    4. Test Adapter mihome-vacuum v2.0.x
      freaktech @Thomas Braun last edited by freaktech
      @Thomas-Braun
      ok mit dem iobroker fixer sieht es jetzt so aus
      pi@ioBroker-RasPi4:/opt/iobroker $ ls -la /opt/iobroker/node_modules/canvas/
      insgesamt 144
      drwxrwxr-x+   8 iobroker iobroker  4096 Aug 13 14:37 .
      drwxrwxrwx+ 816 iobroker iobroker 36864 Aug 14 21:15 ..
      -rw-rwxr--+   1 iobroker iobroker  6832 Okt 26  1985 binding.gyp
      -rw-rwxr--+   1 iobroker iobroker  1064 Okt 26  1985 browser.js
      drwxrwxr-x+   3 iobroker iobroker  4096 Aug 13 14:37 build
      -rw-rwxr--+   1 iobroker iobroker 28011 Okt 26  1985 CHANGELOG.md
      -rw-rwxr--+   1 iobroker iobroker  2363 Okt 26  1985 index.js
      drwxrwxr-x+   2 iobroker iobroker  4096 Aug 13 14:37 lib
      drwxrwxr-x+  10 iobroker iobroker  4096 Aug 13 14:37 node_modules
      -rw-rwxr--+   1 iobroker iobroker  3210 Aug 13 14:37 package.json
      -rw-rwxr--+   1 iobroker iobroker 26514 Okt 26  1985 Readme.md
      drwxrwxr-x+   4 iobroker iobroker  4096 Aug 13 14:37 src
      drwxrwxr-x+   2 iobroker iobroker  4096 Aug 13 14:37 types
      drwxrwxr-x+   2 iobroker iobroker  4096 Aug 13 14:37 util
      pi@ioBroker-RasPi4:/opt/iobroker $ iobroker start
      close	Zeit
      mihome-vacuum.0	2020-08-15 14:38:20.038	debug	(6984) Receive <<< {"result":[{"msg_ver":2,"msg_seq":2016,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
      mihome-vacuum.0	2020-08-15 14:38:20.030	debug	(6984) sendMsg[1] >>> {"id":41,"method":"get_status"}
      mihome-vacuum.0	2020-08-15 14:38:01.177	debug	(6984) Receive <<< {"result":[{"msg_ver":2,"msg_seq":2015,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
      mihome-vacuum.0	2020-08-15 14:38:00.028	debug	(6984) sendMsg[1] >>> {"id":40,"method":"get_status"}
      mihome-vacuum.0	2020-08-15 14:37:40.035	debug	(6984) Receive <<< {"result":[{"msg_ver":2,"msg_seq":2014,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
      mihome-vacuum.0	2020-08-15 14:37:40.032	debug	(6984) Receive <<< {"partner_id":"","id":39,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_0876","ap":{"ssid":"dexter","bssid":"74:83:c2:87:ca:a6","rssi":-44},"netif":{"localIp":"1
      mihome-vacuum.0	2020-08-15 14:37:40.027	debug	(6984) Next WiFi check: 15.08 14:38
      mihome-vacuum.0	2020-08-15 14:37:40.026	debug	(6984) sendMsg[1] >>> {"id":39,"method":"miIO.info"}
      mihome-vacuum.0	2020-08-15 14:37:40.024	debug	(6984) sendMsg[1] >>> {"id":38,"method":"get_status"}
      mihome-vacuum.0	2020-08-15 14:37:20.030	debug	(6984) Receive <<< {"result":[{"msg_ver":2,"msg_seq":2013,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state"
      mihome-vacuum.0	2020-08-15 14:37:20.022	debug	(6984) sendMsg[1] >>> {"id":37,"method":"get_status"}
      mihome-vacuum.0	2020-08-15 14:37:00.885	debug	(6984) system.adapter.admin.0: logging true
      mihome-vacuum.0	2020-08-15 14:36:42.042	debug	(6984) Mappointer_updated
      mihome-vacuum.0	2020-08-15 14:36:42.041	debug	(6984) Receive <<< {"result":["rubyslite%2F320252511%2F5"],"id":34}
      mihome-vacuum.0	2020-08-15 14:36:42.033	debug	(6984) sendMsg[1] >>> {"id":34,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-15 14:36:40.541	debug	(6984) Receive <<< {"result":[23651,324502500,122,[1597486566,1597478982,1597471813,1597471747,1597442430,1597442077,1597442057,1597441956,1597441792,1597441673,1597441472,1597441343,1597440959,15974
      mihome-vacuum.0	2020-08-15 14:36:40.533	debug	(6984) sendMsg[1] >>> {"id":33,"method":"get_clean_summary"}
      mihome-vacuum.0	2020-08-15 14:36:40.042	debug	(6984) Receive <<< {"result":[{"main_brush_work_time":24359,"side_brush_work_time":24359,"filter_work_time":24359,"filter_element_work_time":0,"sensor_dirty_time":23651}],"id":32}
      mihome-vacuum.0	2020-08-15 14:36:40.031	debug	(6984) sendMsg[1] >>> {"id":32,"method":"get_consumable"}
      mihome-vacuum.0	2020-08-15 14:36:40.029	info	(6984) create states for water box filter
      mihome-vacuum.0	2020-08-15 14:36:40.028	info	(6984) create states for water box
      mihome-vacuum.0	2020-08-15 14:36:40.026	debug	(6984) Receive <<< {"result":[{"msg_ver":2,"msg_seq":2011,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
      mihome-vacuum.0	2020-08-15 14:36:40.018	debug	(6984) sendMsg[1] >>> {"id":31,"method":"get_status"}
      mihome-vacuum.0	2020-08-15 14:36:36.902	debug	(6984) Mappointer_updated
      mihome-vacuum.0	2020-08-15 14:36:36.901	debug	(6984) Receive <<< {"result":["rubyslite%2F320252511%2F4"],"id":30}
      mihome-vacuum.0	2020-08-15 14:36:36.890	debug	(6984) sendMsg[1] >>> {"id":30,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-15 14:36:36.888	debug	(6984) stateChange mihome-vacuum.0.map.loadMap {"val":true,"ack":false,"ts":1597494996878,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597432659531}
      mihome-vacuum.0	2020-08-15 14:36:25.160	debug	(6984) CLEAN_LOGGING[{"Datum":"15.8","Start":"12:16","Saugzeit":"8 min","Fläche":"5.24 m²","Error":0,"Ende":true},{"Datum":"15.8","Start":"10:09","Saugzeit":"9 min","Fläche":"8.19 m²","Error":0,"Ende
      mihome-vacuum.0	2020-08-15 14:36:24.964	debug	(6984) Receive <<< {"result":[[1597435574,1597435596,22,0,0,0,2,3,60]],"id":29}
      mihome-vacuum.0	2020-08-15 14:36:24.958	debug	(6984) sendMsg[1] >>> {"id":29,"method":"get_clean_record","params":[1597435574]}
      mihome-vacuum.0	2020-08-15 14:36:24.763	debug	(6984) Receive <<< {"result":[[1597435610,1597435624,14,0,0,0,2,3,60]],"id":28}
      mihome-vacuum.0	2020-08-15 14:36:24.756	debug	(6984) sendMsg[1] >>> {"id":28,"method":"get_clean_record","params":[1597435610]}
      mihome-vacuum.0	2020-08-15 14:36:24.561	debug	(6984) Receive <<< {"result":[[1597435636,1597435656,20,0,0,0,2,3,60]],"id":27}
      mihome-vacuum.0	2020-08-15 14:36:24.554	debug	(6984) sendMsg[1] >>> {"id":27,"method":"get_clean_record","params":[1597435636]}
      mihome-vacuum.0	2020-08-15 14:36:24.358	debug	(6984) Receive <<< {"result":[[1597436334,1597436350,16,140000,0,0,2,1,60]],"id":26}
      mihome-vacuum.0	2020-08-15 14:36:24.351	debug	(6984) sendMsg[1] >>> {"id":26,"method":"get_clean_record","params":[1597436334]}
      mihome-vacuum.0	2020-08-15 14:36:24.183	debug	(6984) Receive <<< {"result":[[1597440532,1597440545,13,0,0,0,2,3,60]],"id":25}
      mihome-vacuum.0	2020-08-15 14:36:24.148	debug	(6984) sendMsg[1] >>> {"id":25,"method":"get_clean_record","params":[1597440532]}
      mihome-vacuum.0	2020-08-15 14:36:23.953	debug	(6984) Receive <<< {"result":[[1597440550,1597440556,6,0,0,0,2,3,60]],"id":24}
      mihome-vacuum.0	2020-08-15 14:36:23.947	debug	(6984) sendMsg[1] >>> {"id":24,"method":"get_clean_record","params":[1597440550]}
      mihome-vacuum.0	2020-08-15 14:36:23.752	debug	(6984) Receive <<< {"result":[[1597440787,1597440812,25,465000,0,0,2,3,60]],"id":23}
      mihome-vacuum.0	2020-08-15 14:36:23.746	debug	(6984) sendMsg[1] >>> {"id":23,"method":"get_clean_record","params":[1597440787]}
      mihome-vacuum.0	2020-08-15 14:36:23.550	debug	(6984) Receive <<< {"result":[[1597440959,1597440974,15,0,0,0,2,3,60]],"id":22}
      mihome-vacuum.0	2020-08-15 14:36:23.544	debug	(6984) sendMsg[1] >>> {"id":22,"method":"get_clean_record","params":[1597440959]}
      mihome-vacuum.0	2020-08-15 14:36:23.349	debug	(6984) Receive <<< {"result":[[1597441343,1597441359,16,0,0,0,2,3,60]],"id":21}
      mihome-vacuum.0	2020-08-15 14:36:23.343	debug	(6984) sendMsg[1] >>> {"id":21,"method":"get_clean_record","params":[1597441343]}
      mihome-vacuum.0	2020-08-15 14:36:23.148	debug	(6984) Receive <<< {"result":[[1597441472,1597441672,13,0,0,0,2,3,60]],"id":20}
      mihome-vacuum.0	2020-08-15 14:36:23.140	debug	(6984) sendMsg[1] >>> {"id":20,"method":"get_clean_record","params":[1597441472]}
      mihome-vacuum.0	2020-08-15 14:36:23.136	debug	(6984) Xiaomi Cloud: Login successful
      mihome-vacuum.0	2020-08-15 14:36:22.934	debug	(6984) Receive <<< {"result":[[1597441673,1597441687,14,0,0,0,2,3,60]],"id":19}
      mihome-vacuum.0	2020-08-15 14:36:22.927	debug	(6984) sendMsg[1] >>> {"id":19,"method":"get_clean_record","params":[1597441673]}
      mihome-vacuum.0	2020-08-15 14:36:22.648	debug	(6984) Receive <<< {"result":[[1597441792,1597441955,13,0,0,0,2,3,60]],"id":18}
      mihome-vacuum.0	2020-08-15 14:36:22.632	debug	(6984) sendMsg[1] >>> {"id":18,"method":"get_clean_record","params":[1597441792]}
      mihome-vacuum.0	2020-08-15 14:36:22.437	debug	(6984) Receive <<< {"result":[[1597441956,1597441969,13,140000,0,0,2,3,60]],"id":17}
      mihome-vacuum.0	2020-08-15 14:36:22.430	debug	(6984) sendMsg[1] >>> {"id":17,"method":"get_clean_record","params":[1597441956]}
      mihome-vacuum.0	2020-08-15 14:36:22.235	debug	(6984) Receive <<< {"result":[[1597442057,1597442076,13,0,0,0,2,3,60]],"id":16}
      mihome-vacuum.0	2020-08-15 14:36:22.228	debug	(6984) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1597442057]}
      mihome-vacuum.0	2020-08-15 14:36:22.033	debug	(6984) Receive <<< {"result":[[1597442077,1597442083,6,0,0,0,2,3,60]],"id":15}
      mihome-vacuum.0	2020-08-15 14:36:22.026	debug	(6984) sendMsg[1] >>> {"id":15,"method":"get_clean_record","params":[1597442077]}
      mihome-vacuum.0	2020-08-15 14:36:21.911	debug	(6984) Mappointer_updated
      mihome-vacuum.0	2020-08-15 14:36:21.910	debug	(6984) Receive <<< {"result":["rubyslite%2F320252511%2F3"],"id":14}
      mihome-vacuum.0	2020-08-15 14:36:21.904	debug	(6984) 0. Mappointer_nomap___retry
      mihome-vacuum.0	2020-08-15 14:36:21.904	debug	(6984) sendMsg[1] >>> {"id":14,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-15 14:36:21.831	debug	(6984) Receive <<< {"result":[[1597442430,1597442445,15,0,0,0,2,3,60]],"id":13}
      mihome-vacuum.0	2020-08-15 14:36:21.824	debug	(6984) sendMsg[1] >>> {"id":13,"method":"get_clean_record","params":[1597442430]}
      mihome-vacuum.0	2020-08-15 14:36:21.637	debug	(6984) Receive <<< {"result":[[1597471747,1597471761,14,122500,0,0,2,1,60]],"id":12}
      mihome-vacuum.0	2020-08-15 14:36:21.622	debug	(6984) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1597471747]}
      mihome-vacuum.0	2020-08-15 14:36:21.418	debug	(6984) Receive <<< {"result":[[1597471813,1597471826,13,140000,0,0,2,1,60]],"id":11}
      mihome-vacuum.0	2020-08-15 14:36:21.411	debug	(6984) sendMsg[1] >>> {"id":11,"method":"get_clean_record","params":[1597471813]}
      mihome-vacuum.0	2020-08-15 14:36:21.401	debug	(6984) Receive <<< {"result":["retry"],"id":10}
      mihome-vacuum.0	2020-08-15 14:36:21.395	debug	(6984) sendMsg[1] >>> {"id":10,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-15 14:36:21.220	debug	(6984) Receive <<< {"result":[[1597478982,1597479687,533,8185000,0,1,2,3,56]],"id":9}
      mihome-vacuum.0	2020-08-15 14:36:21.208	debug	(6984) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1597478982]}
      mihome-vacuum.0	2020-08-15 14:36:21.205	debug	(6984) Receive <<< {"result":[[16,"320001013943"],[17,"320001013946"],[18,"320001013989"],[19,"320001013938"],[20,"320001013934"],[21,"320001013937"],[22,"320001013942"],[23,"320001013990"]],"id":8}
      mihome-vacuum.0	2020-08-15 14:36:21.203	info	(6984) create state for carpet_mode
      mihome-vacuum.0	2020-08-15 14:36:21.202	debug	(6984) Receive <<< {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":7}
      mihome-vacuum.0	2020-08-15 14:36:21.195	debug	(6984) sendMsg[1] >>> {"id":8,"method":"get_room_mapping"}
      mihome-vacuum.0	2020-08-15 14:36:21.194	debug	(6984) sendMsg[1] >>> {"id":7,"method":"get_carpet_mode"}
      mihome-vacuum.0	2020-08-15 14:36:21.011	debug	(6984) Receive <<< {"result":[[1597486566,1597487061,495,5242500,0,1,2,3,56]],"id":6}
      mihome-vacuum.0	2020-08-15 14:36:21.005	debug	(6984) sendMsg[1] >>> {"id":6,"method":"get_clean_record","params":[1597486566]}
      mihome-vacuum.0	2020-08-15 14:36:21.002	debug	(6984) Receive <<< {"result":[23651,324502500,122,[1597486566,1597478982,1597471813,1597471747,1597442430,1597442077,1597442057,1597441956,1597441792,1597441673,1597441472,1597441343,1597440959,15974
      mihome-vacuum.0	2020-08-15 14:36:20.994	debug	(6984) sendMsg[1] >>> {"id":5,"method":"get_clean_summary"}
      mihome-vacuum.0	2020-08-15 14:36:20.800	debug	(6984) Receive <<< {"result":[{"main_brush_work_time":24359,"side_brush_work_time":24359,"filter_work_time":24359,"filter_element_work_time":0,"sensor_dirty_time":23651}],"id":4}
      mihome-vacuum.0	2020-08-15 14:36:20.794	debug	(6984) sendMsg[1] >>> {"id":4,"method":"get_consumable"}
      mihome-vacuum.0	2020-08-15 14:36:20.611	info	(6984) set nächster Timer: Nicht verfügbar
      mihome-vacuum.0	2020-08-15 14:36:20.600	debug	(6984) Receive <<< {"result":[78],"id":3}
      mihome-vacuum.0	2020-08-15 14:36:20.594	debug	(6984) sendMsg[1] >>> {"id":3,"method":"get_sound_volume"}
      mihome-vacuum.0	2020-08-15 14:36:20.402	debug	(6984) Receive <<< {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_0876","ap":{"ssid":"dexter","bssid":"74:83:c2:87:ca:a6","rssi":-44},"netif":{"localIp":"1
      mihome-vacuum.0	2020-08-15 14:36:20.397	debug	(6984) Next WiFi check: 15.08 14:37
      mihome-vacuum.0	2020-08-15 14:36:20.395	debug	(6984) sendMsg[1] >>> {"id":2,"method":"miIO.info"}
      mihome-vacuum.0	2020-08-15 14:36:20.192	info	(6984) Connected
      mihome-vacuum.0	2020-08-15 14:36:20.178	debug	(6984) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
      mihome-vacuum.0	2020-08-15 14:36:20.175	debug	(6984) Receive <<< {"result":[{"msg_ver":2,"msg_seq":2010,"state":8,"battery":100,"clean_time":495,"clean_area":5242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state
      mihome-vacuum.0	2020-08-15 14:36:20.163	debug	(6984) sendMsg[1] >>> {"id":1,"method":"get_status"}
      mihome-vacuum.0	2020-08-15 14:36:20.122	debug	(6984) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
      mihome-vacuum.0	2020-08-15 14:36:20.120	info	(6984) connecting, this can take up to 10 minutes ...
      mihome-vacuum.0	2020-08-15 14:36:20.118	debug	(6984) Receive <<< Helo <<< 21310020000000001316aa5f5f37d6c4ffffffffffffffffffffffffffffffff
      mihome-vacuum.0	2020-08-15 14:36:20.108	info	(6984) New generation or new fw(3.5.8,0876) detected, create new states goto and zoneclean
      mihome-vacuum.0	2020-08-15 14:36:20.096	debug	(6984) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
      mihome-vacuum.0	2020-08-15 14:36:20.027	debug	(6984) server started on 0.0.0.0:53421
      mihome-vacuum.0	2020-08-15 14:36:20.003	info	(6984) Cloud control disabled
      mihome-vacuum.0	2020-08-15 14:36:20.000	info	(6984) Expert mode disabled, states deleted
      mihome-vacuum.0	2020-08-15 14:36:19.982	debug	(6984) Xiaomi Cloud: Logging in
      mihome-vacuum.0	2020-08-15 14:36:19.975	debug	(6984) load Map creator... false
      mihome-vacuum.0	2020-08-15 14:36:19.847	info	(6984) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.18.3, js-controller: 3.1.6
      mihome-vacuum.0	2020-08-15 14:36:18.546	debug	(6984) statesDB connected
      mihome-vacuum.0	2020-08-15 14:36:18.545	debug	(6984) States connected to redis: 127.0.0.1:9000
      mihome-vacuum.0	2020-08-15 14:36:18.513	debug	(6984) States create System PubSub Client
      mihome-vacuum.0	2020-08-15 14:36:18.509	debug	(6984) States create User PubSub Client
      mihome-vacuum.0	2020-08-15 14:36:18.493	debug	(6984) Redis States: Use Redis connection: 127.0.0.1:9000
      mihome-vacuum.0	2020-08-15 14:36:18.490	debug	(6984) objectDB connected
      mihome-vacuum.0	2020-08-15 14:36:18.481	debug	(6984) Objects connected to redis: 127.0.0.1:9001
      mihome-vacuum.0	2020-08-15 14:36:18.420	debug	(6984) Objects client initialize lua scripts
      mihome-vacuum.0	2020-08-15 14:36:18.419	debug	(6984) Objects create User PubSub Client
      mihome-vacuum.0	2020-08-15 14:36:18.416	debug	(6984) Objects create System PubSub Client
      mihome-vacuum.0	2020-08-15 14:36:18.362	debug	(6984) Objects client ready ... initialize now
      mihome-vacuum.0	2020-08-15 14:36:17.369	debug
      der MAPS link ist weiterhin leer
        dirkhe Developer @Rushmed last edited by
        @Rushmed die Räume werden falsch angelegt.Der interessante logeintrag ist
        Receive <<< {"result":[[20,"275001013647"],[16,"275001013641"],[17,"275001013642"],[18,"275001013645"],[19,"275001013646"]],"id":41}
        Kannst du mir den nochmal senden, wenn du jetzt auch die andere Karte umschaltet? Oder da das Log noch mal. Dann versuche ich da mal was zu basteln, dass die Räume bleiben. Ich habe jetzt immer alle automatisch angelegten Räume gesandt, sprich nicht mehr vorhandene gelöscht und due anderen neu angelegt. Als Workaround könntest du die Räume manuell anlegen, die lässt er in Ruhe
          freaktech last edited by
          so ich komm leider nicht weiter
          hier auch mal ein Log wenn er reinigt
          	2020-08-16 01:53:34.685	debug	(2779) Mappointer_updated
          mihome-vacuum.0	2020-08-16 01:53:34.684	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F9"],"id":2360}
          mihome-vacuum.0	2020-08-16 01:53:34.678	debug	(2779) update_Map need new mapurl
          mihome-vacuum.0	2020-08-16 01:53:34.678	debug	(2779) update_Map Mimap enabled
          mihome-vacuum.0	2020-08-16 01:53:34.678	debug	(2779) sendMsg[1] >>> {"id":2360,"method":"get_map_v1"}
          mihome-vacuum.0	2020-08-16 01:53:33.672	debug	(2779) Receive <<< {"result":["ok"],"id":2359}
          mihome-vacuum.0	2020-08-16 01:53:33.666	debug	(2779) sendMsg[1] >>> {"id":2359,"method":"app_charge"}
          mihome-vacuum.0	2020-08-16 01:53:33.663	debug	(2779) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1597535613659,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1597432361481}
          mihome-vacuum.0	2020-08-16 01:53:32.676	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
          mihome-vacuum.0	2020-08-16 01:53:32.538	debug	(2779) update_Map got new time:1597535612
          mihome-vacuum.0	2020-08-16 01:53:32.537	debug	(2779) update_Map got new expires:1597537412
          mihome-vacuum.0	2020-08-16 01:53:32.537	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/7?Expires=1597537412000&GalaxyAccessKeyId=5271733786445&Signature=Nq3Ni/4ckjx++Ljv13AfRfvC24U=
          mihome-vacuum.0	2020-08-16 01:53:32.441	debug	(2779) Mappointer_updated
          mihome-vacuum.0	2020-08-16 01:53:32.441	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F8"],"id":2358}
          mihome-vacuum.0	2020-08-16 01:53:32.427	debug	(2779) update_Map need new mapurl
          mihome-vacuum.0	2020-08-16 01:53:32.427	debug	(2779) update_Map Mimap enabled
          mihome-vacuum.0	2020-08-16 01:53:32.426	debug	(2779) sendMsg[1] >>> {"id":2358,"method":"get_map_v1"}
          mihome-vacuum.0	2020-08-16 01:53:31.927	debug	(2779) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4260,"state":5,"battery":100,"clean_time":19,"clean_area":405000,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0
          mihome-vacuum.0	2020-08-16 01:53:31.926	debug	(2779) Receive <<< {"partner_id":"","id":2357,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_0876","ap":{"ssid":"dexter","bssid":"74:83:c2:87:ca:a6","rssi":-47},"netif":{"localIp":
          mihome-vacuum.0	2020-08-16 01:53:31.921	debug	(2779) Next WiFi check: 16.08 01:54
          mihome-vacuum.0	2020-08-16 01:53:31.920	debug	(2779) sendMsg[1] >>> {"id":2357,"method":"miIO.info"}
          mihome-vacuum.0	2020-08-16 01:53:31.920	debug	(2779) sendMsg[1] >>> {"id":2356,"method":"get_status"}
          mihome-vacuum.0	2020-08-16 01:53:30.426	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
          mihome-vacuum.0	2020-08-16 01:53:30.297	debug	(2779) update_Map got new time:1597535610
          mihome-vacuum.0	2020-08-16 01:53:30.297	debug	(2779) update_Map got new expires:1597537410
          mihome-vacuum.0	2020-08-16 01:53:30.297	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/6?Expires=1597537410000&GalaxyAccessKeyId=5271733786445&Signature=I1r1YsjSLQJlM7Qw8SP/DCkR/SI=
          mihome-vacuum.0	2020-08-16 01:53:30.208	debug	(2779) Mappointer_updated
          mihome-vacuum.0	2020-08-16 01:53:30.207	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F7"],"id":2355}
          mihome-vacuum.0	2020-08-16 01:53:30.201	debug	(2779) update_Map need new mapurl
          mihome-vacuum.0	2020-08-16 01:53:30.201	debug	(2779) update_Map Mimap enabled
          mihome-vacuum.0	2020-08-16 01:53:30.200	debug	(2779) sendMsg[1] >>> {"id":2355,"method":"get_map_v1"}
          mihome-vacuum.0	2020-08-16 01:53:28.199	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
          mihome-vacuum.0	2020-08-16 01:53:28.068	debug	(2779) update_Map got new time:1597535607
          mihome-vacuum.0	2020-08-16 01:53:28.067	debug	(2779) update_Map got new expires:1597537408
          mihome-vacuum.0	2020-08-16 01:53:28.065	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/5?Expires=1597537408000&GalaxyAccessKeyId=5271733786445&Signature=JTBJCqLKf/mXJCpVIeWEPLTGFfQ=
          mihome-vacuum.0	2020-08-16 01:53:27.928	debug	(2779) Mappointer_updated
          mihome-vacuum.0	2020-08-16 01:53:27.927	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F6"],"id":2354}
          mihome-vacuum.0	2020-08-16 01:53:27.916	debug	(2779) update_Map need new mapurl
          mihome-vacuum.0	2020-08-16 01:53:27.916	debug	(2779) update_Map Mimap enabled
          mihome-vacuum.0	2020-08-16 01:53:27.907	debug	(2779) sendMsg[1] >>> {"id":2354,"method":"get_map_v1"}
          mihome-vacuum.0	2020-08-16 01:53:25.904	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
          mihome-vacuum.0	2020-08-16 01:53:25.723	debug	(2779) update_Map got new time:1597535605
          mihome-vacuum.0	2020-08-16 01:53:25.723	debug	(2779) update_Map got new expires:1597537405
          mihome-vacuum.0	2020-08-16 01:53:25.723	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/4?Expires=1597537405000&GalaxyAccessKeyId=5271733786445&Signature=+eko4U453CCKnyc+RiWm9W1RDt4=
          mihome-vacuum.0	2020-08-16 01:53:25.577	debug	(2779) Mappointer_updated
          mihome-vacuum.0	2020-08-16 01:53:25.575	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F5"],"id":2353}
          mihome-vacuum.0	2020-08-16 01:53:25.566	debug	(2779) update_Map need new mapurl
          mihome-vacuum.0	2020-08-16 01:53:25.566	debug	(2779) update_Map Mimap enabled
          mihome-vacuum.0	2020-08-16 01:53:25.565	debug	(2779) sendMsg[1] >>> {"id":2353,"method":"get_map_v1"}
          mihome-vacuum.0	2020-08-16 01:53:23.564	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
          mihome-vacuum.0	2020-08-16 01:53:23.434	debug	(2779) update_Map got new time:1597535603
          mihome-vacuum.0	2020-08-16 01:53:23.434	debug	(2779) update_Map got new expires:1597537403
          mihome-vacuum.0	2020-08-16 01:53:23.434	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/3?Expires=1597537403000&GalaxyAccessKeyId=5271733786445&Signature=CiWtSOVFBD9uxVjOJ9fDCF//pKU=
          mihome-vacuum.0	2020-08-16 01:53:23.296	debug	(2779) Mappointer_updated
          mihome-vacuum.0	2020-08-16 01:53:23.295	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F4"],"id":2352}
          mihome-vacuum.0	2020-08-16 01:53:23.287	debug	(2779) update_Map need new mapurl
          mihome-vacuum.0	2020-08-16 01:53:23.287	debug	(2779) update_Map Mimap enabled
          mihome-vacuum.0	2020-08-16 01:53:23.286	debug	(2779) sendMsg[1] >>> {"id":2352,"method":"get_map_v1"}
          mihome-vacuum.0	2020-08-16 01:53:21.284	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
          mihome-vacuum.0	2020-08-16 01:53:21.147	debug	(2779) update_Map got new time:1597535601
          mihome-vacuum.0	2020-08-16 01:53:21.147	debug	(2779) update_Map got new expires:1597537401
          mihome-vacuum.0	2020-08-16 01:53:21.146	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/2?Expires=1597537401000&GalaxyAccessKeyId=5271733786445&Signature=71qd2EM76sazK0HXc6UgwCqlK+E=
          mihome-vacuum.0	2020-08-16 01:53:21.047	debug	(2779) Mappointer_updated
          mihome-vacuum.0	2020-08-16 01:53:21.046	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F3"],"id":2351}
          mihome-vacuum.0	2020-08-16 01:53:21.034	debug	(2779) update_Map need new mapurl
          mihome-vacuum.0	2020-08-16 01:53:21.034	debug	(2779) update_Map Mimap enabled
          mihome-vacuum.0	2020-08-16 01:53:21.033	debug	(2779) sendMsg[1] >>> {"id":2351,"method":"get_map_v1"}
          mihome-vacuum.0	2020-08-16 01:53:19.033	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
          mihome-vacuum.0	2020-08-16 01:53:18.918	debug	(2779) Mappointer_updated
          mihome-vacuum.0	2020-08-16 01:53:18.918	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F2"],"id":2350}
          mihome-vacuum.0	2020-08-16 01:53:18.909	debug	(2779) update_Map use old mapurl
          mihome-vacuum.0	2020-08-16 01:53:18.908	debug	(2779) update_Map Mimap enabled
          mihome-vacuum.0	2020-08-16 01:53:18.908	debug	(2779) sendMsg[1] >>> {"id":2350,"method":"get_map_v1"}
          mihome-vacuum.0	2020-08-16 01:53:16.906	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
          mihome-vacuum.0	2020-08-16 01:53:16.661	debug	(2779) Mappointer_updated
          mihome-vacuum.0	2020-08-16 01:53:16.660	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F0"],"id":2349}
          mihome-vacuum.0	2020-08-16 01:53:16.654	debug	(2779) update_Map use old mapurl
          mihome-vacuum.0	2020-08-16 01:53:16.653	debug	(2779) update_Map Mimap enabled
          mihome-vacuum.0	2020-08-16 01:53:16.653	debug	(2779) sendMsg[1] >>> {"id":2349,"method":"get_map_v1"}
          mihome-vacuum.0	2020-08-16 01:53:16.424	debug	(2779) Mappointer_updated
          mihome-vacuum.0	2020-08-16 01:53:16.423	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F0"],"id":2348}
          mihome-vacuum.0	2020-08-16 01:53:16.416	debug	(2779) 1. Mappointer_nomap___retry
          mihome-vacuum.0	2020-08-16 01:53:16.415	debug	(2779) sendMsg[1] >>> {"id":2348,"method":"get_map_v1"}
          mihome-vacuum.0	2020-08-16 01:53:15.913	debug	(2779) Receive <<< {"result":["retry"],"id":2347}
          mihome-vacuum.0	2020-08-16 01:53:15.909	debug	(2779) 0. Mappointer_nomap___retry
          mihome-vacuum.0	2020-08-16 01:53:15.908	debug	(2779) sendMsg[1] >>> {"id":2347,"method":"get_map_v1"}
          mihome-vacuum.0	2020-08-16 01:53:15.408	debug	(2779) Receive <<< {"result":["retry"],"id":2346}
          mihome-vacuum.0	2020-08-16 01:53:14.652	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
          mihome-vacuum.0	2020-08-16 01:53:14.428	debug	(2779) update_Map use old mapurl
          mihome-vacuum.0	2020-08-16 01:53:14.427	debug	(2779) update_Map Mimap enabled
          mihome-vacuum.0	2020-08-16 01:53:14.427	debug	(2779) sendMsg[1] >>> {"id":2346,"method":"get_map_v1"}
          mihome-vacuum.0	2020-08-16 01:53:12.426	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
          mihome-vacuum.0	2020-08-16 01:53:12.131	debug	(2779) Receive <<< {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":2345}
          mihome-vacuum.0	2020-08-16 01:53:12.126	debug	(2779) sendMsg[1] >>> {"id":2345,"method":"get_carpet_mode"}
          mihome-vacuum.0	2020-08-16 01:53:12.114	debug	(2779) update_Map got new time:1597535591
          mihome-vacuum.0	2020-08-16 01:53:12.114	debug	(2779) update_Map got new expires:1597537392
          mihome-vacuum.0	2020-08-16 01:53:12.113	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/0?Expires=1597537392000&GalaxyAccessKeyId=5271733786445&Signature=KZiZxJjzO5quElJw1dYHDqyhz9s=
          mihome-vacuum.0	2020-08-16 01:53:11.939	debug	(2779) Receive <<< {"result":[78],"id":2344}
          mihome-vacuum.0	2020-08-16 01:53:11.926	debug	(2779) update_Map need new mapurl
          mihome-vacuum.0	2020-08-16 01:53:11.926	debug	(2779) update_Map Mimap enabled
          mihome-vacuum.0	2020-08-16 01:53:11.925	debug	(2779) sendMsg[1] >>> {"id":2344,"method":"get_sound_volume"}
          mihome-vacuum.0	2020-08-16 01:53:11.924	debug	(2779) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4259,"state":5,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_
          mihome-vacuum.0	2020-08-16 01:53:11.918	debug	(2779) sendMsg[1] >>> {"id":2343,"method":"get_status"}
          mihome-vacuum.0	2020-08-16 01:53:09.924	debug	(2779) Receive <<< {"result":["ok"],"id":2342}
          mihome-vacuum.0	2020-08-16 01:53:09.918	debug	(2779) sendMsg[1] >>> {"id":2342,"method":"app_start"}
          mihome-vacuum.0	2020-08-16 01:53:09.917	info	(2779) trigger cleaning all
          da steht doch so was wie ne url drinnen. ?!?
          aber wenn ich die jetzt imbrowser ansehe kommt so was wie
          url expired
            dirkhe Developer @freaktech last edited by
            @freaktech du hast canvas nicht oder nicht korrekt installiert, gibt es genug Hinweise hier
              freaktech @dirkhe last edited by
              @dirkhe
              hallo
              leider bekomme ich es nicht hin, 2 Leute hätten es auch schon probiert.
              könntest du mir helfen?
                Thomas Braun Most Active @freaktech last edited by Thomas Braun
                @freaktech Da sind vermutlich immer noch Rechte falsch gesetzt.
                getfacl /opt/iobroker/node_modules/canvas/package.json
                bringt z. B.?
                  @Thomas-Braun
                  ja leider bin ich halt nicht so der Profi und mittlerweile steh ich an
                  wenn ein Profi evtl mal 5 min mit teamvifer zeit hätte wär ich da sehr verbunden, denn nach 2 tagen macht das echt keinen Spaß mehr.
                    @Thomas-Braun said in Test Adapter mihome-vacuum v2.0.x:
                    pi@ioBroker-RasPi4:~ $ getfacl /opt/iobroker/node_modules/canvas/package.json
                    getfacl: Entferne führende '/' von absoluten Pfadnamen
                    # file: opt/iobroker/node_modules/canvas/package.json
                    # owner: iobroker
                    # group: iobroker
                    user::rw-
                    group::r-x
                    group:iobroker:rwx
                    mask::rwx
                    other::r--
                      Rushmed Most Active @dirkhe last edited by
                      @dirkhe
                      Log vom Kartenwechsel 1 auf 2:
                      mihome-vacuum.0	2020-08-16 20:17:34.604	debug	(13625) Receive <<< {"result":[{"msg_ver":2,"msg_seq":3262,"state":8,"battery":100,"clean_time":1905,"clean_area":33115000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_sta
                      mihome-vacuum.0	2020-08-16 20:17:34.500	debug	(13625) sendMsg[1] >>> {"id":62,"method":"get_status"}
                      mihome-vacuum.0	2020-08-16 20:17:22.884	debug	(13625) stateChange mihome-vacuum.0.rooms.275001013628.roomFanPower {"val":106,"ack":false,"ts":1597601842880,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":159760184288
                      mihome-vacuum.0	2020-08-16 20:17:22.833	debug	(13625) stateChange mihome-vacuum.0.rooms.275001013648.roomFanPower {"val":106,"ack":false,"ts":1597601842827,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":159760184282
                      mihome-vacuum.0	2020-08-16 20:17:22.828	debug	(13625) stateChange mihome-vacuum.0.rooms.275001013621.roomFanPower {"val":106,"ack":false,"ts":1597601842817,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":159760184281
                      mihome-vacuum.0	2020-08-16 20:17:22.579	info	(13625) room: 275001013646 not mapped
                      mihome-vacuum.0	2020-08-16 20:17:22.577	info	(13625) room: 275001013645 not mapped
                      mihome-vacuum.0	2020-08-16 20:17:22.572	info	(13625) room: 275001013642 not mapped
                      mihome-vacuum.0	2020-08-16 20:17:22.570	info	(13625) room: 275001013641 not mapped
                      mihome-vacuum.0	2020-08-16 20:17:22.562	info	(13625) room: 275001013647 not mapped
                      mihome-vacuum.0	2020-08-16 20:17:22.559	info	(13625) create new room: 275001013628
                      mihome-vacuum.0	2020-08-16 20:17:22.558	info	(13625) create new room: 275001013648
                      mihome-vacuum.0	2020-08-16 20:17:22.556	info	(13625) create new room: 275001013621
                      mihome-vacuum.0	2020-08-16 20:17:22.521	debug	(13625) Receive <<< {"result":[[16,"275001013621"],[17,"275001013648"],[18,"275001013628"]],"id":61}
                      mihome-vacuum.0	2020-08-16 20:17:22.437	debug	(13625) sendMsg[1] >>> {"id":61,"method":"get_room_mapping"}
                      mihome-vacuum.0	2020-08-16 20:17:22.436	debug	(13625) stateChange mihome-vacuum.0.rooms.loadRooms {"val":true,"ack":false,"ts":1597601842434,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597332190595}
                      mihome-vacuum.0	2020-08-16 20:17:14.544	debug	(13625) Receive <<< {"result":[{"msg_ver":2,"msg_seq":3255,"state":8,"battery":100,"clean_time":1905,"clean_area":33115000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_sta
                      mihome-vacuum.0	2020-08-16 20:17:14.531	debug	(13625) Receive <<< {"partner_id":"","id":60,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-47},"netif":{"local
                      mihome-vacuum.0	2020-08-16 20:17:14.499	debug	(13625) Next WiFi check: 16.08 20:18
                      mihome-vacuum.0	2020-08-16 20:17:14.497	debug	(13625) sendMsg[1] >>> {"id":60,"method":"miIO.info"}
                      mihome-vacuum.0	2020-08-16 20:17:14.496	debug	(13625) sendMsg[1] >>> {"id":59,"method":"get_status"}
                      Log vom Kartenwechsel 2 auf 1:
                      mihome-vacuum.0	2020-08-16 20:18:34.520	debug	(13625) Receive <<< {"result":[{"msg_ver":2,"msg_seq":3285,"state":8,"battery":100,"clean_time":1905,"clean_area":33115000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_sta
                      mihome-vacuum.0	2020-08-16 20:18:34.511	debug	(13625) sendMsg[1] >>> {"id":67,"method":"get_status"}
                      mihome-vacuum.0	2020-08-16 20:18:32.713	info	(13625) room: 275001013628 not mapped
                      mihome-vacuum.0	2020-08-16 20:18:32.712	info	(13625) room: 275001013648 not mapped
                      mihome-vacuum.0	2020-08-16 20:18:32.710	info	(13625) room: 275001013621 not mapped
                      mihome-vacuum.0	2020-08-16 20:18:32.709	info	(13625) room: 275001013646 mapped with index undefined
                      mihome-vacuum.0	2020-08-16 20:18:32.708	info	(13625) room: 275001013645 mapped with index undefined
                      mihome-vacuum.0	2020-08-16 20:18:32.706	info	(13625) room: 275001013642 mapped with index undefined
                      mihome-vacuum.0	2020-08-16 20:18:32.692	info	(13625) room: 275001013641 mapped with index undefined
                      mihome-vacuum.0	2020-08-16 20:18:32.690	info	(13625) room: 275001013647 mapped with index undefined
                      mihome-vacuum.0	2020-08-16 20:18:32.620	debug	(13625) Receive <<< {"result":[[20,"275001013647"],[16,"275001013641"],[17,"275001013642"],[18,"275001013645"],[19,"275001013646"]],"id":66}
                      mihome-vacuum.0	2020-08-16 20:18:32.610	debug	(13625) sendMsg[1] >>> {"id":66,"method":"get_room_mapping"}
                      mihome-vacuum.0	2020-08-16 20:18:32.608	debug	(13625) stateChange mihome-vacuum.0.rooms.loadRooms {"val":true,"ack":false,"ts":1597601912603,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597332190595}
                        @Rushmed schon mal danke für die Logs. Allerdings habe ich im Moment noch keine Idee, wie wir damit umgehen sollen. Im Prinzip bekommen wir vom Roboter eine Liste aktueller Räume mit timestamp und Index. Das Problem ist, dass der Index 16 zb bei beiden Karten existiert. Ich kann eigentlich nur immer alle Datenpunkte löschen und wieder neu anlegen. Warum er die bei dir nicht sauber löscht, muss ich nochmal untersuchen. Das Problem ist, dass in manuell gespeicherten Räumen ja auch der Index hinterlegt ist, der bei einem kartenwechsel nicht mehr gültig ist. Also irgendwie bräuchten wir noch einen kartenindex(key).
                        Irgendjemand eine Idee?
                          Sweatchuck @freaktech last edited by
                          @freaktech
                          Ich habe das selbe Probleme allerdings mit einer Synology Docker Installation. Komme auch nicht weiter...
                          Befehle zum änder der Rechte sind hier auch nicht bekannt.
                          Fehler ist zwar identifiziert aber eine Anleitung für Anwender mit minimalen Linux-Wissen ist leider noch nicht vorhanden.
                          Ich beobachte weiter....
                            @Rushmed Installiere bitte mal die 2.2.1 von github, lösche bitte einmal die kaputten Räume und wechsle mal die Karte. Ich habe einen Fehler gefunden, dass er nic ht die korrekten Objekte unterhalb des Raumes löscht. Er lässt die inaktiven Räume eigentliuch stehen und schreibt in den mapIndex "not available" rein.
                              Rushmed Most Active @dirkhe last edited by Rushmed
                              @dirkhe Jess, das funktioniert. Die Ordnerstruktur bleibt beim Kartenwechsel erhaten und ich kann die Reinigug starten.
                              Ich muss aber nach einem Kartenwechsel in der App die Räume neu laden. Ist ein Kartenwechsel mit Aktualisierung der Räume in dem Adapter umsetzbar?
                              Danke vorab!
                                @Rushmed unterhalb von rooms gibt es den Button loadrooms. Wie man die Karte wechselt, weiss ich leider nicht. Entweder müssen wir da mal googeln oder sniffen, da komme ich gerade aber nicht zu.
                                  @dirkhe Jepp den Button kenn ich, damit lade ich doch stets die Räume. Es wäre echt toll wenn der Krtenwechsel noch über den ioBroker durchführbar wäre. 😊
                                    Rushmed Most Active @Rushmed last edited by
                                    @Rushmed Die 2.2.1 funktioniert soweit, mir ist jedoch nicht klar warum bei Räumen der inaktiven Karte die Struktur geändert wird.
                                    Im Bild sind Küche und Essbereich auf einer Karte und aktiv. Bei denen wird der Ordner mapIndex erzeugt in dem die DPs roomClean und state erzeugt werden. Die beiden DPs sind neu erstellt, das erkenne ich daran dass die Zuweisung des Smartnamen fehlt. Bei mehrmaligem Kartenwechsel und Räumeladen wird ein neuer Ordner mapIndex zusätzlich angelegt. Teilweise ohne Inhalt.
                                      @Rushmed er sollte eigentlich nur den state und roomclean bei den aktiven anlegen und bei den inaktiven löschen, weil die ja nicht mehr auswählbar sein sollen. Ich habe gerade nochmal in den Code geschaut und gesehen, dass ich an der falschen Stelle gefixt habe, fixe ich gleich
                                        dirkhe Developer last edited by
                                        So 2.2.2 ist im git, bitte nochmal testen, falsche DP bitte vorher löschen
                                        F R 2 Replies Last reply Reply Quote 0
                                          @dirkhe
                                          könnte diese neue Version auch mein MAP Problem lösen
                                          wo ohne Fehlermeldung der Link leer bleibt?
                                          hättest nicht evtl abends oder nachmittags mal 10 min remote zeit ob ich dass doch irgendwie ans laufen bekommen könnte
                                          lg
                                          tom
                                            @dirkhe Die 2.2.2 geht komplett in die falsche Richtung. Der Adapter stürzt wieder ab, bzw braucht ewig für Reconnects.
                                            Meine mit Smartnamen versehenen DPs werden wieder gelöscht.
                                            Wie komme ich wieder an die Git 2.2.1 ran?
                                            1.0k
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            467522
