    5. [Vorlage] Gartenbewässerung mit 6 Ventilen
      A Former User @Kuddel last edited by
      @Kuddel
      So das Pause zeichen färbt sich doch gelb immer wieder
      Hier mal der Log
      javascript.0 2020-08-19 22:01:50.286 warn (716) at processTimers (internal/timers.js:492:7)
      javascript.0 2020-08-19 22:01:50.285 warn (716) at listOnTimeout (internal/timers.js:551:17)
      javascript.0 2020-08-19 22:01:50.285 warn (716) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1403:29)
      javascript.0 2020-08-19 22:01:50.284 warn (716) at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1345:20)
      javascript.0 2020-08-19 22:01:50.279 warn (716) State "undefined" not found
      javascript.0 2020-08-19 22:01:50.266 error (716) at processTimers (internal/timers.js:492:7)
      javascript.0 2020-08-19 22:01:50.265 error (716) at listOnTimeout (internal/timers.js:551:17)
      javascript.0 2020-08-19 22:01:50.265 error (716) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2001:34)
      javascript.0 2020-08-19 22:01:50.264 error (716) at Object.<anonymous> (script.js.common.Test_Bewässerung:470:9)
      javascript.0 2020-08-19 22:01:50.263 error (716) Error in callback: ReferenceError: Variablen_definieren is not defined
      javascript.0 2020-08-19 22:01:45.289 info (716) script.js.common.Test_Bewässerung: registered 11 subscriptions and 2 schedules
      javascript.0 2020-08-19 22:01:45.288 warn (716) at script.js.common.Test_Bewässerung:1395:118
      javascript.0 2020-08-19 22:01:45.287 warn (716) getState "undefined" not found (3)
      javascript.0 2020-08-19 22:01:45.286 warn (716) at script.js.common.Test_Bewässerung:1395:24
      javascript.0 2020-08-19 22:01:45.285 warn (716) getState "undefined" not found (3)
      javascript.0 2020-08-19 22:01:45.284 warn (716) at script.js.common.Test_Bewässerung:1389:5
      javascript.0 2020-08-19 22:01:45.282 warn (716) getState "undefined" not found (3)
      javascript.0 2020-08-19 22:01:45.281 warn (716) at script.js.common.Test_Bewässerung:1382:5
      javascript.0 2020-08-19 22:01:45.280 warn (716) getState "undefined" not found (3)
      javascript.0 2020-08-19 22:01:45.266 warn (716) at script.js.common.Test_Bewässerung:1372:375
      javascript.0 2020-08-19 22:01:45.264 warn (716) getState "undefined" not found (3)
      javascript.0 2020-08-19 22:01:45.264 warn (716) at script.js.common.Test_Bewässerung:1372:286
      javascript.0 2020-08-19 22:01:45.262 warn (716) getState "undefined" not found (3)
      javascript.0 2020-08-19 22:01:45.262 warn (716) at script.js.common.Test_Bewässerung:1372:197
      javascript.0 2020-08-19 22:01:45.260 warn (716) getState "undefined" not found (3)
      javascript.0 2020-08-19 22:01:45.259 warn (716) at script.js.common.Test_Bewässerung:1372:119
      javascript.0 2020-08-19 22:01:45.257 warn (716) getState "undefined" not found (3)
      javascript.0 2020-08-19 22:01:45.257 warn (716) at script.js.common.Test_Bewässerung:1372:40
      javascript.0 2020-08-19 22:01:45.255 warn (716) getState "undefined" not found (3)
      javascript.0 2020-08-19 22:01:45.254 warn (716) at script.js.common.Test_Bewässerung:1320:5
      javascript.0 2020-08-19 22:01:45.243 warn (716) getState "undefined" not found (3)
      javascript.0 2020-08-19 22:01:45.150 info (716) Start javascript script.js.common.Test_Bewässerung
      javascript.0 2020-08-19 22:01:42.901 info (716) Stop script script.js.common.Test_Bewässerung
      javascript.0 2020-08-19 22:01:41.261 warn (716) unsubscribe: empty name
      javascript.0 2020-08-19 22:01:41.260 warn (716) unsubscribe: empty name
      javascript.0 2020-08-19 22:01:41.258 info (716) Stop script script.js.common.Test_Bewässerung
      K dslraser 2 Replies Last reply Reply Quote 0
        Kuddel @Guest last edited by
        @tobi83 die ganzen Variablen wurden iwie nicht richtig erstellt.
        kannst du mal einen Screenshot von deinen Anpassung bzgl. Ventil-Aktoren etc posten
        • dslraser
          dslraser Forum Testing Most Active @Guest last edited by dslraser
          @tobi83
          Hast Du denn überhaupt schon irgendwas im Blockly eingestellt und die Variablen definiert ?
          Wegen dem Durcheinander im Blockly selbst, klick mal im Blockly auf eine freie leere Stelle mit der rechten Maustaste und dann auf Bausteine aufräumen, ist es dann okay ?
            A Former User @dslraser last edited by
            @dslraser
            Nach dem aufräumen sieht es so aus.... Für mich als nicht wissender sieht das nicht so gut aus....
            • dslraser
              @tobi83
              das ist nicht okay....
                @Kuddel
                das habe ich geändert
                  @tobi83 da ist beim Import mächtig was schief gelaufen. die komplette Struktur im Skript ist zerstört
                    @Kuddel
                    Hab mir ein neues Blockly skript angelegt und dann oben rechts über Blöcke importieren das ganze eingefügt.
                    Liegt da der Fehler?
                    Tobias
                      @tobi83 sagte in [Vorlage] Gartenbewässerung mit 6 Ventilen:
                      @Kuddel
                      Tobias
                      ne das ist nicht der Fehler. genau so muss man das Skript importieren
                      • dslraser
                        @tobi83
                        welche JS-Adapter Version hast Du installiert ?
                          @dslraser
                          4.6.22
                          • dslraser
                            @dslraser
                            4.6.22
                            Okay, ich nutze 4.6.23...Ich habe gerade das Script zum Test herunter geladen und dann über genau Deinen Weg importiert. Bei mir sieht es dann so aus wie es sein sollte.
                            Gesamt: (alles verkleinert)
                            In main muss gar nix eingestellt werden.
                            Nur hier muss es konfiguriert werden:
                            EDIT:
                            Bei Dir fliegen alle möglichen Blöcke lose rum ?
                              @dslraser
                              Wie auf dem Foto alle Teile einzeln....
                              Und den unteren Block um einstellen habe ich garnicht.
                              Komisch
                              • dslraser
                                @dslraser
                                Komisch
                                Ja, so wird das Blockly nicht funktionieren. Warum der Import bei Dir nicht richtig funktioniert...? Dazu fehlt mir im Moment auch die Idee...
                                  @dslraser
                                  Hab eben nochmal das Skript runtergeladen und mit wordpaad geöffnet und kopiert
                                  Das ist was ich nach dem import angezeigt bekomme. Mehr ist nicht da.
                                  dslraser ice77 2 Replies Last reply Reply Quote 0
                                  • dslraser
                                    @tobi83
                                    rechte Maustaste, Bausteine aufräumen gemacht ?
                                      @dslraser
                                      Wenn ich rechts klick mache kommt bausteine aufräumen etc und unten steht 3328 Bausteine löschen. Also muss ja was da sein
                                      Mir ist eben was anderes aufgefallen...
                                      Wenn ich auf die Symbole klicke erscheint nur ein weißes fenster innerhalb des Blockly Fensters
                                        A Former User @Guest last edited by
                                        Bisher hat sich nix geändert.
                                        Muss ich es wohl entfernen alles.
                                        • ice77
                                          ice77 @Guest last edited by
                                          @tobi83 probiers mal mit vim oder Emacs...
                                            benziman @Kuddel last edited by
                                            @Kuddel
                                            ich habe noch zwei Fehler in der Bewässerung gefunden.
                                            Wenn ich Kreis 1 und 2 aktivere (je 30 Minuten) und den Haken "parallel" aktiviere (was ein geniales Feature ist!), dann liegt die Gesamtbewässerungsdauer bei 60 Minuten, nach Ablauf der 30 Minuten gehen die zwei Kreise zwar aus, allerdings blinkt die Automatik weiterhin.
                                            Und in diesem Zusammenhang noch ein zweiter Punkt: wenn ich nach Kreis 1 und 2 noch Kreis 4 aktiviere, dann geht Kreis 1 aus, Kreis 2 bleibt aktiv nach den 30 Minuten und Kreis 4 geht mit an, was allerdings mit dem Wasserdruck dann nicht mehr gut funktioniert. Ich nutze deine aktuellste VIS und Script v2.9.2 (bei der letzten Installation alle DPs gelöscht)
                                            VG
                                            1187
                                            311111
