    4. Test Adapter rtspStream v0.0.x GitHub
      Lumumba last edited by
      Schade, zu lang kein Backup gemacht ich Trottel 🙂
      Naja, macht keine Systemlast, aber Fehlermeldungen...
      • Bluelinux
        Bluelinux last edited by
        Hat jemand noch eine Idee wie ich diesen Adapter deinstalliert bekomme????
          Thomas Braun Most Active @Bluelinux last edited by
          @Bluelinux
          iobroker del adaptername
          Bluelinux 1 Reply Last reply Reply Quote 0
          • Bluelinux
            Bluelinux @Thomas Braun last edited by
            @Thomas-Braun das klappt leider nicht.... bekomme das kack ding nicht vom iobroker
              @Bluelinux Mit welchen Meldungen aus der Konsole?
              • Bluelinux
                @Thomas-Braun
                iobroker@ioBroker-Debian:~$ iobroker del rtspStream
                Commands:
                iobroker setup [--objects <host>] [--states <host>] [custom]
                iobroker start - starts the js-controller
                iobroker stop - stops the js-controller
                iobroker start <adapter>[.instance] - starts a specified adapter instance
                iobroker stop <adapter>.[instance] - stops a specified adapter instance
                iobroker start all - starts js-controller and all adapters
                iobroker restart - restarts the js-controller
                iobroker restart <adapter>[.instance] - restarts a specified adapter
                iobroker debug <adapter> [--ip=<ip>] [--port=<port>] [--wait] - Starts a Node.js debugging session for the adapter
                   --wait stops the execution until the debugger is attached.
                   --ip and --port can be used to change the listen IP and port. Use IP 0.0.0.0 for remote debugging.
                iobroker info - shows the host info
                iobroker logs [adapter] [--watch] [--lines=1000]
                iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
                iobroker install <adapter> - installs a specified adapter
                iobroker rebuild <adapter>|self [--install]
                iobroker url <url> [<name>] - install adapter from specified url, e.g. GitHub
                iobroker del <adapter> - remove adapter from system
                iobroker del <adapter>.<instance> - remove adapter instance
                iobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f] - update repository and optionally filter installed/updateable adapters, use --force to bypass hash check
                iobroker upgrade [repository url]
                iobroker upgrade self [repository url] - upgrade js-controller and all adapters, optionally you can specify the repository url
                iobroker upgrade <adapter> [repository url] - upgrade specified adapter, optionally you can specify the repository url
                iobroker upload <pathToLocalFile> <pathIniobroker>
                iobroker upload all - upload all adapter files to make them available for instances
                iobroker upload <adapter> - upload specified adapter files to make them available for instances
                iobroker object get <id> - get object specified by id
                iobroker object set <id> <json-value> - set object with the given id by providing a new json object
                iobroker object set <id> propertyname=<value or json-value> - update part of the object by providing a new value or partial object
                iobroker object extend <id> <json-value> - extend object with the given id by providing a new json object
                iobroker object del <id|pattern> [--yes]
                iobroker object chmod <object-mode> [state-mode] <id>
                iobroker object chown <user> <group> <id>
                iobroker object list <id>
                iobroker state get <id> - get state, specified by id
                iobroker state getplain <id> [--pretty]
                iobroker state getvalue <id>
                iobroker state set <id> <value> [ack]
                iobroker state del <id>
                iobroker message <adapter>[.instance] <command> [<message>]
                iobroker list <type> [filter]
                iobroker chmod <mode> <file>
                iobroker chown <user> <group> <file>
                iobroker touch <file>
                iobroker rm <file>
                iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
                iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
                iobroker file rm <iobroker-path-to-delete>
                iobroker file sync
                iobroker user add <user> [--ingroup group] [--password pass]
                iobroker user del <user>
                iobroker user passwd <user> [--password pass]
                iobroker user enable <user>
                iobroker user disable <user>
                iobroker user get <user>
                iobroker user check <user> [--password pass]
                iobroker group add <group>
                iobroker group del <group>
                iobroker group list <group>
                iobroker group enable <group>
                iobroker group disable <group>
                iobroker group get <group>
                iobroker group adduser <group> <user>
                iobroker group deluser <group> <user>
                iobroker host this
                iobroker host <hostname>
                iobroker host set <hostname>
                iobroker host remove <hostname>
                iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
                iobroker license <license.file or license.text>
                iobroker cert create
                iobroker cert view [<certificate name>]
                iobroker clean
                iobroker backup
                iobroker restore <backup name or path> - restore a specified backup
                iobroker validate <backup name or path> - validate a specified backup
                iobroker <command> --timeout 5000
                iobroker status [all|<adapter>.<instance>]
                iobroker repo [name]
                iobroker repo add <name> <path or url>
                iobroker repo set <name>
                iobroker repo del <name>
                iobroker uuid
                iobroker unsetup
                iobroker fix - execute the installation fixer script, this updates your ioBroker installation
                iobroker multihost <enable|disable> [--secure true|false]
                iobroker multihost browse
                iobroker multihost connect
                iobroker compact status - show if compact mode is enabled in general
                iobroker compact <enable|on|disable|off> - enable or disable compact mode in general
                iobroker compact <adapter>.<instance> status - show if compact mode is enabled for a specific instance
                iobroker compact <adapter>.<instance> group <group-id> - define compact group of a specific adapter
                iobroker compact <adapter>.<instance> <disable|off> - enable or disable compact mode for specified adapter instance
                iobroker compact <adapter>.<instance> <enable|on> [group-id] - enable or disable compact mode for specified adapter instance and set comapct group optionally
                iobroker plugin enable <pluginname> [--host <hostname>] - enables a plugin for the specified host. If no host is specified, the current one is used
                iobroker plugin disable <pluginname> [--host <hostname>] - disables a plugin for the specified host. If no host is specified, the current one is used
                iobroker plugin status <pluginname> [--host <hostname>] - checks if a plugin is enabled for the specified host. If no host is specified, the current one is used
                iobroker plugin enable <pluginname> --instance <adapter>[.<nr>] - enables a plugin for the specified adapter instance (defaults to instance 0)
                iobroker plugin disable <pluginname> --instance <adapter>[.<nr>] - disables a plugin for the specified adapter instance (defaults to instance 0)
                iobroker plugin status <pluginname> --instance <adapter>[.<nr>] - checks if a plugin is enabled for the specified adapter instance (defaults to instance 0)
                iobroker version [adapter] - show version of js-controller or specified adapter
                iobroker [adapter] -v - show version of js-controller or specified adapter
                Options:
                 --help     Hilfe anzeigen  [boolean]
                 --version  Version anzeigen  [boolean]
                das hier kommt dann
                  @Bluelinux
                  iobroker list adapters
                  • Bluelinux
                    @Thomas-Braun
                    iobroker@ioBroker-Debian:~$ iobroker list adapters
                    system.adapter.admin                   : admin          - v4.1.6
                    system.adapter.alexa2                  : alexa2         - v3.3.1
                    system.adapter.backitup                : backitup       - v1.6.0
                    system.adapter.cloud                   : cloud          - v3.0.4
                    system.adapter.daswetter               : daswetter      - v3.0.1
                    system.adapter.discovery               : discovery      - v2.3.11
                    system.adapter.dwd                     : dwd            - v2.4.10
                    system.adapter.firetv                  : firetv         - v1.0.0
                    system.adapter.flot                    : flot           - v1.10.2
                    system.adapter.fritzbox                : fritzbox       - v0.3.1
                    system.adapter.fritzdect               : fritzdect      - v0.3.2
                    system.adapter.fullybrowser            : fullybrowser   - v1.0.4
                    system.adapter.history                 : history        - v1.9.10
                    system.adapter.ical                    : ical           - v1.7.1
                    system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
                    system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.0.2
                    system.adapter.influxdb                : influxdb       - v1.9.2
                    system.adapter.info                    : info           - v1.7.7
                    system.adapter.iot                     : iot            - v1.7.0
                    system.adapter.javascript              : javascript     - v4.6.22
                    system.adapter.kodi                    : kodi           - v2.0.4
                    system.adapter.mclighting              : mclighting     - v0.1.1
                    system.adapter.mihome-vacuum           : mihome-vacuum  - v2.1.1
                    system.adapter.moma                    : moma           - v1.2.6
                    system.adapter.mqtt                    : mqtt           - v2.1.7
                    system.adapter.nina                    : nina           - v0.0.23
                    system.adapter.nuc                     : nuc            - v0.1.3
                    system.adapter.parser                  : parser         - v1.0.7
                    system.adapter.ping                    : ping           - v1.4.8
                    system.adapter.proxy                   : proxy          - v1.2.1
                    system.adapter.pushover                : pushover       - v2.0.2
                    system.adapter.radar2                  : radar2         - v2.0.1
                    system.adapter.rpi2                    : rpi2           - v1.2.0
                    system.adapter.rtspStream              : rtspStream     - v0.0.2
                    system.adapter.samsung                 : samsung        - v0.2.9
                    system.adapter.simple-api              : simple-api     - v2.4.6
                    system.adapter.socketio                : socketio       - v3.0.12
                    system.adapter.sonoff                  : sonoff         - v2.3.3
                    system.adapter.sql                     : sql            - v1.15.2
                    system.adapter.synology                : synology       - v0.1.18
                    system.adapter.systeminfo              : systeminfo     - v0.3.1
                    system.adapter.tankerkoenig            : tankerkoenig   - v2.0.9
                    system.adapter.telegram                : telegram       - v1.5.9
                    system.adapter.text2command            : text2command   - v2.0.3
                    system.adapter.tr-064                  : tr-064         - v4.0.12
                    system.adapter.upnp                    : upnp           - v1.0.16
                    system.adapter.vis                     : vis            - v1.2.6
                    system.adapter.vis-bars                : vis-bars       - v0.1.4
                    system.adapter.vis-colorpicker         : vis-colorpicker - v1.2.0
                    system.adapter.vis-google-fonts        : vis-google-fonts - v1.0.0
                    system.adapter.vis-history             : vis-history    - v1.0.0
                    system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.5
                    system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
                    system.adapter.vis-justgage            : vis-justgage   - v1.0.2
                    system.adapter.vis-material            : vis-material   - v0.1.3
                    system.adapter.vis-material-webfont    : vis-material-webfont - v0.0.3
                    system.adapter.vis-materialdesign      : vis-materialdesign - v0.3.19
                    system.adapter.vis-metro               : vis-metro      - v1.1.2
                    system.adapter.vis-players             : vis-players    - v0.1.6
                    system.adapter.vis-rgraph              : vis-rgraph     - v0.0.2
                    system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                    system.adapter.web                     : web            - v3.0.10
                    system.adapter.web-speedy              : web-speedy     - v0.2.0
                    system.adapter.wifilight               : wifilight      - v1.1.0
                    system.adapter.wled                    : wled           - v0.5.0
                    system.adapter.yahka                   : yahka          - v0.11.0
                    system.adapter.yr                      : yr             - v2.0.3
                    system.adapter.zigbee                  : zigbee         - v1.2.0
                      @Bluelinux Keine Ahnung. Hat evtl. mit dem Großbuchstaben im Adapternamen zutun. Das wird vielleicht falsch interpretiert. Jedenfalls reagiert die Konsole, als sei der Befehl nicht komplett. Allerdings funktioniert eine Deinstallation über npm auch nicht.
                      Bluelinux Thomas Braun 2 Replies Last reply Reply Quote 0
                      • Bluelinux
                        @Thomas-Braun hmmm na das ist ja echt merkwürdig oder??? nervt mich total das ich da so einen toten adapter habe .... schade aber danke für deine hilfe
                        B Thomas Braun 2 Replies Last reply Reply Quote 0
                          bob der 1. @Bluelinux last edited by
                          @Bluelinux
                          Der Entwickler sollte das lösen odet man sollte von der Adminseite den 1 Post editieren das er sich nicht deinstallieren lässt.
                          Bekekomme ihn auch nicht vom Broker,finde es abet nicht so wild.Weis aber das ich sicherlich von diesem Entwickler nichts mehr nutue solange er es nicht löst
                            bob der 1. @bob der 1. last edited by
                            @bob-der-1 sagte in Test Adapter rtspStream v0.0.x GitHub:
                            @Bluelinux
                            Der Entwickler sollte das lösen oder man sollte von der Adminseite den 1.Post editieren das er sich nicht deinstallieren lässt.
                            Bekomme ihn auch nicht vom Broker,finde es abet nicht so wild.Weis aber das ich sicherlich von diesem Entwickler nichts mehr nutue solange er es nicht löst.
                              @Bluelinux Gibt ein issue dazu im git.
                              • Bluelinux
                                @Thomas-Braun ja aber da gibt es ja auch leider keine antwort so wie ich das sehe.... wirklich schade.....
                                  @Bluelinux Zumindest ist es geloggt.
                                    Thomas Braun Most Active @Thomas Braun last edited by
                                    @Thomas-Braun sagte in Test Adapter rtspStream v0.0.x GitHub:
                                    @apollon77 Hast du da vielleicht noxh einen magischen npm-Befehl in petto? Mit den mir bekannten Dingen bekomme ich den Adapter nicht deinstalliert.
                                    • Jey Cee
                                      Jey Cee Developer @Thomas Braun last edited by
                                      @Thomas-Braun ich bin zwar nicht @apollon77, aber hab da noch ne idee:
                                      1. Instanz löschen
                                      2. per SSH auf den host verbinden
                                      3. in den Ordner node_modules im ioBroker Verzeichnis gehen
                                      4. sudo rm -R iobroker.rtspStream
                                      5. ioBroker neustarten
                                      Das sollte den Adapter Vollständig entfernen.
                                      Thomas Braun Bluelinux 2 Replies Last reply Reply Quote 1
                                        Thomas Braun Most Active @Jey Cee last edited by Thomas Braun
                                        @Jey-Cee sagte in Test Adapter rtspStream v0.0.x GitHub:
                                        1. Instanz löschen
                                        Thanks! Das hat den Kram rausgekickt. Ich war nicht sicher, ob nicht auch noch in irgendwelchen json Files was geändert werden müsste.
                                        Jey Cee 1 Reply Last reply Reply Quote 1
                                        • Jey Cee
                                          Ich war nicht sicher, ob nicht auch noch in irgendwelchen json Files was geändeet werden müsste.
                                          Nur wenn man die Instanz vorher nicht löscht.
                                            bob der 1. @Jey Cee last edited by
                                            @Jey-Cee
                                            Die Instanz lässt sich bei mir nicht mal löschen!
                                            31.7k
                                            79.8k
                                            rtsp stream
                                            36
                                            157
                                            18654
