    4. Test Adapter enigma2 v1.2.x
      Kuddel @Scrounger last edited by Kuddel
      @Scrounger ein paar Fehler bekomme ich aber doch noch:
      javascript.0	2020-03-17 12:11:00.871	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      javascript.0	2020-03-17 12:11:00.871	error	at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:580:17)
      javascript.0	2020-03-17 12:11:00.871	error	at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:1055:17)
      javascript.0	2020-03-17 12:11:00.871	error	at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1464:17)
      javascript.0	2020-03-17 12:11:00.871	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1412:38)
      javascript.0	2020-03-17 12:11:00.871	error	at execute (/opt/iobroker/node_modules/iobroker.javascript/main.js:1228:27)
      javascript.0	2020-03-17 12:11:00.871	error	at Script.runInNewContext (vm.js:139:17)
      javascript.0	2020-03-17 12:11:00.871	error	at Script.runInContext (vm.js:133:20)
      javascript.0	2020-03-17 12:11:00.871	error	at script.js.java.abfragen.receiver_aufnahmen:153:1
      javascript.0	2020-03-17 12:11:00.871	error	at formatList (script.js.java.abfragen.receiver_aufnahmen:79:27)
      javascript.0	2020-03-17 12:11:00.871	error	(38439) script.js.java.abfragen.receiver_aufnahmen: [createList] stack: TypeError: Cannot read property 'includes' of undefined
      javascript.0	2020-03-17 12:11:00.871	error	(38439) script.js.java.abfragen.receiver_aufnahmen: [createList] error: Cannot read property 'includes' of undefined
      Hier mein Skript:
      // import
      const moment = require("moment");
      const momentDurationFormatSetup = require("moment-duration-format");
      moment.locale("de");
      let enigma2AdapterTimerListId = 'enigma2.0.enigma2.TIMER_LIST';
      on({ id: enigma2AdapterTimerListId }, formatList);
      function formatList() {
         try {
             let list = JSON.parse(getState(enigma2AdapterTimerListId).val);
             let myList = [];
             if (list && list !== null && list !== undefined && list !== '') {
                 for (var i = 0; i <= list.length - 1; i++) {
                     let listItem = list[i]
                     let startTime = moment(listItem.starTime * 1000);
                     let endTime = moment(listItem.endTime * 1000);
                     let recordDateFormatted = `${startTime.format('ddd')} ${startTime.format('DD.MM')}`
                     let starTimeFormatted = `${startTime.format('LT')}`
                     let endTimeFormatted = `${endTime.format('LT')}`
                     if (moment().isSame(startTime, 'day')) {
                         recordDateFormatted = `Heute ${startTime.format('DD.MM')}`;
                     } else if (moment().add(1, 'day').isSame(startTime, 'day')) {
                         recordDateFormatted = `Morgen ${startTime.format('DD.MM')}`;
                     let rawtitle = listItem.title;
                     let title = rawtitle;
                     let subtitle = listItem.subtitle;
                     if (title.includes(' - ')) {
                         title = rawtitle.substring(0, rawtitle.indexOf(' - ')).trim();
                         if (subtitle === '') {
                             subtitle = rawtitle.substring(rawtitle.indexOf(' - ') + 2, rawtitle.length).trim();
                     myList.push(
                             channelImage: `http://192.168.4.24:8080/picon/${listItem.serviceRefName}.png`,
                             channel: listItem.channel,
                             title: title,
                             recordDateFormatted: recordDateFormatted,
                             starTimeFormatted: starTimeFormatted,
                             endTimeFormatted: endTimeFormatted,
                             subtitle: subtitle,
                             startTime: listItem.starTime,
                 myList.sort(function (a, b) {
                     // Liste sortieren nach Startzeit
                     return a.starTime == b.starTime ? 0 : +(a.starTime > b.starTime) || -1;
             setState('javascript.0.sonstige.vu_timer_liste', JSON.stringify(myList), true);
         } catch (err) {
             console.error(`[createList] error: ${err.message}`);
             console.error(`[createList] stack: ${err.stack}`);
      formatList();
      EDIT: Fehlalarm. Das war ein anderes Skript mit dem ich angefangen habe, die Aufnahmen auszuwerten.
        Kuddel last edited by
        Ich habe mich jetzt an ein Skript zum Auflisten der ganzen Aufnahmen gemacht:
        So sehen die Rohdaten vom Enigma-Adapter aus:
        [{"filename_stripped":"20200316_2215_-_KABEL_EINS_HD_-_DIE_BRUCE_WILLIS_STORY.ts",
        "description":"Die Bruce Willis StoryDokumentation, D 2020",
        "tags":"0",
        "filesize":4989953340,
        "eventname":"Die Bruce Willis Story",
        "servicename":"kabel eins HD",
        "filesize_readable":"4.65 GB",
        "serviceref":"1:0:0:0:0:0:0:0:0:0:/media/hdd/movie/20200316_2215_-_KABEL_EINS_HD_-_DIE_BRUCE_WILLIS_STORY.ts",
        "filename":"/media/hdd/movie/20200316_2215_-_KABEL_EINS_HD_-_DIE_BRUCE_WILLIS_STORY.ts",
        "length":"71:57",
        "lastseen":0,
        "fullname":"1:0:0:0:0:0:0:0:0:0:/media/hdd/movie/20200316_2215_-_KABEL_EINS_HD_-_DIE_BRUCE_WILLIS_STORY.ts",
        "recordingtime":1584393300,
        "descriptionExtended":"Er ist der berühmteste Glatzkopf Hollywoods: Bruce Willis. Anlässlich seines 65. Geburtstages zeichnet Kabel Eins das Leben des Stars nach und deckt dabei so manches Geheimnis auf. Denn was viele nicht wissen: Abseits seiner Schauspielkarriere ist Willis ein erfolgreicher Geschäftsmann, Sänger, äußert sich immer wieder zu Politik und Zeitgeschehen - und ist bis heute eigentlich ein waschechter Pfälzer Junge ...",
        "begintime":"16.3., 22:15",
        "service":"1:0:19:C359:271E:F001:FFFF0000:0:0:0:",
        "serviceRefName":"1_0_19_C359_271E_F001_FFFF0000_0_0_0"},
        So sieht aktuell meine VIS aus:
        Probleme:
        *Die Anzeige von Datum und Startzeit wie man es von den Aufnahmen kennt ( Heute 17.03. | 20:15 uhr)
        *Die Sortierung nach Datum fuktioniert nicht
        Hier mein Skript
        //Setzer des DPs der Liste mit den Filmen
        let enigma2AdapterMovieListId = 'enigma2.0.enigma2.MOVIE_LIST';
        //Skript ausführen, wenn Film-Liste geändert wird
        on({ id: enigma2AdapterMovieListId }, formatList);
           try {
               let list = JSON.parse(getState(enigma2AdapterMovieListId).val);
               let myList = [];
                       let startTime = moment(listItem.begintime);
                       let startdatum = listItem.begintime
                       //Output
                       myList.push(
                               channel: listItem.servicename,
                               title: listItem.eventname,
                               startdatum: startdatum,
                               dauer: listItem.length,
                               groesse: listItem.filesize_readable
                       return a.startTime == b.startTime ? 0 : +(a.startzeit > b.startzeit) || -1;
               setState('javascript.0.sonstige.vu_aufnahmen_liste', JSON.stringify(myList), true);
           } catch (err) {
        formatList();
        @Scrounger vllt. schaust du bei Gelegenheit mal drüber 🙂
        • Scrounger
          Scrounger Developer @Kuddel last edited by
          @Kuddel sagte in Test Adapter enigma2 v1.2.x:
          Probleme:
          Hier mal mein Skript für die Aufnahmen:
          // import
          let enigma2AdapterRecordListId = 'enigma2.0.enigma2.MOVIE_LIST';
          on({ id: enigma2AdapterRecordListId }, formatList);
              try {
                  let list = JSON.parse(getState(enigma2AdapterRecordListId).val);
                  let myList = [];
                          let recordTime = moment(listItem.recordingtime * 1000);
                          let recordDateFormatted = `${recordTime.format('ddd')} ${recordTime.format('DD.MM')}`;
                          let recordTimeFormatted = `${recordTime.format('LT')}`
                          if (moment().isSame(recordTime, 'day')) {
                              recordDateFormatted = `Heute ${recordTime.format('DD.MM')}`;
                          } else if (moment().add(-1, 'day').isSame(recordTime, 'day')) {
                              recordDateFormatted = `Gestern ${recordTime.format('DD.MM')}`;
                          let rawtitle = listItem.eventname;
                              if (subtitle === undefined) {
                                  subtitle = '';
                          myList.push(
                                  channelImage: `/vis.0/myImages/picons/${listItem.serviceRefName}.png`,
                                  title: title,
                                  lenght: listItem.length + ' min, ' + listItem.filesize_readable,
                                  recordTime: listItem.recordingtime,
                                  subtitle: subtitle,
                      myDevices.Netzwerk.Devices.VuPlus.RecordList.setState(JSON.stringify(myList), true);
              } catch (err) {
                  console.error(`[formatList] error: ${err.message}`);
                  console.error(`[formatList] stack: ${err.stack}`);
          formatList();
          Anzeige von Datum und Uhrzeit Zeile 24-28, muss über das skript formatiert werden:
          damit die Sortierung funktioniert, brauchst du die raw daten als timestamp ohne irgendeine formatuierung und musst dafür eine eigene property im Objekt verwenden:
                          myList.push(
                                  title: title,
                                  recordTime: listItem.recordingtime,  // timestamp der Aufnahme -> darüber kann sortiert werden
                                  subtitle: subtitle,
          Dann musst beim Widget für die Spalte mit deinem formatierten Datum 29.12.2019, 8:50h die Property recordTime als Objektname zum Sortieren eintragen:
            @Scrounger vielen Dank für die Hilfe,
            Jetzt sieht es so aus und funktioniert:
            Spalte 7 (recordTime) ist ausgeblendet und wird in Spalte 4 (Datum) zum sortieren verwendet
            • Matten Matten
              Matten Matten last edited by
              Moin!
              Falls jemand Interesse hat, hab soeben ein Nodered Subflow für Enigma2 veröffentlicht.
              Bild Text https://github.com/Matten-Matten/node-red-enigma2-flow
              Matten Matten
                JanekHinderks @Kuddel last edited by
                @Kuddel Kannst du mir eine fertige View zur Verfügung stellen? 🙂
                Vielen Dank im Voraus.
                Gruß Janek 🙂
                  Kuddel @JanekHinderks last edited by
                  @JanekHinderks nur die Liste der Aufnahmen ?
                    @Kuddel Ich suche eigentlich eine View, wo man z.b. programme / Lautstärke etc. schalten kann.
                    Parallel dazu halt etwas für Aufnahmen 🙂
                    Viell. hast du ja was für mich. Du könntest mir auch erstmal Beispielbilder von deiner View schicken. Das wäre echt cool !
                    Danke schonmal 🙂
                      @JanekHinderks
                      Hier ist meine VIS als Export
                      https://forum.iobroker.net/topic/30497/vorstellung-meine-dritte-vis/2?page=1
                      • Matten Matten
                        Hey all,
                        Neue Version
                        Bild Text
                        NPM version npm i iobroker.enigma2
                        Bild Text https://github.com/Matten-Matten/ioBroker.enigma2.git
                        Changelog
                        1.3.1 (2020-08-20)
                        • (Matten-Matten) correction in .enigma2.Timer_is_set & .enigma2.isRecording login handling
                        Matten Matten
                        ? 1 Reply Last reply Reply Quote 2
                          A Former User @Matten Matten last edited by
                          @Matten-Matten Hi, danke für den Adapter, echt geil!
                          Leider läuft bei mir die Version 1.3.1 nicht, bzw. lässt sich nicht installieren.
                          Vorher hatte ich die ganze Zeit die 1.2.9 am laufen, die 1.3.0 ist mir irgendwie entgangen...
                          Issue auf Git hab ich schon mit Logfiles etc gemacht. 🙂
                          Matten Matten 2 Replies Last reply Reply Quote 0
                          • Matten Matten
                            Matten Matten @Guest last edited by Homoran
                            @ilovegym sagte in Test Adapter enigma2 v1.2.x:
                            bitte noch einmal versuchen, oder von npm installieren.
                            EDIT: kurze Rückmeldung geben ob es jetzt funktioniert!
                            Matten Matten
                            • Matten Matten
                              problem behoben, ich konnte jetzt auch von git installieren.
                                @Matten-Matten Hi, super, du warst ja schneller als der Schall.. konnte eben erst wieder installieren, die Installation vom Admin aus lief einwandfrei durch, instanz erzeugt, einwandfrei, konfiguriert, läuft!
                                Danke! Top!
                                Matten Matten 1 Reply Last reply Reply Quote 0
                                • Matten Matten
                                  Hey all,
                                  Ich habe die Arbeit am Adapter weitestgehend eingestellt.
                                  Projekt Übernehmer gesucht!
                                  Bild Text
                                  Bei Interesse bitte auf das ISSUE antworten -> #44 <-
                                  Matten Matten
                                  dslraser E Xsev Glasfaser 4 Replies Last reply Reply Quote 2
                                  • dslraser
                                    dslraser Forum Testing Most Active @Matten Matten last edited by
                                    @Matten-Matten
                                    @apollon77
                                    kann das dann nicht auch ein Community Adapter werden ?
                                    apollon77 1 Reply Last reply Reply Quote 3
                                      el_malto @Matten Matten last edited by
                                      @Matten-Matten sehr schade. Leider habe ich keine Programmierkenntnisse.
                                      Trotzdem einen RIESEN Dank für diesen Adapter und die Zeit die du da rein gesteckt hast.👏 👏 👏
                                      • dslraser
                                        dslraser Forum Testing Most Active @el_malto last edited by
                                        @el_malto sagte in Test Adapter enigma2 v1.2.x:
                                        Das unterschreibe ich genau so.👍
                                        (Ich habe zwei Instanzen im Einsatz, die schon lange problemlos laufen)
                                        • Xsev
                                          Xsev @Matten Matten last edited by
                                          @Matten-Matten
                                          Danke für den Adapter, lange problemlos im Einsatz. 👍
                                          Hoffe es findet sich jemand.
                                          • Glasfaser
                                            Glasfaser @Matten Matten last edited by
                                            @Matten-Matten sagte in Test Adapter enigma2 v1.2.x:
                                            Großen Dank an dich , für deine Zeit und Pflege des Adapter , die du dort reingesteckt hast .
                                            Der Adapter funktioniert immer problemlos , wie ein Uhrwerk 👍
                                            adapter enigma2
                                            71
                                            640
                                            141465
