    4. Test Adapter rtspStream v0.0.x GitHub
    • Bluelinux
      Bluelinux @Thomas Braun last edited by
      @Thomas-Braun das klappt leider nicht.... bekomme das kack ding nicht vom iobroker
        Thomas Braun Most Active @Bluelinux last edited by
        @Bluelinux Mit welchen Meldungen aus der Konsole?
        Bluelinux 1 Reply Last reply Reply Quote 0
        • Bluelinux
          @Thomas-Braun
          iobroker@ioBroker-Debian:~$ iobroker del rtspStream
          Commands:
          iobroker setup [--objects <host>] [--states <host>] [custom]
          iobroker start - starts the js-controller
          iobroker stop - stops the js-controller
          iobroker start <adapter>[.instance] - starts a specified adapter instance
          iobroker stop <adapter>.[instance] - stops a specified adapter instance
          iobroker start all - starts js-controller and all adapters
          iobroker restart - restarts the js-controller
          iobroker restart <adapter>[.instance] - restarts a specified adapter
          iobroker debug <adapter> [--ip=<ip>] [--port=<port>] [--wait] - Starts a Node.js debugging session for the adapter
             --wait stops the execution until the debugger is attached.
             --ip and --port can be used to change the listen IP and port. Use IP 0.0.0.0 for remote debugging.
          iobroker info - shows the host info
          iobroker logs [adapter] [--watch] [--lines=1000]
          iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
          iobroker install <adapter> - installs a specified adapter
          iobroker rebuild <adapter>|self [--install]
          iobroker url <url> [<name>] - install adapter from specified url, e.g. GitHub
          iobroker del <adapter> - remove adapter from system
          iobroker del <adapter>.<instance> - remove adapter instance
          iobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f] - update repository and optionally filter installed/updateable adapters, use --force to bypass hash check
          iobroker upgrade [repository url]
          iobroker upgrade self [repository url] - upgrade js-controller and all adapters, optionally you can specify the repository url
          iobroker upgrade <adapter> [repository url] - upgrade specified adapter, optionally you can specify the repository url
          iobroker upload <pathToLocalFile> <pathIniobroker>
          iobroker upload all - upload all adapter files to make them available for instances
          iobroker upload <adapter> - upload specified adapter files to make them available for instances
          iobroker object get <id> - get object specified by id
          iobroker object set <id> <json-value> - set object with the given id by providing a new json object
          iobroker object set <id> propertyname=<value or json-value> - update part of the object by providing a new value or partial object
          iobroker object extend <id> <json-value> - extend object with the given id by providing a new json object
          iobroker object del <id|pattern> [--yes]
          iobroker object chmod <object-mode> [state-mode] <id>
          iobroker object chown <user> <group> <id>
          iobroker object list <id>
          iobroker state get <id> - get state, specified by id
          iobroker state getplain <id> [--pretty]
          iobroker state getvalue <id>
          iobroker state set <id> <value> [ack]
          iobroker state del <id>
          iobroker message <adapter>[.instance] <command> [<message>]
          iobroker list <type> [filter]
          iobroker chmod <mode> <file>
          iobroker chown <user> <group> <file>
          iobroker touch <file>
          iobroker rm <file>
          iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
          iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
          iobroker file rm <iobroker-path-to-delete>
          iobroker file sync
          iobroker user add <user> [--ingroup group] [--password pass]
          iobroker user del <user>
          iobroker user passwd <user> [--password pass]
          iobroker user enable <user>
          iobroker user disable <user>
          iobroker user get <user>
          iobroker user check <user> [--password pass]
          iobroker group add <group>
          iobroker group del <group>
          iobroker group list <group>
          iobroker group enable <group>
          iobroker group disable <group>
          iobroker group get <group>
          iobroker group adduser <group> <user>
          iobroker group deluser <group> <user>
          iobroker host this
          iobroker host <hostname>
          iobroker host set <hostname>
          iobroker host remove <hostname>
          iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
          iobroker license <license.file or license.text>
          iobroker cert create
          iobroker cert view [<certificate name>]
          iobroker clean
          iobroker backup
          iobroker restore <backup name or path> - restore a specified backup
          iobroker validate <backup name or path> - validate a specified backup
          iobroker <command> --timeout 5000
          iobroker status [all|<adapter>.<instance>]
          iobroker repo [name]
          iobroker repo add <name> <path or url>
          iobroker repo set <name>
          iobroker repo del <name>
          iobroker uuid
          iobroker unsetup
          iobroker fix - execute the installation fixer script, this updates your ioBroker installation
          iobroker multihost <enable|disable> [--secure true|false]
          iobroker multihost browse
          iobroker multihost connect
          iobroker compact status - show if compact mode is enabled in general
          iobroker compact <enable|on|disable|off> - enable or disable compact mode in general
          iobroker compact <adapter>.<instance> status - show if compact mode is enabled for a specific instance
          iobroker compact <adapter>.<instance> group <group-id> - define compact group of a specific adapter
          iobroker compact <adapter>.<instance> <disable|off> - enable or disable compact mode for specified adapter instance
          iobroker compact <adapter>.<instance> <enable|on> [group-id] - enable or disable compact mode for specified adapter instance and set comapct group optionally
          iobroker plugin enable <pluginname> [--host <hostname>] - enables a plugin for the specified host. If no host is specified, the current one is used
          iobroker plugin disable <pluginname> [--host <hostname>] - disables a plugin for the specified host. If no host is specified, the current one is used
          iobroker plugin status <pluginname> [--host <hostname>] - checks if a plugin is enabled for the specified host. If no host is specified, the current one is used
          iobroker plugin enable <pluginname> --instance <adapter>[.<nr>] - enables a plugin for the specified adapter instance (defaults to instance 0)
          iobroker plugin disable <pluginname> --instance <adapter>[.<nr>] - disables a plugin for the specified adapter instance (defaults to instance 0)
          iobroker plugin status <pluginname> --instance <adapter>[.<nr>] - checks if a plugin is enabled for the specified adapter instance (defaults to instance 0)
          iobroker version [adapter] - show version of js-controller or specified adapter
          iobroker [adapter] -v - show version of js-controller or specified adapter
          Options:
           --help     Hilfe anzeigen  [boolean]
           --version  Version anzeigen  [boolean]
          das hier kommt dann
            @Bluelinux
            iobroker list adapters
            • Bluelinux
              @Thomas-Braun
              iobroker@ioBroker-Debian:~$ iobroker list adapters
              system.adapter.admin                   : admin          - v4.1.6
              system.adapter.alexa2                  : alexa2         - v3.3.1
              system.adapter.backitup                : backitup       - v1.6.0
              system.adapter.cloud                   : cloud          - v3.0.4
              system.adapter.daswetter               : daswetter      - v3.0.1
              system.adapter.discovery               : discovery      - v2.3.11
              system.adapter.dwd                     : dwd            - v2.4.10
              system.adapter.firetv                  : firetv         - v1.0.0
              system.adapter.flot                    : flot           - v1.10.2
              system.adapter.fritzbox                : fritzbox       - v0.3.1
              system.adapter.fritzdect               : fritzdect      - v0.3.2
              system.adapter.fullybrowser            : fullybrowser   - v1.0.4
              system.adapter.history                 : history        - v1.9.10
              system.adapter.ical                    : ical           - v1.7.1
              system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
              system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.0.2
              system.adapter.influxdb                : influxdb       - v1.9.2
              system.adapter.info                    : info           - v1.7.7
              system.adapter.iot                     : iot            - v1.7.0
              system.adapter.javascript              : javascript     - v4.6.22
              system.adapter.kodi                    : kodi           - v2.0.4
              system.adapter.mclighting              : mclighting     - v0.1.1
              system.adapter.mihome-vacuum           : mihome-vacuum  - v2.1.1
              system.adapter.moma                    : moma           - v1.2.6
              system.adapter.mqtt                    : mqtt           - v2.1.7
              system.adapter.nina                    : nina           - v0.0.23
              system.adapter.nuc                     : nuc            - v0.1.3
              system.adapter.parser                  : parser         - v1.0.7
              system.adapter.ping                    : ping           - v1.4.8
              system.adapter.proxy                   : proxy          - v1.2.1
              system.adapter.pushover                : pushover       - v2.0.2
              system.adapter.radar2                  : radar2         - v2.0.1
              system.adapter.rpi2                    : rpi2           - v1.2.0
              system.adapter.rtspStream              : rtspStream     - v0.0.2
              system.adapter.samsung                 : samsung        - v0.2.9
              system.adapter.simple-api              : simple-api     - v2.4.6
              system.adapter.socketio                : socketio       - v3.0.12
              system.adapter.sonoff                  : sonoff         - v2.3.3
              system.adapter.sql                     : sql            - v1.15.2
              system.adapter.synology                : synology       - v0.1.18
              system.adapter.systeminfo              : systeminfo     - v0.3.1
              system.adapter.tankerkoenig            : tankerkoenig   - v2.0.9
              system.adapter.telegram                : telegram       - v1.5.9
              system.adapter.text2command            : text2command   - v2.0.3
              system.adapter.tr-064                  : tr-064         - v4.0.12
              system.adapter.upnp                    : upnp           - v1.0.16
              system.adapter.vis                     : vis            - v1.2.6
              system.adapter.vis-bars                : vis-bars       - v0.1.4
              system.adapter.vis-colorpicker         : vis-colorpicker - v1.2.0
              system.adapter.vis-google-fonts        : vis-google-fonts - v1.0.0
              system.adapter.vis-history             : vis-history    - v1.0.0
              system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.5
              system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
              system.adapter.vis-justgage            : vis-justgage   - v1.0.2
              system.adapter.vis-material            : vis-material   - v0.1.3
              system.adapter.vis-material-webfont    : vis-material-webfont - v0.0.3
              system.adapter.vis-materialdesign      : vis-materialdesign - v0.3.19
              system.adapter.vis-metro               : vis-metro      - v1.1.2
              system.adapter.vis-players             : vis-players    - v0.1.6
              system.adapter.vis-rgraph              : vis-rgraph     - v0.0.2
              system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
              system.adapter.web                     : web            - v3.0.10
              system.adapter.web-speedy              : web-speedy     - v0.2.0
              system.adapter.wifilight               : wifilight      - v1.1.0
              system.adapter.wled                    : wled           - v0.5.0
              system.adapter.yahka                   : yahka          - v0.11.0
              system.adapter.yr                      : yr             - v2.0.3
              system.adapter.zigbee                  : zigbee         - v1.2.0
                @Bluelinux Keine Ahnung. Hat evtl. mit dem Großbuchstaben im Adapternamen zutun. Das wird vielleicht falsch interpretiert. Jedenfalls reagiert die Konsole, als sei der Befehl nicht komplett. Allerdings funktioniert eine Deinstallation über npm auch nicht.
                Bluelinux Thomas Braun 2 Replies Last reply Reply Quote 0
                • Bluelinux
                  @Thomas-Braun hmmm na das ist ja echt merkwürdig oder??? nervt mich total das ich da so einen toten adapter habe .... schade aber danke für deine hilfe
                  B Thomas Braun 2 Replies Last reply Reply Quote 0
                    bob der 1. @Bluelinux last edited by
                    @Bluelinux
                    Der Entwickler sollte das lösen odet man sollte von der Adminseite den 1 Post editieren das er sich nicht deinstallieren lässt.
                    Bekekomme ihn auch nicht vom Broker,finde es abet nicht so wild.Weis aber das ich sicherlich von diesem Entwickler nichts mehr nutue solange er es nicht löst
                      bob der 1. @bob der 1. last edited by
                      @bob-der-1 sagte in Test Adapter rtspStream v0.0.x GitHub:
                      @Bluelinux
                      Der Entwickler sollte das lösen oder man sollte von der Adminseite den 1.Post editieren das er sich nicht deinstallieren lässt.
                      Bekomme ihn auch nicht vom Broker,finde es abet nicht so wild.Weis aber das ich sicherlich von diesem Entwickler nichts mehr nutue solange er es nicht löst.
                        @Bluelinux Gibt ein issue dazu im git.
                        • Bluelinux
                          @Thomas-Braun ja aber da gibt es ja auch leider keine antwort so wie ich das sehe.... wirklich schade.....
                            @Bluelinux Zumindest ist es geloggt.
                              Thomas Braun Most Active @Thomas Braun last edited by
                              @Thomas-Braun sagte in Test Adapter rtspStream v0.0.x GitHub:
                              @apollon77 Hast du da vielleicht noxh einen magischen npm-Befehl in petto? Mit den mir bekannten Dingen bekomme ich den Adapter nicht deinstalliert.
                              • Jey Cee
                                Jey Cee Developer @Thomas Braun last edited by
                                @Thomas-Braun ich bin zwar nicht @apollon77, aber hab da noch ne idee:
                                1. Instanz löschen
                                2. per SSH auf den host verbinden
                                3. in den Ordner node_modules im ioBroker Verzeichnis gehen
                                4. sudo rm -R iobroker.rtspStream
                                5. ioBroker neustarten
                                Das sollte den Adapter Vollständig entfernen.
                                Thomas Braun Bluelinux 2 Replies Last reply Reply Quote 1
                                  Thomas Braun Most Active @Jey Cee last edited by Thomas Braun
                                  @Jey-Cee sagte in Test Adapter rtspStream v0.0.x GitHub:
                                  1. Instanz löschen
                                  Thanks! Das hat den Kram rausgekickt. Ich war nicht sicher, ob nicht auch noch in irgendwelchen json Files was geändert werden müsste.
                                  Jey Cee 1 Reply Last reply Reply Quote 1
                                  • Jey Cee
                                    Ich war nicht sicher, ob nicht auch noch in irgendwelchen json Files was geändeet werden müsste.
                                    Nur wenn man die Instanz vorher nicht löscht.
                                      bob der 1. @Jey Cee last edited by
                                      @Jey-Cee
                                      Die Instanz lässt sich bei mir nicht mal löschen!
                                      • Bluelinux
                                        Bluelinux @Jey Cee last edited by
                                        @Jey-Cee bei mir kappt das leider nicht
                                        • Jey Cee
                                          Dann löscht mal alle Objekte von Hand.
                                          Anschließend schaltet ihr den Expertenmodus ein und sucht nach system.adapter.rtspStream und löscht die Objekte dort auch.
                                          Bluelinux B Thomas Braun 3 Replies Last reply Reply Quote 1
                                          • Bluelinux
                                            @Jey-Cee spitzenmäßig.... jetzt hat es geklappt... alles wech... dankeschön
                                            31.7k
                                            79.8k
                                            rtsp stream
                                            36
                                            157
                                            18654
