x:
                                          @Thomas-Braun
                                          wie kommt das und wie kann ich das ändern?
                                            @freaktech Das kommt durch den falschen Einsatz von sudo vor dem npm Befehl. Das Modul muss dem User und der Gruppe 'iobroker' gehören.
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            467371
