    4. Test Adapter rtspStream v0.0.x GitHub
      Thomas Braun Most Active @Bluelinux last edited by
      @Bluelinux
      iobroker del adaptername
      Bluelinux 1 Reply Last reply Reply Quote 0
      • Bluelinux
        Bluelinux @Thomas Braun last edited by
        @Thomas-Braun das klappt leider nicht.... bekomme das kack ding nicht vom iobroker
          @Bluelinux Mit welchen Meldungen aus der Konsole?
          • Bluelinux
            @Thomas-Braun
            iobroker@ioBroker-Debian:~$ iobroker del rtspStream
            Commands:
            iobroker setup [--objects <host>] [--states <host>] [custom]
            iobroker start - starts the js-controller
            iobroker stop - stops the js-controller
            iobroker start <adapter>[.instance] - starts a specified adapter instance
            iobroker stop <adapter>.[instance] - stops a specified adapter instance
            iobroker start all - starts js-controller and all adapters
            iobroker restart - restarts the js-controller
            iobroker restart <adapter>[.instance] - restarts a specified adapter
            iobroker debug <adapter> [--ip=<ip>] [--port=<port>] [--wait] - Starts a Node.js debugging session for the adapter
               --wait stops the execution until the debugger is attached.
               --ip and --port can be used to change the listen IP and port. Use IP 0.0.0.0 for remote debugging.
            iobroker info - shows the host info
            iobroker logs [adapter] [--watch] [--lines=1000]
            iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
            iobroker install <adapter> - installs a specified adapter
            iobroker rebuild <adapter>|self [--install]
            iobroker url <url> [<name>] - install adapter from specified url, e.g. GitHub
            iobroker del <adapter> - remove adapter from system
            iobroker del <adapter>.<instance> - remove adapter instance
            iobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f] - update repository and optionally filter installed/updateable adapters, use --force to bypass hash check
            iobroker upgrade [repository url]
            iobroker upgrade self [repository url] - upgrade js-controller and all adapters, optionally you can specify the repository url
            iobroker upgrade <adapter> [repository url] - upgrade specified adapter, optionally you can specify the repository url
            iobroker upload <pathToLocalFile> <pathIniobroker>
            iobroker upload all - upload all adapter files to make them available for instances
            iobroker upload <adapter> - upload specified adapter files to make them available for instances
            iobroker object get <id> - get object specified by id
            iobroker object set <id> <json-value> - set object with the given id by providing a new json object
            iobroker object set <id> propertyname=<value or json-value> - update part of the object by providing a new value or partial object
            iobroker object extend <id> <json-value> - extend object with the given id by providing a new json object
            iobroker object del <id|pattern> [--yes]
            iobroker object chmod <object-mode> [state-mode] <id>
            iobroker object chown <user> <group> <id>
            iobroker object list <id>
            iobroker state get <id> - get state, specified by id
            iobroker state getplain <id> [--pretty]
            iobroker state getvalue <id>
            iobroker state set <id> <value> [ack]
            iobroker state del <id>
            iobroker message <adapter>[.instance] <command> [<message>]
            iobroker list <type> [filter]
            iobroker chmod <mode> <file>
            iobroker chown <user> <group> <file>
            iobroker touch <file>
            iobroker rm <file>
            iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
            iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
            iobroker file rm <iobroker-path-to-delete>
            iobroker file sync
            iobroker user add <user> [--ingroup group] [--password pass]
            iobroker user del <user>
            iobroker user passwd <user> [--password pass]
            iobroker user enable <user>
            iobroker user disable <user>
            iobroker user get <user>
            iobroker user check <user> [--password pass]
            iobroker group add <group>
            iobroker group del <group>
            iobroker group list <group>
            iobroker group enable <group>
            iobroker group disable <group>
            iobroker group get <group>
            iobroker group adduser <group> <user>
            iobroker group deluser <group> <user>
            iobroker host this
            iobroker host <hostname>
            iobroker host set <hostname>
            iobroker host remove <hostname>
            iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
            iobroker license <license.file or license.text>
            iobroker cert create
            iobroker cert view [<certificate name>]
            iobroker clean
            iobroker backup
            iobroker restore <backup name or path> - restore a specified backup
            iobroker validate <backup name or path> - validate a specified backup
            iobroker <command> --timeout 5000
            iobroker status [all|<adapter>.<instance>]
            iobroker repo [name]
            iobroker repo add <name> <path or url>
            iobroker repo set <name>
            iobroker repo del <name>
            iobroker uuid
            iobroker unsetup
            iobroker fix - execute the installation fixer script, this updates your ioBroker installation
            iobroker multihost <enable|disable> [--secure true|false]
            iobroker multihost browse
            iobroker multihost connect
            iobroker compact status - show if compact mode is enabled in general
            iobroker compact <enable|on|disable|off> - enable or disable compact mode in general
            iobroker compact <adapter>.<instance> status - show if compact mode is enabled for a specific instance
            iobroker compact <adapter>.<instance> group <group-id> - define compact group of a specific adapter
            iobroker compact <adapter>.<instance> <disable|off> - enable or disable compact mode for specified adapter instance
            iobroker compact <adapter>.<instance> <enable|on> [group-id] - enable or disable compact mode for specified adapter instance and set comapct group optionally
            iobroker plugin enable <pluginname> [--host <hostname>] - enables a plugin for the specified host. If no host is specified, the current one is used
            iobroker plugin disable <pluginname> [--host <hostname>] - disables a plugin for the specified host. If no host is specified, the current one is used
            iobroker plugin status <pluginname> [--host <hostname>] - checks if a plugin is enabled for the specified host. If no host is specified, the current one is used
            iobroker plugin enable <pluginname> --instance <adapter>[.<nr>] - enables a plugin for the specified adapter instance (defaults to instance 0)
            iobroker plugin disable <pluginname> --instance <adapter>[.<nr>] - disables a plugin for the specified adapter instance (defaults to instance 0)
            iobroker plugin status <pluginname> --instance <adapter>[.<nr>] - checks if a plugin is enabled for the specified adapter instance (defaults to instance 0)
            iobroker version [adapter] - show version of js-controller or specified adapter
            iobroker [adapter] -v - show version of js-controller or specified adapter
            Options:
             --help     Hilfe anzeigen  [boolean]
             --version  Version anzeigen  [boolean]
            das hier kommt dann
              @Bluelinux
              iobroker list adapters
              • Bluelinux
                @Thomas-Braun
                iobroker@ioBroker-Debian:~$ iobroker list adapters
                system.adapter.admin                   : admin          - v4.1.6
                system.adapter.alexa2                  : alexa2         - v3.3.1
                system.adapter.backitup                : backitup       - v1.6.0
                system.adapter.cloud                   : cloud          - v3.0.4
                system.adapter.daswetter               : daswetter      - v3.0.1
                system.adapter.discovery               : discovery      - v2.3.11
                system.adapter.dwd                     : dwd            - v2.4.10
                system.adapter.firetv                  : firetv         - v1.0.0
                system.adapter.flot                    : flot           - v1.10.2
                system.adapter.fritzbox                : fritzbox       - v0.3.1
                system.adapter.fritzdect               : fritzdect      - v0.3.2
                system.adapter.fullybrowser            : fullybrowser   - v1.0.4
                system.adapter.history                 : history        - v1.9.10
                system.adapter.ical                    : ical           - v1.7.1
                system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
                system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.0.2
                system.adapter.influxdb                : influxdb       - v1.9.2
                system.adapter.info                    : info           - v1.7.7
                system.adapter.iot                     : iot            - v1.7.0
                system.adapter.javascript              : javascript     - v4.6.22
                system.adapter.kodi                    : kodi           - v2.0.4
                system.adapter.mclighting              : mclighting     - v0.1.1
                system.adapter.mihome-vacuum           : mihome-vacuum  - v2.1.1
                system.adapter.moma                    : moma           - v1.2.6
                system.adapter.mqtt                    : mqtt           - v2.1.7
                system.adapter.nina                    : nina           - v0.0.23
                system.adapter.nuc                     : nuc            - v0.1.3
                system.adapter.parser                  : parser         - v1.0.7
                system.adapter.ping                    : ping           - v1.4.8
                system.adapter.proxy                   : proxy          - v1.2.1
                system.adapter.pushover                : pushover       - v2.0.2
                system.adapter.radar2                  : radar2         - v2.0.1
                system.adapter.rpi2                    : rpi2           - v1.2.0
                system.adapter.rtspStream              : rtspStream     - v0.0.2
                system.adapter.samsung                 : samsung        - v0.2.9
                system.adapter.simple-api              : simple-api     - v2.4.6
                system.adapter.socketio                : socketio       - v3.0.12
                system.adapter.sonoff                  : sonoff         - v2.3.3
                system.adapter.sql                     : sql            - v1.15.2
                system.adapter.synology                : synology       - v0.1.18
                system.adapter.systeminfo              : systeminfo     - v0.3.1
                system.adapter.tankerkoenig            : tankerkoenig   - v2.0.9
                system.adapter.telegram                : telegram       - v1.5.9
                system.adapter.text2command            : text2command   - v2.0.3
                system.adapter.tr-064                  : tr-064         - v4.0.12
                system.adapter.upnp                    : upnp           - v1.0.16
                system.adapter.vis                     : vis            - v1.2.6
                system.adapter.vis-bars                : vis-bars       - v0.1.4
                system.adapter.vis-colorpicker         : vis-colorpicker - v1.2.0
                system.adapter.vis-google-fonts        : vis-google-fonts - v1.0.0
                system.adapter.vis-history             : vis-history    - v1.0.0
                system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.5
                system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
                system.adapter.vis-justgage            : vis-justgage   - v1.0.2
                system.adapter.vis-material            : vis-material   - v0.1.3
                system.adapter.vis-material-webfont    : vis-material-webfont - v0.0.3
                system.adapter.vis-materialdesign      : vis-materialdesign - v0.3.19
                system.adapter.vis-metro               : vis-metro      - v1.1.2
                system.adapter.vis-players             : vis-players    - v0.1.6
                system.adapter.vis-rgraph              : vis-rgraph     - v0.0.2
                system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                system.adapter.web                     : web            - v3.0.10
                system.adapter.web-speedy              : web-speedy     - v0.2.0
                system.adapter.wifilight               : wifilight      - v1.1.0
                system.adapter.wled                    : wled           - v0.5.0
                system.adapter.yahka                   : yahka          - v0.11.0
                system.adapter.yr                      : yr             - v2.0.3
                system.adapter.zigbee                  : zigbee         - v1.2.0
                  @Bluelinux Keine Ahnung. Hat evtl. mit dem Großbuchstaben im Adapternamen zutun. Das wird vielleicht falsch interpretiert. Jedenfalls reagiert die Konsole, als sei der Befehl nicht komplett. Allerdings funktioniert eine Deinstallation über npm auch nicht.
                  Bluelinux Thomas Braun 2 Replies Last reply Reply Quote 0
                  • Bluelinux
                    @Thomas-Braun hmmm na das ist ja echt merkwürdig oder??? nervt mich total das ich da so einen toten adapter habe .... schade aber danke für deine hilfe
                    B Thomas Braun 2 Replies Last reply Reply Quote 0
                      bob der 1. @Bluelinux last edited by
                      @Bluelinux
                      Der Entwickler sollte das lösen odet man sollte von der Adminseite den 1 Post editieren das er sich nicht deinstallieren lässt.
                      Bekekomme ihn auch nicht vom Broker,finde es abet nicht so wild.Weis aber das ich sicherlich von diesem Entwickler nichts mehr nutue solange er es nicht löst
                        bob der 1. @bob der 1. last edited by
                        @bob-der-1 sagte in Test Adapter rtspStream v0.0.x GitHub:
                        @Bluelinux
                        Der Entwickler sollte das lösen oder man sollte von der Adminseite den 1.Post editieren das er sich nicht deinstallieren lässt.
                        Bekomme ihn auch nicht vom Broker,finde es abet nicht so wild.Weis aber das ich sicherlich von diesem Entwickler nichts mehr nutue solange er es nicht löst.
                          @Bluelinux Gibt ein issue dazu im git.
                          • Bluelinux
                            @Thomas-Braun ja aber da gibt es ja auch leider keine antwort so wie ich das sehe.... wirklich schade.....
                              @Bluelinux Zumindest ist es geloggt.
                                Thomas Braun Most Active @Thomas Braun last edited by
                                @Thomas-Braun sagte in Test Adapter rtspStream v0.0.x GitHub:
                                @apollon77 Hast du da vielleicht noxh einen magischen npm-Befehl in petto? Mit den mir bekannten Dingen bekomme ich den Adapter nicht deinstalliert.
                                • Jey Cee
                                  Jey Cee Developer @Thomas Braun last edited by
                                  @Thomas-Braun ich bin zwar nicht @apollon77, aber hab da noch ne idee:
                                  1. Instanz löschen
                                  2. per SSH auf den host verbinden
                                  3. in den Ordner node_modules im ioBroker Verzeichnis gehen
                                  4. sudo rm -R iobroker.rtspStream
                                  5. ioBroker neustarten
                                  Das sollte den Adapter Vollständig entfernen.
                                  Thomas Braun Bluelinux 2 Replies Last reply Reply Quote 1
                                    Thomas Braun Most Active @Jey Cee last edited by Thomas Braun
                                    @Jey-Cee sagte in Test Adapter rtspStream v0.0.x GitHub:
                                    1. Instanz löschen
                                    Thanks! Das hat den Kram rausgekickt. Ich war nicht sicher, ob nicht auch noch in irgendwelchen json Files was geändert werden müsste.
                                    Jey Cee 1 Reply Last reply Reply Quote 1
                                    • Jey Cee
                                      Ich war nicht sicher, ob nicht auch noch in irgendwelchen json Files was geändeet werden müsste.
                                      Nur wenn man die Instanz vorher nicht löscht.
                                        bob der 1. @Jey Cee last edited by
                                        @Jey-Cee
                                        Die Instanz lässt sich bei mir nicht mal löschen!
                                        • Bluelinux
                                          Bluelinux @Jey Cee last edited by
                                          @Jey-Cee bei mir kappt das leider nicht
                                          • Jey Cee
                                            Dann löscht mal alle Objekte von Hand.
                                            Anschließend schaltet ihr den Expertenmodus ein und sucht nach system.adapter.rtspStream und löscht die Objekte dort auch.
                                            Bluelinux B Thomas Braun 3 Replies Last reply Reply Quote 1
                                            31.7k
                                            79.8k
                                            rtsp stream
                                            36
                                            157
                                            18681
