    5. Script per exec ausführen / sudo Rechteproblem?
      Bert @CrunkFX last edited by
      Hier ist das Skript:
      mountpoint='/media/pi/770E-65D0'
      STORAGEPATH="/media/pi/770E-65D0"
      IMAGENAME="rpi"
      LOGFILE="/var/log/"$HOSTNAME_${IMAGENAME}_"backup-image.log"
      sudo mount -a
      iobroker state set 0_userdata.0.Status_des_SD-Karten_Backups_des_ioBrokers "1"
      echo $(date +%Y-%m-%d_%H-%M-%S) " - Started to clone image" >> ${LOGFILE}
      sudo dd if=/dev/mmcblk0 of=${STORAGEPATH}/${IMAGENAME}_$(date +%Y-%m-%d).img bs=1MB
      echo $(date +%Y-%m-%d_%H-%M-%S) " - Finished to clone image" >> ${LOGFILE}
      iobroker state set 0_userdata.0.Status_des_SD-Karten_Backups_des_ioBrokers "2"
      echo $(date +%Y-%m-%d_%H-%M-%S) " - Started to resize image" >> ${LOGFILE}
      sudo /bin/bash /usr/local/bin/pishrink.sh -d ${STORAGEPATH}/${IMAGENAME}_$(date +%Y-%m-%d).img ${STORAGEPATH}/${IMAGENAME}_$(date +%Y-%m-%d)-small.img
      echo $(date +%Y-%m-%d_%H-%M-%S) " - Finished to resize big image" >> ${LOGFILE}
      echo $(date +%Y-%m-%d_%H-%M-%S) " - Started to delete big image" >> ${LOGFILE}
      sudo rm ${STORAGEPATH}/${IMAGENAME}_$(date +%Y-%m-%d).img
      echo $(date +%Y-%m-%d_%H-%M-%S) " - Finished to delete big image" >> ${LOGFILE}
      iobroker state set 0_userdata.0.Status_des_SD-Karten_Backups_des_ioBrokers "3"
      echo $(date +%Y-%m-%d_%H-%M-%S) " - Started to compress small image" >> ${LOGFILE}
      gzip -q ${STORAGEPATH}/${IMAGENAME}_$(date +%Y-%m-%d)-small.img
      echo $(date +%Y-%m-%d_%H-%M-%S) " - Finished to compress small image" >> ${LOGFILE}
      iobroker state set 0_userdata.0.Status_des_SD-Karten_Backups_des_ioBrokers "4"
      mv ${STORAGEPATH}/${IMAGENAME}_$(date +%Y-%m-%d)-small.img.gz /media/pi/bserver
      iobroker state set 0_userdata.0.Status_des_SD-Karten_Backups_des_ioBrokers "5"
      echo $(date +%Y-%m-%d_%H-%M-%S) " - Mission Accomplished!!!" >> ${LOGFILE}
        Bert @Bert last edited by
        Als Ergänzung:
        Grundsätzlich ist mir der Weg zum Ziel vollkommen egal!
        Also wenn es einen Umweg gibt um das Script auszuführen, dann nehme ich den selbstverständlich auch in kauf!
        Mir stellt sich gerade die Frage ob man das Script wohlmöglich per URL bzw. http Befehl ausführen lassen kann ?!
        • Meister Mopper
          Meister Mopper @Bert last edited by Meister Mopper
          @Bert Soviel wie ich verstehe, muss Dein ioBroker-user auch Schreibrechte auf dem Zielsystem haben. Vielleicht hilft ja dieser thread weiter.
            Bert @Meister Mopper last edited by
            @Meister-Mopper
            Vielen Dank für deinen Tipp!
            Habe die Schritte aus deinem Beitrag mal durchgeführt, aber das hat leider auch nicht funktioniert.
            Habe bestimmt schon vorher irgendwas irreparabel gemacht durch das ganz Rechte-hin-und-her vergeben 😔
            Ich denke ich werde besser erstmal das Backup-Image aufspielen und nochmal recherchieren.
            Vielleicht hat ja noch jemand einen Tipp
              fastfoot @Bert last edited by
              @Bert Installiere dir den Terminaladapter und führe das Skript von dort aus. Das wird zwar auch nicht funktionieren aber du siehst womöglich sehr viel besser wo es hakt. Dort ist der user nämlich auch der iobroker
                Thomas Braun Most Active @CrunkFX last edited by Thomas Braun
                @CrunkFX sagte in Script per exec ausführen / sudo Rechteproblem?:
                und dann kann evtl jemand der sich mit Linux auskennt das Mal anschauen. Vielleicht @Thomas-Braun
                Von skripten und insbesondere JavaSkript hab ich keine Ahnung.
                Soll das oben ein shell-skript sein? Dann fehlt da mindestens mal die shebang.
                CrunkFX B 2 Replies Last reply Reply Quote 0
                • CrunkFX
                  CrunkFX Forum Testing @Thomas Braun last edited by
                  @Thomas-Braun Ich hatte in Erinnerung, dass du ein verfechter von sudo bist, daher dachte ich du könntest evtl. bei dem Rechteproblem helfen
                    @CrunkFX @Bert
                    Ich verstehe den Ansatz schon nicht:
                    ein Skript zusammenkopiert welches meine SD-Karte während des laufenden Betriebs klont, shrinkt, gzipt und anschließend auf meinen NAS verschiebt.
                    Ich sicher lediglich per backitup den ioBroker relevanten Kram weg, das System selber ist mir doch wumpe. Das zimmer ich ohnehin schnell fix auf eine neue SD-Karte, im Falle eines Falles. Da mach ich gar keine Klimmzüge für.
                      Bert @Thomas Braun last edited by
                      sorry für die späte Antwort, haben spontan ein paar Tage Urlaub gemacht...
                      @Thomas-Braun said in Script per exec ausführen / sudo Rechteproblem?:
                      sorry, die Shebang ist vorhanden, hab ich nur nicht mitkopiert 🤦‍♂️
                      @CrunkFX @Bert
                      Naja, der eine so, der andere so. Für mich wäre es schon von Vorteil eine "Plug&Play-Sicherung" zu haben die ich zuvor komfortabel aus dem ioBroker gestartet habe. In der VIS soll eine schöne View mit diversen Systembefehlen laufen wo sich auch ein Backup-Button gut macht.
                      Backitup ist natürlich auch im Einsatz und sichert regelmäßig auf dem NAS. Wenn ich am System rumfummel starte ich das Backup-Script vorher von Hand. Alles kein Thema.
                      Trotzdem ist Neugier und der Wunsch nach etwas Komfort vorhanden, aber da das jetzt doch viel zu viel Zeit frisst muss eine von-Hand-Sicherung und Backitup reichen.
                      @fastfoot said in Script per exec ausführen / sudo Rechteproblem?:
                      Terminaladapter habe ich probiert, aber wie du schon sagtest bringt mich das auch nicht weiter 🤷‍♂️
                      Aber auch für den Tipp danke!
                      • SBorg
                        SBorg Forum Testing Most Active @Bert last edited by
                        @Bert Naja, nur weil ein "sudo" davor steht, heißt das noch lange nicht, dass der Befehl auch ausgeführt wird.
                        #6 dürfte schon scheitern, da normalerweise nur "root" mounten darf. Das klappt zwar dann mittels "sudo", nur muss man dann das root-Passwort eingeben (was in einem automatischem Skript eher schlecht geht)...
                        Versuche als Test einfach mal ein
                        sudo -u iobroker sudo mount -a
                        Damit wird dein Befehl als User iobroker ausgeführt.
                        1905
