    4. Test Adapter Linux Control v1.x.x
    • Scrounger
      Scrounger Developer @Homoran last edited by
      @Homoran
      Hab noch was eingebaut, bitte teste mal die aktuelle github version
        Homoran Global Moderator Administrators @Scrounger last edited by
        @Scrounger sagte in Test Adapter Linux Control v0.x.x:
        @Homoran
        Habe neu installiert - upload gemacht und Instanz sicherheitshalber nochmal gestartet.
        steht immer noch null drin
        Hier das leider sehr umfangreiche debug log:
        2020-08-16 10:37:56.204  - info: linux-control.0 (24751) getting data from RasPi4 (192.168.138.139:22)
        2020-08-16 10:37:56.257  - debug: linux-control.0 (24751) [getConnection] Host 'RasPi4' (192.168.138.139:22): using sudo for authentification
        2020-08-16 10:37:56.428  - debug: linux-control.0 (24751) [distributionInfo] RasPi4 (192.168.138.139:22): send command: 'cat /etc/os-release'
        2020-08-16 10:37:56.732  - debug: linux-control.0 (24751) [distributionInfo] RasPi4 (192.168.138.139:22): response stdout: PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
        NAME="Raspbian GNU/Linux"
        VERSION_ID="10"
        VERSION="10 (buster)"
        VERSION_CODENAME=buster
        ID=raspbian
        ID_LIKE=debian
        HOME_URL="http://www.raspbian.org/"
        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        2020-08-16 10:37:56.735  - debug: linux-control.0 (24751) [distributionInfo] RasPi4 (192.168.138.139:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Raspbian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Raspbian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"raspbian"},{"prop":"ID_LIKE","val":"debian"},{"prop":"HOME_URL","val":"http://www.raspbian.org/"},{"prop":"SUPPORT_URL","val":"http://www.raspbian.org/RaspbianForums"},{"prop":"BUG_REPORT_URL","val":"http://www.raspbian.org/RaspbianBugs"}]
        2020-08-16 10:37:56.752  - debug: linux-control.0 (24751) [cmdAptUpdate] RasPi4 (192.168.138.139:22): no datapoints selected -> removing existing datapoints
        2020-08-16 10:37:56.755  - debug: linux-control.0 (24751) [servicesInfo] RasPi4 (192.168.138.139:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
        2020-08-16 10:37:56.780  - debug: linux-control.0 (24751) [servicesInfo] RasPi4 (192.168.138.139:22): response stdout: alsa-restore.service,loaded,active,exited, Save/Restore Sound Card State
        alsa-state.service,loaded,active,running, Manage Sound Card State (restore and store)
        apparmor.service,not-found,inactive,dead, apparmor.service
        apt-daily-upgrade.service,loaded,inactive,dead, Daily apt upgrade and clean activities
        apt-daily.service,loaded,inactive,dead, Daily apt download activities
        auditd.service,not-found,inactive,dead, auditd.service
        auth-rpcgss-module.service,loaded,inactive,dead, Kernel Module supporting RPCSEC_GSS
        avahi-daemon.service,loaded,active,running, Avahi mDNS/DNS-SD Stack
        bluetooth.service,loaded,active,running, Bluetooth service
        bthelper@hci0.service,loaded,inactive,dead, Raspberry Pi bluetooth helper
        connman.service,not-found,inactive,dead, connman.service
        console-screen.service,not-found,inactive,dead, console-screen.service
        console-setup.service,loaded,active,exited, Set console font and keymap
        cron.service,loaded,active,running, Regular background program processing daemon
        dbus.service,loaded,active,running, D-Bus System Message Bus
        dhcpcd.service,loaded,active,running, dhcpcd on all interfaces
        display-manager.service,not-found,inactive,dead, display-manager.service
        dphys-swapfile.service,loaded,active,exited, dphys-swapfile - set up, mount/unmount, and delete a swap file
        emergency.service,loaded,inactive,dead, Emergency Shell
        fake-hwclock.service,loaded,active,exited, Restore / save the current clock
        getty-static.service,loaded,inactive,dead, getty on tty2-tty6 if dbus and logind are not available
        getty@tty1.service,loaded,active,running, Getty on tty1
        gssproxy.service,not-found,inactive,dead, gssproxy.service
        hciuart.service,loaded,active,running, Configure Bluetooth Modems connected by UART
        ifupdown-pre.service,loaded,active,exited, Helper to synchronize boot up for ifupdown
        influxdb.service,not-found,inactive,dead, influxdb.service
        iobroker.service,loaded,active,running, ioBroker Server
        kbd.service,not-found,inactive,dead, kbd.service
        keyboard-setup.service,loaded,active,exited, Set the console keyboard layout
        kmod-static-nodes.service,loaded,active,exited, Create list of required static device nodes for the current kernel
        logrotate.service,loaded,inactive,dead, Rotate log files
        man-db.service,loaded,inactive,dead, Daily man-db regeneration
        mariadb-server.service,not-found,inactive,dead, mariadb-server.service
        mountkernfs.service,masked,inactive,dead, mountkernfs.service
        mysql-server.service,not-found,inactive,dead, mysql-server.service
        networking.service,loaded,active,exited, Raise network interfaces
        NetworkManager.service,not-found,inactive,dead, NetworkManager.service
        nfs-blkmap.service,not-found,inactive,dead, nfs-blkmap.service
        nfs-config.service,loaded,inactive,dead, Preprocess NFS configuration
        nfs-server.service,not-found,inactive,dead, nfs-server.service
        nfs-utils.service,loaded,inactive,dead, NFS server and client services
        plymouth-quit-wait.service,not-found,inactive,dead, plymouth-quit-wait.service
        plymouth-start.service,not-found,inactive,dead, plymouth-start.service
        raspberrypi-net-mods.service,loaded,inactive,dead, Copy user wpa_supplicant.conf
        raspi-config.service,loaded,active,exited, LSB: Switch to ondemand cpu governor (unless shift key is pressed)
        rc-local.service,loaded,active,exited, /etc/rc.local Compatibility
        redis.service,not-found,inactive,dead, redis.service
        regenerate_ssh_host_keys.service,loaded,inactive,dead, Regenerate SSH host keys
        rescue.service,loaded,inactive,dead, Rescue Shell
        rng-tools.service,loaded,active,running, rng-tools.service
        rpc-gssd.service,loaded,inactive,dead, RPC security service for NFS client and server
        rpc-svcgssd.service,loaded,inactive,dead, RPC security service for NFS server
        rpi-eeprom-update.service,loaded,active,exited, Check for Raspberry Pi EEPROM updates
        rsync.service,loaded,inactive,dead, fast remote file copy program daemon
        rsyslog.service,loaded,active,running, System Logging Service
        ssh.service,loaded,active,running, OpenBSD Secure Shell server
        sshswitch.service,loaded,inactive,dead, Turn on SSH if /boot/ssh is present
        systemd-ask-password-console.service,loaded,inactive,dead, Dispatch Password Requests to Console
        systemd-ask-password-wall.service,loaded,inactive,dead, Forward Password Requests to Wall
        systemd-binfmt.service,loaded,inactive,dead, Set Up Additional Binary Formats
        systemd-fsck-root.service,loaded,active,exited, File System Check on Root Device
        systemd-fsck@dev-disk-by\x2dpartuuid-50fbae26\x2d01.service,loaded,active,exited, File System Check on /dev/disk/by-partuuid/50fbae26-01
        systemd-fsckd.service,loaded,inactive,dead, File System Check Daemon to report status
        systemd-hwdb-update.service,loaded,inactive,dead, Rebuild Hardware Database
        systemd-initctl.service,loaded,inactive,dead, initctl Compatibility Daemon
        systemd-journal-flush.service,loaded,active,exited, Flush Journal to Persistent Storage
        systemd-journald.service,loaded,active,running, Journal Service
        systemd-logind.service,loaded,active,running, Login Service
        systemd-machine-id-commit.service,loaded,inactive,dead, Commit a transient machine-id on disk
        systemd-modules-load.service,loaded,active,exited, Load Kernel Modules
        systemd-networkd.service,loaded,inactive,dead, Network Service
        systemd-quotacheck.service,loaded,inactive,dead, File System Quota Check
        systemd-random-seed.service,loaded,active,exited, Load/Save Random Seed
        systemd-remount-fs.service,loaded,active,exited, Remount Root and Kernel File Systems
        systemd-rfkill.service,loaded,inactive,dead, Load/Save RF Kill Switch Status
        systemd-sysctl.service,loaded,active,exited, Apply Kernel Variables
        systemd-sysusers.service,loaded,active,exited, Create System Users
        systemd-timesyncd.service,loaded,active,running, Network Time Synchronization
        systemd-tmpfiles-clean.service,loaded,inactive,dead, Cleanup of Temporary Directories
        systemd-tmpfiles-setup-dev.service,loaded,active,exited, Create Static Device Nodes in /dev
        systemd-tmpfiles-setup.service,loaded,active,exited, Create Volatile Files and Directories
        systemd-udev-trigger.service,loaded,active,exited, udev Coldplug all Devices
        systemd-udevd.service,loaded,active,running, udev Kernel Device Manager
        systemd-update-done.service,not-found,inactive,dead, systemd-update-done.service
        systemd-update-utmp-runlevel.service,loaded,inactive,dead, Update UTMP about System Runlevel Changes
        systemd-update-utmp.service,loaded,active,exited, Update UTMP about System Boot/Shutdown
        systemd-user-sessions.service,loaded,active,exited, Permit User Sessions
        systemd-vconsole-setup.service,not-found,inactive,dead, systemd-vconsole-setup.service
        triggerhappy.service,loaded,active,running, triggerhappy global hotkey daemon
        user-runtime-dir@1000.service,loaded,active,exited, User Runtime Directory /run/user/1000
        user@1000.service,loaded,active,running, User Manager for UID 1000
        wpa_supplicant.service,loaded,active,running, WPA supplicant
        2020-08-16 10:37:56.785  - debug: linux-control.0 (24751) [servicesInfo] RasPi4 (192.168.138.139:22): csvToJson result: [{"id":"alsa-restore.service","load":"loaded","active":"active","running":"exited","description":"Save/Restore Sound Card State"},{"id":"alsa-state.service","load":"loaded","active":"active","running":"running","description":"Manage Sound Card State (restore and store)"},{"id":"apparmor.service","load":"not-found","active":"inactive","running":"dead","description":"apparmor.service"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"avahi-daemon.service","load":"loaded","active":"active","running":"running","description":"Avahi mDNS/DNS-SD Stack"},{"id":"bluetooth.service","load":"loaded","active":"active","running":"running","description":"Bluetooth service"},{"id":"bthelper@hci0.service","load":"loaded","active":"inactive","running":"dead","description":"Raspberry Pi bluetooth helper"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"dhcpcd.service","load":"loaded","active":"active","running":"running","description":"dhcpcd on all interfaces"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"dphys-swapfile.service","load":"loaded","active":"active","running":"exited","description":"dphys-swapfile - set up","field6":"mount/unmount","field7":"and delete a swap file"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"fake-hwclock.service","load":"loaded","active":"active","running":"exited","description":"Restore / save the current clock"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"hciuart.service","load":"loaded","active":"active","running":"running","description":"Configure Bluetooth Modems connected by UART"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mountkernfs.service","load":"masked","active":"inactive","running":"dead","description":"mountkernfs.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"raspberrypi-net-mods.service","load":"loaded","active":"inactive","running":"dead","description":"Copy user wpa_supplicant.conf"},{"id":"raspi-config.service","load":"loaded","active":"active","running":"exited","description":"LSB: Switch to ondemand cpu governor (unless shift key is pressed)"},{"id":"rc-local.service","load":"loaded","active":"active","running":"exited","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"regenerate_ssh_host_keys.service","load":"loaded","active":"inactive","running":"dead","description":"Regenerate SSH host keys"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rng-tools.service","load":"loaded","active":"active","running":"running","description":"rng-tools.service"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpi-eeprom-update.service","load":"loaded","active":"active","running":"exited","description":"Check for Raspberry Pi EEPROM updates"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"sshswitch.service","load":"loaded","active":"inactive","running":"dead","description":"Turn on SSH if /boot/ssh is present"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"active","running":"exited","description":"File System Check on Root Device"},{"id":"systemd-fsck@dev-disk-by\\x2dpartuuid-50fbae26\\x2d01.service","load":"loaded","active":"active","running":"exited","description":"File System Check on /dev/disk/by-partuuid/50fbae26-01"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-quotacheck.service","load":"loaded","active":"inactive","running":"dead","description":"File System Quota Check"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"triggerhappy.service","load":"loaded","active":"active","running":"running","description":"triggerhappy global hotkey daemon"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"},{"id":"wpa_supplicant.service","load":"loaded","active":"active","running":"running","description":"WPA supplicant"}]
        2020-08-16 10:37:57.213  - debug: linux-control.0 (24751) [needrestart] RasPi4 (192.168.138.139:22): no datapoints selected -> removing existing datapoints
        2020-08-16 10:37:57.231  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'sudo du -sk /opt/iobroker/iobroker-data/history | awk '{ print $1 /1024 }' | tail -1'
        2020-08-16 10:37:57.464  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): response stdout:
        195.422
        2020-08-16 10:37:57.466  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.size: 195.42 MB
        2020-08-16 10:37:57.469  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'sudo find /opt/iobroker/iobroker-data/history -name "*" | wc -l | tail -1'
        2020-08-16 10:37:57.674  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): response stdout:
        22286
        2020-08-16 10:37:57.675  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.files: 22286 Dateien
        2020-08-16 10:37:57.679  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'tmp=$(sudo find /opt/iobroker/iobroker-data/history -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}' | tail -1) && date +%s -r $tmp'
        2020-08-16 10:39:35.043  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): response stdout:
        1597567063
        2020-08-16 10:39:35.044  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.lastChange: 1597567063000 -> 16.08.2020 10:37
        2020-08-16 10:39:35.048  - debug: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
        2020-08-16 10:39:35.066  - debug: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: root, description: ): response stdout: 19
        2020-08-16 10:39:35.070  - debug: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1'
        2020-08-16 10:39:35.091  - debug: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: ip, description: ): response stdout: 192.168.138.139
        2020-08-16 10:39:35.096  - debug: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: cpu-temp, description: ): send command: 'vcgencmd measure_temp | awk '{print substr($1, length($0)-5,4)}''
        2020-08-16 10:39:35.112  - debug: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: cpu-temp, description: ): response stdout: 55.0
        2020-08-16 10:39:35.117  - info: linux-control.0 (24751) successful received data from RasPi4 (192.168.138.139:22)
        2020-08-16 10:40:00.035  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 5509
        2020-08-16 10:40:03.867  - info: dwd.0 (5509) starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.21.0, js-controller: 3.1.4
        2020-08-16 10:40:05.425  - info: dwd.0 (5509) Terminated (NO_ERROR): Without reason
        2020-08-16 10:40:05.952  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
        2020-08-16 10:40:20.852  - info: linux-control.0 (24751) getting data from NUC_VM (192.168.138.123:22)
        2020-08-16 10:40:20.886  - debug: linux-control.0 (24751) [getConnection] Host 'NUC_VM' (192.168.138.123:22): using sudo for authentification
        2020-08-16 10:40:20.969  - debug: linux-control.0 (24751) [distributionInfo] NUC_VM (192.168.138.123:22): send command: 'cat /etc/os-release'
        2020-08-16 10:40:21.025  - debug: linux-control.0 (24751) [distributionInfo] NUC_VM (192.168.138.123:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
        NAME="Debian GNU/Linux"
        VERSION_ID="10"
        ID=debian
        HOME_URL="https://www.debian.org/"
        SUPPORT_URL="https://www.debian.org/support"
        BUG_REPORT_URL="https://bugs.debian.org/"
        2020-08-16 10:40:21.028  - debug: linux-control.0 (24751) [distributionInfo] NUC_VM (192.168.138.123:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
        2020-08-16 10:40:21.045  - debug: linux-control.0 (24751) [cmdAptUpdate] NUC_VM (192.168.138.123:22): no datapoints selected -> removing existing datapoints
        2020-08-16 10:40:21.049  - debug: linux-control.0 (24751) [servicesInfo] NUC_VM (192.168.138.123:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
        2020-08-16 10:40:21.060  - debug: linux-control.0 (24751) [servicesInfo] NUC_VM (192.168.138.123:22): response stdout: apache2.service,loaded,active,running, The Apache HTTP Server
        apparmor.service,loaded,active,exited, Load AppArmor profiles
        clamav-daemon.service,not-found,inactive,dead, clamav-daemon.service
        cups-browsed.service,loaded,failed,failed, Make remote CUPS printers available locally
        cups.service,loaded,active,running, CUPS Scheduler
        exim4.service,loaded,active,running, LSB: exim Mail Transport Agent
        greylist.service,not-found,inactive,dead, greylist.service
        ifup@ens18.service,loaded,active,exited, ifup for ens18
        irqbalance.service,loaded,active,running, irqbalance daemon
        mysql.service,not-found,inactive,dead, mysql.service
        ntp.service,loaded,active,running, Network Time Service
        postgresql.service,not-found,inactive,dead, postgresql.service
        rc-local.service,loaded,inactive,dead, /etc/rc.local Compatibility
        rpcbind.service,loaded,active,running, RPC bind portmap service
        spamassassin.service,not-found,inactive,dead, spamassassin.service
        systemd-fsck-root.service,loaded,inactive,dead, File System Check on Root Device
        systemd-timesyncd.service,loaded,inactive,dead, Network Time Synchronization
        2020-08-16 10:40:21.065  - debug: linux-control.0 (24751) [servicesInfo] NUC_VM (192.168.138.123:22): csvToJson result: [{"id":"apache2.service","load":"loaded","active":"active","running":"running","description":"The Apache HTTP Server"},{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"avahi-daemon.service","load":"loaded","active":"active","running":"running","description":"Avahi mDNS/DNS-SD Stack"},{"id":"clamav-daemon.service","load":"not-found","active":"inactive","running":"dead","description":"clamav-daemon.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"cups-browsed.service","load":"loaded","active":"failed","running":"failed","description":"Make remote CUPS printers available locally"},{"id":"cups.service","load":"loaded","active":"active","running":"running","description":"CUPS Scheduler"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"exim4.service","load":"loaded","active":"active","running":"running","description":"LSB: exim Mail Transport Agent"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"greylist.service","load":"not-found","active":"inactive","running":"dead","description":"greylist.service"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"ifup@ens18.service","load":"loaded","active":"active","running":"exited","description":"ifup for ens18"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"irqbalance.service","load":"loaded","active":"active","running":"running","description":"irqbalance daemon"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"mysql.service","load":"not-found","active":"inactive","running":"dead","description":"mysql.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"ntp.service","load":"loaded","active":"active","running":"running","description":"Network Time Service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"postgresql.service","load":"not-found","active":"inactive","running":"dead","description":"postgresql.service"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpcbind.service","load":"loaded","active":"active","running":"running","description":"RPC bind portmap service"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"spamassassin.service","load":"not-found","active":"inactive","running":"dead","description":"spamassassin.service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"}]
        2020-08-16 10:40:21.427  - debug: linux-control.0 (24751) [needrestart] NUC_VM (192.168.138.123:22): no datapoints selected -> removing existing datapoints
        2020-08-16 10:40:21.440  - debug: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'sudo du -sk /opt/iobroker/iobroker-data/history | awk '{ print $1 /1024 }' | tail -1'
        2020-08-16 10:40:21.766  - debug: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): response stdout:
        [sudo] Passwort für pi:
        13533.4
        2020-08-16 10:40:21.768  - debug: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.size: NaN MB
        2020-08-16 10:40:21.772  - debug: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'sudo find /opt/iobroker/iobroker-data/history -name "*" | wc -l | tail -1'
        2020-08-16 10:40:22.085  - debug: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): response stdout:
        112764
        2020-08-16 10:40:22.086  - debug: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.files: NaN Dateien
        2020-08-16 10:40:22.089  - debug: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'tmp=$(sudo find /opt/iobroker/iobroker-data/history -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}' | tail -1) && date +%s -r $tmp'
        2020-08-16 10:40:22.686  - info: linux-control.0 (24751) getting data from Tinker (192.168.138.74:22)
        2020-08-16 10:40:22.719  - debug: linux-control.0 (24751) [getConnection] Host 'Tinker' (192.168.138.74:22): using sudo for authentification
        2020-08-16 10:40:22.825  - debug: linux-control.0 (24751) [distributionInfo] Tinker (192.168.138.74:22): send command: 'cat /etc/os-release'
        2020-08-16 10:40:23.123  - debug: linux-control.0 (24751) [distributionInfo] Tinker (192.168.138.74:22): response stdout: NAME="Ubuntu"
        VERSION="18.04.4 LTS (Bionic Beaver)"
        ID=ubuntu
        ID_LIKE=debian
        PRETTY_NAME="Ubuntu 18.04.4 LTS"
        VERSION_ID="18.04"
        HOME_URL="https://www.ubuntu.com/"
        SUPPORT_URL="https://help.ubuntu.com/"
        BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
        PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
        VERSION_CODENAME=bionic
        UBUNTU_CODENAME=bionic
        2020-08-16 10:40:23.127  - debug: linux-control.0 (24751) [distributionInfo] Tinker (192.168.138.74:22): csvToJson result: [{"prop":"NAME","val":"Ubuntu"},{"prop":"VERSION","val":"18.04.4 LTS (Bionic Beaver)"},{"prop":"ID","val":"ubuntu"},{"prop":"ID_LIKE","val":"debian"},{"prop":"PRETTY_NAME","val":"Ubuntu 18.04.4 LTS"},{"prop":"VERSION_ID","val":"18.04"},{"prop":"HOME_URL","val":"https://www.ubuntu.com/"},{"prop":"SUPPORT_URL","val":"https://help.ubuntu.com/"},{"prop":"BUG_REPORT_URL","val":"https://bugs.launchpad.net/ubuntu/"},{"prop":"PRIVACY_POLICY_URL","val":"https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"},{"prop":"VERSION_CODENAME","val":"bionic"},{"prop":"UBUNTU_CODENAME","val":"bionic"}]
        2020-08-16 10:40:23.152  - debug: linux-control.0 (24751) [cmdAptUpdate] Tinker (192.168.138.74:22): no datapoints selected -> removing existing datapoints
        2020-08-16 10:40:23.155  - debug: linux-control.0 (24751) [servicesInfo] Tinker (192.168.138.74:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
        2020-08-16 10:40:23.178  - debug: linux-control.0 (24751) [servicesInfo] Tinker (192.168.138.74:22): response stdout: alsa-restore.service,loaded,active,exited, Save/Restore Sound Card State
        alsa-state.service,loaded,inactive,dead, Manage Sound Card State (restore and store)
        armbian-firstrun-config.service,loaded,inactive,dead, Armbian first run optional user configuration
        armbian-hardware-monitor.service,loaded,active,exited, Armbian hardware monitoring
        armbian-hardware-optimize.service,loaded,active,exited, Armbian hardware optimization
        armbian-ramlog.service,loaded,active,exited, Armbian memory supported logging
        armbian-zram-config.service,loaded,active,exited, Armbian ZRAM config
        armian-ramlog.service,not-found,inactive,dead, armian-ramlog.service
        chrony.service,loaded,active,running, chrony, an NTP client/server
        cpufrequtils.service,loaded,active,exited, LSB: set CPUFreq kernel parameters
        fstrim.service,loaded,inactive,dead, Discard unused blocks
        haveged.service,loaded,active,running, Entropy daemon using the HAVEGE algorithm
        hostapd.service,loaded,active,exited, LSB: Advanced IEEE 802.11 management daemon
        loadcpufreq.service,loaded,active,exited, LSB: Load kernel modules needed to enable cpufreq scaling
        motd-news.service,loaded,inactive,dead, Message of the Day
        networkd-dispatcher.service,loaded,active,running, Dispatcher daemon for systemd-networkd
        NetworkManager-wait-online.service,loaded,active,exited, Network Manager Wait Online
        NetworkManager.service,loaded,active,running, Network Manager
        ondemand.service,masked,inactive,dead, ondemand.service
        openntpd.service,not-found,inactive,dead, openntpd.service
        polkit.service,loaded,active,running, Authorization Manager
        resolvconf-pull-resolved.service,loaded,inactive,dead, resolvconf-pull-resolved.service
        resolvconf.service,loaded,active,exited, Nameserver information manager
        serial-getty@ttyS2.service,loaded,active,running, Serial Getty on ttyS2
        setvtrgb.service,loaded,active,exited, Set console scheme
        sysfsutils.service,loaded,active,exited, LSB: Set sysfs variables from /etc/sysfs.conf
        sysstat.service,loaded,active,exited, Resets System Activity Data Collector
        systemd-initctl.service,loaded,inactive,dead, /dev/initctl Compatibility Daemon
        systemd-resolved.service,loaded,active,running, Network Name Resolution
        systemd-sysusers.service,not-found,inactive,dead, systemd-sysusers.service
        tinker-bluetooth.service,loaded,active,running, Realtek H5 bluetooth support
        unattended-upgrades.service,loaded,active,running, Unattended Upgrades Shutdown
        user@1002.service,loaded,active,running, User Manager for UID 1002
        2020-08-16 10:40:23.186  - debug: linux-control.0 (24751) [servicesInfo] Tinker (192.168.138.74:22): csvToJson result: [{"id":"alsa-restore.service","load":"loaded","active":"active","running":"exited","description":"Save/Restore Sound Card State"},{"id":"alsa-state.service","load":"loaded","active":"inactive","running":"dead","description":"Manage Sound Card State (restore and store)"},{"id":"apparmor.service","load":"not-found","active":"inactive","running":"dead","description":"apparmor.service"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"armbian-firstrun-config.service","load":"loaded","active":"inactive","running":"dead","description":"Armbian first run optional user configuration"},{"id":"armbian-hardware-monitor.service","load":"loaded","active":"active","running":"exited","description":"Armbian hardware monitoring"},{"id":"armbian-hardware-optimize.service","load":"loaded","active":"active","running":"exited","description":"Armbian hardware optimization"},{"id":"armbian-ramlog.service","load":"loaded","active":"active","running":"exited","description":"Armbian memory supported logging"},{"id":"armbian-zram-config.service","load":"loaded","active":"active","running":"exited","description":"Armbian ZRAM config"},{"id":"armian-ramlog.service","load":"not-found","active":"inactive","running":"dead","description":"armian-ramlog.service"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"bluetooth.service","load":"loaded","active":"active","running":"running","description":"Bluetooth service"},{"id":"chrony.service","load":"loaded","active":"active","running":"running","description":"chrony","field6":"an NTP client/server"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cpufrequtils.service","load":"loaded","active":"active","running":"exited","description":"LSB: set CPUFreq kernel parameters"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"fake-hwclock.service","load":"loaded","active":"active","running":"exited","description":"Restore / save the current clock"},{"id":"fstrim.service","load":"loaded","active":"inactive","running":"dead","description":"Discard unused blocks"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"haveged.service","load":"loaded","active":"active","running":"running","description":"Entropy daemon using the HAVEGE algorithm"},{"id":"hostapd.service","load":"loaded","active":"active","running":"exited","description":"LSB: Advanced IEEE 802.11 management daemon"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"loadcpufreq.service","load":"loaded","active":"active","running":"exited","description":"LSB: Load kernel modules needed to enable cpufreq scaling"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"motd-news.service","load":"loaded","active":"inactive","running":"dead","description":"Message of the Day"},{"id":"mountkernfs.service","load":"masked","active":"inactive","running":"dead","description":"mountkernfs.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networkd-dispatcher.service","load":"loaded","active":"active","running":"running","description":"Dispatcher daemon for systemd-networkd"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager-wait-online.service","load":"loaded","active":"active","running":"exited","description":"Network Manager Wait Online"},{"id":"NetworkManager.service","load":"loaded","active":"active","running":"running","description":"Network Manager"},{"id":"ondemand.service","load":"masked","active":"inactive","running":"dead","description":"ondemand.service"},{"id":"openntpd.service","load":"not-found","active":"inactive","running":"dead","description":"openntpd.service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"polkit.service","load":"loaded","active":"active","running":"running","description":"Authorization Manager"},{"id":"rc-local.service","load":"loaded","active":"active","running":"exited","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"resolvconf-pull-resolved.service","load":"loaded","active":"inactive","running":"dead","description":"resolvconf-pull-resolved.service"},{"id":"resolvconf.service","load":"loaded","active":"active","running":"exited","description":"Nameserver information manager"},{"id":"rng-tools.service","load":"loaded","active":"active","running":"running","description":"rng-tools.service"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"serial-getty@ttyS2.service","load":"loaded","active":"active","running":"running","description":"Serial Getty on ttyS2"},{"id":"setvtrgb.service","load":"loaded","active":"active","running":"exited","description":"Set console scheme"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"sysfsutils.service","load":"loaded","active":"active","running":"exited","description":"LSB: Set sysfs variables from /etc/sysfs.conf"},{"id":"sysstat.service","load":"loaded","active":"active","running":"exited","description":"Resets System Activity Data Collector"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"/dev/initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-resolved.service","load":"loaded","active":"active","running":"running","description":"Network Name Resolution"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-sysusers.service"},{"id":"systemd-timesyncd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"tinker-bluetooth.service","load":"loaded","active":"active","running":"running","description":"Realtek H5 bluetooth support"},{"id":"unattended-upgrades.service","load":"loaded","active":"active","running":"running","description":"Unattended Upgrades Shutdown"},{"id":"user@1002.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1002"},{"id":"wpa_supplicant.service","load":"loaded","active":"active","running":"running","description":"WPA supplicant"}]
        2020-08-16 10:40:23.874  - debug: linux-control.0 (24751) [needrestart] Tinker (192.168.138.74:22): no datapoints selected -> removing existing datapoints
        2020-08-16 10:40:23.886  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): send command: 'sudo du -sk /opt/iobroker/iobroker-data | awk '{ print $1 /1024 }' | tail -1'
        2020-08-16 10:40:23.987  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): response stdout:
        Sorry, user pi is not allowed to execute '/usr/bin/du -sk /opt/iobroker/iobroker-data' as root on localhost.
        2020-08-16 10:40:23.988  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.size: NaN MB
        2020-08-16 10:40:23.991  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): send command: 'sudo find /opt/iobroker/iobroker-data -name "*" | wc -l | tail -1'
        2020-08-16 10:40:24.095  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): response stdout:
        Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name *' as root on localhost.
        0
        2020-08-16 10:40:24.097  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.files: NaN Dateien
        2020-08-16 10:40:24.099  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): send command: 'tmp=$(sudo find /opt/iobroker/iobroker-data -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}' | tail -1) && date +%s -r $tmp'
        2020-08-16 10:40:24.203  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): response stdout:
        Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name * -type f -exec stat -c %Y %n -- {} ;' as root on localhost.
        date: option requires an argument -- 'r'
        Try 'date --help' for more information.
        2020-08-16 10:40:24.204  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.lastChange: NaN ->
        2020-08-16 10:40:24.207  - debug: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
        2020-08-16 10:40:24.235  - debug: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: root, description: ): response stdout: 5
        2020-08-16 10:40:24.239  - debug: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1'
        2020-08-16 10:40:24.250  - debug: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: ip, description: ): response stdout: 192.168.138.74
        2020-08-16 10:40:24.253  - debug: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: cpu-temp, description: ): send command: 'cat /sys/devices/virtual/thermal/thermal_zone0/temp | awk '{print substr($1, length($0)-5,3)}''
        2020-08-16 10:40:24.263  - debug: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: cpu-temp, description: ): response stdout: 47
        2020-08-16 10:40:24.267  - info: linux-control.0 (24751) successful received data from Tinker (192.168.138.74:22)
        ich hoffe es ist alles notwendige drin.
        Ich bilde mir ein gestern wäre das log noch formatiert gewesen 😞
        • Wal
          Wal Developer last edited by
          @Scrounger,
          wäre es möglich, das du deinen Adapter mit der Funktion von meinem Adapter erweiterst ? Mein Adapter führt die Befehle aus, wenn das Objekt dazu auf true gesetzt wird. Warum sollte Zeit in 2 fast gleiche Adapter investiert werden.
          Hier der Github-Link und der Forums-Link.
            liv-in-sky @Wal last edited by liv-in-sky
            @Wal ich denke das geht schon
            Wal 1 Reply Last reply Reply Quote 1
            • Wal
              Wal Developer @liv-in-sky last edited by
              @liv-in-sky sagte in Test Adapter Linux Control v0.x.x:
              Da muß ich mal testen 🙂
                @Wal und ich werd mir deinen mal ansehen - ist total an mir vorbei gegangen
                  @Wal wichtig ist, dass der befehl als button definiert wird
                  • Wal
                    @liv-in-sky
                    hmm, was gebe ich als Abrufintervall ein, ich will ja nicht pollen ?
                      @Wal verstehe ich nicht ganz
                      das interval wird gebraucht für z.b folder abfragen oder service abfragen
                      wenn du nur einen button für einen server einrichten willst - also ohne folder oder service - wird das im moment nicht funktioneren
                      wenn du die datenpunkte (tab DATENPUNKTE) alle deaktivierst, weiß ich nicht ob noch gepollt wird und ob noch die befehle ausgeführt werden - mußt du ausprobieren
                      im log siehst du, ob gepollt wird
                      • Wal
                        Hab alles deaktiviert und den Intervall auf 9999 gestellt, funktioniert, danke.
                        • Scrounger
                          Scrounger Developer @Wal last edited by Scrounger
                          @Wal sagte in Test Adapter Linux Control v0.x.x:
                          Ich bau noch ein, das bei Intervall = 0 das polling deaktiviert wird.
                          Alternativ kann man auch den Adapter einmal nach der Konfirguration eines eigenen Button laufen lassen und dann den host deaktiviert setzen (bei aktiviert den haken raus)
                          @Homoran sagte in Test Adapter Linux Control v0.x.x:
                          @Scrounger sagte in Test Adapter Linux Control v0.x.x:
                          @Homoran
                          Hab noch was eingebaut, bitte teste mal die aktuelle github version
                          Habe neu installiert - upload gemacht und Instanz sicherheitshalber nochmal gestartet.
                          steht immer noch null drin
                          Hab nochmal was eingebaut, bitte teste die aktuelle version von github.
                          Dein Tinker hat keine berechtigung:
                          2020-08-15 16:08:27.315 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): response stdout:
                          Homoran liv-in-sky Stephan Schleich 4 Replies Last reply Reply Quote 0
                            Homoran Global Moderator Administrators @Scrounger last edited by
                            Ja!
                              liv-in-sky @Scrounger last edited by
                              @Homoran
                              ist mir gerade in den sinn gekommen
                              könnte man da was über das sudoers file auf dem tinker machen ?
                                Homoran Global Moderator Administrators @liv-in-sky last edited by
                                @liv-in-sky müsste mich mal schlau machen wo es steht, aber irgendwo konnte man einstellen ob bei sudo das Passwort abgefragt werden soll.
                                Das wollte ich aber eigentlich nicht ändern, im Gegenteil beim RaspiOS stört mich die fehlende Abfrage.
                                  liv-in-sky @Homoran last edited by
                                  @Homoran oder du gehst ohne passwort über rsa key file
                                    Thomas Braun Most Active @liv-in-sky last edited by Thomas Braun
                                    @liv-in-sky Vielleicht geht auch was mit dem sticky bit.
                                    [Edit:] Ich meinte natürlich setuid, nicht sticky bit.
                                      @Scrounger
                                      habe gestern abend mal versucht, eine verbindung über rsa key file zu erstellen. anschliessend habe ich den pfad wieder aus dem setting im adapter genommen um wieder mit passwort zu verbinden - seitdem habe ich fehler und die verbindung wird nicht wieder hergestellt - iobroker restart heute morgen brachte keine verbesserung
                                      linux-control.0	2020-08-17 08:29:10.256	error	(2065) [getConnection] error: config.privateKey does not exist at given fs path, stack: AssertionError [ERR_ASSERTION]: config.privateKey does not exist at given fs path at new AssertionError (int
                                      linux-control.0	2020-08-17 08:29:10.255	error	(2065) [getConnection] Could not establish a connection to 'Proxmox' (192.168.178.10:22)!
                                      linux-control.0	2020-08-17 08:28:10.247	error	(2065) [getConnection] error: config.privateKey does not exist at given fs path, stack: AssertionError [ERR_ASSERTION]: config.privateKey does not exist at given fs path at new AssertionError (int
                                      linux-control.0	2020-08-17 08:28:10.246	error	(2065) [getConnection] Could not establish a connection to 'Proxmox' (192.168.178.10:22)!
                                      linux-control.0	2020-08-17 08:27:10.236	error	(2065) [getConnection] error: config.privateKey does not exist at given fs path, stack: AssertionError [ERR_ASSERTION]: config.privateKey does not exist at given fs path at new AssertionError (int
                                      linux-control.0	2020-08-17 08:27:10.236	error	(2065) [getConnection] Could not establish a connection to 'Proxmox' (192.168.178.10:22)!
                                      hast du eine idee dazu ?
                                      • Scrounger
                                        Scrounger Developer @liv-in-sky last edited by
                                        Ja da muss ich noch was abfangen. Werd im Laufe des Tages noch eine neue Version bauen.
                                          @Scrounger danke und gruß
                                          • Scrounger
                                            @liv-in-sky
                                            So neue Version 0.2.7 ist auf github.
                                            @Homoran
                                            Bitte die auch nochmal testen, hab da noch was eingebaut, was deinen fehler hoffentlich jetzt löst.
                                            ? Homoran liv-in-sky 5 Replies Last reply Reply Quote 0
                                            1.2k
                                            adapter control hardware linux steuern
                                            70
                                            675
                                            168712
