    4. Test Adapter Linux Control v1.x.x
    • Scrounger
      Scrounger Developer @liv-in-sky last edited by
      @liv-in-sky, @ilovegym
      Oh sorry da hab ich was zerschossen. Habs gefixt, bitte Version 0.2.6 testen, thx.
      harrym liv-in-sky ? 3 Replies Last reply Reply Quote 1
      • harrym
        harrym @Scrounger last edited by
        @Scrounger läuft 😉
          liv-in-sky @Scrounger last edited by liv-in-sky
          @Scrounger thanx 👍
            A Former User @Scrounger last edited by
            @Scrounger Super, 0.2.6 läuft ohne meckern 🙂
              Homoran Global Moderator Administrators @Scrounger last edited by Homoran
              @Scrounger sagte in Test Adapter Linux Control v0.x.x:
              Version 0.2.5 bei github verügbar, bitte darauf updaten.
              @Homoran
              Adapter auf debug stellen und dann bitte das log posten.
              erledigt: aber noch mit der alten Version:
              2020-08-15 16:04:21.514 - info: host.raspberrypi Do not restart adapter system.adapter.linux-control.0 because desired by instance
              2020-08-15 16:04:22.317 - debug: linux-control.0 (19029) Redis Objects: Use Redis connection: 127.0.0.1:9001
              2020-08-15 16:04:22.356 - debug: linux-control.0 (19029) Objects client ready ... initialize now
              2020-08-15 16:04:22.370 - debug: linux-control.0 (19029) Objects create System PubSub Client
              2020-08-15 16:04:22.371 - debug: linux-control.0 (19029) Objects create User PubSub Client
              2020-08-15 16:04:22.372 - debug: linux-control.0 (19029) Objects client initialize lua scripts
              2020-08-15 16:04:22.393 - debug: linux-control.0 (19029) Objects connected to redis: 127.0.0.1:9001
              2020-08-15 16:04:22.402 - debug: linux-control.0 (19029) objectDB connected
              2020-08-15 16:04:22.404 - debug: linux-control.0 (19029) Redis States: Use Redis connection: 127.0.0.1:9000
              2020-08-15 16:04:22.416 - debug: linux-control.0 (19029) States create User PubSub Client
              2020-08-15 16:04:22.419 - debug: linux-control.0 (19029) States create System PubSub Client
              2020-08-15 16:04:22.438 - debug: linux-control.0 (19029) States connected to redis: 127.0.0.1:9000
              2020-08-15 16:04:22.439 - debug: linux-control.0 (19029) statesDB connected
              2020-08-15 16:04:24.577 - debug: linux-control.0 (19029) Plugin sentry Initialize Plugin (enabled=true)
              2020-08-15 16:04:24.740 - info: linux-control.0 (19029) starting. Version 0.2.4 in /opt/iobroker/node_modules/iobroker.linux-control, node: v10.21.0, js-controller: 3.1.4
              2020-08-15 16:04:24.814 - info: linux-control.0 (19029) getting data from RasPi4 (192.168.138.139:22)
              2020-08-15 16:04:24.857 - debug: linux-control.0 (19029) [getConnection] Host 'RasPi4' (192.168.138.139:22): using sudo for authentification
              2020-08-15 16:04:25.048 - debug: linux-control.0 (19029) [distributionInfo] RasPi4 (192.168.138.139:22): send command: 'cat /etc/os-release'
              2020-08-15 16:04:25.389 - debug: linux-control.0 (19029) [distributionInfo] RasPi4 (192.168.138.139:22): response stdout: PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
              NAME="Raspbian GNU/Linux"
              VERSION_ID="10"
              VERSION="10 (buster)"
              VERSION_CODENAME=buster
              ID=raspbian
              ID_LIKE=debian
              HOME_URL="http://www.raspbian.org/"
              SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
              BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
              2020-08-15 16:04:25.413 - debug: linux-control.0 (19029) [distributionInfo] RasPi4 (192.168.138.139:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Raspbian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Raspbian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"raspbian"},{"prop":"ID_LIKE","val":"debian"},{"prop":"HOME_URL","val":"http://www.raspbian.org/"},{"prop":"SUPPORT_URL","val":"http://www.raspbian.org/RaspbianForums"},{"prop":"BUG_REPORT_URL","val":"http://www.raspbian.org/RaspbianBugs"}]
              2020-08-15 16:04:25.526 - debug: linux-control.0 (19029) [cmdAptUpdate] RasPi4 (192.168.138.139:22): no datapoints selected -> removing existing datapoints
              2020-08-15 16:04:25.637 - debug: linux-control.0 (19029) [servicesInfo] RasPi4 (192.168.138.139:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
              2020-08-15 16:04:25.662 - debug: linux-control.0 (19029) [servicesInfo] RasPi4 (192.168.138.139:22): response stdout: alsa-restore.service,loaded,active,exited, Save/Restore Sound Card State
              alsa-state.service,loaded,active,running, Manage Sound Card State (restore and store)
              apparmor.service,not-found,inactive,dead, apparmor.service
              apt-daily-upgrade.service,loaded,inactive,dead, Daily apt upgrade and clean activities
              apt-daily.service,loaded,inactive,dead, Daily apt download activities
              auditd.service,not-found,inactive,dead, auditd.service
              auth-rpcgss-module.service,loaded,inactive,dead, Kernel Module supporting RPCSEC_GSS
              avahi-daemon.service,loaded,active,running, Avahi mDNS/DNS-SD Stack
              bluetooth.service,loaded,active,running, Bluetooth service
              bthelper@hci0.service,loaded,inactive,dead, Raspberry Pi bluetooth helper
              connman.service,not-found,inactive,dead, connman.service
              console-screen.service,not-found,inactive,dead, console-screen.service
              console-setup.service,loaded,active,exited, Set console font and keymap
              cron.service,loaded,active,running, Regular background program processing daemon
              dbus.service,loaded,active,running, D-Bus System Message Bus
              dhcpcd.service,loaded,active,running, dhcpcd on all interfaces
              display-manager.service,not-found,inactive,dead, display-manager.service
              dphys-swapfile.service,loaded,active,exited, dphys-swapfile - set up, mount/unmount, and delete a swap file
              emergency.service,loaded,inactive,dead, Emergency Shell
              fake-hwclock.service,loaded,active,exited, Restore / save the current clock
              getty-static.service,loaded,inactive,dead, getty on tty2-tty6 if dbus and logind are not available
              getty@tty1.service,loaded,active,running, Getty on tty1
              gssproxy.service,not-found,inactive,dead, gssproxy.service
              hciuart.service,loaded,active,running, Configure Bluetooth Modems connected by UART
              ifupdown-pre.service,loaded,active,exited, Helper to synchronize boot up for ifupdown
              influxdb.service,not-found,inactive,dead, influxdb.service
              iobroker.service,loaded,active,running, ioBroker Server
              kbd.service,not-found,inactive,dead, kbd.service
              keyboard-setup.service,loaded,active,exited, Set the console keyboard layout
              kmod-static-nodes.service,loaded,active,exited, Create list of required static device nodes for the current kernel
              logrotate.service,loaded,inactive,dead, Rotate log files
              man-db.service,loaded,inactive,dead, Daily man-db regeneration
              mariadb-server.service,not-found,inactive,dead, mariadb-server.service
              mountkernfs.service,masked,inactive,dead, mountkernfs.service
              mysql-server.service,not-found,inactive,dead, mysql-server.service
              networking.service,loaded,active,exited, Raise network interfaces
              NetworkManager.service,not-found,inactive,dead, NetworkManager.service
              nfs-blkmap.service,not-found,inactive,dead, nfs-blkmap.service
              nfs-config.service,loaded,inactive,dead, Preprocess NFS configuration
              nfs-server.service,not-found,inactive,dead, nfs-server.service
              nfs-utils.service,loaded,inactive,dead, NFS server and client services
              plymouth-quit-wait.service,not-found,inactive,dead, plymouth-quit-wait.service
              plymouth-start.service,not-found,inactive,dead, plymouth-start.service
              raspberrypi-net-mods.service,loaded,inactive,dead, Copy user wpa_supplicant.conf
              raspi-config.service,loaded,active,exited, LSB: Switch to ondemand cpu governor (unless shift key is pressed)
              rc-local.service,loaded,active,exited, /etc/rc.local Compatibility
              redis.service,not-found,inactive,dead, redis.service
              regenerate_ssh_host_keys.service,loaded,inactive,dead, Regenerate SSH host keys
              rescue.service,loaded,inactive,dead, Rescue Shell
              rng-tools.service,loaded,active,running, rng-tools.service
              rpc-gssd.service,loaded,inactive,dead, RPC security service for NFS client and server
              rpc-svcgssd.service,loaded,inactive,dead, RPC security service for NFS server
              rpi-eeprom-update.service,loaded,active,exited, Check for Raspberry Pi EEPROM updates
              rsync.service,loaded,inactive,dead, fast remote file copy program daemon
              rsyslog.service,loaded,active,running, System Logging Service
              ssh.service,loaded,active,running, OpenBSD Secure Shell server
              sshswitch.service,loaded,inactive,dead, Turn on SSH if /boot/ssh is present
              systemd-ask-password-console.service,loaded,inactive,dead, Dispatch Password Requests to Console
              systemd-ask-password-wall.service,loaded,inactive,dead, Forward Password Requests to Wall
              systemd-binfmt.service,loaded,inactive,dead, Set Up Additional Binary Formats
              systemd-fsck-root.service,loaded,active,exited, File System Check on Root Device
              systemd-fsck@dev-disk-by\x2dpartuuid-50fbae26\x2d01.service,loaded,active,exited, File System Check on /dev/disk/by-partuuid/50fbae26-01
              systemd-fsckd.service,loaded,inactive,dead, File System Check Daemon to report status
              systemd-hwdb-update.service,loaded,inactive,dead, Rebuild Hardware Database
              systemd-initctl.service,loaded,inactive,dead, initctl Compatibility Daemon
              systemd-journal-flush.service,loaded,active,exited, Flush Journal to Persistent Storage
              systemd-journald.service,loaded,active,running, Journal Service
              systemd-logind.service,loaded,active,running, Login Service
              systemd-machine-id-commit.service,loaded,inactive,dead, Commit a transient machine-id on disk
              systemd-modules-load.service,loaded,active,exited, Load Kernel Modules
              systemd-networkd.service,loaded,inactive,dead, Network Service
              systemd-quotacheck.service,loaded,inactive,dead, File System Quota Check
              systemd-random-seed.service,loaded,active,exited, Load/Save Random Seed
              systemd-remount-fs.service,loaded,active,exited, Remount Root and Kernel File Systems
              systemd-rfkill.service,loaded,inactive,dead, Load/Save RF Kill Switch Status
              systemd-sysctl.service,loaded,active,exited, Apply Kernel Variables
              systemd-sysusers.service,loaded,active,exited, Create System Users
              systemd-timesyncd.service,loaded,active,running, Network Time Synchronization
              systemd-tmpfiles-clean.service,loaded,inactive,dead, Cleanup of Temporary Directories
              systemd-tmpfiles-setup-dev.service,loaded,active,exited, Create Static Device Nodes in /dev
              systemd-tmpfiles-setup.service,loaded,active,exited, Create Volatile Files and Directories
              systemd-udev-trigger.service,loaded,active,exited, udev Coldplug all Devices
              systemd-udevd.service,loaded,active,running, udev Kernel Device Manager
              systemd-update-done.service,not-found,inactive,dead, systemd-update-done.service
              systemd-update-utmp-runlevel.service,loaded,inactive,dead, Update UTMP about System Runlevel Changes
              systemd-update-utmp.service,loaded,active,exited, Update UTMP about System Boot/Shutdown
              systemd-user-sessions.service,loaded,active,exited, Permit User Sessions
              systemd-vconsole-setup.service,not-found,inactive,dead, systemd-vconsole-setup.service
              triggerhappy.service,loaded,active,running, triggerhappy global hotkey daemon
              user-runtime-dir@1000.service,loaded,active,exited, User Runtime Directory /run/user/1000
              user@1000.service,loaded,active,running, User Manager for UID 1000
              wpa_supplicant.service,loaded,active,running, WPA supplicant
              2020-08-15 16:04:25.669 - debug: linux-control.0 (19029) [servicesInfo] RasPi4 (192.168.138.139:22): csvToJson result: [{"id":"alsa-restore.service","load":"loaded","active":"active","running":"exited","description":"Save/Restore Sound Card State"},{"id":"alsa-state.service","load":"loaded","active":"active","running":"running","description":"Manage Sound Card State (restore and store)"},{"id":"apparmor.service","load":"not-found","active":"inactive","running":"dead","description":"apparmor.service"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"avahi-daemon.service","load":"loaded","active":"active","running":"running","description":"Avahi mDNS/DNS-SD Stack"},{"id":"bluetooth.service","load":"loaded","active":"active","running":"running","description":"Bluetooth service"},{"id":"bthelper@hci0.service","load":"loaded","active":"inactive","running":"dead","description":"Raspberry Pi bluetooth helper"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"dhcpcd.service","load":"loaded","active":"active","running":"running","description":"dhcpcd on all interfaces"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"dphys-swapfile.service","load":"loaded","active":"active","running":"exited","description":"dphys-swapfile - set up","field6":"mount/unmount","field7":"and delete a swap file"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"fake-hwclock.service","load":"loaded","active":"active","running":"exited","description":"Restore / save the current clock"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"hciuart.service","load":"loaded","active":"active","running":"running","description":"Configure Bluetooth Modems connected by UART"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mountkernfs.service","load":"masked","active":"inactive","running":"dead","description":"mountkernfs.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"raspberrypi-net-mods.service","load":"loaded","active":"inactive","running":"dead","description":"Copy user wpa_supplicant.conf"},{"id":"raspi-config.service","load":"loaded","active":"active","running":"exited","description":"LSB: Switch to ondemand cpu governor (unless shift key is pressed)"},{"id":"rc-local.service","load":"loaded","active":"active","running":"exited","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"regenerate_ssh_host_keys.service","load":"loaded","active":"inactive","running":"dead","description":"Regenerate SSH host keys"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rng-tools.service","load":"loaded","active":"active","running":"running","description":"rng-tools.service"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpi-eeprom-update.service","load":"loaded","active":"active","running":"exited","description":"Check for Raspberry Pi EEPROM updates"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"sshswitch.service","load":"loaded","active":"inactive","running":"dead","description":"Turn on SSH if /boot/ssh is present"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"active","running":"exited","description":"File System Check on Root Device"},{"id":"systemd-fsck@dev-disk-by\\x2dpartuuid-50fbae26\\x2d01.service","load":"loaded","active":"active","running":"exited","description":"File System Check on /dev/disk/by-partuuid/50fbae26-01"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-quotacheck.service","load":"loaded","active":"inactive","running":"dead","description":"File System Quota Check"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"triggerhappy.service","load":"loaded","active":"active","running":"running","description":"triggerhappy global hotkey daemon"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"},{"id":"wpa_supplicant.service","load":"loaded","active":"active","running":"running","description":"WPA supplicant"}]
              2020-08-15 16:04:28.974 - debug: linux-control.0 (19029) [needrestart] RasPi4 (192.168.138.139:22): no datapoints selected -> removing existing datapoints
              2020-08-15 16:04:29.018 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'sudo du -sk /opt/iobroker/iobroker-data/history | awk '{ print $1 /1024 }''
              2020-08-15 16:04:29.265 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): response stdout:
              194.051
              2020-08-15 16:04:29.281 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.size: 194.05 MB
              2020-08-15 16:04:29.328 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'sudo find /opt/iobroker/iobroker-data/history -name "*" | wc -l'
              2020-08-15 16:04:29.513 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): response stdout:
              22104
              2020-08-15 16:04:29.515 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.files: 22104 Dateien
              2020-08-15 16:04:29.558 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'tmp=$(sudo find /opt/iobroker/iobroker-data/history -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
              2020-08-15 16:05:00.034 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 25920
              2020-08-15 16:05:04.414 - info: dwd.0 (25920) starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.21.0, js-controller: 3.1.4
              2020-08-15 16:05:08.655 - info: dwd.0 (25920) Terminated (NO_ERROR): Without reason
              2020-08-15 16:05:09.175 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
              2020-08-15 16:06:06.140 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): response stdout:
              1597500265
              2020-08-15 16:06:06.153 - debug: linux-control.0 (19029) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.lastChange: 1597500265000 -> 15.08.2020 16:04
              2020-08-15 16:06:06.199 - debug: linux-control.0 (19029) [userCommand] RasPi4 (192.168.138.139:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
              2020-08-15 16:06:06.217 - debug: linux-control.0 (19029) [userCommand] RasPi4 (192.168.138.139:22, id: root, description: ): response stdout: 19
              2020-08-15 16:06:06.270 - debug: linux-control.0 (19029) [userCommand] RasPi4 (192.168.138.139:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1'
              2020-08-15 16:06:06.297 - debug: linux-control.0 (19029) [userCommand] RasPi4 (192.168.138.139:22, id: ip, description: ): response stdout: 192.168.138.139
              2020-08-15 16:06:06.302 - debug: linux-control.0 (19029) [userCommand] RasPi4 (192.168.138.139:22, id: cpu-temp, description: ): send command: 'vcgencmd measure_temp | awk '{print substr($1, length($0)-5,4)}''
              2020-08-15 16:06:06.318 - debug: linux-control.0 (19029) [userCommand] RasPi4 (192.168.138.139:22, id: cpu-temp, description: ): response stdout: 51.0
              2020-08-15 16:06:06.371 - info: linux-control.0 (19029) successful received data from RasPi4 (192.168.138.139:22)
              2020-08-15 16:06:06.372 - info: linux-control.0 (19029) getting data from NUC_VM (192.168.138.123:22)
              2020-08-15 16:06:06.457 - debug: linux-control.0 (19029) [getConnection] Host 'NUC_VM' (192.168.138.123:22): using sudo for authentification
              2020-08-15 16:06:06.510 - debug: linux-control.0 (19029) [distributionInfo] NUC_VM (192.168.138.123:22): send command: 'cat /etc/os-release'
              2020-08-15 16:06:06.574 - debug: linux-control.0 (19029) [distributionInfo] NUC_VM (192.168.138.123:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
              NAME="Debian GNU/Linux"
              VERSION_ID="10"
              ID=debian
              HOME_URL="https://www.debian.org/"
              SUPPORT_URL="https://www.debian.org/support"
              BUG_REPORT_URL="https://bugs.debian.org/"
              2020-08-15 16:06:06.578 - debug: linux-control.0 (19029) [distributionInfo] NUC_VM (192.168.138.123:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
              2020-08-15 16:06:06.594 - debug: linux-control.0 (19029) [cmdAptUpdate] NUC_VM (192.168.138.123:22): no datapoints selected -> removing existing datapoints
              2020-08-15 16:06:06.598 - debug: linux-control.0 (19029) [servicesInfo] NUC_VM (192.168.138.123:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
              2020-08-15 16:06:06.610 - debug: linux-control.0 (19029) [servicesInfo] NUC_VM (192.168.138.123:22): response stdout: apache2.service,loaded,active,running, The Apache HTTP Server
              apparmor.service,loaded,active,exited, Load AppArmor profiles
              clamav-daemon.service,not-found,inactive,dead, clamav-daemon.service
              cups-browsed.service,loaded,failed,failed, Make remote CUPS printers available locally
              cups.service,loaded,active,running, CUPS Scheduler
              exim4.service,loaded,active,running, LSB: exim Mail Transport Agent
              greylist.service,not-found,inactive,dead, greylist.service
              ifup@ens18.service,loaded,active,exited, ifup for ens18
              irqbalance.service,loaded,active,running, irqbalance daemon
              mysql.service,not-found,inactive,dead, mysql.service
              ntp.service,loaded,active,running, Network Time Service
              postgresql.service,not-found,inactive,dead, postgresql.service
              rc-local.service,loaded,inactive,dead, /etc/rc.local Compatibility
              rpcbind.service,loaded,active,running, RPC bind portmap service
              spamassassin.service,not-found,inactive,dead, spamassassin.service
              systemd-fsck-root.service,loaded,inactive,dead, File System Check on Root Device
              systemd-timesyncd.service,loaded,inactive,dead, Network Time Synchronization
              2020-08-15 16:06:06.615 - debug: linux-control.0 (19029) [servicesInfo] NUC_VM (192.168.138.123:22): csvToJson result: [{"id":"apache2.service","load":"loaded","active":"active","running":"running","description":"The Apache HTTP Server"},{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"avahi-daemon.service","load":"loaded","active":"active","running":"running","description":"Avahi mDNS/DNS-SD Stack"},{"id":"clamav-daemon.service","load":"not-found","active":"inactive","running":"dead","description":"clamav-daemon.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"cups-browsed.service","load":"loaded","active":"failed","running":"failed","description":"Make remote CUPS printers available locally"},{"id":"cups.service","load":"loaded","active":"active","running":"running","description":"CUPS Scheduler"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"exim4.service","load":"loaded","active":"active","running":"running","description":"LSB: exim Mail Transport Agent"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"greylist.service","load":"not-found","active":"inactive","running":"dead","description":"greylist.service"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"ifup@ens18.service","load":"loaded","active":"active","running":"exited","description":"ifup for ens18"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"irqbalance.service","load":"loaded","active":"active","running":"running","description":"irqbalance daemon"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"mysql.service","load":"not-found","active":"inactive","running":"dead","description":"mysql.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"ntp.service","load":"loaded","active":"active","running":"running","description":"Network Time Service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"postgresql.service","load":"not-found","active":"inactive","running":"dead","description":"postgresql.service"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpcbind.service","load":"loaded","active":"active","running":"running","description":"RPC bind portmap service"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"spamassassin.service","load":"not-found","active":"inactive","running":"dead","description":"spamassassin.service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"}]
              2020-08-15 16:06:06.984 - debug: linux-control.0 (19029) [needrestart] NUC_VM (192.168.138.123:22): no datapoints selected -> removing existing datapoints
              2020-08-15 16:06:07.002 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'sudo du -sk /opt/iobroker/iobroker-data/history | awk '{ print $1 /1024 }''
              2020-08-15 16:06:07.316 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): response stdout:
              [sudo] Passwort für pi:
              13499.5
              2020-08-15 16:06:07.319 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.size: NaN MB
              2020-08-15 16:06:07.369 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'sudo find /opt/iobroker/iobroker-data/history -name "*" | wc -l'
              2020-08-15 16:06:07.578 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): response stdout:
              112349
              2020-08-15 16:06:07.581 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.files: NaN Dateien
              2020-08-15 16:06:07.629 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'tmp=$(sudo find /opt/iobroker/iobroker-data/history -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
              2020-08-15 16:06:17.713 - info: web.0 (22824) ==>Connected system.user.admin from ::ffff:192.168.138.145
              2020-08-15 16:06:19.906 - info: web.0 (22824) <==Disconnect system.user.admin from ::ffff:192.168.138.145
              2020-08-15 16:08:25.229 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): response stdout:
              1597500492
              2020-08-15 16:08:25.232 - debug: linux-control.0 (19029) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.lastChange: NaN ->
              2020-08-15 16:08:25.279 - debug: linux-control.0 (19029) [userCommand] NUC_VM (192.168.138.123:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
              2020-08-15 16:08:25.291 - debug: linux-control.0 (19029) [userCommand] NUC_VM (192.168.138.123:22, id: root, description: ): response stdout: 55
              2020-08-15 16:08:25.314 - debug: linux-control.0 (19029) [userCommand] NUC_VM (192.168.138.123:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1'
              2020-08-15 16:08:25.323 - debug: linux-control.0 (19029) [userCommand] NUC_VM (192.168.138.123:22, id: ip, description: ): response stdout: 192.168.138.123
              2020-08-15 16:08:25.371 - debug: linux-control.0 (19029) [userCommand] NUC_VM (192.168.138.123:22): datapoint-id: 'cpu-temp', description: '' -> is not enabled!
              2020-08-15 16:08:25.371 - debug: linux-control.0 (19029) [userCommand] NUC_VM (192.168.138.123:22, id: Ordner, description: ): send command: 'du -c /opt/iobroker/iobroker-data/history | tail -1 | awk '{printf $1MB}''
              2020-08-15 16:08:25.671 - debug: linux-control.0 (19029) [userCommand] NUC_VM (192.168.138.123:22, id: Ordner, description: ): response stdout: 13823576
              2020-08-15 16:08:25.676 - info: linux-control.0 (19029) successful received data from NUC_VM (192.168.138.123:22)
              2020-08-15 16:08:25.676 - info: linux-control.0 (19029) getting data from Tinker (192.168.138.74:22)
              2020-08-15 16:08:25.742 - debug: linux-control.0 (19029) [getConnection] Host 'Tinker' (192.168.138.74:22): using sudo for authentification
              2020-08-15 16:08:25.970 - debug: linux-control.0 (19029) [distributionInfo] Tinker (192.168.138.74:22): send command: 'cat /etc/os-release'
              2020-08-15 16:08:26.280 - debug: linux-control.0 (19029) [distributionInfo] Tinker (192.168.138.74:22): response stdout: NAME="Ubuntu"
              VERSION="18.04.4 LTS (Bionic Beaver)"
              ID=ubuntu
              ID_LIKE=debian
              PRETTY_NAME="Ubuntu 18.04.4 LTS"
              VERSION_ID="18.04"
              HOME_URL="https://www.ubuntu.com/"
              SUPPORT_URL="https://help.ubuntu.com/"
              BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
              PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
              VERSION_CODENAME=bionic
              UBUNTU_CODENAME=bionic
              2020-08-15 16:08:26.285 - debug: linux-control.0 (19029) [distributionInfo] Tinker (192.168.138.74:22): csvToJson result: [{"prop":"NAME","val":"Ubuntu"},{"prop":"VERSION","val":"18.04.4 LTS (Bionic Beaver)"},{"prop":"ID","val":"ubuntu"},{"prop":"ID_LIKE","val":"debian"},{"prop":"PRETTY_NAME","val":"Ubuntu 18.04.4 LTS"},{"prop":"VERSION_ID","val":"18.04"},{"prop":"HOME_URL","val":"https://www.ubuntu.com/"},{"prop":"SUPPORT_URL","val":"https://help.ubuntu.com/"},{"prop":"BUG_REPORT_URL","val":"https://bugs.launchpad.net/ubuntu/"},{"prop":"PRIVACY_POLICY_URL","val":"https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"},{"prop":"VERSION_CODENAME","val":"bionic"},{"prop":"UBUNTU_CODENAME","val":"bionic"}]
              2020-08-15 16:08:26.362 - debug: linux-control.0 (19029) [cmdAptUpdate] Tinker (192.168.138.74:22): no datapoints selected -> removing existing datapoints
              2020-08-15 16:08:26.369 - debug: linux-control.0 (19029) [servicesInfo] Tinker (192.168.138.74:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
              2020-08-15 16:08:26.391 - debug: linux-control.0 (19029) [servicesInfo] Tinker (192.168.138.74:22): response stdout: alsa-restore.service,loaded,active,exited, Save/Restore Sound Card State
              alsa-state.service,loaded,inactive,dead, Manage Sound Card State (restore and store)
              armbian-firstrun-config.service,loaded,inactive,dead, Armbian first run optional user configuration
              armbian-hardware-monitor.service,loaded,active,exited, Armbian hardware monitoring
              armbian-hardware-optimize.service,loaded,active,exited, Armbian hardware optimization
              armbian-ramlog.service,loaded,active,exited, Armbian memory supported logging
              armbian-zram-config.service,loaded,active,exited, Armbian ZRAM config
              armian-ramlog.service,not-found,inactive,dead, armian-ramlog.service
              chrony.service,loaded,active,running, chrony, an NTP client/server
              cpufrequtils.service,loaded,active,exited, LSB: set CPUFreq kernel parameters
              fstrim.service,loaded,inactive,dead, Discard unused blocks
              haveged.service,loaded,active,running, Entropy daemon using the HAVEGE algorithm
              hostapd.service,loaded,active,exited, LSB: Advanced IEEE 802.11 management daemon
              loadcpufreq.service,loaded,active,exited, LSB: Load kernel modules needed to enable cpufreq scaling
              motd-news.service,loaded,inactive,dead, Message of the Day
              networkd-dispatcher.service,loaded,active,running, Dispatcher daemon for systemd-networkd
              NetworkManager-wait-online.service,loaded,active,exited, Network Manager Wait Online
              NetworkManager.service,loaded,active,running, Network Manager
              ondemand.service,masked,inactive,dead, ondemand.service
              openntpd.service,not-found,inactive,dead, openntpd.service
              polkit.service,loaded,active,running, Authorization Manager
              resolvconf-pull-resolved.service,loaded,inactive,dead, resolvconf-pull-resolved.service
              resolvconf.service,loaded,active,exited, Nameserver information manager
              serial-getty@ttyS2.service,loaded,active,running, Serial Getty on ttyS2
              setvtrgb.service,loaded,active,exited, Set console scheme
              sysfsutils.service,loaded,active,exited, LSB: Set sysfs variables from /etc/sysfs.conf
              sysstat.service,loaded,active,exited, Resets System Activity Data Collector
              systemd-initctl.service,loaded,inactive,dead, /dev/initctl Compatibility Daemon
              systemd-resolved.service,loaded,active,running, Network Name Resolution
              systemd-sysusers.service,not-found,inactive,dead, systemd-sysusers.service
              tinker-bluetooth.service,loaded,active,running, Realtek H5 bluetooth support
              unattended-upgrades.service,loaded,active,running, Unattended Upgrades Shutdown
              user@1002.service,loaded,active,running, User Manager for UID 1002
              2020-08-15 16:08:26.403 - debug: linux-control.0 (19029) [servicesInfo] Tinker (192.168.138.74:22): csvToJson result: [{"id":"alsa-restore.service","load":"loaded","active":"active","running":"exited","description":"Save/Restore Sound Card State"},{"id":"alsa-state.service","load":"loaded","active":"inactive","running":"dead","description":"Manage Sound Card State (restore and store)"},{"id":"apparmor.service","load":"not-found","active":"inactive","running":"dead","description":"apparmor.service"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"armbian-firstrun-config.service","load":"loaded","active":"inactive","running":"dead","description":"Armbian first run optional user configuration"},{"id":"armbian-hardware-monitor.service","load":"loaded","active":"active","running":"exited","description":"Armbian hardware monitoring"},{"id":"armbian-hardware-optimize.service","load":"loaded","active":"active","running":"exited","description":"Armbian hardware optimization"},{"id":"armbian-ramlog.service","load":"loaded","active":"active","running":"exited","description":"Armbian memory supported logging"},{"id":"armbian-zram-config.service","load":"loaded","active":"active","running":"exited","description":"Armbian ZRAM config"},{"id":"armian-ramlog.service","load":"not-found","active":"inactive","running":"dead","description":"armian-ramlog.service"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"bluetooth.service","load":"loaded","active":"active","running":"running","description":"Bluetooth service"},{"id":"chrony.service","load":"loaded","active":"active","running":"running","description":"chrony","field6":"an NTP client/server"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cpufrequtils.service","load":"loaded","active":"active","running":"exited","description":"LSB: set CPUFreq kernel parameters"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"fake-hwclock.service","load":"loaded","active":"active","running":"exited","description":"Restore / save the current clock"},{"id":"fstrim.service","load":"loaded","active":"inactive","running":"dead","description":"Discard unused blocks"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"haveged.service","load":"loaded","active":"active","running":"running","description":"Entropy daemon using the HAVEGE algorithm"},{"id":"hostapd.service","load":"loaded","active":"active","running":"exited","description":"LSB: Advanced IEEE 802.11 management daemon"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"loadcpufreq.service","load":"loaded","active":"active","running":"exited","description":"LSB: Load kernel modules needed to enable cpufreq scaling"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"motd-news.service","load":"loaded","active":"inactive","running":"dead","description":"Message of the Day"},{"id":"mountkernfs.service","load":"masked","active":"inactive","running":"dead","description":"mountkernfs.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networkd-dispatcher.service","load":"loaded","active":"active","running":"running","description":"Dispatcher daemon for systemd-networkd"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager-wait-online.service","load":"loaded","active":"active","running":"exited","description":"Network Manager Wait Online"},{"id":"NetworkManager.service","load":"loaded","active":"active","running":"running","description":"Network Manager"},{"id":"ondemand.service","load":"masked","active":"inactive","running":"dead","description":"ondemand.service"},{"id":"openntpd.service","load":"not-found","active":"inactive","running":"dead","description":"openntpd.service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"polkit.service","load":"loaded","active":"active","running":"running","description":"Authorization Manager"},{"id":"rc-local.service","load":"loaded","active":"active","running":"exited","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"resolvconf-pull-resolved.service","load":"loaded","active":"inactive","running":"dead","description":"resolvconf-pull-resolved.service"},{"id":"resolvconf.service","load":"loaded","active":"active","running":"exited","description":"Nameserver information manager"},{"id":"rng-tools.service","load":"loaded","active":"active","running":"running","description":"rng-tools.service"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"serial-getty@ttyS2.service","load":"loaded","active":"active","running":"running","description":"Serial Getty on ttyS2"},{"id":"setvtrgb.service","load":"loaded","active":"active","running":"exited","description":"Set console scheme"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"sysfsutils.service","load":"loaded","active":"active","running":"exited","description":"LSB: Set sysfs variables from /etc/sysfs.conf"},{"id":"sysstat.service","load":"loaded","active":"active","running":"exited","description":"Resets System Activity Data Collector"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"/dev/initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-resolved.service","load":"loaded","active":"active","running":"running","description":"Network Name Resolution"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-sysusers.service"},{"id":"systemd-timesyncd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"tinker-bluetooth.service","load":"loaded","active":"active","running":"running","description":"Realtek H5 bluetooth support"},{"id":"unattended-upgrades.service","load":"loaded","active":"active","running":"running","description":"Unattended Upgrades Shutdown"},{"id":"user@1002.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1002"},{"id":"wpa_supplicant.service","load":"loaded","active":"active","running":"running","description":"WPA supplicant"}]
              2020-08-15 16:08:26.816 - debug: linux-control.0 (19029) [needrestart] Tinker (192.168.138.74:22): no datapoints selected -> removing existing datapoints
              2020-08-15 16:08:26.837 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): send command: 'sudo du -sk /opt/iobroker/iobroker-data | awk '{ print $1 /1024 }''
              2020-08-15 16:08:26.904 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): response stdout:
              Sorry, user pi is not allowed to execute '/usr/bin/du -sk /opt/iobroker/iobroker-data' as root on localhost.
              2020-08-15 16:08:26.906 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.size: NaN MB
              2020-08-15 16:08:26.948 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): send command: 'sudo find /opt/iobroker/iobroker-data -name "*" | wc -l'
              2020-08-15 16:08:27.154 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): response stdout:
              Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name *' as root on localhost.
              0
              2020-08-15 16:08:27.157 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.files: NaN Dateien
              2020-08-15 16:08:27.208 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): send command: 'tmp=$(sudo find /opt/iobroker/iobroker-data -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}') && date +%s -r $tmp'
              2020-08-15 16:08:27.315 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): response stdout:
              Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name * -type f -exec stat -c %Y %n -- {} ;' as root on localhost.
              date: option requires an argument -- 'r'
              Try 'date --help' for more information.
              2020-08-15 16:08:27.318 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.lastChange: NaN ->
              2020-08-15 16:08:27.369 - debug: linux-control.0 (19029) [userCommand] Tinker (192.168.138.74:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
              2020-08-15 16:08:27.415 - debug: linux-control.0 (19029) [userCommand] Tinker (192.168.138.74:22, id: root, description: ): response stdout: 5
              2020-08-15 16:08:27.423 - debug: linux-control.0 (19029) [userCommand] Tinker (192.168.138.74:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1'
              2020-08-15 16:08:27.467 - debug: linux-control.0 (19029) [userCommand] Tinker (192.168.138.74:22, id: ip, description: ): response stdout: 192.168.138.74
              2020-08-15 16:08:27.476 - debug: linux-control.0 (19029) [userCommand] Tinker (192.168.138.74:22, id: cpu-temp, description: ): send command: 'cat /sys/devices/virtual/thermal/thermal_zone0/temp | awk '{print substr($1, length($0)-5,3)}''
              2020-08-15 16:08:27.519 - debug: linux-control.0 (19029) [userCommand] Tinker (192.168.138.74:22, id: cpu-temp, description: ): response stdout: 46
              2020-08-15 16:08:27.527 - info: linux-control.0 (19029) successful received data from Tinker (192.168.138.74:22)
              scheint ein seltsames Problem mit dem Passwort bei sudo zu sein.
              Beim Raspi kann man auch auf der Konsole Befehle mit sudo ohne weitere Passworteingabe durchführen. das geht weder beim Tinker (Armbian) noch beim der VM (Debian)
              seltsamerweise funktioniert es aber bei "meine Befehle".
              bei der NUC_VM habe ich den gleichen Befehl (du -c /opt/iobroker/iobroker-data/history | tail -1 | awk '{printf $1MB}') nochmals unter "eigene Befehle" ausgeführt:
              da klappt es:
              • Scrounger
                Scrounger Developer @Homoran last edited by
                @Homoran
                Hab noch was eingebaut, bitte teste mal die aktuelle github version
                  Homoran Global Moderator Administrators @Scrounger last edited by
                  @Scrounger sagte in Test Adapter Linux Control v0.x.x:
                  @Homoran
                  Habe neu installiert - upload gemacht und Instanz sicherheitshalber nochmal gestartet.
                  steht immer noch null drin
                  Hier das leider sehr umfangreiche debug log:
                  2020-08-16 10:37:56.204  - info: linux-control.0 (24751) getting data from RasPi4 (192.168.138.139:22)
                  2020-08-16 10:37:56.257  - debug: linux-control.0 (24751) [getConnection] Host 'RasPi4' (192.168.138.139:22): using sudo for authentification
                  2020-08-16 10:37:56.428  - debug: linux-control.0 (24751) [distributionInfo] RasPi4 (192.168.138.139:22): send command: 'cat /etc/os-release'
                  2020-08-16 10:37:56.732  - debug: linux-control.0 (24751) [distributionInfo] RasPi4 (192.168.138.139:22): response stdout: PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                  NAME="Raspbian GNU/Linux"
                  VERSION_ID="10"
                  VERSION="10 (buster)"
                  VERSION_CODENAME=buster
                  ID=raspbian
                  ID_LIKE=debian
                  HOME_URL="http://www.raspbian.org/"
                  SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                  BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                  2020-08-16 10:37:56.735  - debug: linux-control.0 (24751) [distributionInfo] RasPi4 (192.168.138.139:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Raspbian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Raspbian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"raspbian"},{"prop":"ID_LIKE","val":"debian"},{"prop":"HOME_URL","val":"http://www.raspbian.org/"},{"prop":"SUPPORT_URL","val":"http://www.raspbian.org/RaspbianForums"},{"prop":"BUG_REPORT_URL","val":"http://www.raspbian.org/RaspbianBugs"}]
                  2020-08-16 10:37:56.752  - debug: linux-control.0 (24751) [cmdAptUpdate] RasPi4 (192.168.138.139:22): no datapoints selected -> removing existing datapoints
                  2020-08-16 10:37:56.755  - debug: linux-control.0 (24751) [servicesInfo] RasPi4 (192.168.138.139:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
                  2020-08-16 10:37:56.780  - debug: linux-control.0 (24751) [servicesInfo] RasPi4 (192.168.138.139:22): response stdout: alsa-restore.service,loaded,active,exited, Save/Restore Sound Card State
                  alsa-state.service,loaded,active,running, Manage Sound Card State (restore and store)
                  apparmor.service,not-found,inactive,dead, apparmor.service
                  apt-daily-upgrade.service,loaded,inactive,dead, Daily apt upgrade and clean activities
                  apt-daily.service,loaded,inactive,dead, Daily apt download activities
                  auditd.service,not-found,inactive,dead, auditd.service
                  auth-rpcgss-module.service,loaded,inactive,dead, Kernel Module supporting RPCSEC_GSS
                  avahi-daemon.service,loaded,active,running, Avahi mDNS/DNS-SD Stack
                  bluetooth.service,loaded,active,running, Bluetooth service
                  bthelper@hci0.service,loaded,inactive,dead, Raspberry Pi bluetooth helper
                  connman.service,not-found,inactive,dead, connman.service
                  console-screen.service,not-found,inactive,dead, console-screen.service
                  console-setup.service,loaded,active,exited, Set console font and keymap
                  cron.service,loaded,active,running, Regular background program processing daemon
                  dbus.service,loaded,active,running, D-Bus System Message Bus
                  dhcpcd.service,loaded,active,running, dhcpcd on all interfaces
                  display-manager.service,not-found,inactive,dead, display-manager.service
                  dphys-swapfile.service,loaded,active,exited, dphys-swapfile - set up, mount/unmount, and delete a swap file
                  emergency.service,loaded,inactive,dead, Emergency Shell
                  fake-hwclock.service,loaded,active,exited, Restore / save the current clock
                  getty-static.service,loaded,inactive,dead, getty on tty2-tty6 if dbus and logind are not available
                  getty@tty1.service,loaded,active,running, Getty on tty1
                  gssproxy.service,not-found,inactive,dead, gssproxy.service
                  hciuart.service,loaded,active,running, Configure Bluetooth Modems connected by UART
                  ifupdown-pre.service,loaded,active,exited, Helper to synchronize boot up for ifupdown
                  influxdb.service,not-found,inactive,dead, influxdb.service
                  iobroker.service,loaded,active,running, ioBroker Server
                  kbd.service,not-found,inactive,dead, kbd.service
                  keyboard-setup.service,loaded,active,exited, Set the console keyboard layout
                  kmod-static-nodes.service,loaded,active,exited, Create list of required static device nodes for the current kernel
                  logrotate.service,loaded,inactive,dead, Rotate log files
                  man-db.service,loaded,inactive,dead, Daily man-db regeneration
                  mariadb-server.service,not-found,inactive,dead, mariadb-server.service
                  mountkernfs.service,masked,inactive,dead, mountkernfs.service
                  mysql-server.service,not-found,inactive,dead, mysql-server.service
                  networking.service,loaded,active,exited, Raise network interfaces
                  NetworkManager.service,not-found,inactive,dead, NetworkManager.service
                  nfs-blkmap.service,not-found,inactive,dead, nfs-blkmap.service
                  nfs-config.service,loaded,inactive,dead, Preprocess NFS configuration
                  nfs-server.service,not-found,inactive,dead, nfs-server.service
                  nfs-utils.service,loaded,inactive,dead, NFS server and client services
                  plymouth-quit-wait.service,not-found,inactive,dead, plymouth-quit-wait.service
                  plymouth-start.service,not-found,inactive,dead, plymouth-start.service
                  raspberrypi-net-mods.service,loaded,inactive,dead, Copy user wpa_supplicant.conf
                  raspi-config.service,loaded,active,exited, LSB: Switch to ondemand cpu governor (unless shift key is pressed)
                  rc-local.service,loaded,active,exited, /etc/rc.local Compatibility
                  redis.service,not-found,inactive,dead, redis.service
                  regenerate_ssh_host_keys.service,loaded,inactive,dead, Regenerate SSH host keys
                  rescue.service,loaded,inactive,dead, Rescue Shell
                  rng-tools.service,loaded,active,running, rng-tools.service
                  rpc-gssd.service,loaded,inactive,dead, RPC security service for NFS client and server
                  rpc-svcgssd.service,loaded,inactive,dead, RPC security service for NFS server
                  rpi-eeprom-update.service,loaded,active,exited, Check for Raspberry Pi EEPROM updates
                  rsync.service,loaded,inactive,dead, fast remote file copy program daemon
                  rsyslog.service,loaded,active,running, System Logging Service
                  ssh.service,loaded,active,running, OpenBSD Secure Shell server
                  sshswitch.service,loaded,inactive,dead, Turn on SSH if /boot/ssh is present
                  systemd-ask-password-console.service,loaded,inactive,dead, Dispatch Password Requests to Console
                  systemd-ask-password-wall.service,loaded,inactive,dead, Forward Password Requests to Wall
                  systemd-binfmt.service,loaded,inactive,dead, Set Up Additional Binary Formats
                  systemd-fsck-root.service,loaded,active,exited, File System Check on Root Device
                  systemd-fsck@dev-disk-by\x2dpartuuid-50fbae26\x2d01.service,loaded,active,exited, File System Check on /dev/disk/by-partuuid/50fbae26-01
                  systemd-fsckd.service,loaded,inactive,dead, File System Check Daemon to report status
                  systemd-hwdb-update.service,loaded,inactive,dead, Rebuild Hardware Database
                  systemd-initctl.service,loaded,inactive,dead, initctl Compatibility Daemon
                  systemd-journal-flush.service,loaded,active,exited, Flush Journal to Persistent Storage
                  systemd-journald.service,loaded,active,running, Journal Service
                  systemd-logind.service,loaded,active,running, Login Service
                  systemd-machine-id-commit.service,loaded,inactive,dead, Commit a transient machine-id on disk
                  systemd-modules-load.service,loaded,active,exited, Load Kernel Modules
                  systemd-networkd.service,loaded,inactive,dead, Network Service
                  systemd-quotacheck.service,loaded,inactive,dead, File System Quota Check
                  systemd-random-seed.service,loaded,active,exited, Load/Save Random Seed
                  systemd-remount-fs.service,loaded,active,exited, Remount Root and Kernel File Systems
                  systemd-rfkill.service,loaded,inactive,dead, Load/Save RF Kill Switch Status
                  systemd-sysctl.service,loaded,active,exited, Apply Kernel Variables
                  systemd-sysusers.service,loaded,active,exited, Create System Users
                  systemd-timesyncd.service,loaded,active,running, Network Time Synchronization
                  systemd-tmpfiles-clean.service,loaded,inactive,dead, Cleanup of Temporary Directories
                  systemd-tmpfiles-setup-dev.service,loaded,active,exited, Create Static Device Nodes in /dev
                  systemd-tmpfiles-setup.service,loaded,active,exited, Create Volatile Files and Directories
                  systemd-udev-trigger.service,loaded,active,exited, udev Coldplug all Devices
                  systemd-udevd.service,loaded,active,running, udev Kernel Device Manager
                  systemd-update-done.service,not-found,inactive,dead, systemd-update-done.service
                  systemd-update-utmp-runlevel.service,loaded,inactive,dead, Update UTMP about System Runlevel Changes
                  systemd-update-utmp.service,loaded,active,exited, Update UTMP about System Boot/Shutdown
                  systemd-user-sessions.service,loaded,active,exited, Permit User Sessions
                  systemd-vconsole-setup.service,not-found,inactive,dead, systemd-vconsole-setup.service
                  triggerhappy.service,loaded,active,running, triggerhappy global hotkey daemon
                  user-runtime-dir@1000.service,loaded,active,exited, User Runtime Directory /run/user/1000
                  user@1000.service,loaded,active,running, User Manager for UID 1000
                  wpa_supplicant.service,loaded,active,running, WPA supplicant
                  2020-08-16 10:37:56.785  - debug: linux-control.0 (24751) [servicesInfo] RasPi4 (192.168.138.139:22): csvToJson result: [{"id":"alsa-restore.service","load":"loaded","active":"active","running":"exited","description":"Save/Restore Sound Card State"},{"id":"alsa-state.service","load":"loaded","active":"active","running":"running","description":"Manage Sound Card State (restore and store)"},{"id":"apparmor.service","load":"not-found","active":"inactive","running":"dead","description":"apparmor.service"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"avahi-daemon.service","load":"loaded","active":"active","running":"running","description":"Avahi mDNS/DNS-SD Stack"},{"id":"bluetooth.service","load":"loaded","active":"active","running":"running","description":"Bluetooth service"},{"id":"bthelper@hci0.service","load":"loaded","active":"inactive","running":"dead","description":"Raspberry Pi bluetooth helper"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"dhcpcd.service","load":"loaded","active":"active","running":"running","description":"dhcpcd on all interfaces"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"dphys-swapfile.service","load":"loaded","active":"active","running":"exited","description":"dphys-swapfile - set up","field6":"mount/unmount","field7":"and delete a swap file"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"fake-hwclock.service","load":"loaded","active":"active","running":"exited","description":"Restore / save the current clock"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"hciuart.service","load":"loaded","active":"active","running":"running","description":"Configure Bluetooth Modems connected by UART"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mountkernfs.service","load":"masked","active":"inactive","running":"dead","description":"mountkernfs.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"raspberrypi-net-mods.service","load":"loaded","active":"inactive","running":"dead","description":"Copy user wpa_supplicant.conf"},{"id":"raspi-config.service","load":"loaded","active":"active","running":"exited","description":"LSB: Switch to ondemand cpu governor (unless shift key is pressed)"},{"id":"rc-local.service","load":"loaded","active":"active","running":"exited","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"regenerate_ssh_host_keys.service","load":"loaded","active":"inactive","running":"dead","description":"Regenerate SSH host keys"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rng-tools.service","load":"loaded","active":"active","running":"running","description":"rng-tools.service"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpi-eeprom-update.service","load":"loaded","active":"active","running":"exited","description":"Check for Raspberry Pi EEPROM updates"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"sshswitch.service","load":"loaded","active":"inactive","running":"dead","description":"Turn on SSH if /boot/ssh is present"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"active","running":"exited","description":"File System Check on Root Device"},{"id":"systemd-fsck@dev-disk-by\\x2dpartuuid-50fbae26\\x2d01.service","load":"loaded","active":"active","running":"exited","description":"File System Check on /dev/disk/by-partuuid/50fbae26-01"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-quotacheck.service","load":"loaded","active":"inactive","running":"dead","description":"File System Quota Check"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"triggerhappy.service","load":"loaded","active":"active","running":"running","description":"triggerhappy global hotkey daemon"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"},{"id":"wpa_supplicant.service","load":"loaded","active":"active","running":"running","description":"WPA supplicant"}]
                  2020-08-16 10:37:57.213  - debug: linux-control.0 (24751) [needrestart] RasPi4 (192.168.138.139:22): no datapoints selected -> removing existing datapoints
                  2020-08-16 10:37:57.231  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'sudo du -sk /opt/iobroker/iobroker-data/history | awk '{ print $1 /1024 }' | tail -1'
                  2020-08-16 10:37:57.464  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): response stdout:
                  195.422
                  2020-08-16 10:37:57.466  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.size: 195.42 MB
                  2020-08-16 10:37:57.469  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'sudo find /opt/iobroker/iobroker-data/history -name "*" | wc -l | tail -1'
                  2020-08-16 10:37:57.674  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): response stdout:
                  22286
                  2020-08-16 10:37:57.675  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.files: 22286 Dateien
                  2020-08-16 10:37:57.679  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'tmp=$(sudo find /opt/iobroker/iobroker-data/history -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}' | tail -1) && date +%s -r $tmp'
                  2020-08-16 10:39:35.043  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): response stdout:
                  1597567063
                  2020-08-16 10:39:35.044  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.lastChange: 1597567063000 -> 16.08.2020 10:37
                  2020-08-16 10:39:35.048  - debug: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
                  2020-08-16 10:39:35.066  - debug: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: root, description: ): response stdout: 19
                  2020-08-16 10:39:35.070  - debug: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1'
                  2020-08-16 10:39:35.091  - debug: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: ip, description: ): response stdout: 192.168.138.139
                  2020-08-16 10:39:35.096  - debug: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: cpu-temp, description: ): send command: 'vcgencmd measure_temp | awk '{print substr($1, length($0)-5,4)}''
                  2020-08-16 10:39:35.112  - debug: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: cpu-temp, description: ): response stdout: 55.0
                  2020-08-16 10:39:35.117  - info: linux-control.0 (24751) successful received data from RasPi4 (192.168.138.139:22)
                  2020-08-16 10:40:00.035  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 5509
                  2020-08-16 10:40:03.867  - info: dwd.0 (5509) starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.21.0, js-controller: 3.1.4
                  2020-08-16 10:40:05.425  - info: dwd.0 (5509) Terminated (NO_ERROR): Without reason
                  2020-08-16 10:40:05.952  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
                  2020-08-16 10:40:20.852  - info: linux-control.0 (24751) getting data from NUC_VM (192.168.138.123:22)
                  2020-08-16 10:40:20.886  - debug: linux-control.0 (24751) [getConnection] Host 'NUC_VM' (192.168.138.123:22): using sudo for authentification
                  2020-08-16 10:40:20.969  - debug: linux-control.0 (24751) [distributionInfo] NUC_VM (192.168.138.123:22): send command: 'cat /etc/os-release'
                  2020-08-16 10:40:21.025  - debug: linux-control.0 (24751) [distributionInfo] NUC_VM (192.168.138.123:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
                  NAME="Debian GNU/Linux"
                  VERSION_ID="10"
                  ID=debian
                  HOME_URL="https://www.debian.org/"
                  SUPPORT_URL="https://www.debian.org/support"
                  BUG_REPORT_URL="https://bugs.debian.org/"
                  2020-08-16 10:40:21.028  - debug: linux-control.0 (24751) [distributionInfo] NUC_VM (192.168.138.123:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
                  2020-08-16 10:40:21.045  - debug: linux-control.0 (24751) [cmdAptUpdate] NUC_VM (192.168.138.123:22): no datapoints selected -> removing existing datapoints
                  2020-08-16 10:40:21.049  - debug: linux-control.0 (24751) [servicesInfo] NUC_VM (192.168.138.123:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
                  2020-08-16 10:40:21.060  - debug: linux-control.0 (24751) [servicesInfo] NUC_VM (192.168.138.123:22): response stdout: apache2.service,loaded,active,running, The Apache HTTP Server
                  apparmor.service,loaded,active,exited, Load AppArmor profiles
                  clamav-daemon.service,not-found,inactive,dead, clamav-daemon.service
                  cups-browsed.service,loaded,failed,failed, Make remote CUPS printers available locally
                  cups.service,loaded,active,running, CUPS Scheduler
                  exim4.service,loaded,active,running, LSB: exim Mail Transport Agent
                  greylist.service,not-found,inactive,dead, greylist.service
                  ifup@ens18.service,loaded,active,exited, ifup for ens18
                  irqbalance.service,loaded,active,running, irqbalance daemon
                  mysql.service,not-found,inactive,dead, mysql.service
                  ntp.service,loaded,active,running, Network Time Service
                  postgresql.service,not-found,inactive,dead, postgresql.service
                  rc-local.service,loaded,inactive,dead, /etc/rc.local Compatibility
                  rpcbind.service,loaded,active,running, RPC bind portmap service
                  spamassassin.service,not-found,inactive,dead, spamassassin.service
                  systemd-fsck-root.service,loaded,inactive,dead, File System Check on Root Device
                  systemd-timesyncd.service,loaded,inactive,dead, Network Time Synchronization
                  2020-08-16 10:40:21.065  - debug: linux-control.0 (24751) [servicesInfo] NUC_VM (192.168.138.123:22): csvToJson result: [{"id":"apache2.service","load":"loaded","active":"active","running":"running","description":"The Apache HTTP Server"},{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"avahi-daemon.service","load":"loaded","active":"active","running":"running","description":"Avahi mDNS/DNS-SD Stack"},{"id":"clamav-daemon.service","load":"not-found","active":"inactive","running":"dead","description":"clamav-daemon.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"cups-browsed.service","load":"loaded","active":"failed","running":"failed","description":"Make remote CUPS printers available locally"},{"id":"cups.service","load":"loaded","active":"active","running":"running","description":"CUPS Scheduler"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"exim4.service","load":"loaded","active":"active","running":"running","description":"LSB: exim Mail Transport Agent"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"greylist.service","load":"not-found","active":"inactive","running":"dead","description":"greylist.service"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"ifup@ens18.service","load":"loaded","active":"active","running":"exited","description":"ifup for ens18"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"irqbalance.service","load":"loaded","active":"active","running":"running","description":"irqbalance daemon"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"mysql.service","load":"not-found","active":"inactive","running":"dead","description":"mysql.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"ntp.service","load":"loaded","active":"active","running":"running","description":"Network Time Service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"postgresql.service","load":"not-found","active":"inactive","running":"dead","description":"postgresql.service"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpcbind.service","load":"loaded","active":"active","running":"running","description":"RPC bind portmap service"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"spamassassin.service","load":"not-found","active":"inactive","running":"dead","description":"spamassassin.service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"}]
                  2020-08-16 10:40:21.427  - debug: linux-control.0 (24751) [needrestart] NUC_VM (192.168.138.123:22): no datapoints selected -> removing existing datapoints
                  2020-08-16 10:40:21.440  - debug: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'sudo du -sk /opt/iobroker/iobroker-data/history | awk '{ print $1 /1024 }' | tail -1'
                  2020-08-16 10:40:21.766  - debug: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): response stdout:
                  [sudo] Passwort für pi:
                  13533.4
                  2020-08-16 10:40:21.768  - debug: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.size: NaN MB
                  2020-08-16 10:40:21.772  - debug: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'sudo find /opt/iobroker/iobroker-data/history -name "*" | wc -l | tail -1'
                  2020-08-16 10:40:22.085  - debug: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): response stdout:
                  112764
                  2020-08-16 10:40:22.086  - debug: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.files: NaN Dateien
                  2020-08-16 10:40:22.089  - debug: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'tmp=$(sudo find /opt/iobroker/iobroker-data/history -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}' | tail -1) && date +%s -r $tmp'
                  2020-08-16 10:40:22.686  - info: linux-control.0 (24751) getting data from Tinker (192.168.138.74:22)
                  2020-08-16 10:40:22.719  - debug: linux-control.0 (24751) [getConnection] Host 'Tinker' (192.168.138.74:22): using sudo for authentification
                  2020-08-16 10:40:22.825  - debug: linux-control.0 (24751) [distributionInfo] Tinker (192.168.138.74:22): send command: 'cat /etc/os-release'
                  2020-08-16 10:40:23.123  - debug: linux-control.0 (24751) [distributionInfo] Tinker (192.168.138.74:22): response stdout: NAME="Ubuntu"
                  VERSION="18.04.4 LTS (Bionic Beaver)"
                  ID=ubuntu
                  ID_LIKE=debian
                  PRETTY_NAME="Ubuntu 18.04.4 LTS"
                  VERSION_ID="18.04"
                  HOME_URL="https://www.ubuntu.com/"
                  SUPPORT_URL="https://help.ubuntu.com/"
                  BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
                  PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
                  VERSION_CODENAME=bionic
                  UBUNTU_CODENAME=bionic
                  2020-08-16 10:40:23.127  - debug: linux-control.0 (24751) [distributionInfo] Tinker (192.168.138.74:22): csvToJson result: [{"prop":"NAME","val":"Ubuntu"},{"prop":"VERSION","val":"18.04.4 LTS (Bionic Beaver)"},{"prop":"ID","val":"ubuntu"},{"prop":"ID_LIKE","val":"debian"},{"prop":"PRETTY_NAME","val":"Ubuntu 18.04.4 LTS"},{"prop":"VERSION_ID","val":"18.04"},{"prop":"HOME_URL","val":"https://www.ubuntu.com/"},{"prop":"SUPPORT_URL","val":"https://help.ubuntu.com/"},{"prop":"BUG_REPORT_URL","val":"https://bugs.launchpad.net/ubuntu/"},{"prop":"PRIVACY_POLICY_URL","val":"https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"},{"prop":"VERSION_CODENAME","val":"bionic"},{"prop":"UBUNTU_CODENAME","val":"bionic"}]
                  2020-08-16 10:40:23.152  - debug: linux-control.0 (24751) [cmdAptUpdate] Tinker (192.168.138.74:22): no datapoints selected -> removing existing datapoints
                  2020-08-16 10:40:23.155  - debug: linux-control.0 (24751) [servicesInfo] Tinker (192.168.138.74:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
                  2020-08-16 10:40:23.178  - debug: linux-control.0 (24751) [servicesInfo] Tinker (192.168.138.74:22): response stdout: alsa-restore.service,loaded,active,exited, Save/Restore Sound Card State
                  alsa-state.service,loaded,inactive,dead, Manage Sound Card State (restore and store)
                  armbian-firstrun-config.service,loaded,inactive,dead, Armbian first run optional user configuration
                  armbian-hardware-monitor.service,loaded,active,exited, Armbian hardware monitoring
                  armbian-hardware-optimize.service,loaded,active,exited, Armbian hardware optimization
                  armbian-ramlog.service,loaded,active,exited, Armbian memory supported logging
                  armbian-zram-config.service,loaded,active,exited, Armbian ZRAM config
                  armian-ramlog.service,not-found,inactive,dead, armian-ramlog.service
                  chrony.service,loaded,active,running, chrony, an NTP client/server
                  cpufrequtils.service,loaded,active,exited, LSB: set CPUFreq kernel parameters
                  fstrim.service,loaded,inactive,dead, Discard unused blocks
                  haveged.service,loaded,active,running, Entropy daemon using the HAVEGE algorithm
                  hostapd.service,loaded,active,exited, LSB: Advanced IEEE 802.11 management daemon
                  loadcpufreq.service,loaded,active,exited, LSB: Load kernel modules needed to enable cpufreq scaling
                  motd-news.service,loaded,inactive,dead, Message of the Day
                  networkd-dispatcher.service,loaded,active,running, Dispatcher daemon for systemd-networkd
                  NetworkManager-wait-online.service,loaded,active,exited, Network Manager Wait Online
                  NetworkManager.service,loaded,active,running, Network Manager
                  ondemand.service,masked,inactive,dead, ondemand.service
                  openntpd.service,not-found,inactive,dead, openntpd.service
                  polkit.service,loaded,active,running, Authorization Manager
                  resolvconf-pull-resolved.service,loaded,inactive,dead, resolvconf-pull-resolved.service
                  resolvconf.service,loaded,active,exited, Nameserver information manager
                  serial-getty@ttyS2.service,loaded,active,running, Serial Getty on ttyS2
                  setvtrgb.service,loaded,active,exited, Set console scheme
                  sysfsutils.service,loaded,active,exited, LSB: Set sysfs variables from /etc/sysfs.conf
                  sysstat.service,loaded,active,exited, Resets System Activity Data Collector
                  systemd-initctl.service,loaded,inactive,dead, /dev/initctl Compatibility Daemon
                  systemd-resolved.service,loaded,active,running, Network Name Resolution
                  systemd-sysusers.service,not-found,inactive,dead, systemd-sysusers.service
                  tinker-bluetooth.service,loaded,active,running, Realtek H5 bluetooth support
                  unattended-upgrades.service,loaded,active,running, Unattended Upgrades Shutdown
                  user@1002.service,loaded,active,running, User Manager for UID 1002
                  2020-08-16 10:40:23.186  - debug: linux-control.0 (24751) [servicesInfo] Tinker (192.168.138.74:22): csvToJson result: [{"id":"alsa-restore.service","load":"loaded","active":"active","running":"exited","description":"Save/Restore Sound Card State"},{"id":"alsa-state.service","load":"loaded","active":"inactive","running":"dead","description":"Manage Sound Card State (restore and store)"},{"id":"apparmor.service","load":"not-found","active":"inactive","running":"dead","description":"apparmor.service"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"armbian-firstrun-config.service","load":"loaded","active":"inactive","running":"dead","description":"Armbian first run optional user configuration"},{"id":"armbian-hardware-monitor.service","load":"loaded","active":"active","running":"exited","description":"Armbian hardware monitoring"},{"id":"armbian-hardware-optimize.service","load":"loaded","active":"active","running":"exited","description":"Armbian hardware optimization"},{"id":"armbian-ramlog.service","load":"loaded","active":"active","running":"exited","description":"Armbian memory supported logging"},{"id":"armbian-zram-config.service","load":"loaded","active":"active","running":"exited","description":"Armbian ZRAM config"},{"id":"armian-ramlog.service","load":"not-found","active":"inactive","running":"dead","description":"armian-ramlog.service"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"bluetooth.service","load":"loaded","active":"active","running":"running","description":"Bluetooth service"},{"id":"chrony.service","load":"loaded","active":"active","running":"running","description":"chrony","field6":"an NTP client/server"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cpufrequtils.service","load":"loaded","active":"active","running":"exited","description":"LSB: set CPUFreq kernel parameters"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"fake-hwclock.service","load":"loaded","active":"active","running":"exited","description":"Restore / save the current clock"},{"id":"fstrim.service","load":"loaded","active":"inactive","running":"dead","description":"Discard unused blocks"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"haveged.service","load":"loaded","active":"active","running":"running","description":"Entropy daemon using the HAVEGE algorithm"},{"id":"hostapd.service","load":"loaded","active":"active","running":"exited","description":"LSB: Advanced IEEE 802.11 management daemon"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"loadcpufreq.service","load":"loaded","active":"active","running":"exited","description":"LSB: Load kernel modules needed to enable cpufreq scaling"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"motd-news.service","load":"loaded","active":"inactive","running":"dead","description":"Message of the Day"},{"id":"mountkernfs.service","load":"masked","active":"inactive","running":"dead","description":"mountkernfs.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networkd-dispatcher.service","load":"loaded","active":"active","running":"running","description":"Dispatcher daemon for systemd-networkd"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager-wait-online.service","load":"loaded","active":"active","running":"exited","description":"Network Manager Wait Online"},{"id":"NetworkManager.service","load":"loaded","active":"active","running":"running","description":"Network Manager"},{"id":"ondemand.service","load":"masked","active":"inactive","running":"dead","description":"ondemand.service"},{"id":"openntpd.service","load":"not-found","active":"inactive","running":"dead","description":"openntpd.service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"polkit.service","load":"loaded","active":"active","running":"running","description":"Authorization Manager"},{"id":"rc-local.service","load":"loaded","active":"active","running":"exited","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"resolvconf-pull-resolved.service","load":"loaded","active":"inactive","running":"dead","description":"resolvconf-pull-resolved.service"},{"id":"resolvconf.service","load":"loaded","active":"active","running":"exited","description":"Nameserver information manager"},{"id":"rng-tools.service","load":"loaded","active":"active","running":"running","description":"rng-tools.service"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"serial-getty@ttyS2.service","load":"loaded","active":"active","running":"running","description":"Serial Getty on ttyS2"},{"id":"setvtrgb.service","load":"loaded","active":"active","running":"exited","description":"Set console scheme"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"sysfsutils.service","load":"loaded","active":"active","running":"exited","description":"LSB: Set sysfs variables from /etc/sysfs.conf"},{"id":"sysstat.service","load":"loaded","active":"active","running":"exited","description":"Resets System Activity Data Collector"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"/dev/initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-resolved.service","load":"loaded","active":"active","running":"running","description":"Network Name Resolution"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-sysusers.service"},{"id":"systemd-timesyncd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"tinker-bluetooth.service","load":"loaded","active":"active","running":"running","description":"Realtek H5 bluetooth support"},{"id":"unattended-upgrades.service","load":"loaded","active":"active","running":"running","description":"Unattended Upgrades Shutdown"},{"id":"user@1002.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1002"},{"id":"wpa_supplicant.service","load":"loaded","active":"active","running":"running","description":"WPA supplicant"}]
                  2020-08-16 10:40:23.874  - debug: linux-control.0 (24751) [needrestart] Tinker (192.168.138.74:22): no datapoints selected -> removing existing datapoints
                  2020-08-16 10:40:23.886  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): send command: 'sudo du -sk /opt/iobroker/iobroker-data | awk '{ print $1 /1024 }' | tail -1'
                  2020-08-16 10:40:23.987  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): response stdout:
                  Sorry, user pi is not allowed to execute '/usr/bin/du -sk /opt/iobroker/iobroker-data' as root on localhost.
                  2020-08-16 10:40:23.988  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.size: NaN MB
                  2020-08-16 10:40:23.991  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): send command: 'sudo find /opt/iobroker/iobroker-data -name "*" | wc -l | tail -1'
                  2020-08-16 10:40:24.095  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): response stdout:
                  Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name *' as root on localhost.
                  0
                  2020-08-16 10:40:24.097  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.files: NaN Dateien
                  2020-08-16 10:40:24.099  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): send command: 'tmp=$(sudo find /opt/iobroker/iobroker-data -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}' | tail -1) && date +%s -r $tmp'
                  2020-08-16 10:40:24.203  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): response stdout:
                  Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name * -type f -exec stat -c %Y %n -- {} ;' as root on localhost.
                  date: option requires an argument -- 'r'
                  Try 'date --help' for more information.
                  2020-08-16 10:40:24.204  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.lastChange: NaN ->
                  2020-08-16 10:40:24.207  - debug: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
                  2020-08-16 10:40:24.235  - debug: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: root, description: ): response stdout: 5
                  2020-08-16 10:40:24.239  - debug: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1'
                  2020-08-16 10:40:24.250  - debug: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: ip, description: ): response stdout: 192.168.138.74
                  2020-08-16 10:40:24.253  - debug: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: cpu-temp, description: ): send command: 'cat /sys/devices/virtual/thermal/thermal_zone0/temp | awk '{print substr($1, length($0)-5,3)}''
                  2020-08-16 10:40:24.263  - debug: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: cpu-temp, description: ): response stdout: 47
                  2020-08-16 10:40:24.267  - info: linux-control.0 (24751) successful received data from Tinker (192.168.138.74:22)
                  ich hoffe es ist alles notwendige drin.
                  Ich bilde mir ein gestern wäre das log noch formatiert gewesen 😞
                  • Wal
                    Wal Developer last edited by
                    @Scrounger,
                    wäre es möglich, das du deinen Adapter mit der Funktion von meinem Adapter erweiterst ? Mein Adapter führt die Befehle aus, wenn das Objekt dazu auf true gesetzt wird. Warum sollte Zeit in 2 fast gleiche Adapter investiert werden.
                    Hier der Github-Link und der Forums-Link.
                      liv-in-sky @Wal last edited by liv-in-sky
                      @Wal ich denke das geht schon
                      Wal 1 Reply Last reply Reply Quote 1
                      • Wal
                        Wal Developer @liv-in-sky last edited by
                        @liv-in-sky sagte in Test Adapter Linux Control v0.x.x:
                        Da muß ich mal testen 🙂
                          @Wal und ich werd mir deinen mal ansehen - ist total an mir vorbei gegangen
                            @Wal wichtig ist, dass der befehl als button definiert wird
                            • Wal
                              @liv-in-sky
                              hmm, was gebe ich als Abrufintervall ein, ich will ja nicht pollen ?
                                @Wal verstehe ich nicht ganz
                                das interval wird gebraucht für z.b folder abfragen oder service abfragen
                                wenn du nur einen button für einen server einrichten willst - also ohne folder oder service - wird das im moment nicht funktioneren
                                wenn du die datenpunkte (tab DATENPUNKTE) alle deaktivierst, weiß ich nicht ob noch gepollt wird und ob noch die befehle ausgeführt werden - mußt du ausprobieren
                                im log siehst du, ob gepollt wird
                                • Wal
                                  Hab alles deaktiviert und den Intervall auf 9999 gestellt, funktioniert, danke.
                                  • Scrounger
                                    Scrounger Developer @Wal last edited by Scrounger
                                    @Wal sagte in Test Adapter Linux Control v0.x.x:
                                    Ich bau noch ein, das bei Intervall = 0 das polling deaktiviert wird.
                                    Alternativ kann man auch den Adapter einmal nach der Konfirguration eines eigenen Button laufen lassen und dann den host deaktiviert setzen (bei aktiviert den haken raus)
                                    @Homoran sagte in Test Adapter Linux Control v0.x.x:
                                    @Scrounger sagte in Test Adapter Linux Control v0.x.x:
                                    @Homoran
                                    Hab noch was eingebaut, bitte teste mal die aktuelle github version
                                    Habe neu installiert - upload gemacht und Instanz sicherheitshalber nochmal gestartet.
                                    steht immer noch null drin
                                    Hab nochmal was eingebaut, bitte teste die aktuelle version von github.
                                    Dein Tinker hat keine berechtigung:
                                    2020-08-15 16:08:27.315 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): response stdout:
                                    Homoran liv-in-sky Stephan Schleich 4 Replies Last reply Reply Quote 0
                                      Homoran Global Moderator Administrators @Scrounger last edited by
                                      Ja!
                                        liv-in-sky @Scrounger last edited by
                                        @Homoran
                                        ist mir gerade in den sinn gekommen
                                        könnte man da was über das sudoers file auf dem tinker machen ?
                                          Homoran Global Moderator Administrators @liv-in-sky last edited by
                                          @liv-in-sky müsste mich mal schlau machen wo es steht, aber irgendwo konnte man einstellen ob bei sudo das Passwort abgefragt werden soll.
                                          Das wollte ich aber eigentlich nicht ändern, im Gegenteil beim RaspiOS stört mich die fehlende Abfrage.
                                            liv-in-sky @Homoran last edited by
                                            @Homoran oder du gehst ohne passwort über rsa key file
                                            adapter control hardware linux steuern
                                            70
                                            675
                                            168685
