    4. Test Adapter mihome-vacuum v2.0.x
      freaktech last edited by
      so ich komm leider nicht weiter
      hier auch mal ein Log wenn er reinigt
      	2020-08-16 01:53:34.685	debug	(2779) Mappointer_updated
      mihome-vacuum.0	2020-08-16 01:53:34.684	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F9"],"id":2360}
      mihome-vacuum.0	2020-08-16 01:53:34.678	debug	(2779) update_Map need new mapurl
      mihome-vacuum.0	2020-08-16 01:53:34.678	debug	(2779) update_Map Mimap enabled
      mihome-vacuum.0	2020-08-16 01:53:34.678	debug	(2779) sendMsg[1] >>> {"id":2360,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:33.672	debug	(2779) Receive <<< {"result":["ok"],"id":2359}
      mihome-vacuum.0	2020-08-16 01:53:33.666	debug	(2779) sendMsg[1] >>> {"id":2359,"method":"app_charge"}
      mihome-vacuum.0	2020-08-16 01:53:33.663	debug	(2779) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1597535613659,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1597432361481}
      mihome-vacuum.0	2020-08-16 01:53:32.676	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
      mihome-vacuum.0	2020-08-16 01:53:32.538	debug	(2779) update_Map got new time:1597535612
      mihome-vacuum.0	2020-08-16 01:53:32.537	debug	(2779) update_Map got new expires:1597537412
      mihome-vacuum.0	2020-08-16 01:53:32.537	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/7?Expires=1597537412000&GalaxyAccessKeyId=5271733786445&Signature=Nq3Ni/4ckjx++Ljv13AfRfvC24U=
      mihome-vacuum.0	2020-08-16 01:53:32.441	debug	(2779) Mappointer_updated
      mihome-vacuum.0	2020-08-16 01:53:32.441	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F8"],"id":2358}
      mihome-vacuum.0	2020-08-16 01:53:32.427	debug	(2779) update_Map need new mapurl
      mihome-vacuum.0	2020-08-16 01:53:32.427	debug	(2779) update_Map Mimap enabled
      mihome-vacuum.0	2020-08-16 01:53:32.426	debug	(2779) sendMsg[1] >>> {"id":2358,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:31.927	debug	(2779) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4260,"state":5,"battery":100,"clean_time":19,"clean_area":405000,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0
      mihome-vacuum.0	2020-08-16 01:53:31.926	debug	(2779) Receive <<< {"partner_id":"","id":2357,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_0876","ap":{"ssid":"dexter","bssid":"74:83:c2:87:ca:a6","rssi":-47},"netif":{"localIp":
      mihome-vacuum.0	2020-08-16 01:53:31.921	debug	(2779) Next WiFi check: 16.08 01:54
      mihome-vacuum.0	2020-08-16 01:53:31.920	debug	(2779) sendMsg[1] >>> {"id":2357,"method":"miIO.info"}
      mihome-vacuum.0	2020-08-16 01:53:31.920	debug	(2779) sendMsg[1] >>> {"id":2356,"method":"get_status"}
      mihome-vacuum.0	2020-08-16 01:53:30.426	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
      mihome-vacuum.0	2020-08-16 01:53:30.297	debug	(2779) update_Map got new time:1597535610
      mihome-vacuum.0	2020-08-16 01:53:30.297	debug	(2779) update_Map got new expires:1597537410
      mihome-vacuum.0	2020-08-16 01:53:30.297	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/6?Expires=1597537410000&GalaxyAccessKeyId=5271733786445&Signature=I1r1YsjSLQJlM7Qw8SP/DCkR/SI=
      mihome-vacuum.0	2020-08-16 01:53:30.208	debug	(2779) Mappointer_updated
      mihome-vacuum.0	2020-08-16 01:53:30.207	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F7"],"id":2355}
      mihome-vacuum.0	2020-08-16 01:53:30.201	debug	(2779) update_Map need new mapurl
      mihome-vacuum.0	2020-08-16 01:53:30.201	debug	(2779) update_Map Mimap enabled
      mihome-vacuum.0	2020-08-16 01:53:30.200	debug	(2779) sendMsg[1] >>> {"id":2355,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:28.199	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
      mihome-vacuum.0	2020-08-16 01:53:28.068	debug	(2779) update_Map got new time:1597535607
      mihome-vacuum.0	2020-08-16 01:53:28.067	debug	(2779) update_Map got new expires:1597537408
      mihome-vacuum.0	2020-08-16 01:53:28.065	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/5?Expires=1597537408000&GalaxyAccessKeyId=5271733786445&Signature=JTBJCqLKf/mXJCpVIeWEPLTGFfQ=
      mihome-vacuum.0	2020-08-16 01:53:27.928	debug	(2779) Mappointer_updated
      mihome-vacuum.0	2020-08-16 01:53:27.927	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F6"],"id":2354}
      mihome-vacuum.0	2020-08-16 01:53:27.916	debug	(2779) update_Map need new mapurl
      mihome-vacuum.0	2020-08-16 01:53:27.916	debug	(2779) update_Map Mimap enabled
      mihome-vacuum.0	2020-08-16 01:53:27.907	debug	(2779) sendMsg[1] >>> {"id":2354,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:25.904	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
      mihome-vacuum.0	2020-08-16 01:53:25.723	debug	(2779) update_Map got new time:1597535605
      mihome-vacuum.0	2020-08-16 01:53:25.723	debug	(2779) update_Map got new expires:1597537405
      mihome-vacuum.0	2020-08-16 01:53:25.723	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/4?Expires=1597537405000&GalaxyAccessKeyId=5271733786445&Signature=+eko4U453CCKnyc+RiWm9W1RDt4=
      mihome-vacuum.0	2020-08-16 01:53:25.577	debug	(2779) Mappointer_updated
      mihome-vacuum.0	2020-08-16 01:53:25.575	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F5"],"id":2353}
      mihome-vacuum.0	2020-08-16 01:53:25.566	debug	(2779) update_Map need new mapurl
      mihome-vacuum.0	2020-08-16 01:53:25.566	debug	(2779) update_Map Mimap enabled
      mihome-vacuum.0	2020-08-16 01:53:25.565	debug	(2779) sendMsg[1] >>> {"id":2353,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:23.564	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
      mihome-vacuum.0	2020-08-16 01:53:23.434	debug	(2779) update_Map got new time:1597535603
      mihome-vacuum.0	2020-08-16 01:53:23.434	debug	(2779) update_Map got new expires:1597537403
      mihome-vacuum.0	2020-08-16 01:53:23.434	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/3?Expires=1597537403000&GalaxyAccessKeyId=5271733786445&Signature=CiWtSOVFBD9uxVjOJ9fDCF//pKU=
      mihome-vacuum.0	2020-08-16 01:53:23.296	debug	(2779) Mappointer_updated
      mihome-vacuum.0	2020-08-16 01:53:23.295	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F4"],"id":2352}
      mihome-vacuum.0	2020-08-16 01:53:23.287	debug	(2779) update_Map need new mapurl
      mihome-vacuum.0	2020-08-16 01:53:23.287	debug	(2779) update_Map Mimap enabled
      mihome-vacuum.0	2020-08-16 01:53:23.286	debug	(2779) sendMsg[1] >>> {"id":2352,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:21.284	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
      mihome-vacuum.0	2020-08-16 01:53:21.147	debug	(2779) update_Map got new time:1597535601
      mihome-vacuum.0	2020-08-16 01:53:21.147	debug	(2779) update_Map got new expires:1597537401
      mihome-vacuum.0	2020-08-16 01:53:21.146	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/2?Expires=1597537401000&GalaxyAccessKeyId=5271733786445&Signature=71qd2EM76sazK0HXc6UgwCqlK+E=
      mihome-vacuum.0	2020-08-16 01:53:21.047	debug	(2779) Mappointer_updated
      mihome-vacuum.0	2020-08-16 01:53:21.046	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F3"],"id":2351}
      mihome-vacuum.0	2020-08-16 01:53:21.034	debug	(2779) update_Map need new mapurl
      mihome-vacuum.0	2020-08-16 01:53:21.034	debug	(2779) update_Map Mimap enabled
      mihome-vacuum.0	2020-08-16 01:53:21.033	debug	(2779) sendMsg[1] >>> {"id":2351,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:19.033	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
      mihome-vacuum.0	2020-08-16 01:53:18.918	debug	(2779) Mappointer_updated
      mihome-vacuum.0	2020-08-16 01:53:18.918	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F2"],"id":2350}
      mihome-vacuum.0	2020-08-16 01:53:18.909	debug	(2779) update_Map use old mapurl
      mihome-vacuum.0	2020-08-16 01:53:18.908	debug	(2779) update_Map Mimap enabled
      mihome-vacuum.0	2020-08-16 01:53:18.908	debug	(2779) sendMsg[1] >>> {"id":2350,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:16.906	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
      mihome-vacuum.0	2020-08-16 01:53:16.661	debug	(2779) Mappointer_updated
      mihome-vacuum.0	2020-08-16 01:53:16.660	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F0"],"id":2349}
      mihome-vacuum.0	2020-08-16 01:53:16.654	debug	(2779) update_Map use old mapurl
      mihome-vacuum.0	2020-08-16 01:53:16.653	debug	(2779) update_Map Mimap enabled
      mihome-vacuum.0	2020-08-16 01:53:16.653	debug	(2779) sendMsg[1] >>> {"id":2349,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:16.424	debug	(2779) Mappointer_updated
      mihome-vacuum.0	2020-08-16 01:53:16.423	debug	(2779) Receive <<< {"result":["rubyslite%2F320252511%2F0"],"id":2348}
      mihome-vacuum.0	2020-08-16 01:53:16.416	debug	(2779) 1. Mappointer_nomap___retry
      mihome-vacuum.0	2020-08-16 01:53:16.415	debug	(2779) sendMsg[1] >>> {"id":2348,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:15.913	debug	(2779) Receive <<< {"result":["retry"],"id":2347}
      mihome-vacuum.0	2020-08-16 01:53:15.909	debug	(2779) 0. Mappointer_nomap___retry
      mihome-vacuum.0	2020-08-16 01:53:15.908	debug	(2779) sendMsg[1] >>> {"id":2347,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:15.408	debug	(2779) Receive <<< {"result":["retry"],"id":2346}
      mihome-vacuum.0	2020-08-16 01:53:14.652	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
      mihome-vacuum.0	2020-08-16 01:53:14.428	debug	(2779) update_Map use old mapurl
      mihome-vacuum.0	2020-08-16 01:53:14.427	debug	(2779) update_Map Mimap enabled
      mihome-vacuum.0	2020-08-16 01:53:14.427	debug	(2779) sendMsg[1] >>> {"id":2346,"method":"get_map_v1"}
      mihome-vacuum.0	2020-08-16 01:53:12.426	debug	(2779) TypeError: mapCreator.CanvasMap is not a function
      mihome-vacuum.0	2020-08-16 01:53:12.131	debug	(2779) Receive <<< {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":2345}
      mihome-vacuum.0	2020-08-16 01:53:12.126	debug	(2779) sendMsg[1] >>> {"id":2345,"method":"get_carpet_mode"}
      mihome-vacuum.0	2020-08-16 01:53:12.114	debug	(2779) update_Map got new time:1597535591
      mihome-vacuum.0	2020-08-16 01:53:12.114	debug	(2779) update_Map got new expires:1597537392
      mihome-vacuum.0	2020-08-16 01:53:12.113	debug	(2779) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320252511/0?Expires=1597537392000&GalaxyAccessKeyId=5271733786445&Signature=KZiZxJjzO5quElJw1dYHDqyhz9s=
      mihome-vacuum.0	2020-08-16 01:53:11.939	debug	(2779) Receive <<< {"result":[78],"id":2344}
      mihome-vacuum.0	2020-08-16 01:53:11.926	debug	(2779) update_Map need new mapurl
      mihome-vacuum.0	2020-08-16 01:53:11.926	debug	(2779) update_Map Mimap enabled
      mihome-vacuum.0	2020-08-16 01:53:11.925	debug	(2779) sendMsg[1] >>> {"id":2344,"method":"get_sound_volume"}
      mihome-vacuum.0	2020-08-16 01:53:11.924	debug	(2779) Receive <<< {"result":[{"msg_ver":2,"msg_seq":4259,"state":5,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_
      mihome-vacuum.0	2020-08-16 01:53:11.918	debug	(2779) sendMsg[1] >>> {"id":2343,"method":"get_status"}
      mihome-vacuum.0	2020-08-16 01:53:09.924	debug	(2779) Receive <<< {"result":["ok"],"id":2342}
      mihome-vacuum.0	2020-08-16 01:53:09.918	debug	(2779) sendMsg[1] >>> {"id":2342,"method":"app_start"}
      mihome-vacuum.0	2020-08-16 01:53:09.917	info	(2779) trigger cleaning all
      da steht doch so was wie ne url drinnen. ?!?
      aber wenn ich die jetzt imbrowser ansehe kommt so was wie
      url expired
        dirkhe Developer @freaktech last edited by
        @freaktech du hast canvas nicht oder nicht korrekt installiert, gibt es genug Hinweise hier
          freaktech @dirkhe last edited by
          @dirkhe
          hallo
          leider bekomme ich es nicht hin, 2 Leute hätten es auch schon probiert.
          könntest du mir helfen?
            Thomas Braun Most Active @freaktech last edited by Thomas Braun
            @freaktech Da sind vermutlich immer noch Rechte falsch gesetzt.
            getfacl /opt/iobroker/node_modules/canvas/package.json
            bringt z. B.?
              freaktech @Thomas Braun last edited by
              @Thomas-Braun
              ja leider bin ich halt nicht so der Profi und mittlerweile steh ich an
              wenn ein Profi evtl mal 5 min mit teamvifer zeit hätte wär ich da sehr verbunden, denn nach 2 tagen macht das echt keinen Spaß mehr.
                @Thomas-Braun said in Test Adapter mihome-vacuum v2.0.x:
                pi@ioBroker-RasPi4:~ $ getfacl /opt/iobroker/node_modules/canvas/package.json
                getfacl: Entferne führende '/' von absoluten Pfadnamen
                # file: opt/iobroker/node_modules/canvas/package.json
                # owner: iobroker
                # group: iobroker
                user::rw-
                group::r-x
                group:iobroker:rwx
                mask::rwx
                other::r--
                  Rushmed Most Active @dirkhe last edited by
                  @dirkhe
                  Log vom Kartenwechsel 1 auf 2:
                  mihome-vacuum.0	2020-08-16 20:17:34.604	debug	(13625) Receive <<< {"result":[{"msg_ver":2,"msg_seq":3262,"state":8,"battery":100,"clean_time":1905,"clean_area":33115000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_sta
                  mihome-vacuum.0	2020-08-16 20:17:34.500	debug	(13625) sendMsg[1] >>> {"id":62,"method":"get_status"}
                  mihome-vacuum.0	2020-08-16 20:17:22.884	debug	(13625) stateChange mihome-vacuum.0.rooms.275001013628.roomFanPower {"val":106,"ack":false,"ts":1597601842880,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":159760184288
                  mihome-vacuum.0	2020-08-16 20:17:22.833	debug	(13625) stateChange mihome-vacuum.0.rooms.275001013648.roomFanPower {"val":106,"ack":false,"ts":1597601842827,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":159760184282
                  mihome-vacuum.0	2020-08-16 20:17:22.828	debug	(13625) stateChange mihome-vacuum.0.rooms.275001013621.roomFanPower {"val":106,"ack":false,"ts":1597601842817,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":159760184281
                  mihome-vacuum.0	2020-08-16 20:17:22.579	info	(13625) room: 275001013646 not mapped
                  mihome-vacuum.0	2020-08-16 20:17:22.577	info	(13625) room: 275001013645 not mapped
                  mihome-vacuum.0	2020-08-16 20:17:22.572	info	(13625) room: 275001013642 not mapped
                  mihome-vacuum.0	2020-08-16 20:17:22.570	info	(13625) room: 275001013641 not mapped
                  mihome-vacuum.0	2020-08-16 20:17:22.562	info	(13625) room: 275001013647 not mapped
                  mihome-vacuum.0	2020-08-16 20:17:22.559	info	(13625) create new room: 275001013628
                  mihome-vacuum.0	2020-08-16 20:17:22.558	info	(13625) create new room: 275001013648
                  mihome-vacuum.0	2020-08-16 20:17:22.556	info	(13625) create new room: 275001013621
                  mihome-vacuum.0	2020-08-16 20:17:22.521	debug	(13625) Receive <<< {"result":[[16,"275001013621"],[17,"275001013648"],[18,"275001013628"]],"id":61}
                  mihome-vacuum.0	2020-08-16 20:17:22.437	debug	(13625) sendMsg[1] >>> {"id":61,"method":"get_room_mapping"}
                  mihome-vacuum.0	2020-08-16 20:17:22.436	debug	(13625) stateChange mihome-vacuum.0.rooms.loadRooms {"val":true,"ack":false,"ts":1597601842434,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597332190595}
                  mihome-vacuum.0	2020-08-16 20:17:14.544	debug	(13625) Receive <<< {"result":[{"msg_ver":2,"msg_seq":3255,"state":8,"battery":100,"clean_time":1905,"clean_area":33115000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_sta
                  mihome-vacuum.0	2020-08-16 20:17:14.531	debug	(13625) Receive <<< {"partner_id":"","id":60,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_4436","ap":{"ssid":"Slowdazamba","bssid":"e0:28:6d:87:52:85","rssi":-47},"netif":{"local
                  mihome-vacuum.0	2020-08-16 20:17:14.499	debug	(13625) Next WiFi check: 16.08 20:18
                  mihome-vacuum.0	2020-08-16 20:17:14.497	debug	(13625) sendMsg[1] >>> {"id":60,"method":"miIO.info"}
                  mihome-vacuum.0	2020-08-16 20:17:14.496	debug	(13625) sendMsg[1] >>> {"id":59,"method":"get_status"}
                  Log vom Kartenwechsel 2 auf 1:
                  mihome-vacuum.0	2020-08-16 20:18:34.520	debug	(13625) Receive <<< {"result":[{"msg_ver":2,"msg_seq":3285,"state":8,"battery":100,"clean_time":1905,"clean_area":33115000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_sta
                  mihome-vacuum.0	2020-08-16 20:18:34.511	debug	(13625) sendMsg[1] >>> {"id":67,"method":"get_status"}
                  mihome-vacuum.0	2020-08-16 20:18:32.713	info	(13625) room: 275001013628 not mapped
                  mihome-vacuum.0	2020-08-16 20:18:32.712	info	(13625) room: 275001013648 not mapped
                  mihome-vacuum.0	2020-08-16 20:18:32.710	info	(13625) room: 275001013621 not mapped
                  mihome-vacuum.0	2020-08-16 20:18:32.709	info	(13625) room: 275001013646 mapped with index undefined
                  mihome-vacuum.0	2020-08-16 20:18:32.708	info	(13625) room: 275001013645 mapped with index undefined
                  mihome-vacuum.0	2020-08-16 20:18:32.706	info	(13625) room: 275001013642 mapped with index undefined
                  mihome-vacuum.0	2020-08-16 20:18:32.692	info	(13625) room: 275001013641 mapped with index undefined
                  mihome-vacuum.0	2020-08-16 20:18:32.690	info	(13625) room: 275001013647 mapped with index undefined
                  mihome-vacuum.0	2020-08-16 20:18:32.620	debug	(13625) Receive <<< {"result":[[20,"275001013647"],[16,"275001013641"],[17,"275001013642"],[18,"275001013645"],[19,"275001013646"]],"id":66}
                  mihome-vacuum.0	2020-08-16 20:18:32.610	debug	(13625) sendMsg[1] >>> {"id":66,"method":"get_room_mapping"}
                  mihome-vacuum.0	2020-08-16 20:18:32.608	debug	(13625) stateChange mihome-vacuum.0.rooms.loadRooms {"val":true,"ack":false,"ts":1597601912603,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597332190595}
                    dirkhe Developer @Rushmed last edited by
                    @Rushmed schon mal danke für die Logs. Allerdings habe ich im Moment noch keine Idee, wie wir damit umgehen sollen. Im Prinzip bekommen wir vom Roboter eine Liste aktueller Räume mit timestamp und Index. Das Problem ist, dass der Index 16 zb bei beiden Karten existiert. Ich kann eigentlich nur immer alle Datenpunkte löschen und wieder neu anlegen. Warum er die bei dir nicht sauber löscht, muss ich nochmal untersuchen. Das Problem ist, dass in manuell gespeicherten Räumen ja auch der Index hinterlegt ist, der bei einem kartenwechsel nicht mehr gültig ist. Also irgendwie bräuchten wir noch einen kartenindex(key).
                    Irgendjemand eine Idee?
                      Sweatchuck @freaktech last edited by
                      @freaktech
                      Ich habe das selbe Probleme allerdings mit einer Synology Docker Installation. Komme auch nicht weiter...
                      Befehle zum änder der Rechte sind hier auch nicht bekannt.
                      Fehler ist zwar identifiziert aber eine Anleitung für Anwender mit minimalen Linux-Wissen ist leider noch nicht vorhanden.
                      Ich beobachte weiter....
                        @Rushmed Installiere bitte mal die 2.2.1 von github, lösche bitte einmal die kaputten Räume und wechsle mal die Karte. Ich habe einen Fehler gefunden, dass er nic ht die korrekten Objekte unterhalb des Raumes löscht. Er lässt die inaktiven Räume eigentliuch stehen und schreibt in den mapIndex "not available" rein.
                          Rushmed Most Active @dirkhe last edited by Rushmed
                          @dirkhe Jess, das funktioniert. Die Ordnerstruktur bleibt beim Kartenwechsel erhaten und ich kann die Reinigug starten.
                          Ich muss aber nach einem Kartenwechsel in der App die Räume neu laden. Ist ein Kartenwechsel mit Aktualisierung der Räume in dem Adapter umsetzbar?
                          Danke vorab!
                            @Rushmed unterhalb von rooms gibt es den Button loadrooms. Wie man die Karte wechselt, weiss ich leider nicht. Entweder müssen wir da mal googeln oder sniffen, da komme ich gerade aber nicht zu.
                              @dirkhe Jepp den Button kenn ich, damit lade ich doch stets die Räume. Es wäre echt toll wenn der Krtenwechsel noch über den ioBroker durchführbar wäre. 😊
                                Rushmed Most Active @Rushmed last edited by
                                @Rushmed Die 2.2.1 funktioniert soweit, mir ist jedoch nicht klar warum bei Räumen der inaktiven Karte die Struktur geändert wird.
                                Im Bild sind Küche und Essbereich auf einer Karte und aktiv. Bei denen wird der Ordner mapIndex erzeugt in dem die DPs roomClean und state erzeugt werden. Die beiden DPs sind neu erstellt, das erkenne ich daran dass die Zuweisung des Smartnamen fehlt. Bei mehrmaligem Kartenwechsel und Räumeladen wird ein neuer Ordner mapIndex zusätzlich angelegt. Teilweise ohne Inhalt.
                                  @Rushmed er sollte eigentlich nur den state und roomclean bei den aktiven anlegen und bei den inaktiven löschen, weil die ja nicht mehr auswählbar sein sollen. Ich habe gerade nochmal in den Code geschaut und gesehen, dass ich an der falschen Stelle gefixt habe, fixe ich gleich
                                    dirkhe Developer last edited by
                                    So 2.2.2 ist im git, bitte nochmal testen, falsche DP bitte vorher löschen
                                    F R 2 Replies Last reply Reply Quote 0
                                      @dirkhe
                                      könnte diese neue Version auch mein MAP Problem lösen
                                      wo ohne Fehlermeldung der Link leer bleibt?
                                      hättest nicht evtl abends oder nachmittags mal 10 min remote zeit ob ich dass doch irgendwie ans laufen bekommen könnte
                                      lg
                                      tom
                                        @dirkhe Die 2.2.2 geht komplett in die falsche Richtung. Der Adapter stürzt wieder ab, bzw braucht ewig für Reconnects.
                                        Meine mit Smartnamen versehenen DPs werden wieder gelöscht.
                                        Wie komme ich wieder an die Git 2.2.1 ran?
                                          dirkhe Developer @Rushmed last edited by dirkhe
                                          @Rushmed die 2.2.1 ist definitiv falsch. Das mit den reconnect ist halt manchmal, das habe ich auch. Das hat aber nichts mit dem Adapter zu tun. Der will halt manchmal nicht mit uns sprechen. Manchmal hilft es, gleichzeitig in die App zu gehen. Wenn die App abstürzt, brauche ich ein Log. Ich kann heute Abend aber auch nochmals testen.
                                          Hmmm, smartnames hast du vermutlich am DB roomclean gemacht, dann muss ich den behalten. Ich muss nur Mal sehen, dass ich einen Raum intern als inaktiv erkenne und das es angefangen wird, wenn er trotzdem ausgelöst wird
                                            @freaktech nein, bei den Maps habe ich kaum Aktien drin. Ich habe nur was am roommanger gedreht.
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            467592
