    4. Test Adapter Linux Control v1.x.x
      Homoran Global Moderator Administrators @Scrounger last edited by
      @Scrounger sagte in Test Adapter Linux Control v0.x.x:
      @Homoran
      Hab noch was eingebaut, bitte teste mal die aktuelle github version
      Habe neu installiert - upload gemacht und Instanz sicherheitshalber nochmal gestartet.
      steht immer noch null drin
      Hier das leider sehr umfangreiche debug log:
      2020-08-16 10:37:56.204  - info: linux-control.0 (24751) getting data from RasPi4 (192.168.138.139:22)
      2020-08-16 10:37:56.257  - debug: linux-control.0 (24751) [getConnection] Host 'RasPi4' (192.168.138.139:22): using sudo for authentification
      2020-08-16 10:37:56.428  - debug: linux-control.0 (24751) [distributionInfo] RasPi4 (192.168.138.139:22): send command: 'cat /etc/os-release'
      2020-08-16 10:37:56.732  - debug: linux-control.0 (24751) [distributionInfo] RasPi4 (192.168.138.139:22): response stdout: PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="10"
      VERSION="10 (buster)"
      VERSION_CODENAME=buster
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      2020-08-16 10:37:56.735  - debug: linux-control.0 (24751) [distributionInfo] RasPi4 (192.168.138.139:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Raspbian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Raspbian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"raspbian"},{"prop":"ID_LIKE","val":"debian"},{"prop":"HOME_URL","val":"http://www.raspbian.org/"},{"prop":"SUPPORT_URL","val":"http://www.raspbian.org/RaspbianForums"},{"prop":"BUG_REPORT_URL","val":"http://www.raspbian.org/RaspbianBugs"}]
      2020-08-16 10:37:56.752  - debug: linux-control.0 (24751) [cmdAptUpdate] RasPi4 (192.168.138.139:22): no datapoints selected -> removing existing datapoints
      2020-08-16 10:37:56.755  - debug: linux-control.0 (24751) [servicesInfo] RasPi4 (192.168.138.139:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
      2020-08-16 10:37:56.780  - debug: linux-control.0 (24751) [servicesInfo] RasPi4 (192.168.138.139:22): response stdout: alsa-restore.service,loaded,active,exited, Save/Restore Sound Card State
      alsa-state.service,loaded,active,running, Manage Sound Card State (restore and store)
      apparmor.service,not-found,inactive,dead, apparmor.service
      apt-daily-upgrade.service,loaded,inactive,dead, Daily apt upgrade and clean activities
      apt-daily.service,loaded,inactive,dead, Daily apt download activities
      auditd.service,not-found,inactive,dead, auditd.service
      auth-rpcgss-module.service,loaded,inactive,dead, Kernel Module supporting RPCSEC_GSS
      avahi-daemon.service,loaded,active,running, Avahi mDNS/DNS-SD Stack
      bluetooth.service,loaded,active,running, Bluetooth service
      bthelper@hci0.service,loaded,inactive,dead, Raspberry Pi bluetooth helper
      connman.service,not-found,inactive,dead, connman.service
      console-screen.service,not-found,inactive,dead, console-screen.service
      console-setup.service,loaded,active,exited, Set console font and keymap
      cron.service,loaded,active,running, Regular background program processing daemon
      dbus.service,loaded,active,running, D-Bus System Message Bus
      dhcpcd.service,loaded,active,running, dhcpcd on all interfaces
      display-manager.service,not-found,inactive,dead, display-manager.service
      dphys-swapfile.service,loaded,active,exited, dphys-swapfile - set up, mount/unmount, and delete a swap file
      emergency.service,loaded,inactive,dead, Emergency Shell
      fake-hwclock.service,loaded,active,exited, Restore / save the current clock
      getty-static.service,loaded,inactive,dead, getty on tty2-tty6 if dbus and logind are not available
      getty@tty1.service,loaded,active,running, Getty on tty1
      gssproxy.service,not-found,inactive,dead, gssproxy.service
      hciuart.service,loaded,active,running, Configure Bluetooth Modems connected by UART
      ifupdown-pre.service,loaded,active,exited, Helper to synchronize boot up for ifupdown
      influxdb.service,not-found,inactive,dead, influxdb.service
      iobroker.service,loaded,active,running, ioBroker Server
      kbd.service,not-found,inactive,dead, kbd.service
      keyboard-setup.service,loaded,active,exited, Set the console keyboard layout
      kmod-static-nodes.service,loaded,active,exited, Create list of required static device nodes for the current kernel
      logrotate.service,loaded,inactive,dead, Rotate log files
      man-db.service,loaded,inactive,dead, Daily man-db regeneration
      mariadb-server.service,not-found,inactive,dead, mariadb-server.service
      mountkernfs.service,masked,inactive,dead, mountkernfs.service
      mysql-server.service,not-found,inactive,dead, mysql-server.service
      networking.service,loaded,active,exited, Raise network interfaces
      NetworkManager.service,not-found,inactive,dead, NetworkManager.service
      nfs-blkmap.service,not-found,inactive,dead, nfs-blkmap.service
      nfs-config.service,loaded,inactive,dead, Preprocess NFS configuration
      nfs-server.service,not-found,inactive,dead, nfs-server.service
      nfs-utils.service,loaded,inactive,dead, NFS server and client services
      plymouth-quit-wait.service,not-found,inactive,dead, plymouth-quit-wait.service
      plymouth-start.service,not-found,inactive,dead, plymouth-start.service
      raspberrypi-net-mods.service,loaded,inactive,dead, Copy user wpa_supplicant.conf
      raspi-config.service,loaded,active,exited, LSB: Switch to ondemand cpu governor (unless shift key is pressed)
      rc-local.service,loaded,active,exited, /etc/rc.local Compatibility
      redis.service,not-found,inactive,dead, redis.service
      regenerate_ssh_host_keys.service,loaded,inactive,dead, Regenerate SSH host keys
      rescue.service,loaded,inactive,dead, Rescue Shell
      rng-tools.service,loaded,active,running, rng-tools.service
      rpc-gssd.service,loaded,inactive,dead, RPC security service for NFS client and server
      rpc-svcgssd.service,loaded,inactive,dead, RPC security service for NFS server
      rpi-eeprom-update.service,loaded,active,exited, Check for Raspberry Pi EEPROM updates
      rsync.service,loaded,inactive,dead, fast remote file copy program daemon
      rsyslog.service,loaded,active,running, System Logging Service
      ssh.service,loaded,active,running, OpenBSD Secure Shell server
      sshswitch.service,loaded,inactive,dead, Turn on SSH if /boot/ssh is present
      systemd-ask-password-console.service,loaded,inactive,dead, Dispatch Password Requests to Console
      systemd-ask-password-wall.service,loaded,inactive,dead, Forward Password Requests to Wall
      systemd-binfmt.service,loaded,inactive,dead, Set Up Additional Binary Formats
      systemd-fsck-root.service,loaded,active,exited, File System Check on Root Device
      systemd-fsck@dev-disk-by\x2dpartuuid-50fbae26\x2d01.service,loaded,active,exited, File System Check on /dev/disk/by-partuuid/50fbae26-01
      systemd-fsckd.service,loaded,inactive,dead, File System Check Daemon to report status
      systemd-hwdb-update.service,loaded,inactive,dead, Rebuild Hardware Database
      systemd-initctl.service,loaded,inactive,dead, initctl Compatibility Daemon
      systemd-journal-flush.service,loaded,active,exited, Flush Journal to Persistent Storage
      systemd-journald.service,loaded,active,running, Journal Service
      systemd-logind.service,loaded,active,running, Login Service
      systemd-machine-id-commit.service,loaded,inactive,dead, Commit a transient machine-id on disk
      systemd-modules-load.service,loaded,active,exited, Load Kernel Modules
      systemd-networkd.service,loaded,inactive,dead, Network Service
      systemd-quotacheck.service,loaded,inactive,dead, File System Quota Check
      systemd-random-seed.service,loaded,active,exited, Load/Save Random Seed
      systemd-remount-fs.service,loaded,active,exited, Remount Root and Kernel File Systems
      systemd-rfkill.service,loaded,inactive,dead, Load/Save RF Kill Switch Status
      systemd-sysctl.service,loaded,active,exited, Apply Kernel Variables
      systemd-sysusers.service,loaded,active,exited, Create System Users
      systemd-timesyncd.service,loaded,active,running, Network Time Synchronization
      systemd-tmpfiles-clean.service,loaded,inactive,dead, Cleanup of Temporary Directories
      systemd-tmpfiles-setup-dev.service,loaded,active,exited, Create Static Device Nodes in /dev
      systemd-tmpfiles-setup.service,loaded,active,exited, Create Volatile Files and Directories
      systemd-udev-trigger.service,loaded,active,exited, udev Coldplug all Devices
      systemd-udevd.service,loaded,active,running, udev Kernel Device Manager
      systemd-update-done.service,not-found,inactive,dead, systemd-update-done.service
      systemd-update-utmp-runlevel.service,loaded,inactive,dead, Update UTMP about System Runlevel Changes
      systemd-update-utmp.service,loaded,active,exited, Update UTMP about System Boot/Shutdown
      systemd-user-sessions.service,loaded,active,exited, Permit User Sessions
      systemd-vconsole-setup.service,not-found,inactive,dead, systemd-vconsole-setup.service
      triggerhappy.service,loaded,active,running, triggerhappy global hotkey daemon
      user-runtime-dir@1000.service,loaded,active,exited, User Runtime Directory /run/user/1000
      user@1000.service,loaded,active,running, User Manager for UID 1000
      wpa_supplicant.service,loaded,active,running, WPA supplicant
      2020-08-16 10:37:56.785  - debug: linux-control.0 (24751) [servicesInfo] RasPi4 (192.168.138.139:22): csvToJson result: [{"id":"alsa-restore.service","load":"loaded","active":"active","running":"exited","description":"Save/Restore Sound Card State"},{"id":"alsa-state.service","load":"loaded","active":"active","running":"running","description":"Manage Sound Card State (restore and store)"},{"id":"apparmor.service","load":"not-found","active":"inactive","running":"dead","description":"apparmor.service"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"avahi-daemon.service","load":"loaded","active":"active","running":"running","description":"Avahi mDNS/DNS-SD Stack"},{"id":"bluetooth.service","load":"loaded","active":"active","running":"running","description":"Bluetooth service"},{"id":"bthelper@hci0.service","load":"loaded","active":"inactive","running":"dead","description":"Raspberry Pi bluetooth helper"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"dhcpcd.service","load":"loaded","active":"active","running":"running","description":"dhcpcd on all interfaces"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"dphys-swapfile.service","load":"loaded","active":"active","running":"exited","description":"dphys-swapfile - set up","field6":"mount/unmount","field7":"and delete a swap file"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"fake-hwclock.service","load":"loaded","active":"active","running":"exited","description":"Restore / save the current clock"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"hciuart.service","load":"loaded","active":"active","running":"running","description":"Configure Bluetooth Modems connected by UART"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mountkernfs.service","load":"masked","active":"inactive","running":"dead","description":"mountkernfs.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"raspberrypi-net-mods.service","load":"loaded","active":"inactive","running":"dead","description":"Copy user wpa_supplicant.conf"},{"id":"raspi-config.service","load":"loaded","active":"active","running":"exited","description":"LSB: Switch to ondemand cpu governor (unless shift key is pressed)"},{"id":"rc-local.service","load":"loaded","active":"active","running":"exited","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"regenerate_ssh_host_keys.service","load":"loaded","active":"inactive","running":"dead","description":"Regenerate SSH host keys"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rng-tools.service","load":"loaded","active":"active","running":"running","description":"rng-tools.service"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpi-eeprom-update.service","load":"loaded","active":"active","running":"exited","description":"Check for Raspberry Pi EEPROM updates"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"sshswitch.service","load":"loaded","active":"inactive","running":"dead","description":"Turn on SSH if /boot/ssh is present"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"active","running":"exited","description":"File System Check on Root Device"},{"id":"systemd-fsck@dev-disk-by\\x2dpartuuid-50fbae26\\x2d01.service","load":"loaded","active":"active","running":"exited","description":"File System Check on /dev/disk/by-partuuid/50fbae26-01"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-quotacheck.service","load":"loaded","active":"inactive","running":"dead","description":"File System Quota Check"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"active","running":"running","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"triggerhappy.service","load":"loaded","active":"active","running":"running","description":"triggerhappy global hotkey daemon"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"},{"id":"wpa_supplicant.service","load":"loaded","active":"active","running":"running","description":"WPA supplicant"}]
      2020-08-16 10:37:57.213  - debug: linux-control.0 (24751) [needrestart] RasPi4 (192.168.138.139:22): no datapoints selected -> removing existing datapoints
      2020-08-16 10:37:57.231  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'sudo du -sk /opt/iobroker/iobroker-data/history | awk '{ print $1 /1024 }' | tail -1'
      2020-08-16 10:37:57.464  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): response stdout:
      195.422
      2020-08-16 10:37:57.466  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.size: 195.42 MB
      2020-08-16 10:37:57.469  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'sudo find /opt/iobroker/iobroker-data/history -name "*" | wc -l | tail -1'
      2020-08-16 10:37:57.674  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): response stdout:
      22286
      2020-08-16 10:37:57.675  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.files: 22286 Dateien
      2020-08-16 10:37:57.679  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): send command: 'tmp=$(sudo find /opt/iobroker/iobroker-data/history -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}' | tail -1) && date +%s -r $tmp'
      2020-08-16 10:39:35.043  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): response stdout:
      1597567063
      2020-08-16 10:39:35.044  - debug: linux-control.0 (24751) [folderSizes] RasPi4 (192.168.138.139:22): RasPi4.folders.history.lastChange: 1597567063000 -> 16.08.2020 10:37
      2020-08-16 10:39:35.048  - debug: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
      2020-08-16 10:39:35.066  - debug: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: root, description: ): response stdout: 19
      2020-08-16 10:39:35.070  - debug: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1'
      2020-08-16 10:39:35.091  - debug: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: ip, description: ): response stdout: 192.168.138.139
      2020-08-16 10:39:35.096  - debug: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: cpu-temp, description: ): send command: 'vcgencmd measure_temp | awk '{print substr($1, length($0)-5,4)}''
      2020-08-16 10:39:35.112  - debug: linux-control.0 (24751) [userCommand] RasPi4 (192.168.138.139:22, id: cpu-temp, description: ): response stdout: 55.0
      2020-08-16 10:39:35.117  - info: linux-control.0 (24751) successful received data from RasPi4 (192.168.138.139:22)
      2020-08-16 10:40:00.035  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 5509
      2020-08-16 10:40:03.867  - info: dwd.0 (5509) starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.21.0, js-controller: 3.1.4
      2020-08-16 10:40:05.425  - info: dwd.0 (5509) Terminated (NO_ERROR): Without reason
      2020-08-16 10:40:05.952  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
      2020-08-16 10:40:20.852  - info: linux-control.0 (24751) getting data from NUC_VM (192.168.138.123:22)
      2020-08-16 10:40:20.886  - debug: linux-control.0 (24751) [getConnection] Host 'NUC_VM' (192.168.138.123:22): using sudo for authentification
      2020-08-16 10:40:20.969  - debug: linux-control.0 (24751) [distributionInfo] NUC_VM (192.168.138.123:22): send command: 'cat /etc/os-release'
      2020-08-16 10:40:21.025  - debug: linux-control.0 (24751) [distributionInfo] NUC_VM (192.168.138.123:22): response stdout: PRETTY_NAME="Debian GNU/Linux 10 (buster)"
      NAME="Debian GNU/Linux"
      VERSION_ID="10"
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      2020-08-16 10:40:21.028  - debug: linux-control.0 (24751) [distributionInfo] NUC_VM (192.168.138.123:22): csvToJson result: [{"prop":"PRETTY_NAME","val":"Debian GNU/Linux 10 (buster)"},{"prop":"NAME","val":"Debian GNU/Linux"},{"prop":"VERSION_ID","val":"10"},{"prop":"VERSION","val":"10 (buster)"},{"prop":"VERSION_CODENAME","val":"buster"},{"prop":"ID","val":"debian"},{"prop":"HOME_URL","val":"https://www.debian.org/"},{"prop":"SUPPORT_URL","val":"https://www.debian.org/support"},{"prop":"BUG_REPORT_URL","val":"https://bugs.debian.org/"}]
      2020-08-16 10:40:21.045  - debug: linux-control.0 (24751) [cmdAptUpdate] NUC_VM (192.168.138.123:22): no datapoints selected -> removing existing datapoints
      2020-08-16 10:40:21.049  - debug: linux-control.0 (24751) [servicesInfo] NUC_VM (192.168.138.123:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
      2020-08-16 10:40:21.060  - debug: linux-control.0 (24751) [servicesInfo] NUC_VM (192.168.138.123:22): response stdout: apache2.service,loaded,active,running, The Apache HTTP Server
      apparmor.service,loaded,active,exited, Load AppArmor profiles
      clamav-daemon.service,not-found,inactive,dead, clamav-daemon.service
      cups-browsed.service,loaded,failed,failed, Make remote CUPS printers available locally
      cups.service,loaded,active,running, CUPS Scheduler
      exim4.service,loaded,active,running, LSB: exim Mail Transport Agent
      greylist.service,not-found,inactive,dead, greylist.service
      ifup@ens18.service,loaded,active,exited, ifup for ens18
      irqbalance.service,loaded,active,running, irqbalance daemon
      mysql.service,not-found,inactive,dead, mysql.service
      ntp.service,loaded,active,running, Network Time Service
      postgresql.service,not-found,inactive,dead, postgresql.service
      rc-local.service,loaded,inactive,dead, /etc/rc.local Compatibility
      rpcbind.service,loaded,active,running, RPC bind portmap service
      spamassassin.service,not-found,inactive,dead, spamassassin.service
      systemd-fsck-root.service,loaded,inactive,dead, File System Check on Root Device
      systemd-timesyncd.service,loaded,inactive,dead, Network Time Synchronization
      2020-08-16 10:40:21.065  - debug: linux-control.0 (24751) [servicesInfo] NUC_VM (192.168.138.123:22): csvToJson result: [{"id":"apache2.service","load":"loaded","active":"active","running":"running","description":"The Apache HTTP Server"},{"id":"apparmor.service","load":"loaded","active":"active","running":"exited","description":"Load AppArmor profiles"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"auth-rpcgss-module.service","load":"loaded","active":"inactive","running":"dead","description":"Kernel Module supporting RPCSEC_GSS"},{"id":"avahi-daemon.service","load":"loaded","active":"active","running":"running","description":"Avahi mDNS/DNS-SD Stack"},{"id":"clamav-daemon.service","load":"not-found","active":"inactive","running":"dead","description":"clamav-daemon.service"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"cups-browsed.service","load":"loaded","active":"failed","running":"failed","description":"Make remote CUPS printers available locally"},{"id":"cups.service","load":"loaded","active":"active","running":"running","description":"CUPS Scheduler"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"exim4.service","load":"loaded","active":"active","running":"running","description":"LSB: exim Mail Transport Agent"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"greylist.service","load":"not-found","active":"inactive","running":"dead","description":"greylist.service"},{"id":"gssproxy.service","load":"not-found","active":"inactive","running":"dead","description":"gssproxy.service"},{"id":"ifup@ens18.service","load":"loaded","active":"active","running":"exited","description":"ifup for ens18"},{"id":"ifupdown-pre.service","load":"loaded","active":"active","running":"exited","description":"Helper to synchronize boot up for ifupdown"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"irqbalance.service","load":"loaded","active":"active","running":"running","description":"irqbalance daemon"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"logrotate.service","load":"loaded","active":"inactive","running":"dead","description":"Rotate log files"},{"id":"man-db.service","load":"loaded","active":"inactive","running":"dead","description":"Daily man-db regeneration"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"mysql.service","load":"not-found","active":"inactive","running":"dead","description":"mysql.service"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager.service","load":"not-found","active":"inactive","running":"dead","description":"NetworkManager.service"},{"id":"nfs-blkmap.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-blkmap.service"},{"id":"nfs-config.service","load":"loaded","active":"inactive","running":"dead","description":"Preprocess NFS configuration"},{"id":"nfs-server.service","load":"not-found","active":"inactive","running":"dead","description":"nfs-server.service"},{"id":"nfs-utils.service","load":"loaded","active":"inactive","running":"dead","description":"NFS server and client services"},{"id":"ntp.service","load":"loaded","active":"active","running":"running","description":"Network Time Service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"postgresql.service","load":"not-found","active":"inactive","running":"dead","description":"postgresql.service"},{"id":"rc-local.service","load":"loaded","active":"inactive","running":"dead","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"rpc-gssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS client and server"},{"id":"rpc-svcgssd.service","load":"loaded","active":"inactive","running":"dead","description":"RPC security service for NFS server"},{"id":"rpcbind.service","load":"loaded","active":"active","running":"running","description":"RPC bind portmap service"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"spamassassin.service","load":"not-found","active":"inactive","running":"dead","description":"spamassassin.service"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"loaded","active":"active","running":"exited","description":"Create System Users"},{"id":"systemd-timesyncd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"user-runtime-dir@1000.service","load":"loaded","active":"active","running":"exited","description":"User Runtime Directory /run/user/1000"},{"id":"user@1000.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1000"}]
      2020-08-16 10:40:21.427  - debug: linux-control.0 (24751) [needrestart] NUC_VM (192.168.138.123:22): no datapoints selected -> removing existing datapoints
      2020-08-16 10:40:21.440  - debug: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'sudo du -sk /opt/iobroker/iobroker-data/history | awk '{ print $1 /1024 }' | tail -1'
      2020-08-16 10:40:21.766  - debug: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): response stdout:
      [sudo] Passwort für pi:
      13533.4
      2020-08-16 10:40:21.768  - debug: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.size: NaN MB
      2020-08-16 10:40:21.772  - debug: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'sudo find /opt/iobroker/iobroker-data/history -name "*" | wc -l | tail -1'
      2020-08-16 10:40:22.085  - debug: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): response stdout:
      112764
      2020-08-16 10:40:22.086  - debug: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): NUC_VM.folders.history.files: NaN Dateien
      2020-08-16 10:40:22.089  - debug: linux-control.0 (24751) [folderSizes] NUC_VM (192.168.138.123:22): send command: 'tmp=$(sudo find /opt/iobroker/iobroker-data/history -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}' | tail -1) && date +%s -r $tmp'
      2020-08-16 10:40:22.686  - info: linux-control.0 (24751) getting data from Tinker (192.168.138.74:22)
      2020-08-16 10:40:22.719  - debug: linux-control.0 (24751) [getConnection] Host 'Tinker' (192.168.138.74:22): using sudo for authentification
      2020-08-16 10:40:22.825  - debug: linux-control.0 (24751) [distributionInfo] Tinker (192.168.138.74:22): send command: 'cat /etc/os-release'
      2020-08-16 10:40:23.123  - debug: linux-control.0 (24751) [distributionInfo] Tinker (192.168.138.74:22): response stdout: NAME="Ubuntu"
      VERSION="18.04.4 LTS (Bionic Beaver)"
      ID=ubuntu
      ID_LIKE=debian
      PRETTY_NAME="Ubuntu 18.04.4 LTS"
      VERSION_ID="18.04"
      HOME_URL="https://www.ubuntu.com/"
      SUPPORT_URL="https://help.ubuntu.com/"
      BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
      PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
      VERSION_CODENAME=bionic
      UBUNTU_CODENAME=bionic
      2020-08-16 10:40:23.127  - debug: linux-control.0 (24751) [distributionInfo] Tinker (192.168.138.74:22): csvToJson result: [{"prop":"NAME","val":"Ubuntu"},{"prop":"VERSION","val":"18.04.4 LTS (Bionic Beaver)"},{"prop":"ID","val":"ubuntu"},{"prop":"ID_LIKE","val":"debian"},{"prop":"PRETTY_NAME","val":"Ubuntu 18.04.4 LTS"},{"prop":"VERSION_ID","val":"18.04"},{"prop":"HOME_URL","val":"https://www.ubuntu.com/"},{"prop":"SUPPORT_URL","val":"https://help.ubuntu.com/"},{"prop":"BUG_REPORT_URL","val":"https://bugs.launchpad.net/ubuntu/"},{"prop":"PRIVACY_POLICY_URL","val":"https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"},{"prop":"VERSION_CODENAME","val":"bionic"},{"prop":"UBUNTU_CODENAME","val":"bionic"}]
      2020-08-16 10:40:23.152  - debug: linux-control.0 (24751) [cmdAptUpdate] Tinker (192.168.138.74:22): no datapoints selected -> removing existing datapoints
      2020-08-16 10:40:23.155  - debug: linux-control.0 (24751) [servicesInfo] Tinker (192.168.138.74:22): send command: 'systemctl list-units --type service --all --no-legend | awk '{out=""; for(i=5;i<=NF;i++){out=out" "$i}; print $1","$2","$3","$4","out}''
      2020-08-16 10:40:23.178  - debug: linux-control.0 (24751) [servicesInfo] Tinker (192.168.138.74:22): response stdout: alsa-restore.service,loaded,active,exited, Save/Restore Sound Card State
      alsa-state.service,loaded,inactive,dead, Manage Sound Card State (restore and store)
      armbian-firstrun-config.service,loaded,inactive,dead, Armbian first run optional user configuration
      armbian-hardware-monitor.service,loaded,active,exited, Armbian hardware monitoring
      armbian-hardware-optimize.service,loaded,active,exited, Armbian hardware optimization
      armbian-ramlog.service,loaded,active,exited, Armbian memory supported logging
      armbian-zram-config.service,loaded,active,exited, Armbian ZRAM config
      armian-ramlog.service,not-found,inactive,dead, armian-ramlog.service
      chrony.service,loaded,active,running, chrony, an NTP client/server
      cpufrequtils.service,loaded,active,exited, LSB: set CPUFreq kernel parameters
      fstrim.service,loaded,inactive,dead, Discard unused blocks
      haveged.service,loaded,active,running, Entropy daemon using the HAVEGE algorithm
      hostapd.service,loaded,active,exited, LSB: Advanced IEEE 802.11 management daemon
      loadcpufreq.service,loaded,active,exited, LSB: Load kernel modules needed to enable cpufreq scaling
      motd-news.service,loaded,inactive,dead, Message of the Day
      networkd-dispatcher.service,loaded,active,running, Dispatcher daemon for systemd-networkd
      NetworkManager-wait-online.service,loaded,active,exited, Network Manager Wait Online
      NetworkManager.service,loaded,active,running, Network Manager
      ondemand.service,masked,inactive,dead, ondemand.service
      openntpd.service,not-found,inactive,dead, openntpd.service
      polkit.service,loaded,active,running, Authorization Manager
      resolvconf-pull-resolved.service,loaded,inactive,dead, resolvconf-pull-resolved.service
      resolvconf.service,loaded,active,exited, Nameserver information manager
      serial-getty@ttyS2.service,loaded,active,running, Serial Getty on ttyS2
      setvtrgb.service,loaded,active,exited, Set console scheme
      sysfsutils.service,loaded,active,exited, LSB: Set sysfs variables from /etc/sysfs.conf
      sysstat.service,loaded,active,exited, Resets System Activity Data Collector
      systemd-initctl.service,loaded,inactive,dead, /dev/initctl Compatibility Daemon
      systemd-resolved.service,loaded,active,running, Network Name Resolution
      systemd-sysusers.service,not-found,inactive,dead, systemd-sysusers.service
      tinker-bluetooth.service,loaded,active,running, Realtek H5 bluetooth support
      unattended-upgrades.service,loaded,active,running, Unattended Upgrades Shutdown
      user@1002.service,loaded,active,running, User Manager for UID 1002
      2020-08-16 10:40:23.186  - debug: linux-control.0 (24751) [servicesInfo] Tinker (192.168.138.74:22): csvToJson result: [{"id":"alsa-restore.service","load":"loaded","active":"active","running":"exited","description":"Save/Restore Sound Card State"},{"id":"alsa-state.service","load":"loaded","active":"inactive","running":"dead","description":"Manage Sound Card State (restore and store)"},{"id":"apparmor.service","load":"not-found","active":"inactive","running":"dead","description":"apparmor.service"},{"id":"apt-daily-upgrade.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt upgrade and clean activities"},{"id":"apt-daily.service","load":"loaded","active":"inactive","running":"dead","description":"Daily apt download activities"},{"id":"armbian-firstrun-config.service","load":"loaded","active":"inactive","running":"dead","description":"Armbian first run optional user configuration"},{"id":"armbian-hardware-monitor.service","load":"loaded","active":"active","running":"exited","description":"Armbian hardware monitoring"},{"id":"armbian-hardware-optimize.service","load":"loaded","active":"active","running":"exited","description":"Armbian hardware optimization"},{"id":"armbian-ramlog.service","load":"loaded","active":"active","running":"exited","description":"Armbian memory supported logging"},{"id":"armbian-zram-config.service","load":"loaded","active":"active","running":"exited","description":"Armbian ZRAM config"},{"id":"armian-ramlog.service","load":"not-found","active":"inactive","running":"dead","description":"armian-ramlog.service"},{"id":"auditd.service","load":"not-found","active":"inactive","running":"dead","description":"auditd.service"},{"id":"bluetooth.service","load":"loaded","active":"active","running":"running","description":"Bluetooth service"},{"id":"chrony.service","load":"loaded","active":"active","running":"running","description":"chrony","field6":"an NTP client/server"},{"id":"connman.service","load":"not-found","active":"inactive","running":"dead","description":"connman.service"},{"id":"console-screen.service","load":"not-found","active":"inactive","running":"dead","description":"console-screen.service"},{"id":"console-setup.service","load":"loaded","active":"active","running":"exited","description":"Set console font and keymap"},{"id":"cpufrequtils.service","load":"loaded","active":"active","running":"exited","description":"LSB: set CPUFreq kernel parameters"},{"id":"cron.service","load":"loaded","active":"active","running":"running","description":"Regular background program processing daemon"},{"id":"dbus.service","load":"loaded","active":"active","running":"running","description":"D-Bus System Message Bus"},{"id":"display-manager.service","load":"not-found","active":"inactive","running":"dead","description":"display-manager.service"},{"id":"emergency.service","load":"loaded","active":"inactive","running":"dead","description":"Emergency Shell"},{"id":"fake-hwclock.service","load":"loaded","active":"active","running":"exited","description":"Restore / save the current clock"},{"id":"fstrim.service","load":"loaded","active":"inactive","running":"dead","description":"Discard unused blocks"},{"id":"getty-static.service","load":"loaded","active":"inactive","running":"dead","description":"getty on tty2-tty6 if dbus and logind are not available"},{"id":"getty@tty1.service","load":"loaded","active":"active","running":"running","description":"Getty on tty1"},{"id":"haveged.service","load":"loaded","active":"active","running":"running","description":"Entropy daemon using the HAVEGE algorithm"},{"id":"hostapd.service","load":"loaded","active":"active","running":"exited","description":"LSB: Advanced IEEE 802.11 management daemon"},{"id":"influxdb.service","load":"not-found","active":"inactive","running":"dead","description":"influxdb.service"},{"id":"iobroker.service","load":"loaded","active":"active","running":"running","description":"ioBroker Server"},{"id":"kbd.service","load":"not-found","active":"inactive","running":"dead","description":"kbd.service"},{"id":"keyboard-setup.service","load":"loaded","active":"active","running":"exited","description":"Set the console keyboard layout"},{"id":"kmod-static-nodes.service","load":"loaded","active":"active","running":"exited","description":"Create list of required static device nodes for the current kernel"},{"id":"loadcpufreq.service","load":"loaded","active":"active","running":"exited","description":"LSB: Load kernel modules needed to enable cpufreq scaling"},{"id":"mariadb-server.service","load":"not-found","active":"inactive","running":"dead","description":"mariadb-server.service"},{"id":"motd-news.service","load":"loaded","active":"inactive","running":"dead","description":"Message of the Day"},{"id":"mountkernfs.service","load":"masked","active":"inactive","running":"dead","description":"mountkernfs.service"},{"id":"mysql-server.service","load":"not-found","active":"inactive","running":"dead","description":"mysql-server.service"},{"id":"networkd-dispatcher.service","load":"loaded","active":"active","running":"running","description":"Dispatcher daemon for systemd-networkd"},{"id":"networking.service","load":"loaded","active":"active","running":"exited","description":"Raise network interfaces"},{"id":"NetworkManager-wait-online.service","load":"loaded","active":"active","running":"exited","description":"Network Manager Wait Online"},{"id":"NetworkManager.service","load":"loaded","active":"active","running":"running","description":"Network Manager"},{"id":"ondemand.service","load":"masked","active":"inactive","running":"dead","description":"ondemand.service"},{"id":"openntpd.service","load":"not-found","active":"inactive","running":"dead","description":"openntpd.service"},{"id":"plymouth-quit-wait.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-quit-wait.service"},{"id":"plymouth-start.service","load":"not-found","active":"inactive","running":"dead","description":"plymouth-start.service"},{"id":"polkit.service","load":"loaded","active":"active","running":"running","description":"Authorization Manager"},{"id":"rc-local.service","load":"loaded","active":"active","running":"exited","description":"/etc/rc.local Compatibility"},{"id":"redis.service","load":"not-found","active":"inactive","running":"dead","description":"redis.service"},{"id":"rescue.service","load":"loaded","active":"inactive","running":"dead","description":"Rescue Shell"},{"id":"resolvconf-pull-resolved.service","load":"loaded","active":"inactive","running":"dead","description":"resolvconf-pull-resolved.service"},{"id":"resolvconf.service","load":"loaded","active":"active","running":"exited","description":"Nameserver information manager"},{"id":"rng-tools.service","load":"loaded","active":"active","running":"running","description":"rng-tools.service"},{"id":"rsync.service","load":"loaded","active":"inactive","running":"dead","description":"fast remote file copy program daemon"},{"id":"rsyslog.service","load":"loaded","active":"active","running":"running","description":"System Logging Service"},{"id":"serial-getty@ttyS2.service","load":"loaded","active":"active","running":"running","description":"Serial Getty on ttyS2"},{"id":"setvtrgb.service","load":"loaded","active":"active","running":"exited","description":"Set console scheme"},{"id":"ssh.service","load":"loaded","active":"active","running":"running","description":"OpenBSD Secure Shell server"},{"id":"sysfsutils.service","load":"loaded","active":"active","running":"exited","description":"LSB: Set sysfs variables from /etc/sysfs.conf"},{"id":"sysstat.service","load":"loaded","active":"active","running":"exited","description":"Resets System Activity Data Collector"},{"id":"systemd-ask-password-console.service","load":"loaded","active":"inactive","running":"dead","description":"Dispatch Password Requests to Console"},{"id":"systemd-ask-password-wall.service","load":"loaded","active":"inactive","running":"dead","description":"Forward Password Requests to Wall"},{"id":"systemd-binfmt.service","load":"loaded","active":"inactive","running":"dead","description":"Set Up Additional Binary Formats"},{"id":"systemd-fsck-root.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check on Root Device"},{"id":"systemd-fsckd.service","load":"loaded","active":"inactive","running":"dead","description":"File System Check Daemon to report status"},{"id":"systemd-hwdb-update.service","load":"loaded","active":"inactive","running":"dead","description":"Rebuild Hardware Database"},{"id":"systemd-initctl.service","load":"loaded","active":"inactive","running":"dead","description":"/dev/initctl Compatibility Daemon"},{"id":"systemd-journal-flush.service","load":"loaded","active":"active","running":"exited","description":"Flush Journal to Persistent Storage"},{"id":"systemd-journald.service","load":"loaded","active":"active","running":"running","description":"Journal Service"},{"id":"systemd-logind.service","load":"loaded","active":"active","running":"running","description":"Login Service"},{"id":"systemd-machine-id-commit.service","load":"loaded","active":"inactive","running":"dead","description":"Commit a transient machine-id on disk"},{"id":"systemd-modules-load.service","load":"loaded","active":"active","running":"exited","description":"Load Kernel Modules"},{"id":"systemd-networkd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Service"},{"id":"systemd-random-seed.service","load":"loaded","active":"active","running":"exited","description":"Load/Save Random Seed"},{"id":"systemd-remount-fs.service","load":"loaded","active":"active","running":"exited","description":"Remount Root and Kernel File Systems"},{"id":"systemd-resolved.service","load":"loaded","active":"active","running":"running","description":"Network Name Resolution"},{"id":"systemd-rfkill.service","load":"loaded","active":"inactive","running":"dead","description":"Load/Save RF Kill Switch Status"},{"id":"systemd-sysctl.service","load":"loaded","active":"active","running":"exited","description":"Apply Kernel Variables"},{"id":"systemd-sysusers.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-sysusers.service"},{"id":"systemd-timesyncd.service","load":"loaded","active":"inactive","running":"dead","description":"Network Time Synchronization"},{"id":"systemd-tmpfiles-clean.service","load":"loaded","active":"inactive","running":"dead","description":"Cleanup of Temporary Directories"},{"id":"systemd-tmpfiles-setup-dev.service","load":"loaded","active":"active","running":"exited","description":"Create Static Device Nodes in /dev"},{"id":"systemd-tmpfiles-setup.service","load":"loaded","active":"active","running":"exited","description":"Create Volatile Files and Directories"},{"id":"systemd-udev-trigger.service","load":"loaded","active":"active","running":"exited","description":"udev Coldplug all Devices"},{"id":"systemd-udevd.service","load":"loaded","active":"active","running":"running","description":"udev Kernel Device Manager"},{"id":"systemd-update-done.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-update-done.service"},{"id":"systemd-update-utmp-runlevel.service","load":"loaded","active":"inactive","running":"dead","description":"Update UTMP about System Runlevel Changes"},{"id":"systemd-update-utmp.service","load":"loaded","active":"active","running":"exited","description":"Update UTMP about System Boot/Shutdown"},{"id":"systemd-user-sessions.service","load":"loaded","active":"active","running":"exited","description":"Permit User Sessions"},{"id":"systemd-vconsole-setup.service","load":"not-found","active":"inactive","running":"dead","description":"systemd-vconsole-setup.service"},{"id":"tinker-bluetooth.service","load":"loaded","active":"active","running":"running","description":"Realtek H5 bluetooth support"},{"id":"unattended-upgrades.service","load":"loaded","active":"active","running":"running","description":"Unattended Upgrades Shutdown"},{"id":"user@1002.service","load":"loaded","active":"active","running":"running","description":"User Manager for UID 1002"},{"id":"wpa_supplicant.service","load":"loaded","active":"active","running":"running","description":"WPA supplicant"}]
      2020-08-16 10:40:23.874  - debug: linux-control.0 (24751) [needrestart] Tinker (192.168.138.74:22): no datapoints selected -> removing existing datapoints
      2020-08-16 10:40:23.886  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): send command: 'sudo du -sk /opt/iobroker/iobroker-data | awk '{ print $1 /1024 }' | tail -1'
      2020-08-16 10:40:23.987  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): response stdout:
      Sorry, user pi is not allowed to execute '/usr/bin/du -sk /opt/iobroker/iobroker-data' as root on localhost.
      2020-08-16 10:40:23.988  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.size: NaN MB
      2020-08-16 10:40:23.991  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): send command: 'sudo find /opt/iobroker/iobroker-data -name "*" | wc -l | tail -1'
      2020-08-16 10:40:24.095  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): response stdout:
      Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name *' as root on localhost.
      0
      2020-08-16 10:40:24.097  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.files: NaN Dateien
      2020-08-16 10:40:24.099  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): send command: 'tmp=$(sudo find /opt/iobroker/iobroker-data -name "*" -type f -exec stat -c "%Y %n" -- {} \; | sort -nr | head -n1 | awk '{print $2}' | tail -1) && date +%s -r $tmp'
      2020-08-16 10:40:24.203  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): response stdout:
      Sorry, user pi is not allowed to execute '/usr/bin/find /opt/iobroker/iobroker-data -name * -type f -exec stat -c %Y %n -- {} ;' as root on localhost.
      date: option requires an argument -- 'r'
      Try 'date --help' for more information.
      2020-08-16 10:40:24.204  - debug: linux-control.0 (24751) [folderSizes] Tinker (192.168.138.74:22): Tinker.folders.iobroker.lastChange: NaN ->
      2020-08-16 10:40:24.207  - debug: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: root, description: ): send command: 'df / | grep / | awk '{ print $5}' | sed 's/%//g''
      2020-08-16 10:40:24.235  - debug: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: root, description: ): response stdout: 5
      2020-08-16 10:40:24.239  - debug: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: ip, description: ): send command: 'hostname -I | cut -d' ' -f1'
      2020-08-16 10:40:24.250  - debug: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: ip, description: ): response stdout: 192.168.138.74
      2020-08-16 10:40:24.253  - debug: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: cpu-temp, description: ): send command: 'cat /sys/devices/virtual/thermal/thermal_zone0/temp | awk '{print substr($1, length($0)-5,3)}''
      2020-08-16 10:40:24.263  - debug: linux-control.0 (24751) [userCommand] Tinker (192.168.138.74:22, id: cpu-temp, description: ): response stdout: 47
      2020-08-16 10:40:24.267  - info: linux-control.0 (24751) successful received data from Tinker (192.168.138.74:22)
      ich hoffe es ist alles notwendige drin.
      Ich bilde mir ein gestern wäre das log noch formatiert gewesen 😞
      • Wal
        Wal Developer last edited by
        @Scrounger,
        wäre es möglich, das du deinen Adapter mit der Funktion von meinem Adapter erweiterst ? Mein Adapter führt die Befehle aus, wenn das Objekt dazu auf true gesetzt wird. Warum sollte Zeit in 2 fast gleiche Adapter investiert werden.
        Hier der Github-Link und der Forums-Link.
          liv-in-sky @Wal last edited by liv-in-sky
          @Wal ich denke das geht schon
          Wal 1 Reply Last reply Reply Quote 1
          • Wal
            Wal Developer @liv-in-sky last edited by
            @liv-in-sky sagte in Test Adapter Linux Control v0.x.x:
            Da muß ich mal testen 🙂
              @Wal und ich werd mir deinen mal ansehen - ist total an mir vorbei gegangen
                @Wal wichtig ist, dass der befehl als button definiert wird
                • Wal
                  @liv-in-sky
                  hmm, was gebe ich als Abrufintervall ein, ich will ja nicht pollen ?
                    @Wal verstehe ich nicht ganz
                    das interval wird gebraucht für z.b folder abfragen oder service abfragen
                    wenn du nur einen button für einen server einrichten willst - also ohne folder oder service - wird das im moment nicht funktioneren
                    wenn du die datenpunkte (tab DATENPUNKTE) alle deaktivierst, weiß ich nicht ob noch gepollt wird und ob noch die befehle ausgeführt werden - mußt du ausprobieren
                    im log siehst du, ob gepollt wird
                    • Wal
                      Hab alles deaktiviert und den Intervall auf 9999 gestellt, funktioniert, danke.
                      • Scrounger
                        Scrounger Developer @Wal last edited by Scrounger
                        @Wal sagte in Test Adapter Linux Control v0.x.x:
                        Ich bau noch ein, das bei Intervall = 0 das polling deaktiviert wird.
                        Alternativ kann man auch den Adapter einmal nach der Konfirguration eines eigenen Button laufen lassen und dann den host deaktiviert setzen (bei aktiviert den haken raus)
                        @Homoran sagte in Test Adapter Linux Control v0.x.x:
                        @Scrounger sagte in Test Adapter Linux Control v0.x.x:
                        @Homoran
                        Hab noch was eingebaut, bitte teste mal die aktuelle github version
                        Habe neu installiert - upload gemacht und Instanz sicherheitshalber nochmal gestartet.
                        steht immer noch null drin
                        Hab nochmal was eingebaut, bitte teste die aktuelle version von github.
                        Dein Tinker hat keine berechtigung:
                        2020-08-15 16:08:27.315 - debug: linux-control.0 (19029) [folderSizes] Tinker (192.168.138.74:22): response stdout:
                        Homoran liv-in-sky Stephan Schleich 4 Replies Last reply Reply Quote 0
                          Homoran Global Moderator Administrators @Scrounger last edited by
                          Ja!
                            liv-in-sky @Scrounger last edited by
                            @Homoran
                            ist mir gerade in den sinn gekommen
                            könnte man da was über das sudoers file auf dem tinker machen ?
                              Homoran Global Moderator Administrators @liv-in-sky last edited by
                              @liv-in-sky müsste mich mal schlau machen wo es steht, aber irgendwo konnte man einstellen ob bei sudo das Passwort abgefragt werden soll.
                              Das wollte ich aber eigentlich nicht ändern, im Gegenteil beim RaspiOS stört mich die fehlende Abfrage.
                                liv-in-sky @Homoran last edited by
                                @Homoran oder du gehst ohne passwort über rsa key file
                                  Thomas Braun Most Active @liv-in-sky last edited by Thomas Braun
                                  @liv-in-sky Vielleicht geht auch was mit dem sticky bit.
                                  [Edit:] Ich meinte natürlich setuid, nicht sticky bit.
                                    @Scrounger
                                    habe gestern abend mal versucht, eine verbindung über rsa key file zu erstellen. anschliessend habe ich den pfad wieder aus dem setting im adapter genommen um wieder mit passwort zu verbinden - seitdem habe ich fehler und die verbindung wird nicht wieder hergestellt - iobroker restart heute morgen brachte keine verbesserung
                                    linux-control.0	2020-08-17 08:29:10.256	error	(2065) [getConnection] error: config.privateKey does not exist at given fs path, stack: AssertionError [ERR_ASSERTION]: config.privateKey does not exist at given fs path at new AssertionError (int
                                    linux-control.0	2020-08-17 08:29:10.255	error	(2065) [getConnection] Could not establish a connection to 'Proxmox' (192.168.178.10:22)!
                                    linux-control.0	2020-08-17 08:28:10.247	error	(2065) [getConnection] error: config.privateKey does not exist at given fs path, stack: AssertionError [ERR_ASSERTION]: config.privateKey does not exist at given fs path at new AssertionError (int
                                    linux-control.0	2020-08-17 08:28:10.246	error	(2065) [getConnection] Could not establish a connection to 'Proxmox' (192.168.178.10:22)!
                                    linux-control.0	2020-08-17 08:27:10.236	error	(2065) [getConnection] error: config.privateKey does not exist at given fs path, stack: AssertionError [ERR_ASSERTION]: config.privateKey does not exist at given fs path at new AssertionError (int
                                    linux-control.0	2020-08-17 08:27:10.236	error	(2065) [getConnection] Could not establish a connection to 'Proxmox' (192.168.178.10:22)!
                                    hast du eine idee dazu ?
                                    • Scrounger
                                      Scrounger Developer @liv-in-sky last edited by
                                      Ja da muss ich noch was abfangen. Werd im Laufe des Tages noch eine neue Version bauen.
                                        @Scrounger danke und gruß
                                        • Scrounger
                                          @liv-in-sky
                                          So neue Version 0.2.7 ist auf github.
                                          @Homoran
                                          Bitte die auch nochmal testen, hab da noch was eingebaut, was deinen fehler hoffentlich jetzt löst.
                                          ? Homoran liv-in-sky 5 Replies Last reply Reply Quote 0
                                            A Former User @Scrounger last edited by
                                            @Scrounger 0.2.7 läuft hier, keine Auffälligkeiten.
                                            1.2k
                                            adapter control hardware linux steuern
                                            70
                                            675
                                            168712
